Audi B5 S4 2001.5 - ABS module coding
rubirock
C?ID=331011
Hi all,
current autoscan w/ABS incorrectly coded ABS module:
Monday,16,July,2018,21:21:04:29127
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Mileage: 101887   Repair Order:
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 8D0 907 551 L
   Component: 2.7l V6/5VT     G   0001
   Coding: 06751
   Shop #: WSC 87119
   VCID: 3333E216E22274EFBC5-5161
16524 - Oxygen (Lambda) Sensor B1 S2
            P0140 - 35-00 - No Activity
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-00 - Open Circuit
17522 - Oxygen (Lambda) Sensor; B1 S2
            P1114 - 35-00 - Internal Resistance too High
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Readiness: 0010 0001
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8D0 927 156 DL
   Component: AG5 01V 2.7l5VT USA 1717
   Coding: 00032
   Shop #: WSC 63351
   VCID: 7AAD0F3285C845A73F3-5161
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 8D0 907 389 E
   Component: ABS/ESP allrad      D56
   Coding: 00000
   VCID: 3537DC0EEC566ADF921-5161
            66-10 - Not Matched - Intermittent
            35-00 -  -
Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
   Part No: 8D0 820 043 P
   Component: A4     KLIMAAUTOMAT D58
   Coding: 00160
   Shop #: WSC 63351
   VCID: 2D07F46E0406221FEA1-259F
Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
   Part No: 8D0 959 655 G
   Component: Airbag Front+Kopf  2002
   Coding: 00304
   Shop #: WSC 63351
   VCID: 3A2DCF32C54885A77F3-5161
Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
   Part No: 8D0 920 981 B
   Component: B5-KOMBIINSTR. VDO D12
   Coding: 00264
   Shop #: WSC 22172
   VCID: 2B03FA763A122C2FF45-5161
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00101
   Shop #: WSC 63351
   VCID: 60995D5A0354BF77117-4AA5
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
            35-00 -  -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
            35-00 -  -
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00012
   Shop #: WSC 63351
   VCID: 65974C4E1C76DA5FE21-5161
End----------(Elapsed Time: 03:24, VBatt start/end: 12.4V/12.4V)-----------
Address 01: DTCs cleared
The S4 has a mild stg1 tune (14psi peak) and a catback exhaust. Brakes are stock HP2s. battery connections & fuses are good, as is voltage.
The ABS & ESP lights have been coming on and every time I clear the codes the lights will return after about 10 miles of driving. I spoke to my tuner and he directed me to the ABS control module. I purchased another ABS control module out of another '01 S4 tiptronic (part #s identical, build date about a month prior to the one in my S4) hoping swapping them would solve the problem, but i haven't been able to get that one to work and neither of the modules will take coding or the workshop code.
Here are the coding & wsc from an earlier scan w/the original ABS module:
   Coding: 04397
   Shop #: WSC 06435
Then about two weeks ago i was driving the home in traffic and the brakes completely locked up. Luckily I was in slow traffic and was able to pull off the road. After having the engine was off for about an hour waiting for a tow, i started it up and the brakes were free again so i drove the mile or so home and parked it in the garage where it's been ever since. I started it up last night in a bid to calibrate the steering angle sensor to see if that would allow me to set the coding/wsc, but the brakes were completely locked up again.
This is a snapshot from group005 with my foot off the brakes
                Address 03: ABS Brakes  (8D0 907 389 E)
21:43:43 Group 005
  -12.5°  Steering Angle Sensor (G85)
  0.00°/s  Rotation Rate
  51.43 bar  Brake Pressure
  -0.19 m/s*2  Transverse Acceleration
When I login & attempt to set the coding/wsc, I will get a message in the coding field reading "ad D56". The D56 part i recognize from the ABS module (also on both ABS module stickers) but I haven't found an explanation yet, made a little harder b/c both "ad" & "D56" are too short a term to be used in the search.
Additionally, I'm wondering if there should be something else in the component field for the ABS module instead of "allrad". Asked my tuner about the issue but he just directed me to the ross-tech coding how-to.
I know that was a lot to read through and if you've stayed with me this far, THANKS! Anyone have any idea where to start on this one?
-Could I have two bad control modules?
-I read another thread for an S8 with an ABS issue and one of the suggestions was to fix the wheel speed sensor first in order to get the coding/wsc to stick, could that work for me as well?
