Results 1 to 10 of 20
Thread: 2012 Audi A6 3.0TDI (C7) TCM No Communication
    Aug 2018
    Exclamation 2012 Audi A6 3.0TDI (C7) TCM No Communication
    Hi, I am looking for some advice on my current situation
    As you can probably tell from the title, it's a worrying time and im looking for some reassurance from all you knowledgeable people out there
    I will start by giving a background story to my woes;
    -One day my car decided to throw up a 'Gearbox malfunction: You can continue to drive" (or similiar)
    -It did this over and over, with about 2 minutes between each warning (not a set time)
    -I then realised that the lights on the gear indicator were going on an off, eg. When driving, the D would illuminate as normal but then the light would go out. At this point, the car would give the gearbox malfunction message.
    I must add i was around 200 miles from home on this day..
    -I just kept driving and then out of nowhere, a red Gearbox malfunction warning came up and told me to park up immediately and place in P. Naturally, i continued driving due to being over 100 miles from my house
    -20 miles or so later.. *CLUNK* and the gearbox seemed to momentarily go into neutral and back into gear... followed by Engine Management, TPMS, ABS, Steering fault and Coil light.
    -At this point, the car was stuttering and didn't feel or sound healthy. I pulled up to a stop and the engine was racing to around 1200rpm and wanting to pull away. I stopped the car, let it rest and started it again.
    -I only had the engine management light left on and i managed to drive 80 Miles home with no further issues, gearbox changing perfectly with no untoward noises etc.
    I then took it on a 10 miles drive later that evening to test whether i would make it to work the following day.
    -Doing mixed driving for the first 7-8 miles, the car drove as it should with no sign that anything had gone wrong.
    -I then decided to drive it harder and that is when the gearbox was playing up - Foot to the floor, It seemed to have no power then out of nowhere all the power spiked at once.. then it lost the power... then spiked.. etc
    Parked up and alternate route to work organised.
    I drove it to Audi the following evening without any issues at all (5 miles or so). Booked it in to Audi and only today did they manage to get it in to the workshop.
    I received a phonecall at 4pm telling me that they couldn't get the car to communicate with their system, but they would require 5 more hours of testing - £570 please
    After swiftly refusing to pay that, I told them that i would collect the car after i finished work and would have a rethink about my options.
    I arrive at Audi and i am handed my keys - no fees to be paid. I'm told that my car awaits me outside..
    Outside i go, get in the car and it is in drive... Strange.
    Ignition on, into park and push start... "Please engage N or P to start engine". NOT GOOD.
    This is where i am left... there are no lights showing on the PRNDS gear indicator and the car thinks its out of park, hence i cant start or drive the car.
    I wen't back to audi tonight (they had closed by this time) with my VCDS cable and laptop and have since scanned the car.
    It would be much appreciated if you guys can have a look at the scan and tell me the likely cause of this issue!
    Most modules do seem to be relating back to the lack of communication with the TCM or a fault in the powertrain bus.
    Is there anything that Audi could have done when carrying out the basic diagnostic session that would cause there to be no communication with the TCM at all. Bearing in mind that i did drive the car into Audi, yet now i can't drive it away after a basic diagnostic session..
