A4 B8 Avant - coding issues after Keyless Go / Xenon retrofit
diskoboy
C?ID=50403
I've retrofitted both Keyless Go and Xenon/LED to my 2013 Audi A4 Avant....
I have 2 (well 3 actually) problems:
1) Keyless Go is working almost perfekt. Start button is working. Door handles locks all doors, but when unlocking the car I've got a problem.
- If I touch the driver door handle, all other 3 doors unlocks. Driver door remains locked
- If I touch the front passager door handle, all other 3 doors unlocks. Front passenger door remains locked
- If I touch the one of the the rear doors handle, all other 3 doors unlocks.
It must be a coding issue, but I've really can't see what's going on.
Bonus info: [46] is a used box found on Ebay.
2) My xenon/LED lights are working as they should, however what byte should be enabled for this cornering lights to be enabled ?
3) Service Due! I've reset the service information and in MMI inspection and next oil change is in 27.000 km/+ 500 days, but the cluster keeps telling me that it's time for service when I put the ignition on/off.
What adaption channel do I need to reset ?
Hope it's okay with multiple questions in one thread :-)
Friday,03,August,2018,09:04:03:21096
VCDS Version: 18.2.1.5
VIN: WAUZZZ8K3DA044370   License Plate: A4
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 47 52 53 56 5C
          5F 62 69 6C 6D 72
Address 01: Engine (B8-PA-CDHA)       Labels:. 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
   Component: 1.8l R4/4V TF H04 0002
   Revision: PBH04---
   Coding: 12190013045401022000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM18TFS0118K1907115N 001004
   ROD: EV_ECM18TFS0118K1907115N.rod
   VCID: 3972996DB80BFA8C23-806C
Readiness: 1110 0101
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 16DDC401
   Shop #: WSC 06325 123 12345
   VCID: 07162F95B67F5C7C65-8052
   Part No SW: 8K0 907 064 HJ    HW: 8K0 907 064 GJ
   Component: BCM2 2.0      H13 0641
   Coding: 07A24000000000000000
   Shop #: WSC 12345 123 12345
   VCID: 7F06B775EEAF14BC5D-802A
   Serial number: 2312000060374001
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01220320120348
   Coding: 643802C000
   Shop #: WSC 06335 123 12345
   VCID: 336EAB45926700DCE9-8066
                    Reset counter: 126
                    Mileage: 77270 km
                    Date: 2018.08.03
                    Time: 08:59:17
   Revision: 08016001    Serial number: 00000789001102
   Coding: 26008011C074AFE00681400300001D0D439C270826080341000008000000020000000034000000
   VCID: 78F45C69CB8123841C-802C
   Component: WWS 250312  H07 0070
   Serial number: SWF12030255319
   Coding: 00FD11
   Serial number: 20209350
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001703121109
   Serial number: 5018CD16000000000001
                    Reset counter: 126
                    Mileage: 77270 km
                    Date: 2018.08.03
                    Time: 08:59:18
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H11 0100
   Coding: 00A4B1
   VCID: 3162A14D687B32CC9B-8064
   Serial number: 003KFD91YZKL
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 05298 002 1048576
   VCID: 4894ECA9F3E19304AC-801C
   Serial number: 6334MSME6C112A41A
   Serial number: 6344MSME6D740409H
   Serial number: 6352QSME530F354AM
   Serial number: 6362QSME570F3F6E0
   Serial number: 63732SME7E0F586CN
   Serial number: 63832SME7A0F22665
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LAA00140
   Coding: 0000DF
   VCID: 448CF899C7C9B76440-8010
   Part No SW: 8K0 920 931 D    HW: 8K0 920 931 D
   Component: KOMBIINSTR.   H05 0534
   Revision: 00100000    Serial number: IWU271V4C
   Coding: 0FFF100047010008010001
   Shop #: WSC 00751 204 00897
   VCID: 2F66A7357E4F243C8D-807A
   Revision: 1Z120030    Serial number: 3041Z153080152
   Coding: 80C307FF00
   Shop #: WSC 02391 785 00200
   VCID: 4C9CD0B9EF997F2488-8018
   Serial number: 8519277101
   Serial number: 12056001533021200410
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Shop #: WSC 06385 000 00000
   VCID: 7CFC4079FFB90FA478-8028
   Component: SWA Master    H03 0060
   Serial number: 0187427767
   Coding: 010321
   Shop #: WSC 02152 785 00200
   VCID: 3F86F775A62FD4BC1D-806A
   Component: SWA Slave  H03 0060
   Serial number: 0187448857
   Coding: 000103
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000098250416
   Coding: 011F02205000410001
   Shop #: WSC 00605 128 28888
   VCID: 4FA6C7B51E8F443CED-801A
   Revision: 00001000    Serial number: 0010433530
   Coding: 100001010001
   Shop #: WSC 17369 123 104857
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346CA8599F6907E4F0-8060
   Revision: 00002001    Serial number: 0319784903
   Coding: 01161F2020FD30C183B0023EA4000000
01134 - Alarm Horn (H12)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 126
                    Mileage: 77270 km
                    Date: 2018.08.03
                    Time: 08:59:21
   Revision: 00005001    Serial number: 94813006913102
   VCID: 2D5ABD3D7443562CBF-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000072597277
   Coding: 011F02205C00410001
   VCID: 4E98DAB119854D34E6-801A
