Hi All
Long time browser, first time poster.
This is about my own VW Caddy 1.6tdi CAYC Engine.
Had the fix done, 6 months later, injector had a hissy fit. Have fitted a nearly new injector (less than 4 weeks old), now trying to do anything along the lines of coding it or soft reset or anything, it says I need security access, so I jump back out of the coding section, into security access, and key in the code that appears in the pop up, 27971, but then comes up saying controller refused to send seed Error 7F Service not supported in session or something along those lines. So I then tried 12233, and have the same issue.
Anyone have any ideas on why?
I have pasted a copy of an auto scan below(ignore the Nav/stereo problems, I just haven't finished fitting my new radio, and the Oil Temp problem has been cleared now, although the Gateway fault is mystifying me the more I think about it)
TIA for any an all ideas and assistance.
Tuesday,24,July,2018,14:21:53:18208
VCDS Version: 18.2.1.2 (x64)
VIN: WV1ZZZ2KZCX054576 License Plate: NA61 TDU
Mileage: 300610km-186790mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WV1ZZZ2KZCX054576 Mileage: 300610km-186790miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TF HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000
Coding: 00114010032500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 7DF1979FECB64EAC4C-8028
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 433C400D092703FEC21002EB901FC081300000
Shop #: WSC 35110 377 00142
VCID: 79F9838FF09E728C60-802C
Part No SW: 2K5 937 085 HW: 2K5 937 085
Component: BCM PQ35 B+ 011 1044
Revision: BB011001
Coding: 411A583A8025182A088000829000006403017288524F0160648000000040
VCID: 72EBB4A3ADE801D421-8026
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 07091 26 0512
Coding: 009795
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL007LV6K
Coding: 000000000000000000000000000000003055
VCID: 35614FBF940656ECC4-8060
Part No SW: 5K0 953 507 AR HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KIE000L5
Coding: 5080160000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 000FEE6B9B44234427-8054
Part No SW: 2K0 920 965 E HW: 2K0 920 965 E
Component: KOMBI H03 0606
Coding: 480801
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 31697BAF606E7ACC98-8064
1416448 - Oil Level Thermal Sensor
B1041 29 [008] - Signal Implausible
Fault Frequency: 70
Reset counter: 99
Mileage: 297308 km
Date: 2018.06.18
Time: 16:03:37
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 210911F1003229
Coding: 357401
VCID: 35614FBF9C0656ECC4-8060
Mileage: 286849 km
Date: 2012.08.24
Time: 20:35:37
Component: IMMO H03 0606
VCID: 6ADBACC38D38C91499-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 HW: 3C0 035 279
Component: RNS315 H05 0010
Serial number: VWZAZ2L3312155
Coding: 040004010400000000011000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_RNS315VWEUV1UDS A01005
ROD: EV_RNS315VWEUV1UDS.rod
VCID: 60CFCEEB7B04834447-8034
10 Faults Found:
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Reset counter: 174
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Reset counter: 174
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 56
Mileage: 297305 km
Date: 2018.06.18
Time: 14:40:32
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 56
Mileage: 297305 km
Date: 2018.06.18
Time: 14:40:32
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Reset counter: 98
Mileage: 297303 km
Date: 2018.06.18
Time: 07:38:54
1048632 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Reset counter: 174
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
1048634 - Antenna 2 for radio
B111A 13 [009] - Open Circuit
Reset counter: 174
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
1048582 - GPS Antenna
B1054 13 [008] - Open Circuit
Reset counter: 113
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
1048636 - Digital Radio Antenna
B1103 13 [009] - Open Circuit
Reset counter: 174
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
1048652 - Telephone Microphone
B1048 13 [008] - Open Circuit
Reset counter: 113
Mileage: 261702 km
Date: 2018.04.15
Time: 14:55:24
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 74 0160
Coding: 0000000
VCID: 76E388B301801DF40D-8022
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 346772BB577C4FE4F3-8060
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Component: Tuersteuergeraet 02 0160
Coding: 0000000
VCID: 75E18FBF1C8616EC04-8020
End-------------------------(Elapsed Time: 02:03)--------------------------
