No rental car is safe from a Ross-Tech employee..... sitting in a parking garage in beautiful downtown Turku. For those of you who know me, and my phone number, text me if you want additional info while I've got this 1.0L beast.
Standard Auto-Scan:
Engine map, cold start
Engine map, +80c
Battery Regulation, engine at idle
Central Electronics, driver's door open
Standard Auto-Scan:
Thursday,02,August,2018,14:24:16:29015
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4422.4
VIN: WVWZZZAAZHD089244 License Plate:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 15 17 19 25 44 5F 61 AD
VIN: WVWZZZAAZHD089244 Mileage: 43350km-26936miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 EN HW: 04C 907 309 P
Component: R3 1.0l MPI H24 3171
Revision: UNH24---
Coding: 00110014020401000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020EN 002002
ROD: EV_ECM10MPI_VW12.rod
VCID: EB99C4FA02F4271C62-80BE
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 1S0-614-517.clb
Part No SW: 1S0 614 517 L HW: 1S0 614 517 L
Component: EBC 460 ESP H16 0023
Serial number: A01HLFC
Coding: 12BF247129B502FA48FC24F994AD40505FB100
ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: B8332BB603225C845F-80EC
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 132170075
Coding: 62B82B0000010000010007D06CEB8ED07940706D60CF2D602101000B0900
VCID: B62F258E0136AAF44D-80E2
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 090517 04 42 0106
Coding: 0228DD
Part No SW: 1S0 959 655 C HW: 1S0 959 655 C
Component: VW10Airbag02N H03 0007
Revision: -------- Serial number: 003UB001XD8D
Coding: 00000000000000000000000000000000324E
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
VCID: BE3F3DAE210662B495-80EA
Serial number: 3497ARB405L4NISUH9KZ
Serial number: 3507ARB405L4NISUBHR-
Serial number: 3557BRB405D473B0EGCT
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 861 R HW: 1S0 920 861 R
Component: KOMBI H63 0502
Revision: X0063001 Serial number: 00000000000000
Coding: 1142010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: C0C343565BF21444E7-8094
Part No SW: 1S0 909 901 HW: 1S0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: BW081001
Coding: 001201
VCID: F0A3D39623D2C4C457-80A4
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 861 R
Component: IMMO H63 0502
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: EA97C1FE0D0E3E1419-80BE
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AM HW: 6R1 909 144 E
Component: EPS_TRW_ALow 313 3142
Serial number: CH5G1214
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 8247895E157EC654B1-80D6
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1S0 035 871 HW: 1S0 035 871
Component: MU-E--EU 068 7288
Serial number: 08051700020870
Coding: 022100002800000041110001000002001F0002C40001010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: EC9BC7E607FA20246B-80B8
Part No SW: 1S0 907 534 HW: 1S0 937 090
Component: Batt.regelung H81 0744
Coding: 032B7864
Subsystem 1 - Part No SW: 1S0 915 181 C HW: 1S0 915 181 C
Component: J367-BDM H08 0270
Serial number: 64116L20175861398211
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H08 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: A813FBF6D382CC04CF-80FC
End----------(Elapsed Time: 00:45, VBatt start/end: 13.5V/13.5V)-----------
;SW:04C-906-020-EN HW:04C-907-309-P --- Engine
;Component:R3 1.0l MPI H24 3171, Coding:00110014020401000000
;EV_ECM10MPI01104C906020EN,002002,EV_ECM10MPI_VW12.rod
;Thursday,02,August,2018,14:12:55:29015
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: EB99C4FA02F4271C62-80BE
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WVWZZZAAZHD089244,
IDE00019,Voltage terminal 30,13.334, V
IDE00021,Engine speed,892, /min
IDE00025,Coolant temperature,38, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,36, s
IDE00083,Throttle valve position (absolute),14.9, %
IDE00084,Absolute load value,32, %