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 30000000034229
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 36689251891515F4CE-8062
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H52 0154
   Revision: AB001007    Serial number: 109FV0B7526224
   Coding: 010105010000000001
   Shop #: WSC 31414 790 00001
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08004    Serial number: 4002121190000E
   Coding: 0122002
   Shop #: WSC 06765 128 28888
   VCID: 37769F55461FECFCD5-8062
   Part No SW: 8R1 035 670 M    HW: 8R1 035 670 C
   Component: H-BNT-EU      H46 1036
   Revision: --------    Serial number: 207GZ0D7554081
   Coding: 0F0100010206EBFF3F80EF7E00000403040000000100000300
   VCID: 3D7A8D7DA423C6AC0F-8068
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Component: DU7 High  H42 0104
   Serial number: A130CK0F3302257
   Serial number: 00000002049538
   Component: CD-Database  5298
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Revision:             Serial number: 0000027010898
   Coding: 010C02204000210001
   VCID: 438EFB85C2C7B05C79-8016
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000142341233
   Coding: 010D000000000000
   Shop #: WSC 25381 000 00000
   VCID: 36689251811515F4CE-8062
   Revision: --H11---    Serial number: 525PA8-JB490BS
   Coding: 1030007
   Shop #: WSC 98765 666 38384
   VCID: 38749C694B01E384DC-806C
            000 -  -
                    Reset counter: 126
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H51 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C7C8079BF39CFA438-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H51 0330
   Serial number: 8K9827852A
   Revision:             Serial number: 0000027010090
End-------------------------(Elapsed Time: 04:00)--------------------------
Probably 53 or 55, but...
Go to [SRI Reset], let VCDS read all the SRI-related channels, then click [Add to logfile] and post the file here so we can see exactly what's going on.
diskoboy
C?ID=50403
Here you go
VCDS Release 18.2.1:  SRI Reset
Control Module Part Number: 8K0 920 931 D       Labels:  .8T0-920-xxx-17.clb
Component:KOMBIINSTR.   H05 0534, Coding:0FFF100047010008010001
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	1             	---
40       	Distance since Service                            	km x100   	0             	---
41       	Time since Service                                	Days      	1             	---
42       	Minimum Distance to Service                       	km x100   	150           	---
43       	Maximum Distance to Service                       	km x100   	300           	---
44       	Maximum Time to Service                           	Days      	730           	---
45       	Oil Quality                                       	          	2             	---
47       	Soot Quantity                                     	DIST x100 	0             	---
48       	Thermal Load                                      	DIST x100 	0             	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	150           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	300           	---
53       	Distance since Inspection                         	km x100   	16            	---
54       	Basic Time Value for Inspection                   	Days      	730           	---
55       	Time since Inspection                             	Days      	20            	---
56       	Day Counter                                       	Days      	2433          	---
53 and 55 look OK; they are less than 52 and 54 respectively, so they're not the reason why the light remains on.
But 02 is a 1 in it. That indicates service is due. Not sure how/why what you've done so far, but looking at where it is right now, I'd just go put a zero into channel 2, with considerable confidence that will get the warning gone.
hadez16
C?ID=289891
Regarding your static cornering lights:
You can try two things:
BCM, Set Bit 3 in Byte 4
Test it.
If it does not work, reset it again.
Then set Bit 0 in Byte 31 please and test.
diskoboy
C?ID=50403
Test it.
Thanks for your sugestions :-)
Bit 3 Byte 4 - didn't do anything
Bit 0 Bite 31 however gave me this:
                Address 09: Cent. Elect.       Labels: 8K0-907-063.clb
Control Module Part Number: 8K0 907 063 DH    HW: 8K0 907 063 DH
  Component and/or Version: BCM1 1.0      H16 0103
           Software Coding: 2600C0108074AFC00081400300001D0D0F9C270826090341000008000001020100000034000000
            Work Shop Code: WSC 06335 123 12345
                      VCID: 78F45C69DB8123841C-802C
00497 - Sensor for Vehicle Leveling; Rear
                    Fault Status: 00100111
                    Reset counter: 177
                    Mileage: 77511 km
                    Date: 2018.08.06
                    Time: 21:07:19
01312 - Powertrain Data Bus
                    Reset counter: 137
                    Mileage: 77511 km
                    Date: 2018.08.06
                    Time: 21:07:58
1) Ive noticed that only the left side headlight went up/down when the ignition is on. Is there a easy way to test the modules like if the car has the [55]-module? I’ve been looking through all adaptation channels but can’t find any relevant...
