Results 1 to 10 of 10
Thread: Security access error (abs breakes)
    Pirate
    Aug 2018
    Italy
    I have a problem,
    I have to do a basic setting to restore the ESP and Steering Angle, Sensor Brake and Lateral acceleration, but when I go to Security access after entering the code 40168, I get this window with "not supported by control module" and obviously the basic settings do not work
    Image of the problem:
    Given that I have already reset it once successfully, but this time it does not work
    Aug 2016
    Switzerland
    can you maybe post a full autoscan? see below. thank you. 18.7.1 (Beta) or 18.2.1 (normal) is the most recent VCDS version.
  3. Likes Boki Ar liked this post
    Pirate
    Aug 2018
    Italy
    The my Log:
    Remved.  Data from a clone/pirate copy of VCDS is not welcome here.
    Pirate
    Aug 2018
    Italy
    I see below. thank you.18.7.1 (Beta) or 18.2.1 (normal) is the most recent VCDS version.
    I tried with another version, another computer but it does not work anyway
    Aug 2016
    Switzerland
    you can post the code inline with [code] tag
    Use [Login-11].
    See also here.
    Pirate
    Aug 2018
    Italy
    Use [Login-11].
    See also here.
    I have [Coding II] in ABS BRAKE module, not Login - 11
  9. #8
    Yes use that.
  10. #9
    Pirate
    Aug 2018
    Italy
    Use [Login-11].
    See also here.
    Yes use that.
    With coding 2 accept the code but the basic setting does not work the same
  11. #10
    Getting help on this forum requires the use of a legitimate VCDS system.
    The are available directly from us:
    http://www.ross-tech.com/distributors.php#it
    Let us know via PM if/when you get one so we can adjust your forum status.
  12. Likes Boki Ar, Fredrick Awuor liked this post
