Results 1 to 9 of 9
Thread: Retrofit Jetta MK6 BCM into Jetta MK5 TDI
    Verified VCDS User 0xff's Avatar
    Jan 2018
    Argentina
    Hi folks, this is my first post, and asking for some light on an issue I have with a customer's Jetta MK5 TDI Advance (Argentina spec).
    He has messed around with a crappy chinese interface and, after he fried his BCM (5K0 937 086 F), he retrofitted an used Jetta MK6 Luxury BCM (5K0 937 086 J) as it seems compatible; and then he asked me to re-code his BCM to match the previous coding (which he saved with the chinese interface).
    So, after I re-coded the new BCM, almost all the DTC were gone except for the two that the following scan reports. Also, I noticed this Jetta MK5 has the rear fog light only in the inner left tail light, and the reverse light in the inner tail light and the MK6 doesn't. Should I change the Byte 18?
    Saturday,11,August,2018,13:47:46:43330
    VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
    Dealer/Shop Name: TopHost Soluciones
    VIN: 3VWHC61K0AM179780   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: 3VWHC61K0AM179780   Mileage: 166390km-103389miles
    Address 01: Engine        Labels: None
       Part No SW: 03G 906 056 AC    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000AG  6508
       Revision: --H13---    Serial number:
       Coding: 0000078
       VCID: 689C63395BDA99048F-803C
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 000 - Open Circuit - Intermittent
                        Fault Status: 00110000
                        Mileage: 165598 km
                        Date: 2012.12.24
                        Time: 10:53:47
                        RPM: 147 /min
                        Voltage: 9.88 V
                        Bin. Bits: 00001011
                        Temperature: 7.2°C
                        Bin. Bits: 01110000
       Part No SW: 02E 300 054 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2106
       Revision:    51112    Serial number: 00001001140781
       VCID: 15621ACD3C28D4ECE4-8040
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 113B200D0A290003881204EC50190041310000
       VCID: 0444578987B25D6403-8050
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00066 000 00148
       VCID: 7DB2226DEC582CAC4C-8028
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0045
       Revision: BC011001
       Coding: 08000A3E982DE3E0400800802000012403000088510081605C8000000000
       Shop #: WSC 00066 123 12345
       VCID: 3B36EC75BACCE29C32-806E
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 28081  21  0512
       Coding: 009795
       Subsystem 2 - Part No: 1K8 951 171
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 222
                        Mileage: 166396 km
                        Date: 2013.01.01
                        Time: 13:26:03
                        Voltage: 12.95 V
    02199 - Bulb for Tail Light 2; Right (M50)
                        Reset counter: 222
                        Mileage: 166396 km
                        Date: 2013.01.01
                        Time: 13:25:44
                        Voltage: 13.20 V
       Component: 2N AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2N721+
       Coding: 0012878
       VCID: 3D32E26D64D8ECAC0C-8068
       Subsystem 1 - Serial number: 6332MSME55124B368
       Subsystem 2 - Serial number: 6342MSME55130C266
       Subsystem 3 - Serial number: 6351HSME231F4B014
       Subsystem 4 - Serial number: 6361HSME231F534CD
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Component: J0527           056 0111
       Coding: 0001531
       VCID: 76A03D41016E7FF40D-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5M0 920 870 E    HW: 5M0 920 870 E
       Component: KOMBI         H05 0305
       Coding: 171D00
       Shop #: WSC 15846 002 104857
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 312ACE5D608018CC98-8064
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 04091001210870
       Coding: ED807F0600060200001002
       VCID: 6D92122D7438BC2CFC-8038
       Component: IMMO          H05 0305
       VCID: 6A9819318DD6AB1499-803E
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001317999
       Coding: 0000B4
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 271E20055E44567C46-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005197129
       Coding: 000090
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 312ACE5DA88018CC98-8064
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001302436
       Coding: 0000B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 281C2339535A59044F-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005200871
       Coding: 000090
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  040 0167
       Revision: 00000001    Serial number: VWZ1Z3K3548402
       Coding: 0000041004
       VCID: 628871117DE6F35451-8036
    Address 77: Telephone        Labels: RETROFIT77.lbl
       Part No SW: KTC 364 96P     HW: KTC 364 96P
       Component: SWP:3.21.9      H24 0191
       Shop #: WSC 21977 142 74100
       VCID: 3E30E56169DEF7B415-806A
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.2V)-----------
    Thank you!
