Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: A6 2018 C7 - CD ripping to juke box
    Jul 2018
    Aim: to rip audio CDs to the duke box.
    Tried to enable the so called hidden menu but this doesn’t seem possible on my 2018 A6.
    I read Dana’s information on the forum regarding SA codes and S12345 does not work.
    http://forums.ross-tech.com/showthre...17-Hidden-Menu
    I’m trying to enable the developer mode as I think this will enable the CD Ripping option so I can transfer CDs to the juke box. Just need to enable the correct hidden menu.
    Under Adaptation, IDE02122-Developer mode is currently ‘not activated’ and setting this to ‘activated’ returns ‘Request out of range’.
    I’ve been using VCDS for years (since the MK1 TT, VW Lupo, Polo, A5, Passat, and now my A6). I’m using the Gendan HEX+CAN USB cable and it’s been brilliant so far.
    Current VCDS 18.2.
    Any help would be greatly appreciated.
    Thanks
    Welcome aboard, Simon.
    Please post an Auto-Scan for context.
    Jul 2018
    Wednesday,25,July,2018,14:06:23:42555
    VCDS Version: 18.2.1.5
    VIN: WAUZZZ4GXJN1   License Plate:
    Mileage: 2900km-1801mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
              5F 62 6D 72 AC
    VIN: WAUZZZ4GXJN1   Mileage: 2900km-1801miles
    Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
       Component: R4 2.0l TDI   H20 4166
       Revision: 8DH20---
       Coding: 12254012242401080000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
       ROD: EV_ECM20TDI01104L906021HA_004.rod
       VCID: 6BDED7718223CB1CE1-803E
    Address 02: Auto Trans (J217)       Labels:* Redir Fail!
       Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
       Component: 0CK 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000001024
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002028
       ROD: EV_TCMDL382021_AU48.rod
       VCID: 2E581E6571B17E3486-807A
       Manual Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041180087000240
       Coding: 06A29E41604579829B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 418255D9D02FF14C6B-8014
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01B9704E000000000000
       VCID: 7CFCE42DFF4D5CA478-8028
       Serial number: 3218000058997014
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0113
       Serial number: 11041800041421
       Coding: 34220978210000
       VCID: 63CEBF516AF3835C59-8036
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 1502003S    Serial number: 00001968191502
       Coding: 0105001440349FE041014083800018000F9DC7082F08020100000894E100140200400024030000
       VCID: 74ECCC0DD71D14E430-8020
       Component: WWS57X 180211  H38 0080
       Serial number:         180220091323
       Coding: 0045F7
       Serial number: 21302972X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 09 04 2018  00000839
       Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: CD11912900PAG0MUFU03
    00908 - Control Module for Wiper Motor
                        Reset counter: 113
                        Mileage: 2805 km
                        Date: 2018.07.14
                        Time: 20:16:42
       Component: Airbag10.43   H83 0098
       Revision: --------    Serial number: 003P100G7MF3
       Coding: 30333130313630323639554A305234473053
       VCID: 3B7E2731B2C39B9C31-806E
       Serial number: 3575HRB401A5DNV0HI0P
       Serial number: 3585HRB400G5DP9EB9GQ
       Serial number: 3515JRB405N5DSKIL9NP
       Serial number: 3525JRB405J5EP2CDGHW
       Serial number: 3554VRB405B5FB3KN8V7
       Serial number: 3564VRB405B5FB3KN14H
       Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
       Component: Lenks.Modul   H06 0005
       Revision: C0068538    Serial number: 91560RD1000T8
       Coding: 000035
       VCID: 3B7E2731BAC39B9C31-806E
       Serial number: 04 04 2018  A0006018
       Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
       Component: TDieGb        H17 0225
       Revision: 18001312    Serial number: 658090418592014
       Coding: 33A615000B412600010000
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 489448FDF315C004AC-801C
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002944682
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 002011
       ROD: EV_GatewPkoUDS_002.rod
       VCID: 408450DDDB25F84464-8014
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 8824477304
       Voltage stabilizer:
       Serial number: 180131000000000004CA
              U140B 00 [008] - -
                        Reset counter: 121
                        Mileage: 2896 km
                        Date: 2018.07.24
                        Time: 23:22:56
                        Voltage terminal 30: 11.1 V
