A4 B8 Avant - coding issues after Keyless Go / Xenon retrofit
   #21
Now it's 0...
It still says "Service Due"...
EDIT: After turning on the engine, drive approx 5 meters and reading the "SRI" again, it has now changed the value to 1 again. I'm about to give up... :banghead:
Given the values that are now it, it, I'm at a loss to explain that.
56-Day counter - what is that?
I believe it's the number of days since the car was "born" and cannot be changed.
hadez16
C?ID=289891
It might be possible to flash the BCM module to DJ. Both DH and DJ seem to have H16 as hardware "size" so it might be doable.
Edit: One more edit :)
Did some digging and looks like that there are two different xenon types for facelifted A4. non-AFS and AFS. Difference is that non-AFS does not need range control module and AFS control modules in the headlights. AFS lights need both range control module (older models, FL this is integrated to BCM1) and AFS modules. Range control module controls both the curve light and the side movement of the headlights according to how the steering wheel is turned.
According to your picture, you have AFS xenon lights as non-AFS do not have the curve light.
Do you have 2 control modules on the bottom of the headlight assembly? There should xenon ballast and AFS control module. The AFS control modules are controlled through CAN bus so they need can bus wiring added.
Edit 2 :
Sorry for mixing the thread still but found another source and there it said that FL A4 and A5 have separate level control module integrated to the BCM1. Seems that the BCM1 functions are controlled by parameterizations (surprise surprise) and it needs a new dataset for AFS headlights. That you cannot upload with VCDS unfortunately :(
For the reference, here's the PR codes. The BCM1 needs to support 8Q5 or 8Q6 depending on the AFS variant.
PRCode: 8Q1 =
Headlight-range adjustment
PRCode: 8Q1 = Headlight-range adjustment
PRCode: 8Q1 = Headlight-range adjustment static
PRCode: 8Q0 = Headlight-range adjustment 8Q3 = headlight-range adjustment dynamic
PRCode: 8Q4 = headlamp range adjustment with fixed bending light
PRCode: 8Q5 = headlight-range adjustment automatic / dynamic with bending dynamic light ( AFS 1)
PRCode: 8Q6 = headlight -range adjustment automatic / dynamic with fixed and dynamic bending light ( AFS 2)
PRCode: 8Q7 = Headlight-range adjustment
Hi
I struggled with that issue on a Audi Q5 for weeks...without any solution! I compared the f*** out of any Auto-Scan I could find with these headlights.
I assume that the solution is in parameters but I do not have a prove for that.
The pre-Facelift has a dedicated bit in Unit 55 for these static bending lights.
The problem is that Unit 55 went into the BCM due to the Facelift.
   #23
downtime
C?ID=280813
Yes, I saw your posts on the other forum. Although the picture I attached on the previous page of the BCM1 dataset contents shows that there's parameterization blocks for AFS lights, you're right, it still ain't the full proof that it would be a parameterization issue.
However, to quote Sherlock Holmes, "when you have eliminated the impossible, whatever remains, however improbable, must be the truth?". So in this case, this parameterization is the most logical reason.
   #24
diskoboy
C?ID=50403
Ahhhh :banghead: Just when I've thought I've got the right BCM1 in my car.
Picture of my BCM - please notice that pin 12 and 13 is missing
According to ElsaWin the "xenon-led-lights-can-bus" should be connected here
I think can stop trying to change any coding for now :(
   #25
downtime
C?ID=280813
I'm still pretty sure that you need to upload correct parameters if the BCM1 does not have them. However, get an used BCM1 and try to get one from a xenon equipped car. That should have correct parameters already in and then it's just connect, CP remove, code and fire away :)
   #26
diskoboy
C?ID=50403
Just found one on eBay. I’m 99,99% sure that if the pins are there, all the correct parameters are there as well. Seems that Audi is leaving out the pins when it’s not needed.
   #27
Seems they are making a science out of shaving every fraction of a penny of cost from everything if it's not absolutely needed. :facepalm:
downtime
C?ID=280813
Most likely yes. The CAN connection is only needed for AFS lights.
   #29
PetrolDave
Westbury, UK
C?ID=1423
But are they taking into account the extra cost to their systems of the more complex inventory, and the reduced volumes of every variant?
When I was working for a multi-national telecoms company we looked into this sort of multiple variant schema and found that the extra cost to our systems was greater than the savings in piece part costs!
I've often wondered that myself.
downtime
C?ID=280813
Yes they are. They know that the retrofit scene on VAG cars is BIG. So, why make it easier when you can sell the same part twice or even three times with much bigger premium :) There are always people who will want to do the retrofit before used parts are available so they need to buy brand new parts. That is money for VAG.
I'm pretty sure that it ain't a small amount of money that they get from aftersales.
   #32
PetrolDave
Westbury, UK
C?ID=1423
Then having bought the new part the retrofitter discovers in an increasing number of cases that VAG have made it a swap function, so they can't do the retrofit anyway :banghead: - without going the firmware hack route.