  2. Likes Boki Ar liked this post
  3. #2
    May 2017
    Yes, byte 18.
  4. Likes Boki Ar liked this post
  5. #3
    Jan 2018
    Argentina
    Thank you @downtime!
    Is it safe to change BCM byte 18? I saw some threads in other forums where they had big issues after changing byte 18 (not so sure if they did it with a genuine interface or not).
    If someone did the same retrofit (or similar one), I’ll be glad to hear/read some experiences with that.
    Thanks!
  6. #4
    May 2017
    I never had any issues with byte 18. I've read that someone had managed to destroy the BCM by changing it but well, internet is full of sh*t.
    Search for the byte 18 here and you'll find a list of values you could try out. I think you'll find the correct one quite quickly.
    Jan 2018
    Argentina
    Thank you, I’ll do that.
    Tartu, Estonia
    It's not only Internet. It's really possible do make BCM brick when playing with byte18. I know a such happening with Caddy 2010.
    The world is my oyster...
  9. Likes downtime liked this post
  10. #7
    May 2017
    ^ 99% of the cases a hacked Chinese VCDS copy was involved
    But you're right, there's a slight chance to brick it. That said, unfortunately only route to make your lights work.
  11. #8
    May 2017
    Ok but for some practical stuff. You can find a comprehensive list of byte 18 values below.
    But you could go with Jetta codes first and as the car does not have Xenon then try 05 or 06 depending on the market area. Or 1E might be ok as well.
    Value   Car      Light   Region      Note
    01   BCM (default)
    02   VW Golf (VW360)      Halogen   Rest of World      TFL_0
    03   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0
    04   VW Golf GTI (VW360)   Halogen   Rest of World      TFL_0_LED+LED_SBBR
    05   VW Jetta (VW351)   Halogen   Rest of World      TFL_0
    06   VW Jetta (VW351)   Halogen   NORTH AMERICA   TFL_0
    07   VW Jetta (VW351C)   Halogen   China      TFL_0
    08   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World      TFL_0
    09   VW Golf/Jetta Variant (VW362)   Halogen   NORTH AMERICA   TFL_0
    0A   VW Scirocco (VW364) LHD   Halogen   Rest of World       LHD TFL_0
    0B   VW Scirocco (VW364) RL   Halogen   Rest of World      RHD TFL_0
    0C   VW Caddy Van (VW367)    Halogen   Rest of World      TFL_0
    0D   VW Caddy Van (VW367)    Halogen   Rest of World/Ska      TFL_0_Ska
    0E   VW Golf Plus (VW369)   Halogen   Rest of World      TFL_0
    0F   SEAT Leon (SE350)    Xenon   NORTH AMERICA   TFL_0
    0F   SEAT Altea XL II (SE352)   Xenon   NORTH AMERICA   TFL_0   2/7
    10   SEAT Toledo (SE351)   Xenon   NORTH AMERICA   TFL_0   9/9
    11   SEAT Leon (SE350)    Halogen   NORTH AMERICA   TFL_S
    11   SEAT Altea XL II (SE352)   Halogen   NORTH AMERICA   TFL_S   2/7
    12   SEAT Toledo (SE351)   Halogen   NORTH AMERICA   TFL_0   9/9
    13   VW Sharan (VW428)   Halogen   Rest of World      TFL_1
    14   VW Sharan (VW428)   Xenon   Rest of World      TFL_1
    15   VW Golf GTI (VW360)   Halogen   Rest of World      TFL_0+ LED SBBR
    16   SEAT Leon (SE350   Xenon   Rest of World      TFL_0
    16   SEAT Altea XL II (SE352)   Xenon   Rest of World      TFL_0    2/7
    17   SEAT Toledo (SE351)   Xenon   Rest of World      TFL_0   9/9
