Results 1 to 9 of 9
Thread: Audi A5 3.0TDI Intermittant DPF fault
    Apr 2018
    I'm new to Ross-Tech and this is my first post. I've tried to be as detailed as possible but if I've missed something please let me know. I'm having issues with the DPF on my 2008 Audi A5 3.0 TDI. The issue has been ongoing intermittently for the year and a half that I've owned the car. It's been to a couple of different Audi specialists and the issue is still present, although can go 2 -3 months with out presenting itself. The two DTC's which usually present themselves are: 5188 - Diesel Particulate Filter (Bank 1) P242F 00 [032] - Restricted/Clogged and 5189 - Particulate Trap Bank 1 P2002 00 [032] - Efficiency Below Threshold. It does occasionally present the error 5162 - Exhaust Pressure Sensor 1 (G450)P0471 00 [229] - Implausible Signal although has not yet done this since the latest pressure sensor change.
    The EGR valve has been replaced as after the first pressure sensor change the car popped up with an EGR fault . The car's software has all been updated. The car has had the G450 Pressure sensor replaced three times, once before the EGR valve and twice after at different garages.
    The first two codes popped up again today whilst in stuck in town traffic. The car had just completed a 20 mile run at 60mph plus and then spent around ten minutes in queued traffic The DPF was not due a regeneration (does it around every 200 miles since software update) as the car had only covered just over 50 miles since the last one completed. The DPF light lit up, stayed on for around 30 seconds, then went out and got the flashing glowplug and limp mode. After leaving the car switched off for around 45 minutes, switched back on and no DPF light or flashing glowplug with full power restored. The car has done this previously whilst stuck in traffic, once after around 100 miles on a motorway.
    The freeze frame data show the Distance since regeneration at 0 miles however when going into advance measuring the data shows 54 miles since last regeneration. Clearly something is not right. With the engine off the car showed the Calculated soot level at 12.56g and measured at 0.72g. I then started the engine monitoring these fields and the measured soot levels whilst at idle increased to 24.19g after around 60 seconds before dropping back down to 3.16g after 10 minutes of sitting at idle. Calculated increased slightly to 12.65g. No error codes appeared during this 10 minutes sat at idle.
    The garages have checked all connections, wiring, pressure pipe and can find no issues. Does anyone have any ideas on what could be causing this error?
    Many Thanks
    Michael
    Wednesday,01,August,2018,18:35:03:27910
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WAUZZZ8T88A021410   License Plate: XXXXXX
    Mileage: 150220km-93342mi   Repair Order: 0108181834
                    Address 01: Engine  (8K0 907 401 F)
    18:34:46
      ENG107988   Distance since last regeneration 87663 m
      ENG106427   Exhaust gas temp.after pre-catalyst 140.0 C
      ENG106429   Exhaust gas temp.bef.turbocharger 122.4 C
      ENG106430   Exhaust gas temperature before particulate filter 131.2 C
      ENG105211   Exhaust gas vol.flow particulate filter 0.0 m/h
      ENG107984   Oil ash 0.26 l
      ENG107975   Soot mass calculated 12.56 g
      ENG107974   Soot mass measured 0.72 g
    Wednesday,01,August,2018,18:31:35:27910
    VIN: WAUZZZ8T88A021410   License Plate: xxxxxx
    Mileage: 150220km-93342mi   Repair Order: 0108181831
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 36 37 42 46 47 52 53
              55 56 6C 77
    VIN: WAUZZZ8T88A021410   Mileage: 150220km-93342miles
    Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
       Part No SW: 8K0 907 401 F    HW: 8K0 907 401
       Component: 3.0TDI EDC17  H01 0008
       Revision: --H01---
       Coding: 0114002C180F0118
       Shop #: WSC 74565 000 1048576
       ASAM Dataset: EV_ECM30LTDIA5 A02008
       ROD: EV_ECM30LTDIA5_A02.rod
       VCID: 2E05F3F630919517D3B-807A
                        Mileage: 150221 km
                        Date: 2018.08.01
                        Time: 17:13:10
                        Engine speed: 809.50 /min
                        Normed load value: 25.5 %
                        Coolant temperature: 84 C
                        Intake air temperature: 38 C
                        Voltage terminal 30: 14.320 V
                        Engine speed: 804.0 /min
                        Vehicle speed: 0.00 km/h
                        Field regeneration status-Bits 0-7: 00000000
                        Field regeneration status-Bits 0-7: 00101110
                        Particul.filter diff.pressure: 8 hPa
                        Exh t Adap TP Flt Us: -270.0 C
                        Exhaust gas vol.flow particulate filter: 66.2 m/h
                        Distance since last regeneration: 0 m
    5417 - Glowplug for Cylinder 5 (Q15)
              P161E 00 [109] - Open Circuit
                        Mileage: 149595 km
