Maps 2017 Audi A3 1.4 TFSI E-TRON CUKB (Germany) maps
Maps
henbo
C?ID=318655
Jan-2017 Audi A3 1.4 TFSI e-tron sport +ACC +DAB +MFSW -MMI-TOUCH -NAV -VC
VCDS HNU AutoScan
Thursday,02,August,2018,07:57:04:50490
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WAUZZZ8V6HA000000   License Plate: 2017 A3 E-TRON
Mileage: 30904km-19202mi   Repair Order: 1808020757
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
          8C A5 C6
VIN: WAUZZZ8V6HA000000   Mileage: 30904km-19202miles
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AR    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3440
   Revision: X3H22---
   Coding: 021D0012636401083000
   Shop #: WSC 00000 000 00021
   ASAM Dataset: EV_ECM14TFS01104E906023AR 008003
   ROD: EV_ECM14TFS01104E906023AR_008.rod
   VCID: 70AC0F90AB6629C4D7-8024
   Part No SW: 0DD 300 046     HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1604
   Revision: 00032034    Serial number: TFK01611200000
   Shop #: WSC 00099 780 00200
   ASAM Dataset: EV_TCMDQ400021 001001
   ROD: EV_TCMDQ400021.rod
   VCID: 65826EC464A4FC6CB4-8030
30097 - Transmission Fluid Pressure
          P0867 00 [040] - Function Restriction due to Low Pressure
                    Mileage: 30534 km
                    Date: 2018.07.30
                    Time: 09:48:25
                    Engine speed: 18.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 70 km/h
                    Control Module temperature: 22 °C
                    CURRENT pressure: -10.0 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_7
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 12032
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 63546000000000
   Coding: 12F140A23829227189800E0941C52948021C44917082947218B15074822802
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
   VCID: 7CB42BA0F72E5DA47B-8028
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0426600000
   Coding: 030C0C
   VCID: 3B36E8BCB2A09A9C32-806E
   Part No SW: 8V0 820 043 R    HW: 8V0 820 043 R
   Component: AC Automat    H03 0110
   Revision: 20002000    Serial number: 00000000000000
   Coding: 0300000000001000080000000000100001000000
   ASAM Dataset: EV_AirCondiFrontRDWAU37X 001019
   ROD: EV_AirCondiFrontRDWAU37X.rod
   VCID: 41CA9A54D04CF04C68-8014
   Subsystem 1 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
   Component: J848 HV-PTC  200 0204
   Serial number: -00104.8T.3A20300000
   Serial number: DA48C06880PAG0M00000
   Subsystem 3 - Part No SW: 5QE 816 803     HW: 5QE 816 803
   Component: J842 eKK  H02 0007
393474 - Air Blower
          B10BE 1D [032] - Current Implausible
          [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Kurzschluss oder blockiert]
   Serial number: 02001700200000
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EB021A8E1324FB455-802A
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 161015  043 0580
   Serial number:         161029100000
   Coding: 0A47F7
   Component: G397_RLFS  H06
   Serial number: 62500000
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 22 10 2016  00000000
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 5500E7C111FFC728949C8045000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   Part No SW: 5Q0 959 655 AM    HW: 5Q0 959 655 AM
   Component: AirbagVW21    003 0317
   Serial number: 003PGR00000%
   Coding: 98CCC0000C2000009C540000004800000065
   VCID: 0B56787CA2806A1C42-805E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 701 17
   Serial number: 3570000000000008802H
   Subsystem 2 - Part No SW: -----------    HW: 480 000 701 17
   Serial number: 3580000000000008802M
   Subsystem 3 - Part No SW: -----------    HW: 480 400 901 17
   Serial number: 3510001C523B3B000000
   Subsystem 4 - Part No SW: -----------    HW: 480 400 901 17
   Serial number: 3520001A523B3B300000
   Subsystem 5 - Part No SW: -----------    HW: 480 401 311 16
   Serial number: 3550002B523C4E500000
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 711 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BB23B3B500000
   Subsystem 7 - Part No SW: -----------    HW: 480 400 711 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BB23B3B500000
   Subsystem 8 - Part No SW: -----------    HW: 480 001 212 16
   Serial number: I0M00000000765700000
   Subsystem 9 - Part No SW: -----------    HW: 480 001 212 16
   Serial number: I0N00000000055700000
   Part No SW: 8V0 953 521 MS    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 17101604400000
   Coding: EC18
   VCID: 177E140CEE489EFCF6-8042
   Part No SW: 8V0 920 873 H    HW: 8V0 920 873 H
   Component: KOMBI         H05 8316
   Coding: 07040C186F800008008328101200000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 43C6905CCA50E25C7A-8016
   Part No SW: 3Q0 907 530 D    HW: 3Q0 907 530 D
   Component: GW MQB EV     615 6286
   Serial number: 14121610800839
   Coding: 0201001726F200005B001218581000000001010100010000000300000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 302CCF906BE669C497-8064
   Subsystem 1 - Part No SW: 81A 951 523 B    HW: 81A 951 523 B
   Component: J453 MFL  H04 0003
   Serial number: 20160830000000 20175
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 7895800000
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085430011141
   Coding: 03720100331900010002050500
   Shop #: WSC 52735 001 1048576
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_004.rod
   VCID: 50ECAF100B2609C4F7-8004
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861301116100000
   Revision: 00000000    Serial number: 16000229730008
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424C3809FFE55E4F3-8060
   Serial number: 251116EKP0509A
   Coding: 00101F205C00040000001003
   Serial number: 00000000000012700000
   Coding: 110000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: D106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C28E44C464DC6C54-8010
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H11 1032
   Revision: 00H11000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 291A22F4483C180C50-807C
33109 - DC/DC Converter
          P33CB 00 [032] - Internal Malfunction
                    Fault Frequency: 112
   Serial number: 151216ELF3479A
   Coding: 001017205E00040000001003
   VCID: 42C89558D54AEB5471-8016
   Coding: 090000
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0E5A00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E30E1A8A1B28FB415-806A
   Part No SW: 81A 035 842 A    HW: 81A 035 842 A
   Component: MU-S-D-ER     710 0771
   Coding: 01739300FF00000011111101000A02002F0027440170010002
   ASAM Dataset: EV_MUStd6C3DELP 001013
   ROD: EV_MUStd6C3DELP_AU37.rod
   VCID: 210A3AD4300CD04C08-8074
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY200000
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BB    HW: 8V0 919 614 BB
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL114101600000000
6660 - No Communications with Display Unit 1 for Multimedia
          U10E2 00 [008] - -
          [Display 1: no signal/communication]
                    Reset counter: 185
                    Mileage: 30871 km
                    Date: 2018.07.31
                    Time: 21:44:51
                    Voltage terminal 30: 12.4 V
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0717
   Coding: 0173930110969A0100F800000000
   ROD: EV_OCULowMQB.rod
   VCID: 44C49340CF5EE56443-8010
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0911
   Serial number: U6000000
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006040
   ROD: EV_BECM06020115C6915182_VW37.rod
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0481
   Serial number: V013C1000000857
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0481
   Serial number: V013C1000000858
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0481
   Serial number: V013C1000000940
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0481
   Serial number: V013C1000000859
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0481
   Serial number: V013C1000000724
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0481
   Serial number: V013C1000000713
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0481
   Serial number: V013C1000000723
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0481
   Serial number: V013C1000000656
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 10011711K00000
   Coding: 0403070300000401012200448048A90084000E200020
   ROD: EV_MFKBoschMQBB_VW36.rod
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
   Component: OBC KOSTAL    H31 4013
   Revision: --------    Serial number: 0512160000003F
   Coding: 115068223000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 116A6A14C0AC40CCB8-8044
End----------(Elapsed Time: 01:37, VBatt start/end: 13.1V/13.1V)-----------
VCDS Mobile AutoScan (ROD/ASAM update does not seem to succeed)
VCDS Mobile 0.4411.0.4
Scan: 01 02 03 05 08 09 13 15 16 17 19 23 2B 42 44 52 55 5F 75 A5
	 C6
Address 01: Engine  (CUKB J623)	Labels: 04-01.clb
	Revision: X3H22---
	ROD: N/A
	VCID: 70A343C329B09B4B8163D25288-8025
	No ASAM data for: "EV_ECM14TFS01104E906023AR"
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Revision: 00032034
	VCID: E58DA2976672CEE362F5DBAE9F-80B0
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Revision: 00000000
	ROD: EV_Brake1UDSContiMK100OMG_AU37.rod
	VCID: 7CBB67F375F8EF2B2DDB56C274-8029
8400 - Implausible Data Received from Gear Shift Control Module
	U0404 00 [032] -
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Revision: 00021000
	Coding: 030C0C
	ROD: EV_KessyHellaMQBAB_VW37.rod
	VCID: 3B39A4EF3076281364518DD639-806E
Address 08: Auto HVAC  (E87)	Labels: 8V0-820-043.clb
	Revision: 20002000
	VCID: 41C5D607529A42C33E8DCF1E6B-8014
	Subsystem 1 -
	Subsystem 2 -
393474 - Air Blower
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	ROD: EV_BCMBOSCH_VW37.rod
	VCID: 7EBF6DFB63E4FD3B03EF6CFA52-802B
	Subsystem 1 - 	Part No SW: 8V1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component:
G÷
	Subsystem 2 -
	Subsystem 3 -
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	ROD: N/A
	No ASAM data for: "EV_ACCBOSCHVW416"
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	ROD: EV_AirbaVW20SMEVW37X.rod
	VCID: 8B59B42FA05658939471FD9629-80DE
	Subsystem 1 - 	Part No SW: --------------
	Component: ---
	Subsystem 2 - 	Component: ---
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
	Subsystem 7 - 	Component: ---
	Subsystem 8 - 	Component: ---
Address 16: Steering wheel  (J527)	Labels: 8V-16.lbl
	Revision: --------
	Coding: EC18
	ROD: EV_SMLSKLOMQB_AU37.rod
	VCID: 9771D85FEC9EAC7320E9810695-80C2
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	VCID: 43C9DC0F488650D32CA1E53651-8016
Address 19: CAN Gateway  (J533)	Labels: None
	ROD: N/A
	VCID: 302383C3E930DB4BC1E3125248-8065
	No ASAM data for: "EV_GatewNF"
	Subsystem 1 - 	Part No SW: 81A-951-523-B
	Component: J453 MFL
	Subsystem 2 -
Address 23: Brake Booster  (J539)	Labels: None
	ROD: EV_BrakeBoostBoschMQBOMG_AU37.rod
	VCID: 50E3E34389F0BB4BA12372D228-8005
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Revision: 00000000
	ROD: EV_ELVMarquMQB_VW37.rod
	VCID: 342B8FD31D28E76BA50B3E629C-8061
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	ROD: EV_DCUDriveSideEWMAXKLO.rod
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Coding: D106
	VCID: 45CDC21746B26EE302B5FB2EBF-8010
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	ROD: EV_DCUPasseSideEWMAXKLO.rod
	VCID: 42C7D90B579C59DB2797D80A66-8017
Address 55: Xenon Range  (J745)	Labels: None
	Revision: --------
	ROD: EV_HeadlRegulAUDIMXBAU64X_AU37.rod
	VCID: 3E3FADFB23643D3B436FACFA12-806B
Address 5F: Information Electr.  (J794)	Labels: None
	ROD: EV_MUStd6C3DELP.rod
	VCID: 21057687B2DA62C35E4D6F9E8B-8074
	Subsystem 1 - 	Part No SW: 8V0-919-604-C
	Component: DU High
	Subsystem 2 -
	U10E2 00 [008] -
Address 75: Telematics  (J949)	Labels: 5Q-75.clb
	VCID: 44CBDF134D8857EB15ABEE224C-8011
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
	ROD: EV_MFKBoschMQBB.rod
Address C6: Batt. Chrg.  (J1050)	Labels: None
	Revision: --------
	ROD: N/A
	VCID: 9165A647C27A72436EAD3FDE5B-80C4
	No ASAM data for: "EV_OBCSinglPhaseKLOMQB12P"
henbo
C?ID=318655
01 - Engine
After short EV drive, charging.
Blockmap
;SW:04E-906-023-AR   HW:04E-907-309-F ---  Engine
;Component:R4 1.4l TFS   H22 3440, Coding:021D0012636401083000
;EV_ECM14TFS01104E906023AR,008003,EV_ECM14TFS01104E906023AR_008.rod
;Thursday,02,August,2018,08:05:27:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 70AC0F90AB6629C4D7-8024
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WAUZZZ8V6HA000000,
IDE00019,Voltage terminal 30,13.200, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,26, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),16.5, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,0.0, Nm
IDE00148,Median injection timing,0.000, ms
IDE00151,Oil fill level,73.100, mm
IDE00152,Oil warning threshold,36.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,18.8, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-25.641, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.000, °
IDE00178,Camshaft adjustment intake bank 1: specified value,22.125, °
IDE00179,Camshaft adjustment intake bank 1: actual value,22.000, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,26.3, °C
IDE00188,Fuel high pressure: actual value,9.5875, MPa
IDE00190,Charge air pressure specified value,328.83, hPa
IDE00191,Charge air pressure: actual value,988.36, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,24.6, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,25.7, °C
IDE00201,High fuel pressure: specified value,13.0000, MPa
IDE00202,Low fuel pressure: specified value,509.2, kPa
IDE00304,Fuel level,25.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,25, °C
IDE00349,Throttle valve position: normed,7, %
IDE00350,Air mass: specified value,5.5, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,30.8, °C
IDE00358,Limitation: torque,400.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,991.45, hPa
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,13.67, %
IDE00392,Accelerator pedal: sensor voltage 1,759.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,363.6, mV
IDE00394,Camshaft position: start of phase window,111.67, °
IDE00406,Camshaft speed (RPM),0.0, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,0,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown,
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,21, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.005 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.450, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.999, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,15812, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00587,Vapor pressure in tank ventilation system,-32755, Pa
IDE00588,Fuel tank fill level,59.6, %
IDE00592,Oxygen sensor control status,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
IDE00594,Absolute intake pressure,98, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00657,Hybrid battery voltage,364.75, V
IDE00699,ESI: minimum oil level in service interval,12.576, mm
IDE00700,ESI: maximum oil level in service interval,26.448, mm
IDE00727,Test steps still to be performed,0,
IDE00752,Test of oxygen sensor control.,Syst. OK,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,228,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,21.7, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01260,Generator power,0, W
IDE01267,Height correction,0.97858,
IDE01378,High fuel pressure: control deviation,3.4145, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.450, V
IDE01650,Throttle valve position 2,16, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,blocked,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,13200, mV
IDE01869,Long-term fuel trim bank 1 at idle,-1.97, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,7.2600,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01876,Adaptation of loss torque,0.5, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,3.999, %
IDE01900,Charge press. ctrl.: spec. value,0.0, %
IDE01901,Lost torque adaptation: idle,0.5, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.06293,
IDE01911,Leakage air,4.0, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,15.9998,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,30904, km
IDE01923,Control module distance driven,30876777, m
IDE01928,Close cam shaft angle at quantity control valve,54.0, °
IDE01929,Open cam shaft angle at quantity control valve,-8.0, °
IDE01930,High pressure regulation: adaptation value,-0.1460, MPa
IDE01932,High pressure pump injection volume,279.90, mm³
IDE01975,Numb.of misfir.: cylinder 1,757,
IDE01976,Numb.of misfir.: cylinder 2,580,
IDE01977,Numb.of misfir.: cylinder 3,700,
IDE01978,Numb.of misfir.: cylinder 4,686,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,178,
IDE02116,Exhaust gas temperature before catalytic converter,19.09, °C
IDE02117,Relative load value,79.20, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03262,Adapt of angle sensor 1 f throttle valve,0.496, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.510, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.840, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.161, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3385.6, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,229,
IDE03709,Angle difference actual-specified camshaft adjuster,0.125, °
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767,Engine status,COENG_READY,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03814,Test of secondary air system: deviation mass air flow Bank 1,0.000,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03932,Charge pressure actuator: specified position,13.99, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3366.0, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,266.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.02872,
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04003,Charge air temperature sensor,B1S1:25 °C /  °C,
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:9480/--- kPa,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/26 °C / Compr. in/out---/--- °C,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,0.000000, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,0.000000, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04278,Bypass valve f high press turboch turbine inlet: target value,0.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,13.92, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,5.68, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,-5.68, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,0.00, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,16,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,698.2, mV
IDE04410,Intake manifold pressure: target value,312.42, hPa
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,WAITSIG,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,15.9998,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04872,Brake pedal value sensor: relative value filtered,-0.01, %
IDE04875,Brake pedal value sensor: learned zero point offset value,0.00, %
IDE04882,Operating mode control expanded electrical driving,Correct result,
IDE04882-ENG127289,Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE,1,
IDE04885,Hybrid batt charge cond act val standardized,64.86, %
IDE04887,Powertrain target torque,-284.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,-20.4, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,6,
IDE04913,Current speed of electric motor,0.0, /min
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,237582, s
IDE05140,Intake manifold pressure raw value,985.16, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05217,Hybrid battery charge current actual value,7.75, A
IDE05219,E-machine current actual value,0.00, A
IDE05220,E-machine voltage actual value,364.75, V
IDE05221,E-machine torque actual value,0.2, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05242,Phase angle adaptation request,False result,
IDE05242-ENG127289,Phase angle adaptation request-Test_Program_B TRUE UBYTE,0,
IDE05243,E-machine power consumption: actual value,0, W
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,21.8, °C
IDE05438,Rear cat conv temp main cat conv model value,19.54, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,16.99, %
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,131070, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,-0.00241,
IDE05464,Oxygen sensor 1 bank 1 fast offset adaptation counter,0,
IDE05466,Oxy sensor 1 bank 1 offset spec value,0.00000,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.000,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
IDE05479,Misfire recognition reference moment,0.000, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,375.00, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,255,
IDE05797,Throttle valve adapter: specified value,1.700, %
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,25.5, °C
IDE06021,Intake air temperature before throttle valve: raw value,26.3, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,0.0, /min
IDE06040,High fuel pressure: regulator output value,5.4355, MPa
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06056,Electric driving button status,Correct result,
IDE06056-ENG127289,Electric driving button status-Test_Program_B TRUE UBYTE,1,
IDE06098,Sensor control factor: output value,1.00000,
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06386,Oil level: static measurement,73.036, mm
IDE06387,Oil level: last valid dynamic value,19.464, mm
IDE06388,Oil level: condition for static measurement fulfilled,1,
IDE06393,Oil level: dynamic average value,19.688, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06607,Distance at last active oil overfill warning,0.0, km
IDE06608,Total distance with active oil overfill warnings,0.0, km
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,128,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,2,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,4,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,49,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06758,Air mass since engine start,0.00, kg
IDE06759,Cam shaft adaptation inlet: counter,3,
IDE06760,Camshaft adaptation: exhaust: counter,3,
IDE06828,Coolant recirc. pump 2: spec. value,95.00, %
IDE06830,Coolant pump for charge-air cooling: spec. value,28.32, %
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06948-ENG57549,High-volt. battery mode: spec. value-Bits 0-7,4,
IDE06953,Radiator bypass change-over valve activation,0.00, %
IDE06957,Unfiltered clutch input rpm,0.0, /min
IDE06965,Coolant temp. before power electronics: act. value,42.2, °C
IDE06972,High-volt. battery: charge state: abs. value,66.94, %
IDE07048,Gasoline tank pressure sensor unconditioned voltage,1.699, V
IDE07049,Gasoline tank pressure sensor: offset corrected,-6.10, hPa
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,0.0000,
IDE07095,Correction factor injector cylinder 2,0.0000,
IDE07096,Correction factor injector cylinder 3,0.0000,
IDE07097,Correction factor injector cylinder 4,0.0000,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,4,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,2,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,1,
IDE07239-ENG57549,Operating state of electric drive-Bits 0-7,50,
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07255-ENG57549,Number of refueling processes with time exceedance-Bits 0-7,1,
IDE07256-ENG57549,Number of refueling processes without time exceedance-Bits 0-7,45,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07573,Throttle valve adapter: actual value,8.47, %
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,1.0000,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,0.0000,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,0.0000,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,0.0000,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,0.125, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-0.641, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,0.68, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,-0.15, °
IDE10040,Outlet camshaft bank 1 active operating mode,0,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,0,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,30.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE11290,Heating circuit temp.: raw value,23.6, °C
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,3.254, l
IDE11522-ENG57549,Gasoline pressure tank fueling status-Bits 0-7,10,
IDE11523,State of shut-off valve to the gasoline pressure tank,false,
IDE11523-ENG127289,State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE,0,
IDE11574,Status max. oil level dynamically exceeded,0,
IDE11575,Status max. oil level permanently exceeded,0,
IDE11576,Oil level: last valid dynamic value overfilling,0.000, mm
IDE11968-ENG57549,Meter for tank-empty operation-Bits 0-7,0,
IDE12000,Combustion: minimum number calculated of active crankshaft segments,0.0, %
IDE12001,Combustion: calculated crankshaft angle after TO,0.00, °
IDE12002,Combustion: average calculated crankshaft angle after TO,0.00, °
IDE12003,Combustion: minimum calculated crankshaft angle after TO,0.00, °
IDE12004,Combustion: number of calculated active crankshaft segments,0.0, %
IDE12005,Combustion: average value calculated of active crankshaft segments,0.0, %
ENG119898,Actual_section_of_standard_test,0,
ENG101413,Calibration Identification,04E023AR3440BEAJ,
ENG99697,Calibration Verification Number,27 5E 04 DA,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1,01 51 0A 80 01 55 01 51 00 00 00 00 01 2B 01 51 00 00 00 00 01 25 01 51 00 00 00 00 00 00 00 00 01 05 01 51 00 00 00 00,
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
Elapsed Time: 00:31
ADP Map
;Thursday,02,August,2018,08:05:59:50490
IDE01945-Engine run-in oil pressure,not active ,1
IDE02248-Individually adjustable maximum speed limit,222.0 km/h,2
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04617-Protective function,Enabled ,1
IDE05847-Hybrid drive customer service,not active ,1
IDE11520-Open tank shut-off valve to the gasoline pressure tank,0 s,1
Elapsed Time: 00:02
henbo
C?ID=318655
02 Auto Trans
Block
;SW:0DD-300-046   HW:0DD-927-770-C ---  Auto Trans
;Component:GSG DQ400E    H32 1604, Coding:0014
;EV_TCMDQ400021,001001,EV_TCMDQ400021.rod
;Thursday,02,August,2018,08:02:22:50490
;VCID: 65826EC464A4FC6CB4-8030
IDE00008,Softwareversion,1604,
IDE00018,Voltage terminal 15,12.8, V
IDE00019,Voltage terminal 30,12.6, V
IDE00021-ENG99543,Engine speed-Engine RPM,0, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,0, /min
IDE00023,Transmission output speed,0, /min
IDE00024,Transmission fluid temperature,39, °C
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086-ENG98363,Accelerator position-Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1043.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,48, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG09093,Security Access: Number of invalid keys-Counter Value,0,
IDE00450-ENG12321,Operating Instructions-Requested Action,--no display--,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,602.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,0.00, bar
IDE02221,Engine torque: qualification,valid,
IDE02713,Brake Light Switch,not activated,
IDE02714,Brake test switch,not activated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,Voltage supply E-pump-Voltage Supply Electric Motor,12.6, V
IDE02727-ENG99192,Selector lever lock SPECIFIED condition-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,36, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,36, °C
IDE02742,Oil pressure actual value,0.00, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,1.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,1.50, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,1.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,1.50, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,247.1, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,248.0, mA
IDE02785-ENG120854,Pulse duty factor of valve for partial transmission 1-Duty_Factor_Valve_Transmission_Part_1,0.0, %
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,230.8, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,232.0, mA
IDE02789-ENG120856,Pulse duty factor of valve for partial transmission 2-Duty_Factor_Valve_Transmission_Part_2,0.0, %
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.08, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,0.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,0.0, mA
IDE02799-ENG120860,Duty cycle of valve for clutch 1-Duty_Factor_Valve_Clutch_1,0.0, %
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02801-ENG120891,Specified position clutch 2-Clutch_2_Commanded_Position,0.00, bar
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,0.23, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,0.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,0.0, mA
IDE02808-ENG120864,Duty cycle of valve for clutch 2-Duty_Factor_Valve_Clutch_2,0.0, %
IDE02820,Transmission mileage,30763.1, km
IDE02821-ENG101653,Pressure supply specified pressure/threshold1-Pressure Supply Commanded Value Threshold 1,53.00, bar
IDE02823-ENG100173,Identification of selector lever-Identification Selector Lever,8V1713023AC VL19,
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Steering wheel paddle installation info-Application Info Steering Paddels,59,
IDE02828-ENG103640,Brake installation info-Application Info Breaksystem,59,
IDE02829-ENG103127,Steering wheel module installation info-Application Info Steering Modul,59,
IDE02830-ENG100103,Gateway installation info-Application Info Gateway,59,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid basic calibration,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,7.71, mm
