Results 11 to 20 of 38
Thread: VW e-Golf MK 7 - 2015/16 - Coding issues
    Quote Originally Posted by trangakil View Post
    ,...........if the A socket #60 pin is not wired, I can hard-wire this myself.
    Yes, of course you can do this - but I would physically eyeball the pin (and also pin #31 "C" socket) to ensure that these positions are populated on the BCM housing. Else you might also need a new BCM (I have no idea whether RoW specific pins are populated on NAR BCM s). Replacing the BCM then entails dealing with Component Protection errors - which gets messy because for the need to involve a stealer!
    However, you could also use the "thieving method" that I described above and create your own cross wiring loom. it depends really on which method you see as being the less trouble. I note that you are discussing the same issues over on VWVortex forum - the process that JBale describes for the rear fog lights uses the "thieving method"
    P.S.: I have no clue, I could remember when I started coding the lights around 3 weeks ago, I did touch this channel, but it is strange that is now completely missing. After coding the settings as indicated in your table, I will make a new one again. Let's see if it's still gone.
    I was being a tad cheeky in suggesting that it was something that you had done to cause the adaptation channel to disappear (it's my devious Aussie humor). Fact is that a VCDS cable user can't delete an entire adaptation channel from the admap report - at least I don't believe that this is possible. Rather (if the deficiency is repeated in your next scan report), I suspect that the problem is caused by Release 18.2.1 version software.
  2. Likes trangakil liked this post
  3. #12
    I just checked the data and "ENG116956-ENG116252 - Leuchte20BR LA71 - Lasttyp 20" definitely exists in the DS287 version of EV_BCMBOSCH_013. That implies that VCDS would try to read it when making a map, but that it failed somehow.
    I would suggest going to the Adaptation function and reading it manually to see what happens.
  4. Likes trangakil liked this post
  5. #13
    Verified VCDS-User
    Jul 2018
    Ok Don, tomorrow I will try to dismantle the BCM and make some pictures to figure out what can be the best solution.
  6. #14
    Verified VCDS-User
    Jul 2018
    Hi Guys,
    After programming the whole day I got a little bit further!
    What I did:
    - Programmed the turn signal as inidcated, unfortunately there was no difference;
    - Made some adjustmets to the inner and outer lights;
    - Used the thieving method to connect the rear fog.
    Autoscan:
    Monday,30,July,2018,16:22:31:28664
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWPP7AU2FW909416   License Plate:
    Chassis Type: AU-VW37 (5QE)
    Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
              BD C0 C5 C6
    VIN: WVWPP7AU2FW909416   Mileage: 35721km-22196miles
    BD-Hi Volt. Batt. Charg. -- Status: OK 0000
    C5-Therm. mgt. -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
       Part No SW: 0EA 906 016 C    HW: 0EA 907 309 A
       Component: E-Vehicle     H23 8073
       Revision: WMH23---
       Coding: 000D0016002400007000
       ASAM Dataset: EV_VCU00XXX0110EA906016C 002005
       ROD: EV_VCU00XXX0110EA906016C_002.rod
       VCID: 2F3AE4FA779BB3FFD8D-807A
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AE    HW: 5Q0 907 379 H
       Component: ESC           H31 0808
       Revision: 00000000    Serial number: 60485000000379
       Coding: 01FA40A12C203175017B020181C9298002348C80408194B202810058C242
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
       VCID: 7F5AF4BAE77B837F08D-802A
       Revision: 00021000    Serial number: 0362156484
       Coding: 030C0C
       VCID: 3A2CC5AEBCD966577F3-806E
       Part No SW: 5GE 907 044 AD    HW: 5GE 907 044 AD
       Component: Climatronic   H02 1105
       Revision: 00001K07
       Coding: 00022200200100000005000200111801
       ASAM Dataset: EV_ACClimaBHBVW37X 005132
       ROD: EV_ACClimaBHBVW37X_005_VW37.rod
       VCID: 7EA409BEE0718A7703B-802A
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0137
       Serial number: 01011505400295
       Coding: 00011A66434182B169E44000001407201C00000000000000000000000000
       Shop #: WSC 00196 211 211196
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79AE1AA2F95FAD4F369-802C
       Component: WWS    150221  043 0551
       Serial number:         150227050251
       Component: RLHS  037 0059
       Serial number: S5Y15M03D09H05M10S29
       Coding: 00A8DD
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391505606605
       Coding: 2031151011
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 3D26CEB2ADF7516F5A1-8068
       Serial number: 003GCR01GUEX
       Coding: 8CCCFC00002000005000001AC24800000065
       VCID: 47CAAC5AFF2B0BBFF0D-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J150002CIW90F
       Coding: 303139
