Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
Thread: Audi A3 8V Airbags error - after swap gateway and central elect.
    Feb 2016
    Czech Republic
    Hello
    i swaped gateway due ACC and Central elect. due heated seats.
    Now this airbag have errors (i also swapped panel with parking button).
    What i have to do ?
    Here is scan:
    Monday,06,August,2018,08:32:22:12448
    VCDS Version: 18.7.1.1 (x64)  HEX-NET CB: 0.4427.4
    Data version: 20180731 DS293.0
    VIN: WAUZZZ8V4DA016040   License Plate:
    Mileage: 69294km-43057mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WAUZZZ8V4DA016040   Mileage: 69294km-43057miles
       Part No SW: 04L 906 021 N    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H21 4793
       Revision: 84H21---
       Coding: 0A250012030401092000
       Shop #: WSC 45343 001 104857
       ASAM Dataset: EV_ECM16TDI01104L906021N 002006
       ROD: EV_ECM16TDI01104L906021N_002.rod
       VCID: 302CE44E6B13F3CAA4-8064
       Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5210
       Revision: 00043014    Serial number: CU501210105926
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW26.rod
       VCID: 4AD896A6ED8FA91A8A-801E
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 10F162A220210A720177060401C32508460450806080A4F20059000805
       Shop #: WSC 06314 790 00021
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7DB20D7AECC1CEA27F-8028
       Component: AC Automat    H14 0060
       Revision: 20028000    Serial number: 00000000942221
       Coding: 00000104002000011000000000001100
       Shop #: WSC 06385 790 00016
       VCID: 3326EB429A05C8D2D9-8066
       Serial number: C2580456000000000001
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011415001096
       Coding: 04001846C20100DD03044000001407A80016000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 004C748E9B33A34A14-8054
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 120916  041 0580
       Serial number:         120928192046
       Coding: 0A47F7
       Light switch:
       Subsystem 2 - Part No SW: 8V0 941 531 N    HW: 8V0 941 531 N
       Serial number: 07 08 2012  00000364
       Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20188473
    526359 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [Steuergerät falsch codiert->Keine Anzeige]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:44
       Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0048
       Revision: --------    Serial number: 39231518200419
       Coding: 0001050011
       Shop #: WSC 03569 010 02200
       ROD: EV_EPHVA14AU3700000_002_VW27.rod
       VCID: 3A38C666BD6F399A1A-806E
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 A
       Component: ACC Bosch MQB H03 0304
       Serial number: 20061376510137
       Coding: 000C1301FE033B
       Shop #: WSC 66666 123 28888
       VCID: 383CDC6E83632B8AEC-806C
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:44
                        Control Module temperature: 39 °C
                        Voltage terminal 15: 14.4 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s˛
    1807 - No Enable Indentifications Active
              B2032 00 [009] -  -
              [FAULT_SWAP_NO_FSID_ACTIVE]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:44
                        Voltage terminal 15: 14.3 V
       Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
       Component: AirbagVW20    009 0349
       Serial number: 003GER00CZN1
       Coding: 98CCC0000C0000005C540000004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 49DAA9AAE889A20283-801C
       Subsystem 1 - Part No SW: -----------    HW: 480 001 210 12
       Serial number: 3576700000003561FB0Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 210 12
       Serial number: 358670000005F561FB01
       Subsystem 3 - Part No SW: -----------    HW: 480 401 610 12
       Serial number: 3516502A70D63B34B105
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3526502AD0D19C322136
       Subsystem 5 - Part No SW: -----------    HW: 480 401 109 12
       Serial number: 3556502A10CD5EB570CU
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 210 12
       Serial number: 2286502B30CD5EB591AX
       Subsystem 7 - Part No SW: -----------    HW: 480 401 109 12
       Serial number: 2296502A70CD5EB0627R
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 210 12
       Serial number: 2306502C70D0E4721260
    9442816 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 00 [137] -  -
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:46
    10487296 - Control Module Does Not Match Vehicle
              B2006 00 [137] -  -
              [ECU does not fit to vehicle configuration]
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:46
       Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
       Revision: --------    Serial number: 1710120003012N
       Coding: E408