IDE02865-ENG104121,AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1,0,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,1.0, mA
IDE02870-ENG120871,Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor,0.0, %
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.22, mm
IDE02873-ENG101728,AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1,0,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,2.0, mA
IDE02878-ENG120875,Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor,0.0, %
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.04, mm
IDE02881-ENG99453,AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1,0,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,1.0, mA
IDE02886-ENG120879,Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor,0.0, %
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-8.13, mm
IDE02889-ENG100525,AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1,0,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,0.0, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,2.0, mA
IDE02894-ENG120883,Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor,0.0, %
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,0, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,2,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Data for basic calibration valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03160-ENG100046,Remaining clutch fast adaptations: kiss point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,30401.0, km
IDE03172-ENG100789,Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological,95, %
IDE03173-ENG103567,Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty,4, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,1, %
IDE03180-ENG103176,Number of standard trips-General Denominator,351,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,1416,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG28506,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG28505,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG28507,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG28638,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG28504,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,0.23, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.10, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,213.0, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,30900, km
IDE06425,Roller test bench mode: functional,not activated,
IDE08133-ENG121991,Basic setting: cause for cancellation-Routine_abort_reason,Basic setting not active,
IDE10834-ENG127894,Identification data hybrid module-Anfang,#,
IDE10834-ENG98612,Identification data hybrid module-Date of manufacture,170109,
IDE10834-ENG98577,Identification data hybrid module-END,#,
IDE10834-ENG112382,Identification data hybrid module-Index,K ,
IDE10834-ENG120774,Identification data hybrid module-Lfd. Nr. pro Tag,0000,
IDE10834-ENG120775,Identification data hybrid module-Linienkennung,G04,
IDE10834-ENG124826,Identification data hybrid module-Measured value,Angle=277,0,
IDE10834-ENG126639,Identification data hybrid module-Messwert G1,G1=33,84,
IDE10834-ENG126640,Identification data hybrid module-Messwert G2,G2=29,61,
IDE10834-ENG126641,Identification data hybrid module-Messwert K1,K1=76,27,
IDE10834-ENG126634,Identification data hybrid module-Standort,K,
IDE10834-ENG126637,Identification data hybrid module-Trennzeichen 1,*&*,
IDE10834-ENG126638,Identification data hybrid module-Trennzeichen 2,*,
IDE10834-ENG126643,Identification data hybrid module-Trennzeichen 3,*,
IDE10834-ENG126642,Identification data hybrid module-Trennzeichen 4,*,
IDE10834-ENG126633,Identification data hybrid module-VW-Teilenummer,0DD901152,
IDE10835-IDE00009,Identification data: electric machine-Date of manufacture,161204,
IDE10835-MAS04970,Identification data: electric machine-Part Number,0EC901091,
IDE10835-ENG112382,Identification data: electric machine-Index,T_,
IDE10835-ENG126635,Identification data: electric machine-Kennbuchstabe,EAH_,
IDE10835-ENG126636,Identification data: electric machine-Laufnummer (über Alles),AG0000,
IDE10835-ENG120774,Identification data: electric machine-Lfd. Nr. pro Tag,0000,
IDE10835-ENG120775,Identification data: electric machine-Linienkennung,G00,
IDE10835-ENG126634,Identification data: electric machine-Standort,K,
IDE10889-ENG127918,Pulse duty ratio: clutch cooling valve-Duty Factor Valve Clutch Cooling,100.0, %
IDE10890-ENG127919,Pulse duty ratio: reservoir filling valve-Duty Factor Accumulator Pressure Valve,32.1, %
IDE10891-ENG127920,Pulse duty ratio: clutch valve K0-Duty Factor Valve Clutch 0,0.0, %
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,0,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,1,
IDE11206-ENG98675,Mechatronic identification DQ400e-Construction version,B2,
IDE11206-ENG98612,Mechatronic identification DQ400e-Date of manufacture,161214,
IDE11206-ENG112382,Mechatronic identification DQ400e-Index,F-,
IDE11206-ENG120774,Mechatronic identification DQ400e-Lfd. Nr. pro Tag,0000,
IDE11206-ENG120775,Mechatronic identification DQ400e-Linienkennung,G00,
IDE11206-ENG126634,Mechatronic identification DQ400e-Standort,K,
IDE11206-ENG120776,Mechatronic identification DQ400e-Ventilkennung,A,
IDE11206-ENG126633,Mechatronic identification DQ400e-VW-Teilenummer,0DD325025,
IDE11241-ENG127896,Clutch 0 kiss point: successful adaptation counter-Clutch 0 adaption kisspoint positive case counter,1374,
IDE11242-ENG127897,Clutch 0 upper point adaptation: success counter-Clutch 0 adaption upper point positive case counter,1274,
IDE11243-ENG127898,Clutch 0 adaptation: reference start counter-Clutch 0 adaption counter for reference start counter,1889,
IDE11244-ENG127899,Couple 0 adaptation: characteristic point 1 pressure-Clutch 0 adaption characteristic point 1 pressure,9.50, bar
IDE11245-ENG127900,Couple 0 adaptation: characteristic point 1 torque-Clutch 0 adaption characteristic point 1 torque,0.0, Nm
IDE11246-ENG127901,Couple 0 adaptation: characteristic point 2 pressure-Clutch 0 adaption characteristic point 2 pressure,10.50, bar
IDE11247-ENG127902,Couple 0 adaptation: characteristic point 2 torque-Clutch 0 adaption characteristic point 2 torque,10.0, Nm
IDE11248-ENG127903,Couple 0 adaptation: characteristic point 3 pressure-Clutch 0 adaption characteristic point 3 pressure,25.05, bar
IDE11249-ENG127904,Couple 0 adaptation: characteristic point 3 torque-Clutch 0 adaption characteristic point 3 torque,400.0, Nm
IDE11885-ENG09172,Error status of pump motor activation-Failure_status,0,
IDE11885-ENG09276,Error status of pump motor activation-Failure_status_cumulated,0,
IDE11921-ENG09197,Reason for cancelling emptying of oil pressure reservoir-Abort_reason_automatic_transmission_fluid_pressure_accumulator_discharge,Do not cancel,
IDE12712-ENG36173,Odometer reading on adopting the vehicle odometer reading-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG36135,Transmission odometer reading-Gearbox mileage,30763.1, km
IDE13947-ENG36805,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,0, km
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,303,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,30530, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,1,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,31.5, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,OFF,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG_R,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG_1,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,7.68, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-0.16, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,0.00, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-8.00, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.1, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.3, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,200, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,11.4, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,30, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,30, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,0,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,01 2F,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,1839.4, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,2942067.8, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,199683.9, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,0.0, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,87, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,3012672.1, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,128998.2, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,489.1, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,55.2, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,256, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,3023387.4, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,118686.5, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,133.5, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,3.1, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,164, °C
IDE80097-ENG06584,Analysis 97-Snapshot 1 electric motor actual current,4, A
IDE80097-ENG06583,Analysis 97-Snapshot 1 electric motor actual speed,800, /min
IDE80097-ENG06585,Analysis 97-Snapshot 1 electric motor actual state,geregelt,
IDE80097-ENG06582,Analysis 97-Snapshot 1 electric motor commanded speed,800, /min
IDE80098-ENG06588,Analysis 98-Snapshot 2 electric motor actual current,0, A
IDE80098-ENG06587,Analysis 98-Snapshot 2 electric motor actual speed,0, /min
IDE80098-ENG06589,Analysis 98-Snapshot 2 electric motor actual state,???,
IDE80098-ENG06586,Analysis 98-Snapshot 2 electric motor commanded speed,0, /min
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),430.3, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),103.1, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),1.6, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.7, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,11197,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,35024,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,41092,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,35551,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,30276,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,14299,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,3067,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,80,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,392,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,47,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,293,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,365,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,215,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,30,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),836.8, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),35.8, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.1, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.0, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),839.8, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),33.0, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.0, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),90.4, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),31.7, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),6.6, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),0.4, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),152.8, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),72.0, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),11.5, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),0.4, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80260-ENG127862,Pressure supply: act. press.-Pressure supply actual pressure,46.34, bar
IDE80261-ENG127834,Pressure supply: act. press.: AD value-Pressure supply actual pressure AD value,2614,
IDE80262-ENG127829,Pressure supply: spec. RPM-Pressure supply commanded speed,220, /min
IDE80263-ENG127885,Pressure supply: act. RPM-Pressure supply actual speed,205, /min
IDE80265-ENG127855,Pressure supply: act. current-Pressure supply actual current,130.0, mA
IDE80267-ENG127877,Pressure supply: act. condition-Pressure supply actual state,7,
IDE80269-ENG127893,Pressure supply: last error condition of driver-Pressure supply last driver state,0,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,30904, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,0, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,32,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,400.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,400.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,1896,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,30890, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,1522,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,30890, km
IDE80303-ENG127833,Overall software description-Software full name,H16,
IDE80305-ENG125922,Parameter set description-Data set name,0DD300046_1604_RJSD,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
IDE80313-ENG127174,Transmission identification DQ400e-Baugruppennummer,006,
IDE80313-ENG98612,Transmission identification DQ400e-Date of manufacture,170110,
IDE80313-ENG112382,Transmission identification DQ400e-Index,  ,
IDE80313-ENG126635,Transmission identification DQ400e-Kennbuchstabe,SBZ,
IDE80313-ENG120774,Transmission identification DQ400e-Lfd. Nr. pro Tag,0000,
IDE80313-ENG120775,Transmission identification DQ400e-Linienkennung,G00,
IDE80313-ENG126634,Transmission identification DQ400e-Standort,K,
IDE80313-ENG126633,Transmission identification DQ400e-VW-Teilenummer,0DD300046 ,
IDE80314-ENG127917,Clutch 0 Adaption vehicle odometer reading-Clutch 0 adaption vehicle mileage,30900, km
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,22, °C
ENG130270-ENG130289,Ausgabe der Abschalt- und Resetdaten 1-aktiver Fehler,10,
ENG130270-ENG130284,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 0,80 08 34 D6,
ENG130270-ENG130285,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 1,80 08 39 7A,
ENG130270-ENG130286,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 2,80 08 14 06,
ENG130270-ENG130287,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 3,80 13 D1 E2,
ENG130270-ENG130290,Ausgabe der Abschalt- und Resetdaten 1-erweiterte Informationen zum aktiven Fehler,0,
ENG130270-ENG130283,Ausgabe der Abschalt- und Resetdaten 1-Gesamt-Software-Version,H16,
ENG130270-ENG130292,Ausgabe der Abschalt- und Resetdaten 1-gewichteter Resetzähler,7,
ENG130270-ENG130295,Ausgabe der Abschalt- und Resetdaten 1-Klemme 15-Spannung,12.2, V
ENG130270-ENG130296,Ausgabe der Abschalt- und Resetdaten 1-Klemme 30-Spannung,11.8, V
ENG130270-ENG130288,Ausgabe der Abschalt- und Resetdaten 1-kumulierte Fehlermaske,40 00 04 00,
ENG130270-ENG130297,Ausgabe der Abschalt- und Resetdaten 1-Mechatroniktemperatur,33, °C
ENG130270-ENG98689,Ausgabe der Abschalt- und Resetdaten 1-Odometer reading,1940, km
ENG130270-ENG130291,Ausgabe der Abschalt- und Resetdaten 1-Reset Quelle,3,
ENG130270-ENG112343,Ausgabe der Abschalt- und Resetdaten 1-Reset Status,0,
ENG130270-ENG130293,Ausgabe der Abschalt- und Resetdaten 1-Reset Typ,0,
ENG130270-ENG130294,Ausgabe der Abschalt- und Resetdaten 1-Status CHS-Abschaltung,1,
ENG130270-ENG130300,Ausgabe der Abschalt- und Resetdaten 1-Status des Eintrags,BB,
ENG130270-ENG130299,Ausgabe der Abschalt- und Resetdaten 1-Uds-Lesestatus des Eintrages,1,
ENG130270-ENG130298,Ausgabe der Abschalt- und Resetdaten 1-von Dksw uebergebene Fehlerdaten,0,
ENG130271-ENG130289,Ausgabe der Abschalt- und Resetdaten 2-aktiver Fehler,30,
ENG130271-ENG130284,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 0,80 13 CF 58,
ENG130271-ENG130285,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 1,80 13 17 10,
ENG130271-ENG130286,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 2,A0 01 49 EE,
ENG130271-ENG130287,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 3,00 00 00 00,
ENG130271-ENG130290,Ausgabe der Abschalt- und Resetdaten 2-erweiterte Informationen zum aktiven Fehler,0,
ENG130271-ENG130283,Ausgabe der Abschalt- und Resetdaten 2-Gesamt-Software-Version,H16,
ENG130271-ENG130292,Ausgabe der Abschalt- und Resetdaten 2-gewichteter Resetzähler,7,
ENG130271-ENG130295,Ausgabe der Abschalt- und Resetdaten 2-Klemme 15-Spannung,12.2, V
ENG130271-ENG130296,Ausgabe der Abschalt- und Resetdaten 2-Klemme 30-Spannung,12.0, V
ENG130271-ENG130288,Ausgabe der Abschalt- und Resetdaten 2-kumulierte Fehlermaske,40 00 04 00,
ENG130271-ENG130297,Ausgabe der Abschalt- und Resetdaten 2-Mechatroniktemperatur,33, °C
ENG130271-ENG98689,Ausgabe der Abschalt- und Resetdaten 2-Odometer reading,1940, km
ENG130271-ENG130291,Ausgabe der Abschalt- und Resetdaten 2-Reset Quelle,7,
ENG130271-ENG112343,Ausgabe der Abschalt- und Resetdaten 2-Reset Status,0,
ENG130271-ENG130293,Ausgabe der Abschalt- und Resetdaten 2-Reset Typ,1,
ENG130271-ENG130294,Ausgabe der Abschalt- und Resetdaten 2-Status CHS-Abschaltung,1,
ENG130271-ENG130300,Ausgabe der Abschalt- und Resetdaten 2-Status des Eintrags,BB,
ENG130271-ENG130299,Ausgabe der Abschalt- und Resetdaten 2-Uds-Lesestatus des Eintrages,1,
ENG130271-ENG130298,Ausgabe der Abschalt- und Resetdaten 2-von Dksw uebergebene Fehlerdaten,0,
ENG130272-ENG130289,Ausgabe der Abschalt- und Resetdaten 3-aktiver Fehler,0,
ENG130272-ENG130284,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 0,00 00 00 00,
ENG130272-ENG130285,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 1,00 00 00 00,
ENG130272-ENG130286,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 2,00 00 00 00,
ENG130272-ENG130287,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 3,00 00 00 00,
ENG130272-ENG130290,Ausgabe der Abschalt- und Resetdaten 3-erweiterte Informationen zum aktiven Fehler,0,
ENG130272-ENG130283,Ausgabe der Abschalt- und Resetdaten 3-Gesamt-Software-Version,,
ENG130272-ENG130292,Ausgabe der Abschalt- und Resetdaten 3-gewichteter Resetzähler,0,
ENG130272-ENG130295,Ausgabe der Abschalt- und Resetdaten 3-Klemme 15-Spannung,51.0, V
ENG130272-ENG130296,Ausgabe der Abschalt- und Resetdaten 3-Klemme 30-Spannung,51.0, V
ENG130272-ENG130288,Ausgabe der Abschalt- und Resetdaten 3-kumulierte Fehlermaske,00 00 00 00,
ENG130272-ENG130297,Ausgabe der Abschalt- und Resetdaten 3-Mechatroniktemperatur,215, °C
ENG130272-ENG98689,Ausgabe der Abschalt- und Resetdaten 3-Odometer reading,655350, km
ENG130272-ENG130291,Ausgabe der Abschalt- und Resetdaten 3-Reset Quelle,0,
ENG130272-ENG112343,Ausgabe der Abschalt- und Resetdaten 3-Reset Status,0,
ENG130272-ENG130293,Ausgabe der Abschalt- und Resetdaten 3-Reset Typ,0,
ENG130272-ENG130294,Ausgabe der Abschalt- und Resetdaten 3-Status CHS-Abschaltung,0,
ENG130272-ENG130300,Ausgabe der Abschalt- und Resetdaten 3-Status des Eintrags,FF,
ENG130272-ENG130299,Ausgabe der Abschalt- und Resetdaten 3-Uds-Lesestatus des Eintrages,1,
ENG130272-ENG130298,Ausgabe der Abschalt- und Resetdaten 3-von Dksw uebergebene Fehlerdaten,255,
ENG130273-ENG130289,Ausgabe der Abschalt- und Resetdaten 4-aktiver Fehler,0,
ENG130273-ENG130284,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 0,00 00 00 00,
ENG130273-ENG130285,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 1,00 00 00 00,
ENG130273-ENG130286,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 2,00 00 00 00,
ENG130273-ENG130287,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 3,00 00 00 00,
ENG130273-ENG130290,Ausgabe der Abschalt- und Resetdaten 4-erweiterte Informationen zum aktiven Fehler,0,
ENG130273-ENG130283,Ausgabe der Abschalt- und Resetdaten 4-Gesamt-Software-Version,,
ENG130273-ENG130292,Ausgabe der Abschalt- und Resetdaten 4-gewichteter Resetzähler,0,
ENG130273-ENG130295,Ausgabe der Abschalt- und Resetdaten 4-Klemme 15-Spannung,51.0, V
ENG130273-ENG130296,Ausgabe der Abschalt- und Resetdaten 4-Klemme 30-Spannung,51.0, V
ENG130273-ENG130288,Ausgabe der Abschalt- und Resetdaten 4-kumulierte Fehlermaske,00 00 00 00,
ENG130273-ENG130297,Ausgabe der Abschalt- und Resetdaten 4-Mechatroniktemperatur,215, °C
ENG130273-ENG98689,Ausgabe der Abschalt- und Resetdaten 4-Odometer reading,655350, km
ENG130273-ENG130291,Ausgabe der Abschalt- und Resetdaten 4-Reset Quelle,0,
ENG130273-ENG112343,Ausgabe der Abschalt- und Resetdaten 4-Reset Status,0,
ENG130273-ENG130293,Ausgabe der Abschalt- und Resetdaten 4-Reset Typ,0,
ENG130273-ENG130294,Ausgabe der Abschalt- und Resetdaten 4-Status CHS-Abschaltung,0,
ENG130273-ENG130300,Ausgabe der Abschalt- und Resetdaten 4-Status des Eintrags,FF,
ENG130273-ENG130299,Ausgabe der Abschalt- und Resetdaten 4-Uds-Lesestatus des Eintrages,1,
ENG130273-ENG130298,Ausgabe der Abschalt- und Resetdaten 4-von Dksw uebergebene Fehlerdaten,255,
ENG130274-ENG130289,Ausgabe der Abschalt- und Resetdaten 5-aktiver Fehler,0,
ENG130274-ENG130284,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 0,00 00 00 00,
ENG130274-ENG130285,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 1,00 00 00 00,
ENG130274-ENG130286,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 2,00 00 00 00,
ENG130274-ENG130287,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 3,00 00 00 00,
ENG130274-ENG130290,Ausgabe der Abschalt- und Resetdaten 5-erweiterte Informationen zum aktiven Fehler,0,
ENG130274-ENG130283,Ausgabe der Abschalt- und Resetdaten 5-Gesamt-Software-Version,,
ENG130274-ENG130292,Ausgabe der Abschalt- und Resetdaten 5-gewichteter Resetzähler,0,
ENG130274-ENG130295,Ausgabe der Abschalt- und Resetdaten 5-Klemme 15-Spannung,51.0, V
ENG130274-ENG130296,Ausgabe der Abschalt- und Resetdaten 5-Klemme 30-Spannung,51.0, V
ENG130274-ENG130288,Ausgabe der Abschalt- und Resetdaten 5-kumulierte Fehlermaske,00 00 00 00,
ENG130274-ENG130297,Ausgabe der Abschalt- und Resetdaten 5-Mechatroniktemperatur,215, °C
ENG130274-ENG98689,Ausgabe der Abschalt- und Resetdaten 5-Odometer reading,655350, km
ENG130274-ENG130291,Ausgabe der Abschalt- und Resetdaten 5-Reset Quelle,0,
ENG130274-ENG112343,Ausgabe der Abschalt- und Resetdaten 5-Reset Status,0,
ENG130274-ENG130293,Ausgabe der Abschalt- und Resetdaten 5-Reset Typ,0,
ENG130274-ENG130294,Ausgabe der Abschalt- und Resetdaten 5-Status CHS-Abschaltung,0,
ENG130274-ENG130300,Ausgabe der Abschalt- und Resetdaten 5-Status des Eintrags,FF,
ENG130274-ENG130299,Ausgabe der Abschalt- und Resetdaten 5-Uds-Lesestatus des Eintrages,1,
ENG130274-ENG130298,Ausgabe der Abschalt- und Resetdaten 5-von Dksw uebergebene Fehlerdaten,255,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,8A DB 63 AE,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,CA 94 05 82,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,A2 84 52 43,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,3E 38 87 83,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,6.73, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,12.88, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,30.23, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,40.00, bar
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,6.75, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,13.33, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,33.21, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,40.00, bar
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 F8 00 08,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 F8 00 08,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,1,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,0, km
ENG103186,Clutch center central plate temperature,36, °C
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,0.0, Nm
ENG100625,Coolant temperature,21, °C
ENG26438-ENG36192,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,298.0, mJ
ENG26438-ENG36193,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,258031.8, J
ENG26438-ENG36194,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,298.0, mJ
ENG26438-ENG36195,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,258031.8, J
ENG26438-ENG30210,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG26439-ENG36192,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,363.5, mJ
ENG26439-ENG36193,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,303667.7, J
ENG26439-ENG36194,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,363.5, mJ
ENG26439-ENG36195,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,303667.7, J
ENG26439-ENG30210,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,H15C02,
ENG98602,Driver request torque,-21.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG122353-ENG122493,Einfachsynchronisationszählerstände Klasse 1-1-Gang,0,
ENG122353-ENG122494,Einfachsynchronisationszählerstände Klasse 1-2-Gang,0,
ENG122353-ENG122495,Einfachsynchronisationszählerstände Klasse 1-3-Gang,0,
ENG122353-ENG122496,Einfachsynchronisationszählerstände Klasse 1-4-Gang,0,
ENG122353-ENG122497,Einfachsynchronisationszählerstände Klasse 1-5-Gang,0,
ENG122353-ENG122498,Einfachsynchronisationszählerstände Klasse 1-6-Gang,0,
ENG122353-ENG122499,Einfachsynchronisationszählerstände Klasse 1-7-Gang,0,
ENG122353-ENG108465,Einfachsynchronisationszählerstände Klasse 1-R-Gang,0,
ENG122354-ENG122493,Einfachsynchronisationszählerstände Klasse 2-1-Gang,0,
ENG122354-ENG122494,Einfachsynchronisationszählerstände Klasse 2-2-Gang,0,
ENG122354-ENG122495,Einfachsynchronisationszählerstände Klasse 2-3-Gang,0,
ENG122354-ENG122496,Einfachsynchronisationszählerstände Klasse 2-4-Gang,0,
ENG122354-ENG122497,Einfachsynchronisationszählerstände Klasse 2-5-Gang,0,
ENG122354-ENG122498,Einfachsynchronisationszählerstände Klasse 2-6-Gang,0,
ENG122354-ENG122499,Einfachsynchronisationszählerstände Klasse 2-7-Gang,0,
ENG122354-ENG108465,Einfachsynchronisationszählerstände Klasse 2-R-Gang,0,
ENG122355-ENG122493,Einfachsynchronisationszählerstände Klasse 3-1-Gang,0,
ENG122355-ENG122494,Einfachsynchronisationszählerstände Klasse 3-2-Gang,0,
ENG122355-ENG122495,Einfachsynchronisationszählerstände Klasse 3-3-Gang,0,
ENG122355-ENG122496,Einfachsynchronisationszählerstände Klasse 3-4-Gang,0,
ENG122355-ENG122497,Einfachsynchronisationszählerstände Klasse 3-5-Gang,0,
ENG122355-ENG122498,Einfachsynchronisationszählerstände Klasse 3-6-Gang,0,
ENG122355-ENG122499,Einfachsynchronisationszählerstände Klasse 3-7-Gang,0,
ENG122355-ENG108465,Einfachsynchronisationszählerstände Klasse 3-R-Gang,0,
ENG127824-ENG127910,Electrical_oil_pump_teach_in_parameters-Cosinus Amplitude Korreturwert,548,
ENG127824-ENG127908,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert,2019,
ENG127824-ENG127911,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert 1,0,
ENG127824-ENG127912,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert 2,0,
ENG127824-ENG127909,Electrical_oil_pump_teach_in_parameters-Sinus Amplitude Korrekturwert,552,
ENG127824-ENG127907,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert,2022,
ENG127824-ENG127913,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert 1,0,
ENG127824-ENG127914,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert 2,0,
ENG127824-ENG127905,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude,0.99275,
ENG127824-ENG53351,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude 1,0.00000,
ENG127824-ENG53232,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude 2,0.00000,
ENG127824-ENG127906,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur,11.94250,
ENG127824-ENG53208,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur 1,0.00000,
ENG127824-ENG53345,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur 2,0.00000,
ENG101251,Empty,Empty,
ENG99932,Engine coding info,19,
ENG98756,Engine torque,21.0, Nm
ENG104230,Engine torque loss,21.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,256, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,164, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.3, mm
ENG100089,Gangsteller B Adaption Neutralposition,-0.1, mm
ENG103055,Gangsteller C Adaption Neutralposition,0.1, mm
ENG101354,Gangsteller D Adaption Neutralposition,0.0, mm
ENG110510,Gear actuator adaption engaged position G1,7.7, mm
ENG110511,Gear actuator adaption engaged position G2,-8.4, mm
ENG110512,Gear actuator adaption engaged position G3,-8.3, mm
ENG99484,Gear actuator adaption engaged position G4,8.2, mm
ENG110513,Gear actuator adaption engaged position G5,8.1, mm
ENG110514,Gear actuator adaption engaged position G6,8.2, mm
ENG110516,Gear actuator adaption engaged position GR,-8.5, mm
ENG110517,Gear actuator adaption synchro position G1,2.1, mm
ENG110518,Gear actuator adaption synchro position G2,-2.6, mm
ENG110519,Gear actuator adaption synchro position G3,-2.0, mm
ENG99198,Gear actuator adaption synchro position G4,2.4, mm
ENG110520,Gear actuator adaption synchro position G5,2.2, mm
ENG110521,Gear actuator adaption synchro position G6,2.4, mm
ENG110523,Gear actuator adaption synchro position GR,-2.4, mm
ENG99720,Height info,984, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,21.0, Nm
ENG99582,Intake air temperature,24, °C
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,0,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,0,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,0,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,0,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,0,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,0.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,-1, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.5, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),817.2, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),55.5, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,87, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.3, %
ENG103000,Run time complete system,873.2944, H
ENG102748,Selector lever error flags,00 00,
ENG101057,Specified idle speed,0, /min
ENG100803,Speed: output,0, /min
