RCD310 DAB retrofit fault code
Chinchilla
C?ID=48190
Hi all
I’ve recently upgraded the RCD210 stereo to a RCD310 DAB unit,
I am now getting several fault codes, some of which I understand (I.e. The aerial one as I have only plugged one aerial in, plus the aux, as it wasn’t connected at the time of the autoscan).
The one that is puzzling me are the ones for rear speakers. It is obviously telling me that there are no rear speakers connected -correctly! But how to stop it checking...
I have searched the coding and found that the Long Coding can be altered to set 2 or 4 passive speakers.
Using the long coding helper, I have set the speakers to 2, but the unit will not accept the coding.
Has anyone encountered this before?
Autoscan details:
Tuesday,08,May,2018,18:17:56:25127
VCDS Version: 18.2.0.3 (x64)
VIN: WV2ZZZ7HZFH098552   License Plate:
Mileage: 56710km-35237mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 18 19 25 56
VIN: WV2ZZZ7HZFH098552   Mileage: 56710km-35237miles
Address 01: Engine (J623-CCHA)       Labels: None
   Part No SW: 03L 906 019 FL    HW: 03L 907 309 M
   Component: R4 2.0l TDI   H45 9977
   Revision: 26H45---    Serial number: 00000000000000
   Coding: 0125401A230400080000
   Shop #: WSC 00168 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906019FL 004005
   ROD: EV_ECM20TDI01103L906019FK_004.rod
   VCID: FAF1B03D7DBDFE94D6-80AE
Address 02: Auto Trans (J743)       Labels:. User\0BH-927-711.clb
   Part No SW: 0BT 300 045 R    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H08 2241
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: C48D0EC54FF97864FC-8090
Address 03: ABS Brakes (-----)       Labels: None
   Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
   Component: ESP MK25A XT  H50 0113
   Revision: 00H50001
   Coding: 108724AD09AD089D24A79076BA6012
   Shop #: WSC 02737 790 49152
   VCID: BB7F75393A07079C8D-80EE
   Component: LENKW.SENSOR  H07 0070
   Serial number: 22121404650136
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEF9BC2D6195D2B4EA-80AA
Address 08: Auto HVAC (J255)       Labels:| User\7E5-907-040.clb
   Part No SW: 7E5 907 040 AF    HW: 7E5 907 040 AF
   Component: ClimatronicT5 H19 0407
   Revision: 00001004
   Coding: 0000000102
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: ECDD866507E9502454-80B8
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010601150015148
Address 09: Cent. Elect. (J519)       Labels:. User\7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 356140518
   Coding: A0B4793A0A613413922848102C2B8DD40080612F60040000320000000800
   Shop #: WSC 02759 790 12345
   VCID: C18307D158EB6D4CD7-8094
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: USER\7E0-959-801.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU010121443445656
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: USER\7E0-959-802.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU010121443441270
   Coding: 0000A0
   Subsystem 3 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 7E1 951 171
   Subsystem 6 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: USER\3C8-959-537.CLB
   Serial number: 70000000000000414288
   Coding: E20000
Address 15: Airbags (J234)       Labels:| User\5K0-959-655.clb
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H07 0013
   Revision: --------    Serial number: 003HM005RRJY
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   VCID: B669640D0925DAF472-80E2
   Serial number: 3495ZRB400252K1Q88NL
   Serial number: 3505ZRB400652QV6P1T6
Address 17: Instruments (J285)       Labels:| User\5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 460E01
   VCID: B56B63011423D1EC7B-80E0
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 C
   Component: J737__Standheizung  0605
   Revision: 00087000    Serial number: 09024900A00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: A54BB3416C83A16CCB-80F0
Address 19: CAN Gateway (J533)       Labels: User\6N0-909-901.lbl
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 042300
   VCID: F0E5921523C1B4C468-80A4
Address 25: Immobilizer (J334)       Labels:| User\5K0-920-xxx-25.clb
   Component: IMMO          H04 0805
   VCID: EAD1807D0D1D4E1426-80BE
Address 56: Radio (J503)       Labels:. User\5M0-035-1xx-56.clb
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2N1890493
   Coding: 05000400040014
   Shop #: WSC 02754 790 00000
   VCID: B56B63011C23D1EC7B-80E0
6 Faults Found:
                    Reset counter: 37
                    Mileage: 56711 km
                    Date: 2018.05.08
                    Time: 18:08:12
                    Reset counter: 37
                    Mileage: 56711 km
                    Date: 2018.05.08
                    Time: 18:08:12
                    Reset counter: 37
                    Mileage: 56711 km
                    Date: 2018.05.08
                    Time: 18:13:01
                    Reset counter: 37
                    Mileage: 56711 km
                    Date: 2018.05.08
                    Time: 18:13:01
                    Reset counter: 37
                    Mileage: 56711 km
                    Date: 2018.05.08
                    Time: 18:08:20
03138 - Input AUX IN
                    Reset counter: 37
                    Mileage: 56711 km
                    Date: 2018.05.08
                    Time: 18:08:15
End-------------------------(Elapsed Time: 02:30)--------------------------
iichel
Netherlands, eastern part
C?ID=284912
It is indeed true that the RCD210 comes with the factory equipment of only two speakers.
Is there maybe a bit/byte that allows you to disable the speaker monitoring? You could try to change that together with the 2-4 speaker option.
I'm not quite sure how VW counts, but sometimes it could be:
- 2 speakers is only two speakers in the front doors;
- 4 speakers is two speakers + two tweeters in the a-pillar;
- 6 speakers is 4 speakers + 2 speakers in the rear doors.
rhinopower
C?ID=58979
Is there an option to disable speaker monitoring? Don’t have a 310 here to compare the coding
m87a
Bosnia and Herzegovina
C?ID=156900
vw counts as:
- 2 speakers is two speakers in the front doors and tweeters,
- 4 speakers is four speakers + four tweeters;
if it won't accept 2 speakers coding in byte 2 then set byte 4 to 02 speaker monitoring front active, rear inactive...
Chinchilla
C?ID=48190
Thanks for the advice all.
I had a look today, and the unit definitely won’t accept the coding for front speakers only.
I then tried to turn off monitoring for the rear speakers, but all I could switch off was the monitoring for the tweeters, which reduced the number of fault codes, but did not eliminate them..
Any more suggestions (other than installing rear speakers (!) )
kamold
Australia
C?ID=241363
Are you trying to only change one byte at a time? ie changing byte 2, apply coding, then change byte 4 and apply...
You should in theory be able to change your coding string from
05000400040014
to
05000200020014
This should change to only 2 passive front speakers, and speaker monitoring only for front speakers active...
Chinchilla
C?ID=48190
Kamold,
Thanks for the reply. Yes, I am just trying one change at a time.
The monitoring options for all speakers is just for the tweeters, therefore I cannot turn off for the rears completely..
Looks like I’ll have to install speakers!
kamold
Australia
C?ID=241363
Have you tried applying both coding changes in one go?
Chinchilla
C?ID=48190
Yes, tried all combinations..!!
