Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: 2017 Audi A3 1.4 TFSI E-TRON CUKB (Germany)
  1. #21
    Aug 2018
    75 Telematics
    Has not been doing what it should for a couple of days (reporting to Audi Connect). However, I doubt it's the car's fault.
    Block
    ;SW:5QE-035-284-C   HW:5QE-035-284-C ---  Telematics
    ;Component:OCULowMQBEU   012 0717, Coding:0173930110969A0100F800000000
    ;EV_OCULowMQB,001006,EV_OCULowMQB.rod
    ;Thursday,02,August,2018,08:18:46:50490
    ;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    ;VCID: 44C49340CF5EE56443-8010
    Group,Description,Actual
    IDE00019,Voltage terminal 30,13.0, V
    IDE00020,Terminal 15 status,On,
    IDE00102,Control Module temperature,51, °C
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00608,Type of fuel,Petrol,
    IDE00667,Microphone status,Not available,
    IDE00668,Microphone current consumption,0.0, mA
    IDE00672,Roadside Assistance Button,Not available,
    IDE00673,Information Service Button,Not available,
    IDE00767,No. of unscheduled ECU resets,4,
    IDE01215,Terminal 58d dimmer,Measured value not available,
    IDE01625,Muting of radio/radio navigation system via control wire,Measured value not available,
    IDE01712-IDE06673,GPS Position-Initialization status,initialized,
    IDE01712-MAS01779,GPS Position-Length,E8°28'00.000",
    IDE01712-MAS01780,GPS Position-Width,N48°55'00.000",
    IDE01712-MAS02230,GPS Position-Height,500, m
    IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
    IDE01713-MAS01785,Status GPS reception-Number of visible satellites,11,
    IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,7,
    IDE01715,Status terminal S,On,
    IDE01770-MAS01632,Status of GPS antenna-Status,OK,
    IDE01770-MAS01808,Status of GPS antenna-Antenna current,23, mA
    IDE01971,Lowest recorded control module temperature,-8, °C
    IDE01972,Highest recorded control module temperature,74, °C
    IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
    IDE02067-MAS01808,Antenna for telephone status-Antenna current,1, mA
    IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100.0, %
    IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,31,
    IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,14,
    IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,29,
    IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,32,
    IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,50, dBµV
    IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,49, dBµV
    IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,43, dBµV
    IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,38, dBµV
    IDE02486,Data logger triggering,Measured value not available,
    IDE03348-MAS01586,Speed warning-Alarm,0,
    IDE03348,Speed warning,655.33, km/h
    IDE03348-MAS08775,Speed warning-Calculation frequency,5, s
    IDE03348-MAS08776,Speed warning-tolerance,5, m
    IDE03348-MAS08777,Speed warning-Contact bounce suppression,5, s
    IDE03477-MAS00106,GPS time-Year,2000,
    IDE03477-MAS00107,GPS time-Month,1,
    IDE03477-MAS00108,GPS time-Day,2,
    IDE03477-MAS00109,GPS time-Hours,0,
    IDE03477-MAS00110,GPS time-Minutes,1,
    IDE03477-MAS00111,GPS time-Seconds,34,
    IDE03477-MAS01632,GPS time-Status,valid,
    IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Available,
    IDE04605-MAS01779,Navigation: Corrected position-Length,E8°28'00.000",
    IDE04605-MAS01780,Navigation: Corrected position-Width,N48°55'00.000",
    IDE04605-ENG123297,Navigation: Corrected position-error_value,30, m
    IDE04750-MAS03876,SIM cards-active SIM card,internal,
    IDE04750-MAS03877,SIM cards-SIM ID,89011700000000000000,
    IDE04750-MAS03878,SIM cards-SIM IMSI,310100000000000,
    IDE04750-MAS04226,SIM cards-Telephone number,                              ,
    IDE04750-MAS08401,SIM cards-SIM intern,Available,
    IDE04750-MAS08402,SIM cards-SIM extern,Not available,
    IDE04790,Call for help button,Not available,
    IDE05430,Telephone serial number,359800000000000,
    IDE06644,Vehicle positioning system,Measured value not available,
    IDE07007-IDE00983,A/C heater function via remote control-Interior temperature,25, °C
    IDE07007-IDE04927,A/C heater function via remote control-Window heater,On,
    IDE07007-MAS01118,A/C heater function via remote control-Climate control,OFF,
    IDE07007-MAS02289,A/C heater function via remote control-Outside air temperature,18, °C
    IDE07007-MAS05945,A/C heater function via remote control-Specified temperature,22.3, °C
    IDE07007-MAS08947,A/C heater function via remote control-After-run time for power supply,30, min
    IDE07007-MAS08948,A/C heater function via remote control-After-run time for battery,15, min
    IDE07007-MAS08949,A/C heater function via remote control-Climate control without power supply,On,
    IDE07007-MAS08957,A/C heater function via remote control-A/C window heater,On,
    IDE07007-MAS08958,A/C heater function via remote control-reason for last climate control,Measured value not available,
    IDE07543,Vehicle speed,0.00, km/h
    IDE07940-IDE07007,Status of enabling for online services-A/C heater function via remote control,activated,
    IDE07940-IDE07909,Status of enabling for online services-Remote control for vehicle locking,not activated,
    IDE07940,Status of enabling for online services,activated,
    IDE07940-IDE07974,Status of enabling for online services-Transmission of navigation targets,not activated,
    IDE07940-IDE07975,Status of enabling for online services-Remote control for charge function of H-V battery,activated,
    IDE07940-IDE07976,Status of enabling for online services-Info call,not activated,
    IDE07940-IDE08155,Status of enabling for online services-Vehicle state report,not activated,
    IDE07940-IDE08158,Status of enabling for online services-Roadside assistance / schedule agreement for service,not activated,
    IDE07940-MAS08370,Status of enabling for online services-Position monitoring (Geofencing),not activated,
    IDE07940-MAS08371,Status of enabling for online services-Remote control for speed warning,not activated,
    IDE07940-MAS08372,Status of enabling for online services-Remote control for vehicle shutdown,not activated,
    IDE07940-MAS08373,Status of enabling for online services-Remote control for vehicle location,not activated,
    IDE07940-MAS08374,Status of enabling for online services-Remote control for lights and horn,not activated,
    IDE07940-MAS08375,Status of enabling for online services-Distance statistics display,activated,
    IDE07940-MAS08376,Status of enabling for online services-Display vehicle state,activated,
    IDE07940-MAS08377,Status of enabling for online services-Remote control for departure time programming,activated,
    IDE07940-MAS08448,Status of enabling for online services-Manual roadside assistance,not activated,
    IDE07940-MAS08449,Status of enabling for online services-Automatic roadside assistance,not activated,
    IDE07975-IDE00704,Remote control for charge function of H-V battery-Charge level,active,
    IDE07975-IDE01839,Remote control for charge function of H-V battery-Battery charge condition,48, %
    IDE07975-IDE05431,Remote control for charge function of H-V battery-Locking for H-V charge plug,locked,
    IDE07975-IDE06986,Remote control for charge function of H-V battery-H-V battery charge current: maximum value,32, A
    IDE07975-MAS01002,Remote control for charge function of H-V battery-Remaining operating range,16, km
    IDE07975-MAS01118,Remote control for charge function of H-V battery-Climate control,Measured value not available,
    IDE07975-MAS05682,Remote control for charge function of H-V battery-External Charging,Available,
    IDE07975-MAS08781,Remote control for charge function of H-V battery-Connection state of charging plug,connected,
    IDE07975-MAS08782,Remote control for charge function of H-V battery-Remaining charge time,75, min
    IDE07975-MAS08783,Remote control for charge function of H-V battery-Reason for last battery charge,Measured value not available,
    IDE07975-MAS08784,Remote control for charge function of H-V battery-Charging current type,AC,
    IDE08077-MAS01240,Timer 1 for programming of departure time-Programming status,not programmed,
    IDE08077-MAS01635,Timer 1 for programming of departure time-Monday,not programmed,
    IDE08077-MAS01636,Timer 1 for programming of departure time-Tuesday,not programmed,
    IDE08077-MAS01637,Timer 1 for programming of departure time-Wednesday,not programmed,
    IDE08077-MAS01638,Timer 1 for programming of departure time-Thursday,not programmed,
    IDE08077-MAS01639,Timer 1 for programming of departure time-Friday,not programmed,
    IDE08077-MAS01640,Timer 1 for programming of departure time-Saturday,not programmed,
    IDE08077-MAS01641,Timer 1 for programming of departure time-Sunday,not programmed,
    IDE08077-MAS08963,Timer 1 for programming of departure time-Condition of timer,active,
    IDE08077-ENG123310,Timer 1 for programming of departure time-Timer_Mode,HV charging,
    IDE08077-ENG123309,Timer 1 for programming of departure time-Timer_Type,one time,
    IDE08078-MAS01240,Timer 2 for programming of departure time-Programming status,Measured value not available,
    IDE08078-MAS01635,Timer 2 for programming of departure time-Monday,not programmed,
    IDE08078-MAS01636,Timer 2 for programming of departure time-Tuesday,not programmed,
    IDE08078-MAS01637,Timer 2 for programming of departure time-Wednesday,not programmed,
    IDE08078-MAS01638,Timer 2 for programming of departure time-Thursday,not programmed,
    IDE08078-MAS01639,Timer 2 for programming of departure time-Friday,not programmed,
    IDE08078-MAS01640,Timer 2 for programming of departure time-Saturday,not programmed,
    IDE08078-MAS01641,Timer 2 for programming of departure time-Sunday,not programmed,
    IDE08078-MAS08963,Timer 2 for programming of departure time-Condition of timer,Measured value not available,
    IDE08078-ENG123310,Timer 2 for programming of departure time-Timer_Mode,Measured value not available,
    IDE08078-ENG123309,Timer 2 for programming of departure time-Timer_Type,Measured value not available,
    IDE08079-MAS01240,Timer 3 for programming of departure time-Programming status,Measured value not available,
    IDE08079-MAS01635,Timer 3 for programming of departure time-Monday,not programmed,
    IDE08079-MAS01636,Timer 3 for programming of departure time-Tuesday,not programmed,
    IDE08079-MAS01637,Timer 3 for programming of departure time-Wednesday,not programmed,
    IDE08079-MAS01638,Timer 3 for programming of departure time-Thursday,not programmed,
    IDE08079-MAS01639,Timer 3 for programming of departure time-Friday,not programmed,
    IDE08079-MAS01640,Timer 3 for programming of departure time-Saturday,not programmed,
    IDE08079-MAS01641,Timer 3 for programming of departure time-Sunday,not programmed,
    IDE08079-MAS08963,Timer 3 for programming of departure time-Condition of timer,Measured value not available,
    IDE08079-ENG123310,Timer 3 for programming of departure time-Timer_Mode,Measured value not available,
    IDE08079-ENG123309,Timer 3 for programming of departure time-Timer_Type,Measured value not available,
    IDE08159-IDE07007,Status of online services-A/C heater function via remote control,not active,
    IDE08159-IDE07975,Status of online services-Remote control for charge function of H-V battery,active,
    IDE08159-IDE08158,Status of online services-Roadside assistance / schedule agreement for service,not active,
    IDE08159-MAS08370,Status of online services-Position monitoring (Geofencing),not active,
    IDE08159-MAS08371,Status of online services-Remote control for speed warning,not active,
    IDE08159-MAS08372,Status of online services-Remote control for vehicle shutdown,not active,
    IDE08159-MAS08373,Status of online services-Remote control for vehicle location,not active,
    IDE08159-MAS08374,Status of online services-Remote control for lights and horn,not active,
    IDE08159-MAS08377,Status of online services-Remote control for departure time programming,not active,
    IDE08159-MAS08448,Status of online services-Manual roadside assistance,not active,
    IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,00,
    IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,04,
    IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
    IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
    IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
    IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
    IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
    IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
    IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
    IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
    MAS00464-MAS00107,Standard - ambient data 1-Month,1,
    MAS00464-MAS00108,Standard - ambient data 1-Day,2,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,11,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,30904, km
    MAS01490-MAS08403,Energy management-Remaining short term energy budget,970, mAh
    MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
    MAS01490-MAS08405,Energy management-Wake up cycles counter,531,
    MAS04394-IDE03580,Connection status-Country code for mobile network,262,
    MAS04394-IDE07699,Connection status-Mobile network operator,2,
    MAS04394-MAS03991,Connection status-Reception level antenna 1,100.0, %
    MAS04394-MAS04460,Connection status-Validity,valid,
    MAS04394-MAS08406,Connection status-Network type,HSPA,
    MAS04394-MAS08407,Connection status-Data connection,not active,
    MAS04394-MAS08408,Connection status-Number of hours to next event,6,
    MAS04394-MAS08409,Connection status-Number of minutes to next event,11,
    MAS04394-MAS08410,Connection status-Number of seconds to next event,2,
    MAS04394-ENG123307,Connection status-Radio_Cell_Number,197000000,
    MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
    MAS06193-IDE06986,Profile 1-H-V battery charge current: maximum value,0, A
    MAS06193-MAS04721,Profile 1-Minimum charge level,0, %
    MAS06193-MAS04722,Profile 1-Maximum charge level,0, %
    MAS06193-MAS08967,Profile 1-Start high voltage charging:Hour,0,
    MAS06193-MAS08968,Profile 1-Start high voltage charging:Minute,0,
    MAS06193-MAS08969,Profile 1-End of high voltage charging:Hour,0,
    MAS06193-MAS08970,Profile 1-End of high voltage charging:Minute,0,
    MAS06194-IDE06986,Profile 2-H-V battery charge current: maximum value,0, A
    MAS06194-MAS04721,Profile 2-Minimum charge level,0, %
    MAS06194-MAS04722,Profile 2-Maximum charge level,0, %
    MAS06194-MAS08967,Profile 2-Start high voltage charging:Hour,0,
    MAS06194-MAS08968,Profile 2-Start high voltage charging:Minute,0,
    MAS06194-MAS08969,Profile 2-End of high voltage charging:Hour,0,
    MAS06194-MAS08970,Profile 2-End of high voltage charging:Minute,0,
    MAS06195-IDE06986,Profile 3-H-V battery charge current: maximum value,0, A
    MAS06195-MAS04721,Profile 3-Minimum charge level,0, %
    MAS06195-MAS04722,Profile 3-Maximum charge level,0, %
    MAS06195-MAS08967,Profile 3-Start high voltage charging:Hour,0,
    MAS06195-MAS08968,Profile 3-Start high voltage charging:Minute,0,
    MAS06195-MAS08969,Profile 3-End of high voltage charging:Hour,0,
    MAS06195-MAS08970,Profile 3-End of high voltage charging:Minute,0,
    MAS06413,Audio signal output,Not available,
    MAS08178-IDE02493,Crash information-Automatic door unlocking,No,
    MAS08178-IDE05253,Crash information-Front crash,No,
    MAS08178-IDE05254,Crash information-Side crash on driver side,No,
    MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
    MAS08178-IDE05256,Crash information-Rear crash,No,
    MAS08178-IDE05257,Crash information-Rollover crash,No,
    MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
    MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,No,
    MAS08179,List of last telephone numbers,,
    MAS08180,Remote-controlled horn and lights,0, s
    MAS08181-MAS01779,Area restriction configuration-Length,0, m
    MAS08181-MAS01780,Area restriction configuration-Width,0, m
    MAS08181-MAS08775,Area restriction configuration-Calculation frequency,65535, s
    MAS08181-MAS08776,Area restriction configuration-tolerance,65535, m
    MAS08181-MAS08777,Area restriction configuration-Contact bounce suppression,65535, s
    MAS08181-MAS08778,Area restriction configuration-Rotation angle,65535, °
    MAS08181-MAS08779,Area restriction configuration-Zone type,Not available,
    MAS08181-MAS08780,Area restriction configuration-Area type,rectangle,
    MAS08183-IDE02068,Event list: horn and lights (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08183-MAS08552,Event list: horn and lights (ring memory)-Event generated,Unknown,
    MAS08184-IDE02068,Event list: emergency call(ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08184-MAS08552,Event list: emergency call(ring memory)-Event generated,Unknown,
    MAS08185-IDE02068,Event list: vehicle shut-down (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08185-MAS08552,Event list: vehicle shut-down (ring memory)-Event generated,Unknown,
    MAS08186-IDE02068,Event list: vehicle location (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08186-MAS08552,Event list: vehicle location (ring memory)-Event generated,Unknown,
    MAS08187-IDE02068,Event list area restriction (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08187-MAS08552,Event list area restriction (ring memory)-Event generated,Unknown,
    MAS08188-IDE02068,Event list: Mobile Online services (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08188-MAS08552,Event list: Mobile Online services (ring memory)-Event generated,Unknown,
    MAS08189-IDE02068,Event list: speed warning (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08189-MAS08552,Event list: speed warning (ring memory)-Event generated,Unknown,
    MAS08190-IDE02068,Event list: distance statistics (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08190-MAS08552,Event list: distance statistics (ring memory)-Event generated,Unknown,