    18   SEAT Leon (SE350)    Halogen   Rest of World      TFL_S
    18   SEAT Altea XL II (SE352)   Halogen   Rest of World      TFL_S   2/7
    19   SEAT Toledo (SE351)   Halogen   Rest of World      TFL_S   9
    1A   Skoda Superb Combi (SK462)   Halogen       without TFL, DRL-Low Beams
    1B   Skoda Superb (SK461)   Halogen       without TFL, DRL-Low Beams
    1C   Skoda Superb (SK461)   Halogen   Rest of World      separate TFL_1
    1D   Skoda Superb (SK461)    Xenon   ASUV      TFL_Separate
    1D   Skoda Yeti (SK356)   Xenon   ASUV      TFL_Separate
    1E   VW Golf (VW360)    Halogen   NORTH AMERICA                           TFL_0 + SMR on SL-back
    1E   VW Jetta (VW351)   Halogen   NORTH AMERICA                           TFL_0 + SMR on SL-back
    1F   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0 + LED SBBR
    20   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0_LED
    21   VW Golf (VW360)      Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
    22   VW Golf (VW360)      Halogen   Rest of World/Japan   Japan + LED_SBBR
    23   Audi A3 (AU350PA)    Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
    23   VW Golf (VW360)      Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
    24   Audi A3 (AU350PA)    Halogen   Rest of World      TFL_1
    24   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World      TFL_1
    25   Audi A3 (AU350PA)    Halogen   Rest of World/Ska LDH   TFL_0 LL_Ska
    25   VW Scirocco (VW364)   Halogen   Rest of World/Ska LDH   TFL_0 LL_Ska
    26   Audi A3 (AU350PA)    Xenon   Rest of World/Ska RHD   TFL_0 RL_Ska
    26   VW Scirocco (VW364)   Xenon   Rest of World/Ska RHD   TFL_0 RL_Ska
    27   Audi A3 (AU350PA)    Xenon   Rest of World/Ska      TFL_1_Ska
    27   VW Tiguan (VW316)   Xenon   Rest of World/Ska      TFL_1_Ska
    28   Audi A3 (AU350PA)    Xenon   Rest of World/Ska      TFL_1_Ska
    28   VW EOS (VW465)   Xenon   Rest of World/Ska      TFL_1_Ska
    29   Audi A3 (AU350PA)    Halogen   Rest of World/Ska      TFL_0_Ska
    29   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World/Ska      TFL_0_Ska
    2A   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL with tail, AB2 PA 5door
    2B   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL without tail, AB2 PA 5door
    2C   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL with tail, AB2 PA 5door
    2D   Audi A6 (AU356PA)   Halogen   Rest of World   TFL_0
    2E   Audi A6 (AU356PA)   Xenon   Rest of World   TFL_0
    2F   VW Tiguan (VW316)   Halogen / Xenon   Rest of World   TFL_0
    30   VW Tiguan (VW316)   Halogen / Xenon   Rest of World   TFL_S
    31   Skoda Superb Combi(SK462)   Halogen       separate TFL_1
    32   Skoda Octavia (SK350)    Halogen   RHD   TFL_LED ROM from TFL
    32   Skoda Octavia RS (SK35x-RS)   Halogen   RHD   TFL_LED ROM from TFL
    33   Skoda Octavia (SK350)    Halogen   LHD   TFL_LED ROM from TFL
    33   Skoda Octavia RS (SK35x-RS)   Halogen   LHD   TFL_LED ROM from TFL
    34   Skoda Octavia (SK350)    Halogen   RL   RL from TFL ROM 52 ROM from TFL
    34   Skoda Octavia (SK351)   Halogen   RL   RL from TFL ROM 52 ROM from TFL
    35   Skoda Octavia (SK350)   Halogen   LHD   TFL_1.separat LL halogen -ROM from TFL
    35   Skoda Octavia (SK351)   Halogen   LHD   TFL_1.separat LL halogen -ROM from TFL