-is there a way to relieve the brake pressure even if I haven't sorted the module? I'd like to at least be able to move the car out of the garage.
Any help is much appreciated,
Imran
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Excellent first post, just about all the info we need and CODE tagged. Welcome! :thumbs:
The "ad D56" is just spillover from what's displayed in the Component field in your screenshot. Part number "8D0 907 389 E" and Component field "ABS/ESP allrad D56" from your Auto-Scan got split into "ABS/ESP allr" followed by "ad D56". Allrad is short for AWD in German.
As for why it's displayed like that, that's an excellent question. I don't think the part number should be repeated in the Component field, and you should see your coding in the Soft Coding field instead of overflow. You're also not showing the workshop code. I wonder if that's a VCDS issue. My Phaeton with Bosch 5.7 doesn't show up like that, similar interface and VCDS release:
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008397
   Shop #: WSC 01065 000 00000
   VCID: EB9686C4CBD7F21C61-51A8
I don't have immediate access to a Bosch 5.3 vehicle right now to check if it behaves the same way. Yours is Bosch 5.3 and uses KW1281 instead of KW2000 so it's definitely possible for it to show different behavior than mine above. I'm not sure if this is a cosmetic-only problem, or if it could affect your ability to use VCDS to code the module. That would be a question for Ross-Tech. They might need some debug info.
Whenever odd problems with ABS/ESP crop up, we like to make sure you've got the right unit installed in your car, validated by VIN/PR-code lookup in the genuine VW spare parts database. You'd be astonished how many people get the wrong secondhand controllers installed and end up with inexplicable problems. You took the VIN out of your Auto-Scan above, so I can't check that for you. Would you be willing to provide the VIN in this thread? Or, if you can't do that, you PM it to me.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Additional followup:
Improbable, but possible.
Not seeing evidence of a wheel speed sensor in your scans or listed concerns. What brings a wheel speed sensor to mind for you?
That might be a thing. Some ABS/ESP units have a Basic Settings feature to run the ABS/ESP pump in Basic Settings to bleed it of air, but it's unclear if you have that feature available, or if that feature would actually release the existing line pressure you seem to have. Pop open Basic Settings and see what you see. Ultimately, you might have to (carefully! with hand and eye protection!) crack open the bleeder screw in each caliper. You observed 51 bar (740 PSI) of remaining pressure, that's to be respected.
rubirock
C?ID=331011
Thanks! glad to be here and definitely appreciative for the responses and help
Thank you! I was worried that the tune i'm using had a field incorrectly coded for an Allroad vs the S4 and that might cause a mismatch.
I luckily had the earlier scan that showed what the coding was before it became all zeros as it is now.
   Coding: 04397
   Shop #: WSC 06435
there are only the 5 digits available to enter in the WSC field (i believe, not the 13 digits as in your Phaeton/Bosch 5.7), and whenever I attempt to set the coding/WSC as above after logging in, i'll get either all zeros still or the aforementioned repeated part numbers.
Is there something I can do to facilitate that answer? Like figure out how to prepare the debug info and send an email to support@ross-tech? I can dig into this after work.
No problem, my VIN: WAURD68D01A125434
I have no doubt that part mismatches happen all the time. I found a local guy that was parting another 2001.5 (post "facelift") S4 and if I am not mistaken myself, the ABS control module part numbers are identical (I can verify over lunch in a couple hours) except for what i believe is the manufacture date portion of the sticker, which shows that the one I purchased is less than a month older than the one that was in my car.
I can email the guy to see if he has and old scan of the car saved some where in order to pull the WSC if you think that would be helpful.
Thank you, thank you, thank you again for the help. It is very much appreciated.
rubirock
C?ID=331011
you're correct, I was conflating wheel speed sensor (from previous unsuccessful attempts to diagnose the problem) with steering angle sensor that needs to be recalibrated after setting the soft coding/WSC is set.
There are three drop down options in the basic setting for the 5.3 version, one of which is to bleed the system. In my previous attempts to address the issue i have clicked on that & I can hear what sounds like a pump working for a second or two, but the brake pedal remains stuck as it is now. If I end up having to do it manually, I will make sure to take precautionary steps as noted!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
PartsLink24 shows 8D0 907 389 E to be legitimate for your ABS/ESP controller, post-VIN split in 2001.
