Intermittent EGR fault on Mk7 Golf 1.6 TDI
IWMTom
C?ID=313572
Hi guys,
I've got an intermittent fault code being logged with the EML illuminating relating to the EGR system - sometimes it's the normal EML, and other times its the flashing coil EML with the car going in to limp mode.
My car is a 2014 Mk7 Golf 1.6 TDI, with only 35,000 miles on the clock. It is used primarily on the motorway, with occasional around town driving; I'd say an 80/20 split - it gets up to temperature nearly every time it's driven, with only occasional exceptions.
The fault began shortly after changing the oil and filter at the beginning of July - coincidence?
I've had no loss of power or decrease in fuel economy, apart from when the car goes in to limp mode, of course - the car is otherwise running fine. I can clear the fault and it not reoccur for several hundreds of miles.
I've ran the automated EGR test in the ECU's basic settings, and it comes back okay.
I've attached two Auto Scans showing the fault code (P0401 00 [096] - Insufficient Flow) and associated freeze frames. Please ignore superfluous faults in other modules, as these span from working retrofits. Do the freeze frames perhaps shed any light on what could be wrong?
Any advice or recommendations would be welcomed :)
Thanks!
Thursday,05,July,2018,15:05:20:15053
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4422.4
VIN: WVWZZZAUZFW063529   License Plate: NY14EYS
Mileage: 52443km-32586mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 6C
VIN: WVWZZZAUZFW063529   Mileage: 52443km-32586miles
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012034505092000
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F381B8A979EE0AFD8D-807A
19206 - EGR System
          P0401 00 [237] - Insufficient Flow
                    Mileage: 52177 km
                    Date: 2018.07.03
                    Time: 15:39:26
                    Engine speed: 2057.50 /min
                    Normed load value: 52.5 %
                    Vehicle speed: 34 km/h
                    Coolant temperature: 58 °C
                    Intake air temperature: 60 °C
                    Voltage terminal 30: 13.320 V
                    Exhaust recirculation valve 1 bank 1: mass flow - nominal value: 0.0 kg/h
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                    Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 53.6 kg/h
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 45.70 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 83.78 %
                    Air mass at air mass meter 1: 68.6 kg/h
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.9922
Readiness: 1 1 0 0 0
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 62386000000027
   Coding: 01FA8AA11426096F037C060241CC2580512890C06082A4F3F440F078C002
   VCID: 0748932A5FAE98EF30D-8052
   Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 392C25D259DA3E1F769-806C
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011419800065
   Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DA4F1C20D72C23F1A1-8028
   Component: WWS    140710  042 0551
   Serial number:         140712045121
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D24H06M32S31
   Coding: 00A8DD
   Serial number: 000000000ZY1416330NQ
   Serial number: 00000000000030073175
Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331419901969
   Coding: 0071151001
   ROD: N/A
   VCID: 3D2431C24DF2023F5A1-8068
No ASAM data for: "EV_EPHVA18AU3700000" (VW37)
Address 13: Auto Dist. Reg
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0796S.
   VCID: 7F580BCA077ED02F08D-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B18071470845
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B22071441063
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 107 14
   Serial number: 357670000009E46DA01%
   Subsystem 4 - Part No SW: -----------    HW: 480 002 107 14
   Serial number: 3586700000079C61301P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3516502BF15F3C32C17N
   Subsystem 6 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3526502AB15F3C34C23I
   Subsystem 7 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3556502A515F3C328318
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 21071404400531
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BA0FFDA1366CC0F245-802E
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         204 4270
   Coding: 27A51A002780260001887A011400000000000000
   Shop #: WSC 12345 102 209715
   VCID: 6696BEAE78E461E7EBB-8032
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002258229
   Coding: 030100040B087300EF00005C080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 42DE423E340C7DC7273-8016
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140001791070034295
   Coding: 2CFFFF
   Serial number: 0087543903
Address 42: Door Elect, Driver (J386)       Labels:. 5QX-959-X93-42.clb
   Serial number: 13071402090651
   Coding: 00110220D001048000001000
   ROD: N/A
   VCID: 40DA48363A006FD7317-8014
   Serial number: 00000000000003258255
   Coding: 1D0000
No ASAM data for: "EV_DCUDriveSideEWMAXKLO" (VW37)
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DC4D32310A66DF3E9-8014
Address 52: Door Elect, Pass. (J387)       Labels:. 5QX-959-X92-52.clb
   Serial number: 12071401100511
   Coding: 00110020DE01048000801000
   ROD: N/A
   VCID: 3FD84BCA47FE102F48D-806A
   Serial number: 00000000000003351145
   Coding: 050000
No ASAM data for: "EV_DCUPasseSideEWMAXKLO" (VW37)
65608 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 50
                    Reset counter: 105
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 13:19:23
