Results 1 to 10 of 15
Thread: MKIV R32 Turbo: Random ECM codes. EPS and Traction Control lights - HELP :/
    Oct 2014
    Question MKIV R32 Turbo: Random ECM codes. EPS and Traction Control lights - HELP :/
    This mainly goes out to anybody with a MKIV R32 turbo, but all help is truly appreciated.
    What’s happening :
    I have a MKIV R32 with about 1k, trouble free miles on the turbo setup.
    About two weeks ago I was cruising around 40-45 in 3rd gear and the traction control light turned on. The car started stuttering as if it wasn’t getting fuel, then the EPC light came on. I pulled over and let the car idle. It was super rough, vacuum was bouncing between 10 and 20, idle RPMs were fluctuating and Air/Fuel was in the 20s. I turned the car off, let it sit for about 30 seconds, turned it back on, and it was back to 100% normal.
    Next time I drove the car it was fine. The time after that, it did the same thing cruising down the highway at about 60. I was at about 10% throttle and after about 20 seconds, it went back to normal. Turned it off while cruising, and back on, and again it ran perfect. It’s been doing this completely randomly for the past 100 miles or so.
    Codes I’m getting:
    First time I ran VCDS
    16891 – Idle Control System RPM
    P0507 – 001 – Higher than expected – Intermittent
    16486 – Mass Air Flow Sensor
    P0102 – 002 – Signal too Low – Intermittent
    17796 – Control Module Malfunction – DBW Throttle Monitoring
    P1388 – 008 – Implausible Signal – Intermittent
    (this one came up twice)
    Address 03: ABS
    01314 – Engine Control Module
    013 – Check DTC Memory – Intermittent
    Address 08: Auto HVAC
    01274 – Air Flow Positioning Motor (v71)
    37-10 Faulty - Intermittent
    Address 17: Instruments Label
    01177 – Engine Control Unit
    64-10 Not Currently Testable – Intermittent
    Second time I ran VCDS
    Address 03: ABS
    What I’ve done:
    I cleared all faults, performed a throttle body adaption, and took it for a ride. Ran great for about 5 miles, then did then same thing again. It does seem to happen at any specific time at all. Doesn’t matter if the engine is hot or cold from what I can tell. Doesn’t matter if it’s under load or idling either.
    So, after speaking with Jeff at Ross Tech, he advised me to check my O2 sensors and make sure nothing was burn, frayed, melted, or in any other way damaged and they aren’t. I put her up on a lift, followed every wire and they are all in excellent shape. I check MAF connections and vacuum lines all over and everything seems to be intact and great.
    What should I do?:
    Has anybody else experienced anything like this? Can has been running literally issue free since the build and I have done nothing different. I’m stumped.
    Some specs for reference:
    UM Stage 2 software with launch control and NLS
    UM Haldex performance flash
    Full details of car can be found here: http://jasonwolske.com/portfolio/silvia/
    NC USA
    Would you please post a complete Auto-Scan ?
    It will give the full picture, and help by showing which modules and versions are in the vehicle. THanks!
    2012 A8L 4.2 Oolong/Titanium. Premium, LED, Driver assist, Rear seat comfort, Dual pane, Alcantara, Panorama
  3. Likes Uwe, jawhoa, Jack@European_Parts liked this post
    Oct 2014
    Here we go, Jake. Thanks for any help. Let me know what else is needed.
    Why screen-shots instead of text?
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    What are the fuel trims after a long drive and before clearing?
    Good Luck
    Stoke on Trent, England
    I wondered that Uwe.
    Post the full Autoscan in between CODE tags [CODE] Full AutoScan [/CODE] as it takes up less room.
    New User Keith
    Oct 2014
    Screen grabs because I'm using VCDS mobile on my iPhone and that's how I captured the Autoscan. Can someone guide me and let me know the better way to post them up? I'll gladly do it that way.
    I plan on taking the car for a cruise tonight and plan on running an Autoscan before I head out and after I return. Any particulars I should look for? How do I check the fuel trims, vwtech?
    Thanks for replying and helping out all.
  9. #8
    When the Auto-Scan completes, save the file -- it will be plain text. You can then use [View Saved Files] from the main menu. If you synch 'em to the cloud, they're accessible to from pretty much anywhere, as plain text.
    Oct 2014
    Gotcha. How do I access these saved files? I am linked to the cloud.
  11. #10
    NC USA
    Quote Originally Posted by jawhoa View Post
    Click on [View Saved Files], or login to http://VCDS-Cloud.com and view it there once it is sync'd.
    Copy and paste from either location.
  12. Likes Dana, Jack@European_Parts, Uwe liked this post
