Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: A4 B8 Avant - coding issues after Keyless Go / Xenon retrofit
  1. #31
    May 2017
    But are they taking into account the extra cost to their systems of the more complex inventory, and the reduced volumes of every variant?
    Yes they are. They know that the retrofit scene on VAG cars is BIG. So, why make it easier when you can sell the same part twice or even three times with much bigger premium There are always people who will want to do the retrofit before used parts are available so they need to buy brand new parts. That is money for VAG.
    I'm pretty sure that it ain't a small amount of money that they get from aftersales.
  2. Likes PetrolDave liked this post
  3. #32
    Then having bought the new part the retrofitter discovers in an increasing number of cases that VAG have made it a swap function, so they can't do the retrofit anyway - without going the firmware hack route.
  4. Likes downtime liked this post
  5. #33
    May 2017
    ^ Amen to that
  6. #34
    Aug 2014
    Update! Changed my BCM to a DJ version and now the headlight modules shows up :-)
    Saturday,08,September,2018,10:07:44:21096
    VCDS Version: 18.2.1.5
    VIN: WAUZZZ8K3DA044370   License Plate: A4
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 47 52 53 56 5C
              5F 62 69 6C 6D 72
    Address 01: Engine (B8-PA-CDHA)       Labels:. 06H-907-115-CAB.clb
       Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
       Component: 1.8l R4/4V TF H04 0002
       Revision: PBH04---
       Coding: 12190013045401022000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM18TFS0118K1907115N 001004
       ROD: EV_ECM18TFS0118K1907115N.rod
       VCID: 3972996DB80BFA8C23-806C
    Readiness: 1110 0101
       Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
       Component: ESP8 front    H09 0020
       Coding: 16DDC401
       Shop #: WSC 06325 123 12345
       VCID: 07162F95B67F5C7C65-8052
       Part No SW: 8K0 907 064 HJ    HW: 8K0 907 064 GJ
       Component: BCM2 2.0      H13 0641
       Coding: 07A24000000000000000
       Shop #: WSC 12345 123 12345
       VCID: 7F06B775EEAF14BC5D-802A
       Serial number: 2312000060374001
       Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
       Component: KLIMA 3 ZONEN H04 0036
       Revision: C1000000    Serial number: 01220320120348
       Coding: 643802C000
       Shop #: WSC 06335 123 12345
       VCID: 336EAB45926700DCE9-8066
                        Reset counter: 208
                        Mileage: 78762 km
                        Date: 2018.09.08
                        Time: 10:01:18
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000061453202
       Coding: 260080118074AFE01181408300001D0D4F9CE30826090241000008004401010200020034000000
       VCID: 7AF04661F58D31946A-802E
       Component: WWS 250312  H07 0070
       Serial number: SWF12030255319
       Coding: 00FD11
       Serial number: 20209350
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001703121109
       Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0021
       Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 5018CD16000000000001
    01312 - Powertrain Data Bus
                        Reset counter: 208
                        Mileage: 78762 km
                        Date: 2018.09.08
                        Time: 10:01:18
                        Reset counter: 208
                        Mileage: 78762 km
                        Date: 2018.09.08
                        Time: 10:01:19
       Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
       Component: ACC3          H11 0100
       Coding: 00A4B1
       VCID: 3162A14D687B32CC9B-8064
       Serial number: 003KFD91YZKL
       Coding: 30514435363030303030554A304C384B3053
       Shop #: WSC 05298 002 1048576
       VCID: 4894ECA9F3E19304AC-801C
       Serial number: 6334MSME6C112A41A
       Serial number: 6344MSME6D740409H
       Serial number: 6352QSME530F354AM
       Serial number: 6362QSME570F3F6E0
       Serial number: 63732SME7E0F586CN
       Serial number: 63832SME7A0F22665
       Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
       Component: Lenks.Modul   H03 0004
       Revision: --------    Serial number: 90372LAA00140
       Coding: 0000DF
       VCID: 448CF899C7C9B76440-8010
       Part No SW: 8K0 920 931 D    HW: 8K0 920 931 D
       Component: KOMBIINSTR.   H05 0534
       Revision: 00100000    Serial number: IWU271V4C
       Coding: 0FFF10004F000008010001
       Shop #: WSC 00751 204 00897
       VCID: 2F66A7357E4F243C8D-807A
                000 -  -
                        Reset counter: 208
                        Mileage: 78762 km
                        Date: 2018.09.08
                        Time: 10:02:03
       Revision: 1Z120030    Serial number: 3041Z153080152
       Coding: 80C307FF00
       Shop #: WSC 02391 785 00200
       VCID: 4C9CD0B9EF997F2488-8018
       Serial number: 8519277101
       Serial number: 12056001533021200410
       Revision: AA001002
       Coding: 02019164747464545425363E00
       Shop #: WSC 06385 000 00000
       VCID: 7CFC4079FFB90FA478-8028
       Component: SWA Master    H03 0060
       Serial number: 0187427767
       Coding: 010321
       Shop #: WSC 02152 785 00200
       VCID: 3F86F775A62FD4BC1D-806A
       Component: SWA Slave  H03 0060
       Serial number: 0187448857
       Coding: 000103
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000098250416
       Coding: 011F02205000410001
       Shop #: WSC 00605 128 28888
       VCID: 4FA6C7B51E8F443CED-801A
       Revision: 00001000    Serial number: 0010433530
       Coding: 100001010001
       Shop #: WSC 17369 123 104857
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346CA8599F6907E4F0-8060
       Revision: 00002001    Serial number: 0319784903
       Coding: 01160F2020FD30C183B0023EA4000000
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 208
                        Mileage: 78762 km
                        Date: 2018.09.08
                        Time: 10:03:22
       Revision: 00005001    Serial number: 94813006913102
       VCID: 2D5ABD3D7443562CBF-8078
