Results 11 to 20 of 26
Thread: Tiguan ad1 led retrofit problem
    Dec 2016
    Amsterdam
    Did you enter a wrong SA in your BCM in the past? Because the SA code is definitely 31347, so it could be locked.
    Current:
  2. #12
    May 2017
    Could MasterTommy post your cars 09 adamap? You have LED driving lights yes? Although you have a newer BCM which has coding all zeroes, the leuchte adaptations should be the same anyway.
    OP could check your adamap against his own. This is the blood,sweat and tears part OP needs to do The leuchte settings are real PITA to check one by one but that's how it's done. No shortcuts here unfortunately.
  3. #13
    Dec 2016
    Amsterdam
    I have the full led headlights with ALS. Not sure if OP is retrofitting the basic LED’s or the ALS one.
    Current:
  4. #14
    Apr 2018
    Greece
    Quote Originally Posted by MasterTommy View Post
    never wrong . the 31347 never taken and the the key is now 2 try.
    Vw Tiguan AD1 2.0 tdi 190hp 4motion DSG
  5. #15
    Apr 2018
    Greece
    hi again
    i replace bcm with new because my old has pre production part.
    i make the retrofit but i have "afs problem"'
    the light is working but not afs .
    and why i can see the coding at 09?
    Thursday,14,February,2019,18:03:12:19699
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4502.4
    VIN: WVGZZZ5NZGW306631   License Plate:
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 4B 52 5F 6C
              A5 CA D6 D7
    VIN: WVGZZZ5NZGW306631   Mileage: 50758km-31539miles
    4B-Multifunc. Module -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H23 3015
       Revision: B4H23---
       Coding: 0125001203261D082000
       Shop #: WSC 43251 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906026EJ 004002
       ROD: EV_ECM20TDI01104L906026EJ_004.rod
       VCID: 76B411C6E843F287B41-8022
       Part No SW: 0DL 300 011 A    HW: 0DE 927 711
       Component: GSG DQ500     H12 1404
       Revision: 00H12V32
       ROD: EV_TCMDQ500021.rod
       VCID: 261401867863C207C41-8072
       Part No SW: 5Q0 614 517 BG    HW: 5Q0 614 517 AC
       Component: ESC           H25 0407
       Revision: 00000000    Serial number: 61136000000121
       Coding: 0AEE6B9A54200B72477D670362C44950D62AD0E2E646927D30625078C22A02
       VCID: 77AA1CC2EF498B8FAF7-8022
       Part No SW: 5NA 907 044     HW: 5NA 907 044
       Component: AC Automat    H34 3902
       Revision: 20K07000    Serial number: 00000B00107743
       Coding: 0002012420211001110510400010100A
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ACClimaPrehVW37X 002013
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 7CA003EED66FA8D7C25-8028
       Subsystem 1 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001707501505
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F5AF4E2C779B3CFE77-802A
       Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 160324  033 0372
       Serial number: 00000001603220307531
       Component: RLHS  037 0059
       Serial number: S2Y16M05D06H21M02S23
       Coding: 00A8DD
       Part No SW: 3Q0 919 294     HW: 3Q0 919 294
       Component: PDC 8 Kanal   H07 0152
       Serial number: 002404167478021
       Coding: 0071051011
       ASAM Dataset: EV_EPHBO18VW3260000 007013
       ROD: EV_EPHBO18VW3260000.rod
       Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0155
       Coding: 320040C110FF8728749C806D004087
       ASAM Dataset: EV_ACCMRRCONTIVW376 001010
       ROD: EV_ACCMRRCONTIVW376_001.rod
       VCID: 392EDAFA99DD5DFF993-806C
       Part No SW: 5Q0 959 655 AD    HW: 5Q0 959 655 AD
       Component: AirbagVW21    005 0130
       Serial number: 003NMR1PSXKA
       Coding: 98CCC0C00C0000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 025C7D16B48BDE27889-8056
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NB857705C0121Q01362
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NB857706C0123Q00824
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 000 205 16
       Serial number: 357000000004F024FA1N
       Subsystem 4 - Part No SW: -----------    HW: 480 000 205 16
       Serial number: 35800000000FD024FA1X
       Subsystem 5 - Part No SW: -----------    HW: 480 402 604 16
       Serial number: 35100019D209F106836$
       Subsystem 6 - Part No SW: -----------    HW: 480 402 604 16
       Serial number: 35200019D209F106E497
       Subsystem 7 - Part No SW: -----------    HW: 480 402 504 16
       Serial number: 3550001C52080C22F5E5
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 705 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001B5209F10341CX
