VW Phaeton 3.0 tdi (BMK)
Raven23c
Verified VCDS-Lite User
C?ID=130714
Hi all,
My first post....I have an issue with my Phaeton, the car is in 'limp mode' Exhaust Workshop warning on start up and MIL is on along with the Glowplug light flashing.
In regards to 009263 - Diesel Particulate Filter (Bank 1): Restricted/Clogged P242F - 001 - Upper Limit Exceeded I'd like to check the DPF soot level and if its below the required level perform a DPF regen. (Hoping that this will resolve the issue)
I'm using a registered version of VCDS-Lite can someone tell me how i need to go about this in step-by-step detail?
There are a number of videos online but the VCDS and VCDS-Lite interface is slightly different.
Which measuring block shows the DPF info? Should the soot level be below 68% or below 68g? How is it displayed?
Do I need the Login code or the Security code before performing a DPF regen? If so what are they?
Is there a chance the issue could be a faulty DPF pressure sensor G450? How do I test the sensor individually? (If it is the sensor who the hell decided to put it on top of the gearbox!!!)
Any help or advice appreciated.
Once I get the DPF issue resolved I'll move onto the other fault codes....
Thursday, 09 August 2018, 19:13:13:18525
Chassis Type: 3D - VW Phaeton D1
Scan: 01,02,03,05,06,07,08,09,11,13,15,16,17,18,19,23,27,28,29,2E,34,36,37,38,39,46,47,55,56,57,65,66,68,69,71,75,76,77
Address 01: Engine       Labels: None
   Controller: 3D0 907 401 A
   Component: 3.0L V6TDI  G000AG  0010
   Coding: 0011773
   Shop #: WSC 01065
   VCID: 1D4D122A84A9
Readiness: N/A
Address 02: Auto Trans       Labels: None
   Controller: 09L 927 760 J
   Component: AG6 09L 3.0lTDI RdW 2205
   VCID: 3E0FF5A6296F
Address 03: ABS Brakes       Labels: None
   Controller: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008356
   Shop #: WSC 01065
   VCID: 6BA90CF20A9D
Address 05: Acc/Start Auth.       Labels: None
   Controller: 3D0 909 139
   Component: 0C Kessy            6700
   Coding: 0004328
   Shop #: WSC 01065
   VCID: E6BFFDC6917F
00165 -  Switch for Transmission Position P/N
            007 -  Short to Ground - Intermittent
Address 06: Seat Mem. Pass       Labels: None
   Controller: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1722
   Coding: 0000003
   Shop #: WSC 01065
   VCID: 7781208246D5
Address 07: Control Head       Labels: None
   Controller: 3D0 035 017 X
   Component:    ZAB COCKPIT      0253
   Coding: 0000000
   VCID: 2F11D8E2FE05
01042 -  Control Module; Not Coded
            000 -   -
01044 -  Control Module Incorrectly Coded
            000 -   -
00668 -  Supply Voltage Terminal 30
            002 -  Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC       Labels: None
   Controller: 3D0 907 040 J
   Component: Climatronic D1      2031
   Shop #: WSC 01065
   VCID: 253D3ACAACF9
Address 09: Cent. Elect.       Labels: None
   Controller: 3D0 937 049 J
   Component: J519                1001
   Coding: 600100002A2115000000000000000000
   Shop #: WSC 01065
   VCID: 3115DE9AE831
01494 -  Bulb for Parking Lamps; Left (M1)
            011 -  Open Circuit - Intermittent
Address 16: Steering wheel       Labels: None
   Controller: 3D0 953 549 D
   Component: Lenksäulenmodul     3401
   Coding: 0000032
   Shop #: WSC 01065
   VCID: 2E2FC5E6F90F
Address 17: Instruments       Labels: None
   Controller: 3D0 920 982 H
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0023411
   Shop #: WSC 01065
   VCID: 2D2DC2EAF409
