Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Cannot get J400 LINBus wiper setup to show under 09 on a PQ35 BCM
    Jul 2016
    I'm still totally stuck on this one still.
    I'm using a PQ35 H+ BCM, from a 2015 Passat Sport, 5K0937087AE, on which the car used the double relay 'dumb' wiper motor. As part of my Caddy 2K project (http://forums.ross-tech.com/showthre...-Retrofit-ever) I need to run a J400 wiper setup.
    I have added a wire to the N33 connector pin on the BCM, which is connected to the wiper setup, but cannot get the J400 to populate under the 09 CE module on the drop down section.
    I have tested the motor and wiring on a 2009 GTI with the older style BCM (3C8937049E) and it worked immediately upon being installed.
    At this point I'm totally guessing.. I have seen people retrofit the Rain Sensor using the N-33 pin on the NMS, which lets me know that it can receive a LINBus signal input, but I don't know if the BCM can handle the output for the wupers. I don't have an oscilloscope to verify if there is any LINBus activity currently.
    Auto scan:
    Saturday,02,June,2018,23:09:55:42907
    VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
    VIN: XXX   License Plate:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 72 75
    VIN: XXX   Mileage: 20km-12miles
    72-Door, Rear Right -- Status: Cannot be reached 1100
    75-Telematics -- Status: Not registered 0011
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 K    HW: 06K 907 425 C
       Component: Simos18.2     H13 8104
       Revision: --H13---
       Coding: 001A0012242400170000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM18TFS02006K906071K 001006
       ROD: EV_ECM18TFS02006K906071AC.rod
       VCID: B3265BC81A9273DC6A-80E6
    19795 - EVAP System Leak Detection Pump Heater Control Circuit
              P240A 00 [039] - Open Circuit
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:14:58
                        Coolant temperature: 34 °C
                        Intake air temperature: 29 °C
                        Voltage terminal 30: 11.972 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 100 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 18.359375 %
                        FUP_H_SAE: 15010.0 kPa
    19798 - Control Circuit for EVAP Vent Control
              P0447 00 [039] - Open Circuit
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:14:58
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 99 kPa
    19791 - EVAP Leak Detection Pump Control Circuit
              P2400 00 [039] - Malfunction
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:14:58
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 99 kPa
    17178 - Databus
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:14:55
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels:| 09G-927-749-V1.clb
       Part No SW: 09G 927 749 B    HW: 09G 927 749 B
       Component: AISIN AG6 G3  109 2784
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 001004
       ROD: EV_TCMAQ250031_001_VW41.rod
       VCID: B83C6CE403F490845F-80EC
    22920 - Implausible Data Received from Parking Brake Control Module
              U0417 00 [171] - -
                        Reset counter: 36
                        Mileage: 29 km
                        Engine speed: 0.0 /min
                        Transmission input speed: 0 /min
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 25 °C
                        Accelerator position: 0.0 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Open
                        Electrical Oil Pump target revolution: 65534 /min
                        Electrical Oil Pump actual revolution: 65279 /min
                        Engine Speed signal Current: 65279 /min
                        Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                        Electrical Oil Pump target current: 65278 mA
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Component: ESP MK60EC1   H46 0166
       Revision: 00H46001
       Coding: C54BC0F5492500FBA31103E892210041A1100012
       VCID: 8444C81407BC046483-80D0
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:19
                        Count: 2
                        Count: 12
                        Count: 4096
                        Count: 16390
                        Count: 42496
                        Count: 512
                        Fault Status: 01100101
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:15
                        Count: 2
                        Count: 12
                        Count: 4096
                        Count: 291
                        Count: 42496
                        Count: 512
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: F5A2A5D054662DEC84-80A0
    9471253 - Temperature Sensor for Footwell Vent
              B1085 15 [009] - Open or Short to Plus
                        Reset counter: 27
                        Date: 2018.03.09
                        Time: 03:18:43
    9471509 - Temperature Sensor for Driver Side Vent in Dashboard
              B1086 15 [009] - Open or Short to Plus
                        Reset counter: 27
                        Date: 2018.03.09
                        Time: 03:18:43
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Reset counter: 67
                        Time: 00:00:00
    13701536 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:57:58
    9472533 - Temperature Sensor for Evaporator Vent
              B108A 15 [008] - Open or Short to Plus
                        Reset counter: 67
                        Date: 2018.04.04
                        Time: 00:31:26
              B10AB F0 [009] - Too Low
                        Reset counter: 27
                        Date: 2018.03.09
                        Time: 03:18:44
       Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
       Component: BCM PQ35 H+   122 0174
       Revision: BL122001