       Subsystem 2 - Part No SW: -----------    HW: 480 002 702 15
       Serial number: 357000000008396C731L
       Subsystem 3 - Part No SW: -----------    HW: 480 002 702 15
       Serial number: 358000000004B848731J
       Subsystem 4 - Part No SW: -----------    HW: 480 401 702 15
       Serial number: 35100029919121A3D20S
       Subsystem 5 - Part No SW: -----------    HW: 480 401 602 15
       Serial number: 3520002B91993FC0D2FP
       Subsystem 6 - Part No SW: -----------    HW: 480 401 702 15
       Serial number: 3550002BB1993FC2E0BR
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 702 15
       Serial number: 3560002B91993FC15218
       Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 01031504220908
       Coding: 0410
       ROD: EV_SMLSKLOMQB_013_AU37.rod
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 5GE 920 855     HW: 5GE 920 855
       Component: KOMBI         301 4311
       Coding: 0B35181A2B80CF05020868001700030000000000
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 C    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3203
       Revision: --------    Serial number: 25021510801288
       Coding: 0201001746F81000EF001200081E00000001050100030000000000000000
       ASAM Dataset: EV_GatewEVConti 011020
       ROD: EV_GatewEVConti_011.rod
       VCID: 46D4A15EF82112B70BB-8012
       Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0101
       Serial number: 27140002611420104426
       Coding: 30FFFF
       Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
       Serial number: 7079274703
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
       Component: EBKV          H12 0160
       Serial number:   085430010041
       Coding: 01720100321A02030002000500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
       ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
       VCID: 4CC09376E64DE8E7DDF-8018
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0140
       Serial number: 05802861230215132159
       Revision: 00000000    Serial number: 15000055931004
       Coding: 7900000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3430EB969EBD9027A5F-8060
       Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
       Serial number: 230215BBL16924
       Coding: 003013208000040000000000
       VCID: 40D8B746DA053C87317-8014
       Serial number: 00000000000005469881
       Coding: 111000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: C102
       VCID: 43D2B84ACB13279F2C5-8016
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5QE 907 080 C    HW: 5QE 907 080 C
       Component: VW370E2615010 H06 2461
       Revision: 00H06000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM09550115QE907080C 001020
       ROD: EV_DMCM09550115QE907080C.rod
       Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
       Serial number: 150215BBE06157
       VCID: 3FDAB4BAA7FB437F48D-806A
       Serial number: 00000000000005467289
       Coding: 091000
       Coding: 051A000101000000
       VCID: 75B61692D547C92F521-8020
       Part No SW: 5G0 035 876     HW: 5G0 035 876
       Component: MU-S-NS-US    014 R025
       Serial number: V7B00502152734
       Coding: 02737002FF00000021220001005800001F0209D40100010176
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 698E4AE289FF1DCFC69-803C
       Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
       Component: ABT_Std_Nav  H60 0030
       Serial number: VWZ8Z9RS600KN7
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 45
                        Mileage: 35721 km
                        Date: 2018.07.30
                        Time: 16:18:42
                        Voltage terminal 30: 13.4 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
              B11CF 53 [009] - Deactivated
                        Reset counter: 45
                        Mileage: 35721 km
                        Date: 2018.07.30
                        Time: 16:18:43
       Component: OCULowMQBUS   007 0564
       Coding: 02737001C2829A017FFE06000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
       Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
       Component: K8C           H13 0722
       Serial number: VWADFCA01N
       ASAM Dataset: EV_BECM08820215QE915227M 003016
       ROD: EV_BECM08820215QE915227H.rod
       VCID: 52FC8D0E0469BE17973-8006
    Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V1.clb
       Part No SW: 5QE 915 022 G    HW: 12E 915 022 C
       Component: LMSG          H08 1075
       Serial number: 00920050810140
       Coding: 4A4D01
       ASAM Dataset: EV_HVChargManagVWMQB 001001
       ROD: EV_HVChargManagVWMQB_001.rod
       VCID: 45D6A652C52719AF021-8010
    Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
       Part No SW: 5QE 035 335 H    HW: 5QE 035 335 H
       Component: E_SOUND_SG    H07 0198
       Serial number: EN150800820000
       Coding: 04
       ASAM Dataset: EV_ENoiseS1NNVW3707 005012