    Thanks in advance,
    Greg
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62
              72
    VIN: WAUZZZ4G6CN033226   Mileage: 128836km-80054miles
    02-Auto Trans -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0004
       Revision: 53H37---
       Coding: 0A254012052601020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 2616FFDE786357172BB-8072
    4718 - No Communication with Transmission Control Module
              U0101 00 [039] - -
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:35:04
                        Coolant temperature: 23 °C
                        Intake air temperature: 18 °C
                        Voltage terminal 30: 12.060 V
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        selected gear-Bits 0-7: 9
    Address 02: Auto Trans
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 27A68701E465E180CB00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 34321596BEBF3587A5F-8060
    0058 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_01_Timeout]
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:29:22
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BB
                        Uz: 9C
    0060 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_03_Timeout]
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:29:22
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: 9C
    0061 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_04_Timeout]
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:29:22
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C8
                        Uz: 9C
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Ldm_ApbFailureState]
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:29:22
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 01
                        Uz: 9C
       Part No SW: 4H0 907 064 BG    HW: 4H0 907 064 BG
       Component: BCM2 2.0      H31 0330
       Coding: 01B83006000000000000
       VCID: 6FB8DAFA9799565F98D-803A
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000136281016
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:29:27
       Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
       Component: KLIMA 2 ZONEN H10 0056
       Serial number: 21071100040895
       Coding: 3621000820
       ASAM Dataset: EV_AirCondiBasisUDS 002033
       VCID: 2310E6CA0B51A23F4C5-8076
    0276 - Engine Off Timer Performance
              P150A 00 [009] - -
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:29:29
                        Voltage terminal 30: 12.21 V
       Part No SW: 4H0 907 063 BA    HW: 4H0 907 063 A
       Component: BCM1 2.0      H12 0100
       Revision: 12012002    Serial number: 00000000957887
       Coding: 690000118034A7E00105008000005F5F4F9DC20827080101000004402000
       VCID: 688AB1E6B2778167D97-803C
       Component: WWS57X 110627  H35 0051
       Serial number:         110703235627
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11563052
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
       Component: E1 - LDS  H07 0044
       Serial number: 08 07 2011  00001002
       Component: Humidity_Sens  H02 0002
       Serial number: 81088BB5000000000001
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:32:00
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901120000244
       Coding: 080305
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3B203EAA93E1FAFF645-806E
    12658704 - Databus
              [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
    12648720 - Databus
              [Getriebesteuergerät - Getriebe_03 - kein Signal/keine Kommunikation]
                        Reset counter: 189
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
    12648448 - Databus
              [Motorsteuergerät - Motor_K_02 - kein Signal/keine Kommunikation]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG003CAM%
       Coding: 30323436313330303537554A305234473053
       VCID: 36362F9EA8C327979BB-8062
       Serial number: 3575HRB405R0ISD66HSC
       Serial number: 3585HRB405V0ISD6705L
       Serial number: 3515JRB40570LCOQI1GX
       Serial number: 3525JRB40630JE3GG8VK
       Serial number: 3554VRB404P0JL5IIGFG
       Serial number: 3564VRB404P0JL5I48I+
    9 Faults Found:
    1048576 - Databus
              [CAN: 0x5F0 Dimmung_01 Timeout]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 07:57:35
    1048832 - Databus
              [CAN: 0x100 ESP_01 Timeout]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 07:57:35
    1049088 - Databus
              [CAN: 0x101 ESP_02 Timeout]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 07:57:35
    1049344 - Databus
              [CAN: 0x103 ESP_03 Timeout]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 07:57:35
    1049600 - Databus
              [CAN: 0x084 ESP_06 Timeout]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 07:57:35
    1049856 - Databus
              [CAN: 0x39C Gateway_05 Timeout]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 07:57:35
    1050112 - Databus
              [CAN: 0x086 LWI_01 Timeout]
                        Reset counter: 229
    1051136 - Databus
              U1121 00 [136] - Missing Message
              [CAN: 0x6B4 VIN_01 Timeout]
                        Reset counter: 229
    12583168 - Powertrain Databus
              U0001 00 [008] - Unspecified Malfunction
              [High Speed CAN Communication Bus defect]
       Revision: 00000000    Serial number: 20110722000552
       Coding: 000034
       VCID: 303A19864A2709A7C17-8064
       Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
       Component: E221 - MFL  H07 0009
    01312 - Powertrain Data Bus
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
    02085 - Incorrect Control Module Installed
                000 -  -  - Intermittent
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
                        Voltage: 14.60 V
                        Hex Value: 0x0000
                        Steering Angle: -1.88°
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
                        Fault Status: 00101110
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:20:34
       Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
       Component: TDieGb        H71 0375
       Revision: 26181114    Serial number: 658230711592056
       Coding: 23A7080003012600010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 43D0464AEB11823F2C5-8016
    16776962 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Airbag_01 keine Kommunikation]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:37
    16776967 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [EPB_02 keine Kommunikation]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:37
    16776971 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Motor_03 keine Kommunikation]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:37
