Audi side assist canbus connection
   #61
RussJ
C?ID=288662
As suggested by Ewe, this is a spreadsheet showing all the interconnects:
https://docs.google.com/spreadsheets/d/1KC5IqYgvT6ixcaSGtT1UjHauOEXbwG04sax0uVEiw7E/edit?usp=sharing
I checked continuity from the module connectors to each wires final connection, so I'm reasonably confident that the wiring is OK.
The warning lamps are showing 12v on the permanent live but also approx. 10v on the return wire to the modules. This is what puzzles me, does the voltage leak through the LEDs?
Ooops sorry, should be Uwe
Russ
RussJ
C?ID=288662
Had to take a break from fiddling with the car as family came to stay.
Today my new (to me) modules arrived from Germany so tomorrow, weather permitting, I'll remove the rear bumper (again!),do a final wiring check and then install the new units.
Fingers crossed!
Russ
   #63
RussJ
C?ID=288662
Removed bumper, double checked wiring and all seems OK.
Replaced old modules with new.
Good news - the warning light error has gone. Suggests to me that one or other of the modules were faulty.
Bad news - I've got another fault code!
The 3C reports:
U1121 00 (009) Missing message.
Any ideas?
Russ
   #64
myounus
Northwest UK
C?ID=321059
The 3C reports:
Any ideas?
Russ
Can you post a scan please. If you've got a v2 cable then it'll be easier to work out what it means.
   #65
downtime
C?ID=280813
Missing message, not fatal. The system should work without it.
Might indicate that the gateway has too low sw index.
   #66
RussJ
C?ID=288662
Just re-ran a full scan.
"Missing message" error has gone but the original "warning lights" errors are back!
I'm really stuck now, can't now tell if the new modules are faulty or its a wiring issue.
If its wiring then I can't work out what might be wrong - there are only two wires in the circuit for each warning light.
One carries permanent 12v and the second connects the other side of the light back to a terminal on the module.
I've checked continuity from the module to the light and for any cross links to another wire in the loom but have not found anything suspicious.
The voltage on the return wires to the module is 9v for both lights and this voltage is present at the light itself even when the return wire is disconnected, so it must leak through the warning light.
I'm left with the conclusion that, improbable as it might sound, the new modules have the same issue as my old ones.
There must be an internal short or open circuit within the module.
   #67
iichel
Netherlands, eastern part
C?ID=284912
like suggested earlier, any question is much easier to answer with a fresh autoscan :thumbs:
RussJ
C?ID=288662
Raining last night so have scanned this morning.
Please ignore hatch faults - lots of connectors undone.
I'm gong to try and by-pass the loom and connect a warning light directly to the module. This should show if there is a loom issue (damaged wire/ short etc).
Friday,07,September,2018,10:31:39:63302
VCDS Version: 18.2.1.5 (x64)
VIN: WAUZZZ8R8FA079650   License Plate: CJ55RDJ
Mileage: 34470km-21418mi   Repair Order: New modules 2
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
          56 5C 5F 62 6C 6D 72 A9 C0
VIN: WAUZZZ8R8FA079650   Mileage: 34470km-21418miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0004
   Revision: 57H25---
   Coding: 2A2A4032256603020000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589 001007
   ROD: EV_ECM30BTD0118K5907589.rod
   VCID: 7EF275E8E10033B456-802A
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1007
   Revision: --H19---
   Coding: 000001
   VCID: 000E0B109BF4454424-8054
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
   Component: ESP8 quattro  H09 0020
   Coding: 245DCC01
   Shop #: WSC 06335 000 00000
   VCID: 0E122528D9A02334A6-805A
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05B54040000000000000
   VCID: 000E0B1093F4454424-8054
   Serial number: 3214000163027010
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01211120141279
   Coding: 3625028000
   VCID: 78FE63F0CB240D841C-802C
   Revision: 08016001    Serial number: 00000951648401
   Coding: 260000108074AFE00581404300001D0D0F9D470827090201000008004400030100000034000000
   Shop #: WSC 50664 002 104857
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140825  H12 0050
   Serial number: 90243015140820021300
   Coding: 01DD13
   Serial number: 23488562
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001511146557
   Serial number: 37488D57000000000001
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 007D8A
   VCID: 377CA0CC86BAC2FCD5-8062
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC21U3M
   Coding: 30473431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 489ED330F344BD04AC-801C
   Serial number: 6334MSME4A6B2B05M
   Serial number: 6344MSME4A596417K
   Serial number: 6352QSME5C484164L
   Serial number: 6362QSME5C4B216CV
   Serial number: 63732SME3449245C%
   Serial number: 63832SME714B487A9
   Revision: --------    Serial number: 90372NKI000FS
   Coding: 0000FF
   VCID: 4486C700C76C996440-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 951     HW: 8R0 920 951
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 03I32JJCF
   Coding: 33E7220047012600010000
   VCID: 74E657C0D74C69E430-8020
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z14B190417
   Coding: 80CD07FF00
   VCID: 4C96EF20EF3C512488-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 4899974903
   Serial number: 14311000484011200410
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: 7CF67FE0FF1C21A478-8028
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000124832453
   Coding: 01781B00000000000000
   VCID: 428AC118DD78975472-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0330262003
   Coding: 010312
   Shop #: WSC 06334 123 12345
   VCID: 3F8CC8ECA68AFABC1D-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0330949180
   Coding: 010312
730378 - Warning Lamp for Lane Change Assistance in Driver-Side Ext. Mirror
          C1116 15 [009] - Open or Short to Plus
                    Reset counter: 188
                    Mileage: 34475 km
                    Date: 2018.08.24
                    Time: 18:14:45
730634 - Warning Lamp for Lane Change Assistance in Passenger-Side Ext. Mirror
          C1117 15 [009] - Open or Short to Plus
                    Reset counter: 188
                    Mileage: 34475 km