       ROD: EV_ENoiseS1NNVW3707_005.rod
    Address C5: Therm. mgt. (J1024)       Labels: None
       Part No SW: 5GE 907 458     HW: 5GE 907 458
       Component: TME-Min       H03 0107
       Serial number: 0008305
       ASAM Dataset: EV_ThermContrVISAU49X 001009
       ROD: EV_ThermContrVISAU49X_VW37.rod
       VCID: 025C7D4E9489EE97673-8056
       Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G395 pT-Sens1  H61 0006
       Subsystem 2 - Part No SW: 12E 963 231 E    HW: 12E 963 231 E
       Component: J848 HV-PTC  H09 0205
       Serial number:  T150593003805000056
       Subsystem 3 - Part No SW: 5QE 820 803     HW: 5QE 820 803
       Component: J842 eKK  H03 0006
       Refrigerant Pressure And Temperature Sender 2:
       Subsystem 4 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G826 pT-Sens2  H61 0006
       Refrigerant Pressure And Temperature Sender 3:
       Subsystem 5 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G827 pT-Sens3  H61 0006
       Refrigerant Pressure And Temperature Sender 4:
       Subsystem 6 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G828 pT-Sens4  H61 0006
       Refrigerant Pressure And Temperature Sender 5:
       Subsystem 7 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G829 pT-Sens5  H61 0006
       Refrigerant Expansion Valve 1:
       Subsystem 8 - Part No SW: 4M0 816 682     HW: 4M0 816 682
       Component: N636 EV1_KaMi  H09 0102
       Serial number: 00000000000020030682
       Refrigerant Expansion Valve 2:
       Subsystem 9 - Part No SW: 4M0 816 682     HW: 4M0 816 682
       Component: N637 EV2_KaMi  H09 0102
       Serial number: 00000000000020031239
       Refrigerant Expansion Valve 3:
       Subsystem 10 - Part No SW: 4M0 816 682     HW: 4M0 816 682
       Component: N638 EV3_KaMi  H09 0102
       Serial number: 00000000000020031237
       Refrigerant Shut Off Valve 1:
       Subsystem 11 - Part No SW: 4M0 816 703     HW: 4M0 816 703
       Component: V424 AV1_KaMi  H09 0102
       Serial number: 00000000000040030149
       Refrigerant Shut Off Valve 4:
       Subsystem 12 - Part No SW: 4M0 816 703     HW: 4M0 816 703
       Component: N642 AV4_KaMi  H09 0102
       Serial number: 00000000000040030158
       Refrigerant Shut Off Valve 5:
       Subsystem 13 - Part No SW: 4M0 816 703     HW: 4M0 816 703
       Component: N643 AV5_KaMi  H09 0102
       Serial number: 00000000000040028867
    36921 - Databus
              U1123 00 [039] - Received Error Message
              [Klima_Sensor_03: FSA_Temp_Luft empfangener Fehlerwert]
                        Mileage: 35721 km
                        Date: 2018.07.30
                        Time: 16:18:50
    37009 - Databus
              [Klima_Sensor_03: FSA_Taupunkt empfangener Fehlerwert]
                        Mileage: 35721 km
                        Date: 2018.07.30
                        Time: 16:18:50
    37051 - Databus
              [Klima_Sensor_03: FSA_Temp_Sensor empfangener Fehlerwert]
                        Mileage: 35721 km
                        Date: 2018.07.30
                        Time: 16:18:50
    59059 - Refrigerant Expansion Valve 2
              P1C0E 00 [039] - Implausible Signal
                        Mileage: 35721 km
                        Date: 2018.07.30
                        Time: 16:18:48
    Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
       Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
       Component: OBC Delta-ES  H52 1560
       ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
       ROD: EV_OBCTwoPhaseDT2VW3707.rod
       VCID: 4BC2906AE343EFDFD45-801E
    End----------(Elapsed Time: 01:57, VBatt start/end: 13.4V/13.5V)-----------
    Controller channel map 9:
    SW:5Q0-937-085-AB   HW:5Q0-937-085-AB ---  Cent. Elect.
    Component:BCM MQBAB MNA H18 0137, Coding:00011A66434182B169E44000001407201C00000000000000000000000000
    EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    Friday,27,July,2018,17:01:56:28664
    VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
    IDE01550-Service position,170.49 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
    IDE05142-ENG116706-Access control-Autounlock NAR,active ,8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,not active ,8
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active ,8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