IDE00085,Normed load value,32.9, %
IDE00086,Accelerator position,14, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,29.1, Nm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00167,Exhaust temperature 1 bank 1,282.3, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00178,Camshaft adjustment intake bank 1: specified value,28.000, °
IDE00179,Camshaft adjustment intake bank 1: actual value,28.086, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,29.3, °C
IDE00196,Engine oil temperature,29.3, °C
IDE00304,Fuel level,35.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,30, °C
IDE00349,Throttle valve position: normed,5, %
IDE00350,Air mass: specified value,10.3, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00356-ENG57549,Cruise Control System (CCS): switch position-Bits 0-7,0,
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00371,Fuel consumption,0.82, l/h
IDE00375,Generator: load signal,48.34, %
IDE00392,Accelerator pedal: sensor voltage 1,719.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,362.4, mV
IDE00406,Camshaft speed (RPM),439.3, /min
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,81,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,101, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,13.7, Nm
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,27, °C
IDE00557,Oxygen sensor bank 1 sensor 1 (jump sensor),0.270 V / -6.25 %(lean),
IDE00560,Oxygen sensor bank 1 sensor 2 (jump sensor),0.505, V
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,6, %
IDE00584,Distance driven since erasing DTC memory,43342, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,96.9, %
IDE00592,Oxygen sensor control status,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,6.5, Degrees
IDE00594,Absolute intake pressure,45, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-2.3, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,-7.8, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00015,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE01076,Time since ignition off,44912, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,0, W
IDE01267,Height correction,1.00275,
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,Not operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.499, V
IDE01650,Throttle valve position 2,15, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01869,Long-term fuel trim bank 1 at idle,0.14, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,10.6121,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.116, %
IDE01876,Adaptation of loss torque,-0.2, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,5,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,5.000, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01899,Load value: corrected specified value,95.51, %
IDE01901,Lost torque adaptation: idle,1.9, Nm
IDE01902,Lost torque adaptation A/C compressor,-0.2, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.03229,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.01227,
IDE01911,Leakage air,-0.5, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01922,Vehicle distance driven,43354, km
IDE01923,Control module distance driven,43313744, m
IDE01975,Numb.of misfir.: cylinder 1,6604,
IDE01976,Numb.of misfir.: cylinder 2,5438,
IDE01977,Numb.of misfir.: cylinder 3,4954,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,154,
IDE02116,Exhaust gas temperature before catalytic converter,383.92, °C
IDE02117,Relative load value,29.91, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02756-ENG57549,Number of manual engine starts-Bits 0-7,98,
IDE02756-ENG57549,Number of manual engine starts-Bits 0-7,0,
IDE02756-ENG57549,Number of manual engine starts-Bits 0-7,8,
IDE02757-ENG57549,Number of automatic engine starts-Bits 0-7,0,
IDE02757-ENG57549,Number of automatic engine starts-Bits 0-7,113,
