Results 1 to 8 of 8
Thread: Hi can someone offer some advise with a ABS issue *Warning not for the faint hearted*
    Jul 2018
    Hi everyone apologies in advance for the long post but I want to make sure I cover everything.
    I have a 2004 A3 a few years ago I added park assist (self park not just sensors) and as part of the retrofit I had to change the MK60 ABS unit with the later MK60CE1 unit.
    I checked the cfd for both units and rewired no problem. All was good took a while to code but after doing some research online I was able to build the coding and it was accepted. Itís been this way for about 4 years with no issues.
    The other day I decided to finally bite the bullet and install the 2011 bi-xenon cornering lights, as the wire for the tpms switch again no dramas.
    I coded the lights up ok, I followed a helpful guide on Audi-sport.net for the tpms and coded the dash, gateway and attempted to code the abs. The code was accepted but nothing worked (tpms wise)
    Iíve tried to put everything back to as it was previously but canít code the ABS now, or clear the fault memory. It comes back with ďthe request to clear the codes was not acknowledged by the control moduleĒ or words to that effect.
    i'm trying to attach a log as we speak. I'm planing to address the door issue and the replace the ac unit with the original one at the weekend.
    Tuesday,17,July,2018,15:53:00:40864
    VCDS Version: 18.2.1.2
    VIN: WAUZZZ8P44A135496   License Plate: N17WOL
    Mileage: 165110km-102594mi   Repair Order: after abs coding attempt
    Chassis Type: 8P (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 52 55 56 77
              7D
    VIN: WAUZZZ8P44A135496   Mileage: 165110km-102594miles
    08-Auto HVAC -- Status: Malfunction 1010
    10-Park/Steer Assist -- Status: Not registered 0001
    42-Door Elect, Driver -- Status: Malfunction 1010
    55-Headlight Range -- Status: Not registered 0001
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 016 J    HW: 028 101 138 3
       Component: R4 1,9L EDC G000SG  5497
       Revision: 12345678    Serial number: AUX7Z0D1FN90B9
       Coding: 0000071
       Shop #: WSC 00066 001 57865
       VCID: 2A5BEDDC8560891459-807E
    18043 - Powertrain Data Bus
                P1635 - 000 - Missing Message from A/C Controller - Intermittent
                        Torque: 0.0 Nm
                        Voltage: 12.01 V
                        Bin. Bits: 00101100
                        Bin. Bits: 00000000
                        (no units): 144.0
    Readiness: 0 0 1 1 1
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 13424012092500FFC80F02ED901F0080300450
       VCID: 76E309ACC1589DF40D-8022
                        Fault Status: 00101101
                        Fault Frequency: 17
                        Reset counter: 159
                        Mileage: 163575 km
                        Date: 2018.06.27
                        Time: 19:11:04
                        Count: 6
                        Count: 12800
                        Count: 8193
                        Count: 46592
                        Count: 65280
                        Count: 65279
                        Fault Frequency: 39
                        Reset counter: 170
                        Mileage: 163732 km
                        Date: 2018.07.04
                        Time: 00:33:39
                        Count: 16391
                        Count: 32768
                        Count: 12800
                        Count: 148
                        Count: 51970
                        Count: 775
                        Count: 65280
       VCID: 55A16E20BC9EF6EC24-FFFE
    No Faults Found
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000008302176
       Coding: F78A1B06A0141000800000000000000000096E065C060206000000000000
       VCID: 4581BE600C3E466C54-8010
       Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H12 0050
       Coding: 00056624
       Shop #: WSC 12345
       Component: REGENLICHTSENSORH12 0090
       Coding: 00216109
       Shop #: WSC 12345
                        Fault Frequency: 9
                        Reset counter: 8
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:41:00
                        Voltage: 11.90 V
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 H    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0110
       Revision: --------    Serial number: 88591024652506
       Coding: 10100A
       VCID: 408FAF74D31C634467-8014
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
       Component: Airbag 8.4ED    H00 0140
       Coding: 0011602
       Shop #: WSC 06435 000 00000
       VCID: 4385A078020A785C7A-8016
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0004042
       Shop #: WSC 06314 000 00000
       VCID: 4683B96C31384D745D-8012
       Component: E0221           H06 0080
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
       Component: KOMBIINSTR. VDO H19 0860
       Revision: D0H19007    Serial number: 224DH007011803
       Coding: 0128460
       Shop #: WSC 59227 001 104857
       VCID: 3979C29070C6328C20-806C
       Revision:   H42       Serial number: 210412F2002529
       Coding: 350101
       VCID: 3A7BDD9CB5C0399429-806E
                        Reset counter: 223
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:45:20
                        Fault Frequency: 10
                        Reset counter: 7
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:42:24
                        Fault Frequency: 17
                        Reset counter: 7
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:42:27
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:42:24
       Revision: D0H19007    Serial number: AUX7Z0D1FN90B9
       Shop #: WSC 00115 210 106676
    16346 - Control Module - ROM Error
                014 - Defective
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8P0 035 785     HW: 8P0 035 785