    IDE05142-ENG115758-Access control-Valet Parking,not active ,8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,52 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,53 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,48 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,4C ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,00 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,00 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,35 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00 ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,3F ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,127 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,127 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,127 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,127 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,10 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,10 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,35 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,30 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,55 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,56 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,4A ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,4C ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,00 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,26 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00 ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,47 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,27 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,not active ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,not active ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,6 - LED Lichtmodul ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,6 - LED Lichtmodul ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,6 - LED Lichtmodul ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,6 - LED Lichtmodul ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,12 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,11 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,12 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,20 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,20 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,2 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,4 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,8 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,11 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,8 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,24 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,11 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,12 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,4 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
    IDE07356-Position during interval mode,31.49 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,not active ,8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,not active ,8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active ,8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,7.49 °,2
    IDE10299-Alternating park position 2,29.49 °,2
    MAS05055-lower turn position,31.49 °,2
    MAS05056-upper turn position,170.49 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,55 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,52 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Abblendlicht links ,16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,56 ,16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,53 ,16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Abblendlicht rechts ,16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,10 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,4A ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,48 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Daytime running lights ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Abblendlicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,10 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,4C ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,4C ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Daytime running lights ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Abblendlicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,35 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Blinken links Hellphase ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,30 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Brake light ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,26 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,35 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,32 - allgemeine LED bis 12W ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,27 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,3F ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,32 - allgemeine LED bis 12W ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,6 - LED Lichtmodul ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Abblendlicht links ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,6 - LED Lichtmodul ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Abblendlicht rechts ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
    ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
    ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
    Elapsed Time: 01:35
    	SW:5Q0-937-085-AB   HW:5Q0-937-085-AB ---  Cent. Elect.