       Part No SW: 4G0 907 468 D    HW: 4G0 907 468
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000196832
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 313C1C8241AD00AFCE9-8064
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650991491
       Voltage stabilizer:
       Serial number: 11202000907011200181
    4226 - No Communication with Transmission Control Module
              U0101 00 [009] - -
                        Reset counter: 189
                        Mileage: 128836 km
                        Date: 2018.08.13
                        Time: 00:36:15
                        Voltage terminal 30: 12.0 V
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 27 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200CUYW0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6B80CEEAA301AA7FB45-803E
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204001620002080002
       VCID: 42DE434EF48B8B37273-8016
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0017120273
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323E138E44AB3BB7B73-8066
    3158274 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Ausfall Botschaft "PDU_Motor_03"]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
                        valid
    3158276 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Ausfall Botschaft "PDU_LWI_01"]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
                        valid
    4205828 - Steering angle sensor
              B1168 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:04:54
                        valid
    4208000 - Steering Angle Sensor
              B1168 F1 [008] - Synchronization Failed
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:38
                        valid
              [Lenkungsendanschläge nicht angelernt]
                        Fault Frequency: 57
                        Reset counter: 189
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:04:53
                        valid
       Revision: 00002001    Serial number: 0154356756
       Coding: 011B062200B9040083200804000100000000000000000000000000000000
    6 Faults Found:
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:40
                        Reset counter: 189
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:40
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:40
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:40
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:40
                        Fault Frequency: 30
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:20:46
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41DC4C42F18D902F3E9-8014
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:39
       Revision: --------    Serial number: 00000000111337
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0E0BEE6C7B73770F3-807E
    7 Faults Found:
    333568 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_TSK_05_MESSAGE_TIMEOUT]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.08
                        Time: 15:56:45
                        Voltage terminal 30: 13.3 V
                        Internal Fault ID: 49
                        Vehicle speed: 6 km/h
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
    13644288 - Powertrain Databus
              U0002 00 [008] - No Communications
              [FC_CAN_GLOBAL_TIMEOUT]
                        Reset counter: 229
                        Voltage terminal 30: 11.0 V
                        Internal Fault ID: 58
                        Vehicle speed: 510 km/h
                        Terminal 15 status: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: Emergency running mode
    13641472 - Powertrain Databus
              [FC_CAN_BUSOFF]
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 09:27:12
                        Voltage terminal 30: 11.8 V
                        Internal Fault ID: 59
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    329728 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [FC_GETRIEBE_03_MESSAGE_TIMEOUT]
                        Reset counter: 189
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 17:48:35
                        Voltage terminal 30: 11.6 V
                        Internal Fault ID: 94
                        Function light in parking brake button: On
                        Red operating lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
    329984 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [FC_GETRIEBE_04_MESSAGE_TIMEOUT]
                        Reset counter: 189
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 17:48:35
                        Internal Fault ID: 95
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    397568 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
              [FC_GETRIEBE_03_MESSAGE_COUNTER]
                        Fault Frequency: 136
                        Reset counter: 229
                        Mileage: 128836 km
                        Date: 2018.08.06
                        Time: 17:48:13
                        Voltage terminal 30: 14.6 V
                        Internal Fault ID: 118
                        Vehicle speed: 54 km/h
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: Dynamic
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                        Reset counter: 229
                        Voltage terminal 30: 14.7 V
                        Internal Fault ID: 188
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Part No SW: 4G0 035 056 C    HW: 4G0 035 056
       Component: Radio U STD   H52 0079
       Revision: AB001007    Serial number: 051GO0B7525212
       Coding: 010003020100000001
       VCID: 211CECC211CDB02F5E9-8074
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:45
                        Bin. Bits: 00000000 00001000
       Part No SW: 4G0 035 670 C    HW: 4G0 035 670
       Component: H-BNT-EU      H47 0406
       Revision: --------    Serial number: 428F/0B7517482
       Coding: 050101000003E1ED05008B3E00000003000001000000000000
       VCID: 2310E6CA0BD1A23F4C5-8076
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB13017R9I
       Subsystem 3 - Part No SW: 4G2 919 610 A    HW: 4G2 919 610 A
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KGL0001G
       Component: CD-Database  3371
                        Reset counter: 229
                        Mileage: 128837 km
                        Date: 2018.08.13
                        Time: 10:03:49
                        Bin. Bits: 00010000 00000000
                        Bin. Bits: 00000000 00010000
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 44D24556EE9F850715F-8010
       Component: TSG HR        H04 0212
    End----------(Elapsed Time: 01:52, VBatt start/end: 12.1V/12.1V)-----------
    What kind of transmission is in this car?