   #33
downtime
C?ID=280813
^ Amen to that :D
   #34
diskoboy
C?ID=50403
Update! Changed my BCM to a DJ version and now the headlight modules shows up :-)
Saturday,08,September,2018,10:07:44:21096
VCDS Version: 18.2.1.5
VIN: WAUZZZ8K3DA044370   License Plate: A4
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 47 52 53 56 5C
          5F 62 69 6C 6D 72
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (B8-PA-CDHA)       Labels:. 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
   Component: 1.8l R4/4V TF H04 0002
   Revision: PBH04---
   Coding: 12190013045401022000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM18TFS0118K1907115N 001004
   ROD: EV_ECM18TFS0118K1907115N.rod
   VCID: 3972996DB80BFA8C23-806C
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 16DDC401
   Shop #: WSC 06325 123 12345
   VCID: 07162F95B67F5C7C65-8052
   Part No SW: 8K0 907 064 HJ    HW: 8K0 907 064 GJ
   Component: BCM2 2.0      H13 0641
   Coding: 07A24000000000000000
   VCID: 7F06B775EEAF14BC5D-802A
   Serial number: 2312000060374001
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01220320120348
   Coding: 643802C000
   Shop #: WSC 06335 123 12345
   VCID: 336EAB45926700DCE9-8066
01207 - Control Module for Auxiliary Heater (J364)
                    Reset counter: 208
                    Mileage: 78762 km
                    Date: 2018.09.08
                    Time: 10:01:18
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000061453202
   Coding: 260080118074AFE01181408300001D0D4F9CE30826090241000008004401010200020034000000
   VCID: 7AF04661F58D31946A-802E
   Component: WWS 250312  H07 0070
   Serial number: SWF12030255319
   Coding: 00FD11
   Serial number: 20209350
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001703121109
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0021
   Serial number: 5018CD16000000000001
01312 - Powertrain Data Bus
                    Reset counter: 208
                    Mileage: 78762 km
                    Date: 2018.09.08
                    Time: 10:01:18
                    Reset counter: 208
                    Mileage: 78762 km
                    Date: 2018.09.08
                    Time: 10:01:19
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H11 0100
   Coding: 00A4B1
   VCID: 3162A14D687B32CC9B-8064
   Serial number: 003KFD91YZKL
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 05298 002 1048576
   VCID: 4894ECA9F3E19304AC-801C
   Serial number: 6334MSME6C112A41A
   Serial number: 6344MSME6D740409H
   Serial number: 6352QSME530F354AM
   Serial number: 6362QSME570F3F6E0
   Serial number: 63732SME7E0F586CN
   Serial number: 63832SME7A0F22665
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LAA00140
   Coding: 0000DF
   VCID: 448CF899C7C9B76440-8010
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 931 D    HW: 8K0 920 931 D
   Component: KOMBIINSTR.   H05 0534
   Revision: 00100000    Serial number: IWU271V4C
   Coding: 0FFF10004F000008010001
   Shop #: WSC 00751 204 00897
   VCID: 2F66A7357E4F243C8D-807A
                    Reset counter: 208
                    Mileage: 78762 km
                    Date: 2018.09.08
                    Time: 10:02:03
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z153080152
   Coding: 80C307FF00
   VCID: 4C9CD0B9EF997F2488-8018
   Serial number: 8519277101
   Serial number: 12056001533021200410
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Shop #: WSC 06385 000 00000
   VCID: 7CFC4079FFB90FA478-8028
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H03 0060
   Serial number: 0187427767
   Coding: 010321
   Shop #: WSC 02152 785 00200
   VCID: 3F86F775A62FD4BC1D-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H03 0060
   Serial number: 0187448857
   Coding: 000103
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000098250416
   Coding: 011F02205000410001
   Shop #: WSC 00605 128 28888
   VCID: 4FA6C7B51E8F443CED-801A
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0010433530
   Coding: 100001010001
   Shop #: WSC 17369 123 104857
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346CA8599F6907E4F0-8060
   Revision: 00002001    Serial number: 0319784903
   Coding: 01160F2020FD30C183B0023EA4000000
01134 - Alarm Horn (H12)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 208
                    Mileage: 78762 km
                    Date: 2018.09.08
                    Time: 10:03:22
   Revision: 00005001    Serial number: 94813006913102
   VCID: 2D5ABD3D7443562CBF-8078
   Revision:             Serial number: 0000072597277
   Coding: 011F02205C00410001
   VCID: 4E98DAB119854D34E6-801A
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 30000000034229
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 36689251891515F4CE-8062
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H52 0154
   Revision: AB001007    Serial number: 109FV0B7526224
   Coding: 010105010000000001
   Shop #: WSC 31414 790 00001
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08004    Serial number: 4002121190000E
   Coding: 0122002
   Shop #: WSC 06765 128 28888
   VCID: 37769F55461FECFCD5-8062
   Part No SW: 8R1 035 670 M    HW: 8R1 035 670 C
   Component: H-BNT-EU      H46 1036
   Revision: --------    Serial number: 207GZ0D7554081
   Coding: 0F0100010206EBFF3F80EF7E00000403040000000000000300
   VCID: 3D7A8D7DA423C6AC0F-8068
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Component: DU7 High  H42 0104
   Serial number: A130CK0F3302257
   Serial number: 00000002049538
   Component: CD-Database  5298
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Revision:             Serial number: 0000027010898
   Coding: 010C02204000410001
   VCID: 438EFB85C2C7B05C79-8016
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000142341233
   Coding: 010D000000000000
   Shop #: WSC 25381 000 00000
   VCID: 36689251811515F4CE-8062
   Revision: --H11---    Serial number: 525PA8-JB490BS
   Coding: 1030007
   Shop #: WSC 98765 666 38384
   VCID: 38749C694B01E384DC-806C
03006 - Back-up Camera System not calibrated
                    Reset counter: 208
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H51 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C7C8079BF39CFA438-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H51 0330
   Serial number: 8K9827852A
   Revision:             Serial number: 0000027010090
End-------------------------(Elapsed Time: 04:03)--------------------------
Now I just need to find the correct code for the automatic gearbox (code the BCM to manual transmission), and figure out why there is an error with the powertrain can. That didn't show up before - could it because of the missing automatic gearbox?
