Results 11 to 20 of 22
Thread: Mk7 golf R Facelift MIB2.5 discover pro with 9.2 display retrofit
    Jan 2018
    Kuwait
    ADMAP FOR MODULE 17
    ;SW:5G1-920-791-A   HW:5G1-920-791-A ---  Instruments
    ;Component:KOMBI         408 3196	 Coding:47AD08183B80000801086B001400000000000000
    ;EV_DashBoardVDDMQBAB	9058	EV_DashBoardVDDMQBAB_009_VW37.rod
    ;Thursday	9	August	2018	13:47:18:35129
    ;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    ;VCID: 2A18ECE64D76101459-807E
    IDE00295-Oil temperature display	On 	1
    IDE00301-Distance	11619 km	3
    IDE00342-ESI: Resetting ESI	no warning 	1
    IDE00343-Language version	English 	1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
    IDE00499-Display correction of consumptions and operating range	100%	1
    IDE00500-Hour	12 H	1
    IDE00501-Minute	47 min	1
    IDE00502-Year	2018 yr	2
    IDE00503-Month	8 mon	1
    IDE00504-Day	9 d	1
    IDE00510-ESI: distance driven from inspection	27 km	3
    IDE00511-ESI: time from inspection	1 d	2
    IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
    IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
    IDE00514-ESI: maximum value of time between inspections	730 d	2
    IDE00515-ESI: oil quality	poor oil quality 	1
    IDE00517-ESI: soot entry	0 km	2
    IDE00518-ESI: thermal load	0 km	2
    IDE00819-Day counter	0 d	2
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE00827-ESI: minimum value of time between inspections	365 d	2
    IDE01153-SIA: maximum value of distance to service	15000 km	2
    IDE01154-SIA: maximum value of time to service	365 d	2
    IDE02489-Display depiction	Version 1 	1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.8 l	5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
    IDE03329-Driving profiled for range remaining	8.3 l/100km	2
    IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
    IDE03346-MAS01230-Units adjusted-Date	dd_mm_yy 	3
    IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
    IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
    IDE03346-MAS02957-Units adjusted-Time	24h 	3
    IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
    IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
    IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
    IDE03348-MAS01456-Speed warning-Speed	30	2
    IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
    IDE03348-Speed warning-	not active 	2
    IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	2
    IDE03350-FIX: Maximum time until next time-dependent inspection	1095 d	2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection	0 km	2
    IDE03352-FIX: Time since last time-dependent inspection	1 d	2
    IDE03372-Source for synchronization of time	GPS 	1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
    IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
    IDE03867-Deactivate seat belt warning	No 	1
    IDE05930-Service notification in days	30 d	1
    IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km	2
    IDE05932-FIX: Reset value for next time-dependent inspections	1095 d	2
    IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06588-Ignition active message: actuator	Driver door 	1
    IDE07221-Cylinder shut-off	Display 	1
    IDE11086-Service notification	30 d	1
    IDE11932-MAS01877-Display of colour adjustment-Red	0	3
    IDE11932-MAS01878-Display of colour adjustment-Green	0	3
    IDE11932-MAS01879-Display of colour adjustment-Blue	0	3
    IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation	not active 	1
    IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS	not active 	1
    MAS03555-Lap counter	No display 	1
    ENG117917-BAP_Debug_Mode_Release	not_released 	1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
    ENG119875-defuel_threshold	9 l	1
    ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1	00 00 	24
    ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2	00 0A 	24
    ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3	00 32 	24
    ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4	00 64 	24
    ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5	00 96 	24
    ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6	00 FD 	24
    ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1	00 32 	24
    ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2	00 32 	24
    ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3	00 78 	24
    ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4	00 E6 	24
    ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5	01 F4 	24
    ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6	03 E8 	24
    ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1	00 00 	24
    ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2	00 0A 	24
    ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3	00 64 	24
    ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4	00 96 	24
    ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5	00 DC 	24
    ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6	00 FD 	24
    ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1	00 09 	24
    ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2	00 09 	24
    ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3	00 50 	24
    ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4	01 90 	24
    ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5	03 52 	24
    ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6	03 E8 	24
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 01 	20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 32 	20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	01 2C 	20
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0A 	20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 32 	20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 96 	20
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
    ENG119874-Gas_functionality	not active 	1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
    ENG119882-init_fuel_algorithm	No 	1
    ENG130585-Leaving_warning_delay	1.6 s	1
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 C	16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 C	16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 C	16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
    ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
    ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 C	16
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
    ENG119825-Picture_Upload_Download	not active 	1
    ENG126396-Scale_switching_algorithm	lowbeam_foglight 	1
    ENG153765-Second_digital_speed	Display 	1
    ENG119876-Service_Key_Clear_All_Counter	Yes 	1
    ENG130584-Statistic_phev_mileage	5 km	1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s	18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
    ENG109442-ENG101663-time_parameter_display-tDD15_off	0.15	18
    ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
    ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
    ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
    ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
    ENG112418-ENG99298-total_range_gas-State	not active 	4
    ENG153766-Tube_version	variant_0 	1
    Elapsed Time: 00:27
    ;Component:KOMBI         408 3196	 Coding:47AD20183B80000801086B001400000000000000