                        Date: 2018.07.23
                        Time: 08:44:50
                        Engine speed: 1165.00 /min
                        Normed load value: 64.7 %
                        Coolant temperature: 24 C
                        Intake air temperature: 23 C
                        Voltage terminal 30: 11.640 V
                        Engine speed: 1165.0 /min
                        Vehicle voltage terminal 30: 11660 mV
                        Coolant temperature: 24.7 C
                        Preheating system status-Bits 0-7: 00000000
                        Preheating system status-Bits 0-7: 10110000
                        Glw Plg r LVS Ps: 21.65 %
                        Intake air temperature: 23.5 C
                        Mileage: 150221 km
                        Date: 2018.08.01
                        Time: 17:13:10
       Part No SW: 8K0 907 379 N    HW: 8K0 907 379 N
       Component: ESP8 quattro  H03 0210
       Coding: 1B4500
       Shop #: WSC 06325 000 00000
       VCID: 44D1B15E8E9D0F4715F-8010
       Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
       Component: BCM2.01       H38 0253
       Revision: 00003002
       Coding: 031000
       VCID: 392FD0AAF95F42AF769-806C
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H34 0050
       Serial number: 0107000147258012
       Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
       Component: ELVAUDIB8  H35 0039
       Serial number: 0207000001350008
       Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
       Component: MEM-BFS       H09 0043
       Revision: AA000000    Serial number: 00001001046034
       Coding: 08217025002444111000
       Shop #: WSC 00579 210 91872
       VCID: 42DDB74694890177273-8016
    03338 - Force Limit for Fore/Aft Seat Adjustment: Forwards
                        Fault Status: 01100101
                        Reset counter: 196
                        Mileage: 147858 km
                        Date: 2018.06.11
                        Time: 17:58:08
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 F    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4690
       Revision: 00000000    Serial number: 331KQ077515209
       Coding: 0005002
       VCID: 3C21C9BEFA6D77876DF-8068
       Subsystem 1 - Part No: 8T0 919 609
       Component: E0380 BedienteilH07 0100
       Subsystem 2 - Serial number: 00000000024033
       Subsystem 3 - Serial number: 0117.10.070000000100010063
       Subsystem 4 - Serial number: 010063
       Part No SW: 8T2 820 043 N    HW: 8T2 820 043 N
       Component: KLIMA 3 ZONEN H05 0120
       Revision: D1000000    Serial number: 0107.11.070004
       Coding: 36060000
       VCID: 3D27C4BAED777E8F5A1-8068
                        Reset counter: 174
                        Mileage: 147338 km
                        Date: 2018.05.25
                        Time: 12:10:22
                        Fault Status: 00100011
                        Fault Frequency: 224
                        Reset counter: 65
                        Mileage: 147340 km
                        Date: 2018.05.25
                        Time: 16:37:03
                        Voltage: 14.50 V
                        Temperature: 14.0C
                        Temperature: 11.0C
                        Count: 10681
                        Count: 10904
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H21 0253
       Revision: 05021001    Serial number: 00000000051818
       Coding: 260050910014AF010009000300005D5D001D038800010141000000
       Shop #: WSC 00385 210 90023
       VCID: 3039ED8E2A2583E7C17-8064
       Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 271007  H11 0040
       Serial number: SWFBIE 0000205
       Coding: 00FD11
       Component: RLS  H04 0002
       Serial number: 10017544
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000000511070071
       Part No SW: 8T2 035 110 B    HW: 8T2 035 110 A
       Component: MP3-Changer     H42 0380
       Revision: 00042002    Serial number: AUZ5ZBG4531892
       VCID: 2A0DFFE600F9F9370F3-807E
       Part No SW: 8K0 919 475 C    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0010
       Revision: 11001001    Serial number: 75230731706491
       Coding: 300001
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H23 0409
       Serial number: 0038JD11DDB$
       Coding: 30323433363030303030554A305238543053
       ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
       VCID: 3C21C9BEF6ED77876DF-8068
       Serial number: 6334MSME3177541EF
       Serial number: 6344MSME3174387DK
       Serial number: 6352QSME4577314BJ
       Serial number: 6362QSME4628364BM
       Serial number: 63732SME447B38395
       Serial number: 63832SME447A4009
       Component: Lenks.Modul   H10 0012
       Revision: --------    Serial number: 90304GJV0002P
       Coding: 000016
       Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
       Component: KOMBIINSTR.   H28 0214
       Revision: 00100000    Serial number: 71Y36R5C7
       Coding: 2F05010002002600010000
       VCID: 3B23CAA2F36370BF645-806E
       Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
       Component: GW-BEM 4CAN-M H07 0084
       Revision: EB002032    Serial number: 3200E07A178057
       Coding: 000003
       Shop #: WSC 00583 210 66199
       Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
       Component: J367-BDM  H06 0150
       Serial number: 17006C18221007
       Component: MEM-FS        H09 0043
       Revision: AA000000    Serial number: 00001001047015
       Coding: 08397325002444111000
       Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
       Component: MNS ECE         H50 1030
       Revision: 00000000    Serial number: 333K 077526955
       VCID: 3E25C3B6EC71659743B-806A
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1301
       Coding: 011002225E01120102
       VCID: 50F98D0E4AE5E3E7A17-8004
       Revision: 00003002    Serial number: 0107198771
       Coding: 011B0682003904C0002000
       Shop #: WSC 06335 000 00000
       Component: DWA-Sensor  H02 0030
       Part No SW: 8T0 035 223 M    HW: 8T0 035 223 C
       Component: DSP Prem      H12 0280
       Revision: 00H12003    Serial number: 34813000942102
       Coding: 020101
       Shop #: WSC 12336 024 394758
       VCID: 3829D5AEC2555BA7897-806C
    02247 - Subwoofer (R148/R157)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 174
                        Mileage: 147338 km
                        Date: 2018.05.25
                        Time: 16:32:28
                        Voltage: 12.00 V
                        Temperature: 5.0C
                        Temperature: 8.0C
                        Bin. Bits: 00000100
       Part No SW: 8K0 959 792     HW: 8K0 959 792
       Component: TSG BF        H09 0149
       Revision:             Serial number: i
       Coding: 011002225E012201
       VCID: 7CA109BEB6EDB7872DF-8028
       Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
       Component: EPB Audi B8   H03 0040
       Revision: 00000003    Serial number: 00000000030043
       VCID: 2F3BEEF2371B9C1FD8D-807A
       Part No: 8K0 907 357 A
       VCID: 3333E282D733B8FFBC5-8066
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336KY077524392
       VCID: 2E05F3F63C119517D3B-807A
       Part No SW: 8T0 907 441     HW: 4L0 907 441 A
       Revision: --H12---    Serial number: 525PA8-J7X5068
       Coding: 1022008
       VCID: 75B71C9A99C7E6CF521-8020
       Part No SW: 4E0 910 336 K    HW: 4E0 862 335
       Component: Handyvorb2      H18 0950
       Revision: 00000000    Serial number: 00000005112835
       Coding: 0010920
       Shop #: WSC 00385 210 89996
    End----------(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.0V)-----------
  2. Likes Jack@European_Parts liked this post
  3. #2
    Nice first post & welcome to the VCDS forum.
    Is car stock update verified & not modified?
    Maybe measure the DPF and CAT on one bank and compare to the other bank with vacuum gauge to authenticate the difference and the actual restriction levels.
    Have you tried cleaning the DPF?
    JPPSG for FOD
    Apr 2018
    Thanks for the reply.
    The car is stock update and not modified in any way. The DPF has been cleaned by Terraclean, who also checked and cleaned the intake, turbo and throttle body although there was very little in terms of carbon deposits in these.
    I don't have access to a Vacuum Gauge, but will see if I can get hold of one. In terms of the result should I manage to get hold of one, what should I be looking at as being acceptable back pressure?
    This issue has had both garages puzzled as the car drives fine at all other times and still carries out the regenerations.
    Thanks Michael
    Ref the RTFB and the instructions of the respective tester you use and orifice size because size in this case does matter!
    or
    Find a car that is in perfect working order and measure that one with what you make up and use as a comparison using a +/- 5% deviation max.
    Jul 2014
    Hi Michael,
    Do you know if the Exhaust Pressure Sensors were genuine or aftermarket?
    Regards HMC
  7. Likes Jack@European_Parts liked this post
    Quote Originally Posted by M_Ayre View Post
    Are you 100% sure that the Terraclean has actually cleaned the DPF without damaging it or maybe even the throttle body?
    Terraclean get a regular slating on most UK car owners forums for promising much but delivering little if any benefits.
    OP: Do it yourself..........
  10. Likes Uwe liked this post
  11. #8
    Apr 2018
    The Pressure Sensors are genuine Audi from the Dealership, part 059 906 051A. I only ever get the same DTC's, nothing referring to the throttle body or any other components. I've not managed to manually compare the restriction levels yet. It's frustrating as the car can go months with out any issues then has a few days of persistent error codes.
  12. #9
    Jun 2015
    I would still look at the throttle body and check the plastic gears for missing thoots, I hade the same issue on my CAPA back in january and I think that the issue came from two componets: G450 and throttle body.