    	Component:BCM MQBAB MNA H18 0137, Coding:00011A66434182B169E44000001407201C00000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    	Friday,27,July,2018,17:14:08:28664
    	VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    	VCID: 79AE1AA2F95FAD4F369-802C
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
    IDE01550-Service position,170.49 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
    IDE05142-ENG116706-Access control-Autounlock NAR,active ,8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,not active ,8
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active ,8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
    IDE05142-ENG115758-Access control-Valet Parking,not active ,8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,52 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,53 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,48 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,4C ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,00 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,00 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,35 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00 ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,3F ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,127 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,127 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,127 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,127 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,10 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,10 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,35 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,30 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,55 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,56 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,4A ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,4C ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,00 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,26 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00 ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,47 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,27 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,not active ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,not active ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,6 - LED Lichtmodul ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,6 - LED Lichtmodul ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,6 - LED Lichtmodul ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,6 - LED Lichtmodul ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,12 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,11 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,12 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,20 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,20 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,2 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,4 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,8 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,11 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,8 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,24 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,11 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,12 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,4 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
    IDE07356-Position during interval mode,31.49 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,not active ,8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,not active ,8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active ,8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,7.49 °,2
    IDE10299-Alternating park position 2,29.49 °,2
    MAS05055-lower turn position,31.49 °,2
    MAS05056-upper turn position,170.49 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,55 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,52 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Abblendlicht links ,16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,56 ,16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,53 ,16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Abblendlicht rechts ,16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,10 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,4A ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,48 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Daytime running lights ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Abblendlicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,10 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,4C ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,4C ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Daytime running lights ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Abblendlicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,35 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Blinken links Hellphase ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,30 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Brake light ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,26 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,35 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,32 - allgemeine LED bis 12W ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,27 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,3F ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,32 - allgemeine LED bis 12W ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,6 - LED Lichtmodul ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Abblendlicht links ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,6 - LED Lichtmodul ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Abblendlicht rechts ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
    ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
    ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
    Elapsed Time: 01:36
    	SW:5Q0-937-085-AB   HW:5Q0-937-085-AB ---  Cent. Elect.
    	Component:BCM MQBAB MNA H18 0137, Coding:00011A66434182B169E44000001407201C00000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    	Monday,30,July,2018,16:24:18:28664
    	VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    	VCID: 79AE1AA2F95FAD4F369-802C
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
    IDE01550-Service position,170.49 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
    IDE05142-ENG116706-Access control-Autounlock NAR,active ,8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,not active ,8
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active ,8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
    IDE05142-ENG115758-Access control-Valet Parking,not active ,8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,52 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,53 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,48 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,4C ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,35 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00 ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,3F ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,127 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,127 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,127 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,127 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,10 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,10 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,35 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,55 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,56 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,4A ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,4C ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,26 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00 ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,47 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,27 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,13 - Bremsleuchten ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,13 - Bremsleuchten ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,6 - LED Lichtmodul ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,6 - LED Lichtmodul ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,6 - LED Lichtmodul ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,6 - LED Lichtmodul ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,12 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,11 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,12 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,20 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,20 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,0 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,4 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,24 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,24 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,8 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,26 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,11 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,24 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,24 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,11 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,12 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,4 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
    IDE07356-Position during interval mode,31.49 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,not active ,8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,not active ,8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active ,8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,7.49 °,2
    IDE10299-Alternating park position 2,29.49 °,2
    MAS05055-lower turn position,31.49 °,2