I'm still really wondering how you managed to get in a hydraulically locked-up situation. Can we have you eyeball the hydraulic half of the ABS pump? Its part number won't show up in a scan, and it needs to be compatible with the controller. Not knowing the history of the car, I wonder if the a wrong/used one got in there at some point. It's happened before.
The VIN split makes this really confusing in PL24, but I think we want to see one of 8E0614111T, 8E0614111AA, 8E0614111AS, or 8E0614111AT.
I have to get back to work myself. I'll reply to the rest later tonight.
rubirock
C?ID=331011
As I understand it, Audi added ESP in the post-VIN split and consequently the parts changed for the ABS hydraulic unit. The control module that sits on top of the hydraulic unit failing in the the pre-VIN split models is a common problem, but that is less of a problem for my model b/c they moved the control module to under the rear bench and there are only solenoids attached to the hydraulic unit which rarely fail (according to module masters https://modulemaster.com/rebuilds/wp-content/plugins/WooCommerce-car-filter/include/product_filter.php?make=1&model=43&syear=345), but maybe that's the problem in my case, esp. considering the hydraulic lock up.
You and me both. I will reply with pics of the ABS module and both controllers shortly.
much appreciated.
Part No: 8D0 907 389 E<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< NEIN!
Coding: 00000
NostraJackAss Has Spoken!
"1AT"
Vehicle Identification No.WAURD68D01A125434
ModelAudi S4 qu. 2,7 A4Q
Date of production21.02.2001
Year2001
Sales type8D257Z
Engine CodeAPB
Transmission CodeFAQ
Axle drive5A
EquipmentAZ
Roof color5B
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components0DYInstallation differentiation for build status of vehicle class B5 (AUDI) -- powertrain components --
Emission standard0GLEmission standard TLEV
Trailer hitch1D0without trailer towing
airbag4UBAirbag for NAR
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Label for radio remote control7CAWithout label for radio remote control
Label for central electric0W2Label for central electric system English-speaking countries
Exterior mirror setting6XJExterior mirrors, auto-dimming, power-adjustable/heated
Left exterior mirror5SGLeft exterior mirror, flat
Right exterior mirror5RWRight exterior mirror, convex (US) large viewing field
Alternative drive system0K0Without alternative drive system
Drive type1X1Four-wheel drive
Outside temperature display9Y1Outside temperature display
Equipment levelsA8UExecutive US equipment
Brake type in rear1KEDisc brakes in rear
batteriesJ0RBattery 380 A (80 Ah)
Brake type, front1LXDisc brakes in front
Components with special surface6FCexterior mirror housing aluminum
Beverage holders4M6Beverage holders
Component part sets with country-specific design requirementsB0Abuild parts set without county specific documentatio
Brake systems1ATelectronic satbility programme -ESP-
Owner's manuals0VMInformation kit in American English
Heated door lock cylinder9X6Heated door lock cylinder left, with microswitch
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A1CD changer preparation
General operating permit, alterationsC00Operating permit, initial registration
Shock absorption/suspension, chassis1BDSuspension/shock absorption for special sports design
Roof rails/roof load rack3S0Without roof rails/roof load rack
Double DIN/dual-view display2T1Double-sized standard (DIN)
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Load-through hatch/ski bag3X1Load-through hatch with ski bag
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Theft protection system9V7Electronic immobilizer, with anti-theft alarm system and interior monitoring
Scuff plates7M2Scuff plates in door apertures with "S" emblem
Park distance control7X0Without park distance control
window regulator4R3Power windows with comfort operation
Color of dashboard/door and side trim panel6RADashboard and door trim panel one-piece, single color
Headlight activation8K0Without special driving light switching
Antifreeze1C2Antifreeze up to -35 degree celsius tolerance up to -40 degree C
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
throttle control0L2accelerator pedal with electronic modul
Alternators8GLAlternator 120 A
Transmission types/gearshift mechanisms0G7tiptronic
Transmission shafts, rear axle1YDTransmission shafts for rear axle, diameter 108
Transmission shafts1WDTransmission shaft for tripod joints
Weight category rear axle0YSWeight range 17 installation control only, no requirement forecast
Weight category front axle0JKWeight category front axle weight range 10
Base engineT7Z6-cyl. petrol engine 2.7 l assembly 078.8
Tie down straps/net/pocket6M1Tie down straps
cruise control system8T1Cruise control system (CCS)