ENG100141,Transmission coding info,23,
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG101346,Version info driving strategy,FEJRMRBEB.039,
ENG109005,Voltage Common Highside 1,13.1, V
ENG99955,Voltage Common Highside 2,13.1, V
Elapsed Time: 00:35
ADP (No login)
;Thursday,02,August,2018,08:02:58:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
IDE00001-Production mode,not activated ,3
Elapsed Time: 00:01
henbo
C?ID=318655
03 ABS Brakes
Block
;SW:5Q0-614-517-BL   HW:5Q0-614-517-AH ---  ABS Brakes
;Component:ESC           H62 0855, Coding:12F140A23829227189800E0941C52948021C44917082947218B15074822802
;EV_Brake1UDSContiMK100OMG,003019,EV_Brake1UDSContiMK100OMG_003_AU37.rod
;Thursday,02,August,2018,08:03:12:50490
;VCID: 7CB42BA0F72E5DA47B-8028
Group,Description,Actual
IDE00019,Voltage terminal 30,13.081, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,26, °C
IDE00075,Vehicle speed,0, km/h
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,14.9, %
IDE00097-ENG101171,OBD - requirements for which this vehicle is designed-OBD requirements to which vehicle or engine is certified,EOBD,
IDE00323,Security Access: Number of invalid keys,0,
IDE00601,Monitoring status since erasing DTC memory,00 04 00 00,
IDE00602,Monitoring status in current driving cycle,00 04 00 00,
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,ERROR,
IDE02270-IDE02713,CAN input signal(s) status-Brake Light Switch,not activated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,8V95992,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency brake display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.00000, m/s²
IDE02486,Data logger triggering,not active,
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,indicator lights-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,indicator lights-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,indicator lights--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,indicator lights-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,indicator lights-ABS indicator lamp,OFF,
IDE02986-MAS00556,indicator lights-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,indicator lights-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,indicator lights-Brake system indicator lamp,OFF,
IDE02986-MAS03234,indicator lights-ESP_off indicator lamp,OFF,
IDE03008-IDE04446,Stop process prevented-Hill descent control,not active,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-IDE06139,Stop process prevented-AUTO HOLD slippage recognition,not active,
IDE03008-MAS04485,Stop process prevented-ESP function deactivation,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-MAS07931,Stop process prevented-Retaining function unavailable,not active,
IDE03008-MAS07932,Stop process prevented-Inclination limit,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,20,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,3341,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,248,
IDE03011-IDE04446,Number of requested start processes-Hill descent control,0,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04485,Number of requested start processes-ESP function deactivation,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,8,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,3,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,62,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,3,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,8,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,3,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,23,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.000, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.103, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-1, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.10, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake Light Switch,not activated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,ERROR,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,ERROR,
IDE04425-IDE04436,Left front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04425-IDE04437,Left front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04425-IDE04438,Left front ABS wheel speed sensor-Average division value,Condition not met,
IDE04425-IDE04440,Left front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04425-IDE04441,Left front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Front right wheel speed,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,ERROR,
IDE04426-IDE04436,Right front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04426-IDE04437,Right front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04426-IDE04438,Right front ABS wheel speed sensor-Average division value,Condition not met,
IDE04426-IDE04440,Right front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04426-IDE04441,Right front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,ERROR,
IDE04427-IDE04436,Left rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04427-IDE04437,Left rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04427-IDE04438,Left rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04427-IDE04440,Left rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04427-IDE04441,Left rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,ERROR,
IDE04428-IDE04436,Right rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04428-IDE04437,Right rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04428-IDE04438,Right rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04428-IDE04440,Right rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04428-IDE04441,Right rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,ÿÿÿÿÿÿ,
IDE04442-IDE00010,Vacuum sensor-Serial number,FF FF FF FF FF,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Available,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-1, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,0,
IDE04443-IDE02241,Traction control system sensor-Lateral acceleration sensor 1,0.13734, m/s²
IDE04443-IDE02538,Traction control system sensor-Longitudinal acceleration sensor,-0.05886, m/s²
IDE04443-IDE04429,Traction control system sensor-Lateral acceleration sensor 1: offset,-0.09810, m/s²
IDE04443-IDE04430,Traction control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Traction control system sensor-Rotation rate sensor 1: Z-axis,-0.046, °/s
IDE04443-IDE04460,Traction control system sensor-Steering angle sensor: offset straight line running,44.28, °
IDE04443-MAS00815,Traction control system sensor-Steering angle sensor,-14.875, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE02955,Hill descent control-System status,Not available due to specific system,
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,not activated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,not activated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,not activated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,not activated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,29229, km
IDE04456-MAS01282,Brake disk drying-Wiper,not active,
IDE04456-MAS03095,Brake disk drying-Function status,not active,
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MY3RAH00024,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,completed successfully,
IDE04461-IDE03659,Internal measured values-Roller test bench mode,not active,
IDE04461-MAS01481,Internal measured values-Temperature in control module,29, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognized,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,ERROR,
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.10, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,0, mbar
IDE04508-MAS11246,Hydraulic brake booster-Duration of active control,0,
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04644-MAS03095,Roll-over protection-Function status,not active,
IDE04645-IDE00003,Electromechanical parking brake-Coding,performed,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,Enabled,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,Enabled,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE03493,Electromechanical parking brake-Driver door status,Enabled,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,Enabled,
IDE04645-IDE04941,Electromechanical parking brake-Clearance calibration,calibrated,
IDE04645-IDE04942,Electromechanical parking brake-Main examination mode,not active,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,Enabled,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,Enabled,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,Enabled,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,closed,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,closed,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,22.0, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,22.0, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,4385,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,4385,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE03735,Counter steer support-Steering torque,0, Nm
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,30896, km
IDE04765-MAS03095,Counter steer support-Function status,not active,
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Available,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04774-MAS03095,Vehicle and trailer stabilization-Function status,not active,
IDE04871-IDE01599,Dynamic starting assist-Slope,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire pressure monitoring display-System status,Available,
IDE04939-IDE04248,Tire pressure monitoring display-Left front tire pressure diffusion indicator,251,
IDE04939-IDE04249,Tire pressure monitoring display-Right front tire pressure diffusion indicator,251,
IDE04939-IDE04250,Tire pressure monitoring display-Left rear tire pressure diffusion indicator,251,
IDE04939-IDE04251,Tire pressure monitoring display-Right rear tire pressure diffusion indicator,251,
IDE04939-IDE04432,Tire pressure monitoring display-Tire Pressure Monitoring Display Button,not activated,
IDE04939-IDE04946,Tire pressure monitoring display-Odometer reading at last adaptation,28984, km
IDE04939-IDE04947,Tire pressure monitoring display-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire pressure monitoring display-Odometer reading two adaptations ago,24548, km
IDE04939-MAS04539,Tire pressure monitoring display-Odometer reading three adaptations ago,15974, km
IDE04939-MAS04540,Tire pressure monitoring display-Odometer reading four adaptations ago,15088, km
IDE04939-MAS04541,Tire pressure monitoring display-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire pressure monitoring display-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire pressure monitoring display-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire pressure monitoring display-Left front flat tire indicator,254,
IDE04939-MAS04545,Tire pressure monitoring display-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire pressure monitoring display-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire pressure monitoring display-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,196087,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,835605,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,2370,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,19151,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,3,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,12,
IDE07280-MAS00110,Multiple collision brake-Minutes,3,
IDE07280-MAS00111,Multiple collision brake-Seconds,63,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE09588-ENG103176,In use monitor performance ratio 1-General Denominator,579,
IDE09588-ENG102823,In use monitor performance ratio 1-Ignition Cycle Counter,2690,
IDE09588-ENG100120,In use monitor performance ratio 1-Milage,29630,
IDE09588-ENG102846,In use monitor performance ratio 1-Number of IUMPR Records,1,
IDE09589-ENG101817,In use monitor performance ratio 2-Denominator,277,
IDE09589-ENG103772,In use monitor performance ratio 2-DFCC Value,01 06,
IDE09589-ENG99150,In use monitor performance ratio 2-Numerator,522,
IDE09589-ENG101622,In use monitor performance ratio 2-Record Number,1,
IDE11490-MAS12826,Emergency brake request-current spec. press.,0,
IDE11490-MAS12827,Emergency brake request-Validity of emerg. brake request,invalid,
IDE11490-MAS12828,Emergency brake request-max. spec. pressure eBKV,0,
IDE80101,Analysis 101,A3 32 38 35 31 35 38 37 36 32 32 33 30 30 30 30 36 31 36 43 31 39 30 30 30 31 33 2F 02 15 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,87.4944, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,93.3534, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,90.2286, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,3690,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,88.2756, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,4814,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,96.0876, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,2008,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,95.3064, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,3805,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,22.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,22.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,22.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,22.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake Light Switch,not activated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00121-MAS03095,Electronic Differential Lock-Function status,not active,
MAS00210-IDE80007,Parking Brake-Analysis 7,7928, km
MAS00210-IDE80008,Parking Brake-Analysis 8,30904, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,29640, km
MAS00210-IDE80011,Parking Brake-Analysis 11,30904, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS01464,All Wheel Drive (AWD)-Emergency running mode,not active,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS00988,Hill-start assistant-Reverse gear,not selected,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument panel insert-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument panel insert-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG101413-ENG99697,Calibration Identification-Calibration Verification Number,5Q0517AH085514C,
ENG99697,Calibration Verification Number,01 A3 62 25 58,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG109170,Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,98 18 00 01,
ENG103342-ENG109170,Sup PIDs ($21  - $40 )No. drv cyc since eras DTC mem-Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,00 00 00 01,
ENG100937-ENG109170,Sup PIDs ($41  - $60 ) time since eras DTC mem-Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,C0 80 00 00,
ENG109169-ENG109170,Supported INFOTYPEs ($01 - $20)-Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,14 40 00 00,
Elapsed Time: 00:17
ADP
;Thursday,02,August,2018,08:03:29:50490
IDE00001-Production mode,not active ,3
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,not activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire pressure monitoring display,2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction-,normal ,1
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,1 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,0 ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:13
henbo
C?ID=318655
05 Acc/Start Auth.
Block
;SW:5Q0-959-435-B   HW:5Q0-959-435 ---  Acc/Start Auth.
;Component:VWKESSYMQB    021 0710, Coding:030C0C
;EV_KessyHellaMQBAB,002019,EV_KessyHellaMQBAB_002.rod
;Thursday,02,August,2018,08:03:55:50490
;VCID: 3B36E8BCB2A09A9C32-806E
IDE00019,Voltage terminal 30,13.158, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE01715,Status terminal S,On,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver door,Open,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID sensor 1 authentication: status,No response,
IDE02410,ID sensor 2 authentication: status,No response,
IDE02411,ID sensor 3 authentication: status,No response,
IDE02412,ID sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear exterior door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear exterior door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,33,
IDE02419,Proximity sensor frt.pass. door: number of triggers,201,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardwareversion,FF,
IDE02422-MAS01483,Driver door handle: version information-Softwareversion,FF,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,FF,
IDE02423-MAS01482,ass. door handle: version information-Hardwareversion,FF,
IDE02423-MAS01483,ass. door handle: version information-Softwareversion,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardwareversion,FF,
IDE02424-MAS01483,Left rear door handle: version information-Softwareversion,FF,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,FF,
IDE02425-MAS01482,Right rear door handle: version information-Hardwareversion,FF,
IDE02425-MAS01483,Right rear door handle: version information-Softwareversion,FF,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,FF,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,Yes,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72-hour signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72-hr signaling counter left rear door,0,
IDE02485,72-hr signaling counter right rear door,0,
IDE02486,Data logger triggering,not activated,
IDE02495-MAS00976,Service key: number of activations-Counter,2563,
IDE02496-MAS00976,Service key: number of timeouts-Counter,12,
IDE02497-MAS00976,Service key: number of incomplete messages-Counter,4,
IDE03008-MAS05971,Stop process prevented-Missing message from Engine Control Module,0,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,0,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,0,
IDE03008-MAS06119,Stop process prevented-CAN signal: operation reader coil is set,0,
IDE03010-MAS05971,Number of prevented stop processes-Missing message from Engine Control Module,0,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,3,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,29,
IDE03010-MAS06119,Number of prevented stop processes-CAN signal: operation reader coil is set,3,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,26,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,25,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,30,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,2,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,5,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,58,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,40,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,31,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,39,
IDE03127,Prevented stop processes (ring memory),2,
IDE03213,Start-stop enabling,All releases are present,
IDE04042-ENG20505,ID sensor history data-Scan 1 Origin,Passive Go,
IDE04042-ENG104152,ID sensor history data-Scan 1 Single Scan,Interior with trunk,
IDE04042-ENG20412,ID sensor history data-Scan 1 Trigger,Go authentication request,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG20435,ID sensor history data-Scan 2 Origin,Passive Go,
IDE04042-ENG99359,ID sensor history data-Scan 2 Single Scan,Interior with trunk,
IDE04042-ENG20402,ID sensor history data-Scan 2 Trigger,Go ID request,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG20483,ID sensor history data-Scan 3 Origin,Key Minder,
IDE04042-ENG102354,ID sensor history data-Scan 3 Single Scan,Driver front,
IDE04042-ENG20414,ID sensor history data-Scan 3 Trigger,Entry without proximity,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,A4,
IDE05204,Manufacturing dates for driver door handle,FF FF FF FF FF,
IDE05205,Manufacturing dates for frt.pass. door handle,FF FF FF FF FF,
IDE05206,Manufacturing dates for left rear door handle,00 00 00 00 00,
IDE05207,Manufacturing dates for right rear door handle,00 00 00 00 00,
IDE07359,Dimming of starter button lighting,63 02,
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,00000000 ,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,00000000 ,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,00000001 ,
ENG26348-ENG129142,Scan_cycle_data-Car_key_3,00000000 ,
ENG26348-ENG129143,Scan_cycle_data-Car_key_4,00000000 ,
ENG26348-ENG30036,Scan_cycle_data-Mileage_n,30859, km
ENG26348-ENG30037,Scan_cycle_data-Mileage_n-1,30859, km
ENG26348-ENG30038,Scan_cycle_data-Mileage_n-10,28440, km
ENG26348-ENG30039,Scan_cycle_data-Mileage_n-11,28440, km
ENG26348-ENG30040,Scan_cycle_data-Mileage_n-12,27996, km
ENG26348-ENG30041,Scan_cycle_data-Mileage_n-13,27996, km
ENG26348-ENG30042,Scan_cycle_data-Mileage_n-14,27829, km
ENG26348-ENG30043,Scan_cycle_data-Mileage_n-15,27829, km
ENG26348-ENG30044,Scan_cycle_data-Mileage_n-16,24877, km
ENG26348-ENG30045,Scan_cycle_data-Mileage_n-17,24877, km
ENG26348-ENG30046,Scan_cycle_data-Mileage_n-18,24615, km
ENG26348-ENG30047,Scan_cycle_data-Mileage_n-19,24615, km
ENG26348-ENG30048,Scan_cycle_data-Mileage_n-2,30859, km
ENG26348-ENG30049,Scan_cycle_data-Mileage_n-3,30542, km
ENG26348-ENG30050,Scan_cycle_data-Mileage_n-4,30542, km
ENG26348-ENG30051,Scan_cycle_data-Mileage_n-5,30180, km
ENG26348-ENG30052,Scan_cycle_data-Mileage_n-6,30155, km
ENG26348-ENG30053,Scan_cycle_data-Mileage_n-7,30155, km
ENG26348-ENG30054,Scan_cycle_data-Mileage_n-8,29983, km
ENG26348-ENG30055,Scan_cycle_data-Mileage_n-9,29983, km
ENG26348-ENG30076,Scan_cycle_data-Retry_count_n,6,
ENG26348-ENG30078,Scan_cycle_data-Retry_count_n-1,14,
ENG26348-ENG30079,Scan_cycle_data-Retry_count_n-10,14,
ENG26348-ENG30080,Scan_cycle_data-Retry_count_n-11,6,
ENG26348-ENG30081,Scan_cycle_data-Retry_count_n-12,8,
ENG26348-ENG30082,Scan_cycle_data-Retry_count_n-13,6,
ENG26348-ENG30083,Scan_cycle_data-Retry_count_n-14,8,
ENG26348-ENG30084,Scan_cycle_data-Retry_count_n-15,6,
ENG26348-ENG30085,Scan_cycle_data-Retry_count_n-16,8,
ENG26348-ENG30086,Scan_cycle_data-Retry_count_n-17,6,
ENG26348-ENG30087,Scan_cycle_data-Retry_count_n-18,8,
ENG26348-ENG30088,Scan_cycle_data-Retry_count_n-19,6,
ENG26348-ENG30089,Scan_cycle_data-Retry_count_n-2,6,
ENG26348-ENG30090,Scan_cycle_data-Retry_count_n-3,20,
ENG26348-ENG30091,Scan_cycle_data-Retry_count_n-4,6,
ENG26348-ENG30092,Scan_cycle_data-Retry_count_n-5,6,
ENG26348-ENG32465,Scan_cycle_data-Retry_count_n-6,8,
ENG26348-ENG30093,Scan_cycle_data-Retry_count_n-7,6,
ENG26348-ENG30094,Scan_cycle_data-Retry_count_n-8,8,
ENG26348-ENG30095,Scan_cycle_data-Retry_count_n-9,6,
ENG26348-ENG30114,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG26348-ENG30115,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG26348-ENG30116,Scan_cycle_data-Scan_reason_n-10,Driver_door,
ENG26348-ENG30117,Scan_cycle_data-Scan_reason_n-11,Driver_door,
ENG26348-ENG30118,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG26348-ENG30119,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG26348-ENG30120,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG26348-ENG30121,Scan_cycle_data-Scan_reason_n-15,Driver_door,
ENG26348-ENG30122,Scan_cycle_data-Scan_reason_n-16,Driver_door,
ENG26348-ENG30123,Scan_cycle_data-Scan_reason_n-17,Driver_door,
ENG26348-ENG30124,Scan_cycle_data-Scan_reason_n-18,Driver_door,
ENG26348-ENG30125,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG26348-ENG30126,Scan_cycle_data-Scan_reason_n-2,Driver_door,
ENG26348-ENG30127,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG26348-ENG30128,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG26348-ENG30129,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG26348-ENG30130,Scan_cycle_data-Scan_reason_n-6,Driver_door,
ENG26348-ENG30131,Scan_cycle_data-Scan_reason_n-7,Driver_door,
ENG26348-ENG30132,Scan_cycle_data-Scan_reason_n-8,Driver_door,
ENG26348-ENG30133,Scan_cycle_data-Scan_reason_n-9,Driver_door,
ENG26348-ENG30134,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG26348-ENG30135,Scan_cycle_data-Scan_trigger_n-1,Reset_stop_car,
ENG26348-ENG30136,Scan_cycle_data-Scan_trigger_n-10,Reset_stop_car,
ENG26348-ENG30137,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG26348-ENG30138,Scan_cycle_data-Scan_trigger_n-12,Reset_stop_car,
ENG26348-ENG30139,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG26348-ENG30140,Scan_cycle_data-Scan_trigger_n-14,Reset_stop_car,
ENG26348-ENG30141,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG26348-ENG30142,Scan_cycle_data-Scan_trigger_n-16,Reset_stop_car,
ENG26348-ENG30143,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG26348-ENG30144,Scan_cycle_data-Scan_trigger_n-18,Reset_stop_car,
ENG26348-ENG30145,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG26348-ENG30146,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG26348-ENG30147,Scan_cycle_data-Scan_trigger_n-3,Reset_stop_car,
ENG26348-ENG30148,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG26348-ENG30149,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG26348-ENG30150,Scan_cycle_data-Scan_trigger_n-6,Reset_stop_car,
ENG26348-ENG30151,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG26348-ENG30152,Scan_cycle_data-Scan_trigger_n-8,Reset_stop_car,
ENG26348-ENG30153,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
Elapsed Time: 00:12
ADP
;Thursday,02,August,2018,08:04:08:50490
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105803-ENG120037-DeveloperCoding: Key Minder (Byte 1)-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG105803-ENG101923-DeveloperCoding: Key Minder (Byte 1)-Retry handling big car / expanded search,activated ,1
ENG105803-ENG100928-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening,not activated ,1
ENG105803-ENG99649-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG105803-ENG99417-DeveloperCoding: Key Minder (Byte 1)-Softtouch mounted,installed ,1
ENG105804-ENG99123-DeveloperCoding: Key Minder (Byte 2)-Inhibit ID-transmitter for passive go,activated ,1
ENG105804-ENG102581-DeveloperCoding: Key Minder (Byte 2)-Lock prevention tailgate,not activated ,1
ENG105804-ENG101018-DeveloperCoding: Key Minder (Byte 2)-No locking with ID-transmitter last used interior,activated ,1
ENG105804-ENG103451-DeveloperCoding: Key Minder (Byte 2)-Re-open after passive comfort closing,activated ,1
ENG105804-ENG99711-DeveloperCoding: Key Minder (Byte 2)-Re-open last handling,ZV entriegeln ,1
ENG105804-ENG103237-DeveloperCoding: Key Minder (Byte 2)-Re-open tailgate,activated ,1
ENG105804-ENG104103-DeveloperCoding: Key Minder (Byte 2)-Send numbers of ID-transmitters interior (ELV-Scan),not activated ,1
ENG153804-ENG154598-DeveloperCoding: Miscellaneous 2-exeption_drivers_doors_interior_scan,activated ,1
ENG153804-ENG154691-DeveloperCoding: Miscellaneous 2-interior_scan_clamp_15_new_concept,activated ,1
ENG153804-ENG154710-DeveloperCoding: Miscellaneous 2-open_cabrio_canopy_interior_scan,not activated ,1
ENG105807-ENG121989-DeveloperCoding: Passiv Entry Exit (Byte 1)-Impairment Entry / Exit key on low battery,not activated ,1
ENG105807-ENG125240-DeveloperCoding: Passiv Entry Exit (Byte 1)-lf_crc,not activated ,1
ENG105807-ENG99763-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: access door not open,activated ,1
ENG105807-ENG103722-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: all doors not open,not activated ,1
ENG105808-ENG155267-DeveloperCoding: Passiv Entry Exit (Byte 2)-lf_shutdown,not activated ,1
ENG105808-ENG155268-DeveloperCoding: Passiv Entry Exit (Byte 2)-lf_shutdown_gotrigger,not activated ,1
ENG105808-ENG148905-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry at door locked/safed OR ZV safed,activated ,1
ENG105808-ENG123039-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit,activated ,1
ENG105808-ENG103289-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG105808-ENG103620-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG105808-ENG103529-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry: second control concept,not activated ,1
ENG105809-ENG114300-DeveloperCoding: Passiv Go-Change Go antenna at every request,not activated ,1
ENG105809-ENG114299-DeveloperCoding: Passiv Go-Change Go antenna during retry challenge,activated ,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG148896-DeveloperCoding: Proximity Sensor-Easy Trunk,not activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,Fahrertürgriff wird nicht abgeschaltet ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",Fehlerspeichereintrag wird nicht unterdrueckt ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG148895-DeveloperCoding: Search lights-ZAT active during clamp 58xt on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG105810-ENG120039-DeveloperCoding: Sonstiges-Backdoor TSG,not installed ,1
ENG105810-ENG103075-DeveloperCoding: Sonstiges-Battery manager mounted,activated ,1
ENG105810-ENG102728-DeveloperCoding: Sonstiges-Diagnostic: service 86 - response on event,not activated ,1
ENG105810-ENG98656-DeveloperCoding: Sonstiges-internal,not activated ,1
ENG105810-ENG102591-DeveloperCoding: Sonstiges-Response extension for scan procedure,not activated ,1
ENG105810-ENG99430-DeveloperCoding: Sonstiges-Scan Procedure: Timeoutcontrol active,activated ,1
ENG105810-ENG104010-DeveloperCoding: Sonstiges-Use default antenna data,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,installed ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,3000 ms,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG108165-Passive Entry Exit: control by pulling the door handle during active DSL (timeout),2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG108580-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Go),190 ms,1
ENG108581-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Kombi),700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:24
henbo
C?ID=318655
08 Auto HVAC
missed that one, I wish there was an AutoMap, or did I miss that, too?
henbo
C?ID=318655
09 Cent. Elect.
Block
;SW:5Q0-937-084-CF   HW:5Q0-937-084-CF ---  Cent. Elect.
