A7 2011. quattro fuel tank calibration
ikara
Croatia
C?ID=302492
Hi,instrument cluster has DTC something about Basic setting,fuel gauge not show correctly,any procedure for this,best regards
ikara
Croatia
C?ID=302492
how attach txt.?
You don't attach. You paste in-line, as described in the link in my previous post.
ikara
Croatia
C?ID=302492
Thursday,19,July,2018,17:21:57:04922
VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
VIN: WAUZZZ4G3BN030010   License Plate:
Mileage: 117512km-73018mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 42 44 46 52 53
          55 56 5F 62 6D 72 8F 90
VIN: WAUZZZ4G3BN030010   Mileage: 117512km-73018miles
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---
   Coding: 1A254012042601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001003
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: A600A849D9F4B774FD-80F2
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [032] - -
          [Data bus on board diagnostic interface -J533please read DTC]
                    Mileage: 117511 km
                    Date: 2018.06.14
                    Time: 04:00:31
                    Engine speed: 821.50 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 60 °C
                    Intake air temperature: 42 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 11.800 V
                    ACC target acceleration: 0.000 m/s˛
                    ACC control module received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s˛
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
4527 - Coolant Fan Control Circuit 1
          P0480 00 [032] - Electrical Malfunction
                    Mileage: 117511 km
                    Date: 2018.06.14
                    Time: 03:52:35
                    Coolant temperature: 63 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 11.860 V
                    Air mass: specified value: 340.0 mg/stroke
                    Coolant temperature at radiator outlet: actual value: 45.6 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 38.0 °C
                    Coolant fan 2: activation: 0.00 %
                    Coolant fan 1: activation: 10.00 %
                    Fuel temperature: 35.8 °C
5585 - Diesel Particulate Filter (Bank 1)
          P242F 00 [109] - Restricted/Clogged
                    Mileage: 117511 km
                    Date: 2018.06.14
                    Time: 04:00:26
                    Engine speed: 838.50 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 62 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 11.720 V
                    Crankshaft speed (RPM): 838.5 /min
                    Vehicle speed: 0.00 km/h
                    Exhaust gas jet volume in particle filter: 68.8 mł/h
                    Particul.filter diff.pressure: 5 hPa
                    Particle filter: oil ash volume: 0.41 l
                    Exh t Adap T Oxi Cat Ds: 74.0 °C
                    P Flt Ld fac Ash Cor: 0.6221
14615 - Control Module for Glow Plugs
          P052F 00 [036] - Implausible Voltage
                    Mileage: 117511 km
                    Date: 2018.06.14
                    Time: 03:52:35
                    Glow-control unit: activation voltage: 0 mV
                    Glow_period_control_unit_ground_offset_voltage: 0 mV
                    Glow-control unit: calculated glow voltage: 0 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 0.0 V˛s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 9
                    Glow status-Bits 0-7: 0
                    Co EOM st Op Mode Short-Bits 0-7: 8
   Part No SW: 4G0 927 156 K    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0012
   Revision: --H10---    Serial number: 0000001481
   Coding: 000001
   ROD: EV_TCMDL501.rod
   VCID: B42442011F28D5E473-80E0
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 27A68702E465E140CB00
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: EE9090693184BF3445-80BA
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 01AA3000000000000000
   VCID: F7BEB50D46DEFEFC96-80A2
   Serial number: 2311000088170010
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 02051100040146
   Coding: 3603007800
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: A71EA54DDEFEAE7CC6-80F2
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000001043342
   Coding: 0D07201009769FE081810083A0001800CF9CC3082E090101000308452F00
   VCID: AC145A61CF188D242B-80F8
   Component: WWS57X 110416  H35 0051
   Serial number:         110420112929
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11409099
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000396
   Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0001
   Serial number: 00000000001104041590
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0001
   Serial number: 00000000001012010611
   Serial number: 190801A5000000000001
   Subsystem 7 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0001
   Serial number: 00000000001104042281
   Subsystem 8 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0001
   Serial number: 00000000001104041715
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901109501527
   Coding: 100303
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: B73E750D0E5E3EFC56-80E2
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG0029U6%
   Coding: 30314530323130303031554A304C34473853
   VCID: B62078090954C7F44D-80E2
   Serial number: 3575HRB405B0HJHG6PE.