Exterior noise suppression measures2B5additional noise dampener
Garage door openerVC1Garage door opener
Luggage compartment trim5A5Luggage compartment trim, with storage compartments
Transmission specificationsG0Q5-speed automatic transmission for four-wheel drive
handle for hand brake lever6PChandbrake lever grip (leather)
Rear trim panel6V2Rear trim panel
Rear spoiler5J0Without rear spoiler
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8JDHeadlight with gas discharge lamp for driving on the right (US design)
Customized installationFC0Without individual installation
Instrument clustersU1DInstrument insert w/ mph speedo, clock, tachometer, trip odometer and additional instruments (voltage, oil temperature)
Instrument panel4N0Standard dashboard (Leather trimmed minor gauges + Ipod drawer)
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body styleK8BNotchback
Cassette and CD storage unit4W0without cassette / CD tray
headrest for seat, rear3Q1headrest for seat, rear
Fuel quantity for initial filling1Z5Increase in initial standard fuel filling
Body measures5C1Body measures for increased safety requirements
Catalytic converter control8KBcatalyst-control
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K5Transportation protective film (instead of paint preservation)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
Lumbar support7P1Power adjustable lumbar support in front seats
steering wheels2ZPLeather-wrapped sports steering wheel for airbag system with tiptronic and S emblem
Speaker installation8RYloudspeaker with BOSE-sound
Headlight range control8Q2Automatic-static headlight range control
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q2Multi-function display/trip computer with check control
Engine cooling8Z6Engine cooling, version 2
Engine specificationsMH06-cylinder SI engine 2.7 l/187 kW (30V) base engine is T7Z
Right vanity mirror4TDVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TERear fog light for USA
Front fog lamp/additional headlamp8WCFront fog lamps
Rear of platform module base4P0Rear floor panel module, type 1
WheelsC7RAlloy wheels 7 1/2J x 17 Neo-Avus design, ET 45
Radios8YNRadio "symphony" for USA
Tire pressure monitoring system7K0Without tyre pressure monitor
tireH6GTires 225/45 ZR17 91Y
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G3Alloy spare wheel with original equipment tires
4SP
5MV
PAWall-weather package
PBSaudio package Symphony for USA
PCXcomfort package
WMMAlcantara/leather combination
Sill top/sill cover5E2Sill top with door cover
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Self-collection / special controlA00No self-collection
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E0Tailgate/trunk lid unlocking from outside
Bumper systems2K4Standard bumpers
Seat belt check9P1Seat belt reminder, electric contact in buckle
Center rear seat belts3C3Lap belt with retractor for the center rear seat
Gearshift boot/cover6R0Gearshift boot for automatic transmission
seat coversN7USeat trim covers in Alcantara® and pearl napa leather
Seat adjustment3L5Both front seats power-adjustable
seat heater4A3seat heating for front seats separat controlable
Safety certificate0LMWith special labels safety certificates for California
Control number (no PR family)SA3Directing no. for in-house assembly management
Audio-response system/voice controlQH0without voice control
Sunroof roller blind for rear/side windows3Y0without roller blind
Handling production and pre-productionFA0Control of standard production
Headlamp washer system8X1Headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
mud flaps6N0without mud flaps
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB34Legal requirements USA
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
TV reception/digital radio receptionQV0without TV/digital radio reception
Assembly parts for engine (drive bearing)1VHAssembly part for 6-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EPSpecial identification label (USA)
Type sign2Z1Type sign at rear and "Quattro" nameplates respectively
Delivery equipment2A4Delivery equipment for shipment (transit coating) with thick seat cover
First aid kit / warning triangle1T3First aid kit with warning triangle
Front seatsQ1DSports front seats
Telephone / telematics9W5Phone preparation
Windshield Glass4GPWindshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZFAnodized decorative trims
Additional child seat anchors3B2Child seat anchors acc. to Australian requirements
Additional dust seals6U0Without additional seals outside
Favorite BSG line.........
Four pyramids is a superior hand to someone holding three pyramids!
Who is teaching who here? Cylon grammar slams Starbuck with the correct use of your language is Who is teaching whom!
Nein repair kit!
8E0-614-111AT Nein E! You have ESP
PART NUMBERDESCRIPTIONMGSGILL. NO.
