My vcds wi beep three times then pause and repeat 4 times when I plug it into a car or usb to a computer. It will not update the firmware after the download is finished I get "error code -11"
That is a problem mounting the interface to your PC to write files to it. What is your PC setup like, are you running in a virtual machine? Do you have antivirus software or something like that which might be grabbing it?
Have you paired the new card with the HEX-NET? The procedure is as follows:I installed the new sd card but the app now says there is something wrong with the sd card and I need to contact you guys about it.
I can confirm this procedure works, this is what got my HEX-NET working again earlier this week.Have you paired the new card with the HEX-NET? The procedure is as follows:
With the HEX-NET powered up (either from a USB power source or plugged into a car, it doesn't matter), press and hold the red button for 45 to 50 seconds. Use a timepiece of some sort. When you release the button, you should get a short confirmation beep. Once you do, leave the HEX-NET powered up for a while (5 minutes or so), then remove power and let it sit unpowered for a bit before powering it back up.