       Component: SG ext.Player H08 0100
       Revision: 00000000
       Coding: 020202
       VCID: 74E733A4D7248FE433-8020
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
       Component: RNS-E PU EU     H06 0220
       Revision: 0000012S    Serial number: AUZBZ7LD218569
       Coding: 0229725
       Shop #: WSC 00113 210 105947
       VCID: 3467F3A457A4CFE4F3-8060
                        Reset counter: 223
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:43:36
                        Mileage: 165110 km
                        Count: 1707
                        Clock: 15:43
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 70     2901
       Revision: 00H17000
       Shop #: WSC 00028 028 00001
       VCID: 2F6DFCC8BE82EC3C8E-807A
       Part No: 8P0 959 433
       Component:    KSG          H02 0040
       Coding: 008800186828850548DBC60000
       VCID: 79F902903046F28C60-802C
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Component: Tuer-SG         H04 0101
       Coding: 0000892
       Shop #: WSC 01236 785 00200
       VCID: 4A9B8D5C2520A914B9-801E
    00106 - Signal Central Locking SAVE/LOCK Passenger Side
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000028
       Shop #: WSC 31414 790 00001
       VCID: 2B55E8D88A9A901CA2-807E
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Modul links H03 0004
       Subsystem 2 - Part No: 7L6 941 329 B
       Component: AFS-Modul rechtsH03 0004
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0229725
                        Reset counter: 223
                        Mileage: 165113 km
                        Date: 2018.07.17
                        Time: 15:43:36
                        Mileage: 165110 km
                        Count: 1707
                        Clock: 15:43
       Part No SW: 8P0 862 335 M    HW: 8P0 862 335 M
       Component: FSE_255x BT     H21 0200
       Revision: 00000001    Serial number: 00000000418580
       Coding: 0010222
       Shop #: WSC 01211 210 00000
       VCID: 408FAF74131C634467-8014
       Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
       Revision: 00700000    Serial number:
       VCID: 2C57EBC48F949724AB-8078
    End-------------------------(Elapsed Time: 02:39)--------------------------
    Last edited by Neilios; 07-19-2018 at 05:37 PM. Reason: adding code window for log
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #2
    Nov 2014
    New Zealand
    Quote Originally Posted by Neilios View Post
    No need to apologise for lots of info. Nice first post!
    I can't help you, I don't know whats going on there - but good work with the retrofits!!!
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #3
    Jul 2018
    Thanks Allen i'm hoping to finally be done with pulling the thing apart, though i said that years ago haha. Should have learned after fitting self park to a dinosaur haha.
  6. Likes NZDubNurd liked this post
  7. #4
    Fix brake light switch and overlay twisted pair or verify gateway on the CANBUS for COM issue with 0x01
    Upgrade gateway?
  8. #5
    Jul 2018
    Hi Jack thanks for the reply. Iíve already put a new brake light switch in and read out the values to check Itís working etc, the gateway was upgraded a few years ago so I could fit the Park aid and assist though it has been swapped out with no change. What I canít understand is itís been fine for years but now itís decided to misbehave. Iíll have more time on Sunday to look at it properly. I think Iíll code out and remove the fuse for the new AFS control unit just so is exactly the same as before I started all this.
  9. #6
    Hi Jack thanks for the reply. I’ve already put a new brake light switch in and read out the values to check It’s working etc, the gateway was upgraded a few years ago so I could fit the Park aid and assist though it has been swapped out with no change. What I can’t understand is it’s been fine for years but now it’s decided to misbehave. I’ll have more time on Sunday to look at it properly. I think I’ll code out and remove the fuse for the new AFS control unit just so is exactly the same as before I started all this.
    Bad wire or bad new shit switch......water ingress?
    Hence Sporadic!~
    2 Faults Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Freeze Frame: Fault Status: 00101101 Fault Priority: 2 Fault Frequency: 17 Reset counter: 159 Mileage: 163575 km Time Indication: 0 Date: 2018.06.27 Time: 19:11:04 Freeze Frame: Count: 0 Count: 6 Count: 12800 Count: 8193 Count: 46592 Count: 65280 Count: 65279 Count: 0 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 39 Reset counter: 170 Mileage: 163732 km Time Indication: 0 Date: 2018.07.04 Time: 00:33:39 Freeze Frame: Count: 16391 Count: 32768 Count: 12800 Count: 148 Count: 51970 Count: 775 Count: 65280 Count: 0
  10. #7
    Jul 2018
    I think itís more of a case of I canít clear the code. The switch works fine now as all the values check out now where they didnít before and the cruise control works again (it failed when the switch first packed up) personally I think itís more of a coding issue thatís locked the unit up. I just need to try and find the time to sit down and build the coding up from scratch again just to be 100% itís just having the time haha. To be honest itís been years since I did it and I need to track down my notes. I do have a donner ABS unit if all goes to pot. Iíd rather not have to rip it out though.
  11. #8
    Jul 2018
    Hey sorry I thought Iíd updated this thread. Well after going through each and every bit of coding to check I did indeed have the correct one and no joy I fitted the new abs unit and yet again no joy. Then I threw away all the notes etc and started from scratch, found no ignition live. Now I thought Iíd checked this but am big enough to admit when Iím wrong and not to mention completely stupid for not checking the very first things haha.
  12. Likes Uwe, NZDubNurd, Jack@European_Parts liked this post