                        Voltage terminal 15: 11.1 V
                        Control Module temperature: 38 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 1
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04028264747464545425363E00
       VCID: 67D6AB4196CBEF7C85-8032
    Address 28: HVAC, Rear (E265)       Labels:| 4G0-919-158.clb
       Component: KLIMA FOND    H08 0113
       Serial number: 16041800041323
       Coding: 22
       VCID: 3D7A2929ACD795AC0F-8068
       Revision: AA000000    Serial number: 00000311668595
       Coding: 0078130000006001000001010101102030303232203232
       VCID: 77F6FB01C66B7FFC15-8022
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA7212URCW
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336E0F119A9353DCE9-8066
       Component: TSG FA        H03 0511
       Coding: 011C16015E01620002080002
       VCID: 47964BC1F60BCF7CA5-8012
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H55 0202
       Revision: 00000002    Serial number: 0000599432
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A702235BDF9A2942A-806E
       Revision: 00002001    Serial number: 0477427976
       Coding: 013B0622A0B93080C320098400010F470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00046487688
       VCID: 468846C5F101D6745E-8012
       Part No SW: 4H0 907 801 N    HW: 4H0 907 801 M
       Component: EPB-4         H01 0020
       Revision: --------    Serial number: 00000002478053
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_VW51.rod
       Coding: 04FE02102A630200
       VCID: 346C0C0D9F9D54E4F0-8060
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 021 J    HW: 4G1 035 021 D
       Component: MU-H-LND-EU   054 0910
       Serial number: A733D0JS029831
       Coding: 017502010000000013111102000A00332F0006E7F1700100DF
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 2142F559306FD14C0B-8074
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9JY80A9SD
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
       Serial number: 90349RDC0004U
       Component: Gracenote2  --- 1016
    3086 - Antenna for Telephone Mount
              B1564 01 [009] - Electrical Failure
                        Reset counter: 69
                        Mileage: 2521 km
                        Date: 2018.07.12
                        Time: 15:59:54
                        Voltage terminal 30: 12.1 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
       Component: TSG HL        H03 0511
       Coding: 010814004001620002080002
       VCID: 49924DF9E01F390CB3-801C
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0152
       Revision: 14005003    Serial number: 098800227
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
       VCID: 3668360589E146F4CE-8062
       Component: TSG HR        H03 0511
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 180390118
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F66036176BB773C8D-807A
    End-------------------------(Elapsed Time: 05:48)--------------------------
    Hope that helps! Just picked up the car (2 months old ex-demo) and wipers work just fine so not sure what that fault is, will clear it next time I connect. Power saving is me playing with the ignition on!
    Jul 2018
    Do you need me to post/check anything else?
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Don't need developer / green menu for this. Go in to 5F > Adaptations and look for "Copy multimedia data-Optical drive" and change to "On"
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  6. Likes Uwe, Dana liked this post
    Jul 2018
    Quote Originally Posted by DJAlix View Post
    Thanks for the information, I’ll try that later.
    Regards
    Jul 2018
    I found the option you mentioned and set the value from OFF to ON (verified it too) then reset the MMI but the DVD source is greyed out when selecting the Copy to juke box option. I tried with a couple of different audio CDs and a DVD but no joy. Any ideas?
    Also found another option ‘Copy multimedia data-Data medium’ but did not change as it was already set to On.
    Thanks again.
  9. #8
    Dec 2016
    DE
    Try new coding for 5F:
    017502010000000013111102000A00332F0006E7F1700100FF
    reboot the control module afterwards (I guess this might be achieved holding the ON/OFF button for 10-15 seconds).
  10. Likes Uwe liked this post
  11. #9
    Apr 2015
    Interesting, have never tested this myself as I have a different vehicle but have activated it for many customers without complaints. Will test the next time I can a car over.
    VAG Car Coding
    @vagcarcoding
  12. #10
    Jul 2018
    Anyone have a definitive answer on how to enable copying content to the jukebox? None of the above work. UK A6 C7.5 June 2018 build.
    Thanks
