I've retrofitted both Keyless Go and Xenon/LED to my 2013 Audi A4 Avant....
I have 2 (well 3 actually) problems:
1) Keyless Go is working almost perfekt. Start button is working. Door handles locks all doors, but when unlocking the car I've got a problem.
- If I touch the driver door handle, all other 3 doors unlocks. Driver door remains locked
- If I touch the front passager door handle, all other 3 doors unlocks. Front passenger door remains locked
- If I touch the one of the the rear doors handle, all other 3 doors unlocks.
It must be a coding issue, but I've really can't see what's going on.
Bonus info: [46] is a used box found on Ebay.
2) My xenon/LED lights are working as they should, however what byte should be enabled for this cornering lights to be enabled ?
3) Service Due! I've reset the service information and in MMI inspection and next oil change is in 27.000 km/+ 500 days, but the cluster keeps telling me that it's time for service when I put the ignition on/off.
What adaption channel do I need to reset ?
Hope it's okay with multiple questions in one thread :-)
Friday,03,August,2018,09:04:03:21096
VCDS Version: 18.2.1.5
VIN: WAUZZZ8K3DA044370 License Plate: A4
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 47 52 53 56 5C
5F 62 69 6C 6D 72
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (B8-PA-CDHA) Labels:. 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 N HW: 8K1 907 115 N
Component: 1.8l R4/4V TF H04 0002
Revision: PBH04---
Coding: 12190013045401022000
Shop #: WSC 06208 123 12345
ASAM Dataset: EV_ECM18TFS0118K1907115N 001004
ROD: EV_ECM18TFS0118K1907115N.rod
VCID: 3972996DB80BFA8C23-806C
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Coding: 16DDC401
Shop #: WSC 06325 123 12345
VCID: 07162F95B67F5C7C65-8052
Part No SW: 8K0 907 064 HJ HW: 8K0 907 064 GJ
Component: BCM2 2.0 H13 0641
Coding: 07A24000000000000000
VCID: 7F06B775EEAF14BC5D-802A
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000060374001
Part No SW: 8K1 820 043 N HW: 8K1 820 043 N
Component: KLIMA 3 ZONEN H04 0036
Revision: C1000000 Serial number: 01220320120348
Coding: 643802C000
Shop #: WSC 06335 123 12345
VCID: 336EAB45926700DCE9-8066
01207 - Control Module for Auxiliary Heater (J364)
Reset counter: 126
Mileage: 77270 km
Date: 2018.08.03
Time: 08:59:17
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000789001102
Coding: 26008011C074AFE00681400300001D0D439C270826080341000008000000020000000034000000
VCID: 78F45C69CB8123841C-802C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250312 H07 0070
Serial number: SWF12030255319
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20209350
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001703121109
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 5018CD16000000000001
01771 - Control Module for Headlight Range (J431)
Reset counter: 126
Mileage: 77270 km
Date: 2018.08.03
Time: 08:59:18
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 B HW: 8K0 907 561 B
Component: ACC3 H11 0100
Coding: 00A4B1
VCID: 3162A14D687B32CC9B-8064
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD91YZKL
Coding: 30514435363030303030554A304C384B3053
Shop #: WSC 05298 002 1048576
VCID: 4894ECA9F3E19304AC-801C
Serial number: 6334MSME6C112A41A
Serial number: 6344MSME6D740409H
Serial number: 6352QSME530F354AM
Serial number: 6362QSME570F3F6E0
Serial number: 63732SME7E0F586CN
Serial number: 63832SME7A0F22665
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H03 0004
Revision: -------- Serial number: 90372LAA00140
Coding: 0000DF
VCID: 448CF899C7C9B76440-8010
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 931 D HW: 8K0 920 931 D
Component: KOMBIINSTR. H05 0534
Revision: 00100000 Serial number: IWU271V4C
Coding: 0FFF100047010008010001
Shop #: WSC 00751 204 00897
VCID: 2F66A7357E4F243C8D-807A
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z153080152
Coding: 80C307FF00
VCID: 4C9CD0B9EF997F2488-8018
Serial number: 8519277101
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 12056001533021200410
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02019164747464545425363E00
Shop #: WSC 06385 000 00000
VCID: 7CFC4079FFB90FA478-8028
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H03 0060
Serial number: 0187427767
Coding: 010321
Shop #: WSC 02152 785 00200
VCID: 3F86F775A62FD4BC1D-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H03 0060
Serial number: 0187448857
Coding: 000103
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000098250416
Coding: 011F02205000410001
Shop #: WSC 00605 128 28888
VCID: 4FA6C7B51E8F443CED-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0010433530
Coding: 100001010001
Shop #: WSC 17369 123 104857
ROD: EV_RCEPSAU48X_008.rod
VCID: 346CA8599F6907E4F0-8060
Revision: 00002001 Serial number: 0319784903
Coding: 01161F2020FD30C183B0023EA4000000
01134 - Alarm Horn (H12)
014 - Defective
Fault Status: 01101110
Reset counter: 126
Mileage: 77270 km
Date: 2018.08.03
Time: 08:59:21
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813006913102
VCID: 2D5ABD3D7443562CBF-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000072597277
Coding: 011F02205C00410001
VCID: 4E98DAB119854D34E6-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 30000000034229
ROD: EV_ParkiBrake_AU48.rod
VCID: 36689251891515F4CE-8062
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H52 0154
Revision: AB001007 Serial number: 109FV0B7526224
Coding: 010105010000000001
Shop #: WSC 31414 790 00001
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08004 Serial number: 4002121190000E
Coding: 0122002
Shop #: WSC 06765 128 28888
VCID: 37769F55461FECFCD5-8062
Part No SW: 8R1 035 670 M HW: 8R1 035 670 C
Component: H-BNT-EU H46 1036
Revision: -------- Serial number: 207GZ0D7554081
Coding: 0F0100010206EBFF3F80EF7E00000403040000000100000300
VCID: 3D7A8D7DA423C6AC0F-8068
Subsystem 1 - Part No: 8R0 060 884 EM
Component: EUR 2017/2018 2503
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130CK0F3302257
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000002049538
Component: CD-Database 5298
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000027010898
Coding: 010C02204000210001
VCID: 438EFB85C2C7B05C79-8016
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000142341233
Coding: 010D000000000000
Shop #: WSC 25381 000 00000
VCID: 36689251811515F4CE-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H11--- Serial number: 525PA8-JB490BS
Coding: 1030007
Shop #: WSC 98765 666 38384
VCID: 38749C694B01E384DC-806C
03006 - Back-up Camera System not calibrated
Reset counter: 126
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H51 0330
Revision: -------- Serial number: 8K9827851A
VCID: 3C7C8079BF39CFA438-8068
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H51 0330
Serial number: 8K9827852A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000027010090
End-------------------------(Elapsed Time: 04:00)--------------------------