;Component:BCM MQBAB M+  H34 0236, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,017001,EV_BCMBOSCH_017.rod
;Thursday,02,August,2018,08:07:29:50490
;VCID: 7EB021A8E1324FB455-802A
IDE00322,Status of basic setting,was not yet started,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measured value not available,
IDE00973,Outside air temperature,22.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01285,Counter of component protection malfunctions,0,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,not active,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.00, %
IDE01943-MAS04351,Turn signal-Connector terminal number,60,
IDE01943-MAS04352,Turn signal-Connector number,Plug A,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02486,Data logger triggering,not_defined,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,active,
IDE02515-MAS03873,Low beam-Duty cycle,100.00, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,not coded/not installed,
IDE02743-MAS02248,High Beam-Signal state,not active,
IDE02743-MAS03873,High Beam-Duty cycle,0.00, %
IDE02743-MAS04351,High Beam-Connector terminal number,0,
IDE02743-MAS04352,High Beam-Connector number,Plug A,
IDE02857-IDE03111,Activation current-Interior light,992, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,0, mA
IDE02857-IDE06012,Activation current-Search lights,102, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,16368, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,no error,
IDE02857-ENG128455,Activation current-Cockpittaster_2,no error,
IDE02857-ENG128456,Activation current-Cockpittaster_3,no error,
IDE02857-ENG128457,Activation current-Cockpittaster_4,no error,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,192, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,normal,
IDE02957-MAS02248,Ambient lighting-Signal state,not active,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,61,
IDE02957-MAS04352,Ambient lighting-Connector number,Plug C,
IDE02957-MAS06670,Ambient lighting-Channel,Chan. A,
IDE03111-MAS01737,Interior light-Diagnosis,not coded/not installed,
IDE03111-MAS02248,Interior light-Signal state,not active,
IDE03111-MAS03873,Interior light-Duty cycle,0.00, %
IDE03111-MAS04351,Interior light-Connector terminal number,0,
IDE03111-MAS04352,Interior light-Connector number,Plug A,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,21.7, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,18.1, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,not active,
IDE03310-MAS03873,Brake light-Duty cycle,0.00, %
IDE03310-MAS04351,Brake light-Connector terminal number,71,
IDE03310-MAS04352,Brake light-Connector number,Plug A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,25.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,22.50, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,not_defined,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,not active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,not active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,all,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,not active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,20, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,60, s
IDE03504-MAS07987,Personalized settings-Light intensity,sensitive,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,normal,
IDE03638-MAS02248,static AFS light-Signal state,not active,
IDE03638-MAS03873,static AFS light-Duty cycle,0.00, %
IDE03638-MAS04351,static AFS light-Connector terminal number,6,
IDE03638-MAS04352,static AFS light-Connector number,Plug B,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,not active,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.00, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,Plug A,
IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,On,
IDE05042-MAS02158,Emergency flasher button-Actuation condition,Not operated,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,34.50, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,park position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,73900,
IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
IDE05323-MAS01737,Fog light-Diagnosis,not coded/not installed,
IDE05323-MAS02248,Fog light-Signal state,not active,
IDE05323-MAS03873,Fog light-Duty cycle,0.00, %
IDE05323-MAS04351,Fog light-Connector terminal number,0,
IDE05323-MAS04352,Fog light-Connector number,Plug A,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,not active,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,not_defined,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,Plug A,
IDE05533,Spray nozzle heater,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02339,Window washer system-Windshield washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,Not operated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,not active,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,Plug A,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,active,
IDE05739-MAS03873,Footwell light-Duty cycle,51.00, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,Parking light,
IDE05742-MAS00063,Light switch position-OFF,not activated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not activated,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,335544320,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00211,Driver info-Insufficient brake fluid,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00213,Driver info-Insufficient coolant,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,0,
IDE05836-MAS04806,Rain recognition sensor-Splash,not active,
IDE05836-MAS04807,Rain recognition sensor-park position,active,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS01794,Light recognition sensor-Freeway,OFF,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,36, lx
IDE05838-MAS04808,Light recognition sensor-Rain,OFF,
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,active,
IDE05839-MAS03873,Parking light-Duty cycle,100.00, %
IDE05839-MAS04351,Parking light-Connector terminal number,2,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-IDE08748,Central locking history data-Operating dir.,Door unlock,
IDE05841-MAS06441,Central locking history data-Control-section / cause,autounlock,
IDE05841-MAS07519,Central locking history data-Command,complete unlock,
IDE05841-MAS07942,Central locking history data-Additional information,Measured value not available,
IDE05842-MAS00218,Comfort function history data-Driver door,active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,active,
IDE05842-MAS00220,Comfort function history data-Left rear door,active,
IDE05842-MAS00221,Comfort function history data-Right rear door,active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,radio remote control number_2,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
IDE05842-MAS07941,Comfort function history data-Operating command,Open,
IDE06012-MAS01737,Search lights-Diagnosis,not coded/not installed,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.00, %
IDE06012-MAS04351,Search lights-Connector terminal number,0,
IDE06012-MAS04352,Search lights-Connector number,Plug A,
IDE06012-ENG28566,Search lights-clamp,Unknown,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-27.6, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,24.0, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,57.5, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-36.4, °C
IDE06096-IDE03111,Interior lighting-Interior light,100, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,100.00, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,100.00, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,23.00, %
IDE06096-MAS01634,Interior lighting-Supply voltage,100.00, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,0, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not activated,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,Open,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,not active,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.00, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,Plug A,
IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,On,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not activated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not active,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,4,
IDE06695-MAS00107,Energy management: last critical state-Month,11,
IDE06695-MAS00108,Energy management: last critical state-Day,29,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,10,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,1,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2017,
IDE06864-MAS01737,Daytime running lights-Diagnosis,normal,
IDE06864-MAS02248,Daytime running lights-Signal state,active,
IDE06864-MAS03873,Daytime running lights-Duty cycle,50.00, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,10,
IDE06864-MAS04352,Daytime running lights-Connector number,Plug C,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.34, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.34, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,not activated,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG09185,Central locking-Load_compartment_closing,not coded/not installed,
IDE08343,Immobilizer Challenge,FA 8A 19 0C,
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,0, mA
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,0, mA
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,2088, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,1944, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,112, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,176, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,76, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,16, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,16, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,210, mA
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,222, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,0, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,0, mA
IDE08949-MAS07885,Operating current: light driver-Conn. pin 18,0, mA
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,0, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,0, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,354, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,384, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,90, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,0, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,0, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,23, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,16, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,23, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,16, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,0, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,not_installed_not_active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,not_installed_not_active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not_installed_not_active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,not_installed_not_active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,not_installed_not_active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,not_installed_not_active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,not_installed_not_active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not_installed_not_active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not_installed_not_active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,not_installed_not_active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not_installed_not_active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,not_installed_not_active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not_installed_not_active,
IDE11134-MAS11025,Light sequence HU test result-Status,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,Not available,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,not active,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,Plug A,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,13.10, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,13.10, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,13.10, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,13.10, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,13.10, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.00, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,13.15, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.20, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,2,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,30904, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,operated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-49,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,4, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.00, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,2,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Windshield defogger,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,146,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,1,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,10,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance drive,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,active,
MAS03835-MAS03873,Parking light-Duty cycle,100.00, %
MAS03835-MAS04351,Parking light-Connector terminal number,39,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,normal,
MAS03836-MAS02248,Rear fog light-Signal state,not active,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.00, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,72,
MAS03836-MAS04352,Rear fog light-Connector number,Plug A,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,Vehicle movement recognized,
MAS07959-MAS00107,Remote start history data-Month,0,
MAS07959-MAS00108,Remote start history data-Day,0,
MAS07959-MAS00109,Remote start history data-Hours,0,
MAS07959-MAS00110,Remote start history data-Minutes,0,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,Remote start function active,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,not coded/not installed,
MAS08228-MAS04121,Light sensor-Voltage,not coded/not installed,
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),00 00 00 01 00 1A 00 1A 64 00 00 36 51 00 00 00 00 00 00 00 00 00 00 00 00 02 00 04 00 08 FC BC 00 FE 2A 03 00 00 03 14 00 00 07 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 06 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 05 00 01 00 00 00 00 4E 64 07 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 14 43 00 00 10 00 04 40 21 84 00 20 00 00 00 00 00 00 00 00 00 00 02 D5 D1 BF 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 09 01 00 00 00 00 00 00 00 00 E3 02 00 00 00 8F 0A 00 00 00 00 00,
ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,0,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,0,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,keine Stoerschutzursache,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,405,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,739,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813-ENG28575,Entwicklermesswerte_CONTI-KurzSchlussZaehler,0,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,not coded/not installed,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,not coded/not installed,
ENG116793,Monitor 1,00 00 00 00 00 00 00 00,
ENG116802,Monitor 10,00 00 00 00 00 00 00 00,
ENG116794,Monitor 2,00 00 00 00 00 00 00 00,
ENG116795,Monitor 3,00 00 00 00 00 00 00 00,
ENG116796,Monitor 4,00 00 00 00 00 00 00 00,
ENG116797,Monitor 5,00 00 00 00 00 00 00 00,
ENG116798,Monitor 6,00 00 00 00 00 00 00 00,
ENG116799,Monitor 7,00 00 00 00 00 00 00 00,
ENG116800,Monitor 8,00 00 00 00 00 00 00 00,
ENG116801,Monitor 9,00 00 00 00 00 00 00 00,
ENG128380,Parametermonitor_0,84 14 64 64 AA 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 00 00 00 00 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 FA 64 05 C8 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 3C 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 02 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 05 00 14 32 5A 32 0A 1E 12 03 4B 0A 01 1E 5A 0F 3C 3C 05 0A 00 0A 78 00 FA 01 1C 14 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 46 00 00 1E 28 64 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,C8 02 32 00 5A FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 5A 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 0B 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 19 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 04 03 B4 00 0A 05 05 0A 4B 4B 32 07 00 00 1E 00 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0F 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 55 00 03 09 01 0F 00 00 00 00 00 00 05 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 4F 32 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A A7 9A 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,0,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,0,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,0,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,0,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,1,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,0,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,0,
ENG126654-MAS00108,Personalized_Signals-Day,0,
ENG126654-MAS00109,Personalized_Signals-Hours,0,
ENG126654-MAS00110,Personalized_Signals-Minutes,0,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,1,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,1,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,1,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,1,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,1,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,1,
ENG116792-ENG115817,Power up history-Funktionsanforderung,0,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG124897-ENG124955,Resetcounter_EMW-3.letzte Resetursache,0,
ENG124897-ENG124956,Resetcounter_EMW-4.letzte Resetursach,0,
ENG124897-ENG114872,Resetcounter_EMW-last cause of reset,0,
ENG124897-ENG115805,Resetcounter_EMW-Number of resets,1,
ENG124897-ENG124954,Resetcounter_EMW-vorletzte Resetursache,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,54, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,13.1, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.1, V
ENG116791,Temperatures,22.00, °C
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,680_Ohm,
ENG116907-MAS00063,Zusaetzliche Umgebungsdaten-OFF,not activated,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,22.00, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,13.10, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
ENG116907-ENG124952,Zusaetzliche Umgebungsdaten-last_wakeup,keine Stoerschutzursache,
ENG116907-ENG115838,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN),OFF,
ENG116907-ENG115837,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW),OFF,
Elapsed Time: 00:38
ADP
;Thursday,02,August,2018,08:08:08:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
IDE01550-Service position,133.197670 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,1000 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,32.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05144-Read parameter address,00 00 00 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 04 45 00 1E 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,62.50 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED not installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,21.197781 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.00 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,0 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,0 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,not installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,18.197784 °,2
IDE10299-Alternating park position 2,21.197781 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,1.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,225 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,225 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,225 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,225 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,225 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,225 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,225 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,225 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,225 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,225 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,225 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,225 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,225 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,225 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,225 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,225 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,225 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,225 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,225 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,225 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,225 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,225 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,225 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,225 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,225 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,225 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,225 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,225 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,225 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,225 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS05055-lower turn position,26.197776 °,2
MAS05056-upper turn position,166.197637 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,0.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,0.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,0.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,0.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,0.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,0.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,0.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,0.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,0.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,0.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,0.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,0.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,0.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,0.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,0.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,NOT-DEFINED ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,NOT-DEFINED ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,NOT-DEFINED ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,NOT-DEFINED ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,NOT-DEFINED ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,NOT-DEFINED ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,NOT-DEFINED ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,NOT-DEFINED ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,NOT-DEFINED ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,NOT-DEFINED ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,NOT-DEFINED ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,NOT-DEFINED ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,NOT-DEFINED ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,NOT-DEFINED ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,NOT-DEFINED ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,6400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,separate ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,8 s,18
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141685-Front_wash_function,10 ,2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,500 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,2000 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG117394-Head area heater-blower_speed,0 ,2
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,not active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.10 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-0.60 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.10 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-1.60 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.10 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-2.60 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.10 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-3.60 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.10 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,89.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,83.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,75.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,68.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,61.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,56.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,47.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,40.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,33.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,45 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,4 - LED Tagfahrlichtmodul Signal ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Versorgungsbedarf der LCM Module ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,5D ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,36 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Coming Home oder Leaving Home aktiv ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,5E ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,40 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Coming Home oder Leaving Home aktiv ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,70 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,35 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,0A ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Coming Home oder Leaving Home aktiv ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,70 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,36 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,1A ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Coming Home oder Leaving Home aktiv ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,04 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,46 - LED Kleinleistung ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Ambientelicht 2 ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,0 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,127 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,0 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,127 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,not active ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Brake light ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,95 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,50 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,50 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lights ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,Heckdeckel geschlossen ,16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,95 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,50 ,16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,50 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lights ,16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,Heckdeckel geschlossen ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,37 - allgemeine LED bis 12W ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,37 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,61 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,36 - LED Kleinleistung ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,62 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,36 - LED Kleinleistung ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 03 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 05 00 00 00 00 00 00 00 00 27 09 00 2B 00 00 00 00 00 00 18 00 7F 00 00 00 27 19 00 2D 00 00 00 00 00 00 18 00 7F 00 00 00 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 1E 5F 09 14 32 00 00 00 22 00 B2 2B 1A 00 2A 08 1E 5F 0A 14 32 00 00 00 22 00 B2 2B 28 00 30 08 1E 7F 00 00 00 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 00 00 00 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 00 00 00 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 0A 00 35 08 1E 46 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 1E 46 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm,62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,4.50 mm/%,62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,3.30 mm/%,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Mehrlenkerhinterachse Frontantrieb ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.10 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,1 ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,10 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,10 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,10 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,10 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,550 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,680 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,5.0 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,5 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,60.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,20.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-0.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-0.55 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-1.10 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-2.40 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-2.80 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,0.30 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,0.20 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,0.80 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-4.60 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.20 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG122979-ENG141969-Networking-UGDO,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,0 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,0 ,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,0 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,0.0 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,not active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Audi ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
ENG122929-RLS_LIN_Communication,4 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,1
ENG122935-RLS_Washer_Front,15 s,1
ENG122926-RLS_wiper_position_parking,15 s,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,1000 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1000 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,SMLS ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s,21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,100 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,150 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,unidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,1-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
Elapsed Time: 01:31
henbo
C?ID=318655
13 Auto Dist. Reg
Block
;SW:5Q0-907-572-G   HW:5Q0-907-572-G ---  Auto Dist. Reg
;Component:ACC BOSCH MQB H10 0571, Coding:5500E7C111FFC728949C8045000026
;EV_ACCBOSCHVW416,001005,EV_ACCBOSCHVW416_001_VW37.rod