Address 18: Aux. Heat       Labels: None
   Controller: 3D0 815 005 AG
   Component: Standheizung        2426
   Coding: 0000000
   Shop #: WSC 01065
   VCID: 62B761D6FD57
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 01065
   VCID: F0939B9EA3BB
Address 29: Left Light       Labels: None
   Controller: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Shop #: WSC 01065
   VCID: E6BFFDC6917F
Address 34: Level Control       Labels: None
   Controller: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Shop #: WSC 01065
   VCID: 272130C2D6F5
Address 36: Seat Mem. Drvr       Labels: None
   Controller: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1722
   Coding: 0000004
   Shop #: WSC 01065
   VCID: 6F9118E23E85
Address 37: Navigation       Labels: None
   Controller: 3D0 919 887 E
   Component:    NAVIGATION       0168
   Coding: 0400000
   Shop #: WSC 01065
   VCID: 361FED86015F
Address 38: Roof Electronics       Labels: None
   Controller: 3D0 907 135 C
   Component: Dachmodul           0708
   Coding: 0000062
   Shop #: WSC 01065
   VCID: 233924D2A2CD
Address 39: Right Light       Labels: None
   Controller: 3D0 909 158
   Shop #: WSC 01065
   VCID: E7A1F0C29675
Address 46: Central Conv.       Labels: None
   Controller: 3D0 959 933 F
   Component: X3 HSG              0102
   Coding: 0000040
   Shop #: WSC 01065
   VCID: 3319D492122D
00131 -  Outside Door Handle Illumination/mirror Light Driver Side
            012 -  Electrical Fault in Circuit - Intermittent
00132 -  Outside Door Handle Illumination/mirror Light Passenger Side
00930 -  Locking Module for Central Locking; Rear Left (F222)
            008 -  Implausible Signal
Address 47: Sound System       Labels: None
   Controller: 3D0 035 465 A
   Component: 08K-AUDIOVERST      0112
   Coding: 0000000
   VCID: 1F3128228EA5
Address 68: Wiper Electr.       Labels: None
   Controller: 3D2 955 120 A
   Component: Front Wiper         3000
   Coding: 0000000
   VCID: 20332BDEB3DB
Address 71: Battery Charger       Labels: None
   Controller: 3D0 915 181 D
   Component: Batteriemanagement  2800
   Coding: 0000000
   VCID: 243B27CEA7C3
Address 76: Park Assist       Labels: None
   Controller: 3D0 919 283 D
   Component: 01 Einparkhilfe     0907
   Coding: 0000000
   VCID: 2B29CCF2CA1D
End   --------------------------------------------------------------------------------------------------
How many miles on this car/engine/DPF?
Have a look at MVB 104.
1. Oil Ash Volume
2. Soot Mass (Calculated)
3. Soot Mass (Measured)
4. Distance since last regeneration
102 is also worth looking at. Field 3 should have the differential pressure across the DPF. This should be darn close to zero with the engine not running.
Raven23c
C?ID=130714
127,566 miles
MVB 102
1. 110*C
2. 100*
3. 7.8 mbar
4. 7.8 mbar
MVB 104
1. 0.43
2. 66.9
3. 33.00
4. 1910 km
Raven23c
C?ID=130714
MVB 102 (Engine NOT running)
3. 0.0 mbar
golfi_vend
Tartu, Estonia
C?ID=195131
Field 102.3 is difference pressure and .4 is offset correct...?
If offset is other than 0(or darn close value) i highly recomend changing the sensor.
Raven23c
C?ID=130714
Thanks for your help Uwe, I did a 120 mile motorway journey last Friday, parked the car for the weekend then set off to do the return journey on Sunday, after around 5 miles I stopped for 10 mins. I'm wondering if the regen was maybe underway when I stopped? When I resumed my journey almost straight away the car went into 'limp' mode.
Yes, that's correct, at least according to the info I'm looking at.
