I have got a problem after the battery has been unplugged and the +/- wire was put together, and the coding of the ABS modul was changed to 00000014, and it is not the right code.
We get a code from NETECH 0029986 but it did not resolve the problem with the ABS module, we have found another code on Ross-Tech WIKI 0013602, but i dont think it is the right code for this model, because it still have the failour.
The car is a 2006 VW Passat 3c5 2,0 TDI (140hp) Variant.
And I have made a full autoscan:
Anyone that can help me with the right coding for the ABS module or a hint to where to find it.
I have changed the ABS sensor on the left front wheel and the rear back wheel - but on the back whell i now got no signal.
And furthermore the ABS module switches on the ABS braking while driving.
And it is not possible to make
Basic Setting Sensor for Steering Angle (G85)
and
Steering Limit Stop setting.
Please reply with any suggestions what to do.
Mandag,13,August,2018,21:12:04:46660
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
VCDS version: NEZ 18.2.0.3 HEX-V2 CB: 0.4411.4
Dataversion: 20180301 DS287.0
www.vcds.dk
Firma: Thyren 60662259
Forhandlernr.: 204 12345 023456
Stelnummer: WVWZZZ3CZ6E152275 Indreg.nr.:
Kørestrækning: 234140km Reparationsordre: til rosstech
Modeltype: 3C (3C0)
Søgt på: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 69 72 7D
Stelnummer: WVWZZZ3CZ6E152275 Kørestrækning: 234140km
01-Motor -- Status: Ok 0000
03-ABS bremser -- Status: Fejlfunktion 0010
04-Styrevinkel -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Fejlfunktion 0010
10-Park.assist. -- Status: Kan ikke kontaktes 1100
15-Airbags -- Status: Fejlfunktion 0010
16-Ratelektronik -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Fejlfunktion 0010
25-Startspærre -- Status: Ok 0000
42-Dørelektr. V for -- Status: Ok 0000
44-Servostyring -- Status: Fejlfunktion 0010
46-Komfortelektronik -- Status: Ok 0000
52-Dørelektr. H for -- Status: Ok 0000
53-Parkeringsbremse -- Status: Fejlfunktion 0010
56-Radio -- Status: Ok 0000
62-Dørelektr. V bag -- Status: Ok 0000
69-Anhængertræk -- Status: Ok 0000
72-Dørelektr. H bag -- Status: Ok 0000
7D-Ekstravarmesystem -- Status: Ikke registreret 0011
Styreenhed 01: Motor Forklaringsfil: NEZ\03G-906-018-BKP.clb
Styreenhedsnr: SW: 03G 906 018 CD HW: 03G 906 018 CD
Komponent : R4 2.0l PPD1.5 G 9627
Revision: --H05--- Serienummer: VWZCZ000000000
Kodning : 0000072
Forhandler : WSC 00014 204 68283
VCID: 698F414C6572860FC56-803C
Ingen fejlkoder fundet.
Readiness: Ikke tilg.
