Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: VW T5 2013 Transporter (7H?) reversing sensors not showing on head unit
    Oct 2014
    Couple of questions (new user by the way) from the outset. Using 7H for the scan takes an inordinate amount of time (like 5 mins or so+) is that normal? 7H says for vans up to 2010 and mine is a 2013 but is also a 7H according to VIN.
    Second question relates to the actual problem.
    VW dealership had the van recently and to fix a minor problem they "de-coded everything" and "started again" according to the tech there. Which is cool, however, as I had switched the head unit from the standard RNS 315 to the improved Kenwood DNX 525 DAB unit (standard in the Sportline model in the UK) and the RNS 315 wasn't actually IN the vehicle when they recoded everything I have lost the facility I had before of viewing the reversing sensors on the screen. More importantly, the reversing sensors no longer mute the audio of either of the head units either, so unless you remember to turn down the volume to the bare minimum, you can't even make out the tiny beep that is provided by the OE speaker under the dash.
    I have tried reinstalling the old head unit and auto scanning and making sure the "park assist" is enabled but am now at a loss as to what to try to get it to work.
    Hope that all makes sense.
    New user, so be gentle, tried to validate serial number, assuming that takes time.
    Thanks in advance.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Wuffles View Post
    Welcome!
    On a CAN-based vehicle, if you leave it on Auto-Detect it should go faster. It will only scan modules that the CAN gateway reports installed in your particular vehicle. If you select 7H manually, it will try to scan every address that could conceivably be installed on a 7H vehicle. It will take VCDS a little while to give up and move on each time it tries to scan a module you don't have.
    At a minimum, please paste a current complete, unmodified Auto-Scan here with your aftermarket unit installed like you want it. Also, if you happen to have one saved, please post an Auto-Scan from before the dealer got to it. This will go a lot easier if we can compare before-and-after to see what the dealer did.
    Edit: also, what was the "minor problem"? It may be relevant.
    Jason
  3. Likes Uwe, jakematic liked this post
    Oct 2014
    It was throwing up an error when I tried "Auto Detect", but I'll try it again in a bit and see.
    The minor error was (it's longish story) that the van was convinced it had a trailer attached and had disabled the reversing sensors entirely, plus was giving an error to say that there was a bulb out (which of course there was, all of the ones in the trailer that wasn't there). This all happened after I visited a guy who had a genuine VCDS cable to reset an airbag warning light I triggered when I fitted the new head unit. Westfalia didn't want to know about the trailer hitch as it's not using their cable (it's a Right Connections electronics kit apparently), and the dealer who fitted it (not VW) are miles away, so the dealership checked it over, decided it was the trailer module at fault and disconnected it all (they didn't charge me, which was nice).
    However, on leaving the dealership I realised they'd also disabled the rear sensors completely. So it went back in and that's when they trashed it all and started over. When I collected it I asked them why the graphics had gone from the head unit but was thankful the reversing was now working and I was told it wasn't something they could do for that head unit.
    So...I promptly bought my own cable assuming that just plugging in the old head unit and recoding it would be easy enough and get it back to how it was, then switch the head unit back again. Ta daa.
    And here I am. Hi.
    VCDS Version: Release 12.12.3
    Data version: 20140905
    Tuesday,21,October,2014,11:36:45:38089
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZEH070538
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0110
       Revision: 00H43001
       Coding: 108724AD09AB089524A79074AA6610
       Shop #: WSC 02736 790 49152
       VCID: 3A7B16FEB5CB50CE959-806F
    Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
       Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
       Component: Climatic-T5   H20 0506
       Revision: 00001012
       Coding: 0000000002
       Shop #: WSC 02736 790 50316
       ROD: EV_ClimaT5Basis_VN75.rod
       VCID: 7BF5D3FAF271A9C6CEF-802E
    Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
       Part No SW: 7H0 937 087 M    HW: 7H0 937 087
       Component: BCM T5GP H+4  H34 0413
       Revision: BO034001    Serial number: 0573 318130043
       Coding: A0B0793A0A612413922848106C2B8CD40080432F60840000320000000000
       Shop #: WSC 00000 288 02691
       VCID: 3E731AEEA9E37CEEA91-806B
       Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-801.CLB
       Component: J386__TSG_FT  003 8652
       Coding: 1000B0
       Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-802.CLB
       Component: J387__TSG_BT  003 8652
       Coding: 0000A0
       Subsystem 3 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 7E1 951 172
       Subsystem 6 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Coding: E20000
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00LRY71
