Hi guys,
I've got an intermittent fault code being logged with the EML illuminating relating to the EGR system - sometimes it's the normal EML, and other times its the flashing coil EML with the car going in to limp mode.
My car is a 2014 Mk7 Golf 1.6 TDI, with only 35,000 miles on the clock. It is used primarily on the motorway, with occasional around town driving; I'd say an 80/20 split - it gets up to temperature nearly every time it's driven, with only occasional exceptions.
The fault began shortly after changing the oil and filter at the beginning of July - coincidence?
I've had no loss of power or decrease in fuel economy, apart from when the car goes in to limp mode, of course - the car is otherwise running fine. I can clear the fault and it not reoccur for several hundreds of miles.
I've ran the automated EGR test in the ECU's basic settings, and it comes back okay.
I've attached two Auto Scans showing the fault code (P0401 00 [096] - Insufficient Flow) and associated freeze frames. Please ignore superfluous faults in other modules, as these span from working retrofits. Do the freeze frames perhaps shed any light on what could be wrong?
Any advice or recommendations would be welcomed
Thanks!
Thanks!
Thursday,05,July,2018,15:05:20:15053
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4422.4
VIN: WVWZZZAUZFW063529 License Plate: NY14EYS
Mileage: 52443km-32586mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 6C
VIN: WVWZZZAUZFW063529 Mileage: 52443km-32586miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012034505092000
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F381B8A979EE0AFD8D-807A
19206 - EGR System
P0401 00 [237] - Insufficient Flow
Mileage: 52177 km
Date: 2018.07.03
Time: 15:39:26
Engine speed: 2057.50 /min
Normed load value: 52.5 %
Vehicle speed: 34 km/h
Coolant temperature: 58 °C
Intake air temperature: 60 °C
Voltage terminal 30: 13.320 V
Exhaust recirculation valve 1 bank 1: mass flow - nominal value: 0.0 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 53.6 kg/h
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 45.70 %
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 83.78 %
Air mass at air mass meter 1: 68.6 kg/h
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.9922
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 62386000000027
Coding: 01FA8AA11426096F037C060241CC2580512890C06082A4F3F440F078C002
VCID: 0748932A5FAE98EF30D-8052
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 Q HW: 5G0 907 426 Q
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 392C25D259DA3E1F769-806C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0134
Serial number: 01011419800065
Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DA4F1C20D72C23F1A1-8028
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140710 042 0551
Serial number: 140712045121
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y14M07D24H06M32S31
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1416330NQ
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000030073175
Address 10: Park/Steer Assist (J791) Labels:. 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331419901969
Coding: 0071151001
ROD: N/A
VCID: 3D2431C24DF2023F5A1-8068
No ASAM data for: "EV_EPHVA18AU3700000" (VW37)
Address 13: Auto Dist. Reg
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0796S.