IDE02757-ENG57549,Number of automatic engine starts-Bits 0-7,4,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,41, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,7,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,20,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,43118, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,27,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,14,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,2013,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,9, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG103639,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,10,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99665,Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,13,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG100535,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,43179, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG99682,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,45,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG101771,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,14,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG104020,Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,2013,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03190-ENG103316,Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,0.80, °
IDE03236,Neutral position sensor: adapted transmission angle,0.70, °
IDE03246,Neutral position sensor: upper adaptation value,3120, mV
IDE03247,Neutral position sensor: lower adaptation value,1300, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.505, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.498, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.916, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.088, V
IDE03328,Transmission neutral position sensor voltage,2010, mV
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,62,
IDE03393-ENG57549,Selector lever position-Bits 0-7,0,
IDE03583-ENG57549,Engine shut-down overrides-Bits 0-7,20,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,1,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-ENG57549,Stop overrides for active participants-Bits 0-7,2,
IDE03587-ENG57549,Stop overrides for active participants-Bits 0-7,0,
IDE03588-ENG57549,System malfunctions for active participants start/stop-Bits 0-7,0,
IDE03589-ENG57549,Error status for start-stop related sensors-Bits 0-7,6,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,171,
IDE03694-ENG57549,Result of test of fuel supply system partial throttle-Bits 0-7,0,
IDE03696-ENG57549,Result test of oxygen sensor heater after catalytic converter-Bits 0-7,8,
IDE03697-ENG57549,Result test of oxygen sensor heater before catalytic converter-Bits 0-7,0,
IDE03699-ENG57549,Result of test of oxygen sensor before catalytic converter-Bits 0-7,228,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03708-ENG57549,Result of test 2 of oxygen sensor before catalytic converter-Bits 0-7,4,
IDE03709,Angle difference actual-specified camshaft adjuster,0.133, °
IDE03711,Mass flow through throttle valve,10.0, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,12,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,115072.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.ON,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,216,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.98010,
IDE03966,Transmission neutral position sensor PWM signal,40.26, %
IDE03968-ENG57549,Camshaft adaptation results-Bits 0-7,32,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,106.291431, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,66.246514, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04414,Cat conv temp: modeled,305, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,10.0, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04655-ENG57549,CAN status - transmission control module-Bits 0-7,0,