    MAS08191-IDE02068,Event list: vehicle state (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08191-MAS08552,Event list: vehicle state (ring memory)-Event generated,Unknown,
    MAS08192-IDE02068,Event list: info call (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08192-MAS08552,Event list: info call (ring memory)-Event generated,Unknown,
    MAS08193-IDE02068,Event list: battery charge management (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08193-MAS08552,Event list: battery charge management (ring memory)-Event generated,Unknown,
    MAS08194-IDE02068,Event list: A/C (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08194-MAS08552,Event list: A/C (ring memory)-Event generated,Unknown,
    MAS08195-IDE02068,Event list: departure time (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08195-MAS08552,Event list: departure time (ring memory)-Event generated,Unknown,
    MAS08196-IDE02068,Event list: vehicle status report (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08196-MAS08552,Event list: vehicle status report (ring memory)-Event generated,Unknown,
    MAS08197-IDE02068,Event list:roadside assist and maint. schedule(ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08197-MAS08552,Event list:roadside assist and maint. schedule(ring memory)-Event generated,Unknown,
    MAS08198-IDE02068,Event lists: imported navigation destinations (bring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08198-MAS08552,Event lists: imported navigation destinations (bring memory)-Event generated,Unknown,
    MAS08199-IDE02068,Event list: vehicle locking (ring memory)-Time stamp,00 00 00 00 00 00 00,
    MAS08199-MAS08552,Event list: vehicle locking (ring memory)-Event generated,Unknown,
    ENG123206-ENG123337,Antenna_Switch-GPS_Antenna_Switch,external,
    ENG123206-ENG123336,Antenna_Switch-GSM_Antenna_Switch,external,
    ENG123207-IDE01588,Calculated_Position_And_Direction_Areal_Update-Driving direction,0, °
    ENG123207-MAS01632,Calculated_Position_And_Direction_Areal_Update-Status,Not available,
    ENG123207-MAS01779,Calculated_Position_And_Direction_Areal_Update-Length,,
    ENG123207-MAS01780,Calculated_Position_And_Direction_Areal_Update-Width,,
    ENG123207-ENG123297,Calculated_Position_And_Direction_Areal_Update-error_value,0, m
    ENG02467-ENG02478,Certificate_Hash-Certificate Hash,C0 63 AC 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG123208-MAS00106,Geofencing_schedule_start_time-Year,2000,
    ENG123208-MAS00107,Geofencing_schedule_start_time-Month,0,
    ENG123208-MAS00108,Geofencing_schedule_start_time-Day,0,
    ENG123208-MAS00109,Geofencing_schedule_start_time-Hours,0,
    ENG123208-MAS00110,Geofencing_schedule_start_time-Minutes,0,
    ENG123208-MAS00111,Geofencing_schedule_start_time-Seconds,0,
    ENG123209-MAS00106,Geofencing_schedule_stop_time-Year,2000,
    ENG123209-MAS00107,Geofencing_schedule_stop_time-Month,0,
    ENG123209-MAS00108,Geofencing_schedule_stop_time-Day,0,
    ENG123209-MAS00109,Geofencing_schedule_stop_time-Hours,0,
    ENG123209-MAS00110,Geofencing_schedule_stop_time-Minutes,0,
    ENG123209-MAS00111,Geofencing_schedule_stop_time-Seconds,0,
    ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,9,
    ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,500,
    ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,700,
    ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,initialized,
    ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,300,
    ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,800,
    ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,1000,
    ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,9,
    ENG125913,Hybrid_Type,PlugIn_Hybrid,
    ENG117422,IP_Address,10.00.000.000,
    ENG117869-IDE01588,Nav._Calculated_Direction-Driving direction,26, °
    ENG117869-MAS01632,Nav._Calculated_Direction-Status,Available,
    ENG123203-ENG123321,Network_Statistics-CRC_Errors,0,
    ENG123203-ENG123320,Network_Statistics-DNS_Resolution,11313,
    ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,no error,
    ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,0, min
    ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,24483,
    ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,ERROR,
    ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,0,
    ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,no error,
    ENG123203-ENG123315,Network_Statistics-Number_Of_Events,46546,
    ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,48,
    ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,7767,
    ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,178,
    ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,1914,
    ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,1401,
    ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,423,
    ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,454,
    ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,18775,
    ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,0,
    ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,no error,
    ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,1353,
    ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,1, ms
    ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,no error,
    ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,1546050, B
    ENG123203-ENG123335,Network_Statistics-SMS_Counter,0,
    ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,189434565, B
    ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,ERROR,
    ENG123204,Outgoing_call_line_state,Idle,
    ENG123202,Phone_Register_State,registerstate_roaming,
    ENG129162-ENG98933,Serial_Tracing-Status,not activated,
    ENG123210-MAS00106,Speed_alert_schedule_start_time-Year,2000,
    ENG123210-MAS00107,Speed_alert_schedule_start_time-Month,0,
    ENG123210-MAS00108,Speed_alert_schedule_start_time-Day,0,
    ENG123210-MAS00109,Speed_alert_schedule_start_time-Hours,0,
    ENG123210-MAS00110,Speed_alert_schedule_start_time-Minutes,0,
    ENG123210-MAS00111,Speed_alert_schedule_start_time-Seconds,0,
    ENG123211-MAS00106,Speed_alert_schedule_stop_time-Year,2000,
    ENG123211-MAS00107,Speed_alert_schedule_stop_time-Month,0,
    ENG123211-MAS00108,Speed_alert_schedule_stop_time-Day,0,
    ENG123211-MAS00109,Speed_alert_schedule_stop_time-Hours,0,
    ENG123211-MAS00110,Speed_alert_schedule_stop_time-Minutes,0,
    ENG123211-MAS00111,Speed_alert_schedule_stop_time-Seconds,0,
    ENG123193-ENG123341,Vehicle_Health_Report-Collection_Period,Deactivated,
    ENG123193-ENG123342,Vehicle_Health_Report-Day_at_month_for_report,0,
    ENG123193-ENG123343,Vehicle_Health_Report-Day_at_week_for_report,Not available,
    ENG123193-ENG123339,Vehicle_Health_Report-Distance_Based_Distance,0, km
    ENG123193-ENG123338,Vehicle_Health_Report-Distance_Based_Start_Mileage,0, km
    ENG123193-ENG123340,Vehicle_Health_Report-Maintenance_Based_Distance,0, km
    Elapsed Time: 00:22
    ADP
    ;Thursday,02,August,2018,08:19:08:50490
    IDE00759-Base volume of speech output,0 dB,1
    IDE00761-MAS08397-After-run time-Long term energy budget,3600 mAh,14
    IDE00761-MAS08398-After-run time-Short term energy budget,1000 mAh,14
    IDE00761-MAS08399-After-run time-Waiting period from sleep to standby mode,0 min,14
    IDE00761-MAS08400-After-run time-Waiting period from standby to stop mode,336 H,14
    IDE00761-MAS08950-After-run time-Time period for cyclic stop mode in operating mode,0 min,14
    IDE00761-MAS08951-After-run time-Time period for cyclic standby mode in operating mode,0 min,14
    IDE00761-MAS08952-After-run time-Time period for operating mode,0 d,14
    IDE00761-MAS08953-After-run time-Cyclic time after the operating mode,0 H,14
    IDE00761-MAS08954-After-run time-Connection after T. 15 on,No ,14
    IDE00761-MAS08955-After-run time-Time period for connection after T. 15 on,15 min,14
    IDE00766-Reference channel delay,0 ms,1
    IDE00769-Number 1 for Info call,0 ,1
    IDE00770-Number 1 for roadside assistance,0 ,1
    IDE02067-Antenna for telephone status,automatic ,1
    IDE02330-Number 2 for Info call,0 ,1
    IDE02331-Number 2 for roadside assistance,0 ,1
    IDE02699-Number 1 for roadside assistance,0 ,1
    IDE02700-Number 2 for roadside assistance,0 ,1
    IDE03481-Emergency telephone number,0 ,1
    IDE04307-MAS00688-Vehicle function list BAP-Multifunction indicator,activated ,1
    IDE04307-MAS02957-Vehicle function list BAP-Time,activated ,1
    IDE04307-MAS06654-Vehicle function list BAP-Charge manager,activated ,1
    IDE04478-SMS number 1 for call for help,0 ,1
    IDE07699-Mobile network operator,hrapn.volkswagen.com ,20
    IDE07899-Status of GPS antenna,external ,1
    IDE09244-Fuel tank volume,70 l,1
    IDE11138-Certificate,VzT_EU ,1
    MAS07461-Vehicle shut-down: maximum speed,5 km/h,2
    MAS07464-Waiting period for activation vehicle shutdown,30 s,2
    MAS07465-Safety mode for activation vehicle shutdown,activated ,1
    MAS07466-Safety mode for deactivation vehicle shutdown,not activated ,1
    MAS07467-Speed warning maximum speed,0 km/h,2
    MAS08170-User profile name,none ,4
    MAS08171-User profile password,none ,4
    MAS08172-Mobile Online services: first host name,glcsa01.carit.vwg-connect.com ,29
    MAS08173-Mobile Online services: second host name,glcsa01.carit.vwg-connect.com ,29
    MAS08174-Fallback DNS Server,0.0.0.0 ,7
    MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
    MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,5 km,3
    MAS08176-Test tel. number for roadside assistance,0 ,1
    MAS08177-Acoustic warning for vehicle shut-down,activated ,1
    MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
    MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
    MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
    MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
    MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
    MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
    MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
    MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
    MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
    MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
    MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
    MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
    MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
    MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
    MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
    MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
    MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
    MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
    MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
    MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
    MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
    MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
    MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
    MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
    MAS08983-Dimming coefficient of red function illumination,50 %,1
    MAS08984-Dimming coefficient of green function illumination,50 %,1
    MAS09650-Threshold for vehicle movement recognition,5 km/h,2
    MAS13730-Radio mode,activated ,1
    ENG123201-ENG123295-Cycle_Data_Log_Level-Automatic_Crash_Notification,ERROR ,9
    ENG123201-ENG123362-Cycle_Data_Log_Level-Core_Service_Management,ERROR ,9
    ENG123201-ENG123286-Cycle_Data_Log_Level-Geofencing,ERROR ,9
    ENG123201-ENG123294-Cycle_Data_Log_Level-Information_Call,ERROR ,9
    ENG123201-ENG123186-Cycle_Data_Log_Level-Manual_Emergency_Call,ERROR ,9
    ENG123201-ENG123288-Cycle_Data_Log_Level-POI_Address_Import,ERROR ,9
    ENG123201-ENG123215-Cycle_Data_Log_Level-Remote_Battery_Charging_Management,ERROR ,9
    ENG123201-ENG123293-Cycle_Data_Log_Level-Remote_Departure_Time_Programming,ERROR ,9
    ENG123201-ENG123287-Cycle_Data_Log_Level-Remote_Door_Unlock,ERROR ,9
    ENG123201-ENG123216-Cycle_Data_Log_Level-Remote_Honking_and_Flashing,ERROR ,9
    ENG123201-ENG123214-Cycle_Data_Log_Level-Remote_Pre_Trip_Climatisation,ERROR ,9
    ENG123201-ENG123289-Cycle_Data_Log_Level-Remote_Speed_Alert,ERROR ,9
    ENG123201-ENG123292-Cycle_Data_Log_Level-Remote_Trip_Statistics,ERROR ,9
    ENG123201-ENG123290-Cycle_Data_Log_Level-Remote_Vehicle_Disabling,ERROR ,9
    ENG123201-ENG123183-Cycle_Data_Log_Level-Remote_Vehicle_Status,ERROR ,9
    ENG123201-ENG123291-Cycle_Data_Log_Level-Remote_Vehicle_Tracking,ERROR ,9
    ENG123201-ENG123371-Cycle_Data_Log_Level-Roadside_Assistance_Dealer_Maintenance_Scheduling,ERROR ,9
    ENG123201-ENG123193-Cycle_Data_Log_Level-Vehicle_Health_Report,ERROR ,9
    ENG123200-Driving_Follow_Up_Time,5 min,1
    ENG123199-Emergency_Call_Trigger_Condition,crash_intensity_2 ,1
    ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
    ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
    ENG123190-MAS01424-Geofencing_Area_Highth-max.value,4294967294 m,8
    ENG123190-MAS01425-Geofencing_Area_Highth-min.value,1 m,8
    ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,+2.147.483.647 ,28
    ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2.147.483.648 ,28
    ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,+2.147.483.647 ,28
    ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2.147.483.648 ,28
    ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
    ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
    ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
    ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
    ENG123186-ENG123304-Manual_Emergency_Call-Radio_On_Trigger,On ,1
    ENG123186-ENG123305-Manual_Emergency_Call-Vehicle_Termination,On ,1
    ENG125481-Number_Of_Navigation_Destinations,20 ,1
    ENG123194-ENG123349-Online_Services_Communication_Protocol-APN_Auth_Type,PAP_CHAP ,10
    ENG123194-ENG123350-Online_Services_Communication_Protocol-GSM_Automatic_Operator,manual ,10
    ENG123194-ENG123354-Online_Services_Communication_Protocol-Keep_Connection_Alive_If_Event_Expected_Within,10 min,10
    ENG123194-ENG123356-Online_Services_Communication_Protocol-PDP_Grace_Time,120 s,10
    ENG123194-ENG123351-Online_Services_Communication_Protocol-PDP_Type,IPv4 ,10
    ENG123194-ENG123352-Online_Services_Communication_Protocol-TCP_Max_Receive_Window,65535 B,10
    ENG123194-ENG123353-Online_Services_Communication_Protocol-TCP_Max_Transmit_Window,65535 B,10
    ENG123194-ENG123355-Online_Services_Communication_Protocol-TCPMS,532 B,10
    ENG123196-ENG123362-Online_Services_Data_Roaming-Core_Service_Management,activated ,3
    ENG123196-ENG125484-Online_Services_Data_Roaming-Core_Service_Telephony,activated ,3
    ENG123196-ENG123286-Online_Services_Data_Roaming-Geofencing,not activated ,3
    ENG123196-ENG125485-Online_Services_Data_Roaming-JobMechanism,activated ,3
    ENG123196-ENG123288-Online_Services_Data_Roaming-POI_Address_Import,not activated ,3
    ENG123196-ENG123215-Online_Services_Data_Roaming-Remote_Battery_Charging_Management,activated ,3
    ENG123196-ENG123293-Online_Services_Data_Roaming-Remote_Departure_Time_Programming,activated ,3
    ENG123196-ENG123287-Online_Services_Data_Roaming-Remote_Door_Unlock,not activated ,3
    ENG123196-ENG123216-Online_Services_Data_Roaming-Remote_Honking_and_Flashing,not activated ,3
    ENG123196-ENG123214-Online_Services_Data_Roaming-Remote_Pre_Trip_Climatisation,activated ,3
    ENG123196-ENG123289-Online_Services_Data_Roaming-Remote_Speed_Alert,not activated ,3
    ENG123196-ENG123292-Online_Services_Data_Roaming-Remote_Trip_Statistics,activated ,3
    ENG123196-ENG123290-Online_Services_Data_Roaming-Remote_Vehicle_Disabling,not activated ,3
    ENG123196-ENG123183-Online_Services_Data_Roaming-Remote_Vehicle_Status,activated ,3
    ENG123196-ENG123291-Online_Services_Data_Roaming-Remote_Vehicle_Tracking,not activated ,3
    ENG123196-ENG123363-Online_Services_Data_Roaming-Roadside_Assistance,not activated ,3
    ENG123196-ENG123193-Online_Services_Data_Roaming-Vehicle_Health_Report,not activated ,3
    ENG123195-ENG123358-Online_Services_Timeouts-HTTP_Timeout,125 s,9
    ENG123195-ENG123361-Online_Services_Timeouts-Network_Timeout,120 s,9
    ENG123195-ENG123360-Online_Services_Timeouts-PDP_Timeout,120 s,9
    ENG123195-ENG123359-Online_Services_Timeouts-Secure_Connection_Timeout,120 s,9
    ENG123195-ENG123357-Online_Services_Timeouts-Transport_Protocol_Timeout,120 s,9
    ENG123197-Online_Services_Voice_Roaming,not activated ,1
    ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
    ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Driving direction,30 °,12
    ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
    ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
    ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
    ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
    ENG123183-ENG123302-Remote_Vehicle_Status-Remote_Vehicle_Status_Clamp_15_Off_Delay,60 s,2
    ENG123183-ENG123301-Remote_Vehicle_Status-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,2
    ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
    ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
    ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
    ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
    ENG123184-Roof_Crash_Detection_Speed_Limit,30 km/h,1
    ENG129162-Serial_Tracing, ,6
    ENG123193-Vehicle_Health_Report,15000 km,1
    ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,10 s,6
    ENG123198-ENG123368-Voice_Connection_Timeouts-Redial_ACN_MEC_If_Failed,Yes ,6
    ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,6 ,6
    ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
    ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,15 s,6
    ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
    Elapsed Time: 00:21
  2. #22
    Aug 2018
    8C Hybrid Battery
    Although with VCDS Mobile, this doesn't show up as installed, I can connect and query it just fine, without ROD/ASAM issues or the HN hanging or locking.