       Subsystem 9 - Part No SW: -----------    HW: 480 400 705 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B5209F102364T
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 400 705 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 23000019D209F104F35$
       Subsystem 11 - Part No SW: -----------    HW: 480 002 604 16
       Serial number: I0M000000009F631DA1C
       Subsystem 12 - Part No SW: -----------    HW: 480 002 604 16
       Serial number: I0N0000000008431DA1
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160414400310
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DEB21AF10D053FD13-8014
       Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
       Component: KOMBI         407 2160
       Coding: 03AD000BEB84000811897F031401000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004819740
       Coding: 030500041B087300FB03224E1E0F00010001050000000000000000000000
       VCID: 79AE1AFAD95D9DFFD93-802C
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29150002416760035495
       Coding: 28FFFF
       Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
       Component: J367-BDMHella  H10 9052
       Serial number: 7640060104
    131689 - Rear View Camera System Control Module
              U104C 00 [008] - No communication
              [Timeout Knoten 0x69 / 6C - Steuergerdt f?r R?ckfahrkamerasystem]
                        Reset counter: 60
                        Mileage: 50758 km
                        Date: 2019.02.14
                        Time: 16:38:07
                        Supply voltage: Terminal 30: 13.1 V
                        Terminal 15: OFF
              U1101 00 [009] - Active
                        Reset counter: 19
                        Mileage: 50754 km
                        Date: 2019.02.14
                        Time: 16:24:52
                        Supply voltage: Terminal 30: 11.7 V
                        Terminal 15: On
       Serial number: HA1-00004.04.16
       Coding: 0101
       VCID: 4ACC9536CC3BC667009-801E
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH05 0011
       VCID: 47CAAC02DF293B0F1F7-8012
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 080416ED804578
       Coding: 001003208000048000001000
       Serial number: 00000000000009861037
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000766329
       Coding: 01000011004001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3D26CEEA8DF561DFB5B-8068
       Component: FCM MQB Low   001 0286
       Serial number: 02021610520051
       Coding: 000000070100086E02106F410A0000000000000000000000000000000000
       Shop #: WSC 01356 003 104857
       VCID: 72BC2DD6842BEEA7989-8026
    0035 - Unknown Error Code
              U12EB 00 [009] - -
              [CAN_AFS_multiple_plug_LCM_identified]
                        Fault Frequency: 7
                        Reset counter: 20
                        Mileage: 50754 km
                        Date: 2019.02.14
                        Time: 16:25:58
    13705990 - Databus
              U1123 00 [137] - Received Error Message
              [FA_Hoehenwert_VL_01 received error value]
                        Reset counter: 19
                        Mileage: 50754 km
                        Date: 2019.02.14
                        Time: 16:25:58
    0032 - Headlight
                        Reset counter: 19
                        Mileage: 50754 km
                        Date: 2019.02.14
                        Time: 16:25:58
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 200416EDG3467A
       Coding: 001001208000048000001000
       VCID: 40D8B71EFA070C37DED-8014
       Serial number: 00000000000009889242
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 020 D    HW: 3G0 035 020
       Component: MU-H-ND-EU    H51 0687
       Serial number: A682F0G7504225
       Coding: 02730601FF00000051111101008808001F0106F441200000DF
       VCID: 18683F7EC21764F746D-804C
       Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
       Component: ABT_HIGH  H54 1031
       Serial number: VWZ8Z9SGY002D8
       Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Component: Gracenote2---  --- 1013
    10 Faults Found:
              B201A 00 [009] -  -
                        Fault Frequency: 170
                        Reset counter: 19
                        Mileage: 45719 km
                        Date: 2018.10.14
                        Time: 13:01:45
                        Voltage terminal 30: 12.3 V
                        Status_Software_Version_Management-module_name: MDUW065/DUW
