jameeduardo
- Joined
- Nov 17, 2014
- Messages
- 19
- Reaction score
- 10
- Location
- USA
- VCDS Serial number
- HC425404 (2nd hand?)
Jetta ABS long coding help
Hi Guys
A 2013 Jetta Market USA . The costomer clear the coding ABS with a scan tools.
Could anyone please help with suggestions for possible coding.
Hi Guys
Saturday,04,August,2018,11:35:49:56788
VCDS Version: 18.2.1.5
VIN: 3VWDP7AJ8DM383067 License Plate: JETTA MENDEZ LAST
Mileage: 97240km-60422mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VWDP7AJ8DM383067 Mileage: 97240km-60422miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CP HW: 07K 907 309 B
Component: 2,5l R5/4V G01 4336
Revision: T4H06--- Serial number:
Coding: 0000075
VCID: 7EF39E55292AA1B456-802A
006470 - Control Module 1 for Coolant Fan
P1946 - 000 - Defective - Intermittent
Mileage: 97240 km
Date: 2012.12.25
Time: 20:24:44
RPM: 714 /min
Load: 31.8 %
Temperature: 63.0°C
Temperature: 30.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Readiness: 0110 0101
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2246
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 000FE0AD53DED74424-8054
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
VCID: 7DF19959E42CBAAC4F-8028
03306 - Coding Not Valid
Reset counter: 149
Mileage: 97240 km
Date: 2012.12.25
Time: 20:32:05
Count: 3
Count: 12
Count: 12288
Count: 4161
Count: 44032
Count: 256
Reset counter: 148
Date: 2012.12.25
Time: 20:26:05
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 49408
Fault Status: 01100101
Reset counter: 148
Mileage: 97240 km
Date: 2012.12.25
Time: 20:24:51
Count: 3
Count: 12
Count: 12800
Count: 295
Count: 50176
Count: 256
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AT HW: 5C0 820 047 AT
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001193079
VCID: 72EBBA656D72F5D422-8026
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0256
Revision: B2066001 Serial number: 04371254120677
Coding: 7B994B1808AB0B0000302000240884D400C2502E60000000300000000000
VCID: 2F6D73117EC0983C8D-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3463
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3465
Coding: 820000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3463
Coding: 800000
Subsystem 4 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
01365 - Lock/Unlock Switch; Interior
Reset counter: 148
Mileage: 97223 km
Date: 2012.12.12
Time: 01:14:15
03301 - Response Closing Status of Drivers Door
Fault Frequency: 11
Reset counter: 148
Mileage: 97223 km
Date: 2012.12.12
Time: 02:28:13
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM0882UW
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 34677C7D9FE6BBE4F0-8060
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y120000K1NZ06
Coding: 303037
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4B506258ZZZY
Serial number: 3582MSME7C74646FZZZC
Serial number: 3516KSME6A32771DZZZ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME6A60111EZZZT
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6F2B461DZZZ9
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME4415461DZZZX
Part No SW: 5C6 920 952 B HW: 5C6 920 952 B
Component: KOMBI H06 0705
Coding: 270201
Shop #: WSC 00066 000 00124
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2B55670142D8E41CA1-807E
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0256
Revision: B2066001
Coding: 102200
VCID: 70EFB06DA37EC7C4D4-8024
Component: IMMO H06 0705
Shop #: WSC 00001 000 00000
VCID: 6ADBA2058DA23D149A-803E
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0006
Revision: -----06S Serial number: VWZ4Z6M3430936
Coding: 05000400010006
VCID: 23458F2122082C5C19-8076
Fault Status: 00101011
Reset counter: 188
Mileage: 97240 km
Date: 2012.12.17
Time: 01:08:25
End-------------------------(Elapsed Time: 02:24)-------