    Block
    ;SW:5Q0-915-182-D   HW:5Q0-915-182-C ---  Hybrid Battery
    ;Component:BECM          H05 0911, Coding:00000000
    ;EV_BECM09620115Q0915182,006040,EV_BECM06020115C6915182_VW37.rod
    ;Thursday,02,August,2018,08:19:43:50490
    ;VCID: 3424C3809FFE55E4F3-8060
    IDE00010,Serial number,U6000000,
    IDE00019,Voltage terminal 30,13.00, V
    IDE00030,Status of actuator test,not active,
    IDE00056-ENG36045,History data 1-HVBHDM_1_4,00 00 00 00,
    IDE00056-ENG125711,History data 1-HVBHDM01_1,6,
    IDE00056-ENG125712,History data 1-HVBHDM01_2,8,
    IDE00056-ENG125713,History data 1-HVBHDM01_3,48,
    IDE00057-ENG36046,History data 2-HVBHDM_2_4,00 00 00 00,
    IDE00057-ENG125714,History data 2-HVBHDM02_1,8,
    IDE00057-ENG125715,History data 2-HVBHDM02_2,8,
    IDE00057-ENG125716,History data 2-HVBHDM02_3,64,
    IDE00058-ENG36047,History data 3-HVBHDM_3_4,00 00 00 00,
    IDE00058-ENG125717,History data 3-HVBHDM03_1,8,
    IDE00058-ENG125718,History data 3-HVBHDM03_2,8,
    IDE00058-ENG125719,History data 3-HVBHDM03_3,64,
    IDE00059-ENG36048,History data 4-HVBHDM_4_4,00 00 00 00,
    IDE00059-ENG125720,History data 4-HVBHDM04_1,8,
    IDE00059-ENG125721,History data 4-HVBHDM04_2,8,
    IDE00059-ENG125722,History data 4-HVBHDM04_3,64,
    IDE00060-ENG36049,History data 5-HVBHDM_5_2,00 00 00 00,
    IDE00060-ENG125723,History data 5-HVBHDM05_3,6,
    IDE00061-ENG36050,History data 6-HVBHDM_6_4,00 01 91 98,
    IDE00061-ENG125724,History data 6-HVBHDM06_1,10,
    IDE00061-ENG125725,History data 6-HVBHDM06_2,2,
    IDE00061-ENG125726,History data 6-HVBHDM06_3,20,
    IDE00062-ENG36051,History data 7-HVBHDM_7_4,00 00,
    IDE00062-ENG125727,History data 7-HVBHDM07_1,6,
    IDE00062-ENG125728,History data 7-HVBHDM07_2,6,
    IDE00062-ENG125729,History data 7-HVBHDM07_3,21,
    IDE00063-ENG36052,History data 8-HVBHDM_8_4,00 00,
    IDE00063-ENG125730,History data 8-HVBHDM08_1,6,
    IDE00063-ENG125731,History data 8-HVBHDM08_2,6,
    IDE00063-ENG125732,History data 8-HVBHDM08_3,21,
    IDE00064-ENG36053,History data 9-HVBHDM_9_2,00 0E 0A 24,
    IDE00064-ENG128710,History data 9-HVBHDM09_1,96,
    IDE00065-ENG36054,History data 10-HVBHDM_10_2,00 00 1A 79,
    IDE00065-ENG128711,History data 10-HVBHDM10_1,10,
    IDE00066-ENG36055,History data 11-HVBHDM_11_4,00 00,
    IDE00066-ENG125733,History data 11-HVBHDM11_1,8,
    IDE00066-ENG125734,History data 11-HVBHDM11_2,2,
    IDE00066-ENG125735,History data 11-HVBHDM11_3,16,
    IDE00067-ENG36056,History data 12-HVBHDM_12_4,00 00,
    IDE00067-ENG125736,History data 12-HVBHDM12_1,08,
    IDE00067-ENG125737,History data 12-HVBHDM12_2,02,
    IDE00067-ENG125738,History data 12-HVBHDM12_3,10,
    IDE00068-ENG36044,History data 13-HVBHDM_13_2,00 00 06 79,
    IDE00068-ENG128712,History data 13-HVBHDM13_1,8,
    IDE00069-ENG36057,History data 14-HVBHDM_14_3,75,
    IDE00069-ENG125739,History data 14-HVBHDM14_1,07 3F,
    IDE00069-ENG125740,History data 14-HVBHDM14_2,96,
    IDE00070-ENG36058,History data 15-HVBHDM_15_4,7A,
    IDE00070-ENG125741,History data 15-HVBHDM15_1,8,
    IDE00070-ENG125742,History data 15-HVBHDM15_2,40,
    IDE00070-ENG125743,History data 15-HVBHDM15_3,320,
    IDE00071,History data 16,00 85,
    IDE00071-ENG125744,History data 16-HVBHDM16_1,2E,
    IDE00071-ENG125745,History data 16-HVBHDM16_2,00 07,
    IDE00071-ENG125746,History data 16-HVBHDM16_3,85,
    IDE00071-ENG125747,History data 16-HVBHDM16_4,FF FF,
    IDE00071-ENG125748,History data 16-HVBHDM16_5,96,
    IDE00097,OBD - requirements for which this vehicle is designed,EOBD,
    IDE00322,Status of basic setting,was not yet started,
    IDE00637,Intermediate circuit voltage,371.8, V
    IDE00773,Terminal 15 status via CAN,Measured value not available,
    IDE00961-MAS05695,Malfunction Indicator Lamp-Start request,not active,
    IDE01021,Current of H-V / hybrid battery,7.60, A
    IDE01028-MAS01422,Air temperature of H-V / hybrid battery-Intake,28, °C
    IDE01028-MAS01423,Air temperature of H-V / hybrid battery-Exhaust,28, °C
    IDE01803-ENG36059,History data 17-HVBHDM_17_2,0E 61,
    IDE01803-ENG125750,History data 17-HVBHDM17_1,6,
    IDE01804-ENG36060,History data 18-HVBHDM_18_2,00 2D 01 8E,
    IDE01804-ENG125751,History data 18-HVBHDM18_1,8,
    IDE01805-ENG36061,History data 19-HVBHDM_19_2,00 4A 3B 27,
    IDE01805-ENG125752,History data 19-HVBHDM19_1,7,
    IDE01806-ENG36062,History data 20-HVBHDM_20_2,05 41 D7 2D,
    IDE01806-ENG125753,History data 20-HVBHDM20_1,7,
    IDE01838,Battery temperature,30, °C
    IDE01839,Battery charge condition,75, %
    IDE03410-MAS05695,Yellow warning lamp-Start request,not active,
    IDE03411-MAS05695,Red warning lamp-Start request,not active,
    IDE05416,H-V battery insulation measurement test voltage,500, V
    IDE05417,Serial number of H-V / hybrid battery,288 SYEDT00000 ,
    IDE05963,ASSY part number,,
    IDE06302-MAS01422,Temperature of evaporator-Intake,28, °C
    IDE06302-MAS01423,Temperature of evaporator-Exhaust,28, °C
    IDE06346,H-V battery voltage,372.5, V
    IDE06404,Pilot line,not active,
    IDE06422-ENG106773,IUMPR_1-General_Denominator,374,
    IDE06422-ENG106916,IUMPR_1-Ignition_Cycle_Counter,2689,
    IDE06422-ENG100120,IUMPR_1-Milage,30900, km
    IDE06422-ENG128699,IUMPR_1-Number_of_IUMPR_Records,53,
    IDE06423-ENG128703,IUMPR_2-Denominator_to_DFCC_ID2_2,374,
    IDE06423-ENG128701,IUMPR_2-DFCC_Value_to_Record_ID2_1,26653,
    IDE06423-ENG128702,IUMPR_2-Numerator_to_DFCC_ID2_2,2390,
    IDE06423-ENG128700,IUMPR_2-Recordnumber_uneven,1,
    IDE06424-ENG128707,IUMPR_3-Denominator_to_DFCC_ID3_2,374,
    IDE06424-ENG128705,IUMPR_3-DFCC_value_of_record_ID_3_2,26652,
    IDE06424-ENG128706,IUMPR_3-Numerator_to_DFCC_ID3_2,2514,
    IDE06424-ENG128704,IUMPR_3-Recordnumber_even,2,
    IDE06673,Initialization status,not active,
    IDE06805,Status of voltage freedom,High voltage power off not recognized,
    IDE06948,High-volt. battery mode: spec. value,Extern. charging: AC voltage,
    IDE06973,Power reduction status,not active,
    IDE07044-MAS01420,Predictive limit for charge current-Limit for charge current,32, A
    IDE07045-MAS01420,Dynamic limit for charge current-Limit for charge current,93, A
    IDE07227-IDE01024,Voltage in H-V system-Voltage of hybrid battery after protection,371.8, V
    IDE07227-MAS05684,Voltage in H-V system-Voltage at power electronics,372.2, V
    IDE07227-MAS05685,Voltage in H-V system-Voltage at high-voltage charging device,367.0, V
    IDE08217-MAS01234,maximum voltage for battery cells-Index 1,44,
    IDE08217-MAS02985,maximum voltage for battery cells-Value,3.883, V
    IDE08218-MAS01234,minimum voltage for battery cells-Index 1,16,
    IDE08218-MAS02985,minimum voltage for battery cells-Value,3.873, V
    IDE08230-MAS01421,Dynamic limit for discharge current-Limit for discharge current,330, A
    IDE08231-MAS01421,Predictive limit for discharge current-Limit for discharge current,115, A
    IDE08817,Charge state: cell 01,75, %
    IDE08818,Charge state: cell 02,75, %
    IDE08819,Charge state: cell 03,75, %
    IDE08820,Charge state: cell 04,75, %
    IDE08821,Charge state: cell 05,75, %
    IDE08822,Charge state: cell 06,75, %
    IDE08823,Charge state: cell 07,75, %
    IDE08824,Charge state: cell 08,75, %
    IDE08825,Charge state: cell 09,75, %
    IDE08826,Charge state: cell 10,75, %
    IDE08827,Charge state: cell 11,75, %
    IDE08828,Charge state: cell 12,75, %
    IDE08829,Charge state: cell 13,75, %
    IDE08830,Charge state: cell 14,75, %
    IDE08831,Charge state: cell 15,75, %
    IDE08832,Charge state: cell 16,75, %
    IDE08833,Charge state: cell 17,75, %
    IDE08834,Charge state: cell 18,75, %
    IDE08835,Charge state: cell 19,75, %
    IDE08836,Charge state: cell 20,75, %
    IDE08837,Charge state: cell 21,75, %
    IDE08838,Charge state: cell 22,75, %
    IDE08839,Charge state: cell 23,75, %
    IDE08840,Charge state: cell 24,75, %
    IDE08841,Charge state: cell 25,75, %
    IDE08842,Charge state: cell 26,75, %
    IDE08843,Charge state: cell 27,75, %
    IDE08844,Charge state: cell 28,75, %
    IDE08845,Charge state: cell 29,75, %
    IDE08846,Charge state: cell 30,75, %
    IDE08847,Charge state: cell 31,75, %
    IDE08848,Charge state: cell 32,75, %
    IDE08849,Charge state: cell 33,75, %
    IDE08850,Charge state: cell 34,75, %
    IDE08851,Charge state: cell 35,75, %
    IDE08852,Charge state: cell 36,75, %
    IDE08853,Charge state: cell 37,75, %
    IDE08854,Charge state: cell 38,75, %
    IDE08855,Charge state: cell 39,75, %
    IDE08856,Charge state: cell 40,75, %
    IDE08857,Charge state: cell 41,75, %
    IDE08858,Charge state: cell 42,75, %
    IDE08859,Charge state: cell 43,75, %
    IDE08860,Charge state: cell 44,75, %
    IDE08861,Charge state: cell 45,75, %
    IDE08862,Charge state: cell 46,75, %
    IDE08863,Charge state: cell 47,75, %
    IDE08864,Charge state: cell 48,75, %
    IDE08865,Charge state: cell 49,75, %
    IDE08866,Charge state: cell 50,75, %
    IDE08867,Charge state: cell 51,75, %
    IDE08868,Charge state: cell 52,75, %
    IDE08869,Charge state: cell 53,75, %
    IDE08870,Charge state: cell 54,75, %
    IDE08871,Charge state: cell 55,75, %
    IDE08872,Charge state: cell 56,75, %
    IDE08873,Charge state: cell 57,75, %
    IDE08874,Charge state: cell 58,75, %
    IDE08875,Charge state: cell 59,75, %
    IDE08876,Charge state: cell 60,75, %
    IDE08879,Charge state: cell 61,75, %
    IDE08880,Charge state: cell 62,75, %
    IDE08881,Charge state: cell 63,75, %
    IDE08882,Charge state: cell 64,75, %
    IDE08883,Charge state: cell 65,75, %
    IDE08884,Charge state: cell 66,75, %
    IDE08885,Charge state: cell 67,75, %
    IDE08886,Charge state: cell 68,75, %
    IDE08887,Charge state: cell 69,75, %
    IDE08888,Charge state: cell 70,75, %
    IDE08889,Charge state: cell 71,75, %
    IDE08890,Charge state: cell 72,75, %
    IDE08891,Charge state: cell 73,75, %
    IDE08892,Charge state: cell 74,75, %
    IDE08893,Charge state: cell 75,75, %
    IDE08894,Charge state: cell 76,75, %
    IDE08895,Charge state: cell 77,75, %
    IDE08896,Charge state: cell 78,75, %
    IDE08897,Charge state: cell 79,75, %
    IDE08898,Charge state: cell 80,75, %
    IDE08899,Charge state: cell 81,75, %
    IDE08900,Charge state: cell 82,75, %
    IDE08901,Charge state: cell 83,75, %
    IDE08902,Charge state: cell 84,75, %
    IDE08903,Charge state: cell 85,75, %
    IDE08904,Charge state: cell 86,75, %
    IDE08905,Charge state: cell 87,75, %
    IDE08906,Charge state: cell 88,75, %
    IDE08907,Charge state: cell 89,75, %
    IDE08908,Charge state: cell 90,75, %
    IDE08909,Charge state: cell 91,75, %
    IDE08910,Charge state: cell 92,75, %
    IDE08911,Charge state: cell 93,75, %
    IDE08912,Charge state: cell 94,75, %
    IDE08913,Charge state: cell 95,75, %
    IDE08914,Charge state: cell 96,75, %
    IDE10320-MAS01146,Workshop code and date of last reset of crash shutdown-Workshop code,00 00 00 00 00 00,
    IDE10320-MAS01230,Workshop code and date of last reset of crash shutdown-Date,00 00 00,
    IDE80253,Voltage terminal 30C,12.75, V
    MAS00194-ENG128689,--no display---CMC_SEL_out,01,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2000, yr
    MAS00464-MAS00107,Standard - ambient data 1-Month,1, mon
    MAS00464-MAS00108,Standard - ambient data 1-Day,2, d
    MAS00464-MAS00109,Standard - ambient data 1-Hours,0, H
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,2, min
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,24, s
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,255,
    MAS01302,Protection of posit. terminal of high voltage / hybrid battery,closed,
    MAS01303,Protection of neg. terminal of high voltage / hybrid battery,closed,
    MAS02199-MAS01966,Lowest measured temperature-Temperature sensor,60,
    MAS02199-MAS02985,Lowest measured temperature-Value,29, °C
    MAS02200-MAS01966,Highest measured temperature-Temperature sensor,72,
    MAS02200-MAS02985,Highest measured temperature-Value,30, °C
    MAS04266,Temperature sensor 1,30, °C
    MAS04267,Temperature sensor 2,30, °C
    MAS04268,Temperature sensor 3,29, °C
    MAS04269,Temperature sensor 4,29, °C
    MAS04270,Temperature sensor 5,29, °C
    MAS04271,Temperature sensor 6,29, °C
    MAS04272,Temperature sensor 7,29, °C
    MAS04273,Temperature sensor 8,29, °C
    MAS04291,Positive voltage of high volt battery after protection,372.8, V
    MAS04292,Negative Voltage of high volt battery after protection,0.3, V
    MAS04293-MAS01632,Entire HV system positive terminal insulation resistance-Status,valid,
    MAS04293,Entire HV system positive terminal insulation resistance,3590, kOhm
    MAS04294-MAS01632,HV battery positive terminal insulation resistance-Status,invalid,
    MAS04294,HV battery positive terminal insulation resistance,10000, kOhm
    MAS04295-MAS01632,Entire HV system minus terminal insulation resistance-Status,valid,
    MAS04295,Entire HV system minus terminal insulation resistance,4560, kOhm
    MAS04296-MAS01632,HV battery minus terminal insulation resistance-Status,invalid,
    MAS04296,HV battery minus terminal insulation resistance,10000, kOhm
    MAS04649,Cell 1,3.876, V
    MAS04650,Cell 2,3.876, V
    MAS04651,Cell 3,3.878, V
    MAS04652,Cell 4,3.876, V
    MAS04653,Cell 5,3.879, V
    MAS04654,Cell 6,3.876, V
    MAS04655,Cell 7,3.876, V
    MAS04656,Cell 8,3.882, V
    MAS04657,Cell 9,3.881, V
    MAS04658,Cell 10,3.883, V
    MAS04659,Cell 11,3.881, V
    MAS04660,Cell 12,3.883, V
    MAS04661,Cell 13,3.875, V
    MAS04662,Cell 14,3.876, V
    MAS04663,Cell 15,3.875, V
    MAS04664,Cell 16,3.876, V
    MAS04665,Cell 17,3.875, V
    MAS04666,Cell 18,3.876, V
    MAS04667,Cell 19,3.875, V
    MAS04668,Cell 20,3.883, V
    MAS04669,Cell 21,3.883, V
    MAS04670,Cell 22,3.880, V
    MAS04671,Cell 23,3.883, V
    MAS04672,Cell 24,3.881, V
    MAS04673,Cell 25,3.876, V
    MAS04674,Cell 26,3.880, V
    MAS04675,Cell 27,3.879, V
    MAS04676,Cell 28,3.878, V
    MAS04677,Cell 29,3.877, V
    MAS04678,Cell 30,3.876, V
    MAS04679,Cell 31,3.879, V
    MAS04680,Cell 32,3.882, V
    MAS04681,Cell 33,3.881, V
    MAS04682,Cell 34,3.882, V
    MAS04683,Cell 35,3.881, V
    MAS04684,Cell 36,3.882, V
    MAS04685,Cell 37,3.877, V
    MAS04686,Cell 38,3.878, V
    MAS04687,Cell 39,3.877, V
    MAS04688,Cell 41,3.876, V
    MAS04689,Cell 42,3.876, V
    MAS04690,Cell 43,3.877, V
    MAS04691,Cell 44,3.881, V
    MAS04692,Cell 45,3.884, V
    MAS04693,Cell 46,3.883, V
    MAS04694,Cell 47,3.884, V