    MAS05056-upper turn position,170.49 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,55 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,52 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Abblendlicht links ,16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,56 ,16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,53 ,16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Abblendlicht rechts ,16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,10 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,4A ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,48 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Daytime running lights ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Abblendlicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,10 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,4C ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,4C ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Daytime running lights ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Abblendlicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,35 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,13 - Bremsleuchten ,16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake light ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Brake light ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,13 - Bremsleuchten ,16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake light ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Brake light ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,26 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,35 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,32 - allgemeine LED bis 12W ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,27 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,3F ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,32 - allgemeine LED bis 12W ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,6 - LED Lichtmodul ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Abblendlicht links ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,6 - LED Lichtmodul ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Abblendlicht rechts ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
    ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
    ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
    Elapsed Time: 01:53
    	SW:5Q0-937-085-AB   HW:5Q0-937-085-AB ---  Cent. Elect. --- SA: S12345
    	Component:BCM MQBAB MNA H18 0137, Coding:00011A66434182B169E44000001407201C00000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    	Monday,30,July,2018,16:27:15:28664
    	VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    	VCID: 79AE1AA2F95FAD4F369-802C
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
    IDE01550-Service position,170.49 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
    IDE05142-ENG116706-Access control-Autounlock NAR,active ,8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,not active ,8
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active ,8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
    IDE05142-ENG115758-Access control-Valet Parking,not active ,8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,52 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,53 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,48 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,4C ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,35 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00 ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,3F ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,127 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,127 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,127 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,127 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,10 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,10 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,35 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,55 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,56 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,4A ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,4C ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,26 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00 ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,47 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,27 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,13 - Bremsleuchten ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,13 - Bremsleuchten ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,6 - LED Lichtmodul ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,6 - LED Lichtmodul ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,6 - LED Lichtmodul ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,6 - LED Lichtmodul ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,12 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,11 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,12 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,20 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,20 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,0 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,4 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,24 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,24 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,8 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,26 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,11 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,24 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,24 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,11 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,12 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,4 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
    IDE07356-Position during interval mode,31.49 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,not active ,8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,not active ,8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active ,8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,7.49 °,2
    IDE10299-Alternating park position 2,29.49 °,2
    MAS01490-Energy management,active ,1
    MAS05055-lower turn position,31.49 °,2
    MAS05056-upper turn position,170.49 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
    ENG122934-erase_error_table,55 00 00 ,3
    ENG122933-error_mask,0 bit,2
    ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
    ENG117283-ENG108451-Frontwaschfunktion-reserve,0 ,2
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,55 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,52 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Abblendlicht links ,16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,56 ,16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,53 ,16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Abblendlicht rechts ,16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,10 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,4A ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,48 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Daytime running lights ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Abblendlicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,10 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,4C ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,4C ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Daytime running lights ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Abblendlicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,35 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,13 - Bremsleuchten ,16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake light ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Brake light ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,13 - Bremsleuchten ,16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake light ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Brake light ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,26 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,35 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,32 - allgemeine LED bis 12W ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,27 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,3F ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,32 - allgemeine LED bis 12W ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,6 - LED Lichtmodul ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Abblendlicht links ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,6 - LED Lichtmodul ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Abblendlicht rechts ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
    ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
    ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
    ENG122927-RLS_close_glazing,2.00 s,1
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
    ENG122929-RLS_LIN_Communication,4 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
    ENG122930-RLS_tunel_gateway_recognize,5 s,1
    ENG122935-RLS_Washer_Front,15 s,1
    ENG122926-RLS_wiper_position_parking,15 s,1
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
    Pictures
  7. Likes Uwe liked this post
  8. #15
    Verified VCDS-User
    Jul 2018
    So in the end the braking lights, the fog lights and the normal lights are now in accordance with regulation. The signal lights also, but still if I'm hitting the brake, the also are lighting up...
    Hope someone can help me out with this last part.
    I will start on the BCM now and try to reveal it with some pictures!
    Thanking everybody in advance!
  9. #16
    Verified VCDS-User
    Jul 2018
    And also before I forget... The 20BR channel is acting weird:
  10. #17
    Quote Originally Posted by trangakil View Post
    Please try it with the current Beta.
    I think that was addressed in 18.5.2.
  11. #18
    Verified VCDS-User
    Jul 2018
    Hi Uwe,
    Thanks for the swift reply, probably my lack of knowledge, but can't seem to make it work. I keep changing the channel to beta, but VCDS indicates communication is not set.
  12. #19
    Can you give us the exact error message, please?
    From here, it looks like your HEX-V2 is set to Beta Channel, but still has older software in it.
  13. #20
    Verified VCDS-User
    Jul 2018
    Hi Uwe,
    I'll try to make a screenshot tomorrow.
    The exact message (my closest guess) was when trying to run an auto-scan:
    " Communication error 0" and a line to go into the options and test menu.
