Results 1 to 8 of 8
Thread: 2012 NMS Passat Discover Media/MIB2 retrofit attempt and issues
    Aug 2018
    Smile 2012 NMS Passat Discover Media/MIB2 retrofit attempt and issues
    Hello Everyone! I recently took on a retrofitting project to get an MIB2 unit into my passat. I've been running into a couple issues and I hope you all can help me out in some way. I followed the necessary steps to ensure all new components would work, including upgrading my canbus gateway from 7N0 907 530 P to 7N0 907 530 BD as I read that I would not be able to access the 5F module to code the MIB2 head unit with the old one. Upon hooking everything up, I lost functioning of my sunroof and dashboard analog clock. I contacted the folks at Ross-tech and they read through my scans and saw that 4F was no longer able to be accessed with the new gateway. They inferred that this could be the reason my sunroof stopped working. Now, as far as I'm aware, I need a gateway ending is at least -AN or above to have access to 5F. I installed a -BD version and lost access to 4F. Any recommendations on whether I should try an -AN gateway? Will I still have access to bother 5F and 4F? I am seeing plenty of -AP models for sale for a reasonable price, but the folks at Ross-Tech indicated that per my VIN, 7N0-907-530-AN-Z00 is the version that is listed as a part number for my car. Any reason a -AP unit wouldn't work? I have attached scans before the swap and right after the swap for reference. The head unit works great, except for an issue where the RVC screen does not activate on reverse. It happens almost everyday and I have to restart the unit before the image returns when I place the car in reverse. I have an OEM retrofitted camera installed with an RGB-composite signal converter. I'll be working on fixing that as soon as I figure out what is wrong with the gateway. Thoughts? Thanks!
    Thursday,19,July,2018,17:46:11:64180
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4C 4F 52 56 62 72
              77
    01-Engine -- Status: Sporadic communication error 1000
    4C-Tire Pressure II -- Status: Not registered 0001
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
       Component: 2,5l R5/4V       01 5685
       Revision: T6H02---    Serial number:
       Coding: 0000075
       Shop #: WSC 56460 002 1048576
       VCID: 73CB3A0B124F9CDC2A-8026
       Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
       Component: AQ 250 6F           1916
       Revision: 00H90000    Serial number:
       Coding: 0000328
       Shop #: WSC 09003 957 00200
       VCID: 02256FCF5DF5A55431-8056
       Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
       Revision: 00H31001
       Coding: C54BC0F5492808FAA31003EB921C1061A61C00
       VCID: 7CD91137FF11D3A47B-8028
       Part No SW: 561 907 044 H    HW: 561 907 044 H
       Component: Climatronic   043 0202
       Revision: 00001001
       Coding: 0010001002
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 1C1931B7175173A4DB-8048
       Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
       Component: BCM PQ35 B+   021 0064
       Revision: BH021001
       Coding: 6F200EBBF02B28D48888000116000CE800F5000040A00D60858460040C70
       VCID: 43ABAACBC26F6C5C7A-8016
       Component: RLS 040112 05  54  0403
       Coding: 1030BB
    01134 - Alarm Horn (H12)
                        Reset counter: 166
                            Term 15 Off
                        Voltage: 12.55 V
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 82
                        Mileage: 54753 km
                        Date: 2016.02.01
                        Time: 00:00:04
                            Term 15 Off
                        Voltage: 12.25 V
                        Fault Status: 00101010
                        Reset counter: 246
                        Mileage: 127896 km
                        Date: 2012.11.27
                        Time: 13:35:21
                        Voltage: 13.95 V
    02742 - Bulb for Brake/Turn Signal Light; Left
                        Reset counter: 248
                        Mileage: 127935 km
                        Date: 2012.11.27
                        Time: 17:26:25
                        Voltage: 14.00 V
    02743 - Bulb for Brake/Turn Signal Light; Right
                        Reset counter: 6
                        Mileage: 128873 km
                        Date: 2012.12.06
                        Time: 13:23:02
                        Voltage: 13.65 V
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003ENM01ETAU
       Coding: 00003548
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FC3367BB667B83CCE-803A
       Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
       Component: BF-Gewichtss.  H10 0045
       Serial number: 6940000Y120000BB8X0X
       Coding: 303044
       Serial number: 3572MSME52072265ZZZM
       Serial number: 3582MSME75522165ZZZR
       Serial number: 3516KSME25622317ZZZH
       Serial number: 3526KSME06404216ZZZD
       Serial number: 3556LSME17037B14ZZZS
       Serial number: 3566LSME3A567E14ZZZ2
       Part No SW: 1K5 953 501 Q    HW: 5K0 953 569 H
       Revision: FF010040    Serial number: 20120109101260
       Coding: 0982100000
       VCID: 3957C823B8A3268C20-806C
       Component: E221__MFL-YVJ  H06 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 B    HW: 561 920 970 B
       Component: KOMBI         H07 0507
       Coding: 231E01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
       VCID: 191728A31863068CC0-804C
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 07021201290792
       Coding: 461000
       VCID: 3D5FDC33A48B1AAC0C-8068
                        Fault Status: 00110100