   Serial number: 3585HRB40590HJHG98V$
   Serial number: 3515JRB40550HBR0G94/
   Serial number: 3525JRB404P0FJPKDGA8
   Serial number: 3554VRB40590FAME2HBN
   Serial number: 3564VRB40590FAMEB1KQ
   Revision: 00000000    Serial number: 20110429000566
   Coding: 000034
   VCID: B02C4E11E330E9C417-80E4
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 930 P    HW: 4G8 920 930 P
   Component: TDieRdw       H34 0312
   Revision: 19100074    Serial number: 658180411593027
   Coding: 03A701020B030008040100
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   VCID: BA386C393D4C2394A9-80EE
1048578 - No Basic Setting
          B2010 00 [009] -  -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 78
                    Mileage: 117508 km
                    Date: 2018.06.14
                    Time: 00:47:37
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000141153
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: B02C4E11EB30E9C417-80E4
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650221735
   Voltage stabilizer:
   Serial number: 11119000773021200181
6656 - Control unit for battery monitoring
          U1050 00 [008] - No Communication
                    Reset counter: 118
                    Mileage: 117508 km
                    Date: 2018.06.14
                    Time: 00:48:38
                    Voltage terminal 30: 13.4 V
                    Voltage terminal 15: 13.4 V
                    Control Module temperature: 37 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Revision: AA001002
   Coding: 04018E64747464545425363E
   VCID: B326411D1226D2DC6A-80E6
Address 28: HVAC, Rear (E265)       Labels:| 4G0-919-158.clb
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 21041100040437
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: AF2E4D6DF60EF63C0E-80FA
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [008] - Signal Amplitude Too High
                    Reset counter: 118
                    Mileage: 117511 km
                    Date: 2018.06.14
                    Time: 06:25:40
                    Voltage terminal 30: 13.23 V
                    Outside air temperature: 38.5 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11701
                    Right Rear Upper Body Vent Motor-Specified value: 11701
                    Right Rear Upper Body Vent Motor-Stop open: 11400
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
0034 - Motor for Rear Right Upper Body Vent
          B10D4 21 [009] - Signal Amplitude Too Low
                    Fault Frequency: 7
                    Reset counter: 78
                    Mileage: 117508 km
                    Date: 2018.06.14
                    Time: 00:47:37
                    Voltage terminal 30: 12.14 V
                    Outside air temperature: 40.5 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 10000
                    Right Rear Upper Body Vent Motor-Specified value: 10000
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006121761
   Coding: 0058130000006001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200T4RH0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: AD125765FC02842C3C-80F8
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011F46225E00628002080002
   Shop #: WSC 02312 785 00200
   VCID: C0CC1ED153907944E7-8094
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0003070271
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: B2284419E53CDBD461-80E6
   Revision: 00002001    Serial number: 0148234488
   Coding: 0100062020B9B48083200A84080100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00000262308
   Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA101432000000272778
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
            000 -  -  - Intermittent
                    Reset counter: 118
                    Mileage: 117510 km
                    Date: 2018.06.14
                    Time: 01:36:06
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: BFCE1D2D2E6E06BC9E-80EA
   Revision: --------    Serial number: 00000000068671
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AA185C79CDEC9314D9-80FE
   Serial number: 110429-0004-094
   Coding: 1123A6601002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: AC145A61C7188D242B-80F8
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051DW0B7515854
   Coding: 010003020100000001
   VCID: 9F0EBDAD8EAE66BCBE-80CA
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 118
                    Mileage: 117508 km
                    Date: 2018.06.14
                    Time: 00:47:56
                    Bin. Bits: 00000000 00000001
   Part No SW: 4G0 035 666 B    HW: 4G0 035 666
   Component: H-BN-EU       H46 0239
   Revision: --------    Serial number: 426E40B7598078
   Coding: 090100040003E1ED45108B3E00000003E000010000000000
   VCID: A71EA54DD6FEAE7CC6-80F2
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Serial number: AUZ8ZDB1300PCR
   Subsystem 3 - Part No SW: 4G1 919 612 L    HW: 4G1 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDR000IC
   Component: CD-Database  2712
02612 - Audio Wire Adapter Set
                    Reset counter: 78
                    Mileage: 117508 km
                    Date: 2018.06.14
                    Time: 00:47:47
                    Voltage: 11.80 V
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F04224000628002080002
   VCID: C2C814D95D9C6B54F1-8096
   Part No SW: 4G8 959 107 D    HW: 4G8 959 107
   Component: HDSG-Modul    H12 0036
   Revision: 11012001    Serial number: 105100594
   Coding: 0A3205C000
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0210
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: EFAE8D6D368EB63C4E-80BA
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: F0AC8E112BB0A9C457-80A4
End----------(Elapsed Time: 02:25, VBatt start/end: 11.9V/12.0V)-----------
I do not think that fault code in the instrument cluster is for the fuel gauge or sender(s). I think it is SRI-channel related.
