Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 79
Thread: Audi side assist canbus connection
    Nov 2016
    I've spent the last two days checking and rechecking the loom connections. As you guys suggested, there were some errors so I've re-wired to match the diagrams in ESRA.
    I'm pretty sure that its all correct now.
    However, the 3C module still fails to respond to VCDS.
    I'm coming round to the idea that one or both of the controllers are faulty. They were an eBay purchase and although the seller assured me that they worked fine I have my doubts...
    Is there any way of testing these units, either on or off the car? I'd be happy to take them to a specialist if certain test rigs were required.
  2. #12
    Nov 2016
    One other thing I've noticed is that the small indicator LED in the on/off switch does not come on when I press it. Not sure if that will only work once the modules are coded.
  3. #13
    Dec 2016
    Amsterdam
    Quote Originally Posted by RussJ View Post
    You can test the master module by wiring up power ground and can-high/low directly to the pins on the VCDS cable and on the module. You’ll need to provide an external 12v power source to it as well. Then you should be able to get a reading when manually selecting the module in the control unit screen. You do not get to try different pins on this, if you put 12V on the wrong ping or hook up a can wire to a pin with 12v on it, you can usually throw away the module, the VCDS interface or both. So if you really found more than one error in you wiring like you said I do not reccomend you doing this.
    Current:
  4. #14
    Oct 2017
    Northwest UK
    Can you please deleted all faults and re-scan the car and post the autoscan.
  5. #15
    Nov 2016
    I've run a full scan and deleted DTCs but some of them were persistent.
    I then re-ran a scan and this is shown below.
    When I looked at the installation list on 19 and clicked on 3c, there was a message saying that the module was uninitiated and offering 3 options - use default code, use existing code and manually code.
    I chose "default"
    I hope this helps...
    ednesday,25,July,2018,17:36:05:63302
    VCDS Version: 18.2.1.5 (x64)
    VIN: WAUZZZ8R8FA079650   License Plate: CJ55RDJ
    Mileage: 34030km-21145mi   Repair Order:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
              56 5C 5F 62 6C 6D 72 A9 C0
    VIN: WAUZZZ8R8FA079650   Mileage: 34030km-21145miles
    3C-Lane Change -- Status: Cannot be reached 1100
    5C-Lane Maintain. -- Status: OK 0000
    Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 589     HW: 4G0 907 589
       Component: 3.0BTD EDC17  H25 0004
       Revision: 57H25---
       Coding: 2A2A4032256603020000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30BTD0118K5907589 001007
       ROD: EV_ECM30BTD0118K5907589.rod
       VCID: 7EF275E8E10033B456-802A
       Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H19 1007
       Revision: --H19---
       Coding: 000001
       VCID: 000E0B109BF4454424-8054
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
       Component: ESP8 quattro  H09 0020
       Coding: 245DCC01
       Shop #: WSC 06335 000 00000
       VCID: 0E122528D9A02334A6-805A
       Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
       Component: BCM2 2.0      H15 0711
       Coding: 05B54040000000000000
       VCID: 000E0B1093F4454424-8054
       Serial number: 3214000163027010
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Revision: D1000000    Serial number: 01211120141279
       Coding: 3625028000
       VCID: 78FE63F0CB240D841C-802C
       Revision: 08016001    Serial number: 00000951648401
       Coding: 260000108074AFE00581404300001D0D0F9D470827090201000008004400030100000034000000
       Shop #: WSC 50664 002 104857
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 140825  H12 0050
       Serial number: 90243015140820021300
       Coding: 01DD13
       Serial number: 23488562
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001511146557
       Serial number: 37488D57000000000001
    Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
       Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
       Component: ACC3          H11 0100
       Coding: 007D8A
       VCID: 377CA0CC86BAC2FCD5-8062
    Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003JPDC21U3M
       Coding: 30473431313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 489ED330F344BD04AC-801C
       Serial number: 6334MSME4A6B2B05M
       Serial number: 6344MSME4A596417K
       Serial number: 6352QSME5C484164L
       Serial number: 6362QSME5C4B216CV
       Serial number: 63732SME3449245C%
       Serial number: 63832SME714B487A9
    9445397 - Key switch for deactivation of passenger-side airbag
              B1020 15 [137] - Open or Short to Plus
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:49
    9446677 - Redundant signal path for airbag shut-off; passenger side
              B1025 15 [137] - Open or Short to Plus
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:49
       Revision: --------    Serial number: 90372NKI000FS
       Coding: 0000FF
       VCID: 4486C700C76C996440-8010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 951     HW: 8R0 920 951
       Component: KOMBIINSTR.   H35 0567
       Revision: 00100000    Serial number: 03I32JJCF
       Coding: 33E7220047012600010000
       VCID: 74E657C0D74C69E430-8020
       Component: GW-BEM 5CAN-M H11 0060
       Revision: 1Z120030    Serial number: 3041Z14B190417
       Coding: 80CD07FF00
       VCID: 4C96EF20EF3C512488-8018
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 4899974903
       Serial number: 14311000484011200410
    02849 - Control Module for Lane Change Assistance (J769)
                        Reset counter: 168
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:48
                        Bin. Bits:    10111
                        Voltage: 12.50 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Revision: AA001002
       Coding: 02022064747464545425363E00
       VCID: 7CF67FE0FF1C21A478-8028
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0077
       Revision: AA000000    Serial number: 00000124832453
       Coding: 01781B00000000000000
       VCID: 428AC118DD78975472-8016
    Address 3C: Lane Change
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000126845640
       Coding: 011D12215E01440004
       VCID: 4FACF82C1E2A6A3CED-801A
       Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
