hi again
i replace bcm with new because my old has pre production part.
i make the retrofit but i have "afs problem"'
the light is working but not afs .
and why i can see the coding at 09?
Thursday,14,February,2019,18:03:12:19699
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4502.4
VIN: WVGZZZ5NZGW306631 License Plate:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 4B 52 5F 6C
A5 CA D6 D7
VIN: WVGZZZ5NZGW306631 Mileage: 50758km-31539miles
4B-Multifunc. Module -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI H23 3015
Revision: B4H23---
Coding: 0125001203261D082000
Shop #: WSC 43251 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004002
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: 76B411C6E843F287B41-8022
Part No SW: 0DL 300 011 A HW: 0DE 927 711
Component: GSG DQ500 H12 1404
Revision: 00H12V32
ROD: EV_TCMDQ500021.rod
VCID: 261401867863C207C41-8072
Part No SW: 5Q0 614 517 BG HW: 5Q0 614 517 AC
Component: ESC H25 0407
Revision: 00000000 Serial number: 61136000000121
Coding: 0AEE6B9A54200B72477D670362C44950D62AD0E2E646927D30625078C22A02
VCID: 77AA1CC2EF498B8FAF7-8022
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 HW: 5NA 907 044
Component: AC Automat H34 3902
Revision: 20K07000 Serial number: 00000B00107743
Coding: 0002012420211001110510400010100A
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ACClimaPrehVW37X 002013
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 7CA003EED66FA8D7C25-8028
Subsystem 1 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 00000000000000000000
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001707501505
Shop #: WSC 12345 123 12345
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5AF4E2C779B3CFE77-802A
Subsystem 1 - Part No SW: 5NB 955 119 HW: 5NB 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 160324 033 0372
Serial number: 00000001603220307531
Component: RLHS 037 0059
Serial number: S2Y16M05D06H21M02S23
Coding: 00A8DD
Part No SW: 3Q0 919 294 HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0152
Serial number: 002404167478021
Coding: 0071051011
ASAM Dataset: EV_EPHBO18VW3260000 007013
ROD: EV_EPHBO18VW3260000.rod
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 320040C110FF8728749C806D004087
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 392EDAFA99DD5DFF993-806C
Part No SW: 5Q0 959 655 AD HW: 5Q0 959 655 AD
Component: AirbagVW21 005 0130
Serial number: 003NMR1PSXKA
Coding: 98CCC0C00C0000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 025C7D16B48BDE27889-8056
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5NB857705C0121Q01362
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5NB857706C0123Q00824
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 205 16
Serial number: 357000000004F024FA1N
Subsystem 4 - Part No SW: ----------- HW: 480 000 205 16
Serial number: 35800000000FD024FA1X
Subsystem 5 - Part No SW: ----------- HW: 480 402 604 16
Serial number: 35100019D209F106836$
Subsystem 6 - Part No SW: ----------- HW: 480 402 604 16
Serial number: 35200019D209F106E497
Subsystem 7 - Part No SW: ----------- HW: 480 402 504 16
Component: FrontSensor_D 000 6149
Serial number: 3550001C52080C22F5E5
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 400 705 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001B5209F10341CX
Subsystem 9 - Part No SW: ----------- HW: 480 400 705 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001B5209F102364T
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 400 705 16
Component: PedP_Sensor_C 000 6149
Serial number: 23000019D209F104F35$
Subsystem 11 - Part No SW: ----------- HW: 480 002 604 16
Component: PedPSensor_D2 001 0887
Serial number: I0M000000009F631DA1C
Subsystem 12 - Part No SW: ----------- HW: 480 002 604 16
Component: PedPSensor_P2 001 0887
Serial number: I0N0000000008431DA1
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160414400310
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 41DEB21AF10D053FD13-8014
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 407 2160
Coding: 03AD000BEB84000811897F031401000000000000
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004819740
Coding: 030500041B087300FB03224E1E0F00010001050000000000000000000000
ROD: EV_GatewLear_013_VW37.rod
VCID: 79AE1AFAD95D9DFFD93-802C
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29150002416760035495
Coding: 28FFFF
Subsystem 3 - Part No SW: 5QA 915 181 B HW: 5QA 915 181 B
Component: J367-BDMHella H10 9052
Serial number: 7640060104
131689 - Rear View Camera System Control Module
U104C 00 [008] - No communication
[Timeout Knoten 0x69 / 6C - Steuergerdt f?r R?ckfahrkamerasystem]
