Results 1 to 10 of 16
Thread: VW Phaeton 3.0 tdi (BMK)
    Verified VCDS-Lite User
    Aug 2018
    Hi all,
    My first post....I have an issue with my Phaeton, the car is in 'limp mode' Exhaust Workshop warning on start up and MIL is on along with the Glowplug light flashing.
    In regards to 009263 - Diesel Particulate Filter (Bank 1): Restricted/Clogged P242F - 001 - Upper Limit Exceeded I'd like to check the DPF soot level and if its below the required level perform a DPF regen. (Hoping that this will resolve the issue)
    I'm using a registered version of VCDS-Lite can someone tell me how i need to go about this in step-by-step detail?
    There are a number of videos online but the VCDS and VCDS-Lite interface is slightly different.
    Which measuring block shows the DPF info? Should the soot level be below 68% or below 68g? How is it displayed?
    Do I need the Login code or the Security code before performing a DPF regen? If so what are they?
    Is there a chance the issue could be a faulty DPF pressure sensor G450? How do I test the sensor individually? (If it is the sensor who the hell decided to put it on top of the gearbox!!!)
    Any help or advice appreciated.
    Once I get the DPF issue resolved I'll move onto the other fault codes....
    Thursday, 09 August 2018, 19:13:13:18525
    Chassis Type: 3D - VW Phaeton D1
    Scan: 01,02,03,05,06,07,08,09,11,13,15,16,17,18,19,23,27,28,29,2E,34,36,37,38,39,46,47,55,56,57,65,66,68,69,71,75,76,77
    Address 01: Engine       Labels: None
       Controller: 3D0 907 401 A
       Component: 3.0L V6TDI  G000AG  0010
       Coding: 0011773
       Shop #: WSC 01065
       VCID: 1D4D122A84A9
    Readiness: N/A
    Address 02: Auto Trans       Labels: None
       Controller: 09L 927 760 J
       Component: AG6 09L 3.0lTDI RdW 2205
       VCID: 3E0FF5A6296F
    Address 03: ABS Brakes       Labels: None
       Controller: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008356
       Shop #: WSC 01065
       VCID: 6BA90CF20A9D
    Address 05: Acc/Start Auth.       Labels: None
       Controller: 3D0 909 139
       Component: 0C Kessy            6700
       Coding: 0004328
       Shop #: WSC 01065
       VCID: E6BFFDC6917F
    00165 -  Switch for Transmission Position P/N
                007 -  Short to Ground - Intermittent
    Address 06: Seat Mem. Pass       Labels: None
       Controller: 3D0 959 759 CA
       Component: Sitzmemory D1 BF    1722
       Coding: 0000003
       Shop #: WSC 01065
       VCID: 7781208246D5
    Address 07: Control Head       Labels: None
       Controller: 3D0 035 017 X
       Component:    ZAB COCKPIT      0253
       Coding: 0000000
       VCID: 2F11D8E2FE05
    01042 -  Control Module; Not Coded
                000 -   -
    01044 -  Control Module Incorrectly Coded
                000 -   -
    00668 -  Supply Voltage Terminal 30
                002 -  Lower Limit Exceeded - Intermittent
    Address 08: Auto HVAC       Labels: None
       Controller: 3D0 907 040 J
       Component: Climatronic D1      2031
       Shop #: WSC 01065
       VCID: 253D3ACAACF9
    Address 09: Cent. Elect.       Labels: None
       Controller: 3D0 937 049 J
       Component: J519                1001
       Coding: 600100002A2115000000000000000000
       Shop #: WSC 01065
       VCID: 3115DE9AE831
    01494 -  Bulb for Parking Lamps; Left (M1)
                011 -  Open Circuit - Intermittent
    Address 16: Steering wheel       Labels: None
       Controller: 3D0 953 549 D
       Component: Lenksäulenmodul     3401
       Coding: 0000032
       Shop #: WSC 01065
       VCID: 2E2FC5E6F90F
    Address 17: Instruments       Labels: None
       Controller: 3D0 920 982 H
       Component: KOMBIINSTRUMENT RB8 0610
       Coding: 0023411
       Shop #: WSC 01065
       VCID: 2D2DC2EAF409
    Address 18: Aux. Heat       Labels: None
       Controller: 3D0 815 005 AG
       Component: Standheizung        2426
       Coding: 0000000
       Shop #: WSC 01065
       VCID: 62B761D6FD57
    Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
       Controller: 6N0 909 901
       Coding: 0000006
       Shop #: WSC 01065
       VCID: F0939B9EA3BB
    Address 29: Left Light       Labels: None