    Do you have a scan from before you took it to the dealer?
    Check power, ground, and CAN bus connections to TCU first.
  3. Likes Fredrick Awuor liked this post
    Aug 2018
    Thanks for the quick reply Uwe!
    I forgot to mention that it is the automatic s-tronic gearbox and it’s the 245ps Quattro model.
    Are these TCM’s prone to failing?
    Is there a full wiring diagram available for this car?
    Edit: I’m at work just now, but will post the scan before it went to Audi tonight
    Quote Originally Posted by hutchy7 View Post
    Certainly. See here.
    Aug 2018
    Thanks again for that, I had a mad hour downloading everything that I could.. So will attack this tomorrow.
    Here are the 2 other scans i have of the car.. one when i returned from my 200 miles journey, the second after a short journey that same day.
    Thanks for the help thus far, its greatly appreciated
    Sunday,05,August,2018,19:49:43:17826
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WAUZZZ4G6CN033226   License Plate:
    Mileage: 128800km-80032mi   Repair Order:
              72
    VIN: WAUZZZ4G6CN033226   Mileage: 128800km-80032miles
       Revision: 53H37---
    7 Faults Found:
              U1113 00 [040] - -
                        Mileage: 128673 km
                        Date: 2018.08.05
                        Time: 17:16:42
                        Engine speed: 1818.00 /min
                        Normed load value: 99.6 %
                        Vehicle speed: 119 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 14.140 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 40
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 15
                        Cruise Control System: specified speed: 128.80 km/h
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
              U1113 00 [040] - -
                        Mileage: 128673 km
                        Date: 2018.08.05
                        Time: 17:16:42
                        Engine speed: 1817.50 /min
                        Voltage terminal 30: 14.120 V
    18660 - Start interruption due to insufficient engine speed
              P151D 00 [032] - -
    2937 - Please Check Fault Codes in Transmission Control Module
              U1026 00 [032] - -
              [Transmission control moduleplease read DTC]
    4367 - Powertrain Databus
              U0001 00 [168] - Unspecified Malfunction
                        Mileage: 128675 km
                        Date: 2018.08.05
                        Time: 17:17:46
                        Engine speed: 1827.50 /min
                        Normed load value: 71.8 %
                        Coolant temperature: 88 °C
                        Intake air temperature: 24 °C
                        Limitation: accelerator pedal: 198.3 Nm
                        CAN status - engine control module-Bits 0-7: 128
                        selected gear-Bits 0-7: 7
    4710 - No Communications with Airbag Control Module
              U0151 00 [032] - -
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:20
                        Engine speed: 864.50 /min
                        Normed load value: 15.7 %
                        Vehicle speed: 21 km/h
                        Coolant temperature: 89 °C
                        Intake air temperature: 28 °C
                        Voltage terminal 30: 14.080 V
                        Cruise Control System (CCS): status-Bits 0-7: 45
                        selected gear-Bits 0-7: 3
    4720 - Body Control Module (Central Electric 2)
              U0141 00 [032] - No Communications
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:20
                        Engine speed: 1012.50 /min
                        Vehicle speed: 23 km/h
                        Voltage terminal 30: 14.020 V
    Readiness: 1 1 0 0 0
       Part No SW: 4G2 927 156 M    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0001
       Revision: --H03---    Serial number: 0000001462
       Coding: 000001
       Shop #: WSC 04742 780 00200
       ASAM Dataset: EV_TCMDL501021 A03002
       ROD: EV_TCMDL501021_A03.rod
       VCID: 382A21A6A2D7D1E7897-806C
    10 Faults Found:
    7965 - Signal Line for Gear Display on Selector Lever
              P1893 00 [040] - Electrical Malfunction
                        Fault Frequency: 101
                        Reset counter: 40
                        Mileage: 128428 km
                        Date: 2018.08.05
                        Time: 13:16:41
                        Engine speed: 1120 /min
                        Transmission input speed: 1120 /min
                        Transmission output speed: 473 /min
                        Engine torque: 56 Nm
                        Transmission fluid temperature: 73 °C
                        Accelerator position: 12.8 %
                        Clutch status: Kupplung 2 kann Moment übertragen
    7966 - Signal Line for Gear Display on Selector Lever