IDE04656-ENG57549,CAN status - brake control module 1-Bits 0-7,0,
IDE04657-ENG57549,CAN status - brake control module 2-Bits 0-7,0,
IDE04662-ENG57549,CAN TimeOut meter - transmission-Bits 0-7,0,
IDE04663-ENG57549,Cruise control switch-off: irreversible-Bits 0-7,255,
IDE04664-ENG57549,Cruise control switch-off: reversible-Bits 0-7,255,
IDE04665-ENG57549,Cruise control switch-off: irreversible w. brake intervention-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,1.0000,
IDE04688-ENG57549,Engine control module reset status-Bits 0-7,0,
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04706-ENG57549,ACC interface activation condition-Bits 0-7,0,
IDE04707-ENG57549,Status of reversible switch-off condition ACC_2-Bits 0-7,0,
IDE04708-ENG57549,Status of reversible switch-off condition ACC_3-Bits 0-7,0,
IDE04709-ENG57549,Status of ACC/CCS acceleration interface-Bits 0-7,0,
IDE04710-ENG57549,ACC control module received status-Bits 0-7,0,
IDE04712-ENG57549,Active brake system error status-Bits 0-7,0,
IDE04887,Powertrain target torque,-28.8, Nm
IDE04889,Target torque for combustion engine crankshaft level,-14.9, Nm
IDE05128,Intake air temperature in intake manifold bank 1,31.5, °C
IDE05134,ACC target acceleration,0.000, m/s²
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05140,Intake manifold pressure raw value,466.02, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,1.54,
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0246, rad
IDE05443,Acceleration interface braking torque specified value,0.0, Nm
IDE05444,Air filling: specified value,30.56, %
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,131070, Ohm
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,0.836,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,10.5, kg/h
IDE05479,Misfire recognition reference moment,17.056, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE06006,Idle speed specified value,860, /min
IDE06024-ENG57549,Intake manifold pressure sensor diagnostic release-Bits 0-7,0,
IDE06039,Required RPM at idle speed,860.0, /min
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06098,Sensor control factor: output value,0.92996,
IDE06192,Knock sensor: cylinder 2: voltage,0.850, V
IDE06193,Knock sensor: cylinder 3: voltage,0.542, V
IDE06195,Knock sensor: cylinder 1: voltage,0.522, V
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06432,Oxygen sensor 1 bank 1 signal status,1,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,9948, hPa
IDE06436,A/C compressor: refrigerant pressure: raw value,31.34, %
IDE06443,Oper. readiness status oxyg. sensor bank 1 before cat. conv.,1,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,0.440, V
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,0,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06706-ENG57549,ACC variants-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,0,
IDE06759,Cam shaft adaptation inlet: counter,5,
IDE06795,Oxygen sensor 1 bank 1 intern. resistance,442, Ohm
IDE06796,Oxygen sensor 1 bank 1 intern. resistance limit,17950, Ohm
IDE06800,A/C main switch status,1,
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07102,Evaporator temperature A/C system actual value,6.2, °C
IDE07103,Evaporator temperature A/C system unconditioned voltage,4104.8, mV
IDE07104-ENG57549,Coolant fan stage 1 activation signal relay 1-Bits 0-7,1,
IDE07105-ENG57549,Coolant fan stage 2 activation signal relay 2-Bits 0-7,0,
IDE07125,Result of dynamic test of jump sensor before cat. converter,B1-S1 OK,
IDE07125-ENG130132,Result of dynamic test of jump sensor before cat. converter-Test_Program_Channel 111,237,
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07371,O2 heater resistance: act. value filtered,3.70, Ohm
IDE07573,Throttle valve adapter: actual value,6.08, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,1,
ENG112666,Air conditioner pressure linearised raw value,9824, hPa