Reset counter: 60
Mileage: 50758 km
Date: 2019.02.14
Time: 16:38:07
Supply voltage: Terminal 30: 13.1 V
Terminal 15: OFF
U1101 00 [009] - Active
Reset counter: 19
Mileage: 50754 km
Date: 2019.02.14
Time: 16:24:52
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Serial number: HA1-00004.04.16
Coding: 0101
VCID: 4ACC9536CC3BC667009-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH05 0011
VCID: 47CAAC02DF293B0F1F7-8012
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 080416ED804578
Coding: 001003208000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009861037
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000766329
Coding: 01000011004001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D26CEEA8DF561DFB5B-8068
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0286
Serial number: 02021610520051
Coding: 000000070100086E02106F410A0000000000000000000000000000000000
Shop #: WSC 01356 003 104857
VCID: 72BC2DD6842BEEA7989-8026
0035 - Unknown Error Code
U12EB 00 [009] - -
[CAN_AFS_multiple_plug_LCM_identified]
Fault Frequency: 7
Reset counter: 20
Mileage: 50754 km
Date: 2019.02.14
Time: 16:25:58
13705990 - Databus
[FA_Hoehenwert_VL_01 received error value]
Reset counter: 19
Mileage: 50754 km
Date: 2019.02.14
Time: 16:25:58
0032 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 19
Mileage: 50754 km
Date: 2019.02.14
Time: 16:25:58
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 200416EDG3467A
Coding: 001001208000048000001000
VCID: 40D8B71EFA070C37DED-8014
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009889242
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 020 D HW: 3G0 035 020
Component: MU-H-ND-EU H51 0687
Serial number: A682F0G7504225
Coding: 02730601FF00000051111101008808001F0106F441200000DF
VCID: 18683F7EC21764F746D-804C
Subsystem 1 - Part No SW: 7C0 919 606 HW: 7C0 919 606
Component: ABT_HIGH H54 1031
Serial number: VWZ8Z9SGY002D8
Subsystem 2 - Part No SW: V03 959 800 QT HW: -----------
Component: ECE 2018/2019 --- 0169
Component: Gracenote2--- --- 1013
10 Faults Found:
B201A 00 [009] - -
[Check software version management]
Fault Frequency: 170
Reset counter: 19
Mileage: 45719 km
Date: 2018.10.14
Time: 13:01:45
Voltage terminal 30: 12.3 V
Status_Software_Version_Management-module_name: MDUW065/DUW
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [009] - Missing message
Reset counter: 203
Mileage: 45719 km
Date: 2018.10.14
Time: 13:01:57
Software module: status-SW_Status_Consistency: 00 00 10
Software module: status-SW_Status_Device:
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
[Anti-theft protection - component protection: no basic setting or basic setting incorrect]
Reset counter: 203
Mileage: 45719 km
Date: 2018.10.14
Time: 13:01:41
15361024 - Component Protection
[Anti-theft protection - component protection active (0xEA6400)]
Reset counter: 203
Mileage: 45719 km
Date: 2018.10.14
Time: 13:01:41
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 37
Mileage: 46831 km
Date: 2018.11.26
Time: 14:08:59
Voltage terminal 30: 12.2 V
Interface for external media: status-Status: Measured value not available
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [009] - Open Circuit
Reset counter: 203
Mileage: 45719 km
Date: 2018.10.14
Time: 13:01:41
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 0
Mileage: 45719 km
Date: 2018.10.14
Time: 13:01:41
5688 - Control Head for Mulimedia System
B13C9 F2 [009] - On/Off Switch
Reset counter: 11
Mileage: 49622 km
Date: 2019.01.15
Time: 15:44:53
Voltage terminal 30: 11.9 V
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Reset counter: 43
Mileage: 46830 km
Date: 2018.11.26
Time: 00:00:05
6713 - Databus
[System information: no communication]
Reset counter: 59
Mileage: 50754 km
Date: 2019.02.14
Time: 13:20:29
Network diagnosis-Status: Enabled
Component: RVC Compact H12 0231
Coding: 0123060122002017000040
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Reset counter: 19
Mileage: 50754 km
Time: 00:00:00
13705478 - Databus
[message Parkhilfe_01 not received]
Reset counter: 20
Mileage: 50758 km
Date: 2019.02.14
Time: 17:54:08
passive
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 21041611P21938
Coding: 0003070600000401002223448050010094000E300040
VCID: 3A2CC5F69CDB56E7909-806E
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 208040732602
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: 372ADCC2AFC94B8F6F7-8062
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16743146C8035287541-8042
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 01:48, VBatt start/end: 12.2V/12.1V)-----------