              P1894 00 [040] - Implausible Signal
                        Fault Frequency: 148
                        Reset counter: 40
                        Mileage: 128428 km
                        Date: 2018.08.05
                        Time: 13:16:32
                        Engine speed: 1106 /min
                        Transmission input speed: 1106 /min
                        Transmission output speed: 467 /min
                        Engine torque: 140 Nm
                        Accelerator position: 21.2 %
    7967 - Selector Lever Position Monitoring
              P1892 00 [032] - Malfunction
                        Fault Frequency: 52
                        Reset counter: 40
                        Mileage: 128456 km
                        Date: 2018.08.05
                        Time: 13:51:05
                        Engine speed: 1424 /min
                        Transmission input speed: 1424 /min
                        Transmission output speed: 753 /min
                        Engine torque: 48 Nm
                        Transmission fluid temperature: 90 °C
                        Accelerator position: 12.4 %
                        Clutch status: Kupplung 1 kann Moment übertragen
    7969 - Signal Line for Tiptronic
              P1890 00 [032] - Electrical Malfunction
                        Reset counter: 40
                        Mileage: 128464 km
                        Date: 2018.08.05
                        Time: 14:02:11
                        Engine speed: 788 /min
                        Transmission input speed: 788 /min
                        Transmission output speed: 0 /min
                        Engine torque: -8 Nm
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
                        Voltage terminal 30: 11.700 V
                        W006_Vwh_PrzWh_Whs1-Data: 58.15 %
                        W007_Vwh_PrzWh_Whs2-Data: 58.10 %
                        Selector lever maximum pulse width High-Data: 4.004 ms
                        Selector lever minimum pulse width High-Data: 3.995 ms
                        Selector lever maximum pulse width Low-Data: 50.675 ms
                        Selector lever minimum pulse width Low-Data: 3.800 ms
    18147 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [040] - -
                        Fault Frequency: 19
                        Reset counter: 40
                        Mileage: 128673 km
                        Date: 2018.08.05
                        Time: 17:16:43
                        Engine speed: 1812 /min
                        Transmission input speed: 1812 /min
                        Transmission output speed: 963 /min
                        Engine torque: 308 Nm
                        Accelerator position: 43.6 %
                        Voltage terminal 30: 14.100 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.921 V
    8001 - No Communication with Diagnostic Gateway
              U0146 00 [032] - -
                        Reset counter: 40
                        Mileage: 128726 km
                        Date: 2018.08.05
                        Time: 18:07:33
                        Engine speed: 1328 /min
                        Transmission input speed: 1328 /min
                        Transmission output speed: 697 /min
                        Engine torque: 88 Nm
                        Transmission fluid temperature: 92 °C
                        Accelerator position: 16.8 %
                        Voltage terminal 30: 14.300 V
    17591 - Shift Fork 4
              P2850 00 [096] - Uncommanded Movement
                        Fault Frequency: 0
                        Reset counter: 0
                        Time: 00:00:00
                        Engine speed: 0 /min
                        Transmission input speed: 0 /min
                        Engine torque: -100 Nm
                        Transmission fluid temperature: -40 °C
                        Unlearning counter according OBD: 0
    8008 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [040] - -
                        Reset counter: 40
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        Engine speed: 746 /min
                        Transmission input speed: 746 /min
                        Engine torque: -16 Nm
                        Voltage terminal 30: 14.200 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.920 V
    8015 - Steering Column Control Module
              U0212 00 [032] - No Communications
                        Reset counter: 40
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:19
                        Engine speed: 1075 /min
                        Transmission input speed: 1075 /min
                        Transmission output speed: 198 /min
                        Engine torque: -40 Nm
                        Voltage terminal 30: 14.000 V
    8448 - Implausible Data Received from Engine Control Module
              U0401 00 [096] - -