    36   Skoda Octavia (SK350)   Halogen   RL   DRL-Low Beams (S) (P)
    36   Skoda Octavia (SK351)   Halogen   RL   DRL-Low Beams (S) (P)
    37   Skoda Octavia (SK350)   Halogen   LHD   DRL LHD-Low Beams (S) (P)
    37   Skoda Octavia (SK351)   Halogen   LHD   DRL LHD-Low Beams (S) (P)
    38   Skoda Octavia (SK350)   Halogen   RL   TFL_SH
    38   Skoda Octavia (SK351)   Halogen   RL   TFL_SH
    39   Skoda Octavia (SK350)   Halogen   LHD      TFL_SH
    39   Skoda Octavia (SK351)   Halogen   LHD      TFL_SH
    3A   Audi A1 (AU210)      Halogen   Rest of World       LHD TFL_S
    3A   VW Scirocco (VW364)   Halogen   Rest of World       LHD TFL_S
    3B   VW Scirocco (VW364)   Xenon   Rest of World       RHD TFL_S
    3C   VW Golf (VW360)      Xenon   Rest of World      TFL_S
    3D   VW Golf (VW360)      Xenon   NORTH AMERICA   TFL_S
    3E   VW Golf (VW360)      Halogen   NORTH AMERICA
    3F   VW Golf (VW360)      Xenon   Ska      TFL_S LED_SBBR
    40   VW Golf (VW360)      Halogen   Rest of World
    41   VW Golf (VW360)      Xenon   Rest of World      PO_LED
    42   VW Golf (VW360)      Xenon   Ska      TFL_S_LED
    43   VW Golf (VW360)      Halogen   Ska      TFL_S LED_SBBR
    44   VW Golf (VW360)      Xenon   Rest of World      LED_SBBR
    45   VW Golf (VW360)      Halogen   Ska      TFL_0_S
    46   VW Golf Plus (VW369)   Halogen   Ska      TFL_0_S
    47   VW Golf Plus (VW369)   Xenon   Rest of World      PO_LED
    48   VW Golf Plus (VW369)   Xenon   Rest of World      TFL_LED
    49   VW Golf Plus (VW369)   Halogen   Ska      TFL_S
    4A   VW Jetta (VW351)   Xenon   Rest of World      PO_LED
    4B   VW Jetta (VW351)   Xenon   Rest of World      TFL_LED
    4C   VW Jetta (VW351)   Xenon   NORTH AMERICA   TFL_LED
    4D   VW Golf/Jetta Variant (VW362)   Xenon   Rest of World      PO_LED
    4E   VW Golf/Jetta Variant (VW362)   Xenon   Rest of World      TFL_LED
    4F   VW Golf/Jetta Variant (VW362)   Xenon   NORTH AMERICA   TFL_LED
    50   VW Tiguan (VW316)   Halogen / Xenon   NORTH AMERICA   TFL_1
    51   VW Tiguan (VW316)   Halogen / Xenon   NORTH AMERICA   TFL_S
    52   VW EOS (VW465)   Halogen / Xenon   Rest of World      TFL_1
    53   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_1
    54   VW EOS (VW465)   Halogen / Xenon   Rest of World      TFL_S
    55   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_S
    56   Audi TT Coupe (AU354)   Halogen   Rest of World      TFL_S 2 R
    56   VW EOS (VW465)   Halogen   Rest of World      TFL_S 2 R
    57   Audi TT Coupe (AU354)   Halogen   NORTH AMERICA   TFL_S_II
    57   VW EOS (VW465)   Halogen   NORTH AMERICA   TFL_S_II
    58   Audi TT Coupe (AU354)   Xenon       LED DRL Choming+ H SL
    59   Audi TT Coupe (AU354)   Xenon       LED DRL POL + SL + KZL Choming H SL
    5A   Skoda Octavia (SK35x)   Halogen / Xenon   RL   LED, TFL from Shutter
    5A   Skoda Octavia RS (SK35x-RS)   Halogen / Xenon   RL   LED, TFL from Shutter
    5B   Skoda Octavia (SK35x)   Halogen / Xenon   LHD   LED, TFL from Shutter
    5B   Skoda Octavia RS (SK35x-RS)   Halogen / Xenon   LHD   LED, TFL from Shutter
    5C   VW EOS (VW465FL)   Halogen   Rest of World   TFL_1_LED 8TA
    5D   VW EOS (VW465FL)   Xenon   Rest of World   TFL_1_LED 8TA