ENG101413,Calibration Identification,04C020EN3171BAAD,
ENG99697,Calibration Verification Number,B9 CD 26 E0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,3.643, ms
ENG112667,Generator load normalised value,51.57, %
ENG112929,Generator_torque_request,4.0, Nm
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,9.6, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1,02 14 08 68 02 95 02 14 00 00 00 00 02 4E 02 14 00 00 00 00 06 6A 02 14 00 00 00 00 00 00 00 00 02 5A 02 14 00 00 00 00,
ENG111606,Load value: unrestricted commanded value,29.98, %
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG114216,Ox_sensor_bank_1_sensor_1_char_line_adapted_value_lean_range,0.99,
ENG114217,Ox_sensor_bank_1_sensor_1_char_line_adapted_value_rich_range,1.01,
ENG114218,Ox_sensor_bank_1_sensor_1_char_line_offset_adapted_value,-0.00204,
ENG114219,Ox_sensor_low_temp_ctrl_bank_1_sensor_1_filtered_comm_value,88880, Ohm
ENG114215,Oxygen_sensor_bank_1_sensor_1_cell_resistance_adapted_value,-4.2,
ENG114213,Oxygen_sensor_bank_1_sensor_1_cell_resistance_plausibility,0,
ENG114214,Oxygen_sensor_heater_bank_1_sensor_1_resistance_plausibility,0,
ENG114221-ENG114212,Oxygen_sensor_heater_ctrl_bank_1_sensor_1_activation_status-Buhsv Ext,1,
Elapsed Time: 00:27
Engine map, +80c
;Thursday,02,August,2018,14:22:37:29015
IDE00019,Voltage terminal 30,13.264, V
IDE00021,Engine speed,784, /min
IDE00025,Coolant temperature,86, °C
IDE00078,Time since engine start,618, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,18, %
IDE00085,Normed load value,21.2, %
IDE00086,Accelerator position,15, %
IDE00100,Engine torque,15.3, Nm
IDE00167,Exhaust temperature 1 bank 1,444.4, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00179,Camshaft adjustment intake bank 1: actual value,27.977, °
IDE00182,Camshaft adaptation intake bank 1: phase position,3.16, °
IDE00196,Engine oil temperature,55.5, °C
IDE00348,Intake air temperature,40, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,4.1, kg/h
IDE00371,Fuel consumption,0.43, l/h
IDE00375,Generator: load signal,51.57, %
IDE00393,Accelerator pedal: sensor voltage 2,363.6, mV
IDE00406,Camshaft speed (RPM),389.8, /min
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,0,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00477,Torque request: sum of auxiliary aggregate,3.6, Nm
IDE00557,Oxygen sensor bank 1 sensor 1 (jump sensor),0.095 V / 0.00 %(),
IDE00560,Oxygen sensor bank 1 sensor 2 (jump sensor),0.760, V
IDE00583,Throttle valve specified value,3, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00594,Absolute intake pressure,32, kPa abs
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00612,Target position of EVAP canister valve,44.3, %
IDE01267,Height correction,1.00189,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.758, V
IDE01650,Throttle valve position 2,12, %
IDE01869,Long-term fuel trim bank 1 at idle,0.05, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01873,Test of catalytic converter: measured value,12.0000,
IDE01875,Required torque adjustment by idling regulator,0.058, %
IDE01876,Adaptation of loss torque,2.4, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01899,Load value: corrected specified value,86.30, %
IDE01901,Lost torque adaptation: idle,2.4, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.99286,
IDE01911,Leakage air,0.0, kg/h
IDE01976,Numb.of misfir.: cylinder 2,5439,
IDE01977,Numb.of misfir.: cylinder 3,4955,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,255,
IDE02116,Exhaust gas temperature before catalytic converter,414.53, °C
IDE02117,Relative load value,17.11, %
IDE03328,Transmission neutral position sensor voltage,2000, mV
IDE03696-ENG57549,Result test of oxygen sensor heater after catalytic converter-Bits 0-7,152,
IDE03700,Status adaptation dew point end,ADP is OK,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.148, °