                        Reset counter: 40
                        Mileage: 128676 km
                        Date: 2018.08.05
                        Time: 17:18:48
                        Engine speed: 1646 /min
                        Transmission input speed: 1646 /min
                        Transmission output speed: 542 /min
                        Engine torque: 16 Nm
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
    9 Faults Found:
    0067 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_LWI_01_Timeout]
                        Reset counter: 228
                        Mileage: 128673 km
                        Date: 2018.08.05
                        Time: 17:16:43
                        VzRef: 77
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D8
                        Uz: B8
    0069 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_Motor_01_Timeout]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E0
                        Uz: B6
    0071 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_Motor_02_Timeout]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: ED
                        Uz: B6
    0073 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_Motor_03_Timeout]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F2
                        Uz: B6
    0075 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_Motor_10_Timeout]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F5
                        Uz: B6
    0091 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_TSK_05_Timeout]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 09
                        Uz: B6
              U1113 00 [008] - -
                        Reset counter: 228
                        Mileage: 128658 km
                        Date: 2018.08.05
                        Time: 17:03:23
                        VzRef: 2F
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 01
                        Uz: BA
    0557 - Powertrain Databus
              [NET_BusOffNetwork0]
                        Reset counter: 228
                        Mileage: 128730 km
                        Date: 2018.08.05
                        Time: 18:10:27
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 62
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: 6C
                        Uz: B9
    0787 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
              [SCL_MO_Motormomente_Invalid]
                        Reset counter: 228
                        Mileage: 128676 km
                        Date: 2018.08.05
                        Time: 17:18:47
                        VzRef: 44
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E3
                        Uz: B8
       Coding: 3621000820
    0247 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Motorsteuergerät: Fehlerspeicher auslesen]
                        Reset counter: 228
                        Mileage: 128675 km
                        Date: 2018.08.05
                        Time: 17:17:47
                        Outside air temperature: 20.5 °C
                        Engine speed: 1813 /min
                        Vehicle speed: 119.00 km/h
       Coding: 0045F7
       Coding: 02512B
                        Reset counter: 228
                        Mileage: 128729 km
                        Date: 2018.08.05
                        Time: 18:09:00
       Coding: 080305
       Coding: 000034
       ROD: EV_RBD4K.rod
              U1111 00 [008] - -
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
       Coding: 00CD077D00
       Voltage stabilizer:
    0264 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
              U0009 00 [008] - -
              [Datenbus Antrieb Eindraht]
                        Fault Frequency: 238
                        Reset counter: 228
                        Mileage: 128414 km
                        Date: 2018.08.05
                        Time: 10:53:50
                        Voltage terminal 30: 14.5 V
                        Voltage terminal 15: 14.5 V
                        Control Module temperature: 34 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
              U1111 00 [008] - -
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:37
                        valid
    7 Faults Found:
    721152 - Brake pad replacement mode active
              C1011 00 [000] -  -
              U1111 00 [008] - -
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        Voltage terminal 30: 14.2 V
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    334080 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_02_MESSAGE_TIMEOUT]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        Voltage terminal 30: 14.3 V
                        Internal Fault ID: 51
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331264 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_01_MESSAGE_TIMEOUT]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        Internal Fault ID: 99