Please describe how the fuel gauge does "not show correctly". What does it show with tank full? What does it show with tank empty?
Have you looked at the measuring values for the tank sensor(s)? IDE03473...
ikara
Croatia
C?ID=302492
1ZA8W7176807926906Tuesday,24,July,2018,15:30:45:04922
Address 17: Instruments (4G8 920 930 P)
15:30:20
IDE03473-IDE00730 Fuel tank sens-Fuel level sensor 1 including soiling resistance 283 Ohm
IDE03473-IDE00731 Fuel tank sens-Fuel level sensor 2 including soiling resistance 253 Ohm
IDE03473-IDE00732 Fuel tank sens-Fuel level sensor 1 soiling resistance 1 Ohm
IDE03473-IDE00733 Fuel tank sens-Fuel level sensor 2 soiling resistance 2 Ohm
IDE03473-IDE03494 Fuel tank sens-Fuel level sensor 3 including soiling resistance 65535 Ohm
IDE03473-IDE03495 Fuel tank sens-Fuel level sensor 3 soiling resistance -32768 Ohm
IDE03473-IDE03496 Fuel tank sens-Fuel level sensor 4 including soiling resistance 65535 Ohm
IDE03473-IDE03497 Fuel tank sens-Fuel level sensor 4 soiling resistance -32768 Ohm
IDE03473-MAS03798 Fuel tank sens-Raw value sensor 1 resistor 1 579
IDE03473-MAS03799 Fuel tank sens-Raw value sensor 1 resistor 2 219
IDE03473-MAS03800 Fuel tank sens-Raw value sensor 2 resistor 1 553
IDE03473-MAS03801 Fuel tank sens-Raw value sensor 2 resistor 2 302
15:31:37
IDE03473-MAS03802 Fuel tank sens-Raw value sensor 3 resistor 1 65535
IDE03473-MAS03803 Fuel tank sens-Raw value sensor 3 resistor 2 65535
IDE03473-MAS03804 Fuel tank sens-Raw value sensor 4 resistor 1 65535
IDE03473-MAS03805 Fuel tank sens-Raw value sensor 4 resistor 2 65535
IDE03474-IDE00304 Calculated volume-Fuel level 0.0 l
IDE03474-IDE00306 Calculated volume-Fuel Level Sensor 1 282 Ohm
Dana
Western PA, USA
I agree with Uwe on that DTC in 17 meaning it appears to be service related. Was the Instrument cluster replaced? Were any Adaptation or Coding modifications related to that DTC or the fuel gauge problem?
Also, let us know what the gauge shows with tank full and tank empty.
Next, this vehicle uses 2 level senders so you can ignore sensor 3 and sensor 4 measuring values. After we have a clear picture of the fuel gauge functionality concern a complete set of control module maps from address 17 with a full tank of fuel while on level ground should help us determine which sender or sender wiring may be at fault.
http://www.ross-tech.com/vcds/tour/controller-channels-map.php
You can open those CSV files with Notepad and paste them in reply.
