Originally Posted by
vastechnics
The retrofit with the 4B module is very difficult is my experience. Better to work with the 55 xenon range module. I have retrofit this a lot. Use the 7P6 907 357 E with tiguan file. Make coding in adaptions in 09 and basic settings in 55. Finish.
May you explain how to use 55 with LED? pinout for 55 so that 29 39 D6 D7 will work?
What do you mean? That it doesn't work?
I have 2017 Tiguan with dynamic leds and it uses module 55. Check my cars autoscan : https://forums.ross-tech.com/showthr...l=1#post177795
Newer Tiguans use 4B module.
If you want pinout then buy some quality time from Erwin and print the diagrams.
Post Thanks / Like - 2 Likes
I have retrofited Tiguan with 29 39 D6 D7 and 4B
It's USA imported car.
I have all done, all works without AFS
I'm thinking if I need front camera to install for this AFS fault or its not necessery?
r87mc0
AFS
I am currently preparing to retrofit OEM Led Headlights on NAR BW2 Tiguan. As far as I can tell you dont need to retrofit camera. Camera will only add automatic automatic high bean and other features
Do anyone know what is the login for 4B basic settings ?
OEMplusCC
Camera adds the usual front assist safety functions but it’s not conventional high beam assist. It’s dynamic light assist which brings the shading function. Not dropping the high beams but instead ”shades” the oncoming traffic and car in front of you.
It’s really nice function.
So if you have the interest to retrofit the front camera, you’ll get some nice benefits
Post Thanks / Like - 1 Likes
I have just one fault in 4B.
It calls Basic settings
I can't figure out how AFS works
Some autoscan have 55 29 39 D6 D7 and some 4B A5 29 39 D6 D7
Also some of admap from 09 have lwr or headlight leveling sensor not active and some one of them active.
I've added 4B 29 39 D6 D7 to NAR version without A5
Now I have all done without Basic settings and AFS failure on dash.
Is there any posibility to add lwr sensor to bcm harness?
r87mc0
bcm harness?
I'm actually looking into it as well. See my post
https://forums.ross-tech.com/showthr...o-and-Question
I think Arteon wiring might work but I'm not sure
r87mc0
AFS works
bcm harness?
did you camera ?a5 for afs works need a5 .
need to make the basic setting . its easy and first aknwolege basic and after basic
Vw Tiguan AD1 2.0 tdi 190hp 4motion DSG
The LWR must be connected otherwise the basic setting can't be done. LWR needs to be connected to the BCM in no case of 14 Suspension Electronics. Otherwise to the J250. AFS can work without the A5. Only additional functions needs A5, like MDF and GLW or some don't know terms exaclty.
Uwe liked this post
