Results 1 to 5 of 5
Thread: 000296 - Coolant Thermostat Valve (N214)
    Verified VCDS-Lite User
    Jul 2018
    Sunday,05,August,2018,15:04:45:37835
    VCDS Version: Release 18.2.1 (x64) Running on Windows 10 x64
    Control Module Part Number: 070 906 016 CQ HW: 028 101 196 2
    Component and/or Version: V10 5,0L EDCG000AGMª8472
    Software Coding: 0060575
    Work Shop Code: WSC 31414 000 00000
    VCID: 619F59766D5096BF1EA-5160
    P0128 - 000 - Temperature below Control Range
    Fault Status: 01110000
    Mileage: 78586 km
    RPM: 1470 /min
    Speed: 42.8 km/h
    Temperature: 68.4°C
    Fuel Consump.: 7.60 l/h
    Temperature: 29.7°C
    Temperature: 27.9°C
    Absolute Pres.: 1101.6 mbar
    Readiness: 1 1 0 0 0
    ANY SUGGESTIONS?
    Check MVB 001.4 to see what the ECU thinks the coolan temperature actually is. Check it after the vehicle has sat overnight. It should be within a few degrees of ambient. Then watch (or better yet, log) it after you start the engine and go for a drive to see what happens to it.
    In addition to his Eminence recommendation.
    Please post a complete auto-scan because this vehicle supports master/slave ECU's
    Check for coolant level being proper & leaks further PSI hold, most importantly check expansion tank cap and o-ring for proper fit/seal, in addition to quality of coolant.
    If coolant out of range during logs, change the thermostat control valve.
    Component and/or Version: V10 5,0L EDCG000AGMª8472<<<<<<<<<<<<<<<<<<<<<< Firmware update required 9805 or higher!
    0x01 MASTER and 0x11 SLAVE
  4. Likes Uwe liked this post
    Jun 2014
    Of course do the above but know that failure of the Map Controlled Engine Cooling Thermostat (F265 per RTFB) on our V10’s is common and indicated by failure to reach operating temp.
    Administrator Andy's Avatar
    Have you tried the firmware suggestion from this thread? Try clearing codes using Generic OBD2 since both ECUs may have faults stored. Feel free to post a fresh, complete AutoScan.
