- Joined
- Feb 26, 2016
- Messages
- 152
- Reaction score
- 35
- Location
- Czech Republic
- VCDS Serial number
- C?ID=91614
You were right :-( Not working after dealer Cruise Controll Enable :-(
So i coded all and there are lot of acc errors.
Central Electric i already correct it.
Now i have to try one of this radar, do you have exactly one PN, what is trully working ?
My scan:
My scan:
Tuesday,06,November,2018,01:30:20:12448
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
VIN: WAUZZZ8V4DA016040 License Plate:
Mileage: 69345km-43088mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V4DA016040 Mileage: 69345km-43088miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H21 4793
Revision: 84H21---
Coding: 0A250012036401092000
Shop #: WSC 27488 003 104857
ASAM Dataset: EV_ECM16TDI01104L906021N 002006
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 302CE44E6B13F3CA65-8064
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Mileage: 69345 km
Date: 2018.11.03
Time: 12:49:47
Coolant temperature: 14 °C
Intake air temperature: 15 °C
Voltage terminal 30: 13.180 V
Limitation: accelerator pedal: 111.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
Part No SW: 0CW 300 047 R HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5210
Revision: 00043014 Serial number: CU501210105926
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 4AD896A6ED8FA91A4B-801E
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 10F162A220210A720177060401C32508460450806080A4F2F859F00805
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DB20D7AECC1CEA2BE-8028
8192 - Databus
U1121 00 [137] - Missing Message
[FCAN: ACC_07 message is not received]
Reset counter: 102
Mileage: 69345 km
Date: 2018.11.03
Time: 12:49:46
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 102
Mileage: 69345 km
Date: 2018.11.03
Time: 12:49:46
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000942221
Coding: 00000104002000011000000000001100
Shop #: WSC 06385 790 00016
VCID: 3326EB429A05C8D218-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: C2580456000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011415001096
Coding: 04001846C20100DD03044000001407A80016000000000000000000000000
Shop #: WSC 45343 001 104857
ROD: EV_BCMBOSCH_013.rod
VCID: 004C748E9B33A34AD5-8054
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 120916 041 0580
Serial number: 120928192046
Coding: 0A47F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 N HW: 8V0 941 531 N
Component: E1 - LDS MQB H05 0032
Serial number: 07 08 2012 00000364
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20188473
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 D HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0048
Revision: -------- Serial number: 39231518200419
Coding: 0001050011
Shop #: WSC 03569 010 02200
VCID: 3A38C666BD6F399ADB-806E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0304
Serial number: 20061376510137
Coding: 001C1301FE033B
Shop #: WSC 66666 123 28888
VCID: 383CDC6E83632B8A2D-806C
1037 - Databus
[FAULT_CIS_QDCACC_FAIL]
Reset counter: 102
Mileage: 69345 km
Date: 2018.11.03
Time: 12:49:45
Control Module temperature: 39 °C
Voltage terminal 15: 12.9 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s˛
1807 - No Enable Indentifications Active
B2032 00 [009] - -
[FAULT_SWAP_NO_FSID_ACTIVE]
Reset counter: 102
Mileage: 69345 km
Date: 2018.11.03
Time: 12:49:45
Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
Component: AirbagVW20 009 0349
Serial number: 003GER00CZN1
Coding: 98CCC0000C0000005C540000004800000065
Shop #: WSC 06314 790 00021
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 49DAA9AAE889A20242-801C
Subsystem 1 - Part No SW: ----------- HW: 480 001 210 12
Serial number: 3576700000003561FB0Q
Subsystem 2 - Part No SW: ----------- HW: 480 001 210 12
Serial number: 358670000005F561FB01
Subsystem 3 - Part No SW: ----------- HW: 480 401 610 12
Serial number: 3516502A70D63B34B105
Subsystem 4 - Part No SW: ----------- HW: 480 400 910 12
Serial number: 3526502AD0D19C322136
Subsystem 5 - Part No SW: ----------- HW: 480 401 109 12
Serial number: 3556502A10CD5EB570CU
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 210 12
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B30CD5EB591AX
Subsystem 7 - Part No SW: ----------- HW: 480 401 109 12
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A70CD5EB0627R
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 210 12
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C70D0E4721260
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 1710120003012N
Coding: E408
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 77BE1F52CEFDE4F2E4-8022
Part No SW: 8V0 920 870 B HW: 8V0 920 870 B
Component: KOMBI H23 0490
Coding: 038402082690000808808801000000
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 102
Mileage: 69345 km
Date: 2018.11.03
Time: 12:49:45
Part No SW: 5Q0 907 530 C HW: 5Q0 907 530 C
Component: GW MQB High 109 1072
Revision: -------- Serial number: 0000060099
Coding: 030100F40B0876005B0002581C0B00000001000000000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_GatewLear 005010
ROD: EV_GatewLear_005.rod
VCID: 312AE14A6019FAC26A-8064
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 05 10 2012 C0120978
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 8435508401
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393 A
Component: TSG FS H12 0006
Serial number: 14081200010634
Coding: 005F0E204000040100001002
VCID: 3D32CD7AAC410EA2FE-8068
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392 A
Component: TSG BFS H12 0006
Serial number: 26091200010525
Coding: 005F06204000040100001002
VCID: 3C34C07EB75B07AAC9-8068
End----------(Elapsed Time: 01:09, VBatt start/end: 13.1V/13.1V)-----------
