Results 1 to 10 of 16
Thread: Hi From Brazil
    Aug 2018
    Brazil
    Hi From Brazil
    Hi!
    My name is Rodrigo, i'm a car enthusiast from Brazil!
    I have a 2017 Mini Cooper and a 2019 VW Polo 1.0 TSI - the reason I bought the HEX-V2.
    I received today my HEX-V2 and tried to use with my 2019 VW Polo, but i'm having some troubles regarding the modules, but since i'm new around here, i'll wait for instructions if i post the error messages and auto scan here or on another thread.
    Thanks!
    Aug 2018
    Brazil
    I'll share below some errors i'm having and the Auto Scan:
    Monday,06,August,2018,17:23:36:07009
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    VIN: 9BWAH5BZ1KPXXXXXX   License Plate:
                    Address 17: Instruments
    Control Module Part Number: 2G0 920 790
      Component and/or Version: KOMBI         514 0620
               Software Coding: 042402082180000C020862001000000000000000
                Work Shop Code: WSC 01530
                          VCID: 6491516F9EDA0937F5C-8030
    Advanced Identification/FAZIT
         Identification: VDD-024
         Date: 09.04.18
         Manufacturer number: 9281
         Test stand number: 0643
    Flash Status
         Programming Attempts(application): 0/0/0
         Programming Attempts(data): 0/0/0
         Successful Attempts(data): 0/0/0
         Flash Date: 00.01.01
         Flash Tool Code(data): 00000 000 00000
    Misc.
         Hardware number: 2G0 920 790
         Workshop System Name: J285
         Equipment/PR Code: 0000000000000000
         Dataset Number: -----------
         Dataset Version: ----
         ASAM Dataset: EV_DashBoardVDDMQBA0
         ASAM Dataset Revision: 001029
    Car Info
         Chassis Number: 9BWAH5BZ1KP518656
    VCDS Info:
           Labels: None
           ROD: ERROR - EV_DashBoardVDDMQBA0 001029 ()
    Monday,06,August,2018,17:30:28:07009
    Chassis Type: BZ (2Q0)
    Scan: 01 02 03 05 08 09 10 15 17 19 44 5F
    Address 01: Engine (J623-DHSB)       Labels: None
       Part No SW: 04C 906 026 BT    HW: 04C 907 309 AH
       Component: R3 1.0l TFS   H21 5244
       Revision: WVH21---
       Coding: 011A0012232400001000
       Shop #: WSC 01530 935 00200
       ASAM Dataset: EV_ECM10TFS01104C906026BT 001002
       ROD: N/A
       VCID: 74B1212F2E3A99B765C-8020
    Unsupported vehicle.
    No ASAM data for: "EV_ECM10TFS01104C906026BT" ()
       Part No SW: 09G 927 158 CL    HW: 09G 927 158
       Component: AISIN AG6 G3  202 3409
       Coding: 0000000000000000010000000000000000000000
       ASAM Dataset: EV_TCMAQ250031 002009
       ROD: N/A
       VCID: 7F5BFE03177CCAEF08E-802A
    No ASAM data for: "EV_TCMAQ250031" ()
       Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
       Component: ESC_base      H13 0222
       Serial number: 86401974180404
       Coding: 33044C673742CCB53202EC1B14E0126A49444D26226A242444541254452848569222B26444562424222A482AA229D64214946B4228
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: N/A
       VCID: 3E25C30750F603E7438-806A
    No ASAM data for: "EV_Brake1BOSCHESPMQBA0" ()
    Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0477228806
       Coding: 132C0C0723
       ROD: N/A
    No ASAM data for: "EV_KessyHellaMQBAB" ()
       Part No SW: 2G0 907 057 E    HW: 2G0 907 057 E
       Component: Climatronic   H04 0501
       Coding: 0120000008000000000004000240010D0101000000000000000000000000
       ASAM Dataset: EV_ACClimaBHBMQBA0 004017
       ROD: N/A
       VCID: 2A0DFF57BC7E9F470F0-807E
    No ASAM data for: "EV_ACClimaBHBMQBA0" ()
       Part No SW: 2Q0 937 089     HW: 2Q0 937 089
       Component: BCM A0 Std    H97 0916
       Serial number: 20118085006402
       ASAM Dataset: EV_BCMA0 204001
       ROD: N/A