IDE03711,Mass flow through throttle valve,3.9, kg/h
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,14,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,174.000, Ohm
IDE03966,Transmission neutral position sensor PWM signal,40.04, %
IDE03968-ENG57549,Camshaft adaptation results-Bits 0-7,36,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,1028.229194, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,875.423528, kJ
IDE04414,Cat conv temp: modeled,440, °C
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,1.0078,
IDE04887,Powertrain target torque,-15.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,-11.9, Nm
IDE05128,Intake air temperature in intake manifold bank 1,40.5, °C
IDE05140,Intake manifold pressure raw value,324.06, hPa
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,0,
IDE05444,Air filling: specified value,17.63, %
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,10760, Ohm
IDE05474,Main cat converter OSC age correction factor,0.797,
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,5.3, kg/h
IDE05479,Misfire recognition reference moment,8.998, %
IDE05482,Tank venting adaptation factor,0.033,
IDE06006,Idle speed specified value,780, /min
IDE06039,Required RPM at idle speed,780.0, /min
IDE06098,Sensor control factor: output value,0.99228,
IDE06192,Knock sensor: cylinder 2: voltage,0.654, V
IDE06193,Knock sensor: cylinder 3: voltage,0.503, V
IDE06195,Knock sensor: cylinder 1: voltage,0.542, V
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,160,
IDE06435,A/C compressor: refrigerant pressure,5382, hPa
IDE06436,A/C compressor: refrigerant pressure: raw value,21.70, %
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,0.084, V
IDE06759,Cam shaft adaptation inlet: counter,4,
IDE06795,Oxygen sensor 1 bank 1 intern. resistance,98, Ohm
IDE06796,Oxygen sensor 1 bank 1 intern. resistance limit,3064, Ohm
IDE07102,Evaporator temperature A/C system actual value,19.6, °C
IDE07103,Evaporator temperature A/C system unconditioned voltage,3633.4, mV
IDE07104-ENG57549,Coolant fan stage 1 activation signal relay 1-Bits 0-7,0,
IDE07371,O2 heater resistance: act. value filtered,0.00, Ohm
IDE07573,Throttle valve adapter: actual value,2.83, %
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
ENG112666,Air conditioner pressure linearised raw value,5394, hPa
ENG114220,Effective_injection_duration,1.983, ms
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,5.1, kg/h
ENG111606,Load value: unrestricted commanded value,18.19, %
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00082,
ENG114216,Ox_sensor_bank_1_sensor_1_char_line_adapted_value_lean_range,1.00,
ENG114217,Ox_sensor_bank_1_sensor_1_char_line_adapted_value_rich_range,1.00,
ENG114218,Ox_sensor_bank_1_sensor_1_char_line_offset_adapted_value,-0.00012,
Elapsed Time: 00:27
Elapsed Time: 00:27
;SW:1S0-937-090-F HW:1S0-937-090 --- Cent. Elect.
;Component:BCM PQ25 1MX4 H81 0744, Coding:62B82B0000010000010007D06CEB8ED07940706D60CF2D602101000B0900
;Thursday,02,August,2018,14:16:06:29015
;VCID: B62F258E0136AAF44D-80E2
1,0,,
1,1,,,
;ON, ,
1,2,,,
;Term 50 Off, ,
1,3,,,
;ON, ,
1,4,,,
;Term 15 On, ,
2,0,,
2,1,,,
;13.44 V,Voltage,
2,2,,,
;13.44 V,Voltage,
2,3,,,
;Inactive, ,
2,4,,,
;0.0 km/h,Speed,
3,0,,
3,1,,,
;OFF, ,
3,2,,,
;OFF, ,
3,3,,,
;OFF, ,
3,4,,,
;Stage 1, ,
4,0,,
4,1,,,
;OFF, ,
4,2,,,
;Not Oper., ,
4,3,,,
;Not Oper., ,
4,4,,,
;Not Oper., ,
5,0,,
5,1,,,
;Door Open, ,
5,2,,,
;Door Closed, ,
5,3,,,
;Door Closed, ,
5,4,,,
;Door Closed, ,
6,0,,
6,1,,,
;Closed, ,
6,2,,,
;Closed, ,
6,3,,,
;Closed, ,
6,4,,,
;Not Oper., ,
7,0,,
7,1,,,
;Unlocked, ,
7,2,,,
;Unlocked, ,
7,3,,,
;Unlocked, ,
7,4,,,
;Unlocked, ,
8,0,,
8,1,,,
;Not Oper., ,
8,2,,,
;Not Installed, ,
8,3,,,
;Not Installed, ,
8,4,,,
;Not Oper., ,
9,0,,
9,1,,,
;OFF, ,
9,2,,,
;OFF, ,
9,3,,,
;No, ,
9,4,,,
10,0,,
10,1,,,
;Inactive, ,
10,2,,,
;Inactive, ,
10,3,,,
