Thursday,30,August,2018,11:26:34:22572
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUB8GFF9J1050538 License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 42 44 52 5F 6C BB BC
VIN: WAUB8GFF9J1050538 Mileage: 935km-580miles
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00124426010F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 372B289A8FC8067F80E-8062
Part No SW: 0D9 300 018 A HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01712051417
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1A6DD12E1C1A3B179F0-804E
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 60208000000109
Coding: 13FF6A923425226C897C0B03A0CB29C8562C4491D0059476124150548208420000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 78A9EBA6C256C907494-802C
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0466534908
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C2137B6B6EE25276DC-8068
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001455766
Coding: 03000014010000001000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40D94346DA0641C7314-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 74329C0900PAG0MUFU03
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001801600048
ROD: EV_BCMCONTI.rod
VCID: 0655955EB8A2AFF74B8-8052
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 171214 043 0585
Serial number: 171218131241
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21153841X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 16 09 2017 00001257
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000000125165
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST001XGL2100000
Coding: 101F00
11274 - Bulb for Center Brake Light
B12C6 15 [008] - Open or Short to Plus
Reset counter: 80
Mileage: 876 km
Date: 2018.08.28
Time: 15:03:33
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: B500008111F78428949C8055000024
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
VCID: 3B2334AAB3E0221F646-806E
Component: AirbagVW20 010 0830
Serial number: 003GCR09UKC0
Coding: 9DCCFCC0000000005000001AC24800000065
VCID: 47CB585AFF2876FFF0E-8012
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34230167A17011841189
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34230168A18011840138
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001PPNEL
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 000 701 18
Serial number: 35700000000F9858BA2/
Subsystem 5 - Part No SW: ----------- HW: 480 000 701 18
Serial number: 358000000005A858BA2W
Subsystem 6 - Part No SW: ----------- HW: 480 400 801 18
Serial number: 35100019F287908173F8
Subsystem 7 - Part No SW: ----------- HW: 480 400 801 18
Serial number: 3520001B728DFC75828N
Subsystem 8 - Part No SW: ----------- HW: 480 400 301 18
Serial number: 3550002A725325B3F2B5
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 411 17
Serial number: 3560002B1252D872409.
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Revision: -------- Serial number: 20011804220487
Coding: 2018
VCID: 0D47AA72DDD4DCAF0A2-8058
Part No SW: 8V0 920 961 C HW: 8V0 920 961 C
Component: KOMBI H01 0311
Coding: 0BE418192380CF050280A8001800000000000000
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 16011810804226
Coding: 030100043F085A005B00004C180B00000001010000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 38292BA682D60907894-806C
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20180110132209 20666
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 7588600000180119106A
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00016.10.17
Coding: 0001
VCID: 4CC16776E64E95A7DDC-8018
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000401988006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311F969EBEED67A5C-8060
Component: TSG FS 020 0041
Serial number: 020118ELU03672
Coding: 001C1B204000048000000002
VCID: 43D34C4ACB105ADF2C6-8016
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B3DC8ADB30AA5F7C6-8026
Component: TSG BFS 020 0041
Serial number: 171217ELH02244
Coding: 001C13204400048000000002
VCID: 42DD494ED40A53D7270-8016
Part No SW: 8V1 035 652 E HW: 8V1 035 652
Component: MU-HS-S-US 050 0160
Coding: 01730100FF0A000011220001061A00002F002DC401F001040A
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP_AU37.rod
VCID: 392F2EA2B9DC100F76A-806C
Subsystem 1 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y080YL
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 BF HW: 8V0 919 614 BF
Component: ControlUnit_B H50 0103
Serial number: ALJAL118101700050476
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273010100002001000040
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 211117EKL00909
Coding: 000C13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 211117EKL0090C
End----------(Elapsed Time: 01:33, VBatt start/end: 13.8V/13.8V)-----------