    MAS04695,Cell 48,3.882, V
    MAS04696,Cell 49,3.878, V
    MAS04697,Cell 50,3.877, V
    MAS04698,Cell 51,3.877, V
    MAS04699,Cell 52,3.877, V
    MAS04700,Cell 53,3.877, V
    MAS04701,Cell 54,3.878, V
    MAS04702,Cell 55,3.877, V
    MAS04703,Cell 56,3.883, V
    MAS04704,Cell 57,3.884, V
    MAS04705,Cell 58,3.881, V
    MAS04706,Cell 59,3.884, V
    MAS04707,Cell 60,3.884, V
    MAS04708,Cell 61,3.877, V
    MAS04709,Cell 62,3.876, V
    MAS04710,Cell 63,3.879, V
    MAS04711,Cell 64,3.877, V
    MAS04712,Cell 65,3.876, V
    MAS04713,Cell 66,3.877, V
    MAS04714,Cell 67,3.877, V
    MAS04715,Cell 68,3.881, V
    MAS04716,Cell 69,3.883, V
    MAS04717,Cell 70,3.883, V
    MAS04718,Cell 71,3.883, V
    MAS04719,Cell 72,3.881, V
    MAS04720,Cell 40,3.878, V
    MAS04721-MAS01234,Minimum charge level-Index 1,90,
    MAS04721-MAS02985,Minimum charge level-Value,75, %
    MAS04722-MAS01234,Maximum charge level-Index 1,82,
    MAS04722-MAS02985,Maximum charge level-Value,75, %
    MAS06567-ENG36313,Frequency Counter-Counter SOC 0 to 10,0,
    MAS06567-ENG36314,Frequency Counter-Counter SOC 10 to 20,0,
    MAS06567-ENG36315,Frequency Counter-Counter SOC 20 to 30,0,
    MAS06567-ENG36316,Frequency Counter-Counter SOC 30 to 40,0,
    MAS06567-ENG36317,Frequency Counter-Counter SOC 40 to 50,0,
    MAS06567-ENG36318,Frequency Counter-Counter SOC 50 to 60,0,
    MAS06567-ENG36319,Frequency Counter-Counter SOC 60 to 70,0,
    MAS06567-ENG36320,Frequency Counter-Counter SOC 70 to 80,0,
    MAS06567-ENG36321,Frequency Counter-Counter SOC 80 to 90,0,
    MAS06567-ENG36322,Frequency Counter-Counter SOC 90 to 100,0,
    MAS06567-ENG36323,Frequency Counter-Main counter,0,
    MAS06761,Sum of voltage of all battery cells,372.384, V
    MAS07735,Cell 73,3.878, V
    MAS07736,Cell 74,3.876, V
    MAS07737,Cell 75,3.878, V
    MAS07738,Cell 76,3.876, V
    MAS07739,Cell 77,3.877, V
    MAS07740,Cell 78,3.875, V
    MAS07741,Cell 79,3.877, V
    MAS07742,Cell 80,3.881, V
    MAS07743,Cell 81,3.880, V
    MAS07744,Cell 82,3.880, V
    MAS07745,Cell 83,3.879, V
    MAS07746,Cell 84,3.880, V
    MAS07747,Cell 85,3.876, V
    MAS07748,Cell 86,3.876, V
    MAS07749,Cell 87,3.877, V
    MAS07750,Cell 88,3.877, V
    MAS07751,Cell 89,3.878, V
    MAS07752,Cell 90,3.877, V
    MAS07753,Cell 91,3.878, V
    MAS07754,Cell 92,3.882, V
    MAS07755,Cell 93,3.882, V
    MAS07756,Cell 94,3.881, V
    MAS07757,Cell 95,3.882, V
    MAS07758,Cell 96,3.883, V
    MAS07792,Expanded battery limits,not active,
    MAS07798,Status pre-loader,Open,
    MAS07799,Pump for HV battery coolant: status,no error,
    MAS07804,Pump for HV battery coolant: specified power value,22.5, %
    MAS07805,Pump for HV battery coolant: RPM list value,655340, /min
    MAS07807-MAS07808,Valve 1 coolant HV battery: activation-Valve 1 coolant HV battery: spec. value,closed,
    MAS07807-MAS07809,Valve 1 coolant HV battery: activation-Valve 1 coolant HV battery: act. value,not defined,
    MAS07813,HV battery: cool. level requirement,Stage 1,
    MAS07815,Cooling status BMS,Unknown,
    MAS07826,Reqmnt. emergency discharge HV interm. circ. condenser,not active,
    MAS07827,Mode HV battery actual value,Extern. charging: AC voltage,
    MAS12552,Coolant valve voltage,0.014, V
    MAS12567,Activation signal for high voltage contactor,00,
    MAS12568,Feedback signal for high voltage contactor,01,
    Elapsed Time: 00:33
    ADP
    ;Thursday,02,August,2018,08:20:17:50490
    IDE00010-Serial number,U6000000 ,20
    IDE00011-Vehicle Identification Number (VIN),----------------- ,17
    IDE05417-Serial number of H-V / hybrid battery,288 SYEDT00000  ,15
    IDE05963-ASSY part number, ,12
    IDE11985-Expected OBD requirements,EOBD ,1
    Elapsed Time: 00:01
  3. #23
    Aug 2018
    A5 Frt Sens. Drv. Assist
    Block
    ;SW:3Q0-980-654-G   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist
    ;Component:MQB_B_MFK     H06 0231, Coding:0403070300000401012200448048A90084000E200020
    ;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_VW36.rod
    ;Thursday,02,August,2018,08:20:34:50490
    ;VCID: 3B36E8BCB2A09A9C32-806E
    IDE00018,Voltage terminal 15,13.1, V
    IDE00102,Control Module temperature,42, °C
    IDE00322,Status of basic setting,not active,
    IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
    IDE00326,Steering wheel angle,14.9, °
    IDE00767,No. of unscheduled ECU resets,2,
    IDE00925-MAS02471,Yaw rate-Sign,Negative,
    IDE00925,Yaw rate,0.08, °/s
    IDE00973,Outside air temperature,21.0, °C
    IDE01968,Dynamic calibration: yaw angle offset,0.164, °
    IDE01969,Dynamic calibration: pitch angle offset,-0.493, °
    IDE01970,Dynamic calibration: roll angle offset,-0.202, °
    IDE01971,Lowest recorded control module temperature,-13, °C
    IDE02057,Dynamic calibration: status,Passive values stored,
    IDE02486,Data logger triggering,not active,
    IDE03222-MAS02534,Blindness detection-Clear view,No,
    IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
    IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
    IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
    IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
    IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
    IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
    IDE03222-MAS10690,Blindness detection-Activation condition,activated,
    IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
    IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
    IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
    IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
    IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
    IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,3369, km
    IDE04036,High beam assistant: status,not active,
    IDE04037,High beam recommendation,OFF,
    IDE04123,High beam: reason for shut-off,20,
    IDE04125,Visibility,Not Used,
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
    IDE07214,Dynamic calibration: camera height offset,0, mm
    IDE09424,Number of recognized lane markings,0,
    IDE09433-MAS01632,Perception module for light assistant-Status,passive,
    IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
    IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
    IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
    IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
    IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
    IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
    IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
    IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
    IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
    IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
    IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
    IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
    IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
    IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
    IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
    IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
    IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
    IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
    IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
    IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
    IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
    IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
    IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
    IDE09436,Recognized street illumination,Not available,
    IDE09438,Drive sequence,Left hand driv.,
    IDE10220,Initial online calibration active,not active,
    IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
    IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
    IDE10398-MAS11503,Self-glare-Self-glare status,not active,
    IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
    IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
    IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
    IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
    IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
    IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.143, °
    IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
    IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-0.231, °
    IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
    IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.002, °
    IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
    IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1305, mm
    IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
    IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
    IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
    IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,Calibration not yet performed,
    IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
    IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
    IDE10547,Status of camera,Camera operating,
    IDE10664-MAS00106,Current initial calibration: details-Year,2017,
    IDE10664-MAS00107,Current initial calibration: details-Month,1,
    IDE10664-MAS00108,Current initial calibration: details-Day,17,
    IDE10664-MAS00109,Current initial calibration: details-Hours,15,
    IDE10664-MAS00110,Current initial calibration: details-Minutes,54,
    IDE10664-MAS00111,Current initial calibration: details-Seconds,30,
    IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
    IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
    IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
    IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
    IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WAUZZZ8V6HA000000,
    IDE10664-MAS03010,Current initial calibration: details-Focal length,1384,
    IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,646,
    IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,368,
    IDE10664,Current initial calibration: details,00011111 ,
    IDE10664,Current initial calibration: details,00111111 ,
    IDE10664,Current initial calibration: details,00110011 ,
    IDE11956,Boot manager version,31 12 30 01,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2018,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,8,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
    ENG130818-MAS01505,Windscreen_heater_camera-Engine off,Yes,
    ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,no error,
    ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
    ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
    ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
    ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
    ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
    ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,active,
    ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
    ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
    ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
    ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
    ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
    ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
    Elapsed Time: 00:26
    ADP
    ;Thursday,02,August,2018,08:21:01:50490
    ;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    IDE00001-Production mode,Deactivating ,3
    IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
    IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
    IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
    IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
    IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
    IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
    IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
    IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
    IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
    IDE04733-Road sign detection fusion mode,Road sign fusion ,1
    IDE07358-Distance to calibration field,1500 mm,2
    IDE09375-IDE05717-Axle offset-Front axle transverse position,5.96046e-006 mm,4
    IDE09375-IDE05718-Axle offset-Rear axle transverse position,0.200006 mm,4
    IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,683.25 mm,8
    IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,689 mm,8
    IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,685.25 mm,8
    IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,691.75 mm,8
    IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2351 mm,24
    IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,735 mm,24
    IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1494 mm,24
    IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2351 mm,24
    IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-730 mm,24
    IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1494 mm,24
    IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2351 mm,24
    IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,735 mm,24
    IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,906 mm,24
    IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2351 mm,24
    IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-730 mm,24
    IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,906 mm,24
    IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
    IDE10870-Switch-on condition: lane depart. warn.,off (setting via menu) ,1
    IDE10871-System mode: lane depart. warn:,Selection via menu ,1
    IDE10872-Warning intensity: lane depart. warning,Medium ,1
    IDE10873-BAP personalization,activated ,1
    IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.002 °,8
    IDE10924-MAS05286-Initial calibration: result-Roll angle,0.143 °,8
    IDE10924-MAS05287-Initial calibration: result-Pitch angle,-0.231 °,8
    IDE10924-MAS10678-Initial calibration: result-Camera height,1305 mm,8
    ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
    ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
    ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
    ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
    ENG120319-Mask_error_reactions_for_development,not activated ,1
    ENG107577-Masked_fault_classes-,255 ,4
    ENG130777-standstill_mode,not activated ,1
    ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,12.8 ,5
    ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,0 ,5
    ENG130779-Xcp_interface,not activated ,1
    Elapsed Time: 00:07
  4. #24
    Aug 2018
    C6 Batt. Chrg.