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 203
                        Mileage: 45719 km
                        Date: 2018.10.14
                        Time: 13:01:57
                        Software module: status-SW_Status_Consistency: 00 00 10
                        Software module: status-SW_Status_Device:
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
              [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                        Reset counter: 203
                        Mileage: 45719 km
                        Date: 2018.10.14
                        Time: 13:01:41
    15361024 - Component Protection
              [Anti-theft protection - component protection active (0xEA6400)]
                        Reset counter: 203
                        Mileage: 45719 km
                        Date: 2018.10.14
                        Time: 13:01:41
              U11B8 00 [008] - No Communications
              [USB - communication error]
                        Reset counter: 37
                        Mileage: 46831 km
                        Date: 2018.11.26
                        Time: 14:08:59
                        Voltage terminal 30: 12.2 V
                        Interface for external media: status-Status: Measured value not available
    0013 - Antenna Amplifier 1 for Digital Radio
              B1270 13 [009] - Open Circuit
                        Reset counter: 203
                        Mileage: 45719 km
                        Date: 2018.10.14
                        Time: 13:01:41
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
    2565 - GPS Antenna
              B1054 13 [009] - Open Circuit
              [GPS aerial - open circuit]
                        Reset counter: 0
                        Mileage: 45719 km
                        Date: 2018.10.14
                        Time: 13:01:41
    5688 - Control Head for Mulimedia System
              B13C9 F2 [009] - On/Off Switch
                        Reset counter: 11
                        Mileage: 49622 km
                        Date: 2019.01.15
                        Time: 15:44:53
                        Voltage terminal 30: 11.9 V
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 43
                        Mileage: 46830 km
                        Date: 2018.11.26
                        Time: 00:00:05
    6713 - Databus
              [System information: no communication]
                        Reset counter: 59
                        Mileage: 50754 km
                        Date: 2019.02.14
                        Time: 13:20:29
       Coding: 0123060122002017000040
    10489856 - No Basic Setting
              B2010 00 [009] -  -
              [RearView system not calibrated]
                        Reset counter: 19
                        Mileage: 50754 km
                        Time: 00:00:00
    13705478 - Databus
              [message Parkhilfe_01 not received]
                        Reset counter: 20
                        Mileage: 50758 km
                        Date: 2019.02.14
                        Time: 17:54:08
                        passive
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 21041611P21938
       Coding: 0003070600000401002223448050010094000E300040
       VCID: 3A2CC5F69CDB56E7909-806E
       Part No SW: 4M0 907 594 D    HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 208040732602
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 372ADCC2AFC94B8F6F7-8062
       VCID: 16743146C8035287541-8042
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 01:48, VBatt start/end: 12.2V/12.1V)-----------
  6. #16
    Quote Originally Posted by terris View Post
    Because this is a new-style BCM where everything that was configurable in coding on older ones is now in various Adaptation channels.
  7. #17
    Apr 2018
    Greece
    understand and how we coding? via adaption only?
    about afs problem can you help me?
  8. #18
    Jul 2014
    Tallinn, Estonia
    At the very least, you could try to do headlight basic settings and basic settings confirmation in 4B. Turn the headlights on and see the dipped beam cutoff line move up and down during the basic setting. Afterwards clear the faults in 4B and see what comes back.
  9. #19
    Apr 2018
    Greece
    I try to make basic setting but can’t ."ERROR:request sequence error".
    output test working everything.
    The headlight moving when I start the machine .
  10. #20
    Jul 2014
    Tallinn, Estonia
    Please post an up to date admap of 09.
