Folks
I'd appreciate someone's advice for coding Audi head lights.
The car came from Japan where it was coding by someone to have headlights beams skewed to meet their local driving regulations.
I scanned the car and found that the only module where it could be done was 35 Central Locks (which doesn't make sense to me)
While in long coding I see this context menu that says I need to add 128 to the existing value.
At the same time I coded the car to do auto-lock and I added 32 to the existing value.
It seemed to work and doors started auto-locking once the car reached the speed of 15 Km/h and unlock upon key removal.
But I'm still clueless how to change headlights to LHD as they now blind oncoming drivers.
Below is the full scan results for the car:
Tuesday,07,August,2018,14:50:00:01249
VCDS Version: 18.2.1.5 (x64)
VIN: WUAZZZ4B93N901830 License Plate:
75 76 77
VIN: WUAZZZ4B93N901830 Mileage: 73660km-45770miles
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558 C
Component: 4.2l V8/5VT G 0001
Coding: 0010752
Shop #: WSC 00000 785 00200
VCID: 2E534A40BA13A43486-5140
17649 - Fuel Injector for Cylinder 5 (N83)
P1241 - 004 - Open Circuit - Intermittent
17650 - Fuel Injector for Cylinder 6 (N84)
P1242 - 004 - Open Circuit - Intermittent
18010 - Power Supply Terminal 30
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 001 - Open or Short to Plus - Intermittent
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1214
Coding: 00001
VCID: 6CD780481C8F1624E8-515E
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
VCID: 63C5EB74F151595C59-5140
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00020
VCID: 65C1F56CFF65276CB7-2586
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 P
Component: Airbag 8.4EP 2002
Coding: 0000706
VCID: 3D717D0C67754FAC0F-515E
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 937 B
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 03584
Shop #: WSC 55996
VCID: 2643B260C2E3EC747E-515E
WUAZZZ4B93N901830 AUZ7Z0B2257144
49-00 - No Communications
01304 - Radio
Address 35: Centr. Locks Labels:. 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D37
Coding: 06731
Shop #: WSC 78820
VCID: 33655B34013189DCE9-4F06
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
VCID: 2643B260C2E3EC747E-5140
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
VCID: 0407C8E8141FFE6400-4B4C
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 01156
VCID: 6DD18D4C27951F2CFF-515E
End-------------------------(Elapsed Time: 05:45)--------------------------
