Results 1 to 10 of 14
Thread: UK discover media - Tmc help
    Nov 2016
    Just ironing out the creases now. Retrofitted the unit all ok, but I do not get anything on traffic, just a line through the Tmc icon. Does anyone have an adaption map from a working unit in the UK, or know what needs changing to make it work?
    Oct 2017
    Northwest UK
    Hi
    Can you please post an autoscan first and then let us know what vehicle you retrofitted what into. Your post is a little vague ����
    Nov 2016
    Letís do this a different way, does anyone at Ross tech have an adaption map for a 5C0035680B, from a UK vehicle, so I can compare adaption channels relating to TMC?
    An Auto-Scan would still be helpful, so we know which adaptation map is relevant to the modules fitted to your car.
    Nov 2016
    I can do, but as the 5F unit isnít installed or available on my gateway, the unit has to be access directly, which is why I included my part number
    ^^^ the "standard" technique for enabling TMC is to enter the correct code into the channel IDE05111-Fee-based traffic information (TMC) in the hex5F module.
    Here are the codes that I'm aware-of for various TMC systems:
    65535 - TMC OFF
    1024 - SUNA Traffic (Intelematics)
    0 - dev options
    32771 online traffic + VW TMCPro
    I'm not sure which system UK uses, but if it's the same data transmission mechanism as in Australia (i.e. a harmonic frequency on an FM band radio station via mobile data transmission),then you will need to ensure that RDS is activated in the code-string of the hex5F module as per the screen-shot below (enable bit 1 & bit 3):
    After this, "TP" and "RDS" need to be activated in the set-up menu for the radio
  7. #7
    Nov 2016
    Mine was set to 32768 when I checked. 1024 didnít bring any results. I will check these coding options and report back. Gut feeling is itís going to be a code that nobody has listed so far, but I can try all of the above. Many thanks.
  8. #8
    65535 - TMC OFF
    0 - dev options
    On my UK based Skoda Octavia the value in this channel is 1023.
  9. #9
    Nov 2016
    Thanks for everyoneís help
    3 was the magic number to make it work. Full traffic information now, although it didnít kick in until 24 hours after
  10. Likes Uwe liked this post
  11. #10
    Mar 2019
    Australia
    65535 - TMC OFF
    0 - dev options
    It still doesn't work for me.
    in both my cars MY 2018 Amarok and MY2018 Tiguan
    TMC icon stay always crossed.
    I'm wondering if they disabled another bit somewhere.
    Tiguan
    Thursday,11,April,2019,16:09:26:46987
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    VIN: WVGZZZ5NZJM135223   License Plate:
    Mileage:    Repair Order: tmc on
    UDS Adaptation Channel (2B): IDE05111-Fee-based traffic information (TMC)
    Stored value 1024
    Address 5F,3Q0 035 846 B,recoded (Long Coding-exp),from,02730608FF00000051510001000808001F0500C601200100CF,to,02730608FF00000051510001000908001F0500C601200100CF,(00066/790/00441),
    Amarok
    Wednesday,10,April,2019,15:32:00:46987
    VIN: WV1ZZZ2HZJA020643   License Plate:
    Mileage:    Repair Order: TMC
    Stored value 1024
    Address 5F,5C0 035 680 F,channel IDE02122-Developer mode,adapted from,not activated ,to,activated ,