;Thursday,02,August,2018,08:09:51:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 3B36E8BCB2A09A9C32-806E
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,13.0, V
IDE00030,Status of actuator test,not active,
IDE00102,Control Module temperature,43, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01788,Heated lens control signal,0.00, %
IDE01794,ACC operating lever signal,00000001 01001000 ,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,A5 3F 96 6B,
IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 31 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C9 37 8A 27 80 D8 2C 8D 73 BC DC 20 E7 9C 7C D0 9F 3A 9E EE 13 AB 53 8E 4B E5 96 5C 6B C2 9E CC 51 13 00 E5 1A 81 6F 28 6B 3D 28 B8 9B D9 80 37 13 BB 54 73 69 96 5B 5F D2 C8 3A 8E F0 69 43 40 DE 8E B4 F4 B1 6A A1 C3 06 F3 BC F8 5E 8B D2 E1 04 7E 13 4A 72 CF 2C 3B 52 8E 85 73 72 45 4A 66 7A 01 9A D2 C6 E1 DD 6E BD C7 AF 95 04 BB BA C2 E5 47 D4 58 9C 8C 57 D9 99 B2 E2 AC B3 81 23 6F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE05814,Individualization characteristic,34 84 E6 C3 8C,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE08768,Mirror deviation: horizontal,0.009, °
IDE08769,Mirror deviation: vertical,-0.705, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.259, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.258, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,17,
IDE09380-MAS00107,Performed adjustment-Month,01,
IDE09380-MAS00108,Performed adjustment-Day,17,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.30, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,2.85, °
IDE09906,Vertical deadjustment,3.138, °
ENG107409,Longitudinal_acceleration_vehicle_reference,0.00, m/s²
ENG107860,Number_of_ANB_partial_bracings,0,
ENG107861,Number_of_ANB_target_bracings,5,
ENG107862,Number_of_ANB-CM,0,
ENG00926,Number_of_boost_function_active,9,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00915,Number_of_fully_developed_deceleration_1,1,
ENG00916,Number_of_fully_developed_deceleration_2,0,
ENG06681,Number_of_mainwarnings,0,
ENG03998,number_of_prewarnings,121,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,22192, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,17070, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,17, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,5111, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG00921,Operating_time_ACC_active_timegap_1,347, min
ENG00922,Operating_time_ACC_active_timegap_2,3292, min
ENG00923,Operating_time_ACC_active_timegap_3,65535, min
ENG00924,Operating_time_ACC_active_timegap_4,346, min
ENG00925,Operating_time_ACC_active_timegap_5,26, min
ENG00929,Operating_time_ACC_active_v-delta_0,22192, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG00933,Operating_time_STA_active,0, min
ENG00934,Operating_time_STA_off_activation_possible,0, min
ENG00935,Status_ACC_System,ACC_StandBy,
ENG08760,Sw_version_supplier,1037603449;PF_R28.3.0_VW.MQB_A1_GPevo14.0571_I3.3;0;Compiled by BBT2BP on Thu Apr  7 17:50:31 2016$!,
ENG109878,Velocity_vehicle_reference,0.00, m/s
Elapsed Time: 00:13
ADP
;Thursday,02,August,2018,08:10:04:50490
IDE00001-Production mode,Deactivating ,3
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,On ,1
IDE01949-Distance basic setting option,OFF ,1
IDE03642-Presentation mode,not active ,1
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,OFF ,1
IDE09564-Distance change via speed adjustment,OFF ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,Yes ,1
Elapsed Time: 00:05
henbo
C?ID=318655
15 Airbags
Block
;SW:5Q0-959-655-AM   HW:5Q0-959-655-AM ---  Airbags
;Component:AirbagVW21    003 0317, Coding:98CCC0000C2000009C540000004800000065
;EV_AirbaVW20SMEVW37X,002154,EV_AirbaVW20SMEVW37X_VW37.rod
;Thursday,02,August,2018,08:10:27:50490
;VCID: 0B56787CA2806A1C42-805E
IDE00821,Safety belt switch 2nd row driver side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Safety belt switch 2nd row center,not connected,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.4, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.3, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.2, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.3, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,no measured value present,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,no measured value present,
IDE01114,Driver side belt force limiter igniter ohm value,no measured value present,
IDE01115,side belt force limiter igniter ohm value,no measured value present,
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,416.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,too Low,
IDE01195,Front passenger side seat occupancy detection: Ohm value,484.0, Ohm
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,too High,
IDE01201,Frt.pass. seat position sensor current value,too High,
IDE01205,Safety belt switch 2nd row driver side ohm value,too Low,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,too Low,
IDE01207,Safety belt switch center 2nd row ohm value,too Low,
IDE01208,Seat belt switch 3rd row driver side ohm value,too High,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too High,
IDE01271,Number of rollover bar deployments,0,
IDE01285,Counter of component protection malfunctions,0,
IDE01357,Pedestrian protection trigger: driver side,correct,
IDE01358,Pedestrian protection trigger: frt.pass. side,correct,
IDE01555,Number of frontal crashes,0,
IDE01556,Number of side crashes driver side,0,
IDE01557,Number of side crashes frt.pass. side,0,
IDE01558,Number of rear crashes,0,
IDE01559,Number of rollover crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,2.3, Ohm
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,2.3, Ohm
IDE02246,Number of activations of pedestrian protection,0,
IDE02486,Data logger triggering,not active,
IDE02852,Igniter for battery interrupt: high voltage battery,correct,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,3.1, Ohm
MAS00001,Driver airbag igniter,correct,
MAS00003,Passenger airbag igniter,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,cannot be measured currently,
MAS00016,Front passenger side seat belt tensioner igniter 2,cannot be measured currently,
MAS00017,Driver side belt force limiter igniter,cannot be measured currently,
MAS00018,Front passenger side belt force limiter igniter,cannot be measured currently,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear safety belt tension igniter,cannot be measured currently,
MAS00022,Igniter for battery interrupt,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,not installed,
MAS00044,Supply voltage: Terminal 15,13.1, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:11
ADP
;Thursday,02,August,2018,08:10:39:50490
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,activated ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,activated ,8
Elapsed Time: 00:03
henbo
C?ID=318655
16 Steering wheel
Block
;SW:8V0-953-521-MS   HW:5Q0-953-549-D ---  Steering wheel
;Component:Lenks. Modul  004 0140, Coding:EC18
;EV_SMLSKLOMQB,020002,EV_SMLSKLOMQB_020_AU37.rod
;Thursday,02,August,2018,08:10:56:50490
;VCID: 177E140CEE489EFCF6-8042
IDE00030-ENG99298,Status of actuator test-State,not active,
IDE00329-MAS00232,Buttons for multi-function display-MFI button UP,not coded/not installed,
IDE00329-MAS00233,Buttons for multi-function display-MFI button DOWN,not coded/not installed,
IDE00329-MAS00234,Buttons for multi-function display-MFI button RESET / OK,not coded/not installed,
IDE00329-MAS00236,Buttons for multi-function display-MFI buttons: number 3/4,not coded/not installed,
IDE00329-MAS00688,Buttons for multi-function display-Multifunction indicator,not coded/not installed,
IDE00333,Driver assistance systems button,not activated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,On,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Distance Regulation,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not coded/not installed,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,6 Position operating unit,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,On,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
IDE02694-MAS01288,Signal horn activation-Signal horn,not activated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 2,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear Window Wiper,not activated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,not activated,
IDE02743,High Beam,not activated,
IDE02744-MAS01632,Steering wheel heater-Status,OFF,
IDE02744-MAS04136,Steering wheel heater-Current,0.00, A
IDE02744-MAS09022,Steering wheel heater-PWM value,0, %
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,24, °C
IDE02745-IDE00096,Ignition key removal lock-Selector lever position,Current,
IDE02745-MAS08202,Ignition key removal lock-CAN p locked,Engaged and locked,
IDE02745-MAS08203,Ignition key removal lock-CAN p locked: qualified,Not qualified,
IDE02745-MAS08204,Ignition key removal lock-Hardware input: p_verriegelt,Open,
IDE02745-MAS08205,Ignition key removal lock-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition key removal lock-CAN ESP speed,0, km/h
IDE02745-MAS08207,Ignition key removal lock-CAN GWB obsolete transmission,Current,
ENG120506-ENG100300,CCS_in_indic-lever-E: Blinkerhebel GRA Cancel,not activated,
ENG120506-ENG103377,CCS_in_indic-lever-E: Blinkerhebel GRA Fehler,No malfunction detected,
ENG120506-ENG103714,CCS_in_indic-lever-E: Blinkerhebel GRA OFF,not activated,
ENG120506-ENG102330,CCS_in_indic-lever-E: Blinkerhebel GRA ON,not activated,
ENG120506-ENG120475,CCS_in_indic-lever-E: Blinkerhebel GRA Speedlimiter,OFF,
ENG120506-ENG103991,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Resume/Plus,not activated,
ENG120506-ENG100605,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Set/Minus,not activated,
ENG120506-ENG120476,CCS_in_indic-lever-E: GRA_E_A,OFF,
ENG120507-ENG100163,CCS_in_third_lever-E: 3.ter Hebel ADR Fehler,No malfunction detected,
ENG120507-ENG99937,CCS_in_third_lever-E: 3.ter Hebel ADR Minus,not activated,
ENG120507-ENG101800,CCS_in_third_lever-E: 3.ter Hebel ADR Plus,not activated,
ENG120507-ENG101234,CCS_in_third_lever-E: 3.ter Hebel GRA Cancel,not activated,
ENG120507-ENG103820,CCS_in_third_lever-E: 3.ter Hebel GRA Fehler,No malfunction detected,
ENG120507-ENG99143,CCS_in_third_lever-E: 3.ter Hebel GRA OFF,not activated,
ENG120507-ENG100333,CCS_in_third_lever-E: 3.ter Hebel GRA ON,operated,
ENG120507-ENG101903,CCS_in_third_lever-E: 3.ter Hebel GRA Resume,not activated,
ENG120507-ENG101230,CCS_in_third_lever-E: 3.ter Hebel GRA Set,not activated,
ENG120507-ENG129309,CCS_in_third_lever-E: 3.ter Hebel GRA Speedlimiter,not activated,
ENG120507-ENG126425,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Beschleunigen,not activated,
ENG120507-ENG126426,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Verzögern,not activated,
ENG120507-ENG120477,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Beschleunigen,not activated,
ENG120507-ENG120478,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Verzögern,not activated,
ENG120507-ENG120476,CCS_in_third_lever-E: GRA_E_A,On,
ENG126424-ENG126428,LRH-LRH_current,0.00, A
ENG126424-ENG126430,LRH-LRH_level,low,
ENG126424-ENG126429,LRH-LRH_status,OFF,
ENG126424-ENG126427,LRH-LRH_temperature_NTC,24, °C
Elapsed Time: 00:02
ADP
;Thursday,02,August,2018,08:10:58:50490
ENG126411-p_k_i,0.040 %/s,1
ENG126415-p_k_i_offset,4 K,1
ENG126410-p_k_p,13.0 %,1
ENG126419-p_leistung_lrh,110 W,1
ENG126417-p_n_fehler_p_verriegelt,250 ,1
ENG120504-p_s_NWDF_spg,00000000  ,1
ENG102189-p_t_blinker_entprellen,40 ms,1
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms,1
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms,1
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms,1
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s,1
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms,1
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s,1
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms,1
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s,1
ENG100923-p_t_blinker_err_unplausibel,200 ms,1
ENG103471-p_t_blinker_gra_entprellen,40 ms,1
ENG101294-p_t_blinker_sperrzeit,100 ms,1
ENG127114-p_t_entprellung_p_unplausibel,400 ms,1
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms,1
ENG101392-p_t_entprellzeit_unterspannung,90000 ms,1
ENG102689-p_t_fas_entprellen,40 ms,1
ENG120505-p_t_gra_ea_error,200 ms,1
ENG101014-p_t_grahebel_entprellen,40 ms,1
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms,1
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms,1
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms,1
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s,1
ENG103536-p_t_grahebel_err_unplausibel,200 ms,1
ENG126416-p_t_grenze_v,10 km/h,1
ENG99436-p_t_hupe_entprellen,40 ms,1
ENG102496-p_t_hupe_err_hinweis,2000 ms,1
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms,1
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s,1
ENG101702-p_t_hupe_indien_entprellen,500 ms,1
ENG126421-p_t_lrh_kurzschluss_entprellen,200 ms,1
ENG126422-p_t_lrh_unterbrechung_entprellen,1000 ms,1
ENG103999-p_t_p_verriegelt_entprellen,40 ms,1
ENG126412-p_t_soll_0,39 °C,1
ENG126413-p_t_soll_1,43 °C,1
ENG126414-p_t_soll_2,47 °C,1
ENG100796-p_t_spannung_obere_schwelle,16.7 V,1
ENG102338-p_t_spannung_untere_schwelle,8.5 V,1
ENG100559-p_t_wischer_entprellen,40 ms,1
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms,1
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms,1
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms,1
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s,1
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms,1
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s,1
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms,1
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s,1
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms,1
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s,1
ENG101592-p_t_wischer_intervall_entprellen,40 ms,1
ENG103607-p_t_wischer_winterstellung,60 s,1
ENG126423-p_temp_lenkradheizung_aus,50 °C,1
ENG126420-p_zeit_temperatur_statisch_lrh,300 s,1
Elapsed Time: 00:26
henbo
C?ID=318655
17 Instruments
Block
;SW:8V0-920-873-H   HW:8V0-920-873-H ---  Instruments
;Component:KOMBI         H05 8316, Coding:07040C186F800008008328101200000000000000
;EV_DashBoardVDDMQBAB,009054,EV_DashBoardVDDMQBAB_009_VW37.rod
;Thursday,02,August,2018,08:11:37:50490
;VCID: 43C6905CCA50E25C7A-8016
IDE00019,Voltage terminal 30,13.2, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,25.50, °C
IDE00075,Vehicle speed,0, km/h
IDE00196,Engine oil temperature,25, °C
IDE00301,Distance,30904, km
IDE00310,Outside air temperature,21.5, °C
IDE00316-IDE00500,Time-Hour,8, H
IDE00316-IDE00501,Time-Minute,3, min
IDE00316-MAS00111,Time-Seconds,54, s
IDE00317-IDE00502,Date-Year,2018, yr
IDE00317-IDE00503,Date-Month,8, mon
IDE00317-IDE00504,Date-Day,2, d
IDE00510,ESI: distance driven from inspection,1920, km
IDE00511,ESI: time from inspection,24, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,15000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,1500, km
IDE00520,Phototransistor,59,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,13080, km
IDE00698,ESI: remaining running time,341, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,561, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1947, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2005, mm
IDE00935,ESI: Theoretical service interval,61600, km
IDE01076,Time since ignition off,1594, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-MAS06854,FAZIT identification test sum-Version,02,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,93 87 B5 44,
IDE02307,Parking brake status,not activated,
IDE02642,Outside temp.: displayed value,21.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,99,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,64,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,3604,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,1900, km
IDE03352,FIX: Time since last time-dependent inspection,24, d
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,25.0, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,42.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,43.0, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,27.1, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,23.7, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,42.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,43.0, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,25.3, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,15.6, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,42.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,43.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,16.6, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,33.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,42.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,43.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,34.4, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,30500,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,30100,
IDE03472-MAS06155,Volume after refueling-Third to last distance,29600,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,28900,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,159, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,1, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,1830,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,1967,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,25.2, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,158, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,25.3, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,25.3, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,25.3, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,25.3, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,25.3, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.01,
IDE03474-ENG101623,Calculated volume-reference_volume,25.3, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,8,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0012493,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,0, H
IDE03477-IDE00501,GPS time-Minute,0, min
IDE03477-IDE00502,GPS time-Year,2000, yr
IDE03477-IDE00503,GPS time-Month,1, mon
IDE03477-IDE00504,GPS time-Day,1, d
IDE03477-MAS00111,GPS time-Seconds,0, s
IDE03477-MAS03493,GPS time-last synchronization year,2000, yr
IDE03506,Distance: high resolution,01 D7 90 0E,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,CF F0 00 0D,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,8F F0 00 35,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,4F F0 00 0D,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,0F F0 00 35,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,0F F0 3A CD,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,4F F0 01 16,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,4F F0 02 19,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 71 38,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 71 38,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,CF F0 02 19,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,365, d
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
ENG124477-MAS06854,Adapted_transponders_checksum-Version,01,
ENG124477-MAS06855,Adapted_transponders_checksum-Test sum,2E FA 16 47,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,27, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,64, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,83, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,81, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,26, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,53, km
ENG106922,Immobilizer - Challenge,68 A5 46 65,
ENG99439,Instrument_recorder,03 03 41 00 4D 51 42 41 55 31 36 53 31 43 48 45 00 00 00 00 03 00 6B 00 0F 00 00 05 22 00 00 00 00 80 00 83 69 00 97 00 1C 00 00 00 BF 00 00 00 00 00 00 00 00 01 17 00 35 00 05 04 6E 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 61 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A FF FF FF FF FF FF FF FF FF 00 00 0F 00 6B 00 22 05 00 00 00 00 00 00 35 00 17 01 6E 04 05 00 00 00 00 00 0F 00 6B 00 22 05 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7F FB,
ENG107920-ENG100914,onboard_computer-current_consumption,0.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,5.4, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,5.6, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,2.0, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,410, km
ENG107920-ENG119792,onboard_computer-range_R,415,
ENG107920-ENG112418,onboard_computer-total_range_gas,410, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,143,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG103405,read_out_measured_value_block,30,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,0,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,0,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,0,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 5B 02 00 00 00 03 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,F8,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,F8,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,1C,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,F8,
ENG103284-ENG20775,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG20776,State of Immobilizer Slaves-VTS_state,00,
ENG109576,Transponder ID Key 1,08 FC 44 B4,
ENG109577,Transponder ID Key 2,08 FC 86 78,
Elapsed Time: 00:13
ADP
;Thursday,02,August,2018,08:11:50:50490
IDE00301-Distance,30904 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,German ,1
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,8 H,1
IDE00501-Minute,4 min,1
IDE00502-Year,2018 yr,2
IDE00503-Month,8 mon,1
IDE00504-Day,2 d,1
IDE00510-ESI: distance driven from inspection,1920 km,3
IDE00511-ESI: time from inspection,24 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,15000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,1500 km,2
IDE00819-Day counter,561 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Not available ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,5.6 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,220 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1900 km,2
IDE03352-FIX: Time since last time-dependent inspection,24 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,No display ,1
IDE07221-Cylinder shut-off,Display ,1
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE11086-Service notification,0 d,1
IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,20 l,1
ENG119880-ENG101574-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X1,00 ,12
ENG119880-ENG99557-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X2,0A ,12
ENG119880-ENG102140-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X3,64 ,12
ENG119880-ENG102936-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X4,96 ,12
ENG119880-ENG103548-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X5,DC ,12
ENG119880-ENG113992-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X6,FD ,12
ENG119880-ENG99777-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y1,02 ,12
ENG119880-ENG100480-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y2,02 ,12
ENG119880-ENG100773-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y3,10 ,12
ENG119880-ENG100631-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y4,1E ,12
ENG119880-ENG102174-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y5,3C ,12
ENG119880-ENG113993-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y6,64 ,12
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,03 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,03 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
ENG119881-ENG101574-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X1,00 ,12
ENG119881-ENG99557-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X2,0A ,12
ENG119881-ENG102140-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X3,64 ,12
ENG119881-ENG102936-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X4,96 ,12
ENG119881-ENG103548-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X5,DC ,12
ENG119881-ENG113992-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X6,FD ,12
ENG119881-ENG99777-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y1,02 ,12
ENG119881-ENG100480-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y2,02 ,12
ENG119881-ENG100773-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y3,10 ,12
ENG119881-ENG100631-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y4,1E ,12
ENG119881-ENG102174-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y5,3C ,12
ENG119881-ENG113993-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y6,64 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,6E ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,82 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,AA ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,05 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,14 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,50 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,04 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,04 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,40 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,52 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5F ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,64 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,96 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,08 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,08 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,64 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,64 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,64 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,64 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,96 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0A ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0A ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,32 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,5F ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,64 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,03 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,03 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,19 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,28 ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46 ,12
ENG119874-Gas_functionality,not active ,1
ENG128742-Gauge_dimming_condition,OFF ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG135292-phev_stat_intervall-,5.0 ,3
ENG135292-phev_stat_intervall-,64 m,3
ENG135292-phev_stat_intervall-,00 min,3
ENG126396-Scale_switching_algorithm,auto_lowbeam_sidelight ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,0 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,0 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,1.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,1.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:25
henbo
C?ID=318655
19 CAN Gateway
Block (I wish I knew what all that history stuff is about - can only hope it doesn't reveal my disguided paths)
;SW:3Q0-907-530-D   HW:3Q0-907-530-D ---  CAN Gateway
;Component:GW MQB EV     615 6286, Coding:0201001726F200005B001218581000000001010100010000000300000000
;EV_GatewNF,013020,EV_GatewNF_VW27.rod
;Thursday,02,August,2018,08:12:29:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 302CCF906BE669C497-8064
Group,Description,Actual
IDE00019,Voltage terminal 30,13.1, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00030,Status of actuator test,not active,
IDE00056-ENG20489,History data 1-Life Cycle Data String,2018-02-28-21:30*00.0*01*00000***
2018-02-28-21:01*00.0*01**
2018-02-28-13:20*00.0*01**
IDE00057-ENG20489,History data 2-Life Cycle Data String,-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489,History data 3-Life Cycle Data String,2017-11-29-18:32*0*1*079*030*0-0-1-1-1-0-0*0*0*00.0*01.1**
2017-01-31-07:55*T*0*083*032*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-31-06:27*T*0*084*032*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-30-08:08*T*0*085*030*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-20-08:25*T*0*091*026*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-19-16:37*T*0*091*030*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-19-11:54*T*0*089*026*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-18-01:44*T*0*084*035*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-18-00:03*T*0*085*037*0-0-0-0-0-0-0*0*0*00.0*00.0**
2017-01-17-23:29*T*0*086*039*0-0-0-0-0-0-0*1*0*00.0*00.0**,
IDE00059-ENG20489,History data 4-Life Cycle Data String,2017-01-17-15:36*01*058*JCB*261215F103*10010*02272*0000*0000*0000**
IDE00060-ENG20489,History data 5-Life Cycle Data String,-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061-ENG20489,History data 6-Life Cycle Data String,2018-08-02-07:19*036*+26*+000.4*00.20*0.00*000**
2018-08-01-19:07*039*+28*+000.4*00.40*0.00*000**
2018-08-01-17:18*037*+27*+000.1*00.00*0.00*000**
2018-08-01-09:03*039*+28*+000.7*00.30*0.00*000**
2018-07-31-21:46*037*+35*+000.8*00.10*0.00*000**
2018-07-31-21:24*037*+34*-000.5*00.30*0.00*000**
2018-07-31-18:08*040*+33*+000.2*00.30*0.00*000**
2018-07-31-16:21*039*+31*-000.1*00.00*0.00*000**
2018-07-31-08:08*039*+28*+000.0*00.30*0.00*000**
2018-07-30-21:12*039*+35*+000.5*00.30*0.00*000**,
IDE00062-ENG20489,History data 7-Life Cycle Data String,2018-08-01-19:36*035*+000.0*011.6*00.0*00.0**
2018-08-01-17:19*039*+000.0*001.7*00.0*00.0**
2018-08-01-09:22*037*+000.0*007.8*00.0*00.0**
2018-07-31-21:53*037*+000.0*011.1*00.0*00.0**
2018-07-31-18:27*036*+000.0*002.9*00.0*00.0**
2018-07-31-16:23*040*+000.0*001.7*00.0*00.0**
2018-07-31-16:21*039*+000.1*000.0*00.0*00.0**
2018-07-31-08:27*039*+000.0*007.8*00.0*00.0**
2018-07-30-21:20*037*+000.0*010.7*00.0*00.0**
2018-07-30-18:38*039*+000.0*002.5*00.3*00.2**,
IDE00063-ENG20489,History data 8-Life Cycle Data String,2018-07-09-12:54*1*11*00*00*01*-------------:--*01**
       0028985km*1*10*00*00*01*-------------:--*01**
2018-02-28-13:25*1*09*00*00*01*-------------:--*01**,
IDE00064-ENG20489,History data 9-Life Cycle Data String,2017-01-17-15:39*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
2018-07-19-19:32*098*098*080*035*02168*12.50*+29*04*01*12.70*05311*00000**
2018-07-08-19:35*097*097*086*039*02084*12.60*+30*04*01*12.70*05311*00000**
2018-06-21-18:32*098*098*078*034*01971*12.50*+25*04*01*12.70*05311*00000**
2018-05-27-13:58*097*097*080*035*01850*12.50*+24*04*01*12.70*05311*00000**
2018-05-04-19:14*098*098*082*036*01765*12.50*+22*04*01*12.70*05311*00000**
2018-04-07-16:26*098*098*080*034*01674*12.50*+18*04*01*12.70*05311*00000**
2018-03-28-16:07*097*097*083*035*01619*12.60*+14*04*01*12.70*05311*00000**
2018-03-18-16:40*097*097*082*031*01566*12.50*+05*04*01*12.70*05311*00000**
2018-02-23-07:22*096*095*083*030*01503*12.60*+05*04*01*12.70*03799*00000**
2018-01-25-23:29*099*099*074*031*01451*12.40*+13*04*01*12.70*03799*00000**
2018-01-06-16:33*098*098*081*033*01414*12.50*+11*04*01*12.70*03799*00000**,
IDE00065-ENG20489,History data 10-Life Cycle Data String,-------------:--*-*---.-*-----*-*---.-*-----*--.--*-------**
IDE00066-ENG20489,History data 11-Life Cycle Data String,2018-08-02-07:19*000*000*000*017*0229*017*00.0*00.4*079*035*079*036*01*00569*00599*00952*01471*02511**
2018-08-01-19:07*000*004*018*000*0362*029*00.9*01.3*084*039*084*039*01**
2018-08-01-17:18*000*000*000*001*0004*001*00.0*00.1*081*037*081*037*01**
2018-08-01-09:03*000*000*014*000*0267*019*00.0*00.7*083*037*084*039*01**