                        Reset counter: 246
                        Mileage: 127896 km
                        Date: 2012.11.27
                        Time: 12:51:41
    02649 - Digital Radio Tuner
                        Fault Status: 01110100
                        Reset counter: 82
                        Mileage: 54753 km
                        Date: 2016.02.01
                        Time: 16:34:06
                        Mileage: 57007 km
                        Date: 2016.04.24
                        Time: 18:36:55
    03753 - Control Module for Microphone
                        Reset counter: 82
                        Mileage: 54753 km
                        Date: 2016.02.01
                        Time: 16:34:06
       Component: IMMO          H07 0507
       VCID: 6AF5276F8D855D1499-803E
       Revision: A1001003    Serial number: 7661542874
       Coding: 020000
       VCID: 297718634003960C50-807C
       Part No SW: 3C0 035 684 J    HW: 3C8 035 684 E
       Component: RNS-MID       H65 4366
       Revision: AB001001    Serial number: VWZ6Z7M7113033
       Coding: 06000042010000A4000B
       VCID: 2A75E76F45059D1459-807E
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V10  8246
    00857 - CD Changer Unit (R41)
                        Reset counter: 221
                        Mileage: 54800 km
                        Reset counter: 221
                        Mileage: 69552 km
                        Reset counter: 221
                        Mileage: 123240 km
    01523 - Microphone for Telephone (R38)
                        Reset counter: 221
                        Mileage: 54801 km
                        Date: 2016.02.04
                        Time: 09:52:45
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0003989481
       Coding: 0404F5
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5B9B72AB52DF349C12-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
       Component: EZE_2         H40 1623
       Coding: 01030108
       VCID: 6FC3367BBE67B83CCE-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Serial number: 53388786011133302086
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0004
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0003975172
       Coding: 0404F4
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5C9971B757D133A41B-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
                        Fault Frequency: 35
                        Reset counter: 6
                        Mileage: 127896 km
                        Date: 2018.07.07
                        Time: 13:23:49
    Address 56: Radio
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661254495
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 27731E5B5E17A07C46-8072
    End-------------------------(Elapsed Time: 02:07)--------------------------
    Monday,23,July,2018,18:16:52:64180
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4C 4F 52 56 5F 62
              72 77
    37-Navigation -- Status: Sporadic communication error 1000
    56-Radio -- Status: Sporadic communication error 1000
    5F-Information Electr. -- Status: Not registered 0011
    77-Telephone -- Status: Not registered 1001
       Coding: 0000075
       Coding: 0000328
       Revision: 00H31001
       Revision: 00001001
       Coding: 0010001002
       Revision: BH021001
       Coding: 6F200EBBF02B28D48008000116000CE800F5000040A00D60858460040C70
       Coding: 1030BB
       Coding: 00003548
       Coding: 303044
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 14 [137] - Open or Short to Ground
                        Mileage: 129155 km
                        Date: 2018.07.23
                        Time: 16:52:17
       Coding: 0982100000
       Coding: E20000
       Coding: 231E01
       Part No SW: 7N0 907 530 BD    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1673
       Revision:   H57       Serial number: 120116F1001904
       Coding: 351000
       VCID: 73CB3A0BD24F9CDC2A-8026
                        Reset counter: 41
                        Mileage: 129127 km
                        Date: 2012.12.10
                        Time: 08:28:18
    01304 - Radio
                        Reset counter: 41
                        Mileage: 129127 km
                        Date: 2012.12.10
                        Time: 08:28:18
                        Reset counter: 41
                        Mileage: 129155 km
                        Date: 2012.12.13
                        Time: 16:39:36
                        Fault Frequency: 41
                        Mileage: 129127 km
                        Date: 2012.12.09
                        Time: 18:30:35
    02103 - Control Module 2 for Vehicle Electrical System (J520)
                        Reset counter: 0
                        Mileage: 129127 km
                        Date: 2012.12.09
                        Time: 19:29:55
       Coding: 020000
       Coding: 0404F5
       Slave Driver:
       Coding: 800000
       Coding: 0404F4
       Slave Passenger:
       Coding: 800000
                        Fault Frequency: 36
                        Reset counter: 40
                        Mileage: 127896 km
                        Date: 2018.07.07
                        Time: 13:23:49
    Address 56: Radio
       Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
       Component: MU-S-NS-US    H31 0359
       Serial number: VWZAZ2T1004614
       Coding: 02630102AA00000051220003001808009F0100D400200105C6
       Shop #: WSC 00066 790 00011
       ROD: EV_MUStd4CTSAT_VW27.rod
       VCID: 246909572F214B6463-8070
       Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
    22 Faults Found:
    1537 - Supply voltage