8E0 614 111 EABS unit
for vehicles with electronic
differential lock -edl-
614614-011
8E0 614 111 ATABS unit
For vehicles with electronic
stabilisation program -ESP-
to use for:
614614-011
8E0 998 375repair set
Control unit for ABS
to use for:
927927-000
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Part No: 8D0 907 389 E <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< <<<<<<<<<<<<<<<<<<< NEIN!
Nein repair kit!
"1AT"
I think you're looking at the wrong thing...
* The E-suffixed hydraulic+control complete assembly 8E0 614 111 E (which would indeed be wrong, current part is 8E0 614 111 AT with older superseded variants as I laid out earlier).
* The E-suffixed control unit 8D0 907 389 E (which is what's in the scan, and probably okay for his ESP car, but see below)
Normally PL24 tells you exactly which components belong, by PR code, but PL24 makes a total hash of representing which equipment is right for OP's car. I had to dig around a bit when I was looking earlier. Looks like maybe ETKA does better.
In retrospect, OP's comments about the hydraulics and electronics being physically separated in a mid-year change does illuminate the situation a bit. No "repair kit" for the 8E0 614 111 AT assembly now makes more sense, since it's now a fully separate module.
That said, PL24 makes it very unclear which of the three listed ESP control modules are definitely correct. All three are listed under 927-000-15 for the physically separated control module instead of (1) for the repair kit, PL24 grays out none of the invalid matches as it should, none of them list PR codes, and the two with VIN splits don't match his VIN characters.
I saw no compelling evidence that 8D0 907 389 E is wrong, other than no match on the VIN split, and apparently it's what his car and at least one more came with. If no match on the VIN split is meaningful here, it's possible he needs 4B0 907 389 instead of what he's got. Perhaps you could look to see what ETKA says?
OP states.........
Yes Jason indeed you are correct but both of you ref you are showing is for the ABS pump/controller in your picture or wording not the actual ESP controller...........until now you are... :)
http://forums.ross-tech.com/showthr...-module-coding&p=135146&viewfull=1#post135146
The ABS controller and ESP module are two separate modules......... :rolleyes:
FYI based on VIN break the A is the correct ESP module not the E
8D0-907-389A
ABCDEFGHIJKLMNOPQRSTUVWXYZ
Double FOD!
Excuse me?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
OP states.........
Yes Jason indeed you are correct but both of you ref you are showing the ABS pump/controller in your picture or wording not the actual ESP controller...........
I wasn't aware that they were physically separated on this model-year (or any other Bosch 5.3) so that was educational. Rest of it still stands though, whether the electronics-to-hydraulics distance is 1.5 meters or 0.0 meters. Need to make sure they're both a compatible match and correct for the car.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
X is before Y if I remember correctly....... :rolleyes:
True, but neither "X" nor "Y" are a "1":
WAURD68D01A125434
So neither >>8D-X-400000 nor >>8D-Y-000001 match, unless my education is incomplete in the matter of interpreting mid-year VIN splits, which is certainly possible. Feel free to educate me.
WAURD68D01A125434
So neither >>8D-X-400000 and >>8D-Y-000001 match, unless my education is incomplete in the matter of interpreting VIN splits, which I am certainly willing to discuss.
Dam I need reading glasses.............that's it, it's time........ :rolleyes:
You're okay Jason
rubirock
C?ID=331011
Apologies for the misnomers, here are the pics:
Both controllers (?), the one plugged in is the original and the other is the recently purchased one.
Hydraulic unit
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
You're okay Jason
On further reflection, that X/Y may be their only way to express a mid-year split where they restarted the VIN numbers from zero. That "1" reflects the model year, so they obviously can't change that part mid-year. So you might be onto something with that X before Y. ;)
I seriously hate all mid-year facelifts and VIN splits.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Thanks! 8E0 614 111 T is definitely valid for your car.
so if I'm reading the above correctly, I should be replacing the smaller ESP controller-module-thingy (technical term) instead of the ABS controller....AND FODing
I think (Jack, feel free to jump in) we've concluded that 8D0 907 389 E is valid for your car as well. But seriously, screw VIN splits. :banghead:
I'll reply to the rest of your earlier questions later tonight.
FUN STUFF HUH?
X = >1999
Y = >2000
01 = >2001
Everything says to me because 2.7T APB I would be looking at the 4B0-907-389 but maybe we should go check other 2001 auto-scan's on the web & because data on the Etka and the Link are kind of shitty in this quadrant.
We should be investigating the virtual further......... start finding scans guys.
Be back later........
