Results 1 to 10 of 10
Thread: V10tdi particulate ash values and forced regen
    Jul 2018
    VWV10TDI group labels,desc. Particulate filter ash values, please advise?
    Oct 2014
    Arandjelovac, Serbia
    Welcome aboard!
    Post an full Auto-Scan, please.
  3. Likes Uwe liked this post
    Jul 2018
    when I do an AUTO-Scan there is nothing for engine 1 or II I am not having operational problems except Hvac, I would like to get an idea what status is for soot and ash grams or % of fill,In measuring Block 068 i get 79 units in field 3, I do not know the meaning or if this is relavent, this is a towing unit just purchsed in 2017 and we are planning 3 week trip 5K miles , I have masters degree in fuel systems, ADS pump Shop retired ,3 Benz diesels and other But this is hard to gather info on . Thanks
    Oct 2014
    People do not mean a lot here with [VWV10TDI group labels,desc]. Auto scan is much better, because we can be seen how the vehicle is equipped and configured.
  6. Likes Dana, billywhizz liked this post
    Jul 2018
    I just got off the phone with Peter @ ross tech He explained what you were probably looking for, It will be a couple of days , this is learning curve for me and i'm german.isn't that funny,Thanks
    Jul 2018
    Tuesday,07,August,2018,20:53:53:24229
    VCDS Version: 18.2.1.5  HEX-V2 CB: 0.4411.4
    Dealer/Shop Name: roberts
    VIN: WVGPT77L46D062545   License Plate:
    Mileage: 269060km-167186mi   Repair Order: 8-7-18
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGPT77L46D062545   Mileage: 269060km-167186miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG000AGMª8472
       Revision: --H02---    Serial number: VWZ3Z0E6443672
       Coding: 0060575
       Shop #: WSC 31414 000 00000
       VCID: 619F58C3AD5C405F1EA-5160
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H37000    Serial number:
       Coding: 0004216
       VCID: 7F5BFEBB3BE896AF08E-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D27C4B3716444BF5A2-5160
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137 A    HW: 5WK 485 02
       Component: 29 Kessy            6700
       Revision: 67005915    Serial number: VWZ3Z0E6443672
       Coding: 0147688
       VCID: 313FE883BD3CB0DFCEA-5160
    00180 - Access/Start Authorization Antenna; Passenger Side (R135)
    00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77AB169B13D8AEEF40E-5160
       Part No: 7L6 907 044 T
       Component: CLIMAtronic 2+2     4222
       Coding: 0021030
       Shop #: WSC 02616 444 178905
       VCID: 45D7AC5319B40C7F022-5160
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    00898 - Control Circuit A/C compressor
    02599 - Rear Left Temperature Flap Motor (V313)
                000 -  -  - Intermittent
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3002
       Coding: 0111839
       VCID: 47CBA65B23B81E6FF0E-5160
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG000AGSª8472
       Coding: 0060575
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010032
       VCID: 44D1B157128E357715C-5160
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0005231
       VCID: 48C9A5672EA61117F94-5160
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 815 071 D
       Component: Standheizung E1MAC
       Coding: 0000100
       VCID: 3333E28B472082CFBC6-5160
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70B92D8776B6F9D7814-5160
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D4754730144B43F0A2-5160
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  X012
       Coding: 0000003
       VCID: 66954BDF44722767EB8-5184
    00492 - Body Pitch Angle from Level Control Module
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       VCID: 3635DB9F545297E79B8-5160
       Component: Sitzverstellung     0703
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50F98D07D6F6D9D7A14-5160
       Part No: 3D0 909 158
       Coding: 0000003
       Shop #: WSC 02132 444 84388
       VCID: 678B46DB43783E6FD0E-513C
    No Faults Found
       Part No: 7L0 959 933 J
       Component:    HSG              5115
       Coding: 0000085
       VCID: 43D3B24B1780324F2C6-4B1E
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    01134 - Alarm Horn (H12)
    Address 47: Sound System        Labels:
       VCID: 55F77C13EC04BCFF722-5160
       Note: Excessive Comm Errors
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014062
       VCID: 3537DC9349549CFF922-5160
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C21C9B76A7E4DB76DC-5160
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
       Component: J345  Anhaenger     0080
       Revision: 4A009001    Serial number: 00000193524433
       Coding: 0016386
       Shop #: WSC 00512 001 24584
       VCID: 3FDBBEBB7B6856AF48E-5160
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J620411
       Coding: 0000101
       VCID: 72BD278F78BACBC7770-5160
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 T
       Component: DACHDISPLAY         0539
       Revision: 00900539    Serial number: 2009289.07
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 392FD0A3654C789F76A-5160
    End----(Elapsed Time: 09:52, VBatt start/end: 12.2V/11.9V. VIgn 12.0V)-----
  9. Likes DrPeter, Eric, Dana, Boki Ar liked this post
  10. #7
    MVB 067:
    1. EGT before turbo'
    2. EGT in DPF
    3. Differential pressure across DPF
    4. Differential pressure sensor offset.
    MVB 068:
    1. Soot load in %
    2. Ash loading in grams.
    3. Ask learning value
    MVB 073:
    1. Fuel consumption since regen
    2. Distance since regen
    3. Time since regen
  11. Likes Dana, DrPeter, billywhizz liked this post
  12. #8
    Jul 2018
    I appreciate your help have a couple of ?? Just for laughs, My neighbor came over from Hungary in 61 as 10yr old with his parents ,he'retired machinist and he jokingly calls me Bushwah capitalistic pig which was a label for people from old country who had benz and all the other well engineered marvels.. Okay 1st)is this in the drivetrain section and am I doing DX for engine i and II seperatly and also if you could send other MVB for engine sensors It would be appreciated, I could send e-mail address if ness. Thanks
  13. #9
    Jul 2018
    Also on mvb 68 ,block 3 ask learning value what do es this mean if it has 79 in that block?
  14. #10
    Quote Originally Posted by atomizer View Post
    If I knew, I'd tell you.
  15. Likes Boki Ar liked this post