    ;Saturday	11	August	2018	16:41:18:35129
    IDE00301-Distance	11731 km	3
    IDE00500-Hour	16 H	1
    IDE00501-Minute	41 min	1
    IDE00504-Day	11 d	1
    IDE00510-ESI: distance driven from inspection	139 km	3
    IDE00511-ESI: time from inspection	3 d	2
    IDE00518-ESI: thermal load	400 km	2
    IDE00819-Day counter	3 d	2
    IDE02489-Display depiction	Version 2 	1
    IDE03329-Driving profiled for range remaining	9.3 l/100km	2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection	100 km	2
    IDE03352-FIX: Time since last time-dependent inspection	3 d	2
    IDE03372-Source for synchronization of time	internal clock 	1
    ENG153766-Tube_version	variant_4 	1
    Elapsed Time: 00:26
  2. #12
    Jan 2018
    Kuwait
    admap 5f
    ;SW:3G0-035-045-C HW:3G0-035-045 --- Information Electr.
    ;Component:MU-H-N-RW H51 0687 Coding:0273000C0000000051110002001828001F0207F4012 00000DF
    ;EV_MUHig4CGen2HBAS	1001 EV_MUHig4CGen2HBAS_VW37.rod
    ;Saturday	11	August	2018	16:36:45:35129
    ;VCID: 1E703036013EECB435-804A
    IDE00001-Production mode	00 00 00 3
    IDE00346-Summertime-automatic	none 1
    IDE00759-Base volume of speech output	50%	1
    IDE00760-Microphone sensitivity	0 dB	1
    IDE00768-Country identification: country of sale	-- 2
    IDE00769-Number 1 for Info call	5E 07 A1 00 79 41 07 14 51 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE00770-Number 1 for roadside assistance	5E 07 A1 00 79 41 07 14 51 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 1
    IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 1
    IDE00845-Wheel circ.	0 mm	2
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module	Yes 3
    IDE01996-MAS00839-Installation list: specified installations-TV Tuner	No 3
    IDE01996-MAS00844-Installation list: specified installations-Radio	No 3
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module	Yes 3
    IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1	Yes 3
    IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2	No 3
    IDE01996-MAS04300-Installation list: specified installations-DVD changer	No 3
    IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module	No 3
    IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit	No 3
    IDE01996-ENG154341-Installation list: specified installations-Reserved_8	No 3
    IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1	No 3
    IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2	No 3
    IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1	No 3
    IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2	No 3
    IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1	No 3
    IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2	No 3
    IDE02121-CD eject button	Enabled 1
    IDE02122-Developer mode	not activated 1
    IDE02330-Number 2 for Info call	5E 07 A1 00 79 41 07 14 51 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE02331-Number 2 for roadside assistance	5E 07 A1 00 79 41 07 14 51 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE02332-Deactivate production mode	0	3
    IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic 49
    IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	22	49
    IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz	49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	22	49
    IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz	49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	22	49
    IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz	49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	22	49
    IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz	49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	22	49
    IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz	49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	22	49
    IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz	49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	22	49
    IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz	49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	22	49
    IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	22	49
    IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	22	49
    IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	22	49
    IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	22	49
    IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	22	49
    IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	22	49
    IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	22	49
    IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	22	49
    IDE02502-Confirmation of installation change	64 13 2
    IDE02506-MAS03229-Copy multimedia data-Data medium	On 1
    IDE02506-MAS03230-Copy multimedia data-Optical drive	On 1
    IDE02607-Wheel pulse	0	2
    IDE02699-Number 1 for roadside assistance	5E 02 A1 99 F9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE02701-Number 1 (roaming) for roadside assistance	5E 02 A1 99 F9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF 30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing	OFF 30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO	On 30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless	OFF 30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life OFF 30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios	OFF 30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless	OFF 30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless	OFF 30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb	blocked 30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant	0	30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	On 30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support	OFF 30
    IDE03471-ENG185778-Vehicle configuration-FoD	SWaP 30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL	On 30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless	OFF 30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	On 30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	On 30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	OFF 30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	OFF 30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data	not activated 30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender	Deactivated 30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1 Not Present 30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2 Not Present 30
    IDE03471-ENG127492-Vehicle configuration-LGI	OFF 30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul Deactivated 30
    IDE03471-ENG142142-Vehicle configuration-map_email_support	OFF 30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support	OFF 30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support	OFF 30
    IDE03471-ENG142152-Vehicle configuration-Map_Style	0	30
    IDE03471-ENG152537-Vehicle configuration-media_control not activated 30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link	On 30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code	MIB_EU 30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference	RGB565 30
    IDE03471-ENG117843-Vehicle configuration-my_audi	OFF 30
    IDE03471-ENG117845-Vehicle configuration-online_dictation OFF 30
    IDE03471-ENG127495-Vehicle configuration-online_media OFF 30
    IDE03471-ENG117840-Vehicle configuration-online_navigation OFF 30