    5E   VW EOS (VW465FL)   Halogen   Rest of World   TFL_1 8TC_8TD
    5F   VW EOS (VW465FL)   Xenon   Rest of World   TFL_1_LED 8TC_8TD
    60   VW EOS (VW465FL)   Halogen   NORTH AMERICA   TFL_1 8TA
    61   VW EOS (VW465FL)   Xenon   NORTH AMERICA   TFL_1_Ska 8TA
    62   VW EOS (VW465FL)   Halogen   Rest of World/Ska   TFL_1_Ska 8TC_8TD
    63   VW EOS (VW465FL)   Xenon   Rest of World/Ska   LED_DRLs TFL_1 8TC_8TD
    64   Audi R8   Xenon / ECE   Rest of World   LED DRL without tail
    65   Audi R8   Xenon / ECE   Rest of World   LED DRL with tail
    66   Audi R8   Halogen / Xenon   USA (SM  0W)   LED DRL without tail
    67   Audi R8   Halogen / Xenon   USA (SM  0W)   LED DRL with tail
    68   Audi R8   Xenon / ECE   Rest of World   Complete LED LED DRL without tail
    69   Audi R8   Xenon / ECE   Rest of World   Complete LED, LED DRL with tail
    6A   Audi R8   Halogen / Xenon   USA (SM  0W)   Complete LED, LED DRL without tail (LED tail without TFL)
    6B   Audi R8   Halogen / Xenon   USA (SM  0W)   Complete LED, LED DRL with tail (LED rear TFL)
    6C   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/Bulb 8.08.08
    6D   Audi A1 (AU210)   Halogen / Xenon       TFL with tail, Halogen/ Bulb 8.08.08
    6E   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ LED 8.08.08
    6F   Audi A1 (AU210)   Halogen / Xenon       TFL with tail, Halogen/ LED 8.08.08
    70   Audi A1 (AU210)   Halogen / Xenon       LED TFL without tail, LED TFL/ Bulb 8.08.08
    71   Audi A1 (AU210)   Halogen / Xenon       LED TFL with tail, LED TFL/ Bulb 8.08.08
    72   Audi A1 (AU210)   Halogen / Xenon       LED TFL without tail, LED TFL/ LED 8.08.08
    73   Audi A1 (AU210)   Halogen / Xenon       LED TFL with tail, LED TFL/ LED 8.08.08
    74   Skoda Superb (SK461)   Halogen / Xenon   China      China without DRL SL with BL-function LED SBBR
    75   Skoda Superb (SK461)   Halogen / Xenon   China       China without DRL / TFL-ABL SL without BL function LED SBBR
    76   Audi TT Coupe (NF) (AU354)   Halogen   NORTH AMERICA              separate TFL without SL in CHO
    77   Audi TT Coupe (NF) (AU354)   Xenon   NORTH AMERICA   LED DRL + CHO SL
    78   VW Scirocco (VW364)   Halogen / Xenon   Rest of World      LHD TFL_S
    79   VW Scirocco (VW364)   Halogen / Xenon   Rest of World      RHD TFL_S
    7A   Audi TT Coupe (NF) (AU354)   Halogen / Xenon   NORTH AMERICA   separate DRL with tail
    7B   Audi TT Coupe (NF) (AU354)   Halogen / Xenon   NORTH AMERICA   LED DRL with tail
    7C   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ Bulb (dimmed DRL as taillight)
    7D   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ LED (dimmed DRL as taillight)
    7E   Audi Q3 (AU316)      Halogen / Xenon      TFL_0 (from 05)
    7E   VW Jetta (VW351)   Halogen / Xenon      TFL_0 (from 05)
    7F   Audi Q3 (AU316)      Halogen / Xenon      TFL_S (from 35)
    7F   VW Jetta (VW351)   Halogen / Xenon      TFL_S (from 35)
    80   Audi Q3 (AU316)      Halogen / Xenon   Rest of World   TFL_0 without NSL
    80   VW Scirocco (VW364)   Halogen / Xenon   Rest of World   TFL_0 without NSL
    81   Audi Q3 (AU316)      Halogen / Xenon   Rest of World   TFL_S without NSL
    81   VW Scirocco (VW364)   Halogen / Xenon   Rest of World   TFL_S without NSL
