Quote Originally Posted by A4Allroad View Post
andyhud, if you wanna try:
Address 17 - Byte 04 - Bit 0=0
Address 17 - Byte 03 - Bit 7=1
Address 03 - Byte 14 - Bit 6=0
Address 03 - Byte 26 - Bit 1=0.
The last two codings needs to be performed with other diagnosis (V*P) in a one shot way: copy the 03 original coding from fast-editing field, modify by hand the single bits, and paste the modified coding in the fast-editing field... together with original info as WSC, Imp. and Tester. Then start coding..... For me this procedure has worked....
Thankyou A4Allroad for your input, I've PM'd you.
Andy