Raven23c
C?ID=130714
I looked at that link Uwe but I don't have the 'Coding' option on the VCDS-Lite interface
Then use Login. It's the same button / function, just named differently depending on the protocol the ECU uses.
Raven23c
C?ID=130714
okay guys, a fresh start and a new day, after following the guide on the link posted by Uwe and at the third attempt logging out of VCDS-Lite and starting again the regen worked.
Raven23c
C?ID=130714
I followed all the prequesisites;
Ignition ON
Engine ON (Idle)
Oil Temperature above 70 °C (see MVB 007.2)
Particle Filter Load below 68g (see MVB 104.3)
If the Particle Filter Load is above 68g the Particle Filter needs to be replaced since the car may burn down when regenerating.
Engine Hood CLOSED
Parking Brake ENGAGED
Transmission in (P)ARK
Temperatures at the Exhaust System may rise up to 300 °C!!!
No Fault Codes Stored
Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Con
trol)
Selected 01 (Engine)
Login 11 then entered the code 10016
A pop-up appeared saying code accepted by controller.
The engine revs didn't increase and nothing seemed to happen.
I opened Measuring Blocks and entered;
100 (Go!)
101 (Go!)
102 (Go!)
Readings were as follows;
100
1. 756 /min
2. 135.7*C
3. 0.0
4. 1 (1 = Abort recognised)
101
1. 11111111
2. 11110111
3. 00000000
4. 000
102.
1. 145.0*C
2. 135.7*C
3. 7.8 mbar
4. 7.8 mbar
I switched off the ignition, closed VCDS-Lite an started the process again....
This time after following all the precursors and entering the code 10016 in Login 11 the engine revs immediately increased to approx 1,500 rpm.
I opened Measuring Blocks.
100
1. 1512 /min
2. 578.2*C
3. 112
4. 0
101
1. 11111111
2. 11111111
3. 00000000
4. 010 (Regeneration)
102.
1. 626.4*C
2. 578.2*C
3. 27.4 mbar
4. 7.8 mbar
After about 20 mins Measuring Blocks showed the following;
100
1. 1533 /min
2. 566.4*C
3. 204.0
4. 0
101
1. 11111111
2. 11110111
3. 00000000
4. 000
102.
1. 620.6*C
2. 572.3*C
3. 23.5 mbar
4. 7.8 mbar
Regeneration took about 25 minutes then the engine revs dropped. Measuring Block readings then showed the following;
100
1. 1092 /min
2. 354.0*C
3. 0.0
4. 0
101
1. 11111111
2. 11110111
3. 00000000
4. 100
102.
1. 295.8*C
2. 354.0*C
3. 15.7 mbar
4. 7.8 mbar
After approx 5 mins the revs dropped to idle, the Measuring Blocks then showed the following;
100
1. 735 /min
2. 300.9*C
3. 0.0
4. 0
101
1. 11111111
2. 11111111
3. 00000000
4. 000
102.
1. 255.2*C
2. 300.9*C
3. 7.8 mbar
4. 7.8 mbar
I left the engine running for while, switched off the lights, heated seats, demister and window heater then cleared the Engine fault codes.
I took the car for a test drive and so far so good. I'll update if there are any changes.
A huge thanks to Uwe and Andy at Ross-Tech for your help and your patience.
Robbie-rocket-pants
C?ID=255291
my 2011 Phaeton has engine type CEXA 3.0 V6 TDI.
There's a "Diesel Particulate Filter - Owners Manual" warning on the dash. I have looked at the Ross Tech Wiki and tried to do a regen but the code to access the controller (10016) is not being accepted.
Does anyone know of any other codes ?
Also there are no Fault Codes stored, but I'm wondering if it might be a faulty DPF sensor as it says the last regen was done at 0 km and MVB 102.3 and 102.4 look slightly suspicious to me.
MVB 102 - Engine running.