2018-07-31-21:46*000*000*000*006*0011*006*00.0*00.7*080*037*081*037*01**,
IDE00067-ENG20489,History data 12-Life Cycle Data String,-------------:--*---------------**
2018-07-31-21:46*1*080*037*+34*04*070*+08.07*12.8*1**
2018-07-31-16:19*1*083*039*+30*04*070*-11.93*12.5*1**
2018-07-30-10:28*1*082*037*+30*04*070*-06.34*12.4*1**
2018-07-27-11:12*1*083*039*+28*04*070*-07.65*12.4*1**
2018-07-24-18:01*1*083*038*+29*04*070*-18.74*12.5*1**
00186*00000*00000**,
IDE00068-ENG20489,History data 13-Life Cycle Data String,2017-11-29-18:33*1-0-0-0-0*000.0*00001**
IDE00071-ENG20489,History data 16-Life Cycle Data String,       0030904km**
00038*01645*01453*00000*00000**
02204*00000*00000*00000**
06526*01861*00063*00584**
00683*00741*00507*00774**
01280*01226*00199**
00000*00000*00000*00000**
04695*00023*00007**
00017*00001*00003**
00017*00001*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,0,
IDE00773,Terminal 15 status via CAN,On,
IDE01285,Counter of component protection malfunctions,0,
IDE01459,Energy management heat output control status,not active,
IDE01803-ENG20489,History data 17-Life Cycle Data String,-------------:--*--.-*-----*-----**
2017-01-20-07:31*5*008*02.2*100*000*020*000*009**
2017-01-17-23:00*5*008*02.2*100*000*002**
2017-01-17-19:27*5*000*04.0*078*000*003**
2017-01-17-19:26*5*000*03.8*078*000*000**
2017-01-17-19:25*5*000*03.8*078*000*000**,
IDE01804-ENG20489,History data 18-Life Cycle Data String,-------------:--*---*---*--*---*-*---*---*-----**
2018-08-02-07:19*000*000*032*00.0*02731**
2018-08-01-19:07*000*000*032*00.0**
2018-08-01-17:18*000*000*032*00.0**,
IDE01805-ENG20489,History data 19-Life Cycle Data String,-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Databus drivetrain,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Databus extended,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Databus Infotainment,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.5, H
IDE01809-MAS00106,History data 23-Year,2018,
IDE01809-MAS00107,History data 23-Month,7,
IDE01809-MAS00108,History data 23-Day,21,
IDE01809-MAS00109,History data 23-Hours,14, H
IDE01809-MAS00110,History data 23-Minutes,10, min
IDE01809-MAS14375,History data 23-Cycle counter,3047,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Comfort data bus,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,81,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Drive Motor Control Module,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,36,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,2.3, H
IDE01810-MAS00106,History data 24-Year,2018,
IDE01810-MAS00107,History data 24-Month,7,
IDE01810-MAS00108,History data 24-Day,30,
IDE01810-MAS00109,History data 24-Hours,20, H
IDE01810-MAS00110,History data 24-Minutes,56, min
IDE01810-MAS14375,History data 24-Cycle counter,3101,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,23,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,00 00 05 F0,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,1,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Comfort data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,12 DD 54 6F,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 03 66,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,1,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Comfort data bus,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,3116,
IDE01812-MAS03173,History data 26-Databus drivetrain,615,
IDE01812-MAS03174,History data 26-Comfort data bus,11940,
IDE01812-MAS03175,History data 26-Databus extended,6393,
IDE01812-MAS03177,History data 26-Databus Infotainment,0,
IDE01812-MAS03178,History data 26-Suspension data bus,110,
IDE01812-MAS03180,History data 26-Local data bus,1,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,19059,
IDE01813-MAS03173,History data 27-Databus drivetrain,9030,
IDE01813-MAS03174,History data 27-Comfort data bus,38617,
IDE01813-MAS03175,History data 27-Databus extended,6998,
IDE01813-MAS03177,History data 27-Databus Infotainment,1423,
IDE01813-MAS03178,History data 27-Suspension data bus,1905,
IDE01813-MAS14374,History data 27-Totals,57973,
IDE01814-MAS03173,History data 28-Databus drivetrain,5659,
IDE01814-MAS03174,History data 28-Comfort data bus,27196,
IDE01814-MAS03175,History data 28-Databus extended,0,
IDE01814-MAS03177,History data 28-Databus Infotainment,0,
IDE01814-MAS03178,History data 28-Suspension data bus,76,
IDE01814-MAS14374,History data 28-Totals,32935,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.6, H
IDE01816-MAS00106,History data 30-Year,2017,
IDE01816-MAS00107,History data 30-Month,9,
IDE01816-MAS00108,History data 30-Day,2,
IDE01816-MAS00109,History data 30-Hours,11, H
IDE01816-MAS00110,History data 30-Minutes,58, min
IDE01816-MAS14375,History data 30-Cycle counter,1280,
IDE01816-ENG20570,History data 30-Bus_1,Databus drivetrain,
IDE01816-ENG20572,History data 30-Bus_2,Databus extended,
IDE01816-ENG20574,History data 30-Bus_3,Unknown,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.3, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.1, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,Node_0x-- $-- (empty entry),
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.5, H
IDE01818-MAS00106,History data 32-Year,2018,
IDE01818-MAS00107,History data 32-Month,7,
IDE01818-MAS00108,History data 32-Day,21,
IDE01818-MAS00109,History data 32-Hours,14, H
IDE01818-MAS00110,History data 32-Minutes,10, min
IDE01818-MAS14375,History data 32-Cycle counter,3047,
IDE01818-MAS14391,History data 32-Alerting ECU,Drive Motor Control Module,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,2.3, H
IDE01819-MAS00106,History data 33-Year,2018,
IDE01819-MAS00107,History data 33-Month,7,
IDE01819-MAS00108,History data 33-Day,30,
IDE01819-MAS00109,History data 33-Hours,20, H
IDE01819-MAS00110,History data 33-Minutes,56, min
IDE01819-MAS14375,History data 33-Cycle counter,3101,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 05 F0,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2018,
IDE01820-MAS00107,History data 34-Month,8,
IDE01820-MAS00108,History data 34-Day,2,
IDE01820-MAS00109,History data 34-Hours,7, H
IDE01820-MAS00110,History data 34-Minutes,42, min
IDE01820-MAS14375,History data 34-Cycle counter,3115,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 31,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2017,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,17,
IDE01823-MAS00109,History data 37-Hours,20, H
IDE01823-MAS00110,History data 37-Minutes,16, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,3116,
IDE01823-MAS14429,History data 37-Time in current cycle,0.3, H
IDE01827,Generator specified voltage value,13.2, V
IDE01828,Generator DF Signal,9.700, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,Generator recognition 75-140A,
IDE01834,Battery voltage,13.157, V
IDE01836,Battery current,0.239, A
IDE01837,Temperature of battery sensor,25, °C
IDE01838,Battery temperature,25, °C
IDE01839,Battery charge condition,79, %
IDE01841,Battery internal resistance,4.0, mOhm
IDE01842,Usable battery charge,36, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,0.4, Ah
IDE01849,Previous journey duration,0.3, H
IDE01852,Static current measurement: result,12, mA
IDE01853,Static current measurement: status,Measurement end,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,24.0, A
IDE01948,Battery internal resistance not normed,4.0, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,70 39 F8 DA,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer current too high,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Restart_by_charge_contribution,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer current too high,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,0,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer current too high,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2063,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,3,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,no measured value present,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,no measured value present,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,no measured value present,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,no measured value present,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2063,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,3,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,15,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,3,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,All releases are present,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,58, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,Fleece,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,2612100000,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04186,Battery terminal recognition,connected,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,not activated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,not activated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,not activated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,not activated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,not activated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,not activated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,not activated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,not activated,
IDE05583-IDE02766,Pause recommendation-Malfunction status,no error,
IDE05583-MAS03095,Pause recommendation-Function status,Initializing,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Pause recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,32 B2 6D 16 D5,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,Report error,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,2,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Distance Regulation,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,1,
IDE06007-MAS00108,Driving profile history data 1-Day,18,
IDE06007-MAS00109,Driving profile history data 1-Hours,14,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,4,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,29624, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,Refused switch-over,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Unknown,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,1,
IDE06008-MAS00108,Driving profile history data 2-Day,18,
IDE06008-MAS00109,Driving profile history data 2-Hours,14,
IDE06008-MAS00110,Driving profile history data 2-Minutes,3,
IDE06008-MAS00111,Driving profile history data 2-Seconds,57,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,29517, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,Refused switch-over,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,2,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,A/C behavior,
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,1,
IDE06009-MAS00108,Driving profile history data 3-Day,18,
IDE06009-MAS00109,Driving profile history data 3-Hours,14,
IDE06009-MAS00110,Driving profile history data 3-Minutes,3,
IDE06009-MAS00111,Driving profile history data 3-Seconds,57,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,29517, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Not available,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,Refused switch-over,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Start-stop,
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,1,
IDE06010-MAS00108,Driving profile history data 4-Day,18,
IDE06010-MAS00109,Driving profile history data 4-Hours,14,
IDE06010-MAS00110,Driving profile history data 4-Minutes,3,
IDE06010-MAS00111,Driving profile history data 4-Seconds,57,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,29517, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,AUTO,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,EV_On,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,unknown_profile,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,unknown_profile,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,25,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,20793,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,11879,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,8462,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,6999,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,23332,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,3303,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,13061,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,1071,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,38625,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,31234,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,7,
IDE06230-MAS00109,Break recommend.: last message-Hours,4,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,Stage 2,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,02,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,40,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,1,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,Not available,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,2,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,3,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,5,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,2,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,Not available,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,7,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,Timeout,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,0,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,Not available,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,8,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,9,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,2,
IDE07431-IDE04447,Status: driv prof.select.for corn.light & headlamp range ctrl-Function status,engaged,
IDE07431-IDE06260,Status: driv prof.select.for corn.light & headlamp range ctrl-ID number,11,
IDE07431-MAS01156,Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status,OK,
IDE07431-MAS01447,Status: driv prof.select.for corn.light & headlamp range ctrl-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,Not available,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,10,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,Timeout,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,0,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,Not available,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,14,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,Not available,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,18,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,no request,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop - operation,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,Not permitted,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,70, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,13.1, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,blocked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,blocked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,blocked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in permissible range,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,13.2, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,28, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,207, A
IDE07637,Current charge contingent for feedback,1440.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07639-MAS06342,Methods for support of high voltage side-Operating range support request,no request,
IDE07639-MAS06343,Methods for support of high voltage side-Voltage decrease range extension,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,12.30,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,Initializing,
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,Initializing,
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,13, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,8, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,2317.2, Ah
IDE07681-MAS06087,Battery total charging throughput-Total energy throughput,2269.7, Ah
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Comfort,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,unknown_profile,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,INDIVIDUAL,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,EV_On,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,hybrid_auto,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,hybrid_hold,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,second_hold,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,unknown_profile,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,unknown_profile,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,A8 12 2D C2,
IDE08346-MAS06117,Generator Analysis-Rated voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,8.0, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,565, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,-40, °C
IDE08347,adapted battery capacity,58, Ah
IDE08354-IDE04447,Status: driv.profile select. for front axle differential lock-Function status,engaged,
IDE08354-IDE06260,Status: driv.profile select. for front axle differential lock-ID number,0,
IDE08354-MAS01156,Status: driv.profile select. for front axle differential lock-Communication status,Timeout,
IDE08354-MAS01447,Status: driv.profile select. for front axle differential lock-Act.val.,0,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,Not available,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,20,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,Timeout,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08660,Recharging the NV battery,no request,
IDE08680-MAS03173,Allocation data bus identifier-Databus drivetrain,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Databus extended,15,
IDE08680-MAS03177,Allocation data bus identifier-Databus Infotainment,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Databus drivetrain,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Databus extended,OK,
IDE08681-MAS03177,Data bus defect error-Databus Infotainment,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Databus drivetrain,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Databus extended,OK,
IDE08682-MAS03177,Data bus single wire err.-Databus Infotainment,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Databus drivetrain,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Databus extended,OK,
IDE08683-MAS03177,Data bus TimeOut error-Databus Infotainment,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT09757,Allocation LIN system number-Alternator,00 1D,
IDE08684-SFT09777,Allocation LIN system number-Multi Function Steering Wheel Control Module,00 31,
IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT09833,Allocation LIN system number-Power Converter DC AC,00 69,
IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT10031,Allocation LIN system number-Operating Unit Drive Mode Selection,01 2F,
IDE08684-SFT10046,Allocation LIN system number-Control module for steering wheel touch recognition,00 00,
IDE08685-SFT09757,Status LIN user-Alternator,not active,
IDE08685-SFT09777,Status LIN user-Multi Function Steering Wheel Control Module,active,
IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT09833,Status LIN user-Power Converter DC AC,not active,
IDE08685-SFT09842,Status LIN user-Analog clock,not active,
IDE08685-SFT10031,Status LIN user-Operating Unit Drive Mode Selection,not active,
IDE08685-SFT10046,Status LIN user-Control module for steering wheel touch recognition,not active,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,0,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initializing,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08797-IDE04447,Status: drive profile for area view-Function status,engaged,
IDE08797-IDE06260,Status: drive profile for area view-ID number,0,
IDE08797-MAS01156,Status: drive profile for area view-Communication status,Timeout,
IDE08797-MAS01447,Status: drive profile for area view-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,Not available,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,22,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,Timeout,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE09057,HV battery charge state,67.5, %
IDE09074-MAS01078,Vehicle properties-Vehicle type,Plugin Hybrid,
IDE09074-MAS08256,Vehicle properties-Max energy content,1.6896e+006, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),15.5, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,6.5, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,15.2, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,41.9, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,10.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,343, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,24, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,19, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,367, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,343, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,24, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,0, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,374,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,350,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,24,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometers,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,6.5, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,14.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,14.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,14.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,14.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,14.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,14.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,15.2, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,22.1, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery:  RWB-internal deduction,4200, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.3, l
IDE09561,Closed-circuit current of last LIN sleep phase,-0.014, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10737-IDE04447,Status: driving profile selection for range calculation-Function status,engaged,
IDE10737-IDE06260,Status: driving profile selection for range calculation-ID number,53,
IDE10737-MAS01156,Status: driving profile selection for range calculation-Communication status,Timeout,
IDE10737-MAS01447,Status: driving profile selection for range calculation-Act.val.,0,
IDE10738-IDE04447,Status driving profile selection for electronic brake booster-Function status,engaged,
IDE10738-IDE06260,Status driving profile selection for electronic brake booster-ID number,0,
IDE10738-MAS01156,Status driving profile selection for electronic brake booster-Communication status,OK,
IDE10738-MAS01447,Status driving profile selection for electronic brake booster-Act.val.,2,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,32,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,1,
IDE11573,Energy management in heating power allocation,1000, W
IDE12084,Status of component protection slaves,00 14 19 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,2,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,28,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,30904, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,2,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,1,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
MAS07408,Available power for low-voltage systems,1500, W
MAS07409,Status automatic recharging of low-voltage battery,activated,
MAS07410,Requirement for consumer reduction,none,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognized,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118787-ENG06066,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_AGK,0,
ENG118787-ENG06070,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_EDS,0,
ENG118787-ENG20951,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_FMA,0,
ENG118787-ENG06074,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_HHC,0,
ENG118787-ENG118757,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_IVB,0,
ENG118787-ENG06078,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_PLA,0,
ENG118787-ENG06067,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_AGK,OK,
ENG118787-ENG06071,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_EDS,OK,
ENG118787-ENG20952,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_FMA,OK,
ENG118787-ENG06075,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_HHC,OK,
ENG118787-ENG118759,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_IVB,Timeout,
ENG118787-ENG06079,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_PLA,Timeout,
ENG118787-ENG06065,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_AGK,Not available,
ENG118787-ENG20953,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_EDS,engaged,
ENG118787-ENG20954,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_FMA,engaged,
ENG118787-ENG06073,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_HHC,engaged,
ENG118787-ENG118755,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_IVB,engaged,
ENG118787-ENG06077,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_PLA,engaged,
ENG118787-ENG06064,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_AGK,35,
ENG118787-ENG06072,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_BAS,0,
ENG118787-ENG06068,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_EDS,0,
ENG118787-ENG20955,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_FMA,0,
ENG118787-ENG118753,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_IVB,0,
ENG118787-ENG06076,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_PLA,0,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,2,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG06005-ENG06085,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG06005-ENG06084,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG106123,EM_blAlternator On,On,
ENG106140,EM_Current_Control_Recu,not active,
ENG118437,EM_IAlternatorReserve,208.0, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,100, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,100, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,1,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,0,
ENG118781-ENG118671,EM_Recuperation_Restriction-component_protection_BDM,0,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,1,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,1,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,0915,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,1914,
ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,1014,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,1707,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,7201,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0500,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,0722,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,0220,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3138,
ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,,
ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,A012,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7161,
ENG125882-ENG123177,HV-EM_currents-DCDC_HV_current,0.8, A
ENG125882-ENG123148,HV-EM_currents-ekk_air_condition_current,0.00,
ENG125882-ENG123147,HV-EM_currents-ptc_heater_current,0.00,
ENG125881,HV-EM_operation_mode,HV-EM_active_clamp_15,
ENG125883-ENG123181,HV-EM_reduction_of_comfort_consumers-cutoff_climate_aggregates,No enabling,
ENG125883-ENG123182,HV-EM_reduction_of_comfort_consumers-cutoff_HV_comfort_consumers,not requested,
ENG125883-ENG123178,HV-EM_reduction_of_comfort_consumers-max_current_climate_aggregates,0, A
ENG125883-ENG123180,HV-EM_reduction_of_comfort_consumers-max_power_HV_comfort_consumers,25400, W
ENG125883-ENG123179,HV-EM_reduction_of_comfort_consumers-reduction_climate_aggregates,25_percent,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60026,
Elapsed Time: 00:50
ADP
;SW:3Q0-907-530-D   HW:3Q0-907-530-D ---  CAN Gateway
;Component:GW MQB EV     615 6286, Coding:0201001726F200005B001218581000000001010100010000000300000000
;EV_GatewNF,013020,EV_GatewNF_VW27.rod
;Thursday,02,August,2018,08:13:20:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 302CCF906BE669C497-8064
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,58 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,2612100000 ,15
IDE03903-Production process data 1,0A AA ,2
IDE04186-Battery terminal recognition,connected ,1
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,not activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,not activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,not activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),not activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,not activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,not activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,not activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,not activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,not activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),not activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,not activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,not activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,not activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,not activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,not activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,not activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,not activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,not activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,not activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,not activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,not activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated ,4
IDE06753-MAS19094-Efficiency program display-Convenience_consumption_air_condition_ventilation_rear,not activated ,4
IDE07838-Counter for inconsistent states,0 ,2
IDE08348-Start/stop start voltage limit,9.0 V,1
IDE08624-MKE Check box,activated ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,4 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,0 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,0 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,0 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,15 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,1.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,1.0 l/100km,48
IDE10735-Number requests autonomous recharging,3 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,not activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,not activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,not activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,not activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,not activated ,3
IDE10748-MAS19099-Range gain-Convenience_consumption_means_plug,not activated ,3
IDE10748-MAS19100-Range gain-Convenience_consumption_air_condition_ventilation_manually,not activated ,3
IDE10748-MAS19132-Range gain-Consumption_mirror_heating_in_heated_rear_window,not activated ,3
IDE12132-Dynamic reserve capacity,2550 W,1
MAS16372-Security version number,2 ,2
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,10 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,120 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Elapsed Time: 00:24
henbo
C?ID=318655
23 Brake Booster
Block