       ROD: EV_SMLSKLOMQB_009_AU37.rod
       VCID: 77BE1F52CEFDE4F225-8022
       Part No SW: 8V0 920 870 B    HW: 8V0 920 870 B
       Component: KOMBI         H23 0490
       Coding: 038402082690000808008800000000
    16776980 - Databus
              [PLA_Status_01 keine Kommunikation]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:44
       Part No SW: 5Q0 907 530 C    HW: 5Q0 907 530 C
       Component: GW MQB High   109 1072
       Revision: --------    Serial number: 0000060099
       Coding: 030100F40B0876005B0002481C0B00000001000000000000000000000000
       ASAM Dataset: EV_GatewLear 005010
       ROD: EV_GatewLear_005.rod
       VCID: 312AE14A6019FAC2AB-8064
       Serial number: 05 10 2012  C0120978
       Serial number: 8435508401
       Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393 A
       Component: TSG FS        H12 0006
       Serial number: 14081200010634
       Coding: 005F0E204000040100001002
       VCID: 3D32CD7AAC410EA23F-8068
       Coding: 83
       ROD: EV_SteerAssisMQB_008.rod
    16387 - Steering End Stops Not Learned
              C10AC F0 [009] - Unknown Error Elaboration
              [Endanschläge nicht korrekt eingelernt Beide Endanschläge nicht eingelernt]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:44
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 14.25 V
                        Temperature: 33.0 °C
                        KFC: 40
                        KFA: 00 03
                        Environmental conditions: 5F
                        Rotorlagesensorspannung AMR Sinus: 0.676 V
                        Rotorlagesensorspannung AMR Kosinus: 9.657 V
                        Rotorlagesensorspannung AMR Sinus 2: 0.779 V
                        Rotorlagesensorspannung AMR Cosinus 2: 10.513 V
                        Rotorlagesensorspannung Hall 1: 0.0 V
                        Rotorlagesensorspannung Hall 2: 0.0 V
                        Aktueller Sinus-Offset für ASIC: 0.1 mV
                        Aktueller Cosinus-Offset für ASIC: 0.1 mV
                        aktuelle Sinusverstärkung für ASIC: 0.161
    23552 - Databus
              [PLA_01 Botschaft - CAN-Timeout]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:48
                        Motor status: 01
                        KFC: 5C
                        KFA: 00 00
                        uAdSensI_U5VFiltered_xdu16: 5.07820 V
                        uioUdNotFilt_xdu16: 14.52 V
                        uAdSensI_SwitchedKl30_xdu16: 14.51 V
       Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392 A
       Component: TSG BFS       H12 0006
       Serial number: 26091200010525
       Coding: 005F06204000040100001002
       VCID: 3C34C07EB75B07AA08-8068
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-ENT1.clb
       Part No SW: 8V0 035 889 A    HW: 8V0 035 889
       Component: MU-E--ER      160 0107
       Revision: --------    Serial number: 000031092915000
       Coding: 01730000FF00000010110001000A0000000001040100010000
       ASAM Dataset: EV_MUEnt4CCONT 004052
       ROD: EV_MUEnt4CCONT.rod
       VCID: 40CCB48EDBB3634A54-8014
       Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
       Component: DU Std  H47 0013
       Serial number: AUZ8Z9CG20017H
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614     HW: 8V0 919 614
       Component: ControlUnit_B  H33 0037
       Serial number: C1000006061200010149
              U1111 00 [009] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:50
                        Voltage terminal 30: 14.3 V
                        BAP-BAP_Function_ID: 02
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:47
                        Voltage terminal 30: 14.4 V
    May 2017
    Swap back the original panel. The airbag light is on that panel and that is one part of the airbag system.
    After swapping back the original panel, clear all DTCs and check if the airbag error is gone.
    Then regarding ACC. You do see this on your autoscan :
              B2032 00 [009] -  -
                        Reset counter: 94
                        Mileage: 69294 km
                        Date: 2018.08.04
                        Time: 09:33:44
    You do know that you cannot get the codes at least any official way?
    Feb 2016
    Czech Republic
    Ok, i will try!
    Let you know!
    And yes, i know it is SWAP function, but someone here in forum can activate it... I am waiting for him now.
    May 2017
    Quote Originally Posted by XPepino View Post
    Ok, i will try!
    Let you know!
    I would not count on it.
    There's two ways that I know of :
    1. Needs physical alteration of ACC radar boot loader and certain type of ACC radar. 100% reliable as long as you don't update the radar software. This is how it was done on my car a year ago and everything still works as from factory and no problems after service either.
