Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: B6 passat 3 inch downpipe install CEL on?
    Sep 2017
    hello i installed a 3 inch down pipe with cat delete today. after 30 miles of driving igot my CEL on. got home and did autoscan. why is this coming up?
    also what i had few recalls done at dealership last week so ignore the fuel pump andair bag. however what do the door codes mean? as well
    Saturday,28,July,2018,20:19:48:43295
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    Dealer/Shop Name: ATANAS D
    VIN: WVWUK73C08P051382   License Plate:
    Mileage: 82450   Repair Order:
    Mode 03: Emission related fault codes
    Address 7E8: 1 Fault Found:
    P0420 - Catalyst System; Bank 1: Efficiency Below Threshold
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
    VIN: WVWUK73C08P051382   Mileage: 132730km-82474miles
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    72-Door, Rear Right -- Status: Sporadic communication error 1000
       Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWZCZ000000000
       Coding: 0404010A18070160
       Shop #: WSC 00028 028 00001
       VCID: 3039EE51D629C277C14-8064
                   P0300 - 002 -  - Intermittent
                        Mileage: 131785 km
                        Date: 2018.06.28
                        Time: 02:36:15
                        RPM: 757 /min
                        Load: 14.5 %
                        Temperature: 76.0C
                        Temperature: 42.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.224 V
    000772 - Cylinder 4
                   P0304 - 002 - Misfire Detected - Intermittent
                        Mileage: 131785 km
                        Date: 2018.06.28
                        Time: 02:36:30
                        RPM: 761 /min
                        Load: 14.5 %
                        Temperature: 77.0C
                        Temperature: 42.0C
                        Voltage: 14.224 V
    001299 - Incorrect Immobilizer Key
                   P0513 - 008 -  - Intermittent
                        Mileage: 132059 km
                        Date: 2018.07.12
                        Time: 09:47:28
                        RPM: 739 /min
                        Load: 41.2 %
                        Temperature: 27.0C
                        Temperature: 23.0C
                        Voltage: 11.811 V
    001056 - Catalyst System; Bank 1
                   P0420 - 002 - Efficiency Below Threshold - MIL ON
                        Fault Status: 11100010
                        Mileage: 132718 km
                        Date: 2018.07.28
                        Time: 15:13:38
                        RPM: 1646 /min
                        Load: 28.2 %
                        Speed: 67.0 km/h
                        Temperature: 78.0C
                        Temperature: 40.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.097 V
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
       Component: J104    C4 440 V2   0003
       Revision: --020---    Serial number: 00000776088981
       Coding: 0000345
       VCID: 1F1B1DEDBBB74D0F68E-804A
       Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 6E8530290C9D9487938-803A
       Revision: 00H54000    Serial number: 01000005113356
       Coding: 10840F0340041A28470000000F000000000859435C000100000000000000
       VCID: 71BF2B551DA38B7F8EA-8024
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 020807 003  0205
       Coding: 00046997
       Shop #: WSC 00028
                        Fault Status: 00111100
                        Reset counter: 39
                        Mileage: 132059 km
                        Date: 2018.07.12
                        Time: 09:47:00
                        Voltage: 11.15 V
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 00101001
                        Reset counter: 17
                        Mileage: 132059 km
                        Date: 2018.07.12
                        Time: 08:24:00
                        Voltage: 12.20 V
                        Reset counter: 36
                        Mileage: 132496 km
                        Date: 2018.07.24
                        Time: 06:01:00
                        Voltage: 12.30 V
                        Reset counter: 36
                        Mileage: 132496 km
                        Date: 2018.07.24
                        Time: 06:01:00
                        Voltage: 12.30 V
       Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
       Component: 17 AIRBAG VW8R  032 2522
       Revision: 13032000    Serial number: 003B2PJWXZXL
       Coding: 0012599
       VCID: 313FEB55DD23CB7FCEA-8064
       Subsystem 1 - Part No: 3C0 959 339 B
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 0000000003NQKC
       Subsystem 3 - Serial number: 0001.01.000000700000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME165A056AE†63
       Subsystem 5 - Serial number: A056AE†6342MSME16731B5FL†63
       Subsystem 6 - Serial number: 31B5FL†6351HTS61CGGEOO6-†63
       Subsystem 7 - Serial number: GEOO6-†6361HTS6L4I4O2579†63
       Subsystem 8 - Serial number: 4O2579†63727TS61CGS87V6P†63
       Subsystem 9 - Serial number: S87V6P†63827TS61CGS0A67/
       Subsystem 10 - Serial number: S0A67/
       Part No SW: 3C0 953 549 L    HW: 3C0 953 549 L
       Component: Lenksulenmodul 006 0010