    IDE03471-ENG117837-Vehicle configuration-online_POI	OFF 30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice OFF 30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	OFF 30
    IDE03471-ENG152553-Vehicle configuration-online_radio Deactivated 30
    IDE03471-ENG117841-Vehicle configuration-online_street_view	OFF 30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF 30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold	0	30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis	0	30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy	0	30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	only data service act. 30
    IDE03471-ENG117844-Vehicle configuration-picture_navi	On 30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking	not activated 30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use	not activated 30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest	0	30
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	OFF 30
    IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo OFF 30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.5 30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI	OFF 30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component	activated 30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open	not activated 30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold	not activated 30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe not activated 30
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input FBAS 30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony not activated 30
    IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation	no restriction 30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag REGION_ROW_MIDDLEEAST 30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch	not activated 30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	present 30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support	OFF 30
    IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi	activated 30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	0	30
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF 30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	OFF 30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone	On 30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location	OFF 30
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability OFF 30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving	blocked 30
    IDE03471-ENG137647-Vehicle configuration-UOTA	OFF 30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2	OFF 30
    IDE03471-ENG117852-Vehicle configuration-UPnP	On 30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound	not activated 30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound	not activated 30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte not activated 30
    IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF 30
    IDE03471-ENG127494-Vehicle configuration-VZO	OFF 30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI On 30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	On 30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch	not activated 30
    IDE03902-Automatic ring break diagnostic	No automatic start 1
    IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP 1
    IDE04298-MAS01779-Vehicle dimensions-Length	0 mm	6
    IDE04298-MAS01780-Vehicle dimensions-Width	0 mm	6
    IDE04298-MAS02230-Vehicle dimensions-Height	0 mm	6
    IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 4
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code	2	2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code	2	2
    IDE04521-Sporadic ring break detection	Visual 1
    IDE04522-Awakening ability on optical databus	OFF 1
    IDE04550-Bluetooth: Sniff mode	OFF 1
    IDE05111-Fee-based traffic information (TMC)	65535	2
    IDE05113-Infotainment Recorder	activated 1
    IDE06697-Audio management mute function	Muting of audio sources 1
    IDE07399-ENG142045-Engine type-Engine_type_adaption_1 Petrol 1
    IDE07399-ENG142046-Engine type-Engine_type_adaption_2 Petrol 1
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	On 1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	On 1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	On 1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	On 1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	5	40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-3	40
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	6	40
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
    IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 4
    IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated 4
    IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 4
    IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 4
    IDE10604-Menu entries for mobile online services	not activated 1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold	37 dBV	3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation	32 dB	3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo	15.0 s	3
    IDE11105-Brand-specific display of connect application	256
    IDE11122-Country identification: country of sale HMI	AE 2
    IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength	4294967295	330
    IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle	65535	330
    IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle	65535	330
    IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos	32767	330
    IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle	65535	330
    IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos	32767	330
    IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos	32767	330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0 non_blocked 21
    IDE11502-ENG127602-Locked menu contents-FB_CAR_1 non_blocked 21
    IDE11502-ENG127611-Locked menu contents-FB_CAR_10 non_blocked 21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11 non_blocked 21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12 non_blocked 21
    IDE11502-ENG127614-Locked menu contents-FB_CAR_13 non_blocked 21
    IDE11502-ENG127615-Locked menu contents-FB_CAR_14 non_blocked 21
    IDE11502-ENG127616-Locked menu contents-FB_CAR_15 non_blocked 21
    IDE11502-ENG127617-Locked menu contents-FB_CAR_16 non_blocked 21
    IDE11502-ENG127618-Locked menu contents-FB_CAR_17 non_blocked 21
    IDE11502-ENG127619-Locked menu contents-FB_CAR_18 non_blocked 21
    IDE11502-ENG127620-Locked menu contents-FB_CAR_19 non_blocked 21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2 non_blocked 21
    IDE11502-ENG127621-Locked menu contents-FB_CAR_20 non_blocked 21
    IDE11502-ENG127622-Locked menu contents-FB_CAR_21 non_blocked 21
    IDE11502-ENG127623-Locked menu contents-FB_CAR_22 non_blocked 21
    IDE11502-ENG127624-Locked menu contents-FB_CAR_23 non_blocked 21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3 non_blocked 21
    IDE11502-ENG127605-Locked menu contents-FB_CAR_4 non_blocked 21
    IDE11502-ENG127606-Locked menu contents-FB_CAR_5 non_blocked 21
    IDE11502-ENG127607-Locked menu contents-FB_CAR_6 non_blocked 21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7 non_blocked 21
    IDE11502-ENG127609-Locked menu contents-FB_CAR_8 non_blocked 21