       Shop #: WSC 02734 790 50316
       ROD: EV_AirbaVW10BPAVN750_SE12.rod
       VCID: 356105C294D5BFB678B-8060
       Part No SW: 7E0 920 970 J    HW: 7E0 920 970 J
       Component: KOMBI         H04 0710
       Coding: 460A01
       ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
       VCID: 316931D260BD9396243-8064
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 H34 0413
       Revision: BO034001
       Coding: 042300
       VCID: F0EF74D623375A9EEBD-80A5
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 09:25:17
    01517 - Control Module for Trailer/Towing Sensor (J345)
                        Reset counter: 158
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 09:26:11
                        Reset counter: 198
                        Mileage: 13039 km
                        Date: 2009.14.19
                        Time: 15:09:30
       Part No SW: 3C8 035 279 F    HW: 3C8 035 279 F
       Component: RNS315-EU   H76 0410
       Serial number: VWZAZ2N0640605
       Coding: 000002110200140000039002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2E532AAE71838C6E391-807B
       Component: EUR_W_V5  0055
    1048632 - Antenna 1 for Radio
              B1119 13 [009] - Open Circuit
                        Reset counter: 158
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 11:19:32
    1048634 - Antenna 2 for radio
              B111A 13 [009] - Open Circuit
                        Reset counter: 158
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 11:19:32
    1048582 - GPS Antenna
              B1054 13 [009] - Open Circuit
                        Reset counter: 158
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 11:19:32
    1048652 - Telephone Microphone
              B1048 13 [009] - Open Circuit
                        Reset counter: 158
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 11:19:32
    Address 76: Park Assist (J446)       Labels: 7E0-919-475.clb
       Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0106
       Revision: --------    Serial number: 32961331001412
       Coding: 000002
       Shop #: WSC 11299 002 1048576
       ASAM Dataset: EV_VW75XParkAssis4K 001004
       ROD: EV_VW75XParkAssis4K.rod
       VCID: 3A7B16FEBDCB50CE959-806F
    Oct 2014
    Auto scan worked a charm this time - must have been during my teething troubles at the start. Running XP in a virtual machine, but all working correctly now.
    There's a red herring in there (perhaps) as another shop tried to code the trailer back on again, but apparently couldn't find the physical wire VW had disconnected. I now have a manual for that and will do it once this first problem is sorted.
    Tuesday,21,October,2014,18:09:09:38089
    Chassis Type: 7H (6N0)
    Scan: 01 03 08 09 10 15 17 19 25 37 56 69 0B
    37-Navigation -- Status: Malfunction 1110
    69-Trailer -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
       Component: R4 2,0L EDC   H45 5576
       Revision: 26H45---    Serial number: 00000000000000
       Coding: 01194012232400080000
       ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
       ROD: EV_ECM20TDI01103L906019FM.rod
       VCID: 77FDCFCACE598DA6AA7-8022
       Revision: 00H43001
       Revision: 00001012
       Coding: 0000000002
       Coding: B0B0793A0A612413922848106C2B8CD40080432F60840000320000000000
       Coding: 1000B0
       Coding: 0000A0
       Coding: E20000
    Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
       Coding: 000002
       Coding: 460A01
       Revision: BO034001
       Coding: 042300
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 09:25:17
                        Reset counter: 158
                        Mileage: 13426 km
                        Date: 2009.14.31
                        Time: 09:26:11
                        Reset counter: 158
                        Mileage: 13039 km
                        Date: 2009.14.19
                        Time: 15:09:30
       Component: IMMO          H04 0710
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EADB66BE0DEBA04EA59-80BF
    Cincinnati, OH
    VCDS is having trouble talking to some things in your car. Using VCDS in a virtual machine isn't supported, but it works for many people and I'm not yet sure that's your problem. 56-Radio isn't in either of your scans, but 37-Navigation is in one of them. This is strange because they're different virtual addresses for the same device. 56-Radio is in your GVL in your second scan so it's not been coded out of the car, I don't think.
    Your second scan seems to have terminated early; it's missing a bunch of stuff. Can you do us a favor and install the latest VCDS Desktop Beta 14.8.1? It's almost ready for release anyway, and it has important improvements for newer vehicles like yours. I'd like to see what it makes of your vehicle before we go digging around for radio CAN wiring problems that might not exist.
    You still have the trailer controller in your GVL and the CAN gateway is looking for it without success, so if you intend to re-install it, let's go ahead and do that as well. The CAN gateway is also complaining of incorrect coding, and correcting that probably depends on making a decision about the trailer controller. Also, while I don't personally have experience with that sort of setup, I wonder if the trailer controller has input or influence over how/when the camera is engaged.