1. 130*C
2. 94*C
3. 6 mbar
4. 0 mbar
MVB 104 - Engine running
1. 0.1
2. 44.0
3. 40.0
4. 0 km
MVB 102 - Engine NOT running
3. 0.0 mbar
Thanks,
Robbie
Tuesday,05,March,2019,11:30:20:40164
VCDS Version: 18.9.1.0
VIN: WVWZZZ3DZB8005546   License Plate: SA61
Mileage: 141860km-88147mi   Repair Order:
Chassis Type: 3D-VW61 (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 28 34 36 37 38 42 46
          47 52 55 56 62 68 71 72 76 77
VIN: WVWZZZ3DZB8005546   Mileage: 141860km-88147miles
28-HVAC, Rear -- Status: Not registered 0001
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CEX)       Labels: None
   Part No SW: 3D0 907 401 H    HW: 3D0 907 401 D
   Component: 3.0TDI EDC17G000AG  0010
   Revision: --H05---    Serial number: VWX3Z0J1929198
   Coding: 0406002C191F0160
   Shop #: WSC 95147 753 45725
   VCID: 2447BA87E4471B6A99-5106
   Part No SW: 09L 927 760 R    HW: GS1 911 4
   Component: AG6 09L 3,0 TDI RdW 3606
   Revision: --H05---    Serial number:        4602718
   Shop #: WSC 01065 000 00000
   VCID: 4683000F323B097AA7-5140
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H35 0047
   Coding: 0008356
   VCID: 6BD591BB4919141218-5122
   Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
   Component:    Kessy            6850
   Revision: 00H23072    Serial number: VWX3Z0J1929198
   Coding: 0004328
   VCID: 2A5B54BF8163CD1AA3-807E
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Coding: 0000003
   VCID: 77FDBDCB0251A0F2EC-8022
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0035
   Revision: ABH64001    Serial number: VWZ6Z7M0168023
   VCID: 63C5F99BA6C95C52A0-8036
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 M
   Component: Climatronic D1      2039
   VCID: 285FAEB79F6FFF0AB5-807C
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 P    HW: 3D0 937 049 P
   Component: J519                7600
   Revision: -4006---    Serial number: --------------
   Coding: 618C0000AB2115825502770000000000
   VCID: 377D7DCB42D160F22C-8062
   Part No: 3D0 909 601 F
   Component: 0S Airbag 8.4E+ H13 1155
   Coding: 0012371
   VCID: 2643A08F957BE97A87-8072
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000012
   VCID: 479D0D0B323110725C-8012
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No SW: 3D0 920 983 G    HW: 3D0 920 983 G
   Component: J285 KOMBI-INST.    1421
   Revision: KPH06V04
   Coding: 0039411
   Shop #: WSC 00835 210 72160
   VCID: 2D515FA3B48DDA2246-8078
   Part No: 3D0 815 005 AP
   Component: J737__Standheizung  4405
   Revision: 00084000    Serial number: 09020869A00000
   VCID: 6BD591BB4A19141218-803E
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3D0 920 983 G
   Component: J533  GW-K-CAN TP20 1421
   Coding: 7FF2F7AE3B011003
   VCID: 70EF86D7633FF7CA2D-8024
                    Reset counter: 97
                    Mileage: 141830 km
                    Date: 2019.03.04
                    Time: 10:50:52
Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
   Part No: 3D0 919 158 B
   Component: Klima-Bedienteil D1 0117
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Coding: 0005521
   VCID: 275DAD8B9271F072BC-8072
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Coding: 0000004
   VCID: 6FED85AB7A01E83234-803A
Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
   Part No SW: 3D0 035 680 B    HW: 3D0 035 680 B
   Component: RNS-MID       H64 1230
   Revision: AB001001    Serial number: VWZ6Z7M0168023
   Coding: 020100420000002040
   Shop #: WSC 77012 210 82037
   VCID: 1F4DB56B0E2138B2C4-804A
00856 - Radio Antenna
                    Fault Frequency: 19
                    Reset counter: 98
                    Mileage: 141824 km
                    Date: 2019.03.04
                    Time: 10:51:01
03829 - External Bluetooth Module
                    Reset counter: 98
                    Mileage: 141824 km
                    Date: 2019.03.04