    IDE11502-ENG127610-Locked menu contents-FB_CAR_9 non_blocked 21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0 non_blocked 21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1 non_blocked 21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10 non_blocked 21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11 non_blocked 21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12 non_blocked 21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13 non_blocked 21
    IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14 non_blocked 21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15 non_blocked 21
    IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16 non_blocked 21
    IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17 non_blocked 21
    IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18 non_blocked 21
    IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19 non_blocked 21
    IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2 non_blocked 21
    IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20 non_blocked 21
    IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21 non_blocked 21
    IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22 non_blocked 21
    IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23 non_blocked 21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3 non_blocked 21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4 non_blocked 21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5 non_blocked 21
    IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6 non_blocked 21
    IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7 non_blocked 21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8 non_blocked 21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9 non_blocked 21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0 non_blocked 21
    IDE11502-ENG127626-Locked menu contents-FB_MISC_1 non_blocked 21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10 non_blocked 21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11 non_blocked 21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12 non_blocked 21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13 non_blocked 21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14 non_blocked 21
    IDE11502-ENG127640-Locked menu contents-FB_MISC_15 non_blocked 21
    IDE11502-ENG127641-Locked menu contents-FB_MISC_16 non_blocked 21
    IDE11502-ENG127642-Locked menu contents-FB_MISC_17 non_blocked 21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18 non_blocked 21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19 non_blocked 21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2 non_blocked 21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20 non_blocked 21
    IDE11502-ENG127646-Locked menu contents-FB_MISC_21 non_blocked 21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22 non_blocked 21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23 non_blocked 21
    IDE11502-ENG127649-Locked menu contents-FB_MISC_24 non_blocked 21
    IDE11502-ENG127650-Locked menu contents-FB_MISC_25 non_blocked 21
    IDE11502-ENG127651-Locked menu contents-FB_MISC_26 non_blocked 21
    IDE11502-ENG127652-Locked menu contents-FB_MISC_27 non_blocked 21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28 non_blocked 21
    IDE11502-ENG127654-Locked menu contents-FB_MISC_29 non_blocked 21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3 non_blocked 21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30 non_blocked 21
    IDE11502-ENG127656-Locked menu contents-FB_MISC_31 non_blocked 21
    IDE11502-ENG127657-Locked menu contents-FB_MISC_32 non_blocked 21
    IDE11502-ENG127658-Locked menu contents-FB_MISC_33 non_blocked 21
    IDE11502-ENG127659-Locked menu contents-FB_MISC_34 non_blocked 21
    IDE11502-ENG127660-Locked menu contents-FB_MISC_35 non_blocked 21
    IDE11502-ENG127661-Locked menu contents-FB_MISC_36 non_blocked 21
    IDE11502-ENG127662-Locked menu contents-FB_MISC_37 non_blocked 21
    IDE11502-ENG127663-Locked menu contents-FB_MISC_38 non_blocked 21
    IDE11502-ENG127664-Locked menu contents-FB_MISC_39 non_blocked 21
    IDE11502-ENG127629-Locked menu contents-FB_MISC_4 non_blocked 21
    IDE11502-ENG127665-Locked menu contents-FB_MISC_40 non_blocked 21
    IDE11502-ENG127666-Locked menu contents-FB_MISC_41 non_blocked 21
    IDE11502-ENG127667-Locked menu contents-FB_MISC_42 non_blocked 21
    IDE11502-ENG127668-Locked menu contents-FB_MISC_43 non_blocked 21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44 non_blocked 21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45 non_blocked 21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46 non_blocked 21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47 non_blocked 21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5 non_blocked 21
    IDE11502-ENG127631-Locked menu contents-FB_MISC_6 non_blocked 21
    IDE11502-ENG127632-Locked menu contents-FB_MISC_7 non_blocked 21
    IDE11502-ENG127633-Locked menu contents-FB_MISC_8 non_blocked 21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9 non_blocked 21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0 non_blocked 21
    IDE11502-ENG127562-Locked menu contents-FB_NAV_1 non_blocked 21
    IDE11502-ENG127571-Locked menu contents-FB_NAV_10 non_blocked 21
    IDE11502-ENG127572-Locked menu contents-FB_NAV_11 non_blocked 21
    IDE11502-ENG127573-Locked menu contents-FB_NAV_12 non_blocked 21
    IDE11502-ENG127574-Locked menu contents-FB_NAV_13 non_blocked 21
    IDE11502-ENG127575-Locked menu contents-FB_NAV_14 non_blocked 21
    IDE11502-ENG127576-Locked menu contents-FB_NAV_15 non_blocked 21
    IDE11502-ENG127577-Locked menu contents-FB_NAV_16 non_blocked 21
    IDE11502-ENG127578-Locked menu contents-FB_NAV_17 non_blocked 21
    IDE11502-ENG127579-Locked menu contents-FB_NAV_18 non_blocked 21
    IDE11502-ENG127580-Locked menu contents-FB_NAV_19 non_blocked 21
    IDE11502-ENG127563-Locked menu contents-FB_NAV_2 non_blocked 21
    IDE11502-ENG127581-Locked menu contents-FB_NAV_20 non_blocked 21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21 non_blocked 21
    IDE11502-ENG127583-Locked menu contents-FB_NAV_22 non_blocked 21
    IDE11502-ENG127584-Locked menu contents-FB_NAV_23 non_blocked 21
    IDE11502-ENG127585-Locked menu contents-FB_NAV_24 non_blocked 21
    IDE11502-ENG127586-Locked menu contents-FB_NAV_25 non_blocked 21
    IDE11502-ENG127587-Locked menu contents-FB_NAV_26 non_blocked 21
    IDE11502-ENG127588-Locked menu contents-FB_NAV_27 non_blocked 21
    IDE11502-ENG127589-Locked menu contents-FB_NAV_28 non_blocked 21
    IDE11502-ENG127590-Locked menu contents-FB_NAV_29 non_blocked 21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3 non_blocked 21
    IDE11502-ENG127591-Locked menu contents-FB_NAV_30 non_blocked 21
    IDE11502-ENG127592-Locked menu contents-FB_NAV_31 non_blocked 21
    IDE11502-ENG127593-Locked menu contents-FB_NAV_32 non_blocked 21
    IDE11502-ENG127594-Locked menu contents-FB_NAV_33 non_blocked 21
    IDE11502-ENG127595-Locked menu contents-FB_NAV_34 non_blocked 21
    IDE11502-ENG127596-Locked menu contents-FB_NAV_35 non_blocked 21
    IDE11502-ENG127597-Locked menu contents-FB_NAV_36 non_blocked 21
    IDE11502-ENG127598-Locked menu contents-FB_NAV_37 non_blocked 21