       Controller: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       Shop #: WSC 01065
       VCID: E6BFFDC6917F
    Address 34: Level Control       Labels: None
       Controller: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005521
       Shop #: WSC 01065
       VCID: 272130C2D6F5
    Address 36: Seat Mem. Drvr       Labels: None
       Controller: 3D0 959 760 CA
       Component: Sitzmemory D1 F     1722
       Coding: 0000004
       Shop #: WSC 01065
       VCID: 6F9118E23E85
    Address 37: Navigation       Labels: None
       Controller: 3D0 919 887 E
       Component:    NAVIGATION       0168
       Coding: 0400000
       Shop #: WSC 01065
       VCID: 361FED86015F
    Address 38: Roof Electronics       Labels: None
       Controller: 3D0 907 135 C
       Component: Dachmodul           0708
       Coding: 0000062
       Shop #: WSC 01065
       VCID: 233924D2A2CD
    Address 39: Right Light       Labels: None
       Controller: 3D0 909 158
       Shop #: WSC 01065
       VCID: E7A1F0C29675
    Address 46: Central Conv.       Labels: None
       Controller: 3D0 959 933 F
       Component: X3 HSG              0102
       Coding: 0000040
       Shop #: WSC 01065
       VCID: 3319D492122D
    00131 -  Outside Door Handle Illumination/mirror Light Driver Side
                012 -  Electrical Fault in Circuit - Intermittent
    00132 -  Outside Door Handle Illumination/mirror Light Passenger Side
    00930 -  Locking Module for Central Locking; Rear Left (F222)
                008 -  Implausible Signal
    Address 47: Sound System       Labels: None
       Controller: 3D0 035 465 A
       Component: 08K-AUDIOVERST      0112
       Coding: 0000000
       VCID: 1F3128228EA5
    Address 68: Wiper Electr.       Labels: None
       Controller: 3D2 955 120 A
       Component: Front Wiper         3000
       Coding: 0000000
       VCID: 20332BDEB3DB
    Address 71: Battery Charger       Labels: None
       Controller: 3D0 915 181 D
       Component: Batteriemanagement  2800
       Coding: 0000000
       VCID: 243B27CEA7C3
    Address 76: Park Assist       Labels: None
       Controller: 3D0 919 283 D
       Component: 01 Einparkhilfe     0907
       Coding: 0000000
       VCID: 2B29CCF2CA1D
    End   --------------------------------------------------------------------------------------------------
    How many miles on this car/engine/DPF?
    Have a look at MVB 104.
    1. Oil Ash Volume
    2. Soot Mass (Calculated)
    3. Soot Mass (Measured)
    4. Distance since last regeneration
    102 is also worth looking at. Field 3 should have the differential pressure across the DPF. This should be darn close to zero with the engine not running.
  3. Likes Raven23c liked this post
    Aug 2018
    127,566 miles
    MVB 102
    1. 110*C
    2. 100*
    3. 7.8 mbar
    4. 7.8 mbar
    MVB 104
    1. 0.43
    2. 66.9
    3. 33.00
    4. 1910 km
    Aug 2018
    MVB 102 (Engine NOT running)
    3. 0.0 mbar
    1910 km seems high. I wonder what's keeping it from regenerating automatically?
    The last procedure on this page should be applicable:
    http://wiki.ross-tech.com/wiki/index...y_Regeneration
    Tartu, Estonia
    Field 102.3 is difference pressure and .4 is offset correct...?
    If offset is other than 0(or darn close value) i highly recomend changing the sensor.
    The world is my oyster...
  8. Likes Raven23c liked this post
    Aug 2018
    Thanks for your help Uwe, I did a 120 mile motorway journey last Friday, parked the car for the weekend then set off to do the return journey on Sunday, after around 5 miles I stopped for 10 mins. I'm wondering if the regen was maybe underway when I stopped? When I resumed my journey almost straight away the car went into 'limp' mode.
  10. #8
    Yes, that's correct, at least according to the info I'm looking at.
  11. #9
    Aug 2018
    I looked at that link Uwe but I don't have the 'Coding' option on the VCDS-Lite interface http://www.ross-tech.com/vcds-lite/manual/open.html
  12. #10
    Quote Originally Posted by Raven23c View Post
    Then use Login. It's the same button / function, just named differently depending on the protocol the ECU uses.