;Inactive, ,
10,4,,,
;Inactive, ,
11,0,,
11,1,,,
;Inactive, ,
11,2,,,
;Inactive, ,
11,3,,,
;Inactive, ,
11,4,,,
;Inactive, ,
12,0,,
12,1,,,
;Not Installed, ,
12,2,,,
;Not Installed, ,
12,3,,,
;Not Installed, ,
12,4,,,
;Not Installed, ,
13,0,,
13,1,,,
;Not Installed, ,
13,2,,,
;Not Installed, ,
13,3,,,
;Not Installed, ,
13,4,,,
;Not Installed, ,
14,0,,
14,1,,,
;No, ,
14,2,,,
;No, ,
14,3,,,
;No, ,
14,4,,,
;No, ,
15,0,,
15,1,,,
;Not Oper., ,
15,2,,,
;Yes, ,
15,3,,,
;0,Count,
15,4,,,
;Not Installed, ,
16,0,,
16,1,,,
;0,Count,
16,2,,,
;No, ,
16,3,,,
;Activated, ,
16,4,,,
;Not Installed, ,
17,0,,
17,1,,,
;Inactive, ,
17,2,,,
;No, ,
17,3,,,
;Activated, ,
17,4,,,
;No, ,
18,0,,
18,1,,,
;Not Installed, ,
18,2,,,
;Not Oper., ,
18,3,,,
18,4,,,
19,0,,
19,1,,,
;0,Count,
19,2,,,
;0,Count,
19,3,,,
;0,Count,
19,4,,,
;0,Count,
20,0,,
20,1,,,
;255,Count,
20,2,,,
;2000:00:00,Date,
20,3,,,
;0:00 h,Clock,
20,4,,,
;0 km,Mileage,
21,0,,
21,1,,,
;255,Count,
21,2,,,
;2000:00:00,Date,
21,3,,,
;0:00 h,Clock,
21,4,,,
;0 km,Mileage,
22,0,,
22,1,,,
;255,Count,
22,2,,,
;2000:00:00,Date,
22,3,,,
;0:00 h,Clock,
22,4,,,
;0 km,Mileage,
23,0,,
23,1,,,
;255,Count,
23,2,,,
;2000:00:00,Date,
23,3,,,
;0:00 h,Clock,
23,4,,,
;0 km,Mileage,
24,0,,
24,1,,,
;normal, ,
24,2,,,
;normal, ,
24,3,,,
;No, ,
24,4,,,
25,0,,
25,1,,,
;normal, ,
25,2,,,
;normal, ,
25,3,,,
25,4,,,
26,0,,
26,1,,,
;normal, ,
26,2,,,
;OK, ,
26,3,,,
;Inactive, ,
26,4,,,
;No, ,
27,0,,
27,1,,,
;0,Count,
27,2,,,
;0,Count,
27,3,,,
;0,Count,
27,4,,,
;0,Count,
28,0,,
28,1,,,
;OK, ,
28,2,,,
;0x0C10,Hex Value,
28,3,,,
;Inactive, ,
28,4,,,
;Inactive, ,
29,0,,
29,1,,,
;ON, ,
29,2,,,
;OFF, ,
29,3,,,
;OFF, ,
29,4,,,
;OFF, ,
30,0,,
30,1,,,
;Not Oper., ,
30,2,,,
;Not Oper., ,
30,3,,,
;Not Oper., ,
30,4,,,
;Not Oper., ,
31,0,,
31,1,,,
;Not Oper., ,
31,2,,,
;Not Oper., ,
31,3,,,
;Not Oper., ,
31,4,,,
;OFF, ,
32,0,,
32,1,,,
;Not Oper., ,
32,2,,,
;Not Installed, ,
32,3,,,
;OFF, ,
32,4,,,
;Activated, ,
33,0,,
33,1,,,
;Inactive, ,
33,2,,,
;Inactive, ,
33,3,,,
;Inactive, ,
33,4,,,
;Inactive, ,
34,0,,
34,1,,,
;Inactive, ,
34,2,,,
;Inactive, ,
34,3,,,
;Inactive, ,
34,4,,,
;Inactive, ,
35,0,,
35,1,,,
;Inactive, ,
35,2,,,
;Inactive, ,
35,3,,,
;OK, ,
35,4,,,
;OK, ,
36,0,,
36,1,,,
;Inactive, ,
36,2,,,
;Inactive, ,
36,3,,,
;Not Installed, ,
36,4,,,
;OK, ,
37,0,,
37,1,,,
;normal, ,
37,2,,,
;normal, ,
37,3,,,
;normal, ,
37,4,,,
;0,Count,
38,0,,
38,1,,,
;Not Installed, ,
38,2,,,
;Inactive, ,
38,3,,,
;99.6 %,Duty Cycle,
38,4,,,
;OFF, ,
39,0,,
39,1,,,
;Inactive, ,
39,2,,,
;Inactive, ,
39,3,,,
;Inactive, ,
39,4,,,
;Inactive, ,
40,0,,
40,1,,,
;OK, ,
40,2,,,
;OK, ,
40,3,,,
;OK, ,
40,4,,,
;not available, ,
41,0,,
41,1,,,
;not available, ,
41,2,,,
;not available, ,
41,3,,,
;OK, ,
41,4,,,
;OK, ,
42,0,,
42,1,,,
;OK, ,
42,2,,,
;OK, ,
42,3,,,
;Inactive, ,
42,4,,,
;Inactive, ,
43,0,,
43,1,,,
;Inactive, ,
43,2,,,
;Inactive, ,
43,3,,,
;Inactive, ,
43,4,,,
;OK, ,
44,0,,
44,1,,,
;91.6 %,Duty Cycle,
44,2,,,
;91.6 %,Duty Cycle,
44,3,,,
;0x0000,Hex Value,
44,4,,,
;0x0000,Hex Value,
46,0,,
46,1,,,
;99.6 %,Duty Cycle,
46,2,,,
;ON, ,
46,3,,,
;OK, ,
46,4,,,
;OFF, ,
50,0,,
50,1,,,
;78.0 %,Load,
50,2,,,
;0x0333,Hex Value,
50,3,,,
;0x0273,Hex Value,
50,4,,,
;0x03B3,Hex Value,
57,0,,
57,1,,,
;17.70 V,Voltage,
57,2,,,
;0.0 s,Time,
57,3,,,
;0.0 s,Time,
57,4,,,
;0.0 s,Time,
58,0,,
58,1,,,
;Inactive, ,
58,2,,,
;Inactive, ,
58,3,,,
;0.0,(no units),
58,4,,,
;0.0 s,Time,
59,0,,
59,1,,,
;Inactive, ,
59,2,,,
;Inactive, ,
59,3,,,
;Inactive, ,
59,4,,,
;15.40 V,Voltage,
60,0,,
60,1,,,
;13.45 V,Voltage,
60,2,,,
;Inactive, ,
60,3,,,
;35.20 %, ,
60,4,,,
;12.70 V,Voltage,
61,0,,
61,1,,,
;0.0,(no units),
61,2,,,
;0.0,(no units),
61,3,,,
;0.0,(no units),
61,4,,,
;0.0,(no units),
62,0,,
62,1,,,
;0.0,(no units),
62,2,,,
;0.0,(no units),
62,3,,,
;0,Count,
62,4,,,
;0,Count,
63,0,,
63,1,,,
;Prio2 00 at 0000000 km 2000.00.00 00 h,(no units),
64,0,,
64,1,,,