    82   Audi Q3 (AU316)      Halogen / Xenon   LHD   TFL_1 8TC
    82   VW Scirocco R-SCI (VW364)   Halogen / Xenon   LHD   TFL_1 8TC
    83   Audi Q3 (AU316)      Halogen / Xenon   RHD   TFL_1 8TA/8TD
    83   VW Scirocco R-SCI (VW364)   Halogen / Xenon   RHD   TFL_1 8TA/8TD
    84   Audi Q3 (AU316)      Halogen / Xenon   Ska LHD   TFL_1 LHD_Ska 8TC
    84   VW Scirocco R-SCI (VW364)   Halogen / Xenon   Ska LHD   TFL_1 LHD_Ska 8TC
    85   Audi Q3 (AU316)      Halogen / Xenon   Ska RHD   TFL_1 RL_Ska 8TA/8TD
    85   VW Scirocco R-SCI (VW364)   Halogen / Xenon   Ska RHD   TFL_1 RL_Ska 8TA/8TD
    86   VW Jetta (VW351)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
    87   VW Golf/Jetta Variant (VW352)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
    87   VW Golf/Jetta Variant (VW362)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
    88   VW Scirocco (VW364) LHD   Halogen / Xenon   Rest of World/Ska LDH   TFL_1 LL_Ska
    89   VW Scirocco (VW364) RL   Halogen / Xenon   Rest of World/Ska RHD   TFL_1 RL_Ska
    8A   VW Tiguan (VW416)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
    8A   VW Tiguan (VW316)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
    8B   VW EOS (VW465)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
    8C   VW Jetta (VW361)   Halogen / Xenon   Rest of World      TFL_1
    8D   VW Jetta (VW361)   Halogen / Xenon   NORTH AMERICA   TFL_1
    8E   VW EOS (VW465FL)   Halogen / Xenon   Rest of World      TFL_1
    8E   VW Touran (VW368)   Halogen / Xenon   Rest of World      TFL_1
    8F   VW EOS (VW465FL)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
    8F   VW Touran (VW368)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
    90   VW EOS (VW465FL)   Halogen / Xenon   Rest of World      TFL_1_LED
    90   VW Touran (VW368)   Halogen / Xenon   Rest of World      TFL_1_LED
    91   VW EOS (VW465FL)   Halogen / Xenon   Rest of World/Ska      TFL_1_LED_Ska
    91   VW Touran (VW368)   Halogen / Xenon   Rest of World/Ska      TFL_1_LED_Ska
    92   SEAT Alhambra (SE428)   Halogen   Rest of World      TFL_1
    93   SEAT Alhambra (SE428)   Xenon   Rest of World      TFL_1
    94   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_S, 2 Reverse Lights
    95   VW Caddy Van (VN337)   Halogen / Xenon   Rest of World      TFL_S
    96   VW Passat (VW411)   Halogen / Xenon   NORTH AMERICA   TFL_1
    97   VW Passat (VW411)   Halogen   NORTH AMERICA   TFL_S
    98   VW Passat (VW411)   Halogen / Xenon   China      TFL_1
    99   VW Passat (VW411)   Halogen / Xenon   China      TFL_S
    9A   SEAT Leon (SE350)   Xenon   NORTH AMERICA   TFL_0
    9B   SEAT Leon (SE350)   Halogen   NORTH AMERICA   TFL_S
    9C   SEAT Leon (SE350)   Xenon   Rest of World      TFL_0
    9D   SEAT Leon (SE350)   Halogen   Rest of World
    TFL_0   daytime running lights and rear fog light, reversing
    light
    TFL_1   daytime running lights with daytime running light
    outputs
    TFL_S   daytime running lights via Scandinavia low beam
    lights
    TFL_SH   daytime running lights via shutter
    TFL_LED   LED module with dual function parking lights
    TFL_O_S   special Scandinavia derivative solution
    PO_LED   LED module
  12. #9
    Jan 2018
    Argentina
    Thank you, I’ll try 05 because the car doesn’t have DRLs lamps.