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000072597277
       Coding: 011F02205C00410001
       VCID: 4E98DAB119854D34E6-801A
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 30000000034229
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 36689251891515F4CE-8062
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H52 0154
       Revision: AB001007    Serial number: 109FV0B7526224
       Coding: 010105010000000001
       Shop #: WSC 31414 790 00001
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
       Component: J759 HC             0040
       Revision: 00H08004    Serial number: 4002121190000E
       Coding: 0122002
       Shop #: WSC 06765 128 28888
       VCID: 37769F55461FECFCD5-8062
       Part No SW: 8R1 035 670 M    HW: 8R1 035 670 C
       Component: H-BNT-EU      H46 1036
       Revision: --------    Serial number: 207GZ0D7554081
       Coding: 0F0100010206EBFF3F80EF7E00000403040000000000000300
       VCID: 3D7A8D7DA423C6AC0F-8068
       Subsystem 1 - Part No: 8R0 060 884 EM
       Component: EUR 2017/2018  2503
       Component: DU7 High  H42 0104
       Serial number: A130CK0F3302257
       Serial number: 00000002049538
       Component: CD-Database  5298
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000027010898
       Coding: 010C02204000410001
       VCID: 438EFB85C2C7B05C79-8016
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00000142341233
       Coding: 010D000000000000
       Shop #: WSC 25381 000 00000
       VCID: 36689251811515F4CE-8062
       Revision: --H11---    Serial number: 525PA8-JB490BS
       Coding: 1030007
       Shop #: WSC 98765 666 38384
       VCID: 38749C694B01E384DC-806C
                000 -  -
                        Reset counter: 208
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H51 0330
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C7C8079BF39CFA438-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H51 0330
       Serial number: 8K9827852A
       Revision:             Serial number: 0000027010090
    End-------------------------(Elapsed Time: 04:03)--------------------------
    Now I just need to find the correct code for the automatic gearbox (code the BCM to manual transmission), and figure out why there is an error with the powertrain can. That didn't show up before - could it because of the missing automatic gearbox?
    Also - the coding of [17] - what happened here ?
    Audi A4 Avant - '13
    Next mod: none... Strange...
    Completed: Sport Edition Plus bumpers, Xenon/LED, MMI 3G+ DAB/SIM, PDC, A6 4G exterior door handles with lights, reverse camera, ACC, electric trunk, footwell lights, trailer hitch, Bang & Olufsen DSP, Side Assist, Active Lane Assist and Keyless Go
  7. #35
    Aug 2014
    A little update.
    I've got some of the errors removed, however I still have a problem in 09.
    Wednesday,26,September,2018,16:09:51:21096
    VIN: WAUZZZ8K3DA044370   License Plate: 26-09-2018
              5F 62 69 6C 6D 72
       Revision: PBH04---
       Coding: 16DDCC01
       Coding: 643802C000
                        Reset counter: 8
                        Mileage: 79355 km
                        Date: 2018.09.26
                        Time: 15:57:30
       Coding: 260000118974AFE00681400300001D0D439C270826080341000008000000030200000034000000
       Component: WWS 250312   0070
       Coding: 00FD11
       Coding: 02005D
    H01 0031
    H01 0021
                        Reset counter: 8
                        Mileage: 79355 km
                        Date: 2018.09.26
                        Time: 16:04:46
       Coding: 00A4B1
       Coding: 0000DF
       Coding: 0FFF100047010008010001
       Coding: 80C307FF00
       Revision: AA001002
       Coding: 010321
       Coding: 000103
       Coding: 01160F2020FD30C183B0023684000000
                014 - Defective
                        Reset counter: 8
                        Mileage: 79355 km
                        Date: 2018.09.26
                        Time: 15:57:34
       Coding: 0122002
       Coding: 1030007
                000 -  -
                        Reset counter: 8
    End-------------------------(Elapsed Time: 04:04)--------------------------
    I've found some coding in 03-ABS for 8Q5 (headlight-range adjustment automatic / dynamic with bending dynamic light ( AFS 1)). That did'nt seem to resolve my problem.
    Coding has been matched from another car with the same headlights. I've checked ... and double-checked codings in 09 and 46, but no luck.
    Where is the powertrain-can that I'm missing? I'm guessing that it's purely coding - not missing wires...
    Audi A4 Avant - '13
  8. #36
    Aug 2014
    Update on my Service Due message. Ntech showed me the correct order to reset the service and now the message is gone. The numbers/days for next service is not correct but it’s fine I know then I’ve should make the next service.
    Can someone list all can bus connections that is connected to 09? Could it be that the build-in headlight leveling control unit has its own wires?
    It seems that I’m the only one with this problem. Strangely when connecting to 09 in VCDS the headlights goes up/down and left/right so there is some connection.
    Audi A4 Avant - '13
  9. #37
    Aug 2014
    I solved it!!
    From J533 pin T20d/16 and T20d/6 I was missing powertrain-can wires. Should be connected to gateway T16b/10 and T16b/11. It's easy because of the colours...
    The headlights are now going left and right while turning the steering wheel. The extra lamp is not on. I've recalled that someone wrote in a thread they only turn on while the car is moving. I don't know if this is correct.
    Tomorrow I'll going to try with some different codings to see what's happening :-)
    Audi A4 Avant - '13
  10. Likes Uwe liked this post
  11. #38
    Aug 2014
    Regarding your static cornering lights:
    You can try two things:
    BCM, Set Bit 3 in Byte 4
    Test it.
    If it does not work, reset it again.
    Then set Bit 0 in Byte 31 please and test.
    I've finally tested it...
    Cornering lights in the headlights are byte 33 bit 1 - enabled.
    Audi A4 Avant - '13