   Part No SW: 3G0 000 021 D    HW: 3G0 035 021 E
   Component: MU-H-LND-EU   053 0814
   Serial number: A710A0XX002969
   Coding: 02730001FF00000051111101008808001F0404C401200900D7
   Shop #: WSC 00046 123 12345
   VCID: 117CBD7221EAD65FEE9-8044
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9M23009SW
   Subsystem 2 - Part No SW: V03 959 800 QS    HW: -----------
   Component: ECE 2018  --- 0166
   Component: Gracenote2---  --- 1015
          B201A 00 [009] -  -
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:55
                    Voltage terminal 30: 12.3 V
                    Status_Software_Version_Management-module_name: MDUV101/ABT
2571 - Navigation system
          B126C F2 [009] - Navigation database not enabled
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:50
2565 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 102
                    Mileage: 51699 km
                    Date: 2018.07.01
                    Time: 13:25:24
                    Voltage terminal 30: 12.8 V
   Coding: 01730201C2002017000040
10489856 - No Basic Setting
          B2010 00 [009] -  -
          [RearView system not calibrated]
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:47
                    passive
13705478 - Databus
          [message Parkhilfe_01 not received]
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:48
                    passive
End----------(Elapsed Time: 01:55, VBatt start/end: 12.5V/12.5V)-----------
Thursday,02,August,2018,12:46:00:15053
Mileage: 56271km-34965mi   Repair Order:
VIN: WVWZZZAUZFW063529   Mileage: 56271km-34965miles
   Revision: 84H22---
19206 - EGR System
                    Fault Frequency: 15
                    Mileage: 54869 km
                    Date: 2018.07.26
                    Time: 11:48:00
                    Engine speed: 1969.00 /min
                    Normed load value: 32.5 %
                    Vehicle speed: 101 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 96 °C
                    Voltage terminal 30: 14.040 V
                    Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 51.4 kg/h
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 38.28 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 85.71 %
                    Air mass at air mass meter 1: 63.2 kg/h
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 3.6279
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 133
                    Mileage: 56268 km
                    Date: 2018.08.02
                    Time: 10:56:50
   Revision: 00001K06
   Coding: 00A8DD
   Coding: 0071151001
   ROD: N/A
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 18071476510203
   Coding: 00000300FE0739
   VCID: 382A20D662D02717897-806C
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   Coding: 2CFFFF
   ROD: N/A
   Coding: 1D0000
   Coding: 8103
   ROD: N/A
   Coding: 050000
          - 00 [008]
                    Fault Frequency: 79
                    Reset counter: 133
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 13:19:23
          B201A 00 [009] -  -
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:55
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:50
2565 - GPS Antenna
                    Reset counter: 129
                    Mileage: 53823 km
                    Date: 2018.07.15
                    Time: 12:33:51
                    Voltage terminal 30: 14.4 V
          B2010 00 [009] -  -
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:47
                    passive
13705478 - Databus
                    Reset counter: 34
                    Mileage: 48661 km
                    Date: 2018.06.14
                    Time: 12:38:48
                    passive
End----------(Elapsed Time: 01:40, VBatt start/end: 12.3V/12.3V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Is there a condition to try clean the EGR valve? ;)
IWMTom
C?ID=313572
From what I understand, it's an absolute pig to get to it on this car, so ideally that's last on my list.
Is it not more likely to be an electrical/sensor fault given the intermittent nature of the fault, and the lack of reduction in performance/economy?
myounus
Northwest UK
C?ID=321059
What oil did you use? Was it longlife? The correct viscosity? Did you perform an SRI properly?
IWMTom
C?ID=313572
Castrol Edge 5W30, all up to VW spec.
I believe I did, yeah - would resetting the service indicator incorrectly somehow cause an EGR fault? Surely not?
myounus
Northwest UK
C?ID=321059
When you perform an SRI it doesn't simply switch a light off, it also resets soot quantity. I would suggest trying a regeneration and if you pop down to your local car shop get yourself some Forte DPF cleaner. Run that through and see if it keeps the light off.
IWMTom
C?ID=313572
I see - as I understand it, in the ROW market we cannot use the SRI function within VCDS and instead need to manually adjust the mileage and time in adaptations, which is what I did.
Would this still cause an issue?
I'll certainly give that a try, thanks :)
myounus
Northwest UK
C?ID=321059
I've used the SRI function myself many times and never done it manually.
IWMTom
C?ID=313572
I see.
Just out of curiosity, why does the soot quantity get reset when using the SRI procedure?
The "Soot quantity" in the SRI channels is just a calculated amount of soot in the oil. This calculation affects when the next service is due if the car in question is set to long-life/flexible service. But it has no influence on anything else like the DPF or the EGR system.
IWMTom
C?ID=313572
Gotcha, pretty unlikely that the service reset caused the fault then :)