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331520 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_03_MESSAGE_TIMEOUT]
                        Reset counter: 228
                        Mileage: 128678 km
                        Date: 2018.08.05
                        Time: 17:22:36
                        Internal Fault ID: 100
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1112 00 [008] - -
                        Fault Frequency: 75
                        Reset counter: 228
                        Mileage: 128658 km
                        Date: 2018.08.05
                        Time: 17:03:22
                        Vehicle speed: 48 km/h
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
              U1113 00 [008] - -
                        Reset counter: 228
                        Mileage: 128676 km
                        Date: 2018.08.05
                        Time: 17:18:47
                        Voltage terminal 30: 14.4 V
                        Vehicle speed: 68 km/h
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    End----------(Elapsed Time: 01:53, VBatt start/end: 12.3V/12.3V)-----------
    Address 01: DTCs cleared
    Sunday,05,August,2018,22:03:20:17826
              72
       Revision: 53H37---
              U1113 00 [036] - -
                        Mileage: 128830 km
                        Date: 2018.08.05
                        Time: 21:52:21
                        Engine speed: 1309.50 /min
                        Normed load value: 28.6 %
                        Vehicle speed: 53 km/h
                        Coolant temperature: 90 °C
                        Intake air temperature: 39 °C
                        Cruise control switch-off: reversible-Bits 0-7: 255
              U1113 00 [036] - -
                        Mileage: 128830 km
                        Date: 2018.08.05
                        Time: 21:52:21
                        Engine speed: 1307.50 /min
                        Voltage terminal 30: 14.160 V
       Coding: 000001
              U0100 00 [036] - -
                        Fault Frequency: 19
                        Reset counter: 40
                        Mileage: 128830 km
                        Date: 2018.08.05
                        Time: 21:52:04
                        Engine speed: 1928 /min
                        Transmission input speed: 1928 /min
                        Transmission output speed: 220 /min
                        Engine torque: 292 Nm
                        Transmission fluid temperature: 93 °C
                        Accelerator position: 62.8 %
                        Voltage terminal 30: 13.900 V
    7999 - No Communication with Instrument Cluster
              U0155 00 [036] - -
                        Reset counter: 40
                        Mileage: 128829 km
                        Date: 2018.08.05
                        Time: 21:51:41
                        Engine speed: 2754 /min
                        Transmission input speed: 2754 /min
                        Transmission output speed: 498 /min
                        Engine torque: 296 Nm
                        Accelerator position: 100.0 %
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
              U0146 00 [036] - -
                        Reset counter: 40
                        Mileage: 128830 km
                        Date: 2018.08.05
                        Time: 21:52:15
                        Engine speed: 1356 /min
                        Transmission input speed: 1356 /min
                        Transmission output speed: 426 /min
                        Engine torque: 104 Nm
                        Accelerator position: 18.4 %
    8013 - Body Control Module (Central Electric)
              U0140 00 [036] - No Communications
                        Reset counter: 40
                        Mileage: 128831 km
                        Date: 2018.08.05
                        Time: 21:53:08
                        Engine speed: 1266 /min
                        Transmission input speed: 1266 /min
                        Transmission output speed: 317 /min
                        Engine torque: 24 Nm
                        Accelerator position: 9.2 %
              U0212 00 [036] - No Communications
                        Reset counter: 40
                        Mileage: 128831 km
                        Date: 2018.08.05
                        Time: 21:55:31
                        Engine speed: 749 /min
                        Transmission input speed: 749 /min
                        Engine torque: -12 Nm
              U1111 00 [008] - -
                        Reset counter: 228
                        Mileage: 128830 km
                        Date: 2018.08.05
                        Time: 21:52:21
                        VzRef: 35
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D8
                        Uz: B7