    Block
    ;SW:5QE-915-682-AF   HW:5QE-915-682-AF ---  Batt. Chrg.
    ;Component:OBC KOSTAL    H31 4013, Coding:115068223000
    ;EV_OBCSinglPhaseKLOMQB12P,001001,EV_OBCSinglPhaseKLOMQB12P.rod
    ;Thursday,02,August,2018,08:21:18:50490
    ;VCID: 116A6A14C0AC40CCB8-8044
    Group,Description,Actual
    IDE00019,Voltage terminal 30,13.0, V
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00637,Intermediate circuit voltage,403.4, V
    IDE00767,No. of unscheduled ECU resets,00,
    IDE06954,HV charge current: act. value,9, A
    IDE06955-ENG114223,HV charge current: spec. value-Charger_HV_current_commanded_value,8.8, A
    IDE07975,Remote control for charge function of H-V battery,not activated,
    IDE08421-IDE05431,Power outlet A for battery charging-Locking for H-V charge plug,locked,
    IDE08421-MAS07220,Power outlet A for battery charging-Status connect. recognition,present,
    IDE08421-MAS07221,Power outlet A for battery charging-Connector locking requirement,00000000 ,
    IDE08421-MAS07222,Power outlet A for battery charging-Connector unlocking requirement,00000000 ,
    IDE08421-MAS07223,Power outlet A for battery charging-Max. current of charge connector,20, A
    IDE08421-MAS07565,Power outlet A for battery charging-Activation charge cover lock charge socket A,not requested,
    IDE08421-MAS07567,Power outlet A for battery charging-Status charge cover lock charge socket A,not locked,
    IDE08421-MAS10983,Power outlet A for battery charging-Activation charge cover unlock charge socket A,not requested,
    IDE08421-MAS12565,Power outlet A for battery charging-Charge socket temperature sensor AC,27.0, °C
    IDE08421-MAS12566,Power outlet A for battery charging-Charge sensor temperature sensor DC,0.0, °C
    IDE08422-IDE05431,Power outlet B for battery charging-Locking for H-V charge plug,not locked,
    IDE08422-MAS07220,Power outlet B for battery charging-Status connect. recognition,Not Present,
    IDE08422-MAS07221,Power outlet B for battery charging-Connector locking requirement,00000000 ,
    IDE08422-MAS07222,Power outlet B for battery charging-Connector unlocking requirement,00000000 ,
    IDE08422-MAS07223,Power outlet B for battery charging-Max. current of charge connector,0, A
    IDE08422-MAS07224,Power outlet B for battery charging-Temp. of charge socket,27.0, °C
    IDE08422-MAS07566,Power outlet B for battery charging-Activation charge cover lock charge socket B,not requested,
    IDE08422-MAS07568,Power outlet B for battery charging-Status: chg. cover lock. device: chg. socket B,not locked,
    IDE08423-MAS02949,Control signal for power outlet A for battery charging-Frequency,1000, Hz
    IDE08423-MAS02952,Control signal for power outlet A for battery charging-Control voltage,5759, mV
    IDE08423-MAS03873,Control signal for power outlet A for battery charging-Duty cycle,33.5, %
    IDE08423-MAS04136,Control signal for power outlet A for battery charging-Current,20.2, A
    IDE08423-MAS07262,Control signal for power outlet A for battery charging-Signal recognized,00000001 ,
    IDE08424-MAS02949,Control signal for power outlet B for battery charging-Frequency,0, Hz
    IDE08424-MAS02952,Control signal for power outlet B for battery charging-Control voltage,0, mV
    IDE08424-MAS03873,Control signal for power outlet B for battery charging-Duty cycle,0.0, %
    IDE08424-MAS04136,Control signal for power outlet B for battery charging-Current,0.0, A
    IDE08424-MAS07262,Control signal for power outlet B for battery charging-Signal recognized,00000000 ,
    IDE08425-MAS07225,Indicator lamps for power outlet A for battery charging-Status: indicator light 1,OFF,
    IDE08425-MAS07226,Indicator lamps for power outlet A for battery charging-Status: indicator light 2,Blinking,
    IDE08425-MAS07227,Indicator lamps for power outlet A for battery charging-Status: indicator light 3,OFF,
    IDE08425-MAS07228,Indicator lamps for power outlet A for battery charging-Intensity: indicator light 1,100, %
    IDE08425-MAS07229,Indicator lamps for power outlet A for battery charging-Intensity: indicator light 2,100, %
    IDE08425-MAS07230,Indicator lamps for power outlet A for battery charging-Intensity: indicator light 3,100, %
    IDE08425-MAS07231,Indicator lamps for power outlet A for battery charging-Period duration: indicator light 1,2000, ms
    IDE08425-MAS07232,Indicator lamps for power outlet A for battery charging-Period duration: indicator light 2,2000, ms
    IDE08425-MAS07233,Indicator lamps for power outlet A for battery charging-Period duration: indicator light 3,2000, ms
    IDE08425-MAS07582,Indicator lamps for power outlet A for battery charging-Intensity: activation 4,0, %
    IDE08425-MAS07590,Indicator lamps for power outlet A for battery charging-Period duration: activation 4,0, ms
    IDE08425-MAS13012,Indicator lamps for power outlet A for battery charging-Status: indicator light 4,OFF,
    IDE08426-MAS07225,Indicator lamps for power outlet B for battery charging-Status: indicator light 1,OFF,
    IDE08426-MAS07226,Indicator lamps for power outlet B for battery charging-Status: indicator light 2,OFF,
    IDE08426-MAS07227,Indicator lamps for power outlet B for battery charging-Status: indicator light 3,OFF,
    IDE08426-MAS07228,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 1,100, %
    IDE08426-MAS07229,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 2,100, %
    IDE08426-MAS07230,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 3,100, %
    IDE08426-MAS07231,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 1,2000, ms
    IDE08426-MAS07232,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 2,2000, ms
    IDE08426-MAS07233,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 3,2000, ms
    IDE08426-MAS07582,Indicator lamps for power outlet B for battery charging-Intensity: activation 4,0, %
    IDE08426-MAS07590,Indicator lamps for power outlet B for battery charging-Period duration: activation 4,0, ms
    IDE08426-MAS13012,Indicator lamps for power outlet B for battery charging-Status: indicator light 4,OFF,
    IDE08427-MAS07237,Statistics of power outlet A for battery charging-No. of connections,1485,
    IDE08427-MAS07238,Statistics of power outlet A for battery charging-No. of lockings,1824,
    IDE08428-MAS07237,Statistics of power outlet B for battery charging-No. of connections,0,
    IDE08428-MAS07238,Statistics of power outlet B for battery charging-No. of lockings,0,
    IDE08430,Cause of cancellation of charge procedure,not active,
    IDE08431,Remaining time for charge procedure,40, min
    IDE08432-MAS02158,Button for battery charging-Actuation condition,not activated,
    IDE08432-MAS04737,Button for battery charging-Indicator lamp,On,
    IDE08505-MAS07220,Power outlet for quick charging of HV battery-Status connect. recognition,present,
    IDE08638-MAS04721,SOC limits: set by customer-Minimum charge level,1, %
    IDE08638-MAS04722,SOC limits: set by customer-Maximum charge level,0, %
    IDE08639,max. loading power,3300, W
    IDE08640,Spec. mode: load mgmnt.,AC main charge,
    IDE08649-IDE06971,Ready to charge-Operational readiness in H-V system,active,
    IDE08649-MAS07214,Ready to charge-Status charge readiness: engine,ready for operation,
    IDE08649-MAS07215,Ready to charge-Status charge readiness charge mngmt.,ready for operation,
    IDE08657-MAS01424,Current at DC charg. stat.-max.value,0, A
    IDE08657-MAS07236,Current at DC charg. stat.-Act.val.,0, A
    IDE08658-MAS01424,Voltage at DC charg. stat.-max.value,0, V
    IDE08658-MAS07236,Voltage at DC charg. stat.-Act.val.,0, V
    IDE08659-MAS07237,Statistic of DC charger for battery charging-No. of connections,0,
    IDE08659-MAS07238,Statistic of DC charger for battery charging-No. of lockings,0,
    IDE08659-MAS07239,Statistic of DC charger for battery charging-No. of charging process.,0,
    IDE08677-MAS07258,Load mode-Stat.: charge mode,AC main charge,
    IDE08677-MAS07259,Load mode-Chg. type,Imm. charg.,
    IDE08717,Status mains voltage,present,
    IDE08718-MAS06699,Chademo version-Vehicle,0,
    IDE08718-MAS07395,Chademo version-Chg. statn.,0,
    IDE08719-IDE08720,Values from battery mgmt system-Current condition of battery mgmt. system,External Charging,
    IDE08719-MAS01420,Values from battery mgmt system-Limit for charge current,N/A---,
    IDE08719-MAS04059,Values from battery mgmt system-Battery temperature,30.0, °C
    IDE08719-MAS07289,Values from battery mgmt system-A/C requirement,Med. cooling reqmnt.,
    IDE08719-MAS07396,Values from battery mgmt system-Act. voltage HV battery,N/A---,
    IDE08719-MAS07397,Values from battery mgmt system-Act. current HV battery,N/A---,
    IDE08719-MAS07407,Values from battery mgmt system-Max. battery charging voltage,N/A---,
    IDE08751-MAS02158,Load button-Actuation condition,not activated,
    IDE08751-MAS04737,Load button-Indicator lamp,OFF,
    IDE08751-MAS07596,Load button-Locating illum. charge button,OFF,
    IDE08938,Chrgr cooling reqrmnt,Med. cooling reqmnt.,
    IDE08985,AC line current: actual val,15.0, A
    IDE08986,AC line voltage: actual val,226, V
    IDE09039,HV charger - current output voltage,368, V
    IDE09057,HV battery charge state,74.5, %
    IDE11570-ENG30068,Activation periods of charging cover locking-raw_value_in_develop_by_ODXauthor,00,
    IDE11571-ENG30068,Voltage terminal 30 battery data module-raw_value_in_develop_by_ODXauthor,A3,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,40,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,30904, km
    MAS06335-ENG30068,Voltage low voltage side DCDC - converter-raw_value_in_develop_by_ODXauthor,84,
    MAS07392-MAS07393,Control signal DC charge-Control signal 1,00000000 ,
    MAS07392-MAS07394,Control signal DC charge-Control signal 2,00000001 ,
    MAS07396-ENG30068,Act. voltage HV battery-raw_value_in_develop_by_ODXauthor,05 D5,
    MAS07407-ENG30068,Max. battery charging voltage-raw_value_in_develop_by_ODXauthor,01 90,
    MAS07558,Spec. op. condition charge unit,AC main charge,
    MAS07559,Act.. op. condition charge unit,AC main charge,
    MAS07563,Function limitation charging due to temp. charge socket,not active,
    MAS07564,Function limitation charging due to temp. charge unit,not active,
    MAS12397-ENG30068,Number of lockings: charge cover A-raw_value_in_develop_by_ODXauthor,14 70,
    ENG125865,AC_maximum_input_current_value,16.0, A
    ENG125867,AC_network_frequency,50.0, Hz
    ENG125873,charger_coolant_temperature,40, °C
    ENG123145-ENG123175,Charging_Connector_Locking_Parameter-delocking_request_time_CAN,0, ms
    ENG123145-ENG123173,Charging_Connector_Locking_Parameter-delocking_time_lag,0, ms
    ENG123145-ENG123174,Charging_Connector_Locking_Parameter-locking_delay_time,0, ms
    ENG123145-ENG123176,Charging_Connector_Locking_Parameter-locking_time_lag,0, ms
    ENG123142,charging_process_request,AC_Charging_Request,
    ENG123144,charging_status,Charging,
    ENG125862,current_voltage_protection,not active,
    ENG123148,ekk_air_condition_current,0.0, A
    ENG125863,error_status_battery_charger,not active,
    ENG126556,gate_driver_voltage_DCDC,15.9, V
    ENG126555,gate_driver_voltage_PFC,15.9, V
    ENG126544,high_voltage_activation_request,requested,
    ENG123143,max_HV_DC_voltage_obc,394, V
    ENG123146,permission_to_charge_lm,00000000 ,
    ENG125870,power_efficiency,95.0, %
    ENG125869,power_loss_battery_charger,140, W
    ENG123147,ptc_heater_current,0.0, A
    ENG07647,temperature_battery_charger_PFC_coil,50, °C
    ENG125871,temperature_battery_charger_system_board,61, °C
    ENG125872,temperature_DCDC_coil,45, °C
    ENG125876,temperature_DCDC_powerline,51, °C
    ENG125864,warning_status_battery_charger,no warning,
    Elapsed Time: 00:07
    ADP
    ;Thursday,02,August,2018,08:21:26:50490
    IDE00001-Production mode,OFF ,3
    IDE08427-MAS07237-Statistics of power outlet A for battery charging-No. of connections,1485 ,4
    IDE08427-MAS07238-Statistics of power outlet A for battery charging-No. of lockings,1824 ,4
    IDE08428-MAS07237-Statistics of power outlet B for battery charging-No. of connections,0 ,4
    IDE08428-MAS07238-Statistics of power outlet B for battery charging-No. of lockings,0 ,4
    IDE08659-MAS07237-Statistic of DC charger for battery charging-No. of connections,0 ,6
    IDE08659-MAS07238-Statistic of DC charger for battery charging-No. of lockings,0 ,6
    IDE08659-MAS07239-Statistic of DC charger for battery charging-No. of charging process.,0 ,6
    IDE08686-IDE01464-Base profile load management-Rear window defogger,OFF ,13
    IDE08686-IDE01537-Base profile load management-Windshield defogger,OFF ,13
    IDE08686-MAS04721-Base profile load management-Minimum charge level,1 %,13
    IDE08686-MAS04722-Base profile load management-Maximum charge level,100 %,13
    IDE08686-MAS05945-Base profile load management-Specified temperature,22.0 °C,13
    IDE08686-MAS07289-Base profile load management-A/C requirement,On ,13
    IDE08686-MAS07291-Base profile load management-Recharg.time: status,On ,13
    IDE08686-MAS07292-Base profile load management-Recharge time start hour,23 H,13
    IDE08686-MAS07293-Base profile load management-Recharge time start minute,0 min,13
    IDE08686-MAS07294-Base profile load management-Recharge time end hour,23 H,13
    IDE08686-MAS07295-Base profile load management-Recharge time end minute,0 min,13
    IDE08686-MAS07605-Base profile load management-Charge request,OFF ,13
    IDE08686-MAS08221-Base profile load management-A/C retention time,30 min,13
    IDE08686-MAS08222-Base profile load management-Lead time: start of charging,5 min,13
    IDE08686-MAS08223-Base profile load management-Automatic A/C,On ,13
    IDE08686-MAS08224-Base profile load management-Time for automatic A/C,15 min,13
    IDE08686-MAS08226-Base profile load management-Max charging current,16 A,13
    IDE08686-MAS08227-Base profile load management-Quick charge: SOC upper limit,100 %,13
    MAS12691-MAS12692-Activation times: plug locking device-Re-locking time plug,30 s,3
    MAS12691-MAS12693-Activation times: plug locking device-Locking activation time,400 ms,3
    MAS12691-MAS12694-Activation times: plug locking device-Unlocking activation time,400 ms,3
    Elapsed Time: 00:03
  5. Likes Uwe liked this post
  6. #25
    Aug 2018
    08 Auto HVAC
    Using VCDS Beta ...