       Coding: 81200418802B080101080001060009004104A000408018207F8400000C70
       VCID: F8BCACE44B7450849F-80AC
    9 Faults Found:
    00897 - Windshield Washer Pump (V5)
                        Fault Status: 01101100
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:27
                            Term 15 On
                        Voltage: 12.00 V
                        Fault Status: 01101011
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:27
                            Term 15 On
                        Voltage: 12.00 V
                000 -  -  - Intermittent
                        Reset counter: 76
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 03:12:17
                            Term 15 On
                        Voltage: 11.70 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:57:59
                            Term 15 On
                        Voltage: 11.90 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 03:12:02
                            Term 15 On
                        Voltage: 11.80 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 03:15:00
                            Term 15 On
                        Voltage: 12.05 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 03:14:56
                            Term 15 On
                        Voltage: 12.05 V
    03188 - Bulb for Side Marker Light; Front Left
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:44:41
                            Term 15 On
                        Voltage: 11.90 V
    03189 - Bulb for Side Marker Light; Front Right
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:44:41
                            Term 15 On
                        Voltage: 11.90 V
       Part No SW: 5C0 959 655 AA    HW: 5C0 959 655 AA
       Component: AirbagVW10    500 0975
       Serial number: 003LYD017DHN
       Coding: 00004832
       ASAM Dataset: EV_AirbaVW10SMEVW360 001030
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: F1AA91C0200E01CC58-80A4
       Serial number: 3572MSME4E2F2D48ZZZC
       Serial number: 3582MSME4A312D48ZZZ$
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3516KSME796E0A30ZZZ
       Subsystem 4 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
       Serial number: 3566LSME1567702FZZZ
    17 Faults Found:
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9438235 - Igniter for Front passenger's Head Curtain Airbag
              B1004 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9437723 - Igniter for Passenger's Airbag
              B1002 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9438747 - Igniter for Seat Belt Tensioner; Driver's Side
              B1006 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
              B1007 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9442075 - Driver's Belt Force Limiter Igniter
              B1013 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9442331 - Passenger's Belt Force Limiter Igniter
              B1014 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9437979 - Igniter 2  for Passenger's Airbag
              B1003 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9440539 - Driver's Safety Belt Tensioner Igniter 2
              B100D 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9441051 - Front passenger's safety belt tensioner igniter 2
              B100F 1B [137] - Resistance Too High
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
              B1019 15 [137] - Open or Short to Plus
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 14 [137] - Open or Short to Ground
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
    9445937 - Seat occupied recognition control module
              B1022 31 [137] - No Signal
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:43
    9445141 - Passenger's seat position sensor
              B101F 15 [137] - Open or Short to Plus
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:41
       Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
       Revision: FF010042    Serial number: 20140603200150
       Coding: 089A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: F9BAA9E0787E498CE0-80AC
       Component: E221__MFL-YVJ  H07 0023
       Coding: E30000
    617742 - Selector Lever Park Position Lock Switch
              B1162 07 [009] - Mechanical Failure
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:15:48
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 F    HW: 561 920 970 F
       Component: KOMBI         H04 0811
       Coding: 230A00
       Shop #: WSC 27461 001 104857
       VCID: 9D729D708C16D5ACAC-80C8
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 07091403000360
       Coding: 358400
       VCID: 804CC40413A41844A7-80D4
                        Fault Status: 01110100
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:18:02
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:57:59
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:18:06
                000 -  -
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:57:58
    03272 - Control Module for Audio Interface
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:18:06
    03605 - Control Module Auomatic Sliding Door, Rear Right
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:18:02
    Address 1C: Position Sensing
       Component: IMMO          H04 0811
       VCID: EA9886AC0DD8F21419-80BE
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0008855618
       Coding: 0404B5
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: DBF6D368D2829B9C92-808E
    65538 - Local Data Bus
              U10BA 00 [009] - No Communication
              [Front Timeout LIN Sub bus]
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:19:44
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:19:44
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [009] - Electrical Failure
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 03:12:14
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 211    3501