;Prio1 00 at 0000000 km 2000.00.00 00 h,(no units),
65,0,,
65,1,,,
;17.75 V,Voltage,
65,2,,,
;17.75 V,Voltage,
65,3,,,
;17.75 V,Voltage,
65,4,,,
;255.0,(no units),
66,0,,
66,1,,,
;0.0,(no units),
66,2,,,
;0.0,(no units),
66,3,,,
;0.0,(no units),
66,4,,,
67,0,,
67,1,,,
;0.010 V,Voltage,
67,2,,,
;0.0,(no units),
67,3,,,
;0.0,(no units),
67,4,,,
68,0,,
68,1,,,
;0.0,(no units),
68,2,,,
;0.0,(no units),
68,3,,,
;0.0,(no units),
68,4,,,
;17.75 V,Voltage,
69,0,,
69,1,,,
;13.50 V,Voltage,
69,2,,,
;1.0,(no units),
69,3,,,
;1.0,(no units),
69,4,,,
70,0,,
70,1,,,
;normal, ,
70,2,,,
;normal, ,
70,3,,,
;normal, ,
70,4,,,
;normal, ,
71,0,,
71,1,,,
;Term 15 On, ,
71,2,,,
;OFF, ,
71,3,,,
;Inactive, ,
71,4,,,
;Inactive, ,
72,0,,
72,1,,,
;Not Installed, ,
72,2,,,
;Not Installed, ,
72,3,,,
;0.0 km/h,Speed,
72,4,,,
;27.0°C,Temperature,
73,0,,
73,1,,,
;Closed, ,
73,2,,,
73,3,,,
73,4,,,
;Inactive, ,
74,0,,
74,1,,,
;0.0 %,Load,
74,2,,,
;Tilt position, ,
74,3,,,
;Unnormed, ,
74,4,,,
;Not Learned, ,
75,0,,
75,1,,,
;Inactive, ,
75,2,,,
;Inactive, ,
75,3,,,
;normal, ,
75,4,,,
;normal, ,
76,0,,
76,1,,,
;0.0 %,Load,
76,2,,,
;Tilt position, ,
76,3,,,
;Unnormed, ,
76,4,,,
;Not Learned, ,
77,0,,
77,1,,,
;Inactive, ,
77,2,,,
;Inactive, ,
77,3,,,
;normal, ,
77,4,,,
;normal, ,
78,0,,
78,1,,,
;0.0,(no units),
78,2,,,
;ON, ,
78,3,,,
;ON, ,
78,4,,,
;0.0,(no units),
79,0,,
79,1,,,
;RLS 090517 042 ,(no units),
80,0,,
80,1,,,
;4,Count,
80,2,,,
;OPEN, ,
80,3,,,
;Unlock, ,
80,4,,,
;1,Count,
81,0,,
81,1,,,
;4,Count,
81,2,,,
;Closed, ,
81,3,,,
;Lock, ,
81,4,,,
;1,Count,
82,0,,
82,1,,,
;26,Count,
82,2,,,
;OPEN, ,
82,3,,,
;Single Door, ,
82,4,,,
;0,Count,
83,0,,
83,1,,,
;4,Count,
83,2,,,
;OPEN, ,
83,3,,,
;Unlock, ,
83,4,,,
;1,Count,
84,0,,
84,1,,,
;4,Count,
84,2,,,
;Closed, ,
84,3,,,
;Lock, ,
84,4,,,
;1,Count,
85,0,,
85,1,,,
;Under-, ,
85,2,,,
;Voltage, ,
85,3,,,
;Turn-Off, ,
85,4,,,
86,0,,
86,1,,,
;26,Count,
86,2,,,
;OPEN, ,
86,3,,,
;Single Door, ,
86,4,,,
;0,Count,
87,0,,
87,1,,,
;4,Count,
87,2,,,
;OPEN, ,
87,3,,,
;Unlock, ,
87,4,,,
;1,Count,
88,0,,
88,1,,,
;4,Count,
88,2,,,
;Closed, ,
88,3,,,
;Lock, ,
88,4,,,
;1,Count,
89,0,,
89,1,,,
;26,Count,
89,2,,,
;OPEN, ,
89,3,,,
;Single Door, ,
89,4,,,
;0,Count,
90,0,,
90,1,,,
;Not Installed, ,
90,2,,,
;Not Installed, ,
90,3,,,
;Not Installed, ,
90,4,,,
;Not Installed, ,
93,0,,
93,1,,,
;000 000 000,Raw, Form. N/A,
93,2,,,
93,3,,,
93,4,,,
;000 005 000,Raw, Form. N/A,
94,0,,
94,1,,,
;0,Count,
94,2,,,
;0,Count,
94,3,,,
;0,Count,
94,4,,,
;0,Count,
95,0,,
95,1,,,
;0,Count,
95,2,,,
;0,Count,
95,3,,,
;0,Count,
95,4,,,
;0,Count,
96,0,,
96,1,,,
;0,Count,
96,2,,,
;0,Count,
96,3,,,
;0,Count,
96,4,,,
;0,Count,
97,0,,
97,1,,,
;0,Count,
97,2,,,
;0,Count,
97,3,,,
;0,Count,
97,4,,,
;0,Count,
98,0,,
98,1,,,
;31.0,(no units),
98,2,,,
;00000000 00000000,Bin. Bits,
98,3,,,
;Not Oper., ,
98,4,,,
;Not Oper., ,
99,0,,
99,1,,,
;M6, ,
99,2,,,
;40, ,
99,3,,,
;0x0502,Hex Value,
99,4,,,
;0x2016,Hex Value,
220,0,,
220,1,,,
;0,Count,
220,2,,,
;0,Count,
220,3,,,
;0,Count,
220,4,,,
;0,Count,
221,0,,
221,1,,,
;0,Count,
221,2,,,
;0,Count,
221,3,,,
;0,Count,
221,4,,,
;0,Count,
222,0,,
222,1,,,
;0,Count,
222,2,,,
;0,Count,
222,3,,,
;0,Count,
222,4,,,
;0,Count,
223,0,,
223,1,,,
;0,Count,
223,2,,,
;0,Count,
223,3,,,
;0,Count,
223,4,,,
;0,Count,
224,0,,
224,1,,,
;0,Count,
224,2,,,
;0,Count,
224,3,,,
;0,Count,
224,4,,,
;0,Count,
225,0,,
225,1,,,
;0,Count,
225,2,,,
;0,Count,
225,3,,,
;0,Count,
225,4,,,
;0,Count,
226,0,,
226,1,,,
;not available, ,
226,2,,,
;99.6 %,Duty Cycle,
226,3,,,
226,4,,,
227,0,,
227,1,,,
;Not Oper., ,
227,2,,,
;Not Oper., ,
227,3,,,
;0.0,(no units),
227,4,,,
;Not Oper., ,
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
;0.0,(no units),
228,3,,,
;0.0,(no units),
228,4,,,
;0.0,(no units),
229,0,,
229,1,,,
;0.0,(no units),
229,2,,,
;0.0,(no units),
229,3,,,
;0.0,(no units),
229,4,,,
;Not Oper., ,
230,0,,
230,1,,,
230,2,,,
230,3,,,
230,4,,,