    IDE11502-ENG127599-Locked menu contents-FB_NAV_38 non_blocked 21
    IDE11502-ENG127600-Locked menu contents-FB_NAV_39 non_blocked 21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4 non_blocked 21
    IDE11502-ENG127566-Locked menu contents-FB_NAV_5 non_blocked 21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6 non_blocked 21
    IDE11502-ENG127568-Locked menu contents-FB_NAV_7 non_blocked 21
    IDE11502-ENG127569-Locked menu contents-FB_NAV_8 non_blocked 21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9 non_blocked 21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0 non_blocked 21
    IDE11502-ENG127546-Locked menu contents-FB_PHONE_1 non_blocked 21
    IDE11502-ENG127555-Locked menu contents-FB_PHONE_10 non_blocked 21
    IDE11502-ENG127556-Locked menu contents-FB_PHONE_11 non_blocked 21
    IDE11502-ENG127557-Locked menu contents-FB_PHONE_12 non_blocked 21
    IDE11502-ENG127558-Locked menu contents-FB_PHONE_13 non_blocked 21
    IDE11502-ENG127559-Locked menu contents-FB_PHONE_14 non_blocked 21
    IDE11502-ENG127560-Locked menu contents-FB_PHONE_15 non_blocked 21
    IDE11502-ENG127547-Locked menu contents-FB_PHONE_2 non_blocked 21
    IDE11502-ENG127548-Locked menu contents-FB_PHONE_3 non_blocked 21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4 non_blocked 21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5 non_blocked 21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6 non_blocked 21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7 non_blocked 21
    IDE11502-ENG127553-Locked menu contents-FB_PHONE_8 non_blocked 21
    IDE11502-ENG127554-Locked menu contents-FB_PHONE_9 non_blocked 21
    IDE11502-ENG127505-Locked menu contents-FB_TUNER_0 non_blocked 21
    IDE11502-ENG127506-Locked menu contents-FB_TUNER_1 non_blocked 21
    IDE11502-ENG127515-Locked menu contents-FB_TUNER_10 non_blocked 21
    IDE11502-ENG127516-Locked menu contents-FB_TUNER_11 non_blocked 21
    IDE11502-ENG127517-Locked menu contents-FB_TUNER_12 non_blocked 21
    IDE11502-ENG127518-Locked menu contents-FB_TUNER_13 non_blocked 21
    IDE11502-ENG127519-Locked menu contents-FB_TUNER_14 non_blocked 21
    IDE11502-ENG127520-Locked menu contents-FB_TUNER_15 non_blocked 21
    IDE11502-ENG127507-Locked menu contents-FB_TUNER_2 non_blocked 21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3 non_blocked 21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4 non_blocked 21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5 non_blocked 21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6 non_blocked 21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7 non_blocked 21
    IDE11502-ENG127513-Locked menu contents-FB_TUNER_8 non_blocked 21
    IDE11502-ENG127514-Locked menu contents-FB_TUNER_9 non_blocked 21
    IDE11638-Bluetooth Audio Codec	FF 1
    IDE12266-Follow on time for telephone	activated 1
    IDE12353-Configuration of traffic light online functions	On 1
    MAS00951-Bluetooth	On 1
    MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
    MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
    MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
    MAS03782-WLAN	On 1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off	OFF 12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time	0.00 ms	12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off	OFF 12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time	0.00 ms	12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off	OFF 12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time	0.00 ms	12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off	OFF 12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time	0.00 ms	12
    ENG117920-Audio_Managment_Soundset_Menu	OFF 1
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 60
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 60
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 60
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 60
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	not activated 60
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 60
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	not activated 60
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated 60
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 60
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated 60
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 60
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 60
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 60
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 60
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 60
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 60
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 60
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 60
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 60
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated 60
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 60
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_h igh activated 60
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 60
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 60
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 60
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 60
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 60
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 60
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_discla imer	not activated 60
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 60
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_thresho ld_high not activated 60
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 60
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 60
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 60
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 60
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	not activated 60
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 60
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated 60
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 60
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 60
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 60
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_hig h not activated 60
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	activated 60
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 60
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	activated 60
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 60
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 60
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high activated 60
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	activated 60
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 60
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	activated 60
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	activated 60
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 60
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	activated 60
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 60
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 60
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 60
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 60
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 60