       Component: RCEPS         H41 0509
       Revision: 00001000    Serial number: 0009187955
       Coding: 100001010001
       ASAM Dataset: EV_RCEPSAU48X 008016
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3F8CC8ECA68AFABC1D-806A
                        Reset counter: 168
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:48
                        valid
       Revision: 00002001    Serial number: 0352486413
       Coding: 013B0E22A0B930958720053680040047
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
    02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 168
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:47
    02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                        Reset counter: 168
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:47
       Revision: 00005001    Serial number: 94813037454706
       VCID: 2D5082A474E6782CBF-8078
       Revision:             Serial number: 0000126704127
       VCID: 4E92E52819206334E6-801A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 20000000545768
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A7AB9F8BDA8DF942A-806E
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109K60E7992209
       Coding: 010103010000000001
       VCID: 2B548CBC4AF2761CA1-807E
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
       Component: J759 HC             0040
       Revision: 00H08006    Serial number: 600214B2000165
       Coding: 0002204
       VCID: 377CA0CC46BAC2FCD5-8062
       Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
       Component: H-BN-EU       H48 0897
       Revision: --------    Serial number: 515K10E7503269
       Coding: 1A0101060205A9EF7D80CB5E00000403E40000020000000000
       Shop #: WSC 50664 002 1048576
       VCID: 3E72B5E8A980F3B416-806A
       Subsystem 1 - Part No: 8R0 060 884 CH
       Component: EUR 2014  2004
       Component: DU7 High  H42 0104
       Serial number: A130KZ0E3196812
       Serial number: 00000002055351
       Component: CD-Database  5950
                        Reset counter: 168
                        Mileage: 34036 km
                        Date: 2018.07.24
                        Time: 07:18:53
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000100 00000000
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000126688328
       Coding: 010C12204001240004
       VCID: 4682DD08F150AB745E-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H09---    Serial number: 525PA8-J49A6JS
       Coding: 1020010
       VCID: 346697C057CC29E4F0-8060
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H56 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D70B2E4A486E8AC0F-8068
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H56 0330
       Serial number: 8R0827852D
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000126699217
       Part No SW: 8R0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0007
       Serial number: 141021202723
       VCID: 79F866F4F82E148C63-802C
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 8R0 907 160     HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0002
       Serial number: 141021200750
       VCID: 71E85ED4A05E5CCCDB-8024
    End-------------------------(Elapsed Time: 04:29)--------------------------
    Address 19,8R0 907 468 P,recoded (Installation List),from,FFF1742C0782850C,to,FFF1742C0782850C,,
  6. #16
    Oct 2017
    Northwest UK
    Hi Russ
    Try manually coding the module. If it asks for a wsc then try 12345
  7. Likes RussJ liked this post
  8. #17
    Nov 2016
    I spent yet another couple of days checking the wiring and re-trying VCDS but still no luck.
    I had convinced myself that one or both of the modules were faulty and last night was scouring eBay for some replacements when I noticed that someone was advertising a unit describing it as a “master” when the part number corresponded to a ”slave” – or did it?
    A search of online part catalogues revealed that it was indeed a master as advertised, which puzzled me, as on my car the same module was wired up as a slave.
    Then I realised what had happened.
    The position of the modules is fixed as they are “handed” and therefore can’t be attached to the bumper incorrectly
    The written instructions I had showed the side assist bumper loom entering the car through a grommet on the drivers side, so I had followed that and fitted the loom to match, ie the connector with the short wires went to the drivers side and the extended wires ran across the bumper to connect up on the passengers side.
    However, my Alibaba loom was wired the other way round, presumably LHD as opposed to RHD, and the short wires that should have connected to the master were actually connecting to the slave.
    A quick swop of the modules proved I was right, VCDS connection was established and coding done.
    This morning I reversed the bumper loom and brought it into the car via a grommet on the passengers side. Fortunately there was enough slack in the rest of the loom to avoid any need to extend it.
    Irritatingly, after weeks of unbroken sunshine, its raining now so I can’t finish off the job!
    So, many thanks to those who’ve tried to help and a slightly embarrassed apology for wasting your time.
    Russ
  9. Likes Dana, jyoung8607 liked this post
  10. #18
    Oct 2017
    Northwest UK
    Hi Russ
    You need to be careful not to bring the loom through the side with the exhaust on. When I retrofitted side assist / blind spot assist on a Golf Mk7 I removed the fitted grommet (under the car) for the park pilot wires and used a wider grommet so as to follow a standard pathway.
  11. #19
    Nov 2016
    I have an SQ5 so its got exhausts on both sides!
    I was careful to zip-tie the loom so it couldn't touch anything hot.
    I'm getting an error code on 3C which is telling me that both wing mirror side assist warning lights are either open circuit of shorted to positive.
    I'm not sure what this means as according to ElsaWin, one side on the light is connected to a "30" source, which I assume means permanent 12v, and the other connects to the slave module.
    When a vehicle is detected the slave drops the connection to earth which then flashes the warning light. I can do this manually by earthing the module wire.
    Any idea what the problem is?
    Russ
  12. #20
    Oct 2017
    Northwest UK
    Russ
    The problem sounds like the wires are plugged the wrong way around in the mirror. Turn them around and see if the error goes away.