    2. Fake FSID codes and some way to online activate them to the car. Don't know in detail how this happens but there's one Chinese guy who's also advertising remote activation of MQB functions in Facebook, but I know that VAG is already done some things to prevent this. So not sure how long this will work and what happens when you take the car in for a service. Does it detect from factory that the car should not have these codes and it wipes them from gateway?
  5. Likes Uwe liked this post
    Feb 2016
    Czech Republic
    Hello
    I swapped panel and it works !!! Thank you!
    About SWAP:
    I mean 2. - it makes one Chinese Guy.
    I have there Drive select but after i swapped gateway there is it not available :-/
    I need only add Cruise Control activation, but is very hard to find him.
    Do you know how to activate remotely ?
    May 2017
    Good to hear that. Probably the panel you bought is not correct for your car. The airbag light, as I mentioned, is part of safety systems and if it does not match the one in the car, it gives that error.
    You will get drive select back by going back to the dealer who did the component protection removal and ask them to return the Feature enablement codes to the gateway. After that drive select will work again. They clearly did not do it even it's in the procedure when swapping gateway. You're not the first one to miss features when swapping gateway, there's another thread about this same thing and all was well after dealer returned the features back. They know how to do it. There's even a guided function for that on their diagnostic software.
    And about the ACC activation. Let me explain this to you, I did this in other thread but I try to explain it here as well.
    You CANNOT just add the activation code to the car. It does not work that way. All the FeC's, codes that enable certain features in the modules, are installed to the car during manufacturing phase. The codes are stored to factory database and are tied against your cars VIN number.
    Now when you add a module that needs a FeC, like ACC radar. The module makes a challenge check to gateway, which works as a master, to verify that the FeC is activated. If it is not, the challenge fails and the module is immediately disconnected. The only exception is media system which AFAIK, internally checks the codes. It doesn't check them against gateway.
    Normal cruise control you can retrofit IF you buy the package from manufacturer aftersales. The reason is that the package comes with an one-use enablement code, called also as SWaP (SoftWare As a Product) that will enable the FeC for the cruise control on the target car and at the same time it will store the FeC to factory database, again tied to the target car's VIN number. This enablement needs to be done at dealers as they have online connection to factory.
    ACC is not sold as retrofit or aftermarket package, so you cannot get the SWaP codes for it. At least not officially.
    How this Chinese guy does the enablement, I do not know. What I do know that VAG is aware of this and they've already put some countermeasures in to battle this. I do not know what these countermeasures are, so don't ask
    Again, what I know that only way to surely have working ACC is the hacked radar. You can join MQB coding group in Facebook and ask help from there about ACC retrofit. They can help you on this one.
    Like mentioned in the other thread as well, VAG is making our lives much more difficult on retrofit's with the introduction of SWaP. However, they could utilize it a lot better in my opinion by offering more aftermarket packages like ACC. The ACC could easily be sold as a retrofit part. Radar, stalk set, depending on equipment ABS block, new ABS sensors and possibly new instrument cluster. Of course pricey, but hey, that's life But it would provide more money to the company's back pocket because there would always be people who would buy this package.
  8. Likes PetrolDave, Uwe, Dana liked this post
    Feb 2016
    Czech Republic
    Thank you for explanation!
    It is very interesting.
    Do you mean MQB-Coding & Retrofit ?
    Regards
  10. #8
    May 2017
    Regards
    No probs. Yes, that one
  11. Likes myounus liked this post
  12. #9
    Verified VCDS User martinlop's Avatar
    Oct 2017
    Argentina
    One little "electrical" comment from my side.
    if your new panel has no light indicator (led) for "passenger airbag off", then you can simply "cheat" it with a led between the correct pinouts of the T20 connector of the new panel.
    connecting an orange led, and hiding it inside the hole would be an idea, that can cheat the system, making it think system is working as normal.
  13. #10
    Feb 2016
    Czech Republic
    Hello guys
    i have not reply from this Chinese Guy about enable ACC radar - after i tried more than 1 month to contact him :-/
    Do you have any other solution ?
    MQB-Coding & Retrofit did not reply me on 2 messages on facebook and there is no other contact email.
    I have no Cruise Control installed originaly in my car :-/
    Thank you!