2) Rear sensor - any adaptation channels?
3) After adding byte 31 bit 0 it throws the power train can error . Why? And what pins should they be connected to?
diskoboy
C?ID=50403
Channel 2 is now 0... "Service Due!" is still showing. I've also pulled out the battery just to be sure.
Please post an updated log of the channels, like you did in post #3.
diskoboy
C?ID=50403
Here is an updated scan:
41       	Time since Service                                	Days      	2             	---
53       	Distance since Inspection                         	km x100   	18            	---
55       	Time since Inspection                             	Days      	25            	---
56       	Day Counter                                       	Days      	2438          	---
Uhm.. Channel 02 still has a 1 in it. :confused:
diskoboy
C?ID=50403
Yes - I've just notised that as well. I'm 99,9% that it had 0 in it before I've vent out for a small test drive. However, doesn't "1" mean that service is not necessary ?
diskoboy
C?ID=50403
Regarding my cornering lights, I've searched google last night and found several logs with the same BCM as mine.
The 2 cornering control modules are missing in my setup. Either modules are dead or i'm missing some wires - however it's not possible for me do code byte 31 from 00 to 01 (in the danish version where is a label for that bit)
For example https://www.audizine.com/forum/showthread.php/513222-2013-B8-5-coding-required-please-assist
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
 Revision: 09016001 Serial number: 00000439050502
 Coding: 26000011863CAFE0210048C300003D0D0F9CD388A209022100 0008004000010200020030000000
 Shop #: WSC 06192 000 00000
 VCID: 7AFB4C73F5FCC4C86F1
 Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
 Component: WWS 260612 H15 0080
 Coding: 00FD11
 Coding: 02005D
 Component: USHL4.2 H30 0030
 Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
 H01 0031
 Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
 H01 0031
 Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Could it be that my BCM (8K0 907 063 DH) does not support cornering lights and 8K0 907 063 DJ does - it seems to be exact same software/hardware?
downtime
C?ID=280813
It might be possible to flash the BCM module to DJ. Both DH and DJ seem to have H16 as hardware "size" so it might be doable.
Edit: One more edit :)
Did some digging and looks like that there are two different xenon types for facelifted A4. non-AFS and AFS. Difference is that non-AFS does not need range control module and AFS control modules in the headlights. AFS lights need both range control module (older models, FL this is integrated to BCM1) and AFS modules. Range control module controls both the curve light and the side movement of the headlights according to how the steering wheel is turned.
According to your picture, you have AFS xenon lights as non-AFS do not have the curve light.
Do you have 2 control modules on the bottom of the headlight assembly? There should xenon ballast and AFS control module. The AFS control modules are controlled through CAN bus so they need can bus wiring added.
Edit 2 :
Sorry for mixing the thread still but found another source and there it said that FL A4 and A5 have separate level control module integrated to the BCM1. Seems that the BCM1 functions are controlled by parameterizations (surprise surprise) and it needs a new dataset for AFS headlights. That you cannot upload with VCDS unfortunately :(
For the reference, here's the PR codes. The BCM1 needs to support 8Q5 or 8Q6 depending on the AFS variant.
PRCode: 8Q1 =
Headlight-range adjustment
PRCode: 8Q1 = Headlight-range adjustment
PRCode: 8Q1 = Headlight-range adjustment static
PRCode: 8Q0 = Headlight-range adjustment 8Q3 = headlight-range adjustment dynamic
PRCode: 8Q4 = headlamp range adjustment with fixed bending light
PRCode: 8Q5 = headlight-range adjustment automatic / dynamic with bending dynamic light ( AFS 1)
PRCode: 8Q6 = headlight -range adjustment automatic / dynamic with fixed and dynamic bending light ( AFS 2)
PRCode: 8Q7 = Headlight-range adjustment
No. A non-zero value indicates that the cluster thinks service is necessary.
downtime
C?ID=280813
Looks like the parameter thing was correct. I checked the dataset content and indeed, there are multiple AFS calibration parameter sets and LWR calibration parameter set for your BCM1.
diskoboy
C?ID=50403
Now it's 0...
Component:KOMBIINSTR.   H05 0534, Coding:0FFF10004F010008010001
02       	Service Reminder Status                           	          	0             	---
41       	Time since Service                                	Days      	0             	---
55       	Time since Inspection                             	Days      	26            	---
56       	Day Counter                                       	Days      	2439          	---
It still says "Service Due"...
EDIT: After turning on the engine, drive approx 5 meters and reading the "SRI" again, it has now changed the value to 1 again. I'm about to give up... :banghead:
56-Day counter - what is that?
diskoboy
C?ID=50403
Edit 2 :
PRCode: 8Q1 =
I've check my headlights tomorrow...
Would it be a good idea to update my subscription for VCP to get the correct parameterization ? :-)
diskoboy
C?ID=50403
set Day Counter to 0
It's not possible. If I type 1 in New Value and press "Test" it just writes 2440 again. I've also tried with the security code before changing the value :(