       VCID: 77AB16233F4CF2AF40E-8022
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  047 0105
       Serial number: S5Y17M10D18H17M27S56
       Coding: 0038DD
       Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
       Component: FHSG_DRV  001 0001
       Serial number: 00000000000021543466
       Coding: 138000
       Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000020789630
       Coding: 098000
       Serial number: 000000000ZY180230ADT
       Subsystem 5 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000020193308
       Coding: 030000
       Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000020309641
       Coding: 1B0000
    No ASAM data for: "EV_BCMA0" ()
    Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 55401817240363
       Coding: 0031151011
       ROD: N/A
       VCID: 44D1B1EF3E1A693715C-8010
    No ASAM data for: "EV_EPHVA18AU3700000" ()
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 2QB 959 655     HW: 2QB 959 655
       Component: VW22Airbag    010 0246
       Revision: --------
       Coding: 88C0C00000000000540000CF000800000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
       ROD: N/A
       VCID: 0C4159CF56CAE1771DC-8058
       Subsystem 1 - Part No SW: -----------    HW: 442 1A1 612 17
       Component: SideSensor_Df  2C4 0148
       Serial number: 349B4D1BF28A7CD602EG
       Subsystem 2 - Part No SW: -----------    HW: 442 1A1 612 17
       Component: SideSensor_Pf  2C4 0148
       Serial number: 350B4D1BF28A7CD55286
       Subsystem 3 - Part No SW: -----------    HW: 442 132 402 18
       Component: FrontSensor_D  290 118A
       Serial number: 355AG11A528A2CB483D0
    No ASAM data for: "EV_AirbaVW22BPAVW27X" ()
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 2G0 920 790     HW: 2G0 920 790
       Component: KOMBI         514 0620
       ASAM Dataset: EV_DashBoardVDDMQBA0 001029
       ROD: N/A
    No ASAM data for: "EV_DashBoardVDDMQBA0" ()
       Part No SW: 2Q0 909 901     HW: 2Q0 937 089
       Component: GW MQB A0     H97 0916
       Coding: 0101000020085600F80002081C0F00000001070000000000000000000000
       ASAM Dataset: EV_GatewA0 013020
       ROD: N/A
       VCID: 6FBB2E43471CBA6F98E-803A
       Subsystem 2 - Part No SW: 56D 959 442     HW: 56D 959 442
       Component: E221__MFL-834  H01 0130
       Serial number: 000000000C0876300418
       Coding: 200000
    No ASAM data for: "EV_GatewA0" ()
    Address 44: Steering Assist (J792)       Labels: None
       Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 610 6030
       Serial number: 02I3D0H8CB4J148
       Coding: 00000001000000000101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: N/A
       VCID: 392FD01B49D824DF76A-806C
    No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" ()
    Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
       Component: MU-S-N-ER     851 0867
       Coding: 02720003BE00000041220001001828001F0500F401200400C7
       ROD: N/A
       VCID: 313FE83B91A8EC9FCEA-8064
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZHV0931271
       Subsystem 2 - Part No SW: 3G0 919 866 BF    HW: -----------
       Component: MRM2 2017/18  --- 0821
    No ASAM data for: "EV_MUStd4CDELP" ()
    End----------(Elapsed Time: 01:05, VBatt start/end: 12.8V/12.7V)-----------
    Aug 2016
    The Hague, NL
    I'm afraid your car is maybe a bit too new for it to be supported. The new Polo AW is a brand new car.
    I'm sure the people at Ross Tech will sooner or later have some more information available to support it.
    Have you tried to make an Autoscan with the latest Beta VCDS ?
  5. Likes Uwe liked this post
    +1.
    I would expect that to work much better.
    Aug 2018
    Brazil
    Hi iichel, NEtech and uwe!
