No controller response - Engine Module - 01
i3oricua
C?ID=323497
I've tried to use my cable to read the engine module - 01 so I can log requested vs actual boost but I can't get the controller to respond. I do have a genuine cable purchased through the site. HEX-V2, H11-001984 and am using the most up to date version of VCDS. I even uninstalled and reinstalled VCDS. I am running it on Windows 7 on my Mac through Bootcamp. Has anyone else experienced any problems with this?
Santos
What kind of car are you plugged into?
Can you click [options] then [test] in VCDS and post the results?
It could not hurt to post an Auto-Scan from the car in question. Even if you can't connect to the ECU, there may be clues why in other modules.
i3oricua
C?ID=323497
Thanks for the quick response. I can cannot to some of the other modules but it's hit or miss.
Here's the requested pic.
i3oricua
C?ID=323497
Oh sorry, I forgot to add. The car is a 2006 Audi A4 FWD, 2.0T
i3oricua
C?ID=323497
Thursday,19,July,2018,16:58:27:14030
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUAF78E36A206747   License Plate: EY55AEX
Mileage: 212620km-132115mi   Repair Order:
          67 69 75 76 77
VIN: WAUAF78E36A206747   Mileage: 212620km-132115miles
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H06 0120
   Coding: 0004524
   Shop #: WSC 06335 000 00000
   VCID: 280905ABCEF077A7194-807C
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6D8734BF2482928FAA2-5160
            07-00 - Signal too Low
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0704
   Coding: 01001
   Shop #: WSC 65536
   VCID: 3B23CAE72A76CC3F646-4B00
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N001DBGU
   Coding: 0032607
   Shop #: WSC 34959 183 85138
   VCID: 3C21C9FB2A68CB076DC-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 35YLJ
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB402CC8E930ÿ†63
   Subsystem 5 - Serial number: C8E930ÿ†6342DRB402D5C49C+ÿ†63
   Subsystem 6 - Serial number: 5C49C+ÿ†6352ARB400E77305Iÿ†63
   Subsystem 7 - Serial number: 77305Iÿ†6362ARB400E77073Lÿ†63
   Subsystem 8 - Serial number: 77073Lÿ†63729RB400EE104BRÿ†63
   Subsystem 9 - Serial number: E104BRÿ†63829RB400EE4741Sÿ
   Subsystem 10 - Serial number: E4741Sÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 02021
   Shop #: WSC 06335
   VCID: 41DFB80F489AA6EF3EA-4B00
01304 - Radio
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0022400
   VCID: 2E05F3B3EC042997D38-5184
            010 - Open or Short to Plus
01302 - Control Module for Telematic (J499)
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0022400
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4035
   Coding: 11896
   Shop #: WSC 06335
   VCID: 78A915EB5BC02727494-4B00
   Component: Tõrsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0506
   Component: Tõrsteuer.HL BRM 0606
   Component: Tõrsteuer.HR BRM 0606
            35-00 -  -
            35-00 -  -
00955 - Key 1
            35-10 -  -  - Intermittent
End----------(Elapsed Time: 05:58, VBatt start/end: 12.3V/12.3V)-----------
What happens if you try generic OBD-II?
Is this car an manual trans? Has the ECU been "tuned" or otherwise modded?
i3oricua
C?ID=323497
The car is tuned. I’m stage 3 with a big turbo and a custom tune.
I don’t know what you mean by using generic OBD-II.
On the first screen in VCDS, toward the lower left, there's a button labelled [OBD-II].
i3oricua
C?ID=323497
I haven’t tried that yet. I will in the morning and post results. Thanks!
i3oricua
C?ID=323497
For whatever reason unknown to me I was able to get into that controller this morning. Do you want a log of anything for future troubleshooting?
Edgar
i3oricua
C?ID=323497
Well, nevermind. Did it again. I was able to log my boost this morning but changed a spring on my diverter valve and went to do it again and the same controller error came up. I'm contemplating just getting a Windows based laptop. Cheap and easy one.
What Mac are you using? I had a Macbook Air for a while (bought as a travel laptop before anyone else had anything even remotely comparable) that had Windows 7 on it via Bootcamp and I never had any problems running VCDS on it.
I really wonder if this isn't an issue with your car rather than your computer.
i3oricua
C?ID=323497
It very likely is but I don’t know what could be causing the problem. I’ve cleared any faults it may have had.
Also, I can access the OBD function that you asked about.
I’m fairly certain the tuner didn’t lock out the ECU but I guess I could be wrong. Very mind boggling to me.
i3oricua
C?ID=323497
Sorry. It is a MacBook Pro. Not the newest version though.
i3oricua
C?ID=323497
Ok. So I think I've figured out a way to get working every time. I have to go into the OBD II function and clear all DTCs. Close VCDS. Then cycle the power to the car (ign off/on) and open VCDS and go straight to the controller (Engine - 01). Although this works it doesn't explain why I have to clear the codes every time.
Edgar
I can't explain it either, although it points to your ECU rather than your computer.
If I were to speculate, my money would be on the tune in the ECU being wonky.
i3oricua
C?ID=323497
Updating this thread. VFIZ was causing some communication issue of some sort. I simply reset VFIZ in the settings and now I can access my ECU controllers just fine. Thanks!
So a FOD problem. :D