Styreenhed 03: ABS bremser Forklaringsfil:. NEZ\3C0-614-095-C2.clb
Styreenhedsnr: SW: 3C0 614 095 P HW: 3C0 614 095 P
Komponent : ESP 440 C2 H015 0003
Revision: H015 Serienummer: 0658486980
Kodning : 0013602
Forhandler : WSC 12345 204 23456
VCID: 2F3BEF549B16283FDB2-807A
4 fejlkoder fundet:
00287 - Omdrejningsføler højre baghjul (G44)
004 - Intet signal/kommunikation - Periodisk
Fryseramme:
Fejl status : 00100100
Fejlprioritet: 1
Fejlhyppighed: 3
Nulstiltæller: 214
Kørestrækning: 234100 km
Tidsindikation: 0
Dato: 2000.00.00
Tid: 08:58:53
00290 - Omdrejningsføler venstre baghjul (G46)
008 - Urealistisk signal - Periodisk
Fryseramme:
Fejl status : 00101000
Fejlprioritet: 1
Fejlhyppighed: 3
Nulstiltæller: 214
Tidsindikation: 0
Dato: 2000.00.00
Tid: 08:58:55
00285 - Omdrejningsføler højre forhjul (G45)
Fryseramme:
Fejlprioritet: 1
Fejlhyppighed: 3
Nulstiltæller: 214
Tidsindikation: 0
Dato: 2000.00.00
Tid: 08:58:57
00778 - Ratvinkelsensor (G85)
005 - Manglende eller forkert grundindstilling/adaption
Fryseramme:
Fejlprioritet: 1
Fejlhyppighed: 3
Nulstiltæller: 214
Tidsindikation: 0
Dato: 2000.00.00
Tid: 08:58:57
Styreenhed 08: Klimaanlæg Forklaringsfil: NEZ\3C0-907-044.lbl
Styreenhedsnr: SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Komponent : ClimatronicPQ46 050 0404
Revision: 00050005 Serienummer: 00000000000000
Forhandler : WSC 00000 000 00000
VCID: 629D56609844D55704C-8036
Styreenhed 09: Centralelektrik Forklaringsfil:. NEZ\3C0-937-049-23-M.lbl
Styreenhedsnr: SW: 3C0 937 049 H HW: 3C0 937 049 H
Komponent : Bordnetz-SG H37 1301
Revision: 00H37000 Serienummer: 00000005216713
Kodning : E8888F0700041A00000A00000F000000000959435C0000
Forhandler : WSC 05311 000 00000
VCID: 2E05F2509C1C2137D04-807A
Undersystem 1 - Styreenhedsnr:: 3C1 955 119 Forklaringsfil: NEZ\1KX-955-119.CLB
Komponent : Wischer VW461 012 0503
Kodning : 00063445
Undersystem 2 - Styreenhedsnr:: 1K0 955 559 T Forklaringsfil: NEZ\1K0-955-559-AF.CLB
Komponent : RegenLichtSens 011 1110
Kodning : 00208933
2 fejlkoder fundet:
02395 - Positionslyspære: Højre (M3)
012 - Elektrisk fejl i strømkreds
Fryseramme:
Fejl status : 01101100
Fejlprioritet: 2
Fejlhyppighed: 1
Nulstiltæller: 175
Kørestrækning: 234093 km
Tidsindikation: 0
Fryseramme:
Til
Volt: 14.00 V
Til
Til
Fra
Fra
Fra
02092 - Aktivering sædevarme
009 - Afbrydelse/Kortslutning til stel
Fryseramme:
Fejl status : 01101001
Fejlprioritet: 5
Fejlhyppighed: 1
Nulstiltæller: 175
Tidsindikation: 0
Fryseramme:
Til
Volt: 13.95 V
Til
Til
Fra
Fra
Fra
Styreenhed 10: Park.assist.