    Block
    ;SW:8V0-820-043-R   HW:8V0-820-043-R ---  Auto HVAC
    ;Component:AC Automat    H03 0110, Coding:0300000000001000080000000000100001000000
    ;EV_AirCondiFrontRDWAU37X,001019,EV_AirCondiFrontRDWAU37X.rod
    ;Saturday,04,August,2018,17:08:25:50490
    ;VCDS Version: Beta 18.7.1 (x64)  Data version: 20180731 DS293.0
    ;VCID: 41CA9A54D04CF0425B-8014
    IDE00019,Voltage terminal 30,13.100, V
    IDE00021,Engine speed,0, /min
    IDE00025,Coolant temperature,36, °C
    IDE00075,Vehicle speed,0, km/h
    IDE00198,Refrigerant pressure,8.8, bar
    IDE00767-MAS05494,No. of unscheduled ECU resets-Cause 1,0,
    IDE00767-MAS05495,No. of unscheduled ECU resets-Cause 2,4,
    IDE00767-MAS05496,No. of unscheduled ECU resets-Cause 3,0,
    IDE00767-MAS05497,No. of unscheduled ECU resets-Cause 4,0,
    IDE00767-MAS05498,No. of unscheduled ECU resets-Cause 5,0,
    IDE00767-MAS05499,No. of unscheduled ECU resets-Cause 6,0,
    IDE00767-MAS05793,No. of unscheduled ECU resets-Cause 7,0,
    IDE00767-MAS05794,No. of unscheduled ECU resets-Cause 8,0,
    IDE00965,Compressor shut-off requirement,Electric compressor: not ready,
    IDE00970,Coolant fan activation: actual value,18.0, %
    IDE00971,Coolant fan activation: specified value,0.0, %
    IDE00973,Outside air temperature,33, °C
    IDE00974,Outside air temperature internally calculated,33, °C
    IDE00976,Left front vent temperature,35.5, °C
    IDE00977,Right front vent temperature,35.0, °C
    IDE00981,Footwell vent temperature,35.0, °C
    IDE00982,Temperature after evaporator,35.7, °C
    IDE00983,Interior temperature,38.6, °C
    IDE00984,Sun intensity left,550, W/m²
    IDE00985,Sun intensity right,310, W/m²
    IDE00987,Blower voltage: specified value,6.0, V
    IDE00989,Blower status,active,
    IDE00994,Actual value for fresh air/recirculation air flow flap,68.0, %
    IDE00994,Actual value for fresh air/recirculation air flow flap,638,
    IDE00995,Specified value for fresh air/recirc air flow flap,637,
    IDE00996,Fresh air stop for fresh air/recirculation air flow flap,167,
    IDE00997,Recirculated air stop for fresh air/recirc air flow flap,863,
    IDE00998,Left temperature flap - actual value,0.5, %
    IDE00998,Left temperature flap - actual value,124,
    IDE00999,Left temperature flap - specified value,120,
    IDE01040,Left temperature flap: cold stop,120,
    IDE01041,Left temperature flap: warm stop,904,
    IDE01042,Right temperature flap: actual value,0.5, %
    IDE01042,Right temperature flap: actual value,122,
    IDE01043,Right temperature flap: specified value,116,
    IDE01044,Right temperature flap: cold stop,116,
    IDE01045,Right temperature flap: warm stop,918,
    IDE01050,Front air distribution flap: actual value,234,
    IDE01050,Front air distribution flap: actual value,84.0, %
    IDE01051,Front air distribution flap: specified value,233,
    IDE01052,Front air distribution flap: air outlet stop,929,
    IDE01053,Front air distribution flap: footwell air outlet stop,101,
    IDE01054,Defroster flap: actual value,7.0, %
    IDE01054,Defroster flap: actual value,168,
    IDE01055,Defroster flap: specified value,171,
    IDE01056,Defroster flap: stop open,937,
    IDE01057,Defroster flap: stop closed,109,
    IDE01063,Status of recirculation air,Fresh air,
    IDE01076,Time since ignition off,3, min
    IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
    IDE01217-MAS01448,Left heated seat stage-Specified value,0,
    IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
    IDE01218-MAS01448,Right heated seat stage-Specified value,0,
    IDE01226,Blower voltage: actual value,6.0, V
    IDE01227,Blower current,3.50, A
    IDE01232,Supply voltage for external components,4.9, V
    IDE01287,Counter of compressor switch-offs,0,
    IDE01419,Compressor shut-off condition: last,Invalid signals,
    IDE01420,Compressor shut-off requirement: penultimate,Compressor activation: malfunction in activation path,
    IDE01421,Compressor shut-off requirement: antepenultimate,Invalid signals,
    IDE01433,Air quality status,Clean air,
    IDE01442-MAS01533,Pressing a button-Defrost,not activated,
    IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
    IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
    IDE01442-MAS01550,Pressing a button-AC,not activated,
    IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
    IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
    IDE01442-MAS01560,Pressing a button-OFF,not activated,
    IDE01442-MAS02015,Pressing a button-AUTO,not activated,
    IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
    IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
    IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
    IDE01443,Left push-and-rotary knob counter,0,
    IDE01444,Right push-and-rotary knob counter,0,
    IDE01449-IDE01011,Personalization 1 for climate control-Data record,not active,
    IDE01449-MAS01533,Personalization 1 for climate control-Defrost,0,
    IDE01449-MAS01534,Personalization 1 for climate control-Recirculating air,0,
    IDE01449-MAS01550,Personalization 1 for climate control-AC,1,
    IDE01449-MAS01552,Personalization 1 for climate control-Left specified temperature,21.0, °C
    IDE01449-MAS01553,Personalization 1 for climate control-Right specified temperature,21.0, °C
    IDE01449-MAS01554,Personalization 1 for climate control-Left heated seat,0,
    IDE01449-MAS01555,Personalization 1 for climate control-Left seat ventilation,not installed,
    IDE01449-MAS01556,Personalization 1 for climate control-Right heated seat,0,
    IDE01449-MAS01557,Personalization 1 for climate control-Right seat ventilation,not installed,
    IDE01449-MAS01560,Personalization 1 for climate control-OFF,0,
    IDE01449-MAS01562,Personalization 1 for climate control-Air quality sensor,1,
    IDE01449-MAS01563,Personalization 1 for climate control-Auxiliary Air Heater,not installed,
    IDE01449-MAS01566,Personalization 1 for climate control-Style,not installed,
    IDE01449-MAS01567,Personalization 1 for climate control-Synchronization,0,
    IDE01449-MAS02015,Personalization 1 for climate control-AUTO,1,
    IDE01449-MAS02804,Personalization 1 for climate control-Manual fan speed increase,11,
    IDE01449-MAS03830,Personalization 1 for climate control-Footwell air distribution,0,
    IDE01449-MAS03831,Personalization 1 for climate control-Upper body vent air distribution,0,
    IDE01449-MAS03832,Personalization 1 for climate control-Air distribution up,0,
    IDE01449-MAS04620,Personalization 1 for climate control-Fan setting: absolute,1,
    IDE01449-MAS04621,Personalization 1 for climate control-Left cabin heater,not installed,
    IDE01449-MAS04648,Personalization 1 for climate control-Right cabin heater,not installed,
    IDE01449-MAS06077,Personalization 1 for climate control-Manual blower stage during defrost active,10,
    IDE01449-MAS06366,Personalization 1 for climate control-Display blower levels,0,
    IDE01449-ENG122610,Personalization 1 for climate control-Test_Program_Blower_Step_Absolut,14,
    IDE01449-ENG122611,Personalization 1 for climate control-Test_Program_Manual fan speed increase,11,
    IDE01450-IDE01011,Personalization 2 for climate control-Data record,active,
    IDE01450-MAS01533,Personalization 2 for climate control-Defrost,0,
    IDE01450-MAS01534,Personalization 2 for climate control-Recirculating air,0,
    IDE01450-MAS01550,Personalization 2 for climate control-AC,0,
    IDE01450-MAS01552,Personalization 2 for climate control-Left specified temperature,15.5, °C
    IDE01450-MAS01553,Personalization 2 for climate control-Right specified temperature,15.5, °C
    IDE01450-MAS01554,Personalization 2 for climate control-Left heated seat,0,
    IDE01450-MAS01555,Personalization 2 for climate control-Left seat ventilation,not installed,
    IDE01450-MAS01556,Personalization 2 for climate control-Right heated seat,0,
    IDE01450-MAS01557,Personalization 2 for climate control-Right seat ventilation,not installed,
    IDE01450-MAS01560,Personalization 2 for climate control-OFF,0,
    IDE01450-MAS01562,Personalization 2 for climate control-Air quality sensor,1,
    IDE01450-MAS01563,Personalization 2 for climate control-Auxiliary Air Heater,not installed,
    IDE01450-MAS01566,Personalization 2 for climate control-Style,not installed,
    IDE01450-MAS01567,Personalization 2 for climate control-Synchronization,1,
    IDE01450-MAS02015,Personalization 2 for climate control-AUTO,0,
    IDE01450-MAS02804,Personalization 2 for climate control-Manual fan speed increase,11,
    IDE01450-MAS03830,Personalization 2 for climate control-Footwell air distribution,0,
    IDE01450-MAS03831,Personalization 2 for climate control-Upper body vent air distribution,0,
    IDE01450-MAS03832,Personalization 2 for climate control-Air distribution up,0,
    IDE01450-MAS04620,Personalization 2 for climate control-Fan setting: absolute,1,
    IDE01450-MAS04621,Personalization 2 for climate control-Left cabin heater,not installed,
    IDE01450-MAS04648,Personalization 2 for climate control-Right cabin heater,not installed,
    IDE01450-MAS06077,Personalization 2 for climate control-Manual blower stage during defrost active,10,
    IDE01450-MAS06366,Personalization 2 for climate control-Display blower levels,1,
    IDE01450-ENG122610,Personalization 2 for climate control-Test_Program_Blower_Step_Absolut,4,
    IDE01450-ENG122611,Personalization 2 for climate control-Test_Program_Manual fan speed increase,11,
    IDE01451-IDE01011,Personalization 3 for climate control-Data record,not active,
    IDE01451-MAS01533,Personalization 3 for climate control-Defrost,0,
    IDE01451-MAS01534,Personalization 3 for climate control-Recirculating air,0,
    IDE01451-MAS01550,Personalization 3 for climate control-AC,1,
    IDE01451-MAS01552,Personalization 3 for climate control-Left specified temperature,22.0, °C
    IDE01451-MAS01553,Personalization 3 for climate control-Right specified temperature,22.0, °C
    IDE01451-MAS01554,Personalization 3 for climate control-Left heated seat,0,
    IDE01451-MAS01555,Personalization 3 for climate control-Left seat ventilation,not installed,
    IDE01451-MAS01556,Personalization 3 for climate control-Right heated seat,0,
    IDE01451-MAS01557,Personalization 3 for climate control-Right seat ventilation,not installed,
    IDE01451-MAS01560,Personalization 3 for climate control-OFF,0,
    IDE01451-MAS01562,Personalization 3 for climate control-Air quality sensor,0,
    IDE01451-MAS01563,Personalization 3 for climate control-Auxiliary Air Heater,not installed,
    IDE01451-MAS01566,Personalization 3 for climate control-Style,not installed,
    IDE01451-MAS01567,Personalization 3 for climate control-Synchronization,0,
    IDE01451-MAS02015,Personalization 3 for climate control-AUTO,1,
    IDE01451-MAS02804,Personalization 3 for climate control-Manual fan speed increase,11,
    IDE01451-MAS03830,Personalization 3 for climate control-Footwell air distribution,0,
    IDE01451-MAS03831,Personalization 3 for climate control-Upper body vent air distribution,0,
    IDE01451-MAS03832,Personalization 3 for climate control-Air distribution up,0,
    IDE01451-MAS04620,Personalization 3 for climate control-Fan setting: absolute,1,
    IDE01451-MAS04621,Personalization 3 for climate control-Left cabin heater,not installed,
    IDE01451-MAS04648,Personalization 3 for climate control-Right cabin heater,not installed,
    IDE01451-MAS06077,Personalization 3 for climate control-Manual blower stage during defrost active,10,
    IDE01451-MAS06366,Personalization 3 for climate control-Display blower levels,0,
    IDE01451-ENG122610,Personalization 3 for climate control-Test_Program_Blower_Step_Absolut,14,
    IDE01451-ENG122611,Personalization 3 for climate control-Test_Program_Manual fan speed increase,11,
    IDE01452-IDE01011,Personalization 4 for climate control-Data record,not active,
    IDE01452-MAS01533,Personalization 4 for climate control-Defrost,0,
    IDE01452-MAS01534,Personalization 4 for climate control-Recirculating air,0,
    IDE01452-MAS01550,Personalization 4 for climate control-AC,0,
    IDE01452-MAS01552,Personalization 4 for climate control-Left specified temperature,22.0, °C
    IDE01452-MAS01553,Personalization 4 for climate control-Right specified temperature,22.0, °C
    IDE01452-MAS01554,Personalization 4 for climate control-Left heated seat,0,
    IDE01452-MAS01555,Personalization 4 for climate control-Left seat ventilation,not installed,
    IDE01452-MAS01556,Personalization 4 for climate control-Right heated seat,0,
    IDE01452-MAS01557,Personalization 4 for climate control-Right seat ventilation,not installed,
    IDE01452-MAS01560,Personalization 4 for climate control-OFF,0,
    IDE01452-MAS01562,Personalization 4 for climate control-Air quality sensor,0,
    IDE01452-MAS01563,Personalization 4 for climate control-Auxiliary Air Heater,not installed,
    IDE01452-MAS01566,Personalization 4 for climate control-Style,not installed,
    IDE01452-MAS01567,Personalization 4 for climate control-Synchronization,0,
    IDE01452-MAS02015,Personalization 4 for climate control-AUTO,1,
    IDE01452-MAS02804,Personalization 4 for climate control-Manual fan speed increase,11,
    IDE01452-MAS03830,Personalization 4 for climate control-Footwell air distribution,0,
    IDE01452-MAS03831,Personalization 4 for climate control-Upper body vent air distribution,0,
    IDE01452-MAS03832,Personalization 4 for climate control-Air distribution up,0,
    IDE01452-MAS04620,Personalization 4 for climate control-Fan setting: absolute,1,
    IDE01452-MAS04621,Personalization 4 for climate control-Left cabin heater,not installed,
    IDE01452-MAS04648,Personalization 4 for climate control-Right cabin heater,not installed,
    IDE01452-MAS06077,Personalization 4 for climate control-Manual blower stage during defrost active,10,
    IDE01452-MAS06366,Personalization 4 for climate control-Display blower levels,0,
    IDE01452-ENG122610,Personalization 4 for climate control-Test_Program_Blower_Step_Absolut,14,
    IDE01452-ENG122611,Personalization 4 for climate control-Test_Program_Manual fan speed increase,11,
    IDE02270-IDE00002,CAN input signal(s) status-Transport mode,OFF,
    IDE02270-IDE01211,CAN input signal(s) status-Static current measuring mode,OFF,
    IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
    IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
    IDE02270-MAS01269,CAN input signal(s) status-Wipe wash,OFF,
    IDE02270-MAS01277,CAN input signal(s) status-Rear window heater actual value,OFF,
    IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
    IDE03488,Driving time remaining for basic setting of compressor run in,0, s
    IDE04312-IDE04095,System run time-Engine running time,0, s
    IDE04312-MAS00084,System run time-Terminal 15 on,253, s
    IDE04797,Center push-and-rotary knob counter,0,
    IDE04805-MAS01447,Driving profile selection-Act.val.,0,
    IDE04805-MAS01448,Driving profile selection-Specified value,0,
    IDE04805-MAS03559,Driving profile selection-System status 1,2,
    IDE04805-MAS03917,Driving profile selection-Driver intention,0,
    IDE04805-MAS05471,Driving profile selection-Efficiency,Efficiency mode not active,
    IDE05725,Terminal 58xs dimmer,0, %
    IDE05726,Terminal 58xd dimmer,253,
    IDE06091-MAS04647,Humidity sensor: internal-Dew point,18.3, °C
    IDE06091,Humidity sensor: internal,41.0, °C
    IDE06091,Humidity sensor: internal,-34.0, °C
    IDE06091,Humidity sensor: internal,not installed,
    IDE06091-ENG122608,Humidity sensor: internal-Test_Program_relative_humidity,27.0, %
    IDE06091-ENG122607,Humidity sensor: internal-Test_Program_sensor_temperature,41.0, °C
    IDE06091-ENG122606,Humidity sensor: internal-Test_Program_windshield_temperature,41.0, °C
    IDE06163-MAS04628,External humidity sensor-Air temperature,34.7, °C
    IDE06163-MAS04629,External humidity sensor-Sensor temperature,38.4, °C
    IDE06163-MAS04630,External humidity sensor-Relative humidity,0.0, %
    IDE06163-MAS04647,External humidity sensor-Dew point,18.5, °C
    IDE06163-ENG122609,External humidity sensor-Test_Program_Air temperature,34.7, °C
    IDE06163-ENG122608,External humidity sensor-Test_Program_relative_humidity,31.0, %
    IDE06163-ENG122607,External humidity sensor-Test_Program_sensor_temperature,38.4, °C
    IDE06201,Blower reduction,No switch-off: no reduction,
    IDE06545,Blower voltage for production routines,12, V
    IDE06546,Interior target temperature for production routines,22, °C
    IDE06547,Air distribution for production routines,Footwell air distribution,
    IDE06593,Recirculation air for production routines,Recirculating air,
    IDE06750-IDE01011,Last customer settings-Data record,active,
    IDE06750-MAS01533,Last customer settings-Defrost,0,
    IDE06750-MAS01534,Last customer settings-Recirculating air,0,
    IDE06750-MAS01550,Last customer settings-AC,0,
    IDE06750-MAS01552,Last customer settings-Left specified temperature,15.5, °C
    IDE06750-MAS01553,Last customer settings-Right specified temperature,15.5, °C
    IDE06750-MAS01554,Last customer settings-Left heated seat,0,
    IDE06750-MAS01555,Last customer settings-Left seat ventilation,not installed,
    IDE06750-MAS01556,Last customer settings-Right heated seat,0,
    IDE06750-MAS01557,Last customer settings-Right seat ventilation,not installed,
    IDE06750-MAS01560,Last customer settings-OFF,0,
    IDE06750-MAS01562,Last customer settings-Air quality sensor,1,
    IDE06750-MAS01563,Last customer settings-Auxiliary Air Heater,not installed,
    IDE06750-MAS01566,Last customer settings-Style,not installed,
    IDE06750-MAS01567,Last customer settings-Synchronization,1,
    IDE06750-MAS02015,Last customer settings-AUTO,0,
    IDE06750-MAS02804,Last customer settings-Manual fan speed increase,11,
    IDE06750-MAS03830,Last customer settings-Footwell air distribution,0,
    IDE06750-MAS03831,Last customer settings-Upper body vent air distribution,0,
    IDE06750-MAS03832,Last customer settings-Air distribution up,0,
    IDE06750-MAS04620,Last customer settings-Fan setting: absolute,1,
    IDE06750-MAS04621,Last customer settings-Left cabin heater,not installed,
    IDE06750-MAS04648,Last customer settings-Right cabin heater,not installed,
    IDE06750-MAS06077,Last customer settings-Manual blower stage during defrost active,10,
    IDE06750-MAS06366,Last customer settings-Display blower levels,1,
    IDE06750-ENG122610,Last customer settings-Test_Program_Blower_Step_Absolut,4,
    IDE06750-ENG122611,Last customer settings-Test_Program_Manual fan speed increase,11,
    IDE06926-MAS00106,History memory: reset counter-Year,2127,
    IDE06926-MAS00107,History memory: reset counter-Month,15,
    IDE06926-MAS00108,History memory: reset counter-Day,31,
    IDE06926-MAS00109,History memory: reset counter-Hours,31,
    IDE06926-MAS00110,History memory: reset counter-Minutes,63,
    IDE06926-MAS00111,History memory: reset counter-Seconds,63,
    IDE06926,History memory: reset counter,Measured value not available,
    IDE07617-IDE05241,Compressor status: global-A/C compressor release status,not transmitted,
    IDE07617-IDE06336,Compressor status: global-A/C compressor: target speed,0, /min
    IDE07617-IDE06337,Compressor status: global-A/C compressor: actual speed,0, /min
    IDE07617-MAS04770,Compressor status: global-A/C compressor: function status,Air conditioner compressor off,
    IDE07617-MAS05974,Compressor status: global-A/C compressor error indicator,not active,
    IDE07617-MAS05975,Compressor status: global-A/C compressor: veh. elec. syst. volt.,Measured value not available,
    IDE07617-MAS05976,Compressor status: global-A/C compressor: inverter temperature,44, °C
    IDE07618-MAS04779,Compressor status: internal-A/C compressor: power limitation,not active,
    IDE07618-MAS05976,Compressor status: internal-A/C compressor: inverter temperature,OK,
    IDE07618-MAS05979,Compressor status: internal-A/C compressor: start-up monitor,OK,
    IDE07618-MAS05980,Compressor status: internal-A/C compressor: internal inverter communication,OK,
    IDE07618-MAS05981,Compressor status: internal-A/C compressor: Communication internal gateway,OK,
    IDE07618-MAS05982,Compressor status: internal-A/C compressor: icing protection,not active,
    IDE07618-MAS05983,Compressor status: internal-Inverter: Status,not active,
    IDE07618-MAS05984,Compressor status: internal-A/C compressor: speed (RPM) protection,not active,
    IDE09168-MAS01632,Refrigerant cut-off valve 1-Status,Open,
    IDE09169-MAS01632,Refrigerant cut-off valve 2-Status,Open,
    IDE09171-MAS01447,Coolant circulation pump 1-Act.val.,100,
    IDE09171-MAS01448,Coolant circulation pump 1-Specified value,1,
    IDE09172,Coolant change-over valve 1,not activated,
    IDE09173-MAS01447,Coolant circulation pump 2-Act.val.,0,
    IDE09173-MAS01448,Coolant circulation pump 2-Specified value,0,
    IDE09174,Coolant change-over valve 2,operated,
    IDE09179-MAS01632,Relay for standstill A/C: status-Status,operated,
    IDE09186-MAS01447,Coolant circulation pump 3-Act.val.,0,
    IDE09186-MAS01448,Coolant circulation pump 3-Specified value,100,
    IDE09189-IDE09201,HV heater temperature-Intake temperature,34.0, °C
    IDE09189-IDE09202,HV heater temperature-Exhaust Temperature,34.0, °C
    IDE09190,Coolant change-over valve 3,not activated,
    IDE09197,Temp sensor 5,44.0, °C
    IDE09198-MAS01448,HV heater status: global-Specified value,0, %
    IDE09198-MAS08432,HV heater status: global-Requirement,active,
    IDE09199-IDE09201,HV heater status: internal-Intake temperature,34, °C
    IDE09199-IDE09202,HV heater status: internal-Exhaust Temperature,34, °C
    IDE09199-MAS01481,HV heater status: internal-Temperature in control module,45, °C
    IDE09199-MAS01634,HV heater status: internal-Supply voltage,13.2, V
    IDE09199-MAS02246,HV heater status: internal-Timeout,OK,
    IDE09199-MAS03746,HV heater status: internal-Current: actual value,0.00, A
    IDE09199-MAS07055,HV heater status: internal-Response error,OK,
    IDE09199-MAS09468,HV heater status: internal-Vehicle high voltage system,OK,
    IDE09199-MAS09469,HV heater status: internal-HV heater: status,OK,
    IDE09199-ENG128274,HV heater status: internal-PTC_HV_Err_Heizkreis_1,OK,
    IDE09199-ENG128275,HV heater status: internal-PTC_HV_Err_Heizkreis_2,OK,
    IDE09199-ENG128276,HV heater status: internal-PTC_HV_Err_Heizkreis_3,OK,
    IDE09199-ENG128280,HV heater status: internal-PTC_HV_Err_intern,OK,
    IDE09199-ENG128277,HV heater status: internal-PTC_HV_Err_Leckagestrom,OK,
    IDE09199-ENG128279,HV heater status: internal-PTC_HV_Err_Temperaturschutz,OK,
    IDE09199-ENG128278,HV heater status: internal-PTC_HV_Err_Ueberstromabschaltung,OK,
    IDE09199-ENG128267,HV heater status: internal-supply_voltage_status,OK,
    IDE09203,HV heater shut-off condition,Temperature flap: cold stop,
    IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,0, min
    IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,1,
    IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,0, W
    IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,100, W
    IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,0, Ws
    IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,no overflow,
    IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,0, Ws
    IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,no overflow,
    MAS00464-MAS00107,Standard - ambient data 1-Month,8,
    MAS00464-MAS00108,Standard - ambient data 1-Day,4,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,8,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,10,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,153,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,31012, km
    MAS05977-IDE01233,Compressor: energy monitor-Compressor motor current,0.00, A
    MAS05977-IDE05237,Compressor: energy monitor-A/C compressor power consumption: actual value,0.00, kW
    MAS05977-MAS05978,Compressor: energy monitor-High voltage supply voltage,370, V
    Elapsed Time: 00:12
    ADP
    ;Saturday,04,August,2018,17:08:37:50490
    IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
    IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
    IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
    IDE01476-Store recirculation air setting for terminal 15 off,Matching coding ,1
    IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
    IDE01482-After-run of parking heater or parking ventilation,not activated ,1
    IDE01483-Blower voltage for voice operation,activated ,1
    IDE01490-Fresh air blower voltage offset,Default ,1
    IDE01491-Temperature offset: summer operation,Default ,1
    IDE01492-Temperature offset: winter operation,Default ,1
    IDE01493-Air quality sensor sensitivity,Little ,1
    IDE01495-After-run time of auxiliary heater with A/C off,120 s,1
    IDE01500-Window condensation reduction at high humidity,Matching coding ,1
    IDE01503-Runtime for compressor run-in basic setting,120 s,1
    IDE01505-Tolerance range for basic setting of flap end stops,15 °,1
    IDE01506-Tolerance range for flap end stops,10 °,1
    IDE02155-Reset all counters,not activated ,1
    IDE02371-Time until heated seat power withdrawal stage 3 to stage 2,10 min,1
    IDE02372-Time until heated seat power withdrawal stage 2 to stage 1,0 min,1
    IDE03176-Duration of compressor run in,20 s,1
    IDE04074-Driving program,Matching coding ,1
    IDE06326-Tolerance: compressor speed during compressor run-in,950 /min,1
    IDE06545-Blower voltage for production routines,12 V,1
    IDE06546-Interior target temperature for production routines,22 °C,1
    IDE06547-Air distribution for production routines,Footwell air distribution ,1
    IDE06593-Recirculation air for production routines,Recirculating air ,1
    IDE07106-Application characteristic curves,Matching coding ,1
    IDE07108-Climate modes,Matching coding ,1
    IDE07398-Blower logic for manual adjustment,Matching coding ,1
    IDE10278-Behavior of compressor during moderate outside temperatures,not active ,1
    IDE80006-Analysis 6,not activated ,1
    IDE80007-Analysis 7,00 00 ,2
    IDE80008-Analysis 8,activated ,1
    IDE80009-Analysis 9,not activated ,1
    IDE80011-Analysis 11,not activated ,1
    IDE80013-Analysis 13,4.0 s,1
    Elapsed Time: 00:08
  7. #26
    Aug 2018
    More AutoScans (Beta)
    VCDS Beta
    Saturday,04,August,2018,18:30:07:50490
    VCDS Version: 18.7.1.1 (x64)  HEX-NET CB: 0.4427.4
    VIN: WAUZZZ8V6HA000000   License Plate: A3-ETRON
    Mileage: 31017km-19273mi   Repair Order: 1808041830
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
              8C A5 C6
    VIN: WAUZZZ8V6HA000000   Mileage: 31017km-19273miles
    Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AR    HW: 04E 907 309 F
       Component: R4 1.4l TFS   H22 3440
       Revision: X3H22---
       Coding: 021D0012636401083000
       Shop #: WSC 00000 000 00021
       ASAM Dataset: EV_ECM14TFS01104E906023AR 008003
       ROD: EV_ECM14TFS01104E906023AR_008.rod
       VCID: 70AC0F90AB6629CAE4-8024
       Part No SW: 0DD 300 046     HW: 0DD 927 770 C
       Component: GSG DQ400E    H32 1604
       Revision: 00032034    Serial number: TFK01611200000
       Shop #: WSC 00099 780 00200
       ROD: EV_TCMDQ400021_AU37.rod
       VCID: 65826EC464A4FC6287-8030
    30097 - Transmission Fluid Pressure
              P0867 00 [040] - Function Restriction due to Low Pressure
                        Mileage: 30534 km
                        Date: 2018.07.30
                        Time: 09:48:25
                        Engine speed: 18.75 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 70 km/h
                        Control Module temperature: 22 °C
                        CURRENT pressure: -10.0 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_7
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 12032
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
       Component: ESC           H62 0855
       Revision: 00000000    Serial number: 63546000000000
       Coding: 12F140A23829227189800E0941C52948021C44917082947218B15074822802
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003_VW48.rod
       VCID: 7CB42BA0F72E5DAA48-8028
    8400 - Databus
              [FCAN: AB_Gurt_FA signal is invalid]
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0710
       Revision: 00021000    Serial number: 0426600000
       Coding: 030C0C
       VCID: 3B36E8BCB2A09A9201-806E
       Part No SW: 8V0 820 043 R    HW: 8V0 820 043 R
       Component: AC Automat    H03 0110
       Revision: 20002000    Serial number: 00000001100000
       Coding: 0300000000001000080000000000100001000000
       ASAM Dataset: EV_AirCondiFrontRDWAU37X 001019