                    Time: 10:51:21
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 F
   Component: Dachmodul           0903
   Coding: 0012351
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 M
   Component: 6Z HSG              8133
   Coding: 0000040
   Shop #: WSC 77012 210 91867
   VCID: 3A7B64FF76C37D9AD3-4AE8
   Subsystem 1 - Part No: 3D2 959 701 H
   Component: Tuersteuergeraet FS 0202
   Subsystem 2 - Part No: 3D2 959 702 H
   Component: Tuersteuergeraet BF 0202
   Subsystem 3 - Part No: 3D0 959 703 G
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 3D0 959 704 G
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 3D0 909 610 F
   Component: 3P HDSG             2630
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
00896 - Trunk Lock Unit (F256)
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No SW: 3D0 035 465 C    HW: 3D0 035 465 C
   Component: 08K Audioverst.     0120
   Revision: 00005000    Serial number: 00000000237609
   VCID: 2149B393F8550E42F2-8074
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Coding: 012E00000B000200
   Shop #: WSC 01065 000 00038
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 366370CF89DB99FA37-8062
   Subsystem 1 - Part No: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 3D0 941 329 A  Labels: 3D0-941-329.CLB
Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
                    Fault Frequency: 19
                    Reset counter: 98
                    Mileage: 141824 km
                    Date: 2019.03.04
                    Time: 10:51:01
                    Reset counter: 98
                    Mileage: 141824 km
                    Date: 2019.03.04
                    Time: 10:51:21
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D2 955 120 B
   Component: Front Wiper         3501
   Coding: 0015733
   Shop #: WSC 01065 000 376832
   VCID: 2149B393FC550E42F2-8074
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 E
   VCID: 2541A783E87DE2628E-8070
   Part No: 3D0 919 283 E
   Component: 10 Einparkhilfe     1107
   VCID: 2C5752A78B97D32A51-8078
   Part No SW: 3D0 035 730 A    HW: 3D0 035 730 A
   Component: Telefon       016 0422
   Revision: --------    Serial number: 35909603292512
   Coding: 020100010100011000000000
   Shop #: WSC 01065 123 00022
   ASAM Dataset: EV_UHVPremiPhaet A01002
   ROD: EV_UHVPremiPhaet.rod
   VCID: 1A3B847F1D035D9A33-804E
End-------------------------
Warning on dash with no fault codes from the ECU makes little sense. Any chance the ECU has been "tuned"?
I would fix the Gateway Installation List:
[Select]
[19-CAN Gateway]
[Installation List]
Scroll down to 28-HVAC Rear and put a tick mark next to it.
[Save Coding]
But I rather doubt this will have any effect on the problem at hand.
Robbie-rocket-pants
C?ID=255291
[Select]
[19-CAN Gateway]
[Installation List]
[Save Coding]
Thanks Uwe.
The ECU is standard.
The other faults are just to do with a rear HVAC I installed (It works but I cannot get rid of the error even if I tick the box as it is from an older model Phaeton) and an aerial problem. They have been there for ages so I know they aren't anything to do with the DPF problem.
Although there appears to be no Fault codes with Engine when I run Auto-Scan, strangely there is "Mode 03: emissions related fault codes" if I use "OBD-II Functions" in VCDS.
Any news on a security code to do a DPF regen on the CEXA engine?
Also has there been any progress on creating an "Adaptation" for the G450 sensor, incase I have to replace it ?
Thank you for your help.
Robbie-rocket-pants
C?ID=255291
So I changed the G450 DPF pressure sensor and I went for a drive and the car has done a regen and my problem is fixed.
But I never could get the car to do a forced regen using VCDS. I tried codes 10016, 27971 and 12233.
Do you have any other code suggestions incase I need to try a regen in the future please ?