    Jason
    Auto scan worked a charm this time [...] Running XP in a virtual machine, but all working correctly now.
    Except the Radio/Nav head unit isn't responding?
    If the trailer module is disconnected, the first thing I'd do is tell the GW that there is no trailer module.
    [Select]
    [19-CAN Gatweway]
    [Installation List]
    Scroll down to 69-Trailer and un-tick it.
    [Save Coding]
    Then clear fault codes in in 19-CAN Gateway and see if that helps. My hopes are not that high, but this should be done in any case.
    Oct 2014
    Right on. I'll do all of that in a bit.
    Rather than play with the wiring yet, I will untick the Trailer module. To be honest, the only reason I bought the cable was because of this tinkering. It's not fair to rely on someone else's time for this level of tinkering. So I'd just left it all as it was.
    I was worried I had newer software forced on there by VW too.
    Am loving the feedback from everyone on this, it's been a lonely few weeks speaking with various manufacturers/installers who aren't interested as it's not ALL their specific problem and they've been able to be very slopey shouldered (understandably of course).
    I'll update the software and rescan in about half an hour.
  9. #8
    NC USA
    Ah but in the long run you'll find VCDS will save you a lot of money and headaches
  10. Likes jyoung8607 liked this post
  11. #9
    Oct 2014
    Righto. Took off the Trailer as per instructions. It did give me a message, I went for "no":
    Screen Shot 2014-10-21 at 19.51.02 by Wuffls, on Flickr
    VCDS Version: Beta 14.8.1
    Tuesday,21,October,2014,19:28:36:38089
    Scan: 01 03 08 09 10 15 17 19 25 37 56 0B
    VIN: WV1ZZZ7HZEH070538   Mileage: 13440km-8351miles
       VCID: 77FDCFCACE598D82E8-8022
       Revision: 00H43001
       VCID: 3A7B16FEB5CB50EAD7-806F
       Revision: 00001012
       Coding: 0000000002
       VCID: 7BF5D3FAF271A9E28C-802E
    Address 09: Cent. Elect.        Labels: 7H0-937-08x-09.clb
       Component: BCM T5GP H+4  H34 H34 04130413
       Shop #: WSC 12345 288 02691
       VCID: 3E731AEEA9E37CCAEB-806B
       Subsystem 1 - Part No: 7E0 959 801 K  Labels: 7E0-959-801.CLB
       Coding: 1000B0
       Subsystem 2 - Part No: 7E0 959 802 K  Labels: 7E0-959-802.CLB
       Coding: 0000A0
       Subsystem 6 - Part No: 3C8 959 537 D
       Coding: E20000
    No Faults Found
       Coding: 000002
       ROD: EV_VW75XParkAssis4K_VN75.rod
       VCID: 3A7B16FEBDCB50EAD7-806F
       VCID: 356105C294D5BF923A-8060
       Coding: 460A01
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 316931D260BD93B266-8064
       Revision: BO034001
       Coding: 042300
       VCID: 70EFF4D6A337DABA29-8025
                        Reset counter: 160
                        Mileage: 13444 km
                        Date: 2014.10.21
                        Time: 19:52:36
       VCID: 6ADBE6BE8DEB206A67-803F
    Address 56: Radio
    End-------------------------(Elapsed Time: 03:19)--------------------------
  12. #10
    Cincinnati, OH
    I can't seem to open that without having a Yahoo account, so I'm not sure what it's showing.
    76-Park Assist isn't present in most of your scans, but it's actually present in your first scan, the one where you forced a comprehensive scan of the entire car. So it's there, and maybe even perfectly healthy, but not in the GVL so the CAN gateway may not process or forward its messages properly. Go into the CAN gateway and tick 76-Park Assist in the same way you un-ticked 69-Trailer, and run another Auto-Scan to make sure it shows up. This may or may not fix your current complaint, but it's a step in the right direction.
    37-Navigation and 56-Radio are confirmed MIA, and 19-CAN Gateway doesn't see them either which points away from any potential problem with VCDS. Does your RNS-315 work properly other than the problem with the backup camera? If it's not on the CAN bus, it may not power on/off with the vehicle, it may not recognize headlights on/off and interior dimming, speed-dependent volume may not work, etc. Given that you've swapped radios at least twice in this car (stock to aftermarket to stock), the next thing to check is for damage to the CAN-Hi and CAN-Lo pair in the radio wiring harness.
    Jason