                    Date: 2018.08.24
                    Time: 18:14:45
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000126845640
   Coding: 011D12215E01440004
   VCID: 4FACF82C1E2A6A3CED-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0009187955
   Coding: 100001010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   Revision: 00002001    Serial number: 0352486413
   Coding: 013B0E22A0B930958720053680040047
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 188
                    Mileage: 34475 km
                    Date: 2018.08.24
                    Time: 18:13:55
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 188
                    Mileage: 34475 km
                    Date: 2018.08.24
                    Time: 18:13:55
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 188
                    Mileage: 34475 km
                    Date: 2018.08.24
                    Time: 18:13:59
01134 - Alarm Horn (H12)
                    Reset counter: 188
                    Mileage: 34475 km
                    Date: 2018.08.24
                    Time: 18:13:59
   Revision: 00005001    Serial number: 94813037454706
   VCID: 2D5082A474E6782CBF-8078
   Revision:             Serial number: 0000126704127
   VCID: 4E92E52819206334E6-801A
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000545768
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7AB9F8BDA8DF942A-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109K60E7992209
   Coding: 010103010000000001
   VCID: 2B548CBC4AF2761CA1-807E
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600214B2000165
   Coding: 0002204
   VCID: 377CA0CC46BAC2FCD5-8062
   Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 0897
   Revision: --------    Serial number: 515K10E7503269
   Coding: 1A0101060205A9EF7D80CB5E00000403E40000020000000000
   Shop #: WSC 50664 002 1048576
   VCID: 3E72B5E8A980F3B416-806A
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130KZ0E3196812
   Serial number: 00000002055351
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000126688328
   Coding: 010C12204001240004
   VCID: 4682DD08F150AB745E-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J49A6JS
   Coding: 1020010
   VCID: 346697C057CC29E4F0-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D70B2E4A486E8AC0F-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000126699217
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 141021202723
   VCID: 79F866F4F82E148C63-802C
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 141021200750
   VCID: 71E85ED4A05E5CCCDB-8024
End-------------------------(Elapsed Time: 04:27)-------------------
   #69
DarkyUK
C?ID=61560
On my A5 these connect directly to the Door Controller via a short wire, I can't imagine it being loom damage in that case in both at the same time. Are they connected correctly (polarity)?
   #70
RussJ
C?ID=288662
On the Q5 retrofit they connect to battery 12v and back to the rear slave module. The only connection within the door is an earth(which I've checked).
The lights, being LEDs, are polarity sensitive and wont work the wrong way round. I think the module drops the return line to earth in order to flash the lights. Certainly touching a grounded wire to the return causes the lights to switch on.
   #71
RussJ
C?ID=288662
Just completed the loom by-pass test.
Same warning light error message on both sides.
I guess that confirms that it is the module(s).
The correct part numbers for my car are 8T0 907 566b/568b but they seem to be in short supply.
Can I use modules with similar numbers like 8U0 907 566 (i think from a Q3) or any other 8*0 907 566, either as they come or after re-programming if possible?
   #72
andyhud
C?ID=32695
You sure it isnt 566 and 590 part number wise?
   #73
RussJ
C?ID=288662
8T0 907 566/568 are the correct numbers according to my online catalogue and Norwich Audi.
8T0 907 590 isn't recognised as a valid part number.
   #74
andyhud
C?ID=32695
Fair do's .. was a long shot. 566 and 590 are on the MLBEvo platform like Q7 4M etc.
   #75
downtime
C?ID=280813
Can you try one thing to trick the modules, what if you add some more load to the led modules by using a resistor in parallel?
   #76
MasterTommy
Amsterdam
C?ID=295586
Dont these modules need parameterization?
   #77
downtime
C?ID=280813
If they are used modules they are parameterized already.
   #78
RussJ
C?ID=288662
Sorry its been so long since I updated this thread but I've been away on holiday and frankly needed a break from Audi electrics!
When I got back I once again went through the wiring to check for errors but couldn't find anything wrong.
I decided it was time to admit defeat and take the car to an Audi retrofit expert and see if they could spot where i was going wrong.
Today I drove down to HazzyDayz near St Albans and sure enough they identified my error.
Its a little difficult to explain but here goes:
According to the wiring diagram, there are both switched and permanent supplies to the modules. I took supply from two spare fuse positions in the dashboard fuse box, one switched and one permanent
I had always wondered why the modules needed both switched and permanent but assumed the wiring diagram was correct.
In fact the "permanent" supply originates from the modules and not as a separate supply from the fuse box. This wasn't how I interpreted the diagram as it refers to B310 as a "30" connection within the wiring harness which I thought was a permanent 12v and hence hooked it up to the fuse box. And because I connected the warning lights directly to a 12v source, the module generated the "short to positive" error.
Cutting the supply to the warning lights got everything working as it should with no error messages.
Tomorrow I'll go out for a drive and see if I'm going to need re-calibration of the radar modules but since they came off a 2015 SQ5 like mine I'm hoping they'll work straight out of the box.
Thanks everyone for sticking with me on this long saga and for your help and interest, it was much appreciated.
Russ
   #79
downtime
C?ID=280813
Good that the problem was found and resolved.
It's not admitting defeat what you showed, it's showing strength when you're able to admit that you cannot fix this. And sometimes it's a good thing to have a second pair of eyes take a look on what you've done. You easily get "blind" for your own work and overlook something :)
