2001.5 B5 S4 Auto Scan - need help
rbatty
C?ID=59684
I know some of these fault codes are the direct result of replacing my totally dead batter with a new one. But I was hoping to get help and/or confirm what I've found out ... For example, I know I need a new central locking pump for the car, but not sure of the remaining fault codes(?). Also, the car has been sitting for quite a while (~6-8 months) because the last tech that worked on it said my clutch pilot bearing is bad (he installed new stage 3 big brake kit). I also found that I may need to replace my N80 purge valve(?). Note: I have not cleared any fault codes since I installed my new batter. Thank you in advance..
 Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 8D0 907 551 M
   Component: 5290 V2Pump     G   0002
   Coding: 06711
   Shop #: WSC 78130
   VCID: B46D5AE3840C12E470-5102
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
17834 - EVAP Purge Valve (N80)
            P1426 - 35-10 - Open Circuit - Intermittent
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 8D0 907 389 E
   Component: ABS/ESP allrad      D56
   Coding: 04395
   Shop #: WSC 06435
   VCID: B56B67E78F760BEC47-5102
00532 - Supply Voltage B+
01203 - Electrical Connection between ABS and Instrument Cluster
            03-10 - No Signal - Intermittent
Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
   Part No: 8D0 820 043 P
   Component: A4     KLIMAAUTOMAT D58
   Coding: 00160
   Shop #: WSC 63351
   VCID: AD5B4F876726432C3F-256C
Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
   Part No: 8D0 959 655 G
   Component: Airbag Front+Kopf  1002
   Coding: 00304
   Shop #: WSC 63351
   VCID: BA7174DBA668E494AA-5102
65535 - Internal Control Module Memory Error
            00-10 -  -  - Intermittent
Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
   Part No: 8D0 920 981 B
   Component: B5-KOMBIINSTR. VDO D12
   Coding: 02264
   Shop #: WSC 85555
   VCID: AB5F419F59324D1C21-5102
Address 35: Centr. Locks        Labels:. 8D0-862-257.lbl
   Part No: 8L0 862 257 N
   Component: CV-Pump, Alarm, RC  D16
   Coding: 16140
   Shop #: WSC 63351
   VCID: C0850633C0B4BE44E4-4E94
10 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
            35-00 -  -
            35-00 -  -
            35-00 -  -
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
            35-00 -  -
            35-00 -  -
01366 - Opened Due to Crash Signal
            35-00 -  -
01365 - Lock/Unlock Switch; Interior
            29-00 - Short to Ground
00991 - Interior Lights
            28-00 - Short to Plus
00955 - Key 1
            09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00101
   Shop #: WSC 63351
   VCID: E0C5E6B36074DE44C4-4AE6
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
            35-00 -  -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
            35-00 -  -
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00012
   Shop #: WSC 63351
   VCID: E5CBF7A77F56BB6C37-513C
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 8D0 035 195 A
   Component:  Radio              D00
   Coding: 00110
   Shop #: WSC 63351
   VCID: A44DAAA334EC8264E0-4AE6
PetrolDave
Westbury, UK
C?ID=1423
Start by clearing all the fault codes in all the modules and see which ones come back.
rbatty
C?ID=59684
Thanks Dave. OK, cleared...drove some.. Here's the updated auto scan. Any help would be appreciated. TIA.
   Coding: 06711
   Shop #: WSC 78130
Readiness: 0000 0100
   Coding: 04395
   Shop #: WSC 06435
   Coding: 00160
   Shop #: WSC 63351
   VCID: AD5B4F876726432C3F-2572
   Coding: 00304
   Shop #: WSC 63351
   Coding: 02264
   Shop #: WSC 85555
   VCID: AB5F419F59324D1C21-50E6
   Coding: 16140
   Shop #: WSC 63351
10 Faults Found:
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
00955 - Key 1
   Coding: 00101
   Shop #: WSC 63351
            35-00 -  -
            35-00 -  -
   Coding: 00012
   Shop #: WSC 63351
   VCID: E5CBF7A77F56BB6C37-515A
   Coding: 00110
   Shop #: WSC 63351
Did you really clear codes in all the modules?
Seem like quite a few remain in 35: Centr. Locks and 45: Inter. Monitor and many of them are typical of cruft that accumulates in those modules.
rbatty
C?ID=59684
Hi Uwe. I think I didn't clear them correctly -- I thought I could clear them from the Auto Scan screen, no? I have to manually go into each module? If so, I'll go do that in a few.
rbatty
C?ID=59684
OK, I went into each module and cleared codes; some modules were unresponsive, e.g., Cent. Elec. and one or two others. But I don't believe there were any fault codes under those modules.
   Coding: 06711
   Shop #: WSC 78130
   Coding: 04395
   Shop #: WSC 06435
   Coding: 00160
   Shop #: WSC 63351
   Coding: 00304
   Shop #: WSC 63351
   Coding: 02264
   Shop #: WSC 85555
   Coding: 16140
   Shop #: WSC 63351
            35-00 -  -
   Coding: 00101
   Shop #: WSC 63351
   Coding: 00012
   Shop #: WSC 63351
   Coding: 00110
   Shop #: WSC 63351