       Revision: 00H22000
       VCID: B93A69E0F0FE898CA0-80EC
                        Fault Status: 11100101
                        Date: 2018.03.05
                        Time: 00:11:47
                        Battery Volts: 12.1 V
                            DD
                        Temperature: 24.0°C
                        Count: 3
                        Steering Angle: 0.00°
                            SteerAng n.Init
                        Reset counter: 67
                        Voltage: 12.63 V
                            DD
                        Temperature: 23.0°C
    01316 - ABS Control Module
                        Fault Status: 00101101
                        Fault Frequency: 14
                        Reset counter: 76
                        Mileage: 27 km
                        Date: 2018.05.05
                        Time: 09:54:49
                        Voltage: 14.38 V
                            DU
                        Temperature: 12.0°C
                        RPM: 1741 /min
                        Speed: 17.0 km/h
                        Speed: 17.0 km/h
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 00000000
       VCID: EFAE97B83E3A173C4E-80BA
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0008877502
       Coding: 0404B4
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: DCF4D074D78C9CA49B-8088
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:21:14
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2018.06.02
                        Time: 02:21:14
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3191183
       Coding: 01000400040007
       Shop #: WSC 00066 000 00000
       VCID: E386EB88E2F2A35CDA-80B6
    15 Faults Found:
    01704 - Terminal 58 (Dimming)
                        Reset counter: 67
                        Date: 2018.03.05
                        Time: 00:11:47
    00856 - Radio Antenna
                        Reset counter: 27
                        Date: 2018.03.05
                        Time: 00:11:47
                        Reset counter: 27
                        Date: 2018.03.05
                        Time: 00:11:47
                000 -  -
                        Reset counter: 27
                        Date: 2018.03.05
                        Time: 00:11:47
    00874 - Treble Speaker Front Left (R20)
                        Fault Status: 00101011
                        Reset counter: 67
                        Date: 2018.03.05
                        Time: 00:17:58
    00876 - Treble Speaker Rear Left (R14)
                        Reset counter: 36
                        Date: 2018.03.05
                        Time: 00:17:58
    00877 - Treble Speaker Rear Right (R16)
                        Reset counter: 36
                        Date: 2018.03.05
                        Time: 00:17:58
                        Reset counter: 67
                        Date: 2018.03.05
                        Time: 00:18:00
                        Fault Frequency: 10
                        Reset counter: 36
                        Date: 2018.03.05
                        Time: 00:18:00
                        Fault Frequency: 10
                        Reset counter: 36
                        Date: 2018.03.05
                        Time: 00:18:00
    00532 - Supply Voltage B+
                        Reset counter: 69
                        Date: 2018.03.09
                        Time: 04:03:04
    02633 - Antenna for Satellite Tuner
                        Reset counter: 27
                        Date: 2018.04.03
                        Time: 01:17:31
                        Reset counter: 67
                        Reset counter: 27
                        Reset counter: 27
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140528
       Coding: 02140102C21612107F1606C00000
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 9464F8547FDC94E413-80C0
    10 Faults Found:
    12670208 - Databus
              [CAN TO instrument cluster]
                        Reset counter: 67
                        Time: 00:00:00
    0022 - Databus
              [CAN TO radio]
                        Reset counter: 67
                        Date: 2018.04.03
                        Time: 01:17:55
    0037 - Databus
              [CAN TO Telephone ECU]
                        Fault Frequency: 104
                        Reset counter: 36
                        Time: 00:00:00
    13635840 - Supply voltage
              [supply voltage lower limit exceeded]
                        Reset counter: 69
                        Date: 2018.03.05
                        Time: 05:00:25
              U1400 00 [008] - -
              [restriction due to undervoltage]
                        Fault Frequency: 9
                        Reset counter: 76
                        Date: 2018.03.05
                        Time: 04:55:57
    9455635 - Microphone 1
              B129B 13 [009] - Open Circuit
                        Reset counter: 27
                        Date: 2018.03.05
                        Time: 00:11:47
    9457171 - Audio signal output 1
              B14F1 13 [009] - Open Circuit
                        Reset counter: 27
                        Time: 00:00:00
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
              [roofline module open load]
                        Reset counter: 27
                        Date: 2018.03.05
                        Time: 00:11:47
    9458451 - Cellular Antenna
              B1053 13 [009] - Open Circuit
              [GSM antenna open load]
                        Reset counter: 0
    2566 - GPS Antenna
              B1054 13 [009] - Open Circuit
              [GPS antenna open load]
                        Reset counter: 0
    End----------(Elapsed Time: 01:12, VBatt start/end: 12.1V/12.1V)-----------
    Tartu, Estonia
    I think You may need to enable the LIN connection for LIN wiper. But that must a undocumented bit.
