VCDS Version: 18.2.1.5
VIN: WAUZZZ4GXJNxxxxxx
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
5F 62 6D 72 AC
19-CAN Gateway -- Status: 0010
5F-Information Electr. -- Status: 0010
Address 01: Engine (J623-DDDA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 HA HW: 04L 907 309 AA
Component: R4 2.0l TDI H20 4166
Revision: 8DH20---
Coding: 12254012242401080000
ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
ROD: EV_ECM20TDI01104L906021HA_004.rod
VCID: 6BDED7718223CB1CE1-803E
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 4G1 927 153 G HW: 0CJ 927 156
Component: 0CK 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000001024
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002028
ROD: EV_TCMDL382021_AU48.rod
VCID: 2E581E6571B17E3486-807A
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180087000240
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A29E41604579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 418255D9D02FF14C6B-8014
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0825
Coding: 01B9704E000000000000
VCID: 7CFCE42DFF4D5CA478-8028
Serial number: 3218000058997014
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 11041800041421
Coding: 34220978210000
VCID: 63CEBF516AF3835C59-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001968191502
Coding: 0105001440349FE041014083800018000F9DC7082F08020100000894E100140200400024030000
VCID: 74ECCC0DD71D14E430-8020
Component: WWS57X 180211 H38 0080
Serial number: 180220091323
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21302972X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 09 04 2018 00000839
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: CD11912900PAG0MUFU03
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Component: Airbag10.43 H83 0098
Revision: -------- Serial number: 003P100G7MF3
Coding: 30333130313630323639554A305234473053
VCID: 3B7E2731B2C39B9C31-806E
Serial number: 3575HRB401A5DNV0HI0P
Serial number: 3585HRB400G5DP9EB9GQ
Serial number: 3515JRB405N5DSKIL9NP
Serial number: 3525JRB405J5EP2CDGHW
Serial number: 3554VRB405B5FB3KN8V7
Serial number: 3564VRB405B5FB3KN14H
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560RD1000T8
Coding: 000035
VCID: 3B7E2731BAC39B9C31-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 04 04 2018 A0006018
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 987 R HW: 4G8 920 987 R
Component: TDieGb H17 0225
Revision: 18001312 Serial number: 658090418592014
Coding: 33A615000B412600010000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K.rod
VCID: 489448FDF315C004AC-801C
Part No SW: 4G8 907 468 K HW: 4G8 907 468
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002944682
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 002011
ROD: EV_GatewPkoUDS_002.rod
VCID: 408450DDDB25F84464-8014
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 8824477304
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 180131000000000004CA
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 67D6AB4196CBEF7C85-8032
Address 28: HVAC, Rear (E265) Labels:| 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 16041800041323
Coding: 22
VCID: 3D7A2929ACD795AC0F-8068
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000311668595
VCID: 77F6FB01C66B7FFC15-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA7212URCW
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 336E0F119A9353DCE9-8066
Component: TSG FA H03 0511
Coding: 011C16015E01620002080002
VCID: 47964BC1F60BCF7CA5-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H55 0202
Revision: 00000002 Serial number: 0000599432
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A702235BDF9A2942A-806E
Revision: 00002001 Serial number: 0477427976
Coding: 013B0622A0B93080C320098400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00046487688
Component: TSG BF H03 0511
VCID: 468846C5F101D6745E-8012
Part No SW: 4H0 907 801 N HW: 4H0 907 801 M
Component: EPB-4 H01 0020
Revision: -------- Serial number: 00000002478053
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A630200
VCID: 346C0C0D9F9D54E4F0-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 021 J HW: 4G1 035 021 D
Component: MU-H-LND-EU 054 0910
Serial number: A733D0JS029831
Coding: 017502010000000013111102000A00332F0006E7F1700100DF
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 2142F559306FD14C0B-8074
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9JY80A9SD
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349RDC0004U
Component: Gracenote2 --- 1016
Component: TSG HL H03 0511
VCID: 49924DF9E01F390CB3-801C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0152
Revision: 14005003 Serial number: 098800227
Coding: 093205C010
ROD: EV_HDSGAu571.rod
VCID: 3668360589E146F4CE-8062
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 180390118
ROD: EV_RDCMA00100_008.rod
VCID: 2F66036176BB773C8D-807A
End-------------------------(Elapsed Time: 05:48)--------------------------