       ROD: EV_AirCondiFrontRDWAU37X.rod
       Subsystem 1 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
       Component: J848 HV-PTC  200 0204
       Serial number: -00104.8T.3A20300000
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: DA48C06880PAG0M00000
       Subsystem 3 - Part No SW: 5QE 816 803     HW: 5QE 816 803
       Component: J842 eKK  H02 0007
    393474 - Air Blower
              B10BE 1D [032] - Current Implausible
              [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Kurzschluss oder blockiert]
       Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H34 0236
       Serial number: 02001700200000
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EB021A8E1324FBA66-802A
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 161015  043 0580
       Serial number:         161029100000
       Coding: 0A47F7
       Serial number: 62500000
       Coding: 00006C
       Component: E1 - LDS MQB  H06 0032
       Serial number: 22 10 2016  00000000
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: 5500E7C111FFC728949C8045000026
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
       Part No SW: 5Q0 959 655 AM    HW: 5Q0 959 655 AM
       Component: AirbagVW21    003 0317
       Serial number: 003PGR00000%
       Coding: 98CCC0000C2000009C540000004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 0B56787CA2806A1271-805E
       Subsystem 1 - Part No SW: -----------    HW: 480 000 701 17
       Serial number: 3570000000040000002H
       Subsystem 2 - Part No SW: -----------    HW: 480 000 701 17
       Serial number: 358000000006A000002M
       Subsystem 3 - Part No SW: -----------    HW: 480 400 901 17
       Serial number: 3510001C523B3B000002
       Subsystem 4 - Part No SW: -----------    HW: 480 400 901 17
       Serial number: 3520001A523B3B00000Y
       Subsystem 5 - Part No SW: -----------    HW: 480 401 311 16
       Serial number: 3550002B523C4E000003
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 711 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001BB23B3B000003
       Subsystem 7 - Part No SW: -----------    HW: 480 400 711 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001BB23B3B000009
       Subsystem 8 - Part No SW: -----------    HW: 480 001 212 16
       Serial number: I0M0000000076500000Y
       Subsystem 9 - Part No SW: -----------    HW: 480 001 212 16
       Serial number: I0N0000000005500000R
       Part No SW: 8V0 953 521 MS    HW: 5Q0 953 549 D
       Component: Lenks. Modul  004 0140
       Revision: --------    Serial number: 17101604400000
       Coding: EC18
       VCID: 177E140CEE489EF2C5-8042
       Part No SW: 8V0 920 873 H    HW: 8V0 920 873 H
       Component: KOMBI         H05 8316
       Coding: 07040C186F800008008328101200000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 43C6905CCA50E25249-8016
       Part No SW: 3Q0 907 530 D    HW: 3Q0 907 530 D
       Component: GW MQB EV     615 6286
       Serial number: 14121610800000
       Coding: 0201001726F200005B001218581000000001010100010000000300000000
       ROD: EV_GatewNF_AU27.rod
       VCID: 302CCF906BE669CAA4-8064
       Subsystem 1 - Part No SW: 81A 951 523 B    HW: 81A 951 523 B
       Component: J453 MFL  H04 0003
       Serial number: 20160830000000 20175
       Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
       Serial number: 7895800000
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
       Component: EBKV          H14 0200
       Serial number:   085430000000
       Coding: 03720100331900010002050500
       Shop #: WSC 52735 001 1048576
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
       ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
       VCID: 50ECAF100B2609CAC4-8004
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861301116100000
       Revision: 00000000    Serial number: 16000229700000
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424C3809FFE55EAC0-8060
       Serial number: 251116EKP00000
       Coding: 00101F205C00040000001003
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000012700000
       Coding: 110000
       Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  128 1072
       Coding: D106
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45C28E44C464DC6267-8010
    Address 51: Electric Drive (J841)       Labels: Redir Fail!
       Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
       Component: LE Gen 3.3H11 1032
       Revision: 00H11000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM08530115G0907080E 001008
       ROD: EV_DMCM08530115G0907080E.rod
       VCID: 291A22F4483C180263-807C
    33109 - DC/DC Converter
              P33CB 00 [032] - Internal Malfunction
                        Fault Frequency: 112
       Serial number: 151216ELF00000
       Coding: 001017205E00040000001003
       VCID: 42C89558D54AEB5A42-8016
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
       Coding: 090000
    Address 55: Headlight Range (J745)       Labels:* None
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0E5A00102B200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E30E1A8A1B28FBA26-806A
       Part No SW: 81A 035 842 A    HW: 81A 035 842 A
       Component: MU-S-D-ER     710 0771
       Coding: 01739300FF00000011111101000A02002F0027440170010002
       ASAM Dataset: EV_MUStd6C3DELP 001013
       ROD: EV_MUStd6C3DELP_AU37.rod
       VCID: 210A3AD4300CD0423B-8074
       Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY200000
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 BB    HW: 8V0 919 614 BB
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL114101600000000
    6660 - No Communications with Display Unit 1 for Multimedia
              U10E2 00 [008] - -
              [Display 1: no signal/communication]
                        Reset counter: 185
                        Mileage: 30871 km
                        Date: 2018.07.31
                        Time: 21:44:51
                        Voltage terminal 30: 12.4 V
       Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
       Component: OCULowMQBEU   012 0717
       Coding: 0173930110969A0100F800000000
       ROD: EV_OCULowMQB.rod
       VCID: 44C49340CF5EE56A70-8010
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
       Component: BECM          H05 0911
       Serial number: U6000000
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006040
       ROD: EV_BECM09620115Q0915182.rod
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
       Component: BJB  H28 0240
       Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0481
       Serial number: V013C1661700000
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0481
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0481
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0481
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0481
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0481
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0481
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0481
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 10011711K22189
       Coding: 0403070300000401012200448048A90084000E200020
       ROD: EV_MFKBoschMQBB_VW46.rod
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
       Component: OBC KOSTAL    H31 4013
       Revision: --------    Serial number: 0512160L200000
       Coding: 115068223000
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
       ROD: EV_OBCSinglPhaseKLOMQB12P.rod
       VCID: 116A6A14C0AC40C28B-8044
    End----------(Elapsed Time: 01:37, VBatt start/end: 13.1V/13.1V)-----------
    VCDS Mobile (Beta)
    VCDS Mobile 0.4427.0.4
    Scan: 01 02 03 05 08 09 13 15 16 17 19 23 2B 42 44 52 55 5F 75 A5
    	 C6
    Address 01: Engine  (CUKB J623)	Labels: 04-01.clb
    	Revision: X3H22---
    	VCID: 70A343C329B09B4B8163D252F8-8025
    No fault codes found.
    Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
    	Revision: 00032034
    	ROD: EV_TCMDQ400021.rod
    	VCID: E58DA2976672CEE362F5DBAEEF-80B0
    Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
    	Revision: 00000000
    	ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
    	VCID: 7CBB67F375F8EF2B2DDB56C204-8029
    8400 - Databus
    Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
    	Revision: 00021000
    	Coding: 030C0C
    	VCID: 3B39A4EF3076281364518DD649-806E
    Address 08: Auto HVAC  (E87)	Labels: 8V0-820-043.clb
    	Revision: 20002000
    	VCID: 41C5D607529A42C33E8DCF1E1B-8014
    	Subsystem 1 -
    	Subsystem 2 -
    393474 - Air Blower
    Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
    	ROD: EV_BCMMQB_017.rod
    	VCID: 7EBF6DFB63E4FD3B03EF6CFA22-802B
    	Subsystem 1 - 	Component:
    G÷
    	Subsystem 2 -
    	Subsystem 3 -
    Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
    	ROD: EV_ACCBOSCHVW416_001_AU37.rod
    Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
    	VCID: 8B59B42FA05658939471FD9659-80DE
    	Subsystem 1 - 	Part No SW: --------------
    	Component: ---
    	Subsystem 2 - 	Component: ---
    	Subsystem 3 - 	Component: ---
    	Subsystem 4 - 	Component: ---
    	Subsystem 5 - 	Component: ---
    	Subsystem 6 - 	Component: ---
    	Subsystem 7 - 	Component: ---
    	Subsystem 8 - 	Component: ---
    Address 16: Steering wheel  (J527)	Labels: 8V-16.lbl
    	Revision: --------
    	Coding: EC18
    	VCID: 9771D85FEC9EAC7320E98106E5-80C2
    Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
    	ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
    	VCID: 43C9DC0F488650D32CA1E53621-8016
    Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
    	ROD: EV_GatewNF_AU37.rod
    	VCID: 302383C3E930DB4BC1E3125238-8065
    	Subsystem 1 - 	Part No SW: 81A-951-523-B
    	Component: J453 MFL
    	Subsystem 2 -
    Address 23: Brake Booster  (J539)	Labels: None
    	ROD: EV_BrakeBoostBoschMQBOMG_004.rod
    	VCID: 50E3E34389F0BB4BA12372D258-8005
    Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
    	Revision: 00000000
    	ROD: EV_ELVMarquMQB_004.rod
    	VCID: 342B8FD31D28E76BA50B3E62EC-8061
    Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
    	ROD: EV_DCUDriveSideEWMAXKLO.rod
    Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
    	Coding: D106
    	VCID: 45CDC21746B26EE302B5FB2ECF-8010
    Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
    	ROD: EV_DCUPasseSideEWMAXKLO.rod
    	VCID: 42C7D90B579C59DB2797D80A16-8017
    Address 55: Xenon Range  (J745)	Labels: None
    	Revision: --------
    	VCID: 3E3FADFB23643D3B436FACFA62-806B
    Address 5F: Information Electr.  (J794)	Labels: None
    	ROD: EV_MUStd6C3DELP.rod
    	VCID: 21057687B2DA62C35E4D6F9EFB-8074
    	Subsystem 1 - 	Part No SW: 8V0-919-604-C
    	Component: DU High
    	Subsystem 2 -
    	U10E2 00 [008] -
    Address 75: Telematics  (J949)	Labels: 5Q-75.clb
    	VCID: 44CBDF134D8857EB15ABEE223C-8011
    Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
    	ROD: EV_MFKBoschMQBB_AU37.rod
    Address C6: Batt. Chrg.  (J1050)	Labels: None
    	Revision: --------
    	VCID: 9165A647C27A72436EAD3FDE2B-80C4
  8. Likes Uwe liked this post
  9. #27
    Aug 2018
    AutoScan VCDS Mobile (0.4435)
    The major difference to VCDS (desktop) is (still) that 8C (Hybrid Battery) is not detected as "Installed" and subsequently not listed in the AutoScan.
    VCDS Mobile 0.4435.0.4
    	 C6
    	Revision: X3H22---
    	VCID: 70A343C329B09B4B817280-8025
    	Revision: 00032034
    	VCID: E58DA2976672CEE362E489-80B0
    	Revision: 00000000
    	VCID: 7CBB67F375F8EF2B2DCA04-8029
    	Revision: 00021000
    	Coding: 030C0C
    	VCID: 3B39A4EF307628136440DF-806E
    	Revision: 20002000
    	VCID: 41C5D607529A42C33E9C9D-8014
    	Subsystem 1 -
    	Subsystem 2 - 	Part No SW: 5QE-816-803
    	VCID: 7EBF6DFB63E4FD3B03FE3E-802B
    	Subsystem 1 - 	Part No SW: 8V1-955-119-A	Labels: 5Qx-955-119-V1.clb
    	Component: WWS370 161015043 0580
    	Serial Number:         161029100000
    	Coding: 0A47F7
    	Subsystem 2 - 	Part No SW: 8U0-955-559-C	Labels: 8U0-955-559.clb
    	Serial Number: 62500000
    	Coding: 00006C
    	Subsystem 3 - 	Part No SW: 8V0-941-531-AR
    	Component: H06 0032
    	Serial Number: 22 10 2016  00000000
    	VCID: 8B59B42FA05658939460AF-80DE
    	Component: SideSensor_Df001 0887
    	Serial Number: 3570000000040AD00000
    	Subsystem 2 - 	Part No SW: --------------
    	Component: SideSensor_Pf001 0887
    	Serial Number: 358000000006A2D00000
    	Subsystem 3 - 	Part No SW: --------------
    	Component: SideSensor_Dr000 6149
    	Serial Number: 3510001C523B3B300000
    	Subsystem 4 - 	Part No SW: --------------
    	Component: SideSensor_Pr000 6149
    	Serial Number: 3520001A523B3B00000
    	Subsystem 5 - 	Part No SW: --------------
    	Component: FrontSensor_D001 6149
    	Serial Number: 3550002B523C4E500000
    	Subsystem 6 - 	Part No SW: --------------
    	Component: PedP_Sensor_D000 6149
    	Serial Number: 2280001BB23B3B500000
    	Subsystem 7 - 	Part No SW: --------------
    	Component: PedP_Sensor_P000 6149
    	Serial Number: 2290001BB23B3B500000
    	Subsystem 8 - 	Part No SW: --------------
    	Component: PedPSensor_D2001 0887
    	Serial Number: I0M00000000765700000
    	Revision: --------
    	Coding: EC18
    	VCID: 9771D85FEC9EAC7320F8D3-80C2
    	VCID: 43C9DC0F488650D32CB0B7-8016
    	VCID: 302383C3E930DB4BC1F240-8065
    	Serial Number: 20160830020125 00000
    	Subsystem 2 - 	Part No SW: 5QE-915-181-A
    	Component: J367-BDMHellaH10 9070
    	Serial Number: 7895800000
    	VCID: 50E3E34389F0BB4BA13220-8005
    	Revision: 00000000
    	VCID: 342B8FD31D28E76BA51A6C-8061
    65588 - Motor for Window Regulator
    	B1487 54 [008] - Missing Calibration / Basic Setting
    	Coding: D106
    	VCID: 45CDC21746B26EE302A4A9-8010
    	VCID: 42C7D90B579C59DB27868A-8017
    	Revision: --------
    	VCID: 3E3FADFB23643D3B437EFE-806B
    	VCID: 21057687B2DA62C35E5C3D-8074
    	Serial Number: AUZ8Z9GY200000
    	Subsystem 2 - 	Part No SW: 8V0-919-614-BB
    	Component: ControlUnit_BH50 0103
    	Serial Number: ALJAL114101600000000
    	VCID: 44CBDF134D8857EB15BABC-8011
    	Revision: --------
    	VCID: 9165A647C27A72436EBC6D-80C4
  10. Likes Uwe liked this post
  11. #28
    Aug 2018
    Cool
    Quote Originally Posted by henbo View Post
    That is so yesterday's problem
    https://forums.ross-tech.com/showthr...l=1#post141139
  12. Likes Eric, Uwe liked this post