       Revision: 00006000    Serial number: 3C5953507BK
       Coding: 0000013
       VCID: 3537DF45294BE75F922-8060
       Part No SW: 3C0 920 971 F    HW: 3C0 920 971 F
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 28090631EEF98AB7194-807C
    00771 - Fuel Level Sensor (G)
                        Fault Status: 00101010
                        Reset counter: 17
                        Mileage: 132059 km
                        Date: 2018.07.12
                        Time: 08:24:01
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P078310302
       Coding: F9807F070012021002
       VCID: 2313111D97DF69EF4C6-8076
                        Reset counter: 35
                        Mileage: 132496 km
                        Date: 2018.07.24
                        Time: 06:01:44
                        Reset counter: 35
                        Mileage: 132496 km
                        Date: 2018.07.24
                        Time: 06:01:44
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0003
       Revision: 00005000    Serial number: 1166279TRTRJ06
       VCID: 6D873725019B6F9FAA2-8038
       Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       Shop #: WSC 61689 001 1048576
       VCID: 73B3215D67BFB96F7C6-8026
       Component: J386  TUER-SG FT    1131
       Revision: 32008001    Serial number: 00000043278919
       Coding: 0001205
       VCID: 3B23C97D0F6F312F646-806E
                        Fault Status: 00100101
                        Reset counter: 17
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.134 H08 1901
       Component:    KSG PQ46 RDK 051 0221
       Coding: 13910F8001862E521004141FF08A0F0E085C00
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1131
       Revision: 32008001    Serial number: 00000634978919
       Coding: 0001204
       VCID: 3C21CA610A6136176DC-8068
                        Reset counter: 17
       Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
       Component: J540 EPB3  VW-09393 0009
       Revision:   008       Serial number: 00000000169747
       Coding: 0000057
       VCID: 290F0335F5F3B3BF06A-807C
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
       Component: Radio DE2       014 0019
       Revision: 00014000    Serial number: VWZ4Z7G6288508
       Coding: 0040402
    00856 - Radio Antenna
    00857 - CD Changer Unit (R41)
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1118
       Revision: 12006001    Serial number: 00000002365049
       Coding: 0001168
       VCID: 3E25C0691C7D2407438-806A
       Coding: 0100101
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1118
       Revision: 12006001    Serial number: 00000002374822
       Coding: 0001168
       VCID: 3FDBBD6D1B772D0F48E-806A
    End----------(Elapsed Time: 01:30, VBatt start/end: 12.5V/12.6V)-----------
    De-activating transport mode...Done.
    Aug 2016
    Eindhoven, NB, NL
    Mileage: 132718 km
    Date: 2018.07.28
    Time: 15:13:38
    RPM: 1646 /min
    Load: 28.2 %
    Speed: 67.0 km/h
    Temperature: 78.0C
    Temperature: 40.0C
    Voltage: 14.097 V
    I mean, what did you expect? Remove catalytic converter, get a light...
    Sep 2017
    How can the ecm detect that there is no cat on the car?
  4. Likes Fredrick Awuor liked this post
    Aug 2016
    Eindhoven, NB, NL
    It checks up on the functioning of the catalytic converter using the 1st and 2nd lambda probes.
  6. Likes Fredrick Awuor liked this post
    Sep 2017
    i read several reviews saying i would not get a cel . is there way to fix this w rosstech? also in what mode does this put car or what map?
    are u talking about the O2 sensors? there is nothing else on the exhaust !.
    all reviews said no cel .
    how do they detect no cat? what reading is it, temp changes on the O2 ? I found 1 post you can install a 25mm extention then the O2 and will fix this.
    Sep 2017
    42draftdesigns O2 spacer .... Apparently their spacer works the best for getting rid of the cel code ....
    I know a friend who's catless and stock tune and he installed the rear O2 spacer and that got rid of the code so far ....
    https://www.amazon.com/Degree-Angled...r+spacer&psc=1
    Aug 2016
    Eindhoven, NB, NL
    As far as I'm concerned, the only correct way to solve this is by fitting a functioning catalytic converter...
  10. #8
    JPPSG can help!
    Sounds like FOD! in violation of Cannon Law Conformity
  11. Likes PetrolDave liked this post
  12. #9
    Dec 2016
    Amsterdam
    Quote Originally Posted by Apexmaster33 View Post
    Why do you think it has 2 O2 sensors, one before and one after the catalyst?
    If they both read more or less the same, that means nothing happens in between which means the catalyst is not functioning.
    Current:
  13. Likes Uwe liked this post
  14. #10
    Jul 2018
    Is there any cat you can buy to replace the factory one other than another OEM unit that is qualified to ensure no emissions testing issues?
    I finally got a plug so I could back pressure test my cat via the O2 port. It ended up being no hint of back pressure, so my issue is elsewhere. Prior to that conclusion, I was looking $950 for a replacement cat (I also have a 2.0T) and that seemed nuts. Except every other option possible, with or without a stage 2 tune, is a crapshoot as to if a spacer may or may not address emissions readiness issues (ie, ready and no mil).