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_hi gh activated 60
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated 60
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 60
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated 60
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated 60
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 60
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_hi gh activated 60
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 60
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 60
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 60
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 60
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 60
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 60
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 60
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 60
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 60
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 60
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 60
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 60
    ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 60
    ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaime r	not activated 60
    ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 60
    ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_ high not activated 60
    ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 60
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 60
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 60
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 60
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated 60
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 60
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated 60
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 60
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 60
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 60
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 60
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 60
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated 60
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 60
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated 60
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 60
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaime r	not activated 60
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_ high activated 60
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 60
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 60
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 60
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 60
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 60
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 60
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 60
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 60
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated 60
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 60
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 60
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated 60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	not activated 60
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaim er	not activated 60
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high	not activated 60
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 60
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 60
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 60
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 60
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 60
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 60
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 60
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated 60
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 60
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated 60
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 60
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated 60
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 60
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	activated 60
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 60
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 60
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 60
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 60
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 60
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 60
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated 60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated 60
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 60
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaime r	not activated 60
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 60
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_ high not activated 60
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 60
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_discla imer	not activated 60
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_thresho ld_high not activated 60
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated 60
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer	not activated 60
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high not activated 60
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 60
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 60
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_hig h	not activated 60
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 60
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 60
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 60
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 60
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 60
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 60
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 60
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 60
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 60
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 60
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 60
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 60
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 60
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 60
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 60
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 60
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 60
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 60
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 60
    ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 60
    ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 60
    ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 60
    ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 60
    ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 60
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 60
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 60
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 60
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 60
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	activated 60
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 60