    Yesterday I downloaded the VCDS beta and updated my cable and was able to code some features in the car - not much as I expected, but since the car was launched recently, I understand itíll take sometime to have more features available.
    A new auto scan with the current setup would help? If yes, just let me know and Iíll make it!
    Thanks guys!
  8. Likes Uwe liked this post
    Quote Originally Posted by rfmz View Post
    A new auto scan with the current setup would help? If yes, just let me know and I’ll make it!
    Yes it will help.
  10. Likes Uwe, Dana liked this post
  11. #8
    Aug 2018
    Brazil
    Hi!
    As requested, i'm sharing the auto scan with the Beta 17.7.1 version of VCDS + the latest firmware update for the HEX-V2:
    VIN: 9BWAH5BZ1KP5XXXXX   License Plate:
         Date: 09.04.18
    Flash Status
    Misc.
    Car Info
         Chassis Number: 9BWAH5BZ1KP5XXXXX
    VCDS Info:
           Labels: None
       Revision: WVH21---
       ROD: N/A
       ROD: N/A
       ROD: N/A
       Coding: 132C0C0723
       ROD: N/A
       ROD: N/A
       ROD: N/A
       Coding: 0038DD
       Coding: 138000
       Coding: 098000
       Coding: 030000
       Coding: 1B0000
       Coding: 0031151011
       ROD: N/A
       Revision: --------
       ROD: N/A
       ROD: N/A
       ROD: N/A
       Coding: 200000
       ROD: N/A
       ROD: N/A
    Below i'm sending an example of a coding that i am not able to do (staging for the active info display):
    If there's anything else that I can help regarding the New Polo, just let me know!
  12. #9
    You posted the wrong scan above; it's the same one as in post #2.
  13. #10
    Aug 2018
    Brazil
    Ooops!
    Sorry!
    Wednesday,08,August,2018,19:54:55:07009
    VCDS Version: 18.7.1.1 (x64)  HEX-V2 CB: 0.4427.4
    Data version: 20180731 DS293.0
    VIN: 9BWAH5BZ1KP5XXXXXX   License Plate:
    Mileage: 1283km-797mi   Repair Order:
    Chassis Type: BZ-VW27 (2Q0)
    VIN: 9BWAH5BZ1KP5XXXXX   Mileage: 1283km-797miles
       Revision: WVH21---
       ROD: EV_ECM10TFS01104C906026BT.rod
       VCID: 74B1212F2E3A99B786C-8020
       CAN Converter 01:
       ROD: EV_TCMAQ250031_002_VW27.rod
       VCID: 7F5BFE03177CCAEFEBE-802A
       ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
       VCID: 3E25C30750F603E7A08-806A
       Coding: 132C0C0723
    Address 08: Auto HVAC (J255)       Labels:* None
       Coding: 0120000010000000000004000240010D0101000000000000000000000000
       ROD: EV_ACClimaBHBMQBA0_VW27.rod
       VCID: 2A0DFF57BC7E9F47EC0-807E
       ROD: EV_BCMA0_204.rod
       VCID: 77AB16233F4CF2AFA3E-8022
       Coding: 0038DD
       Drivers Door Control Module:
       Coding: 138000
       Coding: 098000
       Coding: 030000
       Coding: 1B0000
       Coding: 0031151011
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 44D1B1EF3E1A6937F6C-8010
       Revision: --------
       ROD: EV_AirbaVW22BPAVW27X_VW27.rod
       VCID: 0C4159CF56CAE177FEC-8058
       Coding: 002502082180000C020866001000000000000000
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 6491516F9EDA093716C-8030
       ROD: EV_GatewA0.rod
       VCID: 6FBB2E43471CBA6F7BE-803A
       Coding: 200000
    Address 44: Steering Assist (J792)       Labels:* None
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 392FD01B49D824DF95A-806C
       Coding: 02720003BE00000041220001001828001F0500F401200400CF
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 313FE83B91A8EC9F2DA-8064
    End----------(Elapsed Time: 01:07, VBatt start/end: 12.4V/12.3V)-----------
  14. Likes Uwe, Dana liked this post
