Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: Tiguan ad1 led retrofit problem
  1. #41
    Oct 2019
    Quote Originally Posted by vastechnics View Post
    The retrofit with the 4B module is very difficult is my experience. Better to work with the 55 xenon range module. I have retrofit this a lot. Use the 7P6 907 357 E with tiguan file. Make coding in adaptions in 09 and basic settings in 55. Finish.
    May you explain how to use 55 with LED? pinout for 55 so that 29 39 D6 D7 will work?
  2. #42
    May 2017
    What do you mean? That it doesn't work?
    I have 2017 Tiguan with dynamic leds and it uses module 55. Check my cars autoscan : https://forums.ross-tech.com/showthr...l=1#post177795
    Newer Tiguans use 4B module.
    If you want pinout then buy some quality time from Erwin and print the diagrams.
  3. Likes Uwe, m87a liked this post
  4. #43
    Oct 2019
    I have retrofited Tiguan with 29 39 D6 D7 and 4B
    It's USA imported car.
    I have all done, all works without AFS
    I'm thinking if I need front camera to install for this AFS fault or its not necessery?
  5. #44
    Apr 2019
    Quote Originally Posted by r87mc0 View Post
    I am currently preparing to retrofit OEM Led Headlights on NAR BW2 Tiguan. As far as I can tell you dont need to retrofit camera. Camera will only add automatic automatic high bean and other features
  6. #45
    Oct 2019
    Do anyone know what is the login for 4B basic settings ?
  7. #46
    May 2017
    Quote Originally Posted by OEMplusCC View Post
    Camera adds the usual front assist safety functions but it’s not conventional high beam assist. It’s dynamic light assist which brings the shading function. Not dropping the high beams but instead ”shades” the oncoming traffic and car in front of you.
    It’s really nice function.
    So if you have the interest to retrofit the front camera, you’ll get some nice benefits
  8. Likes OEMplusCC liked this post
  9. #47
    Oct 2019
    I have just one fault in 4B.
    It calls Basic settings
    I can't figure out how AFS works
    Some autoscan have 55 29 39 D6 D7 and some 4B A5 29 39 D6 D7
    Also some of admap from 09 have lwr or headlight leveling sensor not active and some one of them active.
    I've added 4B 29 39 D6 D7 to NAR version without A5
    Now I have all done without Basic settings and AFS failure on dash.
    Is there any posibility to add lwr sensor to bcm harness?
  10. #48
    Apr 2019
    I'm actually looking into it as well. See my post
    https://forums.ross-tech.com/showthr...o-and-Question
    I think Arteon wiring might work but I'm not sure
  11. #49
    Apr 2018
    Greece
    did you camera ?a5 for afs works need a5 .
    need to make the basic setting . its easy and first aknwolege basic and after basic
    Vw Tiguan AD1 2.0 tdi 190hp 4motion DSG
  12. #50
    May 2016
    The LWR must be connected otherwise the basic setting can't be done. LWR needs to be connected to the BCM in no case of 14 Suspension Electronics. Otherwise to the J250. AFS can work without the A5. Only additional functions needs A5, like MDF and GLW or some don't know terms exaclty.
  13. Likes Uwe liked this post