Also - the coding of [17] - what happened here ?
   #35
diskoboy
C?ID=50403
A little update.
I've got some of the errors removed, however I still have a problem in 09.
Wednesday,26,September,2018,16:09:51:21096
VIN: WAUZZZ8K3DA044370   License Plate: 26-09-2018
          5F 62 69 6C 6D 72
   Revision: PBH04---
   Coding: 16DDCC01
   Coding: 643802C000
                    Reset counter: 8
                    Mileage: 79355 km
                    Date: 2018.09.26
                    Time: 15:57:30
   Coding: 260000118974AFE00681400300001D0D439C270826080341000008000000030200000034000000
   Component: WWS 250312   0070
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0021
                    Reset counter: 8
                    Mileage: 79355 km
                    Date: 2018.09.26
                    Time: 16:04:46
   Coding: 00A4B1
   Coding: 0000DF
   Coding: 0FFF100047010008010001
   Coding: 80C307FF00
   Revision: AA001002
   Coding: 010321
   Coding: 000103
   Coding: 01160F2020FD30C183B0023684000000
            014 - Defective
                    Reset counter: 8
                    Mileage: 79355 km
                    Date: 2018.09.26
                    Time: 15:57:34
   Coding: 0122002
   Coding: 1030007
                    Reset counter: 8
End-------------------------(Elapsed Time: 04:04)--------------------------
I've found some coding in 03-ABS for 8Q5 (headlight-range adjustment automatic / dynamic with bending dynamic light ( AFS 1)). That did'nt seem to resolve my problem.
Coding has been matched from another car with the same headlights. I've checked ... and double-checked codings in 09 and 46, but no luck.
Where is the powertrain-can that I'm missing? I'm guessing that it's purely coding - not missing wires...
   #36
diskoboy
C?ID=50403
Update on my Service Due message. Ntech showed me the correct order to reset the service and now the message is gone. The numbers/days for next service is not correct but it’s fine ;) I know then I’ve should make the next service.
Can someone list all can bus connections that is connected to 09? Could it be that the build-in headlight leveling control unit has its own wires?
It seems that I’m the only one with this problem. Strangely when connecting to 09 in VCDS the headlights goes up/down and left/right so there is some connection.
diskoboy
C?ID=50403
I solved it!!
From J533 pin T20d/16 and T20d/6 I was missing powertrain-can wires. Should be connected to gateway T16b/10 and T16b/11. It's easy because of the colours...
The headlights are now going left and right while turning the steering wheel. The extra lamp is not on. I've recalled that someone wrote in a thread they only turn on while the car is moving. I don't know if this is correct.
Tomorrow I'll going to try with some different codings to see what's happening :-)
diskoboy
C?ID=50403
Regarding your static cornering lights:
You can try two things:
BCM, Set Bit 3 in Byte 4
Test it.
If it does not work, reset it again.
Then set Bit 0 in Byte 31 please and test.
I've finally tested it...
Cornering lights in the headlights are byte 33 bit 1 - enabled.
   #39
chrisjackd
C?ID=273871
I solved From J533 pin T20d/16 and T20d/6 I was missing powertrain-can wires. Should be connected to gateway T16b/10 and T16b/11. It's easy because of the colours...
What did you have to do to wire up your right headlamp?
I think I have everything wired up correct according to the wiring diagrams, but I don't know what to do on this page for T14b/1 and T14b/2.
The wiring diagram: https://imgur.com/WWs7Ifo has white/grey & green/grey wires as T14b/1 & T14b/2 going into the high bus and low bus, but I'm not sure what that is.
   #40
Dana
Western PA, USA
Post 24+ (where he mentioned xenon-led-lights-can-bus) covers those splices.
Because Facelift B8s don't use a 55-Headlight range/Xenon module all of the headlight control is handled by J519. For that reason the headlights need databus wiring to address 09/J519.
If you need help with the configuration please start a new thread with the Auto-Scan before the retrofit and another one at this point in time so anyone able to assist can check your part numbers and use the VIN for market specific wiring diagrams.