Kan ikke kontaktes
Styreenhed 15: Airbags Forklaringsfil: NEZ\3C0-909-605.lbl
Styreenhedsnr: SW: 3C0 909 605 P HW: 3C0 909 605 P
Komponent : 03 AIRBAG VW8 033 2522
Revision: 13033000 Serienummer: 003CWPKHA4F9
Kodning : 0012339
VCID: 3333E324773E0CDFBFA-8066
Undersystem 1 - Serienummer: 6332MSME0D575B0E
Undersystem 2 - Serienummer: 6342MSME0D2E3E33
Undersystem 3 - Serienummer: 6351HTS61IK6T1I2
Undersystem 4 - Serienummer: 6361HTS61IKU0J13
Undersystem 5 - Serienummer: 00000000000000000
Undersystem 6 - Serienummer: 00000000000000000
1 fejl fundet:
01218 - Tændsats sideairbag i passagerside (N200)
001 - Over øvre grænseværdi - Fejllampe aktiveret
Styreenhed 16: Ratelektronik Forklaringsfil: NEZ\3C0-953-549-SW20.lbl
Styreenhedsnr: SW: 3C0 953 549 A HW: 3C0 953 549 A
Komponent : Lenksäulenmodul 005 0010
Revision: 00005000 Serienummer: 3C9953507C
Kodning : 0000014
VCID: 2A0DFE40A0F44D170CC-807E
Styreenhed 17: Instrument Forklaringsfil: NEZ\3C0-920-xxx-17.lbl
Styreenhedsnr: SW: 3C0 920 860 H HW: 3C0 920 860 H
Komponent : KOMBIINSTRUMENT VD1 4240
Revision: X0014000 Serienummer: 00000000000000
Kodning : 0006505
VCID: 270B0774B3E6707F132-8072
Styreenhed 19: CAN Gateway Forklaringsfil:. NEZ\3C0-907-530-V3.clb
Styreenhedsnr: SW: 3C0 907 530 N HW: 3C0 907 951
Komponent : J533 Gateway H14 0172
Revision: H14 Serienummer: 1091G113280033
Kodning : F9A07F4600020200F102
VCID: 2C01F858AA005327FE0-8078
3 fejlkoder fundet:
02830 - Styring af CAN-Extended skilleenhed for førerassistentsystem
Fryseramme:
Fejlprioritet: 1
Fejlhyppighed: 5
Nulstiltæller: 174
Kørestrækning: 234099 km
Tidsindikation: 0
Dato: 2000.00.00
Tid: 08:47:15
01044 - Styreenhed forkert kodet
Fryseramme:
Fejl status : 01100000
Fejlprioritet: 1
Fejlhyppighed: 1
Nulstiltæller: 170
Tidsindikation: 0
Dato: 2000.00.00
Tid: 08:47:20
03075 - Styreenhed til parkeringsassistent (J791)
Fryseramme:
Fejl status : 01100100
Fejlprioritet: 2
Fejlhyppighed: 1
Nulstiltæller: 174
Kørestrækning: 234149 km
Tidsindikation: 0
Dato: 2000.00.00
Tid: 20:47:47
Styreenhed 25: Startspærre Forklaringsfil: NEZ\3C0-959-433-25.clb
Styreenhedsnr: SW: 3C0 959 433 K HW: 3C0 959 433 K
Komponent : IMMO 038 0367
Revision: 00038000 Serienummer: VWZCZ000000000
Forhandler : WSC 131071 1023 2097151
VCID: 323DE620882405D7B4C-8066
Undersystem 1 - Styreenhedsnr:: 3C0 905 861 D
Komponent : ELV 024 0370
3C0905861D ELV 024 0370
Styreenhed 42: Dørelektr. V for Forklaringsfil: NEZ\1K0-959-701-MIN2.lbl
Styreenhedsnr:: 1K0 959 701 K
Komponent : Tuer-SG 024 2365
Kodning : 0000181
VCID: 3635DA30644C19F7984-8062
Styreenhed 44: Servostyring Forklaringsfil: NEZ\1Kx-909-144-G2V2.clb
Styreenhedsnr:: 1K1 909 144 J
Komponent : EPS_ZFLS Kl.5 D04 1606
2 fejlkoder fundet:
02546 - Anslag for fuldt styreudslag
Fryseramme:
Kørestrækning: 4080 km
Temperatur: 28.0°C
Volt: 14.00 V