    The world is my oyster...
  3. Likes the brit liked this post
    Jul 2016
    Searching for either how to enable / wake LIN on this BCM, or for a BCM that will work correctly. I'm at the point of just throwing parts at it I guess..
    Per http://forums.ross-tech.com/showthre...emote-matching :
    5K0 937 085 S - 2012 Passat NMS lowline BCM
    5K0 937 087 Q - Highline BCM - doesn't allow coding of remotes possibly due to Kessy.
    As I'm searching, it seems that my OEM 2017 Caddy 2K HID w/ LED might not have the LEDs functioning because of the BCM also. So perhaps one BCM swap can rule them all.
    Test this Coding for [09]
    81200418802B080101080001060009004104A000400018207F8400000C70
  6. Likes the brit, Uwe liked this post
    Jul 2016
    81200418802B080101080001060009004104A000400018207F 8400000C70
    Existing coding_____: 81200418802B080101080001060009004104A000408018207F8400000C70
    Suggested coding__: 81200418802B080101080001060009004104A000400018207F8400000C70
    Thank you for the input! I definitely owe anyone with the solution a good meal!
    On Byte 21 on the Helper I can't seem to manipulate the first number, so it seems scary going in blind, but I'll give it a go now.
    Jul 2016
    Coding was accepted with 81200418802B080101080001060009004104A000400018207F 8400000C70.
    Now going out to the car to test. I have all my fingers crossed, and I'm practically holding my breath, haha.
    EDIT:
    Scanned Fault Codes on 09 before testing in car, and I now have a 00153 - 004 on the V216 fault showing:
    Sunday,03,June,2018,16:15:38:42907
    VCDS Version: Release 18.2.1 (x64) Running on Windows 10 x64
                    Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
    Control Module Part Number: 5K0 937 087 AE    HW: 5K0 937 087 AE
      Component and/or Version: BCM PQ35 H+   122 0174
               Software Coding: 81200418802B080101080001060009004104A000400018207F8400000C70
                Work Shop Code: WSC 09003 957 00200
                          VCID: F8BCACE45B7450849F-80AC
    10 Faults Found:
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 00:08:37
                            Term 15 On
                        Voltage: 12.05 V
                        Fault Status: 00101100
                        Reset counter: 76
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 02:15:27
                            Term 15 On
                        Voltage: 12.00 V
                        Reset counter: 76
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 02:15:27
                            Term 15 On
                        Voltage: 12.00 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 02:57:59
                            Term 15 On
                        Voltage: 11.90 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 03:12:02
                            Term 15 On
                        Voltage: 11.80 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 03:15:00
                            Term 15 On
                        Voltage: 12.05 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 03:14:56
                            Term 15 On
                        Voltage: 12.05 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 02:44:41
                            Term 15 On
                        Voltage: 11.90 V
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 02:44:41
                            Term 15 On
                        Voltage: 11.90 V
    03281 - Signal Lights On from Light Sensor
                        Reset counter: 36
                        Mileage: 29 km
                        Date: 2021.14.21
                        Time: 07:18:04
                            Term 15 Off
                        Voltage: 12.05 V
  9. Likes Uwe liked this post
  10. #7
    Jul 2016
    Reporting back from test in car: No action on the J400 wipers. They're connected directly to the Pin 33, and to an external 12v and ground.
  11. #8
    Tartu, Estonia
    I did a small search and i didn't find any scan with your BCM and Lin-Wiper. It may be totally possible, that this BCM doesn't support LIN-Wiper. Also when using ETKA-s cross-reference i see that this BCM is only installed in small amount of cars like Caddy and Jetta.
    I see that Niels recommended trying LC,21,7. Before replacing BCM, give this a try.
  12. Likes the brit liked this post
  13. #9
    Jul 2016
    All Caddy 2K use LIN-wipers, which makes me thing it should be okay. I did check that the Pin is populated on the BCM at that location, but I haven't opened it to look inside.
    The physical BCM I'm using is from a 2015 NMS Passat, which uses V216 dumb wipers, which when I changed to NETech's suggestion, now shows as a fault code for no communication. This BCM does have "Rain/Light Sensor (RLS) installed" option under Byte 21, which uses the LINBus to communicate.
    I assume Niels is NETech?
  14. #10
    Jul 2016
    I'm wondering if a good old fashioned holding of the positive and negative battery terminals together for a while would help the BCM discovered the J400 connected to it.
    I'm definitely clutching at straws..