;SW:5QE-909-059-E   HW:5QE-909-059-B ---  Brake Booster
;Component:EBKV          H14 0200, Coding:03720100331900010002050500
;EV_BrakeBoostBoschMQBOMG,004001,EV_BrakeBoostBoschMQBOMG_004.rod
;Thursday,02,August,2018,08:14:01:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 50ECAF100B2609C4F7-8004
Group,Description,Actual
IDE00019,Voltage terminal 30,33,
IDE00021,Engine speed,00,
IDE00025,Coolant temperature,42,
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,00,
IDE00085,Normed load value,00,
IDE00086,Accelerator position,26,
IDE00097,OBD - requirements for which this vehicle is designed,01,
IDE00102,Control Module temperature,25.035, °C
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00601-ENG30035,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG30057,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG30070,Monitoring status since erasing DTC memory-Readiness_State,00,
IDE00601-ENG30155,Monitoring status since erasing DTC memory-Supported_Info,00,
IDE00601-ENG30156,Monitoring status since erasing DTC memory-Supported_Info_Readiness,04,
IDE00602,Monitoring status in current driving cycle,00,
IDE02486,Data logger triggering,not active,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,13.2, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,13.1, V
IDE03680-MAS06928,Supply voltages-Supply voltage pedal travel sensor,5.0, V
IDE05793-IDE06045,Brake activation-Output DTM status,No activation,
IDE05793-MAS11301,Brake activation-Timer,0, s
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,0.0, km/h
IDE05816-IDE00086,Input signals from data bus-Accelerator position,0.0, %
IDE05816-IDE00643,Input signals from data bus-Minimum torque of electric machine,0.0,
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.0, bar
IDE05816-IDE03660,Input signals from data bus-Longitudinal acceleration,0.1, m/s²
IDE05816-IDE05221,Input signals from data bus-E-machine torque actual value,0.0,
IDE05816-IDE07152,Input signals from data bus-Fall-back level,not active,
IDE05816-IDE07667,Input signals from data bus-Desired torque of regeneration,0.0,
IDE05816-IDE09126,Input signals from data bus-Vehicle switch-off time,24.0,
IDE05816-IDE09127,Input signals from data bus-Status: switch-off time,calculated,
IDE05816-MAS01078,Input signals from data bus-Vehicle type,Hybrid vehicle,
IDE05816-MAS05179,Input signals from data bus-ABS intervention,not active,
IDE05816-MAS05187,Input signals from data bus-MSR intervention,not active,
IDE05816-MAS06150,Input signals from data bus-Terminal 50,not active,
IDE05816-MAS08112,Input signals from data bus-Drive readiness,Not ready,
IDE05816-MAS08788,Input signals from data bus-Driving Cycle,Not available,
IDE05816-MAS12319,Input signals from data bus-Alternator failure,no error,
IDE05816-MAS13659,Input signals from data bus-Warm air cycle,Not available,
IDE05816-MAS14468,Input signals from data bus-OBD type,Type 1,
IDE05816-MAS14473,Input signals from data bus-OBD Normed Trip,Not available,
IDE05816-MAS14474,Input signals from data bus-OBD Minimum Trip,fulfilled,
IDE06422-ENG103176,IUMPR_1-General Denominator,394,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,2689,
IDE06422-ENG100120,IUMPR_1-Milage,30710, km
IDE06422-ENG101622,IUMPR_1-Record Number,1,
IDE06423-ENG101817,IUMPR_2-Denominator,394,
IDE06423-ENG103772,IUMPR_2-DFCC Value,03 69,
IDE06423-ENG99150,IUMPR_2-Numerator,790,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE08586-IDE00805,Status: electromechanical power brake-Dead volume,15.0, mm³
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready for operation,
IDE08586-IDE06673,Status: electromechanical power brake-Initialization status,completed successfully,
IDE08586-IDE11447,Status: electromechanical power brake-electro-mechanical brake booster,active,
IDE08586-IDE11985,Status: electromechanical power brake-Expected OBD requirements,NO OBD,
IDE08586-MAS08092,Status: electromechanical power brake-Basic setting: electromechanical power brake,performed,
IDE08586-MAS10343,Status: electromechanical power brake-Correction factor_1,0.0000,
IDE08586-MAS10344,Status: electromechanical power brake-Correction factor_2,0.0000,
IDE08587-MAS02925,Power brake displays-Brake system indicator lamp,--no display--,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08587-MAS08098,Power brake displays-Note - text message,--no display--,
IDE08587-MAS08100,Power brake displays-Warnings - text message,--no display--,
IDE08588-IDE06373,Sensor signals for electromechanical power brake-Rotor position of drive motor for electric drive,0.14, °
IDE08588-MAS08107,Sensor signals for electromechanical power brake-Brake pedal position sensor pulse width,18.4, %
IDE08588-MAS08108,Sensor signals for electromechanical power brake-Brake pedal sensor 2 pulse width,82.0, %
IDE08588-MAS08109,Sensor signals for electromechanical power brake-Input rod path sensor: plausibilized,0.0, mm
IDE08588-MAS08110,Sensor signals for electromechanical power brake-Brake pedal actuation,OFF,
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.023, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.0000, Nm
IDE08588-MAS11260,Sensor signals for electromechanical power brake-Brake pedal position sensor distance,-0.041, mm
IDE08588-MAS11261,Sensor signals for electromechanical power brake-Brake pedal position sensor 2 distance,-0.014, mm
IDE08589-IDE06673,Status of brake press. accum.-Initialization status,operational,
IDE08589-IDE08581,Status of brake press. accum.-Recuperation,active,
IDE08589-MAS08113,Status of brake press. accum.-Brake pressure accum. basic setting,performed,
IDE08590-IDE00019,Supply voltages for brake press. accum.-Voltage terminal 30,13.3, V
IDE08591,Control module temp. brake press. accum.,27, °C
IDE08597-IDE06045,Activation brake press. accum.-Output DTM status,No activation,
IDE08597-MAS11301,Activation brake press. accum.-Timer,0, s
IDE11836,Query of the supported PIDs (0x01 - 0x20),98,
IDE11837,Query of the supported PIDs (0x21 - 0x40),00,
IDE11838,Query of the supported PIDs (0x41 - 0x60),C0,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),14,
IDE80001-IDE80011,Analysis 1-Analysis 11,00,
IDE80001-IDE80012,Analysis 1-Analysis 12,00,
IDE80001-IDE80013,Analysis 1-Analysis 13,00 00 00,
IDE80001-IDE80015,Analysis 1-Analysis 15,-0.0137, mm
IDE80002,Analysis 2,00 00,
IDE80002,Analysis 2,00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,2,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,21,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,30904, km
MAS10353-IDE00634,Brake press. accum. current-Vehicle electrical system current,0.0, A
MAS10353-MAS10347,Brake press. accum. current-max. veh. elec. sys. current during last pressurization,2.7, A
MAS10354-MAS10348,Sensor signals for break press. accum.-Act. volume,490.20, mm³
MAS10354-MAS10349,Sensor signals for break press. accum.-System volume,4656.4, mm³
MAS10354-MAS10350,Sensor signals for break press. accum.-Target volume,469.6, mm³
MAS10354-MAS10351,Sensor signals for break press. accum.-Maximum volume,0.00, mm³
MAS10354-MAS10352,Sensor signals for break press. accum.-Resting volume,0.00, mm³
ENG101413,Calibration Identification,2,
ENG101413,Calibration Identification,5QEB 0200 P #((S,
ENG101413,Calibration Identification,5QE057A 0152xxxx,
ENG99697,Calibration Verification Number,02 2E D0 0E,
ENG100152,ECUNAME,EBBC-ElecBrkBstCtrl,
ENG100152,ECUNAME,1,
Elapsed Time: 00:04
ADP
;Thursday,02,August,2018,08:14:05:50490
IDE08581-Recuperation,active ,1
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements,NO OBD ,1
IDE80011-MAS05513-Analysis 11-Bit 0,OFF ,1
IDE80011-MAS05514-Analysis 11-Bit 1,OFF ,1
IDE80011-MAS05515-Analysis 11-Bit 2,OFF ,1
IDE80011-MAS05516-Analysis 11-Bit 3,OFF ,1
IDE80011-MAS05517-Analysis 11-Bit 4,OFF ,1
IDE80011-MAS05518-Analysis 11-Bit 5,OFF ,1
IDE80011-MAS05519-Analysis 11-Bit 6,OFF ,1
IDE80011-MAS05520-Analysis 11-Bit 7,OFF ,1
IDE80012-MAS05513-Analysis 12-Bit 0,OFF ,1
IDE80012-MAS05514-Analysis 12-Bit 1,OFF ,1
IDE80012-MAS05515-Analysis 12-Bit 2,OFF ,1
IDE80012-MAS05516-Analysis 12-Bit 3,OFF ,1
IDE80012-MAS05517-Analysis 12-Bit 4,OFF ,1
IDE80012-MAS05518-Analysis 12-Bit 5,OFF ,1
IDE80012-MAS05519-Analysis 12-Bit 6,OFF ,1
IDE80012-MAS05520-Analysis 12-Bit 7,OFF ,1
IDE80013-Analysis 13,00 00 00 ,3
IDE80015-Analysis 15,On ,1
IDE80016-Analysis 16,On ,1
IDE80017-Analysis 17,On ,1
IDE80018-Analysis 18,OFF ,1
IDE80019-Analysis 19,00 00 00 00 ,4
IDE80020-Analysis 20,00 00 00 00 ,4
Elapsed Time: 00:03
henbo
C?ID=318655
2B Steer. Col. Lock
Block
;SW:5Q0-905-861-A   HW:5Q0-905-861-A ---  Steer. Col. Lock
;Component:ELV-MQBA      H01 0120, Coding:5D00000000000000
;EV_ELVMarquMQB,004111,EV_ELVMarquMQB.rod
;Thursday,02,August,2018,08:14:26:50490
;VCID: 3424C3809FFE55E4F3-8060
IDE00019,Voltage terminal 30,13.100, V
IDE00021,Engine speed,0.00, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00075,Vehicle speed,0.00, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS05509,Distance impulses-Left front wheel signal state,valid,
IDE01766-MAS05510,Distance impulses-Right front wheel signal state,valid,
IDE01766-MAS05511,Distance impulses-Left rear wheel signal state,valid,
IDE01766-MAS05512,Distance impulses-Right rear wheel signal state,valid,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02571-MAS05507,Terminal 50: line status-Actual value engine control module,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,not activated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02578,Play protection status,not activated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02580,Number of unlocks,2574,
IDE02581-MAS02312,Drive train uncoupling-Powertrain (engine),decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02586-MAS02398,ID sensor authenticated in vehicle-ID sensor 1,No,
IDE02586-MAS02399,ID sensor authenticated in vehicle-ID sensor 2,No,
IDE02586-MAS02400,ID sensor authenticated in vehicle-ID sensor 3,No,
IDE02586-MAS02401,ID sensor authenticated in vehicle-ID sensor 4,No,
IDE02587,ID sensor search: status,not active,
IDE02589-MAS02255,Rotary latch status-Status of rotary latch in driver door,Open,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02682-MAS02250,Disengage starter-Disengage request,No,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03527-IDE00660,CAN signals-Drive readiness,not active,
IDE03527-IDE03410,CAN signals-Yellow warning lamp,not active,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02578,Locking requirements-Play protection status,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-IDE07029,Locking requirements-Terminal status via CAN,Condition not met,
IDE06746-MAS02349,Locking requirements-Learn mode,Condition met,
IDE07028,Time until shut-off terminal S,4.14e+006, ms
IDE08440,Recommendation energy management,no restriction,
IDE09068-IDE00020,Status: automatic terminal shut-off-Terminal 15 status,Condition met,
IDE09068-IDE00021,Status: automatic terminal shut-off-Engine speed,Condition met,
IDE09068-IDE00325,Status: automatic terminal shut-off-Diagnostic mode,Condition not met,
IDE09068-IDE02579,Status: automatic terminal shut-off-Park selector lever position,Not coded,
IDE09068-IDE06983,Status: automatic terminal shut-off-Diesel emissions re-treatment: status,Condition met,
IDE09068-IDE08099,Status: automatic terminal shut-off-Status engine speed,Condition met,
IDE09068-IDE08440,Status: automatic terminal shut-off-Recommendation energy management,Condition not met,
IDE09068-MAS06473,Status: automatic terminal shut-off-Status vehicle standstill,Condition met,
IDE09068-MAS08076,Status: automatic terminal shut-off-Exiting the vehicle,Condition not met,
IDE09068-MAS08788,Status: automatic terminal shut-off-Driving Cycle,Condition not met,
IDE09068-MAS08789,Status: automatic terminal shut-off-Valid distance impulses,Condition met,
IDE09068-MAS08790,Status: automatic terminal shut-off-Driver absence,Condition met,
MAS00025,Driver seat belt switch,not connected,
MAS01493,Engine running,not active,
MAS03129,Reset counter,3,
MAS03607,Engine stop in start-stop mode active,not active,
MAS05104,Driver request: start engine,not active,
MAS09771,Driver information comfort switching,No switch-off,
ENG111213-ENG111202,Activated_Fault_Reactions-CoCo permanent reset,No,
ENG111213-ENG111201,Activated_Fault_Reactions-KL50 disabled,No,
ENG111213-ENG111200,Activated_Fault_Reactions-Locking disabled / Clamp change up disabled,No,
ENG125217,Active_requirement_light_lag,not activated,
ENG120012-ENG100326,CAN Message CLS_02-Can State,active,
ENG120012-ENG119946,CAN Message CLS_02-Time to Timeout ZV_02,1880, ms
ENG120012-ENG119966,CAN Message CLS_02-ZV_gesafet_extern_soll,0,
ENG120012-ENG119965,CAN Message CLS_02-ZV_verriegelt_extern_soll,0,
ENG120020-ENG119995,CAN Message ESCL_01-ELV_Anf_Klemme_15,1,
ENG120020-ENG119996,CAN Message ESCL_01-ELV_Anf_Klemme_50,0,
ENG120020-ENG119994,CAN Message ESCL_01-ELV_Anf_Klemme_S,1,
ENG120020-ENG120001,CAN Message ESCL_01-ELV_Anlernmodus,0,
ENG120020-ENG119998,CAN Message ESCL_01-ELV_Entriegelt,1,
ENG120020-ENG120000,CAN Message ESCL_01-ELV_Lebenszustand,1,
ENG120020-ENG120003,CAN Message ESCL_01-ELV_LED_Gelb,0,
ENG120020-ENG120002,CAN Message ESCL_01-ELV_LED_Rot,0,
ENG120020-ENG120009,CAN Message ESCL_01-ELV_P_verriegelt,0,
ENG120020-ENG120007,CAN Message ESCL_01-ELV_Txt_Defekt,0,
ENG120020-ENG120005,CAN Message ESCL_01-ELV_Txt_Lkg_Bewegen,0,
ENG120020-ENG120008,CAN Message ESCL_01-ELV_Txt_P_Gang,0,
ENG120020-ENG120004,CAN Message ESCL_01-ELV_Txt_Panikabschaltung,0,
ENG120020-ENG120006,CAN Message ESCL_01-ELV_Txt_Werkstatt,0,
ENG120020-ENG119997,CAN Message ESCL_01-ELV_Verriegelt,0,
ENG120020-ENG119999,CAN Message ESCL_01-ELV_ZAT_betaetigt,0,
ENG120016-ENG100326,CAN Message ESP_10-Can State,active,
ENG120016-ENG119984,CAN Message ESP_10-ESP_10_BZ,8,
ENG120016-ENG119985,CAN Message ESP_10-ESP_10_CRC,179,
ENG120016-ENG119993,CAN Message ESP_10-ESP_QBit_Wegimpuls_HL,0,
ENG120016-ENG119992,CAN Message ESP_10-ESP_QBit_Wegimpuls_HR,0,
ENG120016-ENG119990,CAN Message ESP_10-ESP_QBit_Wegimpuls_VL,0,
ENG120016-ENG119991,CAN Message ESP_10-ESP_QBit_Wegimpuls_VR,0,
ENG120016-ENG119989,CAN Message ESP_10-ESP_Wegimpuls_HL,0,
ENG120016-ENG119988,CAN Message ESP_10-ESP_Wegimpuls_HR,0,
ENG120016-ENG119986,CAN Message ESP_10-ESP_Wegimpuls_VL,0,
ENG120016-ENG119987,CAN Message ESP_10-ESP_Wegimpuls_VR,0,
ENG120016-ENG119951,CAN Message ESP_10-Time to Timeout ESP_10,1900, ms
ENG120014-ENG100326,CAN Message Gateway_71-Can State,active,
ENG120014-ENG119687,CAN Message Gateway_71-ESP_21_alt,0,
ENG120014-ENG119968,CAN Message Gateway_71-ESP_QBit_v_Signal,0,
ENG120014-ENG119967,CAN Message Gateway_71-ESP_v_Signal,0.00, km/h
ENG120014-ENG119947,CAN Message Gateway_71-Time to Timeout Gateway_71,940, ms
ENG120019-ENG100326,CAN Message Gateway_73-Can State,active,
ENG120019-ENG119976,CAN Message Gateway_73-MO_Drehzahl_01,0.00, /min
ENG120019-ENG119977,CAN Message Gateway_73-MO_QBit_Drehzahl_01,0,
ENG120019-ENG119684,CAN Message Gateway_73-Motor_12_alt,0,
ENG120019-ENG119948,CAN Message Gateway_73-Time to Timeout Gateway_73,480, ms
ENG120015-ENG100326,CAN Message Kessy_04-Can State,active,
ENG120015-ENG119978,CAN Message Kessy_04-KY_ID_Geber 1_im_Fzg,0,
ENG120015-ENG119979,CAN Message Kessy_04-KY_ID_Geber 2_im_Fzg,0,
ENG120015-ENG119980,CAN Message Kessy_04-KY_ID_Geber 3_im_Fzg,0,
ENG120015-ENG119981,CAN Message Kessy_04-KY_ID_Geber 4_im_Fzg,0,
ENG120015-ENG119982,CAN Message Kessy_04-KY_ID_Geber_Suche,0,
ENG120015-ENG119950,CAN Message Kessy_04-Time to Timeout Kessy_04,1980, ms
ENG120013-ENG100326,CAN Message Motor_14-Can State,active,
ENG120013-ENG119969,CAN Message Motor_14-MO_Aussp_Anlass,0,
ENG120013-ENG119970,CAN Message Motor_14-MO_BLS,0,
ENG120013-ENG119971,CAN Message Motor_14-MO_Fahrer_bremst,0,
ENG120013-ENG119975,CAN Message Motor_14-MO_HYB_Fahrbereitschaft,0,
ENG120013-ENG119973,CAN Message Motor_14-MO_Interlock,1,
ENG120013-ENG119681,CAN Message Motor_14-MO_Kl_50,0,
ENG120013-ENG119972,CAN Message Motor_14-MO_Qbit_Fahrer_bremst,0,
ENG120013-ENG119974,CAN Message Motor_14-MO_StartStopp_Motorstopp,0,
ENG120013-ENG119949,CAN Message Motor_14-Time to Timeout Motor_14,920, ms
ENG120010-ENG100326,CAN Message term._Status_01-Can State,active,
ENG120010-ENG119944,CAN Message term._Status_01-Time to Timeout Klemmen_Status_01,940, ms
ENG120010-ENG119680,CAN Message term._Status_01-ZAS_Kl_15,1,
ENG120010-ENG119679,CAN Message term._Status_01-ZAS_Kl_S,1,
ENG120011-ENG100326,CAN Message TSG_FT_01-Can State,active,
ENG120011-ENG119964,CAN Message TSG_FT_01-FT_Tuer_geoeffnet,1,
ENG120011-ENG119945,CAN Message TSG_FT_01-Time to Timeout TSG_FT_01,920, ms
ENG120018-ENG100326,CAN Message WFS_01-Can State,active,
ENG120018-ENG119952,CAN Message WFS_01-Time to Timeout WFS_01,1920, ms
ENG120018-ENG119983,CAN Message WFS_01-WFS_Schluessel_Ist,2,
ENG111214-ENG119959,CAN Request-Clamp generation,active,
ENG111214-ENG119958,CAN Request-Diagnostic connection,active,
ENG111214-ENG119961,CAN Request-Immobilizer authentication,not active,
ENG111214-ENG119960,CAN Request-Move,not active,
ENG111215-ENG119959,CAN Request-Clamp generation,active,
ENG111215-ENG119958,CAN Request-Diagnostic connection,active,
ENG111215-ENG119961,CAN Request-Immobilizer authentication,not active,
ENG111215-ENG119960,CAN Request-Move,not active,
ENG111211-ENG111203,Endposition_Button_Blocked_Contact-Button Blocked Contact 1,not activated,
ENG111211-ENG111204,Endposition_Button_Blocked_Contact-Button Blocked Contact 2,operated,
ENG111217-ENG111209,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 1,operated,
ENG111217-ENG111210,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 2,not activated,
ENG111212-ENG111184,Errorcounter-AD-Converter corrupt,0,
ENG111212-ENG111176,Errorcounter-CoCo RAM-Check,0,
ENG111212-ENG111177,Errorcounter-CoCo ROM-Check,0,
ENG111212-ENG111194,Errorcounter-CPU-Test CoCo,0,
ENG111212-ENG111192,Errorcounter-CPU-Test HaCo,0,
ENG111212-ENG111186,Errorcounter-Enable CoCo incorrect active KL15,0,
ENG111212-ENG111187,Errorcounter-Enable CoCo incorrect active locking,0,
ENG111212-ENG111178,Errorcounter-Endposition locked not reached,0,
ENG111212-ENG111181,Errorcounter-Endposition switches implausible,0,
ENG111212-ENG119957,Errorcounter-Error clamp15: - Steeringlock isn't unlock,0,
ENG111212-ENG111185,Errorcounter-HaCo CoCo communication disturbed,0,
ENG111212-ENG111175,Errorcounter-HaCo EEPROM-Check,0,
ENG111212-ENG111173,Errorcounter-HaCo RAM-Check,0,
ENG111212-ENG111174,Errorcounter-HaCo ROM-Check,0,
ENG111212-ENG111196,Errorcounter-KL15 ELV locked,0,
ENG111212-ENG111188,Errorcounter-No CoCo enable KL15,0,
ENG111212-ENG111189,Errorcounter-No CoCo enable locking,0,
ENG111212-ENG111182,Errorcounter-Particle,0,
ENG111212-ENG111195,Errorcounter-Program sequence CoCo,0,
ENG111212-ENG111193,Errorcounter-Program sequence HaCo,0,
ENG111212-ENG111190,Errorcounter-Reset HaCo CoCo failed,0,
ENG111212-ENG111191,Errorcounter-Reset SBC HaCo failed,0,
ENG111212-ENG119956,Errorcounter-Return address,00 00 00 00,
ENG111212-ENG111183,Errorcounter-SBC-Error,0,
ENG111212-ENG111197,Errorcounter-SDA-Error,0,
ENG111212-ENG111179,Errorcounter-Shortcut motor driver highside,0,
ENG111212-ENG111180,Errorcounter-Shortcut motor driver lowside,0,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,1,
ENG125220-MAS00108,History last automatic terminal switch off-Day,30,
ENG125220-MAS00108,History last automatic terminal switch off-Day,31,
ENG125220-MAS00108,History last automatic terminal switch off-Day,27,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,15,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,2,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,29,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,25,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,17,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,35,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,40,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,30859, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,30542, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,30539, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,30539, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,30262, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG111218-ENG98599,Last reset reason-external,WAKEUP_SST1,
ENG111218-ENG98656,Last reset reason-internal,NOT_INTERNAL,
ENG125219-ENG125224,Status_Selective_catalytic_reduction-Count_engine_start,OK,
ENG125219-ENG125223,Status_Selective_catalytic_reduction-Selective_catalytic_reduction_install,not installed,
ENG125218,Suppression_ignition_message,not activated,
ENG120017-ENG100326,Timeout CAN Messages-Can State,active,
ENG120017-ENG119953,Timeout CAN Messages-Time to Timeout Diagnose_01,4560, ms
ENG120017-ENG119951,Timeout CAN Messages-Time to Timeout ESP_10,1960, ms
ENG120017-ENG119947,Timeout CAN Messages-Time to Timeout Gateway_71,940, ms
ENG120017-ENG119948,Timeout CAN Messages-Time to Timeout Gateway_73,500, ms
ENG120017-ENG119950,Timeout CAN Messages-Time to Timeout Kessy_04,1840, ms
ENG120017-ENG119944,Timeout CAN Messages-Time to Timeout Klemmen_Status_01,940, ms
ENG120017-ENG119949,Timeout CAN Messages-Time to Timeout Motor_14,980, ms
ENG120017-ENG119954,Timeout CAN Messages-Time to Timeout Systeminfo_01,4820, ms
ENG120017-ENG119945,Timeout CAN Messages-Time to Timeout TSG_FT_01,920, ms
ENG120017-ENG119952,Timeout CAN Messages-Time to Timeout WFS_01,1840, ms
ENG120017-ENG119946,Timeout CAN Messages-Time to Timeout ZV_02,1940, ms
Elapsed Time: 00:08
ADP
;Thursday,02,August,2018,08:14:34:50490
Elapsed Time: 00:01
henbo
C?ID=318655
42 Door Elect, Driver
Block
;SW:5Q0-959-593-E   HW:5Q0-959-593-B ---  Door Elect, Driver
;Component:TSG FS        020 0041, Coding:00101F205C00040000001003
;EV_DCUDriveSideEWMAXKLO,006003,EV_DCUDriveSideEWMAXCONT.rod
;Thursday,02,August,2018,08:14:52:50490
;VCID: 43C6905CCA50E25C7A-8016
IDE00310,Outside air temperature,21.0, °C
IDE00322,Status of basic setting,was not yet started,
IDE01766-MAS02248,Distance impulses-Signal state,OK,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,13.2, V
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,13.1, V
IDE02668,Central window regulator switch,not installed,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not activated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,255, %
IDE04539-MAS02229,Mirror memory-Y coordinate,255, %
IDE04539-MAS02476,Mirror memory-install,not installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,255, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE04586,Mirror fold-in activation,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,100, %
IDE05726,Terminal 58xd dimmer,35, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not activated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.0, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.0, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,215, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,255, %
IDE06621,Driver side rear power window button,not activated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,A305,
IDE06933,Front window regulator relay: driver side,Open,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.5, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.5, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.5, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.5, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,0.0, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.5, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.5, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.5, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not recognized,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
IDE07222,Window regulator child lock: driver side,Not available,
IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,22, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,205, °C
IDE07413,Comfort function for front window regulator: driver side,not active,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.0, km/h
IDE08061,Child safety lock button 2,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.0, A
IDE09798,Play protection: mirror fold-in,not active,
MAS00464-MAS00106,Standard - ambient data 1-Year,2018,
MAS00464-MAS00109,Standard - ambient data 1-Hours,8,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,35712, km
MAS01872,Rear lid remote release button,not activated,
MAS02099,Switch for inside door handle,not installed,
MAS02100,Switch for outside door handle,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,255, %
ENG117313-ENG99000,control_event_memory_driver_side_rear-Value,18 04 42 B0 02 8B 78 70 A0 12 83 FC 88 02 42 B0 02 A2 78 80 9E 12 53 0C A5 02 11 78 00 8B 78 70 9F 12 18 FC A9,
ENG117295-MAS00966,Driver_Rear_VW_FAZIT_Identification_String-Manufacture location index,KUO-KUO,
ENG117295-MAS00968,Driver_Rear_VW_FAZIT_Identification_String-Day of manufacture,02.01.17,
ENG117295-MAS00969,Driver_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number,0000,
ENG117295-MAS00970,Driver_Rear_VW_FAZIT_Identification_String-Running manufacturer number,0000,
ENG117311,Status_Of_Input_Output_Control_Subsystem_1,not active,
ENG117312,Status_Of_Input_Output_Control_Subsystem_2,was not yet started,
ENG117309,Window_Regulator_Driver_Side_Rear_Sleep_Indication,not active,
ENG117315-ENG99000,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-Value,J926 ,
Elapsed Time: 00:08
ADP
;Thursday,02,August,2018,08:15:01:50490
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
ENG117304-Patch_Code_Driver_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 03 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 0A 00 0A 03 84 27 10 53 6D 03 00 10 80 0C 01 FF DF FF 00 00 00 0A 00 00 00 00 7E 31 ,128
ENG117303-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2,03 84 02 58 14 EC FF 02 02 0A 02 01 00 0A 05 1E 02 14 19 0B 00 05 F6 32 1E 0E 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 29 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 47 02 19 08 14 10 64 EC D8 FB F6 1E 14 32 05 0C 00 01 5E 02 19 0C 16 12 64 D8 C4 F6 F1 28 1E 32 0A 0C 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 A5 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 78 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 41 33 30 35 01 00 00 00 00 00 00 00 00 00 61 3C ,88
Elapsed Time: 00:07
henbo
C?ID=318655
44 Steering Assist
Block
;SW:5Q0-909-144-T   HW:5Q0-909-144-R ---  Steering Assist
;Component:EPS_MQB_ZFLS  128 1072, Coding:D106
;EV_SteerAssisMQB,013144,EV_SteerAssisMQB_013.rod
;Thursday,02,August,2018,08:15:22:50490
;VCID: 45C28E44C464DC6C54-8010
IDE00018,Voltage terminal 15,13.17, V
IDE00019,Voltage terminal 30,13.24, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,0, /min
IDE00102,Control Module temperature,34.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,08,
IDE00550-MAS01078,Identification of parameterization-Vehicle type,G0,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,07,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assistant-System status,Marginal conditions have not been met,
IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assistant-Function status,activated,
IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
IDE02202,End stage temperature,25.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Waiting for start request,
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,0, /min
IDE03682-MAS02961,Sensor for motor position-Engine angle,185.0, °
IDE03682-MAS03083,Sensor for motor position-Cosine signal,N/A---,
IDE03682-MAS03211,Sensor for motor position-Sine signal,N/A---,
IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,0, %
IDE03725-MAS03001,Steering Assistance-Mode,Unknown,
IDE03725-MAS03095,Steering Assistance-Function status,not activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,4095.9, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,-4077.5, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,0.054, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE03736,Steering torque 2,0.054, Nm
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-1.1, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-1.1, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active reset-Restoring force: setpoint,-1, N
IDE04183,Steering assistance: target engine torque,0.000, Nm
IDE04184,Steering assistance: engine output,0.000, %
IDE04185,Terminal 30 voltage filtered,13.16, V
IDE04186,Battery terminal recognition,connected,
IDE04187,Steering torque: raw value 1,66.992, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-60.156, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,66.992, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-60.156, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.40, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.39, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.40, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,-0.5, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.4, A
IDE04194,Steering assistance: electromotor power,N/A---,
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-14.9, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-1.0, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.88, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical center,0.08, mm
IDE04460,Steering angle sensor: offset straight line running,0.6, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognized,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognized,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognized,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,N/A---,
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.52, mm
IDE05162-MAS01850,Software end stop-Right,-80.36, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,148271,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,144908,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,91,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,22035,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,1,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,93,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG120739,Engine specified torque load-above_10_kilo_newton,3,
IDE05994-ENG120718,Engine specified torque load-below_-10_kilo_newton,0,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,2830135,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,448,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,15,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,316,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,412,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,178,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,4946,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,0,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition not met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,46,
MAS00976-IDE80003,Counter-Analysis 3,632298386,
MAS00976-IDE80004,Counter-Analysis 4,131,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
Elapsed Time: 00:07
ADP
;Thursday,02,August,2018,08:15:30:50490
IDE03724-Straight line running,active ,1
IDE03734-Support power,100% ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE04555-Activation of pwr steering asst without engine running,not active ,1
IDE05162-Software end stop,active ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE07540-Download without rest bus,not active ,1
IDE09571-RPM monitoring,active ,1
MAS02080-XCP calibration protocol,not active ,1
Elapsed Time: 00:02
henbo
C?ID=318655
51 Electric Drive
Block
;SW:5G0-907-080-E   HW:5G0-907-080-E ---  Electric Drive
;Component:LE Gen 3.3H11 1032, Coding:C0020000000000000000