                        Reset counter: 144
                        Mileage: 9376 km
                        Date: 2012.10.19
                        Time: 04:10:08
                        Voltage terminal 30: 9.1 V
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 144
                        Mileage: 9376 km
                        Date: 2012.10.19
                        Time: 04:19:52
                        Voltage terminal 30: 8.5 V
              B11CF 53 [009] - Deactivated
                        Reset counter: 227
                        Mileage: 6985 km
                        Date: 2012.08.05
                        Time: 08:17:50
                        Voltage terminal 30: 14.0 V
                        SDARS_tuner_status_2-Antenna current: 0 mA
                        SDARS_tuner_status_2-Reception quality: Not available
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: FF
    0542 - Audio signal output 1
              B14F1 13 [009] - Open Circuit
                        Reset counter: 0
                        Voltage terminal 30: 12.6 V
    0546 - Audio signal output 2
              B14F2 13 [009] - Open Circuit
                        Reset counter: 0
    0553 - Audio signal output 3
              B14F3 01 [009] - Electrical Failure
                        Reset counter: 0
    0554 - Audio signal output 4
              B14F4 13 [009] - Open Circuit
                        Reset counter: 0
    0009 - Antenna for Satelite Radio
              B10F4 13 [008] - Open Circuit
                        Reset counter: 40
                        Voltage terminal 30: 12.8 V
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
    2565 - GPS Antenna
              B1054 13 [008] - Open Circuit
                        Reset counter: 40
                        Voltage terminal 30: 12.7 V
    6720 - Rear View Camera
              B1102 31 [009] - No Signal
                        Reset counter: 1
                        Mileage: 129155 km
                        Date: 2018.07.23
                        Time: 16:57:47
                        Voltage terminal 30: 13.6 V
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 40
    6700 - Databus
                        Reset counter: 40
    6702 - Databus
                        Reset counter: 40
    6705 - Databus
                        Reset counter: 40
                        Voltage terminal 30: 11.5 V
    6706 - Databus
                        Reset counter: 40
    6714 - Databus
                        Reset counter: 40
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 0
                        BAP-BAP_Function_ID: 02
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 0
    0001 - Antenna 1 for Radio
              B1119 13 [008] - Open Circuit
                        Reset counter: 40
                        Mileage: 9376 km
                        Date: 2012.10.15
                        Time: 01:38:25
                        Voltage terminal 30: 13.0 V
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 1 for radio-Reception level antenna 1: 0 dBV
    0003 - Antenna 2 for radio
              B111A 13 [008] - Open Circuit
                        Reset counter: 40
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 0 dBV
              U11B8 00 [008] - No Communications
                        Reset counter: 40
                        Interface for external media: status-Status: Open circuit
    7223 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 0
    End-------------------------(Elapsed Time: 02:06)--------------------------
    Nov 2016
    Just use the original gateway, and to access the discover media put 5F in the bottom left box to access it on vcds.
    Jul 2014
    Tallinn, Estonia
    I think 7N0907530AN in its original form does not bring the support for 5F but it is the version that can be software upgraded to at least 7N0907530BC (and including BG, BL) to gain 5F support. Just buy the BC version and you should be good to go.
    If you have Discover Media, you can remove the MDI box (address 2E) and Bluetooth (address 77). I'm unsure if MDI messes with 5F but in my experience the Bluetooth does.
    Nov 2016
    Im still using original 3c0 gateway no issue. You dont need to change to a gateway that supports 5F
    Aug 2018
    I'll give putting the old gateway back into the car and see if that helps return 4F functionality. I currently have a -BD gateway installed as I mentioned before. I'm unsure why I would lose 4F access with that version in the first place. I was under the impression that anything above -BC would work in my car...maybe -BD is different than BC/BG/BL etc.
    Aug 2018
    UPDATE: changed back to the old gateway and everything that was lost is working again. I can confirm that I can access the 5F module by searching for it in the bottom left area. Still having the issue with the RVC. Will change it to a composite aftermarket one sometime this week to see if that resolves the issue. Thanks
  7. #7
    Tartu, Estonia
    Different CAN-gw have different connections. There are LIN1, LIN2 and Can-Extended. There also might be more. Be safe and use one with HW:530AN(SW: AN,BC BG BL).
    Been there, done that.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  8. #8
    Aug 2018
    Update: Changed the RVC to an aftermarket composite one with a digital relay...issue still persists. Not sure what to do next. I have read on other threads that a possible software update may be required as a bug fix. Not sure how I can do that with a retrofitted unit with component protection removed. I have to reset the unit every time I start the car now to get it to change to the RVC screen. Not great.