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_hig h activated 60
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 60
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 60
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 60
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 60
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 60
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 60
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 60
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 60
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 60
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 60
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 60
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 60
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 60
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 60
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated 60
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 60
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated 60
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 60
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 60
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 60
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	not activated 60
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaime r	not activated 60
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_ high not activated 60
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	activated 60
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 60
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated 60
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 60
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 60
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 60
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 60
    ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 60
    ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 60
    ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 60
    ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 60
    ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	not activated 64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended 64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus 64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	Databus Infotainment 64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus 64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated 64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15 64
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain 64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	activated 64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment 64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	activated 64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus 64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus 64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated 64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment 64
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus 64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated 64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus 64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus 64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus 64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus 64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	not activated 64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus 64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	Comfort data bus 64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	not activated 64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus 64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	Comfort data bus 64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus 64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus 64
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain 64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated 64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus 64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	not activated 64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended 64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus 64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment 64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	activated 64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus 64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated 64
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus 64
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended 64
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment 64
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus 64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain 64
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus 64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	Comfort data bus 64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	Comfort data bus 64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus 64
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 64
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus 64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	activated 64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment 64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated 64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended 64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Suspension data bus 64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated 64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended 64
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus 64
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus 64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15 64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus 64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated 64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Databus Infotainment 64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	not activated 64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment 64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus 64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available 8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus 8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment 8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL Available 8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available 8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain 8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available 8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus 8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Comfort data bus 8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Comfort data bus 8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN Available 8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus 8
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps	On 10
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture	On 10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart	OFF 10
    ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode	H264 10
    ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution	resolution_1 10
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode	MOST_streaming 10
    ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon	0	10
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most	On 10
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode	H264 10
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution	resolution_1 10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode	MOST_streaming 10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart	OFF 10
    ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_U nit-X1 0	6
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_U nit-X2 50	6
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_U nit-X3 100	6
    ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_U nit-Y1 0	6
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_U nit-Y2 50	6
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_U nit-Y3 100	6
    ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display _Unit-X1	0	6
    ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display _Unit-X2	50	6
    ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display _Unit-X3	100	6
    ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display _Unit-Y1	0	6
    ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display _Unit-Y2	50	6
    ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display _Unit-Y3	100	6
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	100	12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	150	12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	220	12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	1%	12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	8%	12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	20%	12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	60%	12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
    ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07	FF 32
    ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F	FF 32
    ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17	FF 32
    ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F	FF 32
    ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27	FF 32
    ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F	FF 32
    ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37	FF 32
    ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F	FF 32
    ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47	FF 32
    ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F	FF 32
    ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57	FF 32
    ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F	FF 32
    ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67	FF 32
    ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F	FF 32
    ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77	FF 32
    ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F	FF 32
    ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87	FF 32
    ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F	FF 32
    ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97	FF 32
    ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F	FF 32
    ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7	FF 32
    ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF	FF 32
    ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7	FF 32
    ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF	FF 32
    ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7	FF 32
    ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF	FF 32
    ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7	FF 32
    ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF	FF 32
    ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7	FF 32
    ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF	FF 32
    ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7	FF 32
    ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF	FF 32
    ENG107658-ENG126192-mobile phone voice control availability-apple_device	not installed 1
    ENG107658-ENG126193-mobile phone voice control availability-other_devices	not installed 1
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basi c_Adaptation	04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE 40
    ENG117809-p_damping_Display	5 ms	1
    ENG117808-p_HMI_Display	13%	1
    ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
    ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
    ENG117919-Startup_Screen_Sticker_HMI	00 02 2
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN	0	3
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit	0 km/h	3
  3. #13
    Jan 2018
    Kuwait
    Any help , why the map is not showing , it’s just the compass, when I click show map using the steering buttons, it keeps saying “starting map view and nothing happens.
    What adaptation for the module 17 , 5F should be done with 8” discover pro system for golf R.
  4. #14
    Quote Originally Posted by Qassem View Post
    Are the maps for the Discover Pro read from the internal SSD/HDD?
  5. #15
    Jan 2018
    Kuwait
    Yes , I think all 8” discover pro has internal hard drive to save the map.
    I also updated the map to the recent Map, hoping this will help .
  6. #16
    Jan 2015
    Bosnia and Herzegovina
    in 17 adaptations
    IDE02489-Display depiction Version 2
    change to Version 1
    this should get you a map in AID
    also check that
    5F Byte 22 Bit 0 is unchecked
  7. #17
    Jan 2018
    Kuwait
    Quote Originally Posted by m87a View Post
    in 17 adaptations
    change to Version 1
    also check that
    Thanks for the reply.
    I tried version 1 , didn’t work also
    5F byte 22 bit 0 is already unchecked
    Finally , guess what:
    This was the first adaptation I did for the 5F
    - Dashboard_Display_Configuration-ability_switch_nav_maps ---> On (enables the toggle switch on the touch screen)
    Because I have the discover pro I shouldn’t activate it since 8” discover pro shows map on both central and active info display at the same time.
    Once put it back to off, map appeared.
    Now my question , the POI (point of interest) doesn’t show in AID , just in the central 8” display.
    Is this how it works ??! Or it should appear also?!
    Also , how I can zoom in and out in AID ?!
  8. #18
    Jan 2018
    Kuwait
    All problems fixed.
    AID fitted with my old MIB2 discover pro.
    My dealer ordered a new 5F module (ROW) so I can fit the facelift 9” display.
    Lesson learned: when you order a used MIB ( make sure about region) , also make sure the map data inside include your country.
    Otherwise you will end up without navigation.
    Note: you can go the “hacked unit rout” but for me I would like it to be done by official dealer to avoid any hassle in the future (like firmware updating possibilities , updating maps , coding when the dealer attempts to do anything with the car .. etc)
  9. Likes D-Dub, Uwe, iichel liked this post
  10. #19
    Jan 2018
    Kuwait
    Anyone know what I should change (coding or adaptation) in order for the R logo to appear in the active info display.
    It should appear in the first 5 second after starting the vehicle.
  11. #20
    Jan 2015
    I think byte 2 bit 3-6 for start logo
    and for 320km/h go to adaptation Tube_version and select version 4, version 3 is gti 280
  12. Likes Qassem, Bogdan.audi liked this post