VCID: 7F580BCA077ED02F08D-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B18071470845
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B22071441063
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 107 14
Serial number: 357670000009E46DA01%
Subsystem 4 - Part No SW: ----------- HW: 480 002 107 14
Serial number: 3586700000079C61301P
Subsystem 5 - Part No SW: ----------- HW: 480 401 707 14
Serial number: 3516502BF15F3C32C17N
Subsystem 6 - Part No SW: ----------- HW: 480 401 707 14
Serial number: 3526502AB15F3C34C23I
Subsystem 7 - Part No SW: ----------- HW: 480 401 707 14
Serial number: 3556502A515F3C328318
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 21071404400531
Coding: 0C00
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BA0FFDA1366CC0F245-802E
Part No SW: 5G1 920 941 HW: 5G1 920 941
Component: KOMBI 204 4270
Coding: 27A51A002780260001887A011400000000000000
Shop #: WSC 12345 102 209715
VCID: 6696BEAE78E461E7EBB-8032
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002258229
Coding: 030100040B087300EF00005C080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011_VW37.rod
VCID: 42DE423E340C7DC7273-8016
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 27140001791070034295
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0087543903
Address 42: Door Elect, Driver (J386) Labels:. 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 13071402090651
Coding: 00110220D001048000001000
ROD: N/A
VCID: 40DA48363A006FD7317-8014
Serial number: 00000000000003258255
Coding: 1D0000
No ASAM data for: "EV_DCUDriveSideEWMAXKLO" (VW37)
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DC4D32310A66DF3E9-8014
Address 52: Door Elect, Pass. (J387) Labels:. 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 12071401100511
Coding: 00110020DE01048000801000
ROD: N/A
VCID: 3FD84BCA47FE102F48D-806A
Serial number: 00000000000003351145
Coding: 050000
No ASAM data for: "EV_DCUPasseSideEWMAXKLO" (VW37)
65608 - ROD - Unknown Error Code
- 00 [008]
Fault Frequency: 50
Reset counter: 105
Mileage: 48661 km
Date: 2018.06.14
Time: 13:19:23
Part No SW: 3G0 000 021 D HW: 3G0 035 021 E
Component: MU-H-LND-EU 053 0814
Serial number: A710A0XX002969
Coding: 02730001FF00000051111101008808001F0404C401200900D7
Shop #: WSC 00046 123 12345
VCID: 117CBD7221EAD65FEE9-8044
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H42 0022
Serial number: VWZ8Z9M23009SW
Subsystem 2 - Part No SW: V03 959 800 QS HW: -----------
Component: ECE 2018 --- 0166
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1015
B201A 00 [009] - -
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:55
Voltage terminal 30: 12.3 V
Status_Software_Version_Management-module_name: MDUV101/ABT
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:50
2565 - GPS Antenna
B1054 13 [008] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 102
Mileage: 51699 km
Date: 2018.07.01
Time: 13:25:24
Voltage terminal 30: 12.8 V
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 01730201C2002017000040
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:47
passive
13705478 - Databus
[message Parkhilfe_01 not received]
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:48
passive
End----------(Elapsed Time: 01:55, VBatt start/end: 12.5V/12.5V)-----------
Thursday,02,August,2018,12:46:00:15053
Mileage: 56271km-34965mi Repair Order:
VIN: WVWZZZAUZFW063529 Mileage: 56271km-34965miles
Revision: 84H22---
19206 - EGR System
Fault Frequency: 15
Mileage: 54869 km
Date: 2018.07.26
Time: 11:48:00
Engine speed: 1969.00 /min
Normed load value: 32.5 %
Vehicle speed: 101 km/h
Coolant temperature: 90 °C
Intake air temperature: 96 °C
Voltage terminal 30: 14.040 V
Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 51.4 kg/h
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 38.28 %
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 85.71 %
Air mass at air mass meter 1: 63.2 kg/h
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 3.6279
8291 - Databus
[FCAN: MO_QBit_Motormomente signal is invalid]
Reset counter: 133
Mileage: 56268 km
Date: 2018.08.02
Time: 10:56:50
Revision: 00001K06
Coding: 00A8DD
Coding: 0071151001
ROD: N/A
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 18071476510203
Coding: 00000300FE0739
VCID: 382A20D662D02717897-806C
Coding: 333135
Coding: 333135
Coding: 0C00
Coding: 2CFFFF
ROD: N/A
Coding: 1D0000
Coding: 8103
ROD: N/A
Coding: 050000
- 00 [008]
Fault Frequency: 79
Reset counter: 133
Mileage: 48661 km
Date: 2018.06.14
Time: 13:19:23
B201A 00 [009] - -
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:55
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:50
2565 - GPS Antenna
Reset counter: 129
Mileage: 53823 km
Date: 2018.07.15
Time: 12:33:51
Voltage terminal 30: 14.4 V
B2010 00 [009] - -
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:47
passive
13705478 - Databus
Reset counter: 34
Mileage: 48661 km
Date: 2018.06.14
Time: 12:38:48
passive
End----------(Elapsed Time: 01:40, VBatt start/end: 12.3V/12.3V)-----------