Volt: 13.70 V
Fryseramme:
Styreenhed 46: Komfortelektronik Forklaringsfil:. NEZ\3C0-959-433-46.clb
Komponent : KSG PQ46 ELV 038 0455
Kodning : 0091020851030E763804941570084F0B603C80
Undersystem 1 - Komponent : Sounder n.mounted
Undersystem 2 - Komponent : NGS n.mounted
Undersystem 3 - Komponent : IRUE n.mounted
Styreenhed 52: Dørelektr. H for Forklaringsfil: NEZ\1K0-959-702-MIN2.lbl
Styreenhedsnr:: 1K0 959 702 K
Kodning : 0000180
VCID: 372BD7346346E0FF832-8062
Styreenhed 53: Parkeringsbremse Forklaringsfil: NEZ\3C0-907-801-53.clb
Styreenhedsnr: SW: 3C0 907 801 G HW: 3C0 907 801 G
Komponent : EPB VD8HC005 013 0005
Revision: 013
Kodning : 0000012
VCID: 26150A70B4EC6977284-8072
3 fejlkoder fundet:
02433 - Parkeringsbremsemotor i højre side: Spændingsforsyning (V283)
011 - Afbrydelse - Fejllampe aktiveret
Fryseramme:
Fejl status : 11101011
Fejlprioritet: 1
Fejlhyppighed: 94
Nulstiltæller: 125
Kørestrækning: 233568 km
Tidsindikation: 0
Dato: 2000.00.00
Tid: 22:27:42
Fryseramme:
Volt: 14.80 V
Tæller: 103
01316 - Bremsestyreenhed
013 - Kontroller fejlkoder - Fejllampe aktiveret
Fryseramme:
Fejl status : 11101101
Fejlprioritet: 3
Fejlhyppighed: 254
Nulstiltæller: 175
Kørestrækning: 234144 km
Tidsindikation: 0
Dato: 2000.00.00
Tid: 20:39:32
Fryseramme:
Volt: 11.90 V
Tæller: 236
02844 - Kontrollampe for automatisk parkeringsfunktion
009 - Afbrydelse/Kortslutning til stel - Fejllampe aktiveret
Fryseramme:
Fejl status : 11101001
Fejlprioritet: 4
Fejlhyppighed: 9
Nulstiltæller: 169
Kørestrækning: 234088 km
Tidsindikation: 0
Dato: 2000.00.00
Tid: 13:10:21
Fryseramme:
Volt: 10.97 V
Tæller: 64
Styreenhed 56: Radio Forklaringsfil: NEZ\1K0-035-1xx-56.lbl
Styreenhedsnr:: 1K0 035 186 P
Komponent : Radio GR0 015 0019
Revision: 0001503S Serienummer: VWZ2Z2E3014820
Kodning : 0040400
Styreenhed 62: Dørelektr. V bag Forklaringsfil: NEZ\1K0-959-703-GEN2.lbl
Styreenhedsnr:: 3C9 959 703
Komponent : Tuer-SG 021 2505
Kodning : 0000144
VCID: 70B92C2846A877C7828-8024
Styreenhed 69: Anhængertræk (J345) Forklaringsfil:. NEZ\1K0-907-383-V2.lbl
Styreenhedsnr: SW: 1K0 907 383 E HW: 1K0 907 383 E
Komponent : Anhaenger H08 0080
Revision: 3A002002 Serienummer: 00000120413366
Kodning : 0100000100000000
VCID: 2F3BEF549716283FDB2-807A
Styreenhed 72: Dørelektr. H bag Forklaringsfil: NEZ\1K0-959-704-GEN2.lbl
Styreenhedsnr:: 3C9 959 704
Kodning : 0000144
VCID: 71BF292C4DA27ECF8D6-8024
Styreenhed 7D: Ekstravarmesystem Forklaringsfil: NEZ\1K0-963-235.lbl
Styreenhedsnr: SW: 1K0 963 235 E HW: 1K0 963 235 E
Komponent : PTC-Element 0404
Revision: 00800000 Serienummer:
VCID: 2D07F55C911A5A2FE9E-8078
2 fejlkoder fundet:
00361 - Varmelegeme til ekstravarme (Z35)
014 - Defekt
01299 - Diagnose-interface for databus (J533)
Slutning-------(Forløbet tid: 01:11, VBat. start/slut: 14.0V/13.9V)--------
and
