Results 1 to 7 of 7
Thread: '05 Golf MK5, G62 sensor failure
    Oct 2014
    Norway
    Question '05 Golf MK5, G62 sensor failure
    I ran AutoScan which discovered failure with the G62 sensor.
    I refitted a new original sensor original from VAG, cleared all DTC's, but there is stil a problem with the sensor.
    I have tried to disconnect the positive cable on the battery to check if that could help.. but no...
    Is there anyone that could help me?
    Thanks in advance!
    Here is the code:
    Monday,20,October,2014,21:45:11:15915
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140905
    VIN: WVWZZZ1KZ5W050772   License Plate: KH30927
    Mileage: 137500km-85438mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
    VIN: WVWZZZ1KZ5W050772   Mileage: 137500km/85438miles
    Address 01: Engine        Labels: 036-906-032-AXP.lbl
       Part No SW: 036 997 032 D    HW: xxxxxxxxxxx
       Component: BOSCH ME7.5.10      9736
       Revision: 00000000    Serial number: VWZ7Z0D0119662
       Coding: 0000071
       Shop #: WSC 00220 218 16467
       VCID: 1B35FCB6DA9BEBC66EF-804E
    16502 - Engine Coolant Temp. Sensor (G62)
                P0118 - 002 - Signal too High - MIL ON
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 N
       Component: ASR FRONT MK70      0103
       Coding: 0017025
       Shop #: WSC 01392 785 00200
       VCID: 3D71122E644F85F6B0B-8068
       Part No: 1K0 820 047 CS
       Component: Climatic PQ35   081 0404
       VCID: 77FDC00606F36FA6AA7-8022
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
       Component: Bordnetz-SG 1.0 H30 0704
       Revision: 00030000    Serial number: 00000000893085
       Coding: 088F8F0600041800001400001400000000
       VCID: 3F8D68266E4397E6A27-806A
       Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
       Component: 01 AIRBAG VW8   023 0700
       Revision: 06023000    Serial number: 00385D0H2AM.
       Coding: 0012337
       Shop #: WSC 01371 785 00200
       VCID: 31693E1EA8177196243-8064
       Subsystem 1 - Serial number: 6332MSME35254803
       Subsystem 2 - Serial number: 6342MSME224D4903
       Subsystem 3 - Serial number: 6351HSME4B483803
       Subsystem 4 - Serial number: 6361HSME1C413D03
       Part No SW: 1K0 953 549     HW: 1K0 953 549
       Component: Lenksäulenmodul 500 0030
       VCID: EFED7866FEA3A766F27-80BA
       Part No: 1K0 920 851
       Component: KOMBIINSTRUMENT VDD 0814
       Coding: 0007103
       Shop #: WSC 00220 218 96319
       VCID: E5C11A4E2C5F6D3688B-80B0
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 E    HW: 1K0 907 951
       Component: Gateway         H09 0110
       Revision: 09          Serial number: 27001047060A20
       Coding: 3D3F4340070002
       VCID: 2959D67E80C70956EC3-807C
       Component: IMMO            VDD 0814
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0147
       Coding: 0000052
       VCID: 306F3B1AA31D789E2BD-8065
       Part No: 1K1 909 144 G
       Component: EPS_ZFLS Kl.1       1401
       VCID: 2F6D3866BE236766327-807A
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0201
       Coding: 00E802087F2D8404084F0100
       Shop #: WSC 00040 218 58589
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Component: Tuersteuergeraet 09 0153
       Coding: 0000052
       Part No: 1K0 035 186 L
       Component: Radio BVX       140 0022
       Coding: 0020200
       Shop #: WSC 00220 218 89102
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 06 0202
       Coding: 0000016
    Address 69: Trailer        Labels: 8P0-907-383.lbl
       Part No SW: 8P0 907 383     HW: 8P0 907 383
       Component: ANHAENGERELEKTR H01 0010
       VCID: F6E34D0281F996AE311-80A3
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Component: Tuersteuergeraet 06 0213
       Coding: 0000016
    Last edited by Uwe; 10-21-2014 at 10:30 AM. Reason: Wrapped CODE tags around Auto-Scan
    Look at Measuring Block 001, field 2 to see what the the ECU thinks the engine coolant temperature really is.
    If you have already replaced the sensor, then perhaps you have a wiring problem.
    Oct 2014
    Norway
    Thanks for your reply, I will check this later today.
    What is the easiest way to find out if I have a wiring problem? What value on the cable shall I expect to measure on the pins inside the connector? Is it possible get a value with out connect the sensor?
    United States
    Quote Originally Posted by JKB80 View Post
    Using the factory level wiring diagram is the easiest way to determine which terminal pins and wires are used but you may have success searching for "G62" in the repair manual to see if a Checking and/or Testing section is available. I personally wouldn't worry about any of that if you haven't already replaced G62.
    Most engine controllers support an ECT range of -40°C to +140°C so you should see something close to that when unplugged and the other when shorted but I would NOT short wires while testing unless you have a wiring diagram handy to reference.
    P.S. It doesn't look like you are registered with us. Please fill out this form so we can switch your forum status to Verified:
    http://www.ross-tech.com/vca/hex-com-reg.php
    Last edited by Dana; 10-21-2014 at 12:05 PM. Reason: VCDS Dongle Registration link added
  5. Likes Uwe liked this post
    Oct 2014
    Norway
    I did finaly managed to remove the error on the sensor.
    I removed the fault in the "Fault Codes" window instead of "Clear All DTC's" in the autoscan window.
    It's quite obvious that there is a difference..?
    I have not read all documentation for this tool yet, so it's probably described in a manual somewhere. It's about time to read some manuals..
    Of course I will register asap, I love this tool! Nice to have control, and save a lot of money as well! VAG workshops in Norway are not cheap..
  7. Likes Dana liked this post
    Tartu, Estonia
    Yay, another European user here
    Workshop prices aren't cheap nowhere, but based on average wage in Norway, i assume it's quite high.
    The world is my oyster...
  9. Likes Dana liked this post
  10. #7
    United States
    In a CAN car like this [Clear All DTCs] from the [Auto-Scan] function sends a command to the 19-CAN Gateway to clear faults without connecting to each and every controller.
    You could compare this to the old fashioned method of walking to and then knocking on the door at the neighbors house to borrow a cup of sugar (call this pre-CAN cars). If someone answered, there is a good chance that you are leaving with that sugar (or cleared fault codes).
    The new school method of sending a group text message to ALL of the neighbors in your contact list or posting on Facebook (call this CAN) does not guarantee that the recipients of that group message read it or feel obligated to look for the sugar (clear faults as they were asked).
    Golf based CAN cars rarely clear faults in the Engine Controller when clicking [Clear All DTCs] so it may be necessary to double click it from the Auto-Scan result page, where the module will open without having to backtrack to the Main Screen, and click [Clear Codes - 05].
    The Interactive (clickable buttons) Manual may be helpful: Online Demo / Manual
  11. Likes Uwe liked this post