;EV_DMCM08530115G0907080E,001008,EV_DMCM08530115G0907080E.rod
;Thursday,02,August,2018,08:15:44:50490
;VCID: 291A22F4483C180C50-807C
IDE00018,Voltage terminal 15,1,
IDE00019,Voltage terminal 30,13.095, V
IDE00613,Phase current phase U,1.63, A
IDE00614,Phase current phase V,0.94, A
IDE00615,Phase current phase W,0.31, A
IDE00619,RPM of electric machine,0, /min
IDE00626,Temperature of electric machine,30.00, °C
IDE00628,Specified value of intermediate circuit voltage,0.00, V
IDE00635,Intermediate circuit current,0.00, A
IDE00637,Intermediate circuit voltage,370.34, V
IDE00643,Minimum torque of electric machine,0.13, Nm
IDE00644,Maximum torque of electric machine,0.06, Nm
IDE00645,Specified torque of electric machine,0.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00796,Offset angle of rotor positions,276.779, °el
IDE00938,Calculated actual torque of electric machine,0.13, Nm
IDE00952,Availability of high voltage,1,
IDE04222,Test voltage for insulation measurement for power electronics,500.00, V
IDE04223,Test voltage for insulation measurement for e-machine,500.00, V
IDE05246,Power electronics heat sink temperature,42.78, °C
IDE05248,E-machine speed: actual value,0, /min
IDE05249,Regulation due to excessive temperature,0,
IDE05250,Drive control condition,Standby,
IDE05250-ENG14691,Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE,2,
IDE05419,Intermediate circuit current maximum limit,317.88, A
IDE05420,Intermediate circuit current minimum threshold,-92.69, A
IDE05421,Torque: current value,0.13, Nm
IDE05425,Output current of DCDC converter,25.13, A
IDE05426,Buck converter operation due to current limit being exceeded,0,
IDE05427,Boost converter operation due to current limit being exceeded,0,
IDE05428,Buck converter operation due to voltage limit being exceeded,0,
IDE05429,Boost converter operation due to voltage limit being exceeded,0,
IDE05578,DCDC converter intermediate circuit voltage,370.47, V
IDE06501,Adaptation of magnetic flow: status,0,
IDE06502,Offset angle adaptation: status,OfsAccurate_E,
IDE06502-ENG14694,Offset angle adaptation: status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb St Ag Rtr Offs UBYTE,2,
IDE06805,Status of voltage freedom,2,
IDE09094,CAN signal: battery manag system: traction network current,7.50, A
IDE09095,CAN signal: battery management system: traction network voltage,370.50, V
IDE09096,CAN signal: battery management sys.:hi. voltage protect.:status,MaiClsd,
IDE09096-ENG14700,CAN signal: battery management sys.:hi. voltage protect.:status-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Hvb Cntct UBYTE,2,
IDE09097,Electric motor: electric rotor frequency,0.0, Hz
IDE09098,Electric motor: electric power,0, W
IDE09099,Electric motor: mechanical power,96, W
IDE09100,Electric motor: idle status,WithoutStatorCurrent,
IDE09100-ENG14698,Electric motor: idle status-Test_Program_Rbe Asw Invr MCT enum Frwhl UBYTE,0,
IDE09101,Electric motor: magnetic flux reference value,0.000000, Wb
IDE09102,Electric motor: RMS current,0.44, A
IDE09103,E-machine: stator temperature,29.98, °C
IDE09104,E-machine: stator temperature char. curve range,1,
IDE09105,Power electronics: intermediate circuit current,0.00, A
IDE09107,Power electronics: internal power supply 2,0.439, V
IDE09108,Power electronics: internal power supply IGBT,29.924, V
IDE09111,Power electronics: gate driver status,ShortCircuitBot,
IDE09111-ENG14696,Power electronics: gate driver status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Gate Drv UBYTE,0,
IDE09113,Power electronics: IGBT module temp: phase U,42.36, °C
IDE09114,Power electronics: IGBT module temp: phase V,42.41, °C
IDE09115,Power electronics: IGBT module temp: phase W,42.31, °C
IDE09117,Position offset calibration: stay,0.00, s
IDE09118,Magnetic flow calibration: status,0,
IDE09119,Position offset calibration: diagnostic status,NotTested__E,
IDE09119-ENG14697,Position offset calibration: diagnostic status-Test_Program_Rbe Asw Invr ISC enum St Diag Al Rtr Ofs Clb UBYTE,0,
IDE09123,D/C-D/C converter: power section temp,42.30, °C
IDE09124,DC/DC converter: traction network current,-0.932, A
IDE09126,Vehicle switch-off time,24, min
IDE09127,Status: switch-off time,Abstellzeit_berechnet,
IDE09127-ENG14695,Status: switch-off time-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Dwn Ti UBYTE,1,
IDE09128,DC/DC converter: status,rbe_AswDcdc_BuckReq_e,
IDE09128-ENG14699,DC/DC converter: status-Test_Program_Rbe Asw Dcdc Enum rbe Cmn Glb Dcdc Mod Cust Des UBYTE,4,
IDE09129,DC/DC converter: output current term 30,24.00, A
IDE09130,DC/DC converter: regulated output current term 30,13.203, V
IDE09210,Phase current phase U unrestricted,3.69, A
IDE09211,Phase current phase V unrestricted,-1.19, A
IDE09212,Phase current phase W unrestricted,1.69, A
MAS06713,Supply voltage Terminal 30 - internal,12.547, V
MAS09947,Condition interm. circuit discharge circuit,DchaNotActv,
MAS09947-ENG14701,Condition interm. circuit discharge circuit-Test_Program_Rbe Asw Invr SYM enum St Dcha UBYTE,0,
MAS12577,Rotor position sensor 2 sine offset,0.000, V
MAS12578,Rotor position sensor 2 Cosine offset,0.018, V
MAS12772,DC/DC changer: high voltage current restriction,14.00, A
MAS12773,DC/DC changer: spec. operating mode,1,
MAS12774,DC/DC changer: spec. output voltage terminal 30,13.199, V
MAS13360,Discharge current HV intermediate circuit power electronics,312.94, A
MAS13361,PCB temperature power electronics,59.48, °C
MAS13362,Calculated coolant temperature DCDC converter,41.95, °C
MAS13363,Redundant intermediate circuit voltage power electronics,370.28, V
MAS13431,Low-voltage fuse: current,0.895, A
MAS13432,Low-voltage fuse: voltage,13.055, V
MAS13802,Rotor position sensor 2: cosine amplitude,2.666, V
MAS13803,Rotor position sensor 2: sine amplitude,2.670, V
MAS13804,Rotor position sensor 2: exciter amplitude,8.924, V
ENG105721,Current_DC_Link_power,0, W
ENG105722,Current_in_d-direction,-0.19, A
ENG105723,Current_in_q-direction,0.31, A
ENG105770,DCDC_derating_due_to_overtemperature,0,
ENG105797,Desired_current_in_d-direction,0.00, A
ENG105798,Desired_current_in_q-direction,0.06, A
ENG105799,Desired_torque,0.00, Nm
ENG106053,Effective_value_stator_current,0.75, A
ENG106109,Electric_drive_cooling_activated,option_not_available,
ENG106109-ENG14693,Electric_drive_cooling_activated-Test_Program_Rbe Asw Cif Enum rbe Asw Cif Sttr Coolt Circ UBYTE,3,
ENG106482,Failure_emergency_shut_off,0,
ENG106483,Failure_free_wheeling,0,
ENG106484,Failure_inverter_limited_performance,0,
ENG106485,Failure_inverter_shut_off,0,
ENG106555,Fieldweakening_active,0,
ENG13207,HV-circuit_operation_mode,rbe_CddHvMcu_NormMod_e,
ENG13207-ENG14703,HV-circuit_operation_mode-Test_Program_Rbe Cdd Hv Mcu Enum rbe Cdd Hv Mcu St Mod UBYTE,0,
ENG13208,IGBT_temperature_characteristic_curve_state,1,
ENG13209,Internal_sum_error_itemization,0,
ENG13205,Internal_supply_voltage_15_inverter_IGBT,15.227, V
ENG107077,Inverter_state,0,
ENG26312,ISC t Dbc Invr Snsr Max,42.30, °C
ENG107397,Load_moment_auxiliaries,-5.13, Nm
ENG107584,Maximal_DC-Link_voltage,400.00, V
ENG107585,Maximal_torque_hybrid_controller,2047.94, Nm
ENG107589,Maximum_power_limit,95008, W
ENG107590,Maximum_torque_derating_reason,inactive,
ENG107590-ENG14692,Maximum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG26321,MCT Temp Rtr,36.84, °C
ENG107604,Mechanical_angular_speed,0.00, rad/s
ENG107623,Minimal_torque_hybrid_controller,-2047.94, Nm
ENG107624,Minimum_DC-Link_voltage,250.00, V
ENG107625,Minimum_power_limit,-95008, W
ENG107626,Minimum_torque_derating_reason,inactive,
ENG107626-ENG14692,Minimum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG107742,Necessary_generator_torque,0.06, Nm
ENG13206,Operation_mode_DCDC_actual_state,rbe_AswDcdc_Buck_e,
ENG13206-ENG14702,Operation_mode_DCDC_actual_state-Test_Program_Rbe Com Dcdc Can Enum rbe Cmn Glb Dcdc Oper Mod UBYTE,1,
ENG13204,Periodic_time_gate_driver,111.10, µs
ENG26341,Rbe Asw Invr Isc t Lnk Cap,46.38, °C
ENG26343,Rec rbe Com Drv Can 10ms t Oil Gbx Smp,38, °C
ENG109097,Stator_frequency,0.0, Hz
ENG99035,Voltage terminal 30,13.100, V
Elapsed Time: 00:10
ADP
;Thursday,02,August,2018,08:15:54:50490
Elapsed Time: 00:00
henbo
C?ID=318655
52 Door Elect, Pass.
Block
;SW:5Q0-959-592-E   HW:5Q0-959-592-B ---  Door Elect, Pass.
;Component:TSG BFS       020 0041, Coding:001017205E00040000001003
;EV_DCUPasseSideEWMAXKLO,006003,EV_DCUPasseSideEWMAXCONT.rod
;Thursday,02,August,2018,08:16:07:50490
;VCID: 42C89558D54AEB5471-8016
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,13.1, V
IDE02266,Passenger side rear power window button,not activated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,13.1, V
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,47, %
IDE04539-MAS02229,Mirror memory-Y coordinate,44, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.0, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.0, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,215, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,not activated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,A305,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.5, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.5, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.5, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.5, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.5, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,22, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,205, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.0, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.5, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.5, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.5, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.5, %
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
ENG117314-ENG99000,control_event_memory_passenger_side_rear-Value,24 02 11 9D 00 8B 78 70 9F 12 18 FC 29 04 42 B9 02 8B 78 70 9F 12 83 FC 08 02 42 B8 02 A2 78 80 9E 12 53 0C 25,
ENG117296-MAS00966,Passenger_Rear_VW_FAZIT_Identification_String-Manufacture location index,KUO-KUO,
ENG117296-MAS00968,Passenger_Rear_VW_FAZIT_Identification_String-Day of manufacture,06.01.17,
ENG117296-MAS00969,Passenger_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number,0000,
ENG117296-MAS00970,Passenger_Rear_VW_FAZIT_Identification_String-Running manufacturer number,0000,
ENG117310,Window_Regulator_Passenger_Side_Rear_Sleep_Indication,not active,
ENG117316-ENG99000,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-Value,J927 ,
Elapsed Time: 00:07
ADP
;Thursday,02,August,2018,08:16:14:50490
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
ENG117308-Patch_Code_Passenger_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 03 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 0A 00 0A 03 84 27 10 53 6D 03 00 10 80 0C 01 FF DF FF 00 00 00 0A 00 00 00 00 2D B9 ,128
ENG117307-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2,03 84 02 58 14 EC FF 02 02 0A 02 01 00 0A 05 1E 02 14 19 0B 00 05 F6 32 1E 0E 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 29 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 47 02 19 08 14 10 64 EC D8 FB F6 1E 14 32 05 0C 00 01 5E 02 19 0C 16 12 64 D8 C4 F6 F1 28 1E 32 0A 0C 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 A5 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 78 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 41 33 30 35 01 00 00 00 00 00 00 00 00 00 6C BA ,88
Elapsed Time: 00:07
henbo
C?ID=318655
55 Headlight Range
Block
;SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range
;Component:MxB-ECU       001 0230, Coding:0E5A00102B200200
;EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
;Thursday,02,August,2018,08:16:34:50490
;VCID: 3E30E1A8A1B28FB415-806A
Group,Description,Actual
IDE00018,Voltage terminal 15,13.010, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.0, km/h
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00326,Steering wheel angle,-14.9, °
IDE01232,Supply voltage for external components,8.536, V
IDE01714,Status reverse gear,OFF,
IDE01943,Turn signal,not activated,
IDE01946,ESP intervention,not active,
IDE01992-ENG118424,Installation list: current installations-Gateway_Component_List_Present_Node_0x54,installed,
IDE01992-ENG118425,Installation list: current installations-Gateway_Component_List_Present_Node_0x82,installed,
IDE01992-ENG118426,Installation list: current installations-Gateway_Component_List_Present_Node_0x83,installed,
IDE01992-ENG118427,Installation list: current installations-Gateway_Component_List_Present_Node_0x96,installed,
IDE01992-ENG118428,Installation list: current installations-Gateway_Component_List_Present_Node_0x97,installed,
IDE01993-ENG06597,Control module reference number-Gateway_component_list_allocation_node_0x54,Headlight Regulation,
IDE01993-ENG06598,Control module reference number-Gateway_component_list_allocation_node_0x82,Light Control Left,
IDE01993-ENG06599,Control module reference number-Gateway_component_list_allocation_node_0x83,Light Control Right,
IDE01993-ENG06600,Control module reference number-Gateway_component_list_allocation_node_0x96,Light Control Left 2,
IDE01993-ENG06601,Control module reference number-Gateway_component_list_allocation_node_0x97,Light Control Right 2,
IDE02384-ENG118429,Status of event memory-Gateway_Component_List_dtc_Node_0x54,OK,
IDE02384-ENG118430,Status of event memory-Gateway_Component_List_dtc_Node_0x82,OK,
IDE02384-ENG118431,Status of event memory-Gateway_Component_List_dtc_Node_0x83,OK,
IDE02384-ENG118432,Status of event memory-Gateway_Component_List_dtc_Node_0x96,OK,
IDE02384-ENG118433,Status of event memory-Gateway_Component_List_dtc_Node_0x97,OK,
IDE02389,Ambient brightness,36, lx
IDE02486,Data logger triggering,not active,
IDE02515,Low beam,On,
IDE02743,High Beam,OFF,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,active,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,active,
IDE03150-SFT00085,Readiness for bus sleep mode-Headlight Regulation,active,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,50.27, %
IDE03616,Motor status,OFF,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-9.1, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03630,Left headlight beam adjusting motor: specified value,0.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,0.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),0.00, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),51.94, %
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00085,Bus identification-Headlight Regulation,Busmaster,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,00,
IDE04805-MAS01448,Driving profile selection-Specified value,00,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,No,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE08447,Driving axis angle,NO VALUE AVAILABLE,
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,both sides,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS06932,Actual angle of ref. segments-Horizontal angle reference segment left,NO VALUE AVAILABLE,
IDE08706-MAS06933,Actual angle of ref. segments-Horizontal angle reference segment right,NO VALUE AVAILABLE,
IDE08706-MAS06934,Actual angle of ref. segments-Vertical angle reference segment left,NO VALUE AVAILABLE,
IDE08706-MAS06935,Actual angle of ref. segments-Vertical angle reference segment right,NO VALUE AVAILABLE,
IDE08713-MAS06936,Matrix light: calculated offset values-Horizontal offset: light left,NO VALUE AVAILABLE,
IDE08713-MAS06937,Matrix light: calculated offset values-Horizontal offset: light right,NO VALUE AVAILABLE,
IDE08713-MAS06938,Matrix light: calculated offset values-Vertical offset: light left,NO VALUE AVAILABLE,
IDE08713-MAS06939,Matrix light: calculated offset values-Vertical offset: light right,NO VALUE AVAILABLE,
IDE08714-MAS06929,Axle offsets-Axle offset front,NO VALUE AVAILABLE,
IDE08714-MAS06930,Axle offsets-Axle offset rear,NO VALUE AVAILABLE,
IDE08715,Func. status matrix high beam,not active,
IDE80001,Analysis 1,00 37 83 31 12 00 02 17 00 20 17 79 FF FF FF FF FF FF FF FF FF FF FF FF,
ENG101323,Headlight leveling control state,static,
ENG103737,Left headlight leveling control value,1024.0, mm
ENG124613,Predictive_Route_Data_Intown_Flag,not_available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,not_available,
ENG124612,Predictive_Route_Data_Placename_Sign,not_available,
ENG124611,Predictive_Route_Data_Speed_Limit,Unknown,
ENG124609,Predictive_Route_Data_Street_Class,not_available,
ENG102296,Right headlight leveling control value,1024.0, mm
Elapsed Time: 00:06
ADP
;Thursday,02,August,2018,08:16:41:50490
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE08418-Matrix light: total dimming,100.8 ,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG100660-PWM to Level Scaling Factor Front,3.30 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,5.30 mm/%,2
ENG124607-Reference_Run_Activation_Effect,Activation effect enabled by motor start ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:05
henbo
C?ID=318655
5F Information Electr.
Block
;SW:81A-035-842-A   HW:81A-035-842-A ---  Information Electr.
;Component:MU-S-D-ER     710 0771, Coding:01739300FF00000011111101000A02002F0027440170010002
;EV_MUStd6C3DELP,001013,EV_MUStd6C3DELP_AU37.rod
;Thursday,02,August,2018,08:17:04:50490
;VCID: 210A3AD4300CD04C08-8074
IDE00019,Voltage terminal 30,13.1, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00075,Vehicle speed,0.00, km/h
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.90, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,1, counts
IDE00916-IDE02127,Speaker status-Left front speaker,OK,
IDE00916-IDE02128,Speaker status-Right front speaker,OK,
IDE00916-IDE02129,Speaker status-Left rear speaker,OK,
IDE00916-IDE02130,Speaker status-Right rear speaker,OK,
IDE00916-MAS01198,Speaker status-Center speaker,Measured value not available,
IDE00916-MAS01201,Speaker status-Subwoofer speaker,Measured value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,75, dBµV
IDE01700-MAS01765,Status of tuner for digital radio (DAB)-Audio Signal,Available,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not activated,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,208064, kHz
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,MPEG_4_HE_AAC_v2,
IDE01700-ENG117350,Status of tuner for digital radio (DAB)-Audio_Mode,01,
IDE01700-ENG117354,Status of tuner for digital radio (DAB)-Audio_Quality,99,
IDE01700-ENG117330,Status of tuner for digital radio (DAB)-availability_traffic_data_TMC,Not available,
IDE01700-ENG117329,Status of tuner for digital radio (DAB)-availability_traffic_data_TP,Available,
IDE01700-ENG117348,Status of tuner for digital radio (DAB)-Bit_Rate,112, kbps
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG117327,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_FIC,0.000970,
IDE01700-ENG117326,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_MSC,0.000000,
IDE01700-ENG117328,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_NET,0.000000,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 D3 A3,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,0000            ,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,F0 00,
IDE01700-ENG117331,Status of tuner for digital radio (DAB)-Ensemble_ID,00 00 10 EA,
IDE01700-ENG117332,Status of tuner for digital radio (DAB)-Ensemble_Label,00000000        ,
IDE01700-ENG117333,Status of tuner for digital radio (DAB)-Ensemble_Label_Mask,FF 00,
IDE01700-ENG117334,Status of tuner for digital radio (DAB)-Extended_Country_Code,E0,
IDE01700-ENG117342,Status of tuner for digital radio (DAB)-Label_Masks,F0 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,00 00 D3 A3,
IDE01700-ENG117351,Status of tuner for digital radio (DAB)-Protection_Level,3_A_equal_protection_level,
IDE01700-ENG117349,Status of tuner for digital radio (DAB)-Sample_Rate,48, kHz
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,00,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,0000            ,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,F0 00,
IDE01700-ENG117325,Status of tuner for digital radio (DAB)-signal_quality,99,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,04,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01700-ENG117353,Status of tuner for digital radio (DAB)-SYNC/OFDM_Lock,activated,
IDE01700-ENG117352,Status of tuner for digital radio (DAB)-Transmission_Mode,1,
IDE01715,Status terminal S,On,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,66, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,59, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,49, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,21, dBµV
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,53, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,Electrical OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,Electrical OK,
IDE01771-ENG117327,Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC,0.001290,
IDE01771-ENG117326,Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC,0.000000,
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,16776960,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,FF,
IDE03880-MAS03425,MOST address-Physical address,FF FF,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,27, min
IDE04317-MAS00108,Total system run time-Day,40, d
IDE04317-MAS00109,Total system run time-Hours,13, H
IDE04317-MAS00110,Total system run time-Minutes,37, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 05 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,DF 1A 06 8B 5D 39 B5 14 47 9A 55 23 D7 47 F2 22 A5 9D DD 0D 63 39 6A B4 B0 02 AB 52 F8 BA 91 5B 3A DA D7 0C 45 0F D8 33 14 37 23 65 11 79 28 61 81 B7 30 86 91 B6 E8 0F E5 90 49 0A 7A 79 0F 27 DC B4 CE 6B 91 70 83 C7 5A 57 93 1A 72 A7 D1 96 04 53 E7 29 77 DD 67 31 56 7D 18 DD C4 1E 7D 26 5A 0D 6D 37 72 E5 A9 04 B3 51 8B DF 29 76 B7 B4 E8 1E E6 02 1E 2F 99 16 A6 18 81 D2 5F 92 C7 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04547,Traffic information,On,
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.4, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 2,
IDE04649-MAS06857,Activation for housing fan-Speed,4140, /min
IDE04748,Microphone override meter,0,
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,Mute,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,00 00 00 00 00 00,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05432-IDE07365,Mechanics of display unit 1 for multimedia system-Limit switch for display open,operated,
IDE05432-IDE07366,Mechanics of display unit 1 for multimedia system-Limit switch for display close,not activated,
IDE05432-MAS01458,Mechanics of display unit 1 for multimedia system-Operating condition,Open,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,ŸzœûA0000000------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,00 00 00 00 00 00,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,ŸzœûA0000000------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),CC 9F,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),CC 9F,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,ŸzœûA0000000------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,0000000
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,CC 9F,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,CC 9F,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,CC 9F,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,CC 9F,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,CC 9F,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,CC 9F,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,CC 9F,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,CC 9F,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,CC 9F,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,CC 9F,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,CC 9F,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,CC 9F,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,CC 9F,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,CC 9F,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,CC 9F,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,CC 9F,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,CC 9F,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,65280,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,65280,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,65280,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,65280,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,65280,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Terminal 58xs dimmer,100, %
IDE05726,Terminal 58xd dimmer,60.44, %
IDE05814,Individualization characteristic,23 AB B0 9A 90,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06425,Roller test bench mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE10478-MAS01632,Interface for external media: status-Status,Measured value not available,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,300,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,2,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,6,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,30904, km
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,633, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,53, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,13.1, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,68, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,26, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,33, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,98.4, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,68, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,31, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,16, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03121,Ring break diagnostic line status,Not available,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,1129000000000000,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,99, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,18, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,8, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,2, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,7, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,41, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,18, s
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,61, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,-8, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,40, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,56, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,-12, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,34, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,57, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,-8, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,36, °C
Elapsed Time: 00:50
ADP
;Thursday,02,August,2018,08:17:55:50490
IDE00346-Summertime-automatic,Europe ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,18150 Hz,49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,31 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,18150 Hz,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,21 ,49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,18150 Hz,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,21 ,49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,18150 Hz,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,31 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
IDE02502-Confirmation of installation change,36 2D ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,OFF ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,0 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),5 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),5 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),5 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,0 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,0 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,0 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,0 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,6 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,0 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,0 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,0 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,0 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,0 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,0 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,0 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,0 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,0 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,0 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,5 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,0 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,0 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,0 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,0 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,0 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,0 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,0 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,0 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,5 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,0 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE11122-Country identification: country of sale HMI,-- ,2
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Terminal 15 ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,not activated ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Terminal 15 ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15 ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,4 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,9 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,30 %,12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,00 ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,00 ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,00 ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,00 ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,00 ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,00 ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,00 ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,00 ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,00 ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,00 ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,00 ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,00 ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,00 ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,00 ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,00 ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,00 ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,00 ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,00 ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,00 ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,00 ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,00 ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,00 ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,00 ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,00 ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,00 ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,00 ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,00 ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,00 ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,00 ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,00 ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,00 ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,00 ,32
ENG117808-p_HMI_Display,10 %,1
Elapsed Time: 00:38