              U1113 00 [008] - -
                        Reset counter: 228
                        Mileage: 128826 km
                        Date: 2018.08.05
                        Time: 21:47:57
                        VzRef: 2A
                        Bit Info 1: 80
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 01
                        Uz: B6
       Coding: 3621000820
       Coding: 0045F7
       Coding: 02512B
       Coding: 080305
       Coding: 000034
       Coding: 00CD077D00
       Voltage stabilizer:
              U0009 00 [008] - -
                        Fault Frequency: 99
                        Reset counter: 228
                        Mileage: 128801 km
                        Date: 2018.08.05
                        Time: 19:59:43
                        Voltage terminal 30: 13.8 V
                        Voltage terminal 15: 13.8 V
                        Control Module temperature: 40 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
              U1112 00 [008] - -
                        Reset counter: 228
                        Mileage: 128811 km
                        Date: 2018.08.05
                        Time: 21:34:46
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    End----------(Elapsed Time: 01:52, VBatt start/end: 12.5V/12.3V)-----------
    Sunday,05,August,2018,22:04:20:17826
                    Address 19: CAN Gateway       Labels: None
    Control Module Part Number: 4G0 907 468 D    HW: 4G0 907 468
      Component and/or Version: J533--Gateway H08 0213
               Software Coding: 00CD077D00
                Work Shop Code: WSC 02391 785 00200
                  ASAM Dataset: EV_GatewUDS 001025 (AU57)
              U0009 00 [009] - -
                        Reset counter: 188
                        Mileage: 128831 km
                        Date: 2018.08.05
                        Time: 22:02:51
                        Control Module temperature: 44 °C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 19: DTCs cleared
    OK, so that's a 7-speed 0B5 DSG and the TCM was still alive during those scans.
    I think the simplest explanation here is that the TCM/Mechatronic unit has failed.
    From the Wiki page about it:
    Special Notes
    Numerous Audi TPIs/TSBs exist for 0B5 transmission problems. Although a majority are flash update related some are hardware related ("printed circuits" internal wiring harness) instead. As of October, 2015 the following list may be helpful but the Official Factory Repair Information should be used to confirm if they apply to the vehicle in question:
    NAR (North American) Market:
    - TPI 2027363
    RoW (Rest of World) Market:
    - 2022497
    - 2027286
    - 2027291
    Aug 2018
    Hi, thanks for the response!
    Currently working on my car and I found that fuse 1 in fuse holder A kept blowing which is for the automatic gearbox control unit J217
    I then unplugged the large connector that connects directly into the gearbox and it has burnt/melted itself partially.. I cleaned it out with an air line and the car has started and the P light comes on every so often!
    My question; what lies behind this connector? Can I replace this itself?
    Thanks,
    Greg
  9. #8
    Aug 2018
  10. Likes Boki Ar, jyoung8607 liked this post
  11. #9
    United States
    Ouch! I hope I'm off-track here but we receive a lot of feedback from 4G and 4H vehicles that have coolant ingress into Engine controllers and the related wiring harnesses. We have had a few (non DSG) reports of TCM and related harness failure as well due to coolant. Handful of Wiki pages I can think of include:
    http://wiki.ross-tech.com/wiki/index.php/P1888
    http://wiki.ross-tech.com/wiki/index.php/P2755
    http://wiki.ross-tech.com/wiki/index.php/P2753
    With any luck that's just gear lube (which cleans up easily) but make sure it isn't coolant because that corrodes harnesses.
  12. Likes Boki Ar, jyoung8607 liked this post
  13. #10
    Aug 2018
    I hope you’re off track too..
    I will have a look at the coolant areas and see if there are any leaks etc.
    I only bought the car in May, at the time I didn’t know about it’s last Service.. but it has a full service history with Audi, having had a gearbox oil change in January as well as another one in April due to a “leak”. Obviously there are greater issues here.
    Does anyone know a part number or where I can get another female connector/harness for this? I am hoping that the pins that are within the gearbox housing are still ok, even though there is a slight bit of melting and one of the female pins stuck on. I’ve also got my fingers crossed that it hasn’t damaged the TCM itself!
    I still have the lack of PRNDS lights for the most part and that will hopefully be due to one of the pins missing and the 2 cables shorting within the connector depending on how the connector is held/moved.
    Where would I have been without this forum, cheers
